Çözüldü Assassin's Creed IV: Black Flag açılmıyor
6447
30 Nisan 2024
İyi günler. Steam üzerinden Assassin's Creed IV: Black Flag oynamak istiyorum ama oyun tepki vermiyor. Steam üzerinde oyuna girmişim gibi gösteriyor sonra açılmıyor.
Denediğim yöntemler dosya doğrulaması yapmak oyunu silip baştan yüklemek bu iki çözümde işe yaramadı.
Bunu sil:
C:\Windows\SysWOW64\D3DX9_43.dll
Bunu kur:
Kod:
21:11:22,0897616    AC4BFSP.exe    12996    CreateFile    C:\Windows\SysWOW64\wbem\d3dx9_43.dll    NAME NOT FOUND    Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
21:11:22,0897638    AC4BFSP.exe    12996    CreateFile    C:\Windows\SysWOW64\wbem\d3dx9_43.dll    NAME NOT FOUND    Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
21:11:22,0898109    AC4BFSP.exe    12996    CreateFileMapping    C:\Windows\SysWOW64\msvcp100.dll    SUCCESS    SyncType: SyncTypeOther
21:11:22,0898863    AC4BFSP.exe    12996    ReadFile    C:\Windows\SysWOW64\msvcr100.dll    SUCCESS    Offset: 54.272, Length: 32.768, I/O Flags: Non-cached, Paging I/O, Synchronous Paging I/O, Priority: Normal
21:11:22,0899129    AC4BFSP.exe    12996    Load Image    C:\Windows\SysWOW64\msvcp100.dll    SUCCESS    Image Base: 0x6dc10000, Image Size: 0x69000
21:11:22,0899474    AC4BFSP.exe    12996    ReadFile    C:\Windows\SysWOW64\msvcp100.dll    SUCCESS    Offset: 381.440, Length: 11.264, I/O Flags: Non-cached, Paging I/O, Synchronous Paging I/O, Priority: Normal
21:11:22,0900883    AC4BFSP.exe    12996    CreateFile    C:\Windows\SysWOW64\WindowsPowerShell\v1.0\d3dx9_43.dll    NAME NOT FOUND    Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
21:11:22,0901016    AC4BFSP.exe    12996    CreateFile    C:\Windows\SysWOW64\WindowsPowerShell\v1.0\d3dx9_43.dll    NAME NOT FOUND    Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
21:11:22,0903282    AC4BFSP.exe    12996    CreateFile    C:\Windows\SysWOW64\OpenSSH\d3dx9_43.dll    PATH NOT FOUND    Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
21:11:22,0903437    AC4BFSP.exe    12996    CreateFile    C:\Windows\SysWOW64\OpenSSH\d3dx9_43.dll    PATH NOT FOUND    Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
21:11:22,0905736    AC4BFSP.exe    12996    CreateFile    C:\Program Files\Microsoft VS Code\bin\d3dx9_43.dll    NAME NOT FOUND    Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
21:11:22,0905965    AC4BFSP.exe    12996    CreateFile    C:\Program Files\Microsoft VS Code\bin\d3dx9_43.dll    NAME NOT FOUND    Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
21:11:22,0908596    AC4BFSP.exe    12996    CreateFile    C:\Program Files (x86)\dotnet\d3dx9_43.dll    NAME NOT FOUND    Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
21:11:22,0908709    AC4BFSP.exe    12996    CreateFile    C:\Program Files (x86)\dotnet\d3dx9_43.dll    NAME NOT FOUND    Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
21:11:22,0911722    AC4BFSP.exe    12996    CreateFile    C:\Program Files\dotnet\d3dx9_43.dll    NAME NOT FOUND    Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
21:11:22,0911730    AC4BFSP.exe    12996    CreateFile    C:\Program Files\dotnet\d3dx9_43.dll    NAME NOT FOUND    Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
21:11:22,0912203    AC4BFSP.exe    12996    ReadFile    C:\Windows\SysWOW64\msvcr100.dll    SUCCESS    Offset: 33.792, Length: 20.480, I/O Flags: Non-cached, Paging I/O, Synchronous Paging I/O, Priority: Normal
21:11:22,0914848    AC4BFSP.exe    12996    CreateFile    C:\Users\Can\AppData\Local\Microsoft\WindowsApps\d3dx9_43.dll    NAME NOT FOUND    Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
21:11:22,0915492    AC4BFSP.exe    12996    CreateFile    C:\Users\Can\AppData\Local\Microsoft\WindowsApps\d3dx9_43.dll    NAME NOT FOUND    Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
Rapor al:
Rapor alamıyorum çünkü hata çıkmıyor exe başlamadığı için rapor oluşturulmuyor.
Hadi ya, bilgisayarına bağlanıp ben rapor almayı deneyeyim mi bakalım rapor olaşcak mı oluşmayacak mı?
Rapor oluşması için hata çıkmasına gerek yok.
Tabii bağlanabilirsin ya da işlemleri ben yanlış yaptım en azından çözüm üretebilirim çünkü oyunu oynamak istiyorum.
Rapor aldım sanırım doğru yaptım.
Bunu sil:
Bunu kur:
Kod:
Teşekkürler sorun çözüldü.
