ASUS Vivobook S 15 DxDiag
Kod:
System Information
      Time of this report: 12/9/2024, 17:46:07
             Machine name: LAPTOP-3KRL8M00
               Machine Id: {2853F2A2-21A0-457B-A5B5-86E6F9084E14}
         Operating System: Windows 11 Home 64-bit (10.0, Build 26100) (26100.ge_release.240331-1435)
                 Language: Turkish (Regional Setting: Turkish)
      System Manufacturer: ASUSTeK COMPUTER INC.
             System Model: ASUS Vivobook S 15 S5507QA_S5507QA
                     BIOS: S5507QA.309 (type: UEFI)
                Processor: Snapdragon(R) X Plus - X1P42100 - Qualcomm(R) Oryon(TM) CPU (8 CPUs), ~3.4GHz
                   Memory: 16384MB RAM
      Available OS Memory: 15982MB RAM
                Page File: 5611MB used, 13315MB available
              Windows Dir: C:\WINDOWS
          DirectX Version: DirectX 12
      DX Setup Parameters: Not found
         User DPI Setting: 192 DPI (200 percent)
       System DPI Setting: 192 DPI (200 percent)
          DWM DPI Scaling: UnKnown
                 Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Not Supported
 DirectX Database Version: 1.6.3
   Auto Super Res Version: 1.0.6.0
       System Mux Support: Mux Support Inactive - Ok
           Mux Target GPU: dGPU
           DxDiag Version: 10.00.26100.0712 64bit Unicode
DxDiag Notes
      Display Tab 1: No problems found.
        Sound Tab 1: No problems found.
          Input Tab: No problems found.
DirectX Debug Levels
Direct3D:    0/4 (retail)
DirectDraw:  0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay:  0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow:  0/6 (retail)
Display Devices
           Card name: Qualcomm(R) Adreno(TM) X1-45 GPU
        Manufacturer: Qualcomm Incorporated
           Chip type: Qualcomm(R) Adreno(TM) Graphics
            DAC type: InternalDAC
         Device Type: Full Device (POST)
          Device Key: Enum\ACPI\VEN_QCOM&DEV_0D17&SUBSYS_1FC31043&REV_0001
       Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
 Device Problem Code: No Problem
 Driver Problem Code: Unknown
      Display Memory: 8119 MB
    Dedicated Memory: 128 MB
       Shared Memory: 7991 MB
        Current Mode: 2880 x 1620 (32 bit) (120Hz)
         HDR Support: Supported
    Display Topology: Internal
 Display Color Space: DXGI_COLOR_SPACE_RGB_FULL_G22_NONE_P709
     Color Primaries: Red(0.679688,0.320312), Green(0.237305,0.722656), Blue(0.139648,0.049805), White Point(0.312500,0.329102)
   Display Luminance: Min Luminance = 0.004000, Max Luminance = 616.883972, MaxFullFrameLuminance = 400.000000
        Monitor Name: Generic PnP Monitor
       Monitor Model: unknown
          Monitor Id: SDC41B1
         Native Mode: 2880 x 1620(p) (120.002Hz)
         Output Type: Internal
Monitor Capabilities: HDR Supported (BT2020RGB Eotf2084Supported )
Display Pixel Format: DISPLAYCONFIG_PIXELFORMAT_32BPP
      Advanced Color: AdvancedColorSupported
      Using DDisplay: Yes
                 WCG: Wcg Not Supported
   Active Color Mode: DISPLAYCONFIG_ADVANCED_COLOR_MODE_SDR
         Driver Name: <>,C:\WINDOWS\System32\DriverStore\FileRepository\qcdx8380.inf_arm64_3cab1dfe836f6c02\qcdx11arm64xum.dll,C:\WINDOWS\System32\DriverStore\FileRepository\qcdx8380.inf_arm64_3cab1dfe836f6c02\qcdx11arm64xum.dll,C:\WINDOWS\System32\DriverStore\FileRepository\qcdx8380.inf_arm64_3cab1dfe836f6c02\qcdx12arm64xum.dll
 Driver File Version: 31.00.0067.0000 (English)
      Driver Version: 31.0.67.0
         DDI Version: 12
  Adapter Attributes: HARDWARE_TYPE_GPU,D3D11_GRAPHICS,D3D12_GRAPHICS,D3D12_CORE_COMPUTE,D3D12_GENERIC_ML,D3D12_GENERIC_MEDIA
      Feature Levels: 12_1,12_0,11_1,11_0,10_1,10_0,9_3,9_2,9_1,1_0_CORE
        Driver Model: WDDM 3.1
 Hardware Scheduling: DriverSupportState:AlwaysOff Enabled:False
         Displayable: Supported
 Graphics Preemption: DMA
  Compute Preemption: DMA
            Miracast: Not Supported by Graphics driver
      Detachable GPU: No
 Hybrid Graphics GPU: Integrated
     GPU Mux Support: None, Uninitialized - Unknown Error
      Power P-states: Not Supported
      Virtualization: Paravirtualization
          Block List: No Blocks
  Catalog Attributes: Universal:True Declarative:True
   Driver Attributes: Final Retail
    Driver Date/Size: 1.08.2024 03:00:00, 17755512 bytes
         WHQL Logo'd: n/a
     WHQL Date Stamp: n/a
   Device Identifier: {9AF84DB1-0770-26FE-8125-3013AEC2D235}
           Vendor ID: 0x4D4F4351
           Device ID: 0x37314430
           SubSys ID: 0x33343031
         Revision ID: 0x0001
  Driver Strong Name: oem112.inf:e1a2240eca87ceaa:QCDX_Inst_Base_111_Purwa.NT:31.0.67.0:ACPI\VEN_QCOM&DEV_0D17&REV_0001
      Rank Of Driver: 00D12000
         Video Accel:
         DXVA2 Modes: DXVA2_ModeH264_VLD_NoFGT  DXVA2_ModeHEVC_VLD_Main  DXVA2_ModeHEVC_VLD_Main10  DXVA2_ModeVP9_VLD_Profile0  DXVA2_ModeVP9_VLD_10bit_Profile2  {B8BE4CCB-CF53-46BA-8D59-D6B8A6DA5D2A}  {129F7B40-5C5B-48E5-8178-48C0CEA05A90}  {886348BD-B400-4378-A5AE-654ADC0947DC}  {4B3A8728-6585-4675-955E-D692AC71EE07}  {BDB6AC4F-8D9C-44F7-9731-52761C4924A9}
         D3D12 Encode Modes:
    Deinterlace Caps: {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                      {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBLineReplicate
                      {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                      {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBLineReplicate
                      {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                      {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBLineReplicate
                      {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                      {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBLineReplicate
                      {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,0x31434d49) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                      {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,0x31434d49) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBLineReplicate
                      {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,0x32434d49) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                      {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,0x32434d49) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBLineReplicate
                      {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,0x33434d49) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                      {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,0x33434d49) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBLineReplicate
                      {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,0x34434d49) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                      {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,0x34434d49) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBLineReplicate
                      {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,0x30343353) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                      {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,0x30343353) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBLineReplicate
                      {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,0x32343353) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                      {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,0x32343353) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBLineReplicate
        D3D9 Overlay: Not Supported
             DXVA-HD: Supported
        DDraw Status: Enabled
          D3D Status: Enabled
          AGP Status: Enabled
       MPO MaxPlanes: 9
            MPO Caps: VERTICAL_FLIP,HORIZONTAL_FLIP,RGB,YUV,STRETCH_YUV,STRETCH_RGB,HDR (MPO3)
         MPO Stretch: 20.000X - 0.250X
     MPO Media Hints: resizing, colorspace Conversion
         MPO Formats: NV12
                          YCBCR_STUDIO_G22_LEFT_P601
                          YCBCR_FULL_G22_LEFT_P601
                          YCBCR_STUDIO_G22_LEFT_P709
                          YCBCR_FULL_G22_LEFT_P709
                          YCBCR_STUDIO_G22_LEFT_P2020
                          YCBCR_FULL_G22_LEFT_P2020
                          YCBCR_STUDIO_G22_TOPLEFT_P2020
                      R8G8B8A8_UNORM
                          RGB_STUDIO_G22_NONE_P709
                          RGB_STUDIO_G22_NONE_P2020
                          RGB_FULL_G2084_NONE_P2020
                          RGB_STUDIO_G2084_NONE_P2020
                          RGB_FULL_G22_NONE_P2020
                          RGB_STUDIO_G24_NONE_P709
                          RGB_STUDIO_G24_NONE_P2020
                      B8G8R8A8_UNORM
    PanelFitter Caps: VERTICAL_FLIP,HORIZONTAL_FLIP,RGB,YUV,STRETCH_YUV,STRETCH_RGB,HDR (MPO3)
 PanelFitter Stretch: 20.000X - 0.250X
   Extension Drivers:
             Driver Name: C:\WINDOWS\System32\DriverStore\FileRepository\qcdxext_qcdpps8380.inf_arm64_86819d082c9ff825\qcdxext_qcdpps8380.inf
          Driver Version: 1.0.4085.5900
             Driver Date: 07/23/2024
         Driver Provider: Qualcomm Incorporated
      Catalog Attributes: Universal:False Declarative:True
             Driver Name: C:\WINDOWS\System32\DriverStore\FileRepository\qcdxext_crd8380.inf_arm64_f6d4feb7d13347e6\qcdxext_crd8380.inf
          Driver Version: 31.0.66.1
             Driver Date: 08/06/2024
   Component Drivers:
             Driver Name: Unknown
          Driver Version: Unknown
             Driver Date: Unknown
         Driver Provider: Unknown
      Catalog Attributes: N/A
MCDM Devices
            Device Name: Snapdragon(R) X Plus - X1P42100 - Qualcomm(R) Hexagon(TM) NPU
    Device Manufacturer: Qualcomm Technologies, Inc.
          Hardware Type: NPU
     Adapter Attributes: D3D12_Generic_ML
Direct3D Feature Levels: 1_0_GENERIC
           Engine Names: Compute
              Device ID: 0x41304430
           SubSystem ID: 0x00000000
            Revision ID: 0x0101
             Device Key: Enum\ACPI\QCOM0D0A
       Dedicated Memory: 0 MB
Dedicated System Memory: 0 MB
   Shared System Memory: 7991 MB
     Compute Preemption: DMA Buffer
            Driver Name: C:\WINDOWS\System32\DriverStore\FileRepository\qcnspmcdm8380.inf_arm64_8704c790d003662a\qcnspdx12arm64xum.dll,C:\WINDOWS\System32\DriverStore\FileRepository\qcnspmcdm8380.inf_arm64_8704c790d003662a\qcnspdx12arm64xum.dll,C:\WINDOWS\System32\DriverStore\FileRepository\qcnspmcdm8380.inf_arm64_8704c790d003662a\qcnspdx12arm64xum.dll,C:\WINDOWS\System32\DriverStore\FileRepository\qcnspmcdm8380.inf_arm64_8704c790d003662a\qcnspdx12arm64xum.dll
         Driver Version: 30.0.31.250
    Driver File Version: 30.00.0031.0250
   Driver Model Version: MCDM 3.0
       Driver File Size: 6514384 bytes
         Rank of Driver: 00FF0000
Driver Node Strong Name: oem127.inf:d051a865540dbee6:NSPMCDM_Device8A.NT:30.0.31.250:ACPI\VEN_QCOM&DEV_0D0A&REV_0101
            Driver Date: 8/6/2024 03:00:00
        Driver Language:  ngilizce
            Driver Beta: Final
           Driver Debug: No
          Driver Signed: Yes
    Driver Signed Valid: Yes
               Hardware: Yes
             Detachable: No
Sound Devices
            Description: Hoparl r (Qualcomm(R) Aqstic(TM) Audio Adapter Device)
 Default Sound Playback: Yes
 Default Voice Playback: Yes
            Hardware ID: AUCD\VEN_QCOM&DEV_0C29&SUBSYS_1FC31043
        Manufacturer ID: N/A
             Product ID: N/A
                   Type: N/A
            Driver Name: qcaudminiport8380.sys
         Driver Version: 1.0.4095.9100 (English)
            WHQL Logo'd: n/a
          Date and Size: 1.08.2024 03:00:00, 703080 bytes
            Other Files:
        Driver Provider: Qualcomm Technologies, Inc.
         HW Accel Level: Emulation Only
              Cap Flags: 0x0
    Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
 Static/Strm HW 3D Bufs: 0, 0
              HW Memory: 0
       Voice Management: No
 EAX(tm) 2.0 Listen/Src: No, No
   I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Sound Capture Devices
            Description: Mikrofon Dizisi (Qualcomm(R) Aqstic(TM) ACX Static Endpoints Audio Device)
  Default Sound Capture: Yes
  Default Voice Capture: Yes
            Driver Name: qcasd8380.sys
         Driver Version: 1.0.4085.5900 (English)
          Date and Size: 23.07.2024 03:00:00, 435408 bytes
              Cap Flags: 0x0
           Format Flags: 0x0
Video Capture Devices
Number of Devices: 3
           FriendlyName: ASUS FHD webcam
               Category: Camera
           SymbolicLink: \\?\display#qcom_avstream_8380#3&3a94f9b9&1&uid32768#{e5323777-f976-4f5b-9b55-b94699c46e44}\{4faeafd4-041b-4e46-85fd-400473891182}
               Rotation: 0
      SensorOrientation: 0
             HardwareID: VIDEO\VEN_4D4F4351&DEV_37314430&SUBSYS_3334303133434631&REV_01&QCOM_AVStream_8380,VIDEO\VEN_4D4F4351&DEV_37314430&SUBSYS_3334303133434631&QCOM_AVStream_8380,VIDEO\VEN_4D4F4351&DEV_37314430&QCOM_AVStream_8380,VIDEO\QCOM_AVStream_8380
             DriverDesc: Qualcomm(R) Spectra(TM) 695 ISP Camera AVStream Device
         DriverProvider: Qualcomm
          DriverVersion: 4606.637.0.0
      DriverDateEnglish: 8/1/2024 00:00:00
    DriverDateLocalized: 1.08.2024 00:00:00
                Service: QCCamAvs
                  Class: Camera
          DevNodeStatus: 180200A[DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
            ContainerId: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}
            ProblemCode: No Problem
  BusReportedDeviceDesc: Qualcomm Camera AVStream Mini Driver
                 Parent: ACPI\VEN_QCOM&DEV_0D17&SUBSYS_1FC31043&REV_0001\0
      DriverProblemDesc: n/a
           UpperFilters: n/a
           LowerFilters: n/a
                  Stack: \Driver\ksthunk,\Driver\QCCamAvs,\Driver\ACPI,\Driver\QCDX
      ContainerCategory: n/a
          SensorGroupID: {466E96E6-4C7A-4FAF-83F2-7E584B192DB4}
                   MFT0: n/a
                   DMFT: {4C2331F0-66BE-4177-9841-2FCBA8CCF5CA}
    CustomCaptureSource: n/a
  DependentStillCapture: n/a
     EnablePlatformDMFT: n/a
              DMFTChain: n/a
 EnableDshowRedirection: n/a
     FrameServerEnabled: n/a
             MEPOptedIn: True
             MEPVersion: 2.0.8.0
         MEPHighResMode: n/a
        AnalogProviders: n/a
        CompanionAppPfn: n/a
         MSXUCapability: n/a
            Fingerprint: 4606.637.0.0;01DAE3A5C0868000;1;4;0;0000000000000000;33F08445F62E4CE0;
             ProfileIDs: {6B52B017-42C7-4A21-BFE3-23F009149887},1000;{6B52B017-42C7-4A21-BFE3-23F009149887},2000;{81361B22-700B-4546-A2D4-C52E907BFC27},3000;{32440725-961B-4CA3-B5B2-854E719D9E1B},1000;{32440725-961B-4CA3-B5B2-854E719D9E1B},2000;{B4894D81-62B7-4EEC-8740-80658C4A9D3E},0;{C5444A88-E1BF-4597-B2DD-9E1EAD864BB8},2000;{C5444A88-E1BF-4597-B2DD-9E1EAD864BB8},50;{A0E517E8-8F8C-4F6F-9A57-46FC2F647EC0},1000;{A0E517E8-8F8C-4F6F-9A57-46FC2F647EC0},2000;{E4ED96D9-CD40-412F-B20A-B7402A43DCD2},0
           FriendlyName: ASUS Auxiliary Camera
               Category: Sensor
           SymbolicLink: \\?\display#qcom_avstream_8380#3&3a94f9b9&1&uid32768#{24e552d7-6523-47f7-a647-d3465bf1f5ca}\{193f2acd-143d-4440-a3c4-0a2b8e5539e0}
               Rotation: 0
                Service: QCCamAvs
                  Class: Camera
           UpperFilters: n/a
           LowerFilters: n/a
                   MFT0: n/a
              DMFTChain: n/a
             MEPOptedIn: n/a
             MEPVersion: 2.0.8.0
         MEPHighResMode: n/a
         MSXUCapability: n/a
             ProfileIDs: {81361B22-700B-4546-A2D4-C52E907BFC27},3000;{B4894D81-62B7-4EEC-8740-80658C4A9D3E},0
           FriendlyName: AvStream Media Device
               Category: Sensor Group
           SymbolicLink: \\?\swd#sgdevapi#be6408082c3176f06f1d7ccaa47a0aebedb8d49f87a3c9b79dea09ba0051ce2a#{669c7214-0a88-4311-a7f3-4e79820e33bd}\be6408082c3176f06f1d7ccaa47a0aebedb8d49f87a3c9b79dea09ba0051ce2a
    DeviceSymbolicLinks: \\?\DISPLAY#QCOM_AVStream_8380#3&3a94f9b9&1&UID32768#{e5323777-f976-4f5b-9b55-b94699c46e44}\{4FAEAFD4-041B-4E46-85FD-400473891182},\\?\DISPLAY#QCOM_AVStream_8380#3&3a94f9b9&1&UID32768#{24e552d7-6523-47f7-a647-d3465bf1f5ca}\{193F2ACD-143D-4440-A3C4-0A2B8E5539E0}
             ProfileIDs: {6B52B017-42C7-4A21-BFE3-23F009149887},1000;{6B52B017-42C7-4A21-BFE3-23F009149887},2000;{81361B22-700B-4546-A2D4-C52E907BFC27},3000;{32440725-961B-4CA3-B5B2-854E719D9E1B},1000;{32440725-961B-4CA3-B5B2-854E719D9E1B},2000;{B4894D81-62B7-4EEC-8740-80658C4A9D3E},0;{02399D9D-4EE8-49BA-BC07-5FF156531413},1000;{02399D9D-4EE8-49BA-BC07-5FF156531413},2000;{C5444A88-E1BF-4597-B2DD-9E1EAD864BB8},2000;{C5444A88-E1BF-4597-B2DD-9E1EAD864BB8},50;{A0E517E8-8F8C-4F6F-9A57-46FC2F647EC0},1000;{A0E517E8-8F8C-4F6F-9A57-46FC2F647EC0},2000
DirectInput Devices
      Device Name: Fare
         Attached: 1
    Controller ID: n/a
Vendor/Product ID: n/a
        FF Driver: n/a
      Device Name: Klavye
         Attached: 1
    Controller ID: n/a
        FF Driver: n/a
      Device Name: HIDI2C Device
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x0B05, 0x4543
        FF Driver: n/a
      Device Name: ASUS HID minidriver (KMDF version) Device
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x0B05, 0x7788
        FF Driver: n/a
      Device Name: Sanal HID  er evesi (VHF) HID ayg t
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
      Device Name: D n  t r lm   Ta  nabilir Cihaz Denetimi cihaz
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x045E, 0x0000
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x04F3, 0x32E2
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
      Device Name: HID D  mesi Kesme S r c s   zerinde
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
Gameport Devices
PS/2 Devices
+ HID Klavye Ayg t
| Vendor/Product ID: 0x0B05, 0x0000
| Matching Device ID: HID_DEVICE_SYSTEM_KEYBOARD
| Service: kbdhid
| Driver: kbdhid.sys, 4/1/2024 11:43:15, 55296 bytes
| Driver: kbdclass.sys, 4/1/2024 11:43:23, 73632 bytes
+ ASUS Keyboard Feature
| Matching Device ID: HID\ASUH2024&Col02
| Lower Filters: AsusKeyboard
| Service: kbdhid
| Driver: AsusKeyboardFilter.sys, 4/24/2024 16:05:46, 77664 bytes
+ HID Klavye Ayg t
| Service: kbdhid
+ HID Klavye Ayg t
| Service: kbdhid
+ HID uyumlu fare
| Vendor/Product ID: 0x04F3, 0x0000
| Matching Device ID: HID_DEVICE_SYSTEM_MOUSE
| Service: mouhid
| Driver: mouhid.sys, 4/1/2024 11:43:15, 42496 bytes
| Driver: mouclass.sys, 4/1/2024 11:43:23, 70448 bytes
Disk & DVD/CD-ROM Drives
      Drive: C:
 Free Space: 326.6 GB
Total Space: 486.1 GB
File System: NTFS
      Model: SAMSUNG MZVL8512HELU-00BTW
      Drive: F:
 Free Space: 2189.4 GB
Total Space: 3815.4 GB
File System: exFAT
      Model: Micron CT4000X10PROSSD9 SCSI Disk Device
System Devices
     Name: PCI Express K k Ba lant  Noktas
Device ID: PCI\VEN_17CB&DEV_0111&SUBSYS_00000000&REV_00\3&2C8B7305&0&00
   Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 10.00.26100.0712 (Turkish), 6/25/2024 05:15:55, 599360 bytes
Device ID: PCI\VEN_17CB&DEV_0111&SUBSYS_00000000&REV_00\3&71811BB&0&00
     Name: Qualcomm FastConnect 7800 Wi-Fi 7 Dual Band Simultaneous (DBS) Network Adapter
Device ID: PCI\VEN_17CB&DEV_1107&SUBSYS_E0EF105B&REV_01\4&CDACDEC&0&0000
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\qcwlanhmt8380.inf_arm64_5f2a8769f0c2f7ae\qcwlanhmt8380.sys, 1.00.4085.5900 (English), 8/6/2024 12:13:06, 3724496 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\qcwlanhmt8380.inf_arm64_5f2a8769f0c2f7ae\wlanfw20.mbn, 8/6/2024 12:13:06, 6066240 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\qcwlanhmt8380.inf_arm64_5f2a8769f0c2f7ae\phy_ucode20.elf, 8/6/2024 12:13:06, 299660 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\qcwlanhmt8380.inf_arm64_5f2a8769f0c2f7ae\bdwlan.elf, 8/6/2024 12:13:06, 88792 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\qcwlanhmt8380.inf_arm64_5f2a8769f0c2f7ae\regdb.bin, 8/6/2024 12:13:06, 24278 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\qcwlanhmt8380.inf_arm64_5f2a8769f0c2f7ae\Data20.msc, 8/6/2024 12:13:06, 1504029 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\qcwlanhmt8380.inf_arm64_5f2a8769f0c2f7ae\qdss_trace_config_v1.cfg, 8/6/2024 12:13:06, 4912 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\qcwlanhmt8380.inf_arm64_5f2a8769f0c2f7ae\qdss_trace_config_v2.cfg, 8/6/2024 12:13:06, 5089 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\qcwlanhmt8380.inf_arm64_5f2a8769f0c2f7ae\bdwlan_wcn785x_2p0_ncm825.elf, 8/6/2024 12:13:06, 88792 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\qcwlanhmt8380.inf_arm64_5f2a8769f0c2f7ae\bdwlan_wcn785x_2p0_ncm825_QC_revB.elf, 8/6/2024 12:13:06, 88860 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\qcwlanhmt8380.inf_arm64_5f2a8769f0c2f7ae\bdwlan_wcn785x_2p0_ncm825_AS_S55_SA.elf, 8/6/2024 12:13:06, 88860 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\qcwlanhmt8380.inf_arm64_5f2a8769f0c2f7ae\bdwlan_wcn785x_2p0_ncm825_PZ36.elf, 8/6/2024 12:13:06, 88860 bytes
     Name: Standart NVM Express Denetleyicisi
Device ID: PCI\VEN_144D&DEV_A80D&SUBSYS_A801144D&REV_00\4&3606B996&0&0000
   Driver: C:\WINDOWS\system32\DRIVERS\stornvme.sys, 10.00.26100.1000 (English), 9/21/2024 05:02:11, 257456 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,10.00.26100.1150
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,10.00.26100.1150
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,10.00.26100.1150
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,10.00.26100.1150
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,10.00.26100.1150
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,10.00.26100.1150
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,10.00.26100.1150
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,10.00.26100.1150
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,10.00.26100.1150
DV Muxer,0x00400000,0,0,qdv.dll,10.00.26100.1150
Color Space Converter,0x00400001,1,1,quartz.dll,10.00.26100.1150
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.26100.0001
AVI Splitter,0x00600000,1,1,quartz.dll,10.00.26100.1150
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,10.00.26100.1150
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,10.00.26100.1150
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,10.00.26100.1150
StreamBufferSink,0x00200000,0,0,sbe.dll,10.00.26100.1150
MJPEG Decompressor,0x00600000,1,1,quartz.dll,10.00.26100.1150
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,10.00.26100.1150
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,10.00.26100.1150
SBE2FileScan,0x00200000,0,0,sbe.dll,10.00.26100.1150
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.26100.1150
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,10.00.26100.1150
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,10.00.26100.1150
DV Splitter,0x00600000,1,2,qdv.dll,10.00.26100.1150
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,10.00.26100.1150
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,10.00.26100.1150
ACM Wrapper,0x00600000,1,1,quartz.dll,10.00.26100.1150
Video Renderer,0x00800001,1,0,quartz.dll,10.00.26100.1150
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,10.00.26100.1150
Line 21 Decoder,0x00600000,1,1,,
Video Port Manager,0x00600000,2,1,quartz.dll,10.00.26100.1150
Video Renderer,0x00400000,1,0,quartz.dll,10.00.26100.1150
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.26100.0001
File writer,0x00200000,1,0,qcap.dll,10.00.26100.1150
DVD Navigator,0x00200000,0,3,qdvd.dll,10.00.26100.0268
Overlay Mixer2,0x00200000,1,1,,
AVI Draw,0x00600064,9,1,quartz.dll,10.00.26100.1150
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.26100.1150
DV Video Decoder,0x00800000,1,1,qdv.dll,10.00.26100.1150
SampleGrabber,0x00200000,1,1,qedit.dll,10.00.26100.1150
Null Renderer,0x00200000,1,0,qedit.dll,10.00.26100.1150
StreamBufferSource,0x00200000,0,0,sbe.dll,10.00.26100.1150
Smart Tee,0x00200000,1,2,qcap.dll,10.00.26100.1150
Overlay Mixer,0x00200000,0,0,,
AVI Decompressor,0x00600000,1,1,quartz.dll,10.00.26100.1150
AVI/WAV File Source,0x00400000,0,2,quartz.dll,10.00.26100.1150
Wave Parser,0x00400000,1,1,quartz.dll,10.00.26100.1150
MIDI Parser,0x00400000,1,1,quartz.dll,10.00.26100.1150
Multi-file Parser,0x00400000,1,1,quartz.dll,10.00.26100.1150
File stream renderer,0x00400000,1,1,quartz.dll,10.00.26100.1150
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,10.00.26100.1150
StreamBufferSink2,0x00200000,0,0,sbe.dll,10.00.26100.1150
AVI Mux,0x00200000,1,0,qcap.dll,10.00.26100.1150
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,10.00.26100.1150
File Source (Async.),0x00400000,0,1,quartz.dll,10.00.26100.1150
File Source (URL),0x00400000,0,1,quartz.dll,10.00.26100.1150
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,10.00.26100.1150
Enhanced Video Renderer,0x00200000,1,0,evr.dll,10.00.26100.1150
MPEG Video Decoder,0x40000001,1,1,quartz.dll,10.00.26100.1150
WDM Streaming Tee/Splitter Devices:
T/Al c dan-Al c ya D n  t r c ,0x00200000,1,1,ksproxy.ax,10.00.26100.1150
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,10.00.26100.1150
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,10.00.26100.0001
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,10.00.26100.0001
DV Video Encoder,0x00200000,0,0,qdv.dll,10.00.26100.1150
MJPEG Compressor,0x00200000,0,0,quartz.dll,10.00.26100.1150
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,10.00.26100.1150
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,10.00.26100.0001
IMA ADPCM,0x00200000,1,1,quartz.dll,10.00.26100.1150
Microsoft ADPCM,0x00200000,1,1,quartz.dll,10.00.26100.1150
GSM 6.10,0x00200000,1,1,quartz.dll,10.00.26100.1150
CCITT A-Law,0x00200000,1,1,quartz.dll,10.00.26100.1150
CCITT u-Law,0x00200000,1,1,quartz.dll,10.00.26100.1150
MPEG Layer-3,0x00200000,1,1,quartz.dll,10.00.26100.1150
Audio Capture Sources:
Mikrofon Dizisi (Qualcomm(R) Aqstic(TM) ACX Static Endpoints Audio Device),0x00200000,0,0,qcap.dll,10.00.26100.1150
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,10.00.26100.1150
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,10.00.26100.1150
WDM Streaming Capture Devices:
,0x00000000,0,0,,
,0x00000000,0,0,,
QCAUD Wave Microphone Headset,0x00200000,1,1,ksproxy.ax,10.00.26100.1150
ACX Microphone Array - Front,0x00000000,0,0,,
ASUS FHD webcam,0x00200000,0,4,ksproxy.ax,10.00.26100.1150
WDM Streaming Rendering Devices:
QCAUD Wave Speaker,0x00200000,2,2,ksproxy.ax,10.00.26100.1150
QCAUD Wave Speaker Headset,0x00200000,2,2,ksproxy.ax,10.00.26100.1150
,0x00000000,0,0,,
,0x00000000,0,0,,
Video Capture Sources:
OBS Virtual Camera,0x00200000,0,1,obs-virtualcam-module64.dll,30.02.0003.0000
WDM Streaming Communication Transforms:
Audio Renderers:
Hoparl r (Qualcomm(R) Aqstic(TM) Audio Adapter Device),0x00200000,1,0,quartz.dll,10.00.26100.1150
Default DirectSound Device,0x00800000,1,0,quartz.dll,10.00.26100.1150
Default WaveOut Device,0x00200000,1,0,quartz.dll,10.00.26100.1150
DirectSound: Hoparl r (Qualcomm(R) Aqstic(TM) Audio Adapter Device),0x00200000,1,0,quartz.dll,10.00.26100.1150
Preferred DirectShow Filters
[HKEY_LOCAL_MACHINE\Software\Microsoft\DirectShow\Preferred]
<media subtype GUID>, [<filter friendly name>, ]<filter CLSID>
MEDIASUBTYPE_MPEG1Payload, MPEG Video Decoder, CLSID_CMpegVideoCodec
MEDIASUBTYPE_MPEG1Packet, MPEG Video Decoder, CLSID_CMpegVideoCodec
MEDIASUBTYPE_DVD_LPCM_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_VIDEO, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
{78766964-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_mp4s, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{6C737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64697678-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{64687664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{58564944-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{5634504D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_MP4S, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MJPG, MJPEG Decompressor, CLSID_MjpegDec
{44495658-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVA, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mpg4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_h264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_H264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_WMV3, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_MP43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMV2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS2, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_M4S2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WVP2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_WMV1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS1, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_WVC1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_AVC1, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
{20637664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
MEDIASUBTYPE_MPEG_LOAS, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG_ADTS_AAC, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_WMAUDIO_LOSSLESS, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_WMAUDIO3, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
WMMEDIASUBTYPE_WMAudioV8, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
WMMEDIASUBTYPE_MP3, MP3 Decoder DMO, CLSID_CMP3DecMediaObject
MEDIASUBTYPE_MPEG1AudioPayload, MPEG Audio Decoder, CLSID_CMpegAudioCodec
WMMEDIASUBTYPE_WMSP2, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
WMMEDIASUBTYPE_WMSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
Media Foundation File Versions
  mfcore.dll, 10.00.26100.1150
  mfreadwrite.dll, 10.00.26100.0001
  mfcaptureengine.dll, 10.00.26100.1150
  mfsensorgroup.dll, 10.00.26100.0001
  windows.media.dll, 10.00.26100.1150
  frameserver.dll, 10.00.26100.1000
  frameserverclient.dll, 10.00.26100.1150
Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms]
<category>:
  <transform friendly name>, <transform CLSID>, <flags>, [<merit>, ]<file name>, <file version>
Video Decoders:
  Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}, 0x1, msmpeg2vdec.dll, 10.00.26100.1150
  Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT, 0x1, mp4sdecd.dll, 10.00.26100.1150
  Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT, 0x1, msmpeg2vdec.dll, 10.00.26100.1150
  WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject, 0x1, wmvsdecd.dll, 10.00.26100.1150
  WMVideo Decoder MFT, CLSID_CWMVDecMediaObject, 0x1, wmvdecod.dll, 10.00.26100.1150
  MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}, 0x1, mfmjpegdec.dll, 10.00.26100.1150
  Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject, 0x1, mp43decd.dll, 10.00.26100.1150
  Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject, 0x1, mpg4decd.dll, 10.00.26100.1150
  HEVCVideoExtension
  HEIFImageExtension
  RawImageExtension
  VP9VideoExtensionDecoder
  WebpImageExtension
Video Encoders:
  QCOM Hardware Encoder - AV1, {0705AB91-0EC9-4D51-90E2-00C3360F41C4}, 0x4, 7, qcvidencarm64xmftAV18380.dll, 11.18.4000.0006
  QCOM Hardware Encoder - HEVC, {5AAFFE75-4EA4-424C-89E3-4A1E3F9A570D}, 0x4, 7, qcvidencarm64xmfthevc8380.dll, 11.18.4000.0006
  QCOM Hardware Encoder - H264, {7790EE16-08E3-426D-AADA-F96774308EA1}, 0x4, 7, qcvidencarm64xmfth2648380.dll, 11.18.4000.0006
  H264 Encoder MFT, {6CA50344-051A-4DED-9779-A43305165E35}, 0x1, mfh264enc.dll, 10.00.26100.1150
  WMVideo8 Encoder MFT, CLSID_CWMVXEncMediaObject, 0x1, wmvxencd.dll, 10.00.26100.1150
  H263 Encoder MFT, {BC47FCFE-98A0-4F27-BB07-698AF24F2B38}, 0x1, mfh263enc.dll, 10.00.26100.1150
  WMVideo9 Encoder MFT, CLSID_CWMV9EncMediaObject, 0x1, wmvencod.dll, 10.00.26100.0001
  Microsoft MPEG-2 Video Encoder MFT, {E6335F02-80B7-4DC4-ADFA-DFE7210D20D5}, 0x2, msmpeg2enc.dll, 10.00.26100.1150
  HEVCVideoExtensionEncoder
  HEIFImageExtension
  VP9VideoExtensionEncoder
Video Effects:
  Frame Rate Converter, CLSID_CFrameRateConvertDmo, 0x1, mfvdsp.dll, 10.00.26100.1150
  Resizer MFT, CLSID_CResizerDMO, 0x1, vidreszr.dll, 10.00.26100.1150
  VideoStabilization MFT, {51571744-7FE4-4FF2-A498-2DC34FF74F1B}, 0x1, MSVideoDSP.dll, 10.00.26100.0001
  Color Control, CLSID_CColorControlDmo, 0x1, mfvdsp.dll, 10.00.26100.1150
  Color Converter MFT, CLSID_CColorConvertDMO, 0x1, colorcnv.dll, 10.00.26100.1150
Video Processor:
  Microsoft Video Processor MFT, {88753B26-5B24-49BD-B2E7-0C445C78C982}, 0x1, msvproc.dll, 10.00.26100.1150
Audio Decoders:
  Microsoft MpegH Decoder MFT, {134DEA6F-C2EB-4FA8-8281-356600A9814E}, 0x1, mfaudiocnv.dll, 10.00.26100.1150
  MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}, 0x1, MSAMRNBDecoder.dll, 10.00.26100.0001
  WMAudio Decoder MFT, CLSID_CWMADecMediaObject, 0x1, WMADMOD.DLL, 10.00.26100.1150
  Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT, 0x1, MSAudDecMFT.dll, 10.00.26100.1150
  A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}, 0x1, mfcore.dll, 10.00.26100.1150
  GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}, 0x1, mfcore.dll, 10.00.26100.1150
  WMAPro over S/PDIF MFT, CLSID_CWMAudioSpdTxDMO, 0x1, WMADMOD.DLL, 10.00.26100.1150
  Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}, 0x1, MSOpusDecoder.dll, 10.00.26100.1150
  Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}, 0x1, MSFlacDecoder.dll, 10.00.26100.1150
  Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}, 0x1, MSAudDecMFT.dll, 10.00.26100.1150
  WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject, 0x1, WMSPDMOD.DLL, 10.00.26100.1150
  G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}, 0x1, mfcore.dll, 10.00.26100.1150
  IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}, 0x1, mfcore.dll, 10.00.26100.1150
  Dolby AC-3 and E-AC-3 IEC-61937 converter MFT, {A7E6022F-F78F-4AA9-A49A-567A60332635}, 0x1, mfaudiocnv.dll, 10.00.26100.1150
  MP3 Decoder MFT, CLSID_CMP3DecMediaObject, 0x1, mp3dmod.dll, 10.00.26100.1150
  Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}, 0x1, MSAlacDecoder.dll, 10.00.26100.0001
  ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}, 0x1, mfcore.dll, 10.00.26100.1150
  Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}, 0x1, mfaudiocnv.dll, 10.00.26100.1150
  DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}, 0x1, mfaudiocnv.dll, 10.00.26100.1150
  Dolby Digital Plus Decoder MFT
Audio Encoders:
  LPCM DVD-Audio MFT, {068A8476-9229-4CC0-9D49-2FC699DCD30A}, 0x1, mfaudiocnv.dll, 10.00.26100.1150
  MP3 Encoder ACM Wrapper MFT, {11103421-354C-4CCA-A7A3-1AFF9A5B6701}, 0x1, mfcore.dll, 10.00.26100.1150
  Microsoft FLAC Audio Encoder MFT, {128509E9-C44E-45DC-95E9-C255B8F466A6}, 0x1, MSFlacEncoder.dll, 10.00.26100.1150
  WM Speech Encoder DMO, CLSID_CWMSPEncMediaObject2, 0x1, WMSPDMOE.DLL, 10.00.26100.1150
  MS AMRNB Encoder MFT, {2FAE8AFE-04A3-423A-A814-85DB454712B0}, 0x1, MSAMRNBEncoder.dll, 10.00.26100.0001
  Microsoft MPEG-2 Audio Encoder MFT, {46A4DD5C-73F8-4304-94DF-308F760974F4}, 0x1, msmpeg2enc.dll, 10.00.26100.1150
  WMAudio Encoder MFT, CLSID_CWMAEncMediaObject, 0x1, WMADMOE.DLL, 10.00.26100.0001
  Microsoft AAC Audio Encoder MFT, {93AF0C51-2275-45D2-A35B-F2BA21CAED00}, 0x1, mfAACEnc.dll, 10.00.26100.1150
  Microsoft ALAC Audio Encoder MFT, {9AB6A28C-748E-4B6A-BFFF-CC443B8E8FB4}, 0x1, MSAlacEncoder.dll, 10.00.26100.1150
Audio Effects:
  AEC, CLSID_CWMAudioAEC, 0x1, mfwmaaec.dll, 10.00.26100.1150
  Resampler MFT, CLSID_CResamplerMediaObject, 0x1, resampledmo.dll, 10.00.26100.1150
Multiplexers:
  Microsoft MPEG2 Multiplexer MFT, {AB300F71-01AB-46D2-AB6C-64906CB03258}, 0x2, mfmpeg2srcsnk.dll, 10.00.26100.1150
Others:
  Microsoft H264 Video Remux (MPEG2TSToMP4) MFT, {05A47EBB-8BF0-4CBF-AD2F-3B71D75866F5}, 0x1, msmpeg2vdec.dll, 10.00.26100.1150
Media Foundation Enabled Hardware Categories
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\HardwareMFT]
Media Foundation Byte Stream Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\ByteStreamHandlers]
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\Preferred]
<file ext. or MIME type>, <handler CLSID>, <brief description>[, Preferred]
.3g2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.ac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.adt, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.am?, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler
.amr, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler, Preferred
.asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
.dvr-ms, {65964407-A5D8-4060-85B0-1CCD63F768E2}, dvr-ms Byte Stream Handler, Preferred
.dvr-ms, {A8721937-E2FB-4D7A-A9EE-4EB08C890B6E}, MF SBE Source ByteStreamHandler
.ec3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
.m2t, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m2ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mk3d, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mka, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mks, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mkv, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mov, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp2v, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mpg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.nsc, {B084785C-DDE0-4D30-8CA8-05A373E185BE}, NSC Byte Stream Handler, Preferred
.sami, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.smi, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.tod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.uvu, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.vob, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
.weba, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
.webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
.wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wtv, {65964407-A5D8-4060-85B0-1CCD63F768E2}, WTV Byte Stream Handler, Preferred
audio/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/aacp, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/eac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
audio/L16, {3FFB3B8C-EB99-472B-8902-E1C1B05F07CF}, LPCM Byte Stream Handler, Preferred
audio/mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/MP4A-LATM, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/vnd.dlna.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/vnd.dolby.dd-raw, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
audio/webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
audio/x-aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/x-flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
audio/x-m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
audio/x-mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-ms-wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
audio/x-wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
video/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/vnd.dece.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/vnd.dlna.mpeg-tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
video/x-m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
video/x-ms-asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
Media Foundation Scheme Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\SchemeHandlers]
<URL type>, <handler CLSID>, <brief description>[, Preferred]
file:, {477EC299-1421-4BDD-971F-7CCB933F21AD}, File Scheme Handler, Preferred
http:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler
http:, {9EC4B4F9-3029-45AD-947B-344DE2A249E2}, Urlmon Scheme Handler
http:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpd:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler, Preferred
https:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpsd:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcast:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcrecv:, {FA6D33D4-9405-4BA5-9983-12604AC8E77A}, Miracast Sink Scheme Handler, Preferred
mms:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
ms-appdata:, {CFC81939-3886-4ACF-9692-DA58037AE716}, MsAppData Scheme Handler, Preferred
ms-appx-web:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppxWeb Scheme Handler, Preferred
ms-appx:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppx Scheme Handler, Preferred
ms-winsoundevent:, {F79A6BF9-7415-4CF3-AE10-4559509ABC3C}, Sound Event Scheme Handler, Preferred
rtsp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtsps:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
sdp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
Preferred Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\Preferred]
<media subtype GUID>, [<transform friendly name>, ]<transform CLSID>
{EB27CEC4-163E-4CA3-8B74-8E25F91B517E}, Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}
{E06D8033-DB46-11CF-B4D1-00805F6CBBEA}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
MFVideoFormat_MPEG2, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
{C2FE6F0A-4E3C-4DF1-9B60-50863091E4B9}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{A61AC364-AD0E-4744-89FF-213CE0DF8804}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{A2E58EB7-0FA9-48BB-A40C-FA0E156D0645}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{7C13C441-EBF8-4931-B678-800B19242236}, Microsoft MpegH Decoder MFT, {134DEA6F-C2EB-4FA8-8281-356600A9814E}
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{73616D72-767A-494D-B478-F29D25DC9037}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
MEDIASUBTYPE_mp4s, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{63616C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}
MFVideoFormat_MP4V, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_MP4S, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{53314356-0000-0010-8000-00AA00389B71}, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MJPG, MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}
MEDIASUBTYPE_WMVA, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{3F40F4F0-5622-4FF8-B6D8-A17A584BEE5E}, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MEDIASUBTYPE_mpg4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_H264, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MFVideoFormat_WMV3, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{33363248-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_mp43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MFVideoFormat_MP43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_WMV2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS2, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_M4S2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_WVP2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_WMV1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS1, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_MPG1, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MFVideoFormat_WVC1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{19EE97FE-1BE0-4255-A876-E99F53A42AE3}, Microsoft MpegH Decoder MFT, {134DEA6F-C2EB-4FA8-8281-356600A9814E}
{0000F1AC-0000-0010-8000-00AA00389B71}, Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}
{00007361-0000-0010-8000-00AA00389B71}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
{0000704F-0000-0010-8000-00AA00389B71}, Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}
{00006C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}
{00002001-0000-0010-8000-00AA00389B71}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
MFAudioFormat_AAC, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_ADTS, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_WMAudio_Lossless, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV9, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV8, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_MP3, MP3 Decoder MFT, CLSID_CMP3DecMediaObject
MFAudioFormat_MPEG, Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}
{00000031-0000-0010-8000-00AA00389B71}, GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}
{00000011-0000-0010-8000-00AA00389B71}, IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}
MFAudioFormat_MSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
KSDATAFORMAT_SUBTYPE_MULAW, G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}
{00000006-0000-0010-8000-00AA00389B71}, A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}
KSDATAFORMAT_SUBTYPE_ADPCM, ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}
Disabled Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\DoNotUse]
<transform CLSID>
Disabled Media Sources
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\DoNotUse]
<media source CLSID>
EVR Power Information
Current Setting: {651288E5-A7ED-4076-A96B-6CC62D848FE1} (Balanced)
  Quality Flags: 2576
    Enabled:
    Force throttling
    Allow half deinterlace
    Allow scaling
    Decode Power Usage: 100
  Balanced Flags: 1424
    Enabled:
    Force throttling
    Allow batching
    Force half deinterlace
    Force scaling
    Decode Power Usage: 50
  PowerFlags: 1424
    Enabled:
    Force throttling
    Allow batching
    Force scaling
    Decode Power Usage: 0
Geri
Yukarı Alt
