0: kd> !analyze -v
* Bugcheck Analysis *
KERNEL_SECURITY_CHECK_FAILURE (139)
A kernel component has corrupted a critical data structure. The corruption
could potentially allow a malicious user to gain control of this machine.
Arguments:
Arg1: 0000000000000002, Stack cookie instrumentation code detected a stack-based
buffer overrun.
Arg2: fffff8064ea8afa0, Address of the trap frame for the exception that caused the BugCheck
Arg3: fffff8064ea8aef8, Address of the exception record for the exception that caused the BugCheck
Arg4: 0000000000000000, Reserved
Debugging Details:
KEY_VALUES_STRING: 1
Key : Analysis.CPU.mSec
Value: 4000
Key : Analysis.Elapsed.mSec
Value: 4002
Key : Analysis.IO.Other.Mb
Value: 0
Key : Analysis.IO.Read.Mb
Value: 0
Key : Analysis.IO.Write.Mb
Value: 0
Key : Analysis.Init.CPU.mSec
Value: 812
Value: 22792
Value: 97
Key : Analysis.Version.DbgEng
Value: 10.0.27704.1001
Key : Analysis.Version.Description
Value: 10.2408.27.01 amd64fre
Key : Analysis.Version.Ext
Value: 1.2408.27.1
Key : Bugcheck.Code.LegacyAPI
Value: 0x139
Key : Bugcheck.Code.TargetModel
Value: 0x139
Key : Dump.Attributes.AsUlong
Value: 8
Key : Dump.Attributes.KernelGeneratedTriageDump
Value: 1
Key : FailFast.Name
Value: STACK_COOKIE_CHECK_FAILURE
Key : FailFast.Type
Value: 2
Key : Failure.Bucket
Value: 0x139_MISSING_GSFRAME_rt640x64!unknown_function
Key : Failure.Hash
Value: {2c7a6b39-0b08-f942-2b65-f44960d08147}
Key : Stack.Pointer
Value: PRCBException
BUGCHECK_CODE: 139
BUGCHECK_P1: 2
BUGCHECK_P2: fffff8064ea8afa0
BUGCHECK_P3: fffff8064ea8aef8
BUGCHECK_P4: 0
FILE_IN_CAB: 112524-3703-01.dmp
DUMP_FILE_ATTRIBUTES: 0x8
Kernel Generated Triage Dump
FAULTING_THREAD: fffff80649527a00
TRAP_FRAME: fffff8064ea8afa0 -- (.trap 0xfffff8064ea8afa0)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=fffff8064dd00000 rbx=0000000000000000 rcx=0000000000000002
rdx=0000000000000000 rsi=0000000000000000 rdi=0000000000000000
rip=fffff8064dd3d755 rsp=fffff8064ea8b138 rbp=fffff8064ea8b710
r8=0000000000000000 r9=fffff8064ea75740 r10=fffff8064ea75740
r11=0000000000000090 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei ng nz ac pe nc
ndis!_report_gsfailure+0x5:
fffff806`4dd3d755 cd29 int 29h
Resetting default scope
EXCEPTION_RECORD: fffff8064ea8aef8 -- (.exr 0xfffff8064ea8aef8)
ExceptionAddress: fffff8064dd3d755 (ndis!_report_gsfailure+0x0000000000000005)
ExceptionCode: c0000409 (Security check failure or stack buffer overrun)
ExceptionFlags: 00000001
NumberParameters: 1
Parameter[0]: 0000000000000002
Subcode: 0x2 FAST_FAIL_STACK_COOKIE_CHECK_FAILURE
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: System
ERROR_CODE: (NTSTATUS) 0xc0000409 - Sistem, bu uygulamada y n tabanl bir arabelle in ta t n alg lad . Bu ta ma, k t niyetli bir kullan c n n bu uygulaman n denetimini ele ge irmesine olanak verebilir.
EXCEPTION_CODE_STR: c0000409
EXCEPTION_PARAMETER1: 0000000000000002
EXCEPTION_STR: 0xc0000409
STACK_TEXT:
fffff806`4ea8ac78 fffff806`48c12da9 : 00000000`00000139 00000000`00000002 fffff806`4ea8afa0 fffff806`4ea8aef8 : nt!KeBugCheckEx
fffff806`4ea8ac80 fffff806`48c13350 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiBugCheckDispatch+0x69
fffff806`4ea8adc0 fffff806`48c111f2 : fffffb03`519175d8 fffff806`4ea8b7c0 fffff806`4ea8b210 ffffffff`c0000005 : nt!KiFastFailDispatch+0xd0
fffff806`4ea8afa0 fffff806`4dd3d755 : fffff806`4dd40496 fffff806`4ea8b710 fffff806`48aeebaf fffff806`4dde869c : nt!KiRaiseSecurityCheckFailure+0x332
fffff806`4ea8b138 fffff806`4dd40496 : fffff806`4ea8b710 fffff806`48aeebaf fffff806`4dde869c fffff806`00000000 : ndis!_report_gsfailure+0x5
fffff806`4ea8b140 fffff806`4dd4042b : fffff806`4ea8b210 00000000`00000000 fffff806`4ea8b748 fffff806`4ea8b720 : ndis!_GSHandlerCheckCommon+0x5a
fffff806`4ea8b170 fffff806`48c090c2 : fffff806`4dd40418 00000000`00000000 00000000`00000000 00000000`00000000 : ndis!_GSHandlerCheck+0x13
fffff806`4ea8b1a0 fffff806`48aee997 : fffff806`4ea8b710 00000000`00000000 fffff806`4ea75740 fffff806`4dd07776 : nt!RtlpExecuteHandlerForException+0x12
fffff806`4ea8b1d0 fffff806`48b39536 : fffff806`4ea74f68 fffff806`4ea8be20 fffff806`4ea74f68 ffffd08c`aa99b201 : nt!RtlDispatchException+0x297
fffff806`4ea8b8f0 fffff806`48bff6e2 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiDispatchException+0x186
fffff806`4ea8bfb0 fffff806`48bff6b0 : fffff806`48c12ee5 fffff806`4ea74f88 00000000`00000002 00000000`00000000 : nt!KxExceptionDispatchOnExceptionStack+0x12
fffff806`4ea74e28 fffff806`48c12ee5 : fffff806`4ea74f88 00000000`00000002 00000000`00000000 fffff806`48a9095d : nt!KiExceptionDispatchOnExceptionStackContinue
fffff806`4ea74e30 fffff806`48c0e2ef : ffffd08c`aaf31b70 00000000`00000000 00060080`01000000 00000000`00000000 : nt!KiExceptionDispatch+0x125
fffff806`4ea75010 fffff806`4dd13cef : ffffd08c`aa2fc981 00000000`00000003 ffffd08c`aaee3570 fffff806`4ea75300 : nt!KiGeneralProtectionFault+0x32f
fffff806`4ea751a0 fffff806`4dd021c9 : ffffd08c`aaf30000 ffffd08c`a6c55008 00000000`00000000 00000000`00000003 : ndis!ndisParseReceivedNBL+0x53
fffff806`4ea75200 fffff806`4dd01be1 : ffffd08c`00000000 00000000`00000008 ffffd08c`aa8b41a0 00000000`00000000 : ndis!ndisSortNetBufferLists+0xb9
fffff806`4ea75280 fffff806`4dd07de0 : ffffd08c`aa8b41a0 ffffd08c`aa99b701 ffffd08c`aa8b41a0 00000000`00000001 : ndis!ndisMTopReceiveNetBufferLists+0x141
fffff806`4ea75300 fffff806`4dd3ea4f : ffffd08c`aa99b780 fffff806`4ea753d1 00000000`00000000 fffff806`5c2aa1fd : ndis!ndisCallReceiveHandler+0x60
fffff806`4ea75350 fffff806`4dd04984 : 00000000`000014f7 00000000`00000001 ffffd08c`aa8b41a0 00000000`00000001 : ndis!ndisInvokeNextReceiveHandler+0x1df
fffff806`4ea75420 fffff806`5c25ae87 : ffffd08c`71370f7c ffffd08c`aa603000 ffffd08c`aa99b780 00000000`00000000 : ndis!NdisMIndicateReceiveNetBufferLists+0x104
fffff806`4ea754b0 ffffd08c`71370f7c : ffffd08c`aa603000 ffffd08c`aa99b780 00000000`00000000 0000004d`00000001 : rt640x64+0x1ae87
fffff806`4ea754b8 ffffd08c`aa603000 : ffffd08c`aa99b780 00000000`00000000 0000004d`00000001 00000000`00000000 : 0xffffd08c`71370f7c
fffff806`4ea754c0 ffffd08c`aa99b780 : 00000000`00000000 0000004d`00000001 00000000`00000000 00000003`4ea75500 : 0xffffd08c`aa603000
fffff806`4ea754c8 00000000`00000000 : 0000004d`00000001 00000000`00000000 00000003`4ea75500 ffff8000`00007501 : 0xffffd08c`aa99b780
SYMBOL_NAME: rt640x64+1ae87
MODULE_NAME: rt640x64
IMAGE_NAME: rt640x64.sys
STACK_COMMAND: .process /r /p 0xfffff80649524a00; .thread 0xfffff80649527a00 ; kb
BUCKET_ID_FUNC_OFFSET: 1ae87
FAILURE_BUCKET_ID: 0x139_MISSING_GSFRAME_rt640x64!unknown_function
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {2c7a6b39-0b08-f942-2b65-f44960d08147}
Followup: MachineOwner
3: kd> !analyze -v
MEMORY_MANAGEMENT (1a)
# Any other values for parameter 1 must be individually examined.
Arguments:
Arg1: 0000000000041791, The subtype of the BugCheck.
Arg2: ffffb5000bfdb760
Arg3: ffdfb95c80000040
Arg4: 0000000000010021
Debugging Details:
Value: 3562
Value: 3559
Value: 0
Value: 0
Value: 0
Value: 781
Value: 5729
Value: 91
Value: 1.2408.27.1
Value: 0x1a
Value: 0x1a
Value: 8
Value: 1
Value: 0x1a_41791_nt!MmUnlockPages
Key : Failure.Hash
Value: {257cd050-e4e1-a6f4-7c65-0c6aaef71f68}
BUGCHECK_CODE: 1a
BUGCHECK_P1: 41791
BUGCHECK_P2: ffffb5000bfdb760
BUGCHECK_P3: ffdfb95c80000040
BUGCHECK_P4: 10021
FILE_IN_CAB: 112524-5218-01.dmp
FAULTING_THREAD: ffff8c8c14d97040
BLACKBOXWINLOGON: 1
PROCESS_NAME: WmiPrvSE.exe
STACK_TEXT:
ffffb985`dd317438 fffff803`05473519 : 00000000`0000001a 00000000`00041791 ffffb500`0bfdb760 ffdfb95c`80000040 : nt!KeBugCheckEx
ffffb985`dd317440 fffff803`05829e26 : ffffb985`dd317680 00000000`00000103 ffffb985`00000002 00000000`00000000 : nt!MmUnlockPages+0xd89
ffffb985`dd317530 fffff803`05828b83 : 00000047`be7fc180 00000000`00000008 ffffb985`dd317768 00000000`00000004 : nt!MmCopyVirtualMemory+0x7d6
ffffb985`dd317980 fffff803`05828a1b : ffff8c8c`14d97040 00000047`be7fc168 00000047`be7fc230 00007ff9`f9db9510 : nt!MiReadWriteVirtualMemory+0x153
ffffb985`dd317a10 fffff803`05612508 : 00000245`fef02fd0 00007ff9`f9db9510 00000000`00000000 00007ff9`f9db45a0 : nt!NtReadVirtualMemory+0x1b
ffffb985`dd317a50 00007ffa`16acdcd4 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x28
00000047`be7fc148 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ffa`16acdcd4
SYMBOL_NAME: nt!MmUnlockPages+d89
MODULE_NAME: nt
IMAGE_VERSION: 10.0.19041.5129
STACK_COMMAND: .process /r /p 0xffff8c8c15432080; .thread 0xffff8c8c14d97040 ; kb
IMAGE_NAME: ntkrnlmp.exe
BUCKET_ID_FUNC_OFFSET: d89
FAILURE_BUCKET_ID: 0x1a_41791_nt!MmUnlockPages
OSNAME: Windows 10
FAILURE_ID_HASH: {257cd050-e4e1-a6f4-7c65-0c6aaef71f68}
Realtek Ethernet sürücünü kaldırıp tekrar kurabilir misin?
1. minidump dosyasında Realtek sürücüsüyle alakalı bir problem olduğu gözüküyor 2. minidump dosyası ntkrnlmp.exe ile ilgili.
BIOS'tan XMP kapatmayı deneyebilir misin?
Arguments:
buffer overrun.
Debugging Details:
Value: 1046
Value: 4822
Value: 3
Value: 1
Value: 23
Value: 421
Value: 16273
Value: 89
Value: 10.0.27725.1000
Value: 1.2408.27.1
Value: 0x139
Value: 0x139
Value: 8
Value: 1
Key : FailFast.Name
Key : FailFast.Type
Value: 2
Key : Failure.Hash
Key : Stack.Pointer
BUGCHECK_CODE: 139
BUGCHECK_P1: 2
BUGCHECK_P4: 0
NumberParameters: 1
BLACKBOXWINLOGON: 1
STACK_TEXT:
OSNAME: Windows 10
[SMBIOS Data Tables v3.3]
[DMI Version - 0]
[2.0 Calling Convention - No]
[Table Size - 2476 bytes]
Vendor American Megatrends Inc.
BIOS Version 3802
BIOS Release Date 04/28/2022
BIOS ROM Size 1000000
BIOS Characteristics
07: - PCI Supported
10: - APM Supported
11: - Upgradeable FLASH BIOS
15: - CD-Boot Supported
17: - BIOS ROM Socketed
19: - EDD Supported
23: - 1.2MB Floppy Supported
24: - 720KB Floppy Supported
25: - 2.88MB Floppy Supported
27: - Keyboard Services Supported
32: - BIOS Vendor Reserved
00: - ACPI Supported
01: - USB Legacy Supported
BIOS Major Revision 5
BIOS Minor Revision 17
EC Firmware Major Revision 255
EC Firmware Minor Revision 255
Extended BIOS ROM Size 16 MB
Manufacturer ASUS
Product Name System Product Name
Version System Version
Serial Number System Serial Number
UUID 00000000-0000-0000-0000-000000000000
Wakeup Type Power Switch
SKUNumber SKU
Family To be filled by O.E.M.
Manufacturer ASUSTeK COMPUTER INC.
Product PRIME B450M-K II
Version Rev X.0x
Serial Number 201278998600951
Asset Tag
Feature Flags 09h
00: - Motherboard
03: - Replaceable
Location Default string
Chassis Handle 0003h
Board Type 0ah - Processor/Memory Module
Number of Child Handles 0
Manufacturer Default string
Chassis Type Desktop
Version Default string
Serial Number
Asset Tag Number
Bootup State Safe
Power Supply State Safe
Thermal State Safe
Security Status None
OEM Defined 0
Height 0U
Number of Power Cords 1
Number of Contained Elements 0
Contained Element Size 3
[Onboard Devices Information (Type 10) - Length 6 - Handle 001eh]
Note: The On Board Device Information (Type 10) struct is obsolete as of SMBIOs spec v2.6 Number of Devices 1
01: Type Video [enabled]
01: Description To Be Filled By O.E.M.
[OEM Strings (Type 11) - Length 5 - Handle 001fh]
Number of Strings 8
1 Default string
2 Default string
3 Default string
4 Default string
5 Default string
6 Default string
7 Default string
8 Default string
[System Configuration Options (Type 12) - Length 5 - Handle 0020h]
[ (Type 256) - Length 50 - Handle 0023h]
[ (Type 256) - Length 11 - Handle 0024h]
[ (Type 256) - Length 9 - Handle 0025h]
[ (Type 256) - Length 31 - Handle 0026h]
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 0027h]
[Physical Memory Array (Type 16) - Length 23 - Handle 0028h]
Location 03h - SystemBoard/Motherboard
Use 03h - System Memory
Memory Error Correction 03h - None
Maximum Capacity 134217728KB
Memory Error Inf Handle 0027h
Number of Memory Devices 2
[Memory Array Mapped Address (Type 19) - Length 31 - Handle 0029h]
Starting Address 00000000h
Ending Address 0033ffffh
Memory Array Handle 0028h
Partition Width 02
Extended Starting Address 0000000000000000h
Extended Ending Address 0000000000000000h
[Memory Array Mapped Address (Type 19) - Length 31 - Handle 002ah]
Starting Address 00400000h
Ending Address 010bffffh
Partition Width 02
[Cache Information (Type 7) - Length 27 - Handle 002bh]
Socket Designation L1 - Cache
Cache Configuration 0180h - WBEnabled Int NonSocketed L1
Maximum Cache Size 0180h - 384K
Installed Size 0180h - 384K
Supported SRAM Type 0010h - Pipeline-Burst
Current SRAM Type 0010h - Pipeline-Burst
Cache Speed 1ns
Error Correction Type Specification Reserved
System Cache Type Unified
Associativity 8-way Set-Associative
Maximum Cache Size 2 180 - 00000384l Kb
Installed Cache Size 2 180 - 00000384l Kb
[Cache Information (Type 7) - Length 27 - Handle 002ch]
Socket Designation L2 - Cache
Cache Configuration 0181h - WBEnabled Int NonSocketed L2
Maximum Cache Size 0c00h - 3072K
Installed Size 0c00h - 3072K
Cache Speed 1ns
Maximum Cache Size 2 c00 - 00003072l Kb
Installed Cache Size 2 c00 - 00003072l Kb
[Cache Information (Type 7) - Length 27 - Handle 002dh]
Socket Designation L3 - Cache
Cache Configuration 0182h - WBEnabled Int NonSocketed L3
Maximum Cache Size 8200h - 32768K
Installed Size 8200h - 32768K
Cache Speed 1ns
Associativity 16-way Set-Associative
Maximum Cache Size 2 80000200 - 00032768l Kb
Installed Cache Size 2 80000200 - 00032768l Kb
[Processor Information (Type 4) - Length 48 - Handle 002eh]
Socket Designation AM4
Processor Type Central Processor
Processor Family 6bh - AMD Zen Processor Family
Processor Manufacturer Advanced Micro Devices, Inc.
Processor ID 120fa200fffb8b17
Processor Version AMD Ryzen 5 5600 6-Core Processor
Processor Voltage 8bh - 1.1V
External Clock 100MHz
Max Speed 4450MHz
Current Speed 3500MHz
Status Enabled Populated
Processor Upgrade Socket AM4
L1 Cache Handle 002bh
L2 Cache Handle 002ch
L3 Cache Handle 002dh
Serial Number
Asset Tag Number
Part Number Unknown
Core Count 6
Core Enabled 6
Thread Count 12
Processor Characteristics fc
Enabled Characteristics:
0x 2: 64-bit Capable
0x 3: Multi-Core
0x 4: Hardware Thread
0x 5: Execute Protection
0x 6: Enhanced Virtualization
Processor Family 2 006bh - AMD Zen Processor Family
Core Count 2 6
Core Enabled 2 6
Thread Count 2 12
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 002fh]
[Memory Device (Type 17) - Length 92 - Handle 0030h]
Memory Error Info Handle 002fh
Total Width 64 bits
Data Width 64 bits
Size 8192MB
Form Factor 09h - DIMM
Device Set [None]
Device Locator DIMM_A1
Bank Locator BANK 0
Memory Type 1ah - DDR4
Type Detail 4080h - Synchronous Unbuffered (Unregistered)
Speed 3200MHz
Manufacturer A-DATA
Serial Number
Asset Tag Number [String Not Specified]
Part Number DDR4 3200
Attributes 1
Extended Size 0
Configured Memory Speed 3200
Minimum Voltage 1200
Maximum Voltage 1200
Configured Voltage 1200
Memory Technology 3
Memory Operating Mode Capability 8
Firmware Version 6
Module Manufacturer Id 51972
Module Product Id 0
Memory Subsystem Controller Manufacturer Id 0
Memory Subsystem Controller Product Id 0
Non-Volatile Size 0
Volatile Size 0
Cache Size 0
Logical Size 0
Extended Speed 0
Extended Configured Memory Speed 0
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 0031h]
Ending Address 00ffffffh
Memory Device Handle 0030h
Mem Array Mapped Adr Handle 002ah
Partition Row Position [Unknown]
Interleave Position [Unknown]
Interleave Data Depth [Unknown]
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 0032h]
[Memory Device (Type 17) - Length 92 - Handle 0033h]
Memory Error Info Handle 0032h
Total Width 64 bits
Data Width 64 bits
Size 8192MB
Device Set [None]
Device Locator DIMM_B1
Bank Locator BANK 1
Speed 3200MHz
Manufacturer A-DATA
Serial Number
Attributes 1
Extended Size 0
Memory Technology 3
Firmware Version 6
Module Product Id 0
Non-Volatile Size 0
Volatile Size 0
Cache Size 0
Logical Size 0
Extended Speed 0
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 0034h]
Memory Device Handle 0033h
[ (Type 256) - Length 4 - Handle 0039h]
Arguments:
Debugging Details:
Value: 812
Value: 812
Value: 2
Value: 1
Value: 18
Value: 375
Value: 11233
Value: 82
Value: 1.2408.27.1
Value: 0x1a
Value: 0x1a
Value: 8
Value: 1
Key : Failure.Hash
BUGCHECK_CODE: 1a
BUGCHECK_P1: 41791
BUGCHECK_P4: 10021
BLACKBOXWINLOGON: 1
STACK_TEXT:
MODULE_NAME: nt
OSNAME: Windows 10
[DMI Version - 0]
BIOS Version 3802
07: - PCI Supported
10: - APM Supported
19: - EDD Supported
Manufacturer ASUS
SKUNumber SKU
Version Rev X.0x
Asset Tag
Feature Flags 09h
00: - Motherboard
03: - Replaceable
Serial Number
Asset Tag Number
Bootup State Safe
Thermal State Safe
OEM Defined 0
Height 0U
Number of Strings 8
1 Default string
2 Default string
3 Default string
4 Default string
5 Default string
6 Default string
7 Default string
8 Default string
Partition Width 02
Partition Width 02
Cache Speed 1ns
Cache Speed 1ns
Cache Speed 1ns
Max Speed 4450MHz
Serial Number
Asset Tag Number
Part Number Unknown
Core Count 6
Core Enabled 6
Thread Count 12
0x 3: Multi-Core
Core Count 2 6
Core Enabled 2 6
Thread Count 2 12
Total Width 64 bits
Data Width 64 bits
Size 8192MB
Device Set [None]
Bank Locator BANK 0
Speed 3200MHz
Manufacturer A-DATA
Serial Number
Attributes 1
Extended Size 0
Memory Technology 3
Firmware Version 6
Module Product Id 0
Non-Volatile Size 0
Volatile Size 0
Cache Size 0
Logical Size 0
Extended Speed 0
Total Width 64 bits
Data Width 64 bits
Size 8192MB
Device Set [None]
Bank Locator BANK 1
Speed 3200MHz
Manufacturer A-DATA
Serial Number
Attributes 1
Extended Size 0
Memory Technology 3
Firmware Version 6
Module Product Id 0
Non-Volatile Size 0
Volatile Size 0
Cache Size 0
Logical Size 0
Extended Speed 0
Alperen'in dediğine ek olarak BIOS sürümünüz epey eski, günmceller misinizi?
PRIME B450M-K II
M.2 desteği, HDMI/DVI-D/D-Sub, SATA 6 Gbps, 1 Gb Ethernet, USB 3.2 Gen 1 Type-A ve BIOS FlashBack™ özelliklerine sahip AMD B450 (Ryzen AM4) micro ATX anakartwww.asus.com
Kod:KERNEL_SECURITY_CHECK_FAILURE (139) A kernel component has corrupted a critical data structure. The corruption. could potentially allow a malicious user to gain control of this machine. Arguments: Arg1: 0000000000000002, Stack cookie instrumentation code detected a stack-based buffer overrun. Arg2: fffff8064ea8afa0, Address of the trap frame for the exception that caused the BugCheck. Arg3: fffff8064ea8aef8, Address of the exception record for the exception that caused the BugCheck. Arg4: 0000000000000000, Reserved. Debugging Details: ------------------ KEY_VALUES_STRING: 1 Key : Analysis.CPU.mSec Value: 1046. Key : Analysis.Elapsed.mSec Value: 4822. Key : Analysis.IO.Other.Mb Value: 3 Key : Analysis.IO.Read.Mb Value: 1 Key : Analysis.IO.Write.Mb Value: 23. Key : Analysis.Init.CPU.mSec Value: 421. Key : Analysis.Init.Elapsed.mSec Value: 16273. Key : Analysis.Memory.CommitPeak.Mb Value: 89. Key : Analysis.Version.DbgEng Value: 10.0.27725.1000 Key : Analysis.Version.Description Value: 10.2408.27.01 amd64fre. Key : Analysis.Version.Ext Value: 1.2408.27.1 Key : Bugcheck.Code.LegacyAPI Value: 0x139. Key : Bugcheck.Code.TargetModel Value: 0x139. Key : Dump.Attributes.AsUlong Value: 8 Key : Dump.Attributes.KernelGeneratedTriageDump Value: 1 Key : FailFast.Name Value: STACK_COOKIE_CHECK_FAILURE Key : FailFast.Type Value: 2 Key : Failure.Bucket Value: 0x139_MISSING_GSFRAME_rt640x64!unknown_function Key : Failure.Hash Value: {2c7a6b39-0b08-f942-2b65-f44960d08147} Key : Stack.Pointer Value: PRCBException. BUGCHECK_CODE: 139. BUGCHECK_P1: 2 BUGCHECK_P2: fffff8064ea8afa0. BUGCHECK_P3: fffff8064ea8aef8. BUGCHECK_P4: 0 FILE_IN_CAB: 112524-3703-01.dmp DUMP_FILE_ATTRIBUTES: 0x8. Kernel Generated Triage Dump. FAULTING_THREAD: fffff80649527a00. TRAP_FRAME: fffff8064ea8afa0 -- (.trap 0xfffff8064ea8afa0) NOTE: The trap frame does not contain all registers. Some register values may be zeroed or incorrect. rax=fffff8064dd00000 rbx=0000000000000000 rcx=0000000000000002 rdx=0000000000000000 rsi=0000000000000000 rdi=0000000000000000 rip=fffff8064dd3d755 rsp=fffff8064ea8b138 rbp=fffff8064ea8b710 r8=0000000000000000 r9=fffff8064ea75740 r10=fffff8064ea75740 r11=0000000000000090 r12=0000000000000000 r13=0000000000000000 r14=0000000000000000 r15=0000000000000000 iopl=0 nv up ei ng nz ac pe nc. ndis!_report_gsfailure+0x5: fffff806`4dd3d755 cd29 int 29h. Resetting default scope. EXCEPTION_RECORD: fffff8064ea8aef8 -- (.exr 0xfffff8064ea8aef8) ExceptionAddress: fffff8064dd3d755 (ndis!_report_gsfailure+0x0000000000000005) ExceptionCode: c0000409 (Security check failure or stack buffer overrun) ExceptionFlags: 00000001. NumberParameters: 1 Parameter[0]: 0000000000000002. Subcode: 0x2 FAST_FAIL_STACK_COOKIE_CHECK_FAILURE BLACKBOXBSD: 1 (!blackboxbsd) BLACKBOXNTFS: 1 (!blackboxntfs) BLACKBOXWINLOGON: 1 CUSTOMER_CRASH_COUNT: 1 PROCESS_NAME: System. ERROR_CODE: (NTSTATUS) 0xc0000409 - Sistem, bu uygulamada y n tabanl bir arabelle in ta t n alg lad . Bu ta ma, k t niyetli bir kullan c n n bu uygulaman n denetimini ele ge irmesine olanak verebilir. EXCEPTION_CODE_STR: c0000409. EXCEPTION_PARAMETER1: 0000000000000002. EXCEPTION_STR: 0xc0000409. STACK_TEXT: fffff806`4ea8ac78 fffff806`48c12da9 : 00000000`00000139 00000000`00000002 fffff806`4ea8afa0 fffff806`4ea8aef8 : nt!KeBugCheckEx fffff806`4ea8ac80 fffff806`48c13350 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiBugCheckDispatch+0x69 fffff806`4ea8adc0 fffff806`48c111f2 : fffffb03`519175d8 fffff806`4ea8b7c0 fffff806`4ea8b210 ffffffff`c0000005 : nt!KiFastFailDispatch+0xd0 fffff806`4ea8afa0 fffff806`4dd3d755 : fffff806`4dd40496 fffff806`4ea8b710 fffff806`48aeebaf fffff806`4dde869c : nt!KiRaiseSecurityCheckFailure+0x332 fffff806`4ea8b138 fffff806`4dd40496 : fffff806`4ea8b710 fffff806`48aeebaf fffff806`4dde869c fffff806`00000000 : ndis!_report_gsfailure+0x5 fffff806`4ea8b140 fffff806`4dd4042b : fffff806`4ea8b210 00000000`00000000 fffff806`4ea8b748 fffff806`4ea8b720 : ndis!_GSHandlerCheckCommon+0x5a fffff806`4ea8b170 fffff806`48c090c2 : fffff806`4dd40418 00000000`00000000 00000000`00000000 00000000`00000000 : ndis!_GSHandlerCheck+0x13 fffff806`4ea8b1a0 fffff806`48aee997 : fffff806`4ea8b710 00000000`00000000 fffff806`4ea75740 fffff806`4dd07776 : nt!RtlpExecuteHandlerForException+0x12 fffff806`4ea8b1d0 fffff806`48b39536 : fffff806`4ea74f68 fffff806`4ea8be20 fffff806`4ea74f68 ffffd08c`aa99b201 : nt!RtlDispatchException+0x297 fffff806`4ea8b8f0 fffff806`48bff6e2 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiDispatchException+0x186 fffff806`4ea8bfb0 fffff806`48bff6b0 : fffff806`48c12ee5 fffff806`4ea74f88 00000000`00000002 00000000`00000000 : nt!KxExceptionDispatchOnExceptionStack+0x12 fffff806`4ea74e28 fffff806`48c12ee5 : fffff806`4ea74f88 00000000`00000002 00000000`00000000 fffff806`48a9095d : nt!KiExceptionDispatchOnExceptionStackContinue fffff806`4ea74e30 fffff806`48c0e2ef : ffffd08c`aaf31b70 00000000`00000000 00060080`01000000 00000000`00000000 : nt!KiExceptionDispatch+0x125 fffff806`4ea75010 fffff806`4dd13cef : ffffd08c`aa2fc981 00000000`00000003 ffffd08c`aaee3570 fffff806`4ea75300 : nt!KiGeneralProtectionFault+0x32f fffff806`4ea751a0 fffff806`4dd021c9 : ffffd08c`aaf30000 ffffd08c`a6c55008 00000000`00000000 00000000`00000003 : ndis!ndisParseReceivedNBL+0x53 fffff806`4ea75200 fffff806`4dd01be1 : ffffd08c`00000000 00000000`00000008 ffffd08c`aa8b41a0 00000000`00000000 : ndis!ndisSortNetBufferLists+0xb9 fffff806`4ea75280 fffff806`4dd07de0 : ffffd08c`aa8b41a0 ffffd08c`aa99b701 ffffd08c`aa8b41a0 00000000`00000001 : ndis!ndisMTopReceiveNetBufferLists+0x141 fffff806`4ea75300 fffff806`4dd3ea4f : ffffd08c`aa99b780 fffff806`4ea753d1 00000000`00000000 fffff806`5c2aa1fd : ndis!ndisCallReceiveHandler+0x60 fffff806`4ea75350 fffff806`4dd04984 : 00000000`000014f7 00000000`00000001 ffffd08c`aa8b41a0 00000000`00000001 : ndis!ndisInvokeNextReceiveHandler+0x1df fffff806`4ea75420 fffff806`5c25ae87 : ffffd08c`71370f7c ffffd08c`aa603000 ffffd08c`aa99b780 00000000`00000000 : ndis!NdisMIndicateReceiveNetBufferLists+0x104 fffff806`4ea754b0 ffffd08c`71370f7c : ffffd08c`aa603000 ffffd08c`aa99b780 00000000`00000000 0000004d`00000001 : rt640x64+0x1ae87 fffff806`4ea754b8 ffffd08c`aa603000 : ffffd08c`aa99b780 00000000`00000000 0000004d`00000001 00000000`00000000 : 0xffffd08c`71370f7c fffff806`4ea754c0 ffffd08c`aa99b780 : 00000000`00000000 0000004d`00000001 00000000`00000000 00000003`4ea75500 : 0xffffd08c`aa603000 fffff806`4ea754c8 00000000`00000000 : 0000004d`00000001 00000000`00000000 00000003`4ea75500 ffff8000`00007501 : 0xffffd08c`aa99b780 SYMBOL_NAME: rt640x64+1ae87 MODULE_NAME: rt640x64. IMAGE_NAME: rt640x64.sys STACK_COMMAND: .process /r /p 0xfffff80649524a00; .thread 0xfffff80649527a00 ; kb. BUCKET_ID_FUNC_OFFSET: 1ae87. FAILURE_BUCKET_ID: 0x139_MISSING_GSFRAME_rt640x64!unknown_function OSPLATFORM_TYPE: x64. OSNAME: Windows 10. FAILURE_ID_HASH: {2c7a6b39-0b08-f942-2b65-f44960d08147} Followup: MachineOwner. --------- [SMBIOS Data Tables v3.3] [DMI Version - 0] [2.0 Calling Convention - No] [Table Size - 2476 bytes] [BIOS Information (Type 0) - Length 26 - Handle 0000h] Vendor American Megatrends Inc. BIOS Version 3802. BIOS Starting Address Segment f000. BIOS Release Date 04/28/2022 BIOS ROM Size 1000000. BIOS Characteristics. 07: - PCI Supported. 10: - APM Supported. 11: - Upgradeable FLASH BIOS. 12: - BIOS Shadowing Supported. 15: - CD-Boot Supported. 16: - Selectable Boot Supported. 17: - BIOS ROM Socketed. 19: - EDD Supported. 23: - 1.2MB Floppy Supported. 24: - 720KB Floppy Supported. 25: - 2.88MB Floppy Supported. 26: - Print Screen Device Supported. 27: - Keyboard Services Supported. 28: - Serial Services Supported. 29: - Printer Services Supported. 32: - BIOS Vendor Reserved. BIOS Characteristic Extensions. 00: - ACPI Supported. 01: - USB Legacy Supported. 08: - BIOS Boot Specification Supported. 10: - Enable Targeted Content Distribution. 11: - UEFI Specification Supported. BIOS Major Revision 5 BIOS Minor Revision 17. EC Firmware Major Revision 255. EC Firmware Minor Revision 255. Extended BIOS ROM Size 16 MB. [System Information (Type 1) - Length 27 - Handle 0001h] Manufacturer ASUS. Product Name System Product Name. Version System Version. Serial Number System Serial Number. UUID 00000000-0000-0000-0000-000000000000 Wakeup Type Power Switch. SKUNumber SKU. Family To be filled by O.E.M. [BaseBoard Information (Type 2) - Length 15 - Handle 0002h] Manufacturer ASUSTeK COMPUTER INC. Product PRIME B450M-K II. Version Rev X.0x Serial Number 201278998600951. Asset Tag Feature Flags 09h. 00: - Motherboard. 03: - Replaceable. Location Default string. Chassis Handle 0003h. Board Type 0ah - Processor/Memory Module. Number of Child Handles 0 [System Enclosure (Type 3) - Length 22 - Handle 0003h] Manufacturer Default string. Chassis Type Desktop. Version Default string. Serial Number Asset Tag Number Bootup State Safe. Power Supply State Safe. Thermal State Safe. Security Status None. OEM Defined 0 Height 0U. Number of Power Cords 1 Number of Contained Elements 0 Contained Element Size 3 [Onboard Devices Information (Type 10) - Length 6 - Handle 001eh] Note: The On Board Device Information (Type 10) struct is obsolete as of SMBIOs spec v2.6 Number of Devices 1 01: Type Video [enabled] 01: Description To Be Filled By O.E.M. [OEM Strings (Type 11) - Length 5 - Handle 001fh] Number of Strings 8 1 Default string. 2 Default string. 3 Default string. 4 Default string. 5 Default string. 6 Default string. 7 Default string. 8 Default string. [System Configuration Options (Type 12) - Length 5 - Handle 0020h] [ (Type 256) - Length 50 - Handle 0023h] [ (Type 256) - Length 11 - Handle 0024h] [ (Type 256) - Length 9 - Handle 0025h] [ (Type 256) - Length 31 - Handle 0026h] [32Bit Memory Error Information (Type 18) - Length 23 - Handle 0027h] [Physical Memory Array (Type 16) - Length 23 - Handle 0028h] Location 03h - SystemBoard/Motherboard Use 03h - System Memory. Memory Error Correction 03h - None. Maximum Capacity 134217728KB. Memory Error Inf Handle 0027h. Number of Memory Devices 2 [Memory Array Mapped Address (Type 19) - Length 31 - Handle 0029h] Starting Address 00000000h. Ending Address 0033ffffh. Memory Array Handle 0028h. Partition Width 02. Extended Starting Address 0000000000000000h. Extended Ending Address 0000000000000000h. [Memory Array Mapped Address (Type 19) - Length 31 - Handle 002ah] Starting Address 00400000h. Ending Address 010bffffh. Memory Array Handle 0028h. Partition Width 02. Extended Starting Address 0000000000000000h. Extended Ending Address 0000000000000000h. [Cache Information (Type 7) - Length 27 - Handle 002bh] Socket Designation L1 - Cache. Cache Configuration 0180h - WBEnabled Int NonSocketed L1. Maximum Cache Size 0180h - 384K. Installed Size 0180h - 384K. Supported SRAM Type 0010h - Pipeline-Burst Current SRAM Type 0010h - Pipeline-Burst Cache Speed 1ns. Error Correction Type Specification Reserved. System Cache Type Unified. Associativity 8-way Set-Associative Maximum Cache Size 2 180 - 00000384l Kb. Installed Cache Size 2 180 - 00000384l Kb. [Cache Information (Type 7) - Length 27 - Handle 002ch] Socket Designation L2 - Cache. Cache Configuration 0181h - WBEnabled Int NonSocketed L2. Maximum Cache Size 0c00h - 3072K. Installed Size 0c00h - 3072K. Supported SRAM Type 0010h - Pipeline-Burst Current SRAM Type 0010h - Pipeline-Burst Cache Speed 1ns. Error Correction Type Specification Reserved. System Cache Type Unified. Associativity 8-way Set-Associative Maximum Cache Size 2 c00 - 00003072l Kb. Installed Cache Size 2 c00 - 00003072l Kb. [Cache Information (Type 7) - Length 27 - Handle 002dh] Socket Designation L3 - Cache. Cache Configuration 0182h - WBEnabled Int NonSocketed L3. Maximum Cache Size 8200h - 32768K. Installed Size 8200h - 32768K. Supported SRAM Type 0010h - Pipeline-Burst Current SRAM Type 0010h - Pipeline-Burst Cache Speed 1ns. Error Correction Type Specification Reserved. System Cache Type Unified. Associativity 16-way Set-Associative Maximum Cache Size 2 80000200 - 00032768l Kb. Installed Cache Size 2 80000200 - 00032768l Kb. [Processor Information (Type 4) - Length 48 - Handle 002eh] Socket Designation AM4. Processor Type Central Processor. Processor Family 6bh - AMD Zen Processor Family. Processor Manufacturer Advanced Micro Devices, Inc. Processor ID 120fa200fffb8b17. Processor Version AMD Ryzen 5 5600 6-Core Processor Processor Voltage 8bh - 1.1V External Clock 100MHz. Max Speed 4450MHz. Current Speed 3500MHz. Status Enabled Populated. Processor Upgrade Socket AM4. L1 Cache Handle 002bh. L2 Cache Handle 002ch. L3 Cache Handle 002dh. Serial Number Asset Tag Number Part Number Unknown. Core Count 6 Core Enabled 6 Thread Count 12. Processor Characteristics fc. Enabled Characteristics: 0x 2: 64-bit Capable. 0x 3: Multi-Core 0x 4: Hardware Thread. 0x 5: Execute Protection. 0x 6: Enhanced Virtualization. 0x 7: Power/Performance Control. Processor Family 2 006bh - AMD Zen Processor Family. Core Count 2 6 Core Enabled 2 6 Thread Count 2 12. [32Bit Memory Error Information (Type 18) - Length 23 - Handle 002fh] [Memory Device (Type 17) - Length 92 - Handle 0030h] Memory Error Info Handle 002fh. Total Width 64 bits. Data Width 64 bits. Size 8192MB. Form Factor 09h - DIMM. Device Set [None] Device Locator DIMM_A1. Bank Locator BANK 0 Memory Type 1ah - DDR4. Type Detail 4080h - Synchronous Unbuffered (Unregistered) Speed 3200MHz. Manufacturer A-DATA Serial Number Asset Tag Number [String Not Specified] Part Number DDR4 3200 Attributes 1 Extended Size 0 Configured Memory Speed 3200. Minimum Voltage 1200. Maximum Voltage 1200. Configured Voltage 1200. Memory Technology 3 Memory Operating Mode Capability 8 Firmware Version 6 Module Manufacturer Id 51972. Module Product Id 0 Memory Subsystem Controller Manufacturer Id 0 Memory Subsystem Controller Product Id 0 Non-Volatile Size 0 Volatile Size 0 Cache Size 0 Logical Size 0 Extended Speed 0 Extended Configured Memory Speed 0 [Memory Device Mapped Address (Type 20) - Length 35 - Handle 0031h] Starting Address 00000000h. Ending Address 00ffffffh. Memory Device Handle 0030h. Mem Array Mapped Adr Handle 002ah. Partition Row Position [Unknown] Interleave Position [Unknown] Interleave Data Depth [Unknown] Extended Starting Address 0000000000000000h. Extended Ending Address 0000000000000000h. [32Bit Memory Error Information (Type 18) - Length 23 - Handle 0032h] [Memory Device (Type 17) - Length 92 - Handle 0033h] Memory Error Info Handle 0032h. Total Width 64 bits. Data Width 64 bits. Size 8192MB. Form Factor 09h - DIMM. Device Set [None] Device Locator DIMM_B1. Bank Locator BANK 1 Memory Type 1ah - DDR4. Type Detail 4080h - Synchronous Unbuffered (Unregistered) Speed 3200MHz. Manufacturer A-DATA Serial Number Asset Tag Number [String Not Specified] Part Number DDR4 3200 Attributes 1 Extended Size 0 Configured Memory Speed 3200. Minimum Voltage 1200. Maximum Voltage 1200. Configured Voltage 1200. Memory Technology 3 Memory Operating Mode Capability 8 Firmware Version 6 Module Manufacturer Id 51972. Module Product Id 0 Memory Subsystem Controller Manufacturer Id 0 Memory Subsystem Controller Product Id 0 Non-Volatile Size 0 Volatile Size 0 Cache Size 0 Logical Size 0 Extended Speed 0 Extended Configured Memory Speed 0 [Memory Device Mapped Address (Type 20) - Length 35 - Handle 0034h] Starting Address 00000000h. Ending Address 00ffffffh. Memory Device Handle 0033h. Mem Array Mapped Adr Handle 002ah. Partition Row Position [Unknown] Interleave Position [Unknown] Interleave Data Depth [Unknown] Extended Starting Address 0000000000000000h. Extended Ending Address 0000000000000000h. [ (Type 256) - Length 4 - Handle 0039h]
Kod:MEMORY_MANAGEMENT (1a) # Any other values for parameter 1 must be individually examined. Arguments: Arg1: 0000000000041791, The subtype of the BugCheck. Arg2: ffffb5000bfdb760. Arg3: ffdfb95c80000040. Arg4: 0000000000010021. Debugging Details: ------------------ KEY_VALUES_STRING: 1 Key : Analysis.CPU.mSec Value: 812. Key : Analysis.Elapsed.mSec Value: 812. Key : Analysis.IO.Other.Mb Value: 2 Key : Analysis.IO.Read.Mb Value: 1 Key : Analysis.IO.Write.Mb Value: 18. Key : Analysis.Init.CPU.mSec Value: 375. Key : Analysis.Init.Elapsed.mSec Value: 11233. Key : Analysis.Memory.CommitPeak.Mb Value: 82. Key : Analysis.Version.DbgEng Value: 10.0.27725.1000 Key : Analysis.Version.Description Value: 10.2408.27.01 amd64fre. Key : Analysis.Version.Ext Value: 1.2408.27.1 Key : Bugcheck.Code.LegacyAPI Value: 0x1a. Key : Bugcheck.Code.TargetModel Value: 0x1a. Key : Dump.Attributes.AsUlong Value: 8 Key : Dump.Attributes.KernelGeneratedTriageDump Value: 1 Key : Failure.Bucket Value: 0x1a_41791_nt!MmUnlockPages Key : Failure.Hash Value: {257cd050-e4e1-a6f4-7c65-0c6aaef71f68} BUGCHECK_CODE: 1a. BUGCHECK_P1: 41791. BUGCHECK_P2: ffffb5000bfdb760. BUGCHECK_P3: ffdfb95c80000040. BUGCHECK_P4: 10021. FILE_IN_CAB: 112524-5218-01.dmp DUMP_FILE_ATTRIBUTES: 0x8. Kernel Generated Triage Dump. FAULTING_THREAD: ffff8c8c14d97040. BLACKBOXBSD: 1 (!blackboxbsd) BLACKBOXNTFS: 1 (!blackboxntfs) BLACKBOXWINLOGON: 1 CUSTOMER_CRASH_COUNT: 1 PROCESS_NAME: WmiPrvSE.exe STACK_TEXT: ffffb985`dd317438 fffff803`05473519 : 00000000`0000001a 00000000`00041791 ffffb500`0bfdb760 ffdfb95c`80000040 : nt!KeBugCheckEx ffffb985`dd317440 fffff803`05829e26 : ffffb985`dd317680 00000000`00000103 ffffb985`00000002 00000000`00000000 : nt!MmUnlockPages+0xd89 ffffb985`dd317530 fffff803`05828b83 : 00000047`be7fc180 00000000`00000008 ffffb985`dd317768 00000000`00000004 : nt!MmCopyVirtualMemory+0x7d6 ffffb985`dd317980 fffff803`05828a1b : ffff8c8c`14d97040 00000047`be7fc168 00000047`be7fc230 00007ff9`f9db9510 : nt!MiReadWriteVirtualMemory+0x153 ffffb985`dd317a10 fffff803`05612508 : 00000245`fef02fd0 00007ff9`f9db9510 00000000`00000000 00007ff9`f9db45a0 : nt!NtReadVirtualMemory+0x1b ffffb985`dd317a50 00007ffa`16acdcd4 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x28 00000047`be7fc148 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ffa`16acdcd4 SYMBOL_NAME: nt!MmUnlockPages+d89 MODULE_NAME: nt. IMAGE_VERSION: 10.0.19041.5129 STACK_COMMAND: .process /r /p 0xffff8c8c15432080; .thread 0xffff8c8c14d97040 ; kb. IMAGE_NAME: ntkrnlmp.exe BUCKET_ID_FUNC_OFFSET: d89. FAILURE_BUCKET_ID: 0x1a_41791_nt!MmUnlockPages OSPLATFORM_TYPE: x64. OSNAME: Windows 10. FAILURE_ID_HASH: {257cd050-e4e1-a6f4-7c65-0c6aaef71f68} Followup: MachineOwner. --------- [SMBIOS Data Tables v3.3] [DMI Version - 0] [2.0 Calling Convention - No] [Table Size - 2476 bytes] [BIOS Information (Type 0) - Length 26 - Handle 0000h] Vendor American Megatrends Inc. BIOS Version 3802. BIOS Starting Address Segment f000. BIOS Release Date 04/28/2022 BIOS ROM Size 1000000. BIOS Characteristics. 07: - PCI Supported. 10: - APM Supported. 11: - Upgradeable FLASH BIOS. 12: - BIOS Shadowing Supported. 15: - CD-Boot Supported. 16: - Selectable Boot Supported. 17: - BIOS ROM Socketed. 19: - EDD Supported. 23: - 1.2MB Floppy Supported. 24: - 720KB Floppy Supported. 25: - 2.88MB Floppy Supported. 26: - Print Screen Device Supported. 27: - Keyboard Services Supported. 28: - Serial Services Supported. 29: - Printer Services Supported. 32: - BIOS Vendor Reserved. BIOS Characteristic Extensions. 00: - ACPI Supported. 01: - USB Legacy Supported. 08: - BIOS Boot Specification Supported. 10: - Enable Targeted Content Distribution. 11: - UEFI Specification Supported. BIOS Major Revision 5 BIOS Minor Revision 17. EC Firmware Major Revision 255. EC Firmware Minor Revision 255. Extended BIOS ROM Size 16 MB. [System Information (Type 1) - Length 27 - Handle 0001h] Manufacturer ASUS. Product Name System Product Name. Version System Version. Serial Number System Serial Number. UUID 00000000-0000-0000-0000-000000000000 Wakeup Type Power Switch. SKUNumber SKU. Family To be filled by O.E.M. [BaseBoard Information (Type 2) - Length 15 - Handle 0002h] Manufacturer ASUSTeK COMPUTER INC. Product PRIME B450M-K II. Version Rev X.0x Serial Number 201278998600951. Asset Tag Feature Flags 09h. 00: - Motherboard. 03: - Replaceable. Location Default string. Chassis Handle 0003h. Board Type 0ah - Processor/Memory Module. Number of Child Handles 0 [System Enclosure (Type 3) - Length 22 - Handle 0003h] Manufacturer Default string. Chassis Type Desktop. Version Default string. Serial Number Asset Tag Number Bootup State Safe. Power Supply State Safe. Thermal State Safe. Security Status None. OEM Defined 0 Height 0U. Number of Power Cords 1 Number of Contained Elements 0 Contained Element Size 3 [Onboard Devices Information (Type 10) - Length 6 - Handle 001eh] Note: The On Board Device Information (Type 10) struct is obsolete as of SMBIOs spec v2.6 Number of Devices 1 01: Type Video [enabled] 01: Description To Be Filled By O.E.M. [OEM Strings (Type 11) - Length 5 - Handle 001fh] Number of Strings 8 1 Default string. 2 Default string. 3 Default string. 4 Default string. 5 Default string. 6 Default string. 7 Default string. 8 Default string. [System Configuration Options (Type 12) - Length 5 - Handle 0020h] [ (Type 256) - Length 50 - Handle 0023h] [ (Type 256) - Length 11 - Handle 0024h] [ (Type 256) - Length 9 - Handle 0025h] [ (Type 256) - Length 31 - Handle 0026h] [32Bit Memory Error Information (Type 18) - Length 23 - Handle 0027h] [Physical Memory Array (Type 16) - Length 23 - Handle 0028h] Location 03h - SystemBoard/Motherboard Use 03h - System Memory. Memory Error Correction 03h - None. Maximum Capacity 134217728KB. Memory Error Inf Handle 0027h. Number of Memory Devices 2 [Memory Array Mapped Address (Type 19) - Length 31 - Handle 0029h] Starting Address 00000000h. Ending Address 0033ffffh. Memory Array Handle 0028h. Partition Width 02. Extended Starting Address 0000000000000000h. Extended Ending Address 0000000000000000h. [Memory Array Mapped Address (Type 19) - Length 31 - Handle 002ah] Starting Address 00400000h. Ending Address 010bffffh. Memory Array Handle 0028h. Partition Width 02. Extended Starting Address 0000000000000000h. Extended Ending Address 0000000000000000h. [Cache Information (Type 7) - Length 27 - Handle 002bh] Socket Designation L1 - Cache. Cache Configuration 0180h - WBEnabled Int NonSocketed L1. Maximum Cache Size 0180h - 384K. Installed Size 0180h - 384K. Supported SRAM Type 0010h - Pipeline-Burst Current SRAM Type 0010h - Pipeline-Burst Cache Speed 1ns. Error Correction Type Specification Reserved. System Cache Type Unified. Associativity 8-way Set-Associative Maximum Cache Size 2 180 - 00000384l Kb. Installed Cache Size 2 180 - 00000384l Kb. [Cache Information (Type 7) - Length 27 - Handle 002ch] Socket Designation L2 - Cache. Cache Configuration 0181h - WBEnabled Int NonSocketed L2. Maximum Cache Size 0c00h - 3072K. Installed Size 0c00h - 3072K. Supported SRAM Type 0010h - Pipeline-Burst Current SRAM Type 0010h - Pipeline-Burst Cache Speed 1ns. Error Correction Type Specification Reserved. System Cache Type Unified. Associativity 8-way Set-Associative Maximum Cache Size 2 c00 - 00003072l Kb. Installed Cache Size 2 c00 - 00003072l Kb. [Cache Information (Type 7) - Length 27 - Handle 002dh] Socket Designation L3 - Cache. Cache Configuration 0182h - WBEnabled Int NonSocketed L3. Maximum Cache Size 8200h - 32768K. Installed Size 8200h - 32768K. Supported SRAM Type 0010h - Pipeline-Burst Current SRAM Type 0010h - Pipeline-Burst Cache Speed 1ns. Error Correction Type Specification Reserved. System Cache Type Unified. Associativity 16-way Set-Associative Maximum Cache Size 2 80000200 - 00032768l Kb. Installed Cache Size 2 80000200 - 00032768l Kb. [Processor Information (Type 4) - Length 48 - Handle 002eh] Socket Designation AM4. Processor Type Central Processor. Processor Family 6bh - AMD Zen Processor Family. Processor Manufacturer Advanced Micro Devices, Inc. Processor ID 120fa200fffb8b17. Processor Version AMD Ryzen 5 5600 6-Core Processor Processor Voltage 8bh - 1.1V External Clock 100MHz. Max Speed 4450MHz. Current Speed 3500MHz. Status Enabled Populated. Processor Upgrade Socket AM4. L1 Cache Handle 002bh. L2 Cache Handle 002ch. L3 Cache Handle 002dh. Serial Number Asset Tag Number Part Number Unknown. Core Count 6 Core Enabled 6 Thread Count 12. Processor Characteristics fc. Enabled Characteristics: 0x 2: 64-bit Capable. 0x 3: Multi-Core 0x 4: Hardware Thread. 0x 5: Execute Protection. 0x 6: Enhanced Virtualization. 0x 7: Power/Performance Control. Processor Family 2 006bh - AMD Zen Processor Family. Core Count 2 6 Core Enabled 2 6 Thread Count 2 12. [32Bit Memory Error Information (Type 18) - Length 23 - Handle 002fh] [Memory Device (Type 17) - Length 92 - Handle 0030h] Memory Error Info Handle 002fh. Total Width 64 bits. Data Width 64 bits. Size 8192MB. Form Factor 09h - DIMM. Device Set [None] Device Locator DIMM_A1. Bank Locator BANK 0 Memory Type 1ah - DDR4. Type Detail 4080h - Synchronous Unbuffered (Unregistered) Speed 3200MHz. Manufacturer A-DATA Serial Number Asset Tag Number [String Not Specified] Part Number DDR4 3200 Attributes 1 Extended Size 0 Configured Memory Speed 3200. Minimum Voltage 1200. Maximum Voltage 1200. Configured Voltage 1200. Memory Technology 3 Memory Operating Mode Capability 8 Firmware Version 6 Module Manufacturer Id 51972. Module Product Id 0 Memory Subsystem Controller Manufacturer Id 0 Memory Subsystem Controller Product Id 0 Non-Volatile Size 0 Volatile Size 0 Cache Size 0 Logical Size 0 Extended Speed 0 Extended Configured Memory Speed 0 [Memory Device Mapped Address (Type 20) - Length 35 - Handle 0031h] Starting Address 00000000h. Ending Address 00ffffffh. Memory Device Handle 0030h. Mem Array Mapped Adr Handle 002ah. Partition Row Position [Unknown] Interleave Position [Unknown] Interleave Data Depth [Unknown] Extended Starting Address 0000000000000000h. Extended Ending Address 0000000000000000h. [32Bit Memory Error Information (Type 18) - Length 23 - Handle 0032h] [Memory Device (Type 17) - Length 92 - Handle 0033h] Memory Error Info Handle 0032h. Total Width 64 bits. Data Width 64 bits. Size 8192MB. Form Factor 09h - DIMM. Device Set [None] Device Locator DIMM_B1. Bank Locator BANK 1 Memory Type 1ah - DDR4. Type Detail 4080h - Synchronous Unbuffered (Unregistered) Speed 3200MHz. Manufacturer A-DATA Serial Number Asset Tag Number [String Not Specified] Part Number DDR4 3200 Attributes 1 Extended Size 0 Configured Memory Speed 3200. Minimum Voltage 1200. Maximum Voltage 1200. Configured Voltage 1200. Memory Technology 3 Memory Operating Mode Capability 8 Firmware Version 6 Module Manufacturer Id 51972. Module Product Id 0 Memory Subsystem Controller Manufacturer Id 0 Memory Subsystem Controller Product Id 0 Non-Volatile Size 0 Volatile Size 0 Cache Size 0 Logical Size 0 Extended Speed 0 Extended Configured Memory Speed 0 [Memory Device Mapped Address (Type 20) - Length 35 - Handle 0034h] Starting Address 00000000h. Ending Address 00ffffffh. Memory Device Handle 0033h. Mem Array Mapped Adr Handle 002ah. Partition Row Position [Unknown] Interleave Position [Unknown] Interleave Data Depth [Unknown] Extended Starting Address 0000000000000000h. Extended Ending Address 0000000000000000h. [ (Type 256) - Length 4 - Handle 0039h]
We use cookies and similar technologies for the following purposes:
Do you accept cookies and these technologies?
