Çözüldü DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1) mavi ekran hatası
11766
22 Ekim 2024
Kod:
************* Preparing the environment for Debugger Extensions Gallery repositories **************
   ExtensionRepository : Implicit
   UseExperimentalFeatureForNugetShare : true
   AllowNugetExeUpdate : true
   NonInteractiveNuget : true
   AllowNugetMSCredentialProviderInstall : true
   AllowParallelInitializationOfLocalRepositories : true
   EnableRedirectToChakraJsProvider : false
   -- Configuring repositories
      ----> Repository : LocalInstalled, Enabled: true
      ----> Repository : UserExtensions, Enabled: true
>>>>>>>>>>>>> Preparing the environment for Debugger Extensions Gallery repositories completed, duration 0.000 seconds
************* Waiting for Debugger Extensions Gallery to Initialize **************
>>>>>>>>>>>>> Waiting for Debugger Extensions Gallery to Initialize completed, duration 0.016 seconds
   ----> Repository : UserExtensions, Enabled: true, Packages count: 0
   ----> Repository : LocalInstalled, Enabled: true, Packages count: 42
Microsoft (R) Windows Debugger Version 10.0.27725.1000 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Users\vmurs\Desktop\110124-18343-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: srv*
Executable search path is:
Windows 10 Kernel Version 26100 MP (12 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Kernel base = 0xfffff803`88200000 PsLoadedModuleList = 0xfffff803`890f4730
Debug session time: Fri Nov  1 21:52:13.682 2024 (UTC + 3:00)
System Uptime: 0 days 21:57:50.679
Loading Kernel Symbols
Loading User Symbols
PEB is paged out (Peb.Ldr = 000000d3`bc643018).  Type ".hh dbgerr001" for details
Loading unloaded module list
For analysis of this file, run !analyze -v
nt!KeBugCheckEx:
fffff803`886b8680 48894c2408      mov     qword ptr [rsp+8],rcx ss:0018:ffffb705`25e3a1e0=000000000000000a
6: kd> !analyze -v
*                        Bugcheck Analysis                                    *
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high.  This is usually
caused by drivers using improper addresses.
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: ffffa60f22d6d004, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, value 0 = read operation, 1 = write operation
Arg4: fffff8033e162688, address which referenced memory
Debugging Details:
KEY_VALUES_STRING: 1
    Key  : Analysis.CPU.mSec
    Value: 1500
    Key  : Analysis.Elapsed.mSec
    Value: 10831
    Key  : Analysis.IO.Other.Mb
    Value: 2
    Key  : Analysis.IO.Read.Mb
    Value: 1
    Key  : Analysis.IO.Write.Mb
    Value: 23
    Key  : Analysis.Init.CPU.mSec
    Value: 640
    Value: 27439
    Value: 142
    Value: 10.0.27725.1000
    Value: 10.2408.27.01 amd64fre
    Key  : Analysis.Version.Ext
    Value: 1.2408.27.1
    Value: 0xd1
    Value: 0xd1
    Value: 21808
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Key  : Failure.Bucket
    Value: AV_FBNetFlt!unknown_function
    Key  : Failure.Hash
    Value: {a930455f-6e65-8e8c-d1b4-40f3e912c54d}
    Key  : Hypervisor.Enlightenments.ValueHex
    Value: 7417df84
    Key  : Hypervisor.Flags.AnyHypervisorPresent
    Value: 1
    Key  : Hypervisor.Flags.ApicEnlightened
    Value: 0
    Key  : Hypervisor.Flags.ApicVirtualizationAvailable
    Value: 1
    Key  : Hypervisor.Flags.AsyncMemoryHint
    Value: 0
    Key  : Hypervisor.Flags.CoreSchedulerRequested
    Value: 0
    Key  : Hypervisor.Flags.CpuManager
    Value: 1
    Key  : Hypervisor.Flags.DeprecateAutoEoi
    Value: 1
    Key  : Hypervisor.Flags.DynamicCpuDisabled
    Value: 1
    Key  : Hypervisor.Flags.Epf
    Value: 0
    Key  : Hypervisor.Flags.ExtendedProcessorMasks
    Value: 1
    Key  : Hypervisor.Flags.HardwareMbecAvailable
    Value: 1
    Key  : Hypervisor.Flags.MaxBankNumber
    Value: 0
    Key  : Hypervisor.Flags.MemoryZeroingControl
    Value: 0
    Key  : Hypervisor.Flags.NoExtendedRangeFlush
    Value: 0
    Key  : Hypervisor.Flags.NoNonArchCoreSharing
    Value: 1
    Key  : Hypervisor.Flags.Phase0InitDone
    Value: 1
    Key  : Hypervisor.Flags.PowerSchedulerQos
    Value: 0
    Key  : Hypervisor.Flags.RootScheduler
    Value: 0
    Key  : Hypervisor.Flags.SynicAvailable
    Value: 1
    Key  : Hypervisor.Flags.UseQpcBias
    Value: 0
    Key  : Hypervisor.Flags.Value
    Value: 55185662
    Key  : Hypervisor.Flags.ValueHex
    Value: 34a10fe
    Key  : Hypervisor.Flags.VpAssistPage
    Value: 1
    Key  : Hypervisor.Flags.VsmAvailable
    Value: 1
    Key  : Hypervisor.RootFlags.AccessStats
    Value: 1
    Key  : Hypervisor.RootFlags.CrashdumpEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.CreateVirtualProcessor
    Value: 1
    Key  : Hypervisor.RootFlags.DisableHyperthreading
    Value: 0
    Key  : Hypervisor.RootFlags.HostTimelineSync
    Value: 1
    Key  : Hypervisor.RootFlags.HypervisorDebuggingEnabled
    Value: 0
    Key  : Hypervisor.RootFlags.IsHyperV
    Value: 1
    Key  : Hypervisor.RootFlags.LivedumpEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.MapDeviceInterrupt
    Value: 1
    Key  : Hypervisor.RootFlags.MceEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.Nested
    Value: 0
    Key  : Hypervisor.RootFlags.StartLogicalProcessor
    Value: 1
    Key  : Hypervisor.RootFlags.Value
    Value: 1015
    Key  : Hypervisor.RootFlags.ValueHex
    Value: 3f7
BUGCHECK_CODE:  d1
BUGCHECK_P1: ffffa60f22d6d004
BUGCHECK_P2: 2
BUGCHECK_P3: 0
BUGCHECK_P4: fffff8033e162688
FILE_IN_CAB:  110124-18343-01.dmp
TAG_NOT_DEFINED_202b:  *** Unknown TAG in analysis list 202b
DUMP_FILE_ATTRIBUTES: 0x21808
  Kernel Generated Triage Dump
FAULTING_THREAD:  ffffa60f322020c0
READ_ADDRESS: fffff803891c34b0: Unable to get MiVisibleState
Unable to get NonPagedPoolStart
Unable to get NonPagedPoolEnd
Unable to get PagedPoolStart
Unable to get PagedPoolEnd
unable to get nt!MmSpecialPagesInUse
 ffffa60f22d6d004
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  LenovoVantage-
TRAP_FRAME:  ffffb70525e3a320 -- (.trap 0xffffb70525e3a320)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=0000000000000000 rbx=0000000000000000 rcx=ffffa60f05fb7920
rdx=ffffa60f22d6cf60 rsi=0000000000000000 rdi=0000000000000000
rip=fffff8033e162688 rsp=ffffb70525e3a4b0 rbp=0000000000000002
 r8=ffffa60f22d6d004  r9=000000000000000e r10=ffffae0bdc473288
r11=fffff8033e1653d2 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0         nv up ei pl nz na pe nc
FBNetFlt+0x2688:
fffff803`3e162688 664183385c      cmp     word ptr [r8],5Ch ds:ffffa60f`22d6d004=????
Resetting default scope
STACK_TEXT:
ffffb705`25e3a1d8 fffff803`88887ae9     : 00000000`0000000a ffffa60f`22d6d004 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
ffffb705`25e3a1e0 fffff803`88882da8     : 000000b8`1b0c40d8 ffffb705`25e3a3a0 000000b8`1b0c40f2 0000c14f`99aa97b3 : nt!KiBugCheckDispatch+0x69
ffffb705`25e3a320 fffff803`3e162688     : ffffa60f`1a5d8658 ffffa60f`05fb7ba0 ffffa60e`f2100000 00000006`00000040 : nt!KiPageFault+0x468
ffffb705`25e3a4b0 ffffa60f`1a5d8658     : ffffa60f`05fb7ba0 ffffa60e`f2100000 00000006`00000040 ffffa60e`f7f1e5c0 : FBNetFlt+0x2688
ffffb705`25e3a4b8 ffffa60f`05fb7ba0     : ffffa60e`f2100000 00000006`00000040 ffffa60e`f7f1e5c0 fffff803`3e161ebb : 0xffffa60f`1a5d8658
ffffb705`25e3a4c0 ffffa60e`f2100000     : 00000006`00000040 ffffa60e`f7f1e5c0 fffff803`3e161ebb ffffa60f`05fb7920 : 0xffffa60f`05fb7ba0
ffffb705`25e3a4c8 00000006`00000040     : ffffa60e`f7f1e5c0 fffff803`3e161ebb ffffa60f`05fb7920 00000000`00000002 : 0xffffa60e`f2100000
ffffb705`25e3a4d0 ffffa60e`f7f1e5c0     : fffff803`3e161ebb ffffa60f`05fb7920 00000000`00000002 ffffa60f`331e8e00 : 0x00000006`00000040
ffffb705`25e3a4d8 fffff803`3e161ebb     : ffffa60f`05fb7920 00000000`00000002 ffffa60f`331e8e00 ffffe281`4a34f9b8 : 0xffffa60e`f7f1e5c0
ffffb705`25e3a4e0 ffffa60f`05fb7920     : 00000000`00000002 ffffa60f`331e8e00 ffffe281`4a34f9b8 00000000`0000f9b0 : FBNetFlt+0x1ebb
ffffb705`25e3a4e8 00000000`00000002     : ffffa60f`331e8e00 ffffe281`4a34f9b8 00000000`0000f9b0 fffff6bf`fe4e6c18 : 0xffffa60f`05fb7920
ffffb705`25e3a4f0 ffffa60f`331e8e00     : ffffe281`4a34f9b8 00000000`0000f9b0 fffff6bf`fe4e6c18 ffffbc80`059c6790 : 0x2
ffffb705`25e3a4f8 ffffe281`4a34f9b8     : 00000000`0000f9b0 fffff6bf`fe4e6c18 ffffbc80`059c6790 00000000`00000000 : 0xffffa60f`331e8e00
ffffb705`25e3a500 00000000`0000f9b0     : fffff6bf`fe4e6c18 ffffbc80`059c6790 00000000`00000000 fffff803`3e1687b8 : 0xffffe281`4a34f9b8
ffffb705`25e3a508 fffff6bf`fe4e6c18     : ffffbc80`059c6790 00000000`00000000 fffff803`3e1687b8 ffffb705`00000000 : 0xf9b0
ffffb705`25e3a510 ffffbc80`059c6790     : 00000000`00000000 fffff803`3e1687b8 ffffb705`00000000 00000000`00001001 : 0xfffff6bf`fe4e6c18
ffffb705`25e3a518 00000000`00000000     : fffff803`3e1687b8 ffffb705`00000000 00000000`00001001 00000000`00000fff : 0xffffbc80`059c6790
SYMBOL_NAME:  FBNetFlt+2688
MODULE_NAME: FBNetFlt
IMAGE_NAME:  FBNetFlt.sys
STACK_COMMAND:  .process /r /p 0xffffa60f0e387080; .thread 0xffffa60f322020c0 ; kb
BUCKET_ID_FUNC_OFFSET:  2688
FAILURE_BUCKET_ID:  AV_FBNetFlt!unknown_function
OSPLATFORM_TYPE:  x64
OSNAME:  Windows 10
FAILURE_ID_HASH:  {a930455f-6e65-8e8c-d1b4-40f3e912c54d}
Followup:     MachineOwner
FBNetFlt.sys dosyası, Lenovo'nun ağ ayarlarını yönetmek ve optimize etmek için kullanılan Lenovo Vantage gibi yazılımlarıyla ilişkilendirilen bir ağ filtreleme sürücüsü. Genellikle zararsız, ancak özellikle oyun oynarken veya yüksek işlem gücü gerektiren aktivitelerde "Mavi Ekran Hatası" (BSOD) sorunlarına yol açabiliyor. Vantage için güncelleme varsa yap.
Teşekkür ederim hocam hemen hallediyorum.
