Ben de öyle düşünüyorum. Mavi ekran dökümlerini paylaşabilir misiniz?Tahminim donanımsal bir sorun olabilir.
İnşallah büyük bir sorun yoktur.MediaFire
MediaFire is a simple to use free service that lets you put all your photos, documents, music, and video in a single place so you can access them anywhere and share them everywhere.www.mediafire.com
PAGE_FAULT_IN_NONPAGED_AREA (50)
Invalid system memory was referenced. This cannot be protected by try-except.
Typically the address is just plain bad or it is pointing at freed memory.
Arguments:
Arg1: ffffc5fe1b7017b8, memory referenced.
Arg2: 0000000000000002, X64: bit 0 set if the fault was due to a not-present PTE.
bit 1 is set if the fault was due to a write, clear if a read.
bit 3 is set if the processor decided the fault was due to a corrupted PTE.
bit 4 is set if the fault was due to attempted execute of a no-execute PTE.
- ARM64: bit 1 is set if the fault was due to a write, clear if a read.
bit 3 is set if the fault was due to attempted execute of a no-execute PTE.
Arg3: fffff80692befdd7, If non-zero, the instruction address which referenced the bad memory
address.
Arg4: 0000000000000002, (reserved)
Debugging Details:
*** WARNING: Unable to verify timestamp for nvlddmkm.sys
KEY_VALUES_STRING: 1
Key : AV.Type
Value: Write
Key : Analysis.CPU.mSec
Value: 1359
Key : Analysis.Elapsed.mSec
Value: 5417
Key : Analysis.IO.Other.Mb
Value: 0
Key : Analysis.IO.Read.Mb
Value: 0
Key : Analysis.IO.Write.Mb
Value: 0
Key : Analysis.Init.CPU.mSec
Value: 280
Value: 675
Value: 82
Key : Bugcheck.Code.LegacyAPI
Value: 0x50
Key : Bugcheck.Code.TargetModel
Value: 0x50
Key : Failure.Bucket
Value: AV_W_(null)_nvlddmkm!unknown_function
Key : Failure.Hash
Value: {838100fa-f28b-2ef7-d702-e31713cb338c}
Key : WER.OS.Branch
Value: vb_release
Key : WER.OS.Version
Value: 10.0.19041.1
BUGCHECK_CODE: 50
BUGCHECK_P1: ffffc5fe1b7017b8
BUGCHECK_P2: 2
BUGCHECK_P3: fffff80692befdd7
BUGCHECK_P4: 2
FILE_IN_CAB: 081624-7484-01.dmp
FAULTING_THREAD: ffffcc8f9148d040
READ_ADDRESS: fffff805634fb390: Unable to get MiVisibleState
Unable to get NonPagedPoolStart
Unable to get NonPagedPoolEnd
Unable to get PagedPoolStart
Unable to get PagedPoolEnd
unable to get nt!MmSpecialPagesInUse
ffffc5fe1b7017b8
MM_INTERNAL_CODE: 2
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: System
TRAP_FRAME: ffff85862a119910 -- (.trap 0xffff85862a119910)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=ffffc5fd88a00000 rbx=0000000000000000 rcx=0000000024b405ee
rdx=0000000092d017b8 rsi=0000000000000000 rdi=0000000000000000
rip=fffff80692befdd7 rsp=ffff85862a119aa0 rbp=000000002b139d30
r8=000000002b139d30 r9=ffff85862a119ac0 r10=ffffcc8f94621380
r11=ffff85862a119ac0 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei pl nz na po nc
nvlddmkm+0x8fdd7:
fffff806`92befdd7 891c88 mov dword ptr [rax+rcx*4],ebx ds:ffffc5fe`1b7017b8=????????
Resetting default scope
STACK_TEXT:
ffff8586`2a119668 fffff805`62c4ac53 : 00000000`00000050 ffffc5fe`1b7017b8 00000000`00000002 ffff8586`2a119910 : nt!KeBugCheckEx
ffff8586`2a119670 fffff805`62a6e7b0 : ffff8586`2a119878 00000000`00000002 ffff8586`2a119990 00000000`00000000 : nt!MiSystemFault+0x1b2273
ffff8586`2a119770 fffff805`62c0b7d8 : ffff8586`2a1199b9 fffff806`92c064cf ffffcc8f`94487000 ffffcc8f`9448898c : nt!MmAccessFault+0x400
ffff8586`2a119910 fffff806`92befdd7 : 00000000`2b139d30 00000000`2b139d30 ffffcc8f`9461fa40 ffffcc8f`9461fa40 : nt!KiPageFault+0x358
ffff8586`2a119aa0 00000000`2b139d30 : 00000000`2b139d30 ffffcc8f`9461fa40 ffffcc8f`9461fa40 00000000`92d01700 : nvlddmkm+0x8fdd7
ffff8586`2a119aa8 00000000`2b139d30 : ffffcc8f`9461fa40 ffffcc8f`9461fa40 00000000`92d01700 00000000`00000000 : 0x2b139d30
ffff8586`2a119ab0 ffffcc8f`9461fa40 : ffffcc8f`9461fa40 00000000`92d01700 00000000`00000000 00000000`00000020 : 0x2b139d30
ffff8586`2a119ab8 ffffcc8f`9461fa40 : 00000000`92d01700 00000000`00000000 00000000`00000020 fffff806`92ce5229 : 0xffffcc8f`9461fa40
ffff8586`2a119ac0 00000000`92d01700 : 00000000`00000000 00000000`00000020 fffff806`92ce5229 00000000`92d017b8 : 0xffffcc8f`9461fa40
ffff8586`2a119ac8 00000000`00000000 : 00000000`00000020 fffff806`92ce5229 00000000`92d017b8 ffffcc8f`9461f000 : 0x92d01700
SYMBOL_NAME: nvlddmkm+8fdd7
MODULE_NAME: nvlddmkm
IMAGE_NAME: nvlddmkm.sys
STACK_COMMAND: .process /r /p 0xffffcc8f880b31c0; .thread 0xffffcc8f9148d040 ; kb
BUCKET_ID_FUNC_OFFSET: 8fdd7
FAILURE_BUCKET_ID: AV_W_(null)_nvlddmkm!unknown_function
OS_VERSION: 10.0.19041.1
BUILDLAB_STR: vb_release
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {838100fa-f28b-2ef7-d702-e31713cb338c}
Followup: MachineOwner
PnpActivityId : {00000000-0000-0000-0000-000000000000}
PnpActivityTime : 133682974323825554
PnpEventInformation: 2
PnpEventInProgress : 0
PnpProblemCode : 24
PnpVetoType : 0
DeviceId : ROOT\BERTREADER\0000
VetoString :
[SMBIOS Data Tables v3.0]
[DMI Version - 0]
[2.0 Calling Convention - No]
[Table Size - 3894 bytes]
[BIOS Information (Type 0) - Length 24 - Handle 0000h]
Vendor LENOVO
BIOS Version 8TCN61WW
BIOS Starting Address Segment e000
BIOS Release Date 05/19/2021
BIOS ROM Size 5f0000
BIOS Characteristics
07: - PCI Supported
11: - Upgradeable FLASH BIOS
15: - CD-Boot Supported
19: - EDD Supported
22: - 360KB Floppy Supported
23: - 1.2MB Floppy Supported
24: - 720KB Floppy Supported
25: - 2.88MB Floppy Supported
27: - Keyboard Services Supported
49: - System Vendor Reserved
51: - System Vendor Reserved
52: - System Vendor Reserved
00: - ACPI Supported
01: - USB Legacy Supported
BIOS Major Revision 1
BIOS Minor Revision 61
EC Firmware Major Revision 1
EC Firmware Minor Revision 61
Manufacturer LENOVO
Product Name 81DM
Version Lenovo ideapad 330-17IKB
Serial Number PF195AY1
UUID 00000000-0000-0000-0000-000000000000
Wakeup Type Power Switch
SKUNumber LENOVO_MT_81DM_BU_idea_FM_ideapad 330-17IKB
Family ideapad 330-17IKB
Manufacturer LENOVO
Product LNVNB161216
Version SDK0J40679 WIN
Asset Tag
Feature Flags 09h
00: - Motherboard
03: - Replaceable
Location Type2 - Board Chassis Location
Chassis Handle 0003h
Board Type 0ah - Processor/Memory Module
Number of Child Handles 0
Manufacturer LENOVO
Chassis Type Notebook
Serial Number
Asset Tag Number
Bootup State Safe
Power Supply State Safe
Thermal State Safe
Security Status None
OEM Defined 0
Height 0U
Number of Power Cords 1
Number of Contained Elements 0
Contained Element Size 0
[Processor Information (Type 4) - Length 48 - Handle 0004h]
Socket Designation U3E1
Processor Type Central Processor
Processor Family cdh - Intel Core 2 Solo processor
Processor Manufacturer Intel(R) Corporation
Processor ID ea060800fffbebbf
Processor Version Intel(R) Core(TM) i5-8250U CPU @ 1.60GHz
Processor Voltage 86h - 0.6V
External Clock 100MHz
Max Speed 3400MHz
Current Speed 1500MHz
Status Enabled Populated
Processor Upgrade Socket BGA1356
L1 Cache Handle 0005h
L2 Cache Handle 0006h
L3 Cache Handle 0007h
Serial Number
Asset Tag Number
Part Number To Be Filled By O.E.M.
Core Count 4
Core Enabled 4
Thread Count 8
Processor Characteristics fc
Enabled Characteristics:
0x 2: 64-bit Capable
0x 3: Multi-Core
0x 4: Hardware Thread
0x 5: Execute Protection
0x 6: Enhanced Virtualization
Processor Family 2 00cdh - Intel Core 2 Solo processor
Core Count 2 4
Core Enabled 2 4
Thread Count 2 8
[Cache Information (Type 7) - Length 19 - Handle 0005h]
Socket Designation L1 Cache
Cache Configuration 0180h - WBEnabled Int NonSocketed L1
Maximum Cache Size 0100h - 256K
Installed Size 0100h - 256K
Supported SRAM Type 0020h - Synchronous
Current SRAM Type 0020h - Synchronous
Cache Speed 0ns
Error Correction Type ParitySingle-Bit ECC
System Cache Type Unified
Associativity 8-way Set-Associative
Maximum Cache Size 2 4320314c - 1126183244l Kb
[Cache Information (Type 7) - Length 19 - Handle 0006h]
Socket Designation L2 Cache
Cache Configuration 0181h - WBEnabled Int NonSocketed L2
Maximum Cache Size 0400h - 1024K
Installed Size 0400h - 1024K
Cache Speed 0ns
Error Correction Type Multi-Bit ECC
Associativity 4-way Set-Associative
Maximum Cache Size 2 4320324c - 1126183500l Kb
[Cache Information (Type 7) - Length 19 - Handle 0007h]
Socket Designation L3 Cache
Cache Configuration 0182h - WBEnabled Int NonSocketed L3
Maximum Cache Size 1800h - 6144K
Installed Size 1800h - 6144K
Cache Speed 0ns
Error Correction Type Specification Reserved
Associativity 12-way Set-Associative
Maximum Cache Size 2 4320334c - 1126183756l Kb
[OEM Strings (Type 11) - Length 5 - Handle 001eh]
Number of Strings 3
1 OemString1
2 OemString2
3 OemString3
[System Configuration Options (Type 12) - Length 5 - Handle 001fh]
[Physical Memory Array (Type 16) - Length 23 - Handle 0025h]
Location 03h - SystemBoard/Motherboard
Use 03h - System Memory
Memory Error Correction 03h - None
Maximum Capacity 33554432KB
Memory Error Inf Handle [No Errors]
Number of Memory Devices 2
[Memory Device (Type 17) - Length 40 - Handle 0026h]
Memory Error Info Handle [No Errors]
Total Width 64 bits
Data Width 64 bits
Size 4096MB
Form Factor 0dh - SODIMM
Device Set [None]
Device Locator ChannelA-DIMM0
Bank Locator BANK 0
Memory Type 1ah - DDR4
Type Detail 4080h - Synchronous Unbuffered (Unregistered)
Speed 2133MHz
Manufacturer Samsung
Serial Number
Asset Tag Number
Part Number M471A5244CB0-CRC
Attributes 1
Extended Size 0
Configured Memory Speed 2133
Minimum Voltage 1500
Maximum Voltage 1500
Configured Voltage 1200
[Memory Device (Type 17) - Length 40 - Handle 0027h]
Total Width 64 bits
Data Width 64 bits
Size 8192MB
Device Set [None]
Device Locator ChannelB-DIMM0
Bank Locator BANK 2
Speed 2133MHz
Manufacturer SK Hynix
Serial Number
Asset Tag Number
Part Number HMA81GS6CJR8N-VK
Attributes 1
Extended Size 0
Minimum Voltage 1250
[Memory Array Mapped Address (Type 19) - Length 31 - Handle 0028h]
Starting Address 00000000h
Ending Address 00bfffffh
Memory Array Handle 0025h
Partition Width 02
Extended Starting Address 0000000000000000h
Extended Ending Address 0000000000000000h
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 0029h]
Ending Address ffffffffh
Memory Device Handle 0026h
Mem Array Mapped Adr Handle 0028h
Partition Row Position [Unknown]
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 002ah]
Memory Device Handle 0027h
[ (Type 256) - Length 17 - Handle 0033h]
[ (Type 256) - Length 11 - Handle 0034h]
[ (Type 256) - Length 8 - Handle 0035h]
[ (Type 256) - Length 8 - Handle 0036h]
[ (Type 256) - Length 20 - Handle 0037h]
[ (Type 256) - Length 64 - Handle 0038h]
[ (Type 256) - Length 5 - Handle 0039h]
[ (Type 256) - Length 6 - Handle 003ah]
[ (Type 256) - Length 81 - Handle 003ch]
[ (Type 256) - Length 26 - Handle 003dh]
[ (Type 256) - Length 26 - Handle 003eh]
[ (Type 256) - Length 75 - Handle 003fh]
[ (Type 256) - Length 54 - Handle 0040h]
[ (Type 256) - Length 103 - Handle 0041h]
[ (Type 256) - Length 14 - Handle 0042h]
[ (Type 256) - Length 18 - Handle 0043h]
[ (Type 256) - Length 4 - Handle feffh]
Arguments:
Arg1: ffffd0ffaf2d17b8, memory referenced.
Arg3: fffff805507bfdd7, If non-zero, the instruction address which referenced the bad memory
address.
Debugging Details:
Key : AV.Type
Value: Write
Value: 1296
Value: 7956
Value: 0
Value: 0
Value: 0
Value: 233
Value: 675
Value: 82
Value: 0x50
Value: 0x50
Key : Failure.Hash
Key : WER.OS.Branch
Value: vb_release
Value: 10.0.19041.1
BUGCHECK_CODE: 50
BUGCHECK_P1: ffffd0ffaf2d17b8
BUGCHECK_P2: 2
BUGCHECK_P3: fffff805507bfdd7
BUGCHECK_P4: 2
FILE_IN_CAB: 081624-7640-01.dmp
FAULTING_THREAD: ffffd50577bef040
READ_ADDRESS: fffff805188fb390: Unable to get MiVisibleState
ffffd0ffaf2d17b8
MM_INTERNAL_CODE: 2
BLACKBOXWINLOGON: 1
TRAP_FRAME: ffffbd88de125910 -- (.trap 0xffffbd88de125910)
rax=ffffd0ff5ea00000 rbx=0000000000000000 rcx=00000000142345ee
rdx=00000000508d17b8 rsi=0000000000000000 rdi=0000000000000000
rip=fffff805507bfdd7 rsp=ffffbd88de125aa0 rbp=00000000df135d30
r8=00000000df135d30 r9=ffffbd88de125ac0 r10=ffffd50573b52380
r11=ffffbd88de125ac0 r12=0000000000000000 r13=0000000000000000
nvlddmkm+0x8fdd7:
fffff805`507bfdd7 891c88 mov dword ptr [rax+rcx*4],ebx ds:ffffd0ff`af2d17b8=????????
STACK_TEXT:
ffffbd88`de125668 fffff805`1804ac53 : 00000000`00000050 ffffd0ff`af2d17b8 00000000`00000002 ffffbd88`de125910 : nt!KeBugCheckEx
ffffbd88`de125670 fffff805`17e6e7b0 : ffffbd88`de125878 00000000`00000002 ffffbd88`de125990 00000000`00000000 : nt!MiSystemFault+0x1b2273
ffffbd88`de125770 fffff805`1800b7d8 : ffffbd88`de1259b9 fffff805`507d64cf ffffd505`7a44e000 ffffd505`7a44f98c : nt!MmAccessFault+0x400
ffffbd88`de125910 fffff805`507bfdd7 : 00000000`df135d30 00000000`df135d30 ffffd505`73b50a40 ffffd505`73b50a40 : nt!KiPageFault+0x358
ffffbd88`de125aa0 00000000`df135d30 : 00000000`df135d30 ffffd505`73b50a40 ffffd505`73b50a40 00000000`508d1700 : nvlddmkm+0x8fdd7
ffffbd88`de125aa8 00000000`df135d30 : ffffd505`73b50a40 ffffd505`73b50a40 00000000`508d1700 00000000`00000000 : 0xdf135d30
ffffbd88`de125ab0 ffffd505`73b50a40 : ffffd505`73b50a40 00000000`508d1700 00000000`00000000 00000000`00000020 : 0xdf135d30
ffffbd88`de125ab8 ffffd505`73b50a40 : 00000000`508d1700 00000000`00000000 00000000`00000020 fffff805`508b5229 : 0xffffd505`73b50a40
ffffbd88`de125ac0 00000000`508d1700 : 00000000`00000000 00000000`00000020 fffff805`508b5229 00000000`508d17b8 : 0xffffd505`73b50a40
ffffbd88`de125ac8 00000000`00000000 : 00000000`00000020 fffff805`508b5229 00000000`508d17b8 ffffd505`73b50000 : 0x508d1700
STACK_COMMAND: .process /r /p 0xffffd5056e6ce080; .thread 0xffffd50577bef040 ; kb
OSNAME: Windows 10
PnpActivityTime : 133682971356365207
PnpEventInformation: 0
PnpProblemCode : 21
PnpVetoType : 0
DeviceId : PCI\VEN_10DE&DEV_1D10&SUBSYS_396317AA&REV_A1\4&143356b3&0&00E0
VetoString :
[DMI Version - 0]
Vendor LENOVO
07: - PCI Supported
19: - EDD Supported
Manufacturer LENOVO
Product Name 81DM
Manufacturer LENOVO
Product LNVNB161216
Asset Tag
Feature Flags 09h
00: - Motherboard
03: - Replaceable
Manufacturer LENOVO
Serial Number
Asset Tag Number
Bootup State Safe
Thermal State Safe
OEM Defined 0
Height 0U
Max Speed 3400MHz
Serial Number
Asset Tag Number
Core Count 4
Core Enabled 4
Thread Count 8
0x 3: Multi-Core
Core Count 2 4
Core Enabled 2 4
Thread Count 2 8
Cache Speed 0ns
Cache Speed 0ns
Cache Speed 0ns
Number of Strings 3
1 OemString1
2 OemString2
3 OemString3
Total Width 64 bits
Data Width 64 bits
Size 4096MB
Device Set [None]
Bank Locator BANK 0
Speed 2133MHz
Serial Number
Asset Tag Number
Attributes 1
Extended Size 0
Total Width 64 bits
Data Width 64 bits
Size 8192MB
Device Set [None]
Bank Locator BANK 2
Speed 2133MHz
Serial Number
Asset Tag Number
Attributes 1
Extended Size 0
Partition Width 02
Arguments:
Arg1: ffff9f7b72d79ee8, memory referenced.
Arg3: fffff8040e15bfc2, If non-zero, the instruction address which referenced the bad memory
address.
Debugging Details:
Key : AV.Type
Value: Write
Value: 1187
Value: 9627
Value: 0
Value: 0
Value: 0
Value: 218
Value: 665
Value: 82
Value: 0x50
Value: 0x50
Key : Failure.Hash
Key : WER.OS.Branch
Value: vb_release
Value: 10.0.19041.1
BUGCHECK_CODE: 50
BUGCHECK_P1: ffff9f7b72d79ee8
BUGCHECK_P2: 2
BUGCHECK_P3: fffff8040e15bfc2
BUGCHECK_P4: 2
FILE_IN_CAB: 081624-9593-01.dmp
FAULTING_THREAD: ffffcb088e275040
READ_ADDRESS: fffff80275afb390: Unable to get MiVisibleState
ffff9f7b72d79ee8
MM_INTERNAL_CODE: 2
BLACKBOXWINLOGON: 1
TRAP_FRAME: ffffdb08e9e1e9b0 -- (.trap 0xffffdb08e9e1e9b0)
rax=0000000095cf5000 rbx=0000000000000000 rcx=ffff9f7b64c00000
rdx=000000000385e7ba rsi=0000000000000000 rdi=0000000000000000
rip=fffff8040e15bfc2 rsp=ffffdb08e9e1eb48 rbp=0000000000000000
r8=ffffcb0895cc61d8 r9=000000000e179eeb r10=ffffcb0895cc5000
r11=ffffdb08e9e1eb30 r12=0000000000000000 r13=0000000000000000
iopl=0 nv up ei pl nz na pe cy
nvlddmkm+0xfbfc2:
fffff804`0e15bfc2 890491 mov dword ptr [rcx+rdx*4],eax ds:ffff9f7b`72d79ee8=????????
STACK_TEXT:
ffffdb08`e9e1e708 fffff802`7524ac53 : 00000000`00000050 ffff9f7b`72d79ee8 00000000`00000002 ffffdb08`e9e1e9b0 : nt!KeBugCheckEx
ffffdb08`e9e1e710 fffff802`7506e7b0 : 00000000`00000000 00000000`00000002 ffffdb08`e9e1ea30 00000000`00000000 : nt!MiSystemFault+0x1b2273
ffffdb08`e9e1e810 fffff802`7520b7d8 : 00000000`00000000 ffffdb08`e9e1ea98 fffff804`0e475342 00000000`00000002 : nt!MmAccessFault+0x400
ffffdb08`e9e1e9b0 fffff804`0e15bfc2 : fffff804`0e57ab34 00000000`95cf5000 00000000`00000000 00000000`0e179eeb : nt!KiPageFault+0x358
ffffdb08`e9e1eb48 fffff804`0e57ab34 : 00000000`95cf5000 00000000`00000000 00000000`0e179eeb fffff804`0e15f16e : nvlddmkm+0xfbfc2
ffffdb08`e9e1eb50 00000000`95cf5000 : 00000000`00000000 00000000`0e179eeb fffff804`0e15f16e ffffcb08`95cf5000 : nvlddmkm+0x51ab34
ffffdb08`e9e1eb58 00000000`00000000 : 00000000`0e179eeb fffff804`0e15f16e ffffcb08`95cf5000 fffff804`00000020 : 0x95cf5000
SYMBOL_NAME: nvlddmkm+fbfc2
STACK_COMMAND: .process /r /p 0xffffcb0885e9b040; .thread 0xffffcb088e275040 ; kb
BUCKET_ID_FUNC_OFFSET: fbfc2
OSNAME: Windows 10
PnpActivityTime : 133682899479655301
PnpEventInformation: 3
PnpProblemCode : 24
PnpVetoType : 0
DeviceId : SW\{96E080C7-143C-11D1-B40F-00A0C9223196}\{3C0D501A-140B-11D1-B40F-00A0C9223196}
VetoString :
[DMI Version - 0]
Vendor LENOVO
07: - PCI Supported
19: - EDD Supported
Manufacturer LENOVO
Product Name 81DM
Manufacturer LENOVO
Product LNVNB161216
Asset Tag
Feature Flags 09h
00: - Motherboard
03: - Replaceable
Manufacturer LENOVO
Serial Number
Asset Tag Number
Bootup State Safe
Thermal State Safe
OEM Defined 0
Height 0U
Max Speed 3400MHz
Serial Number
Asset Tag Number
Core Count 4
Core Enabled 4
Thread Count 8
0x 3: Multi-Core
Core Count 2 4
Core Enabled 2 4
Thread Count 2 8
Cache Speed 0ns
Cache Speed 0ns
Cache Speed 0ns
Number of Strings 3
1 OemString1
2 OemString2
3 OemString3
Total Width 64 bits
Data Width 64 bits
Size 4096MB
Device Set [None]
Bank Locator BANK 0
Speed 2133MHz
Serial Number
Asset Tag Number
Attributes 1
Extended Size 0
Total Width 64 bits
Data Width 64 bits
Size 8192MB
Device Set [None]
Bank Locator BANK 2
Speed 2133MHz
Serial Number
Asset Tag Number
Attributes 1
Extended Size 0
Partition Width 02
Ekran kartınız arızalanmış gibi.
Kod:PAGE_FAULT_IN_NONPAGED_AREA (50) Invalid system memory was referenced. This cannot be protected by try-except. Typically the address is just plain bad or it is pointing at freed memory. Arguments: Arg1: ffffc5fe1b7017b8, memory referenced. Arg2: 0000000000000002, X64: bit 0 set if the fault was due to a not-present PTE. bit 1 is set if the fault was due to a write, clear if a read. bit 3 is set if the processor decided the fault was due to a corrupted PTE. bit 4 is set if the fault was due to attempted execute of a no-execute PTE. - ARM64: bit 1 is set if the fault was due to a write, clear if a read. bit 3 is set if the fault was due to attempted execute of a no-execute PTE. Arg3: fffff80692befdd7, If non-zero, the instruction address which referenced the bad memory address. Arg4: 0000000000000002, (reserved) Debugging Details: ------------------ *** WARNING: Unable to verify timestamp for nvlddmkm.sys KEY_VALUES_STRING: 1 Key : AV.Type Value: Write Key : Analysis.CPU.mSec Value: 1359 Key : Analysis.Elapsed.mSec Value: 5417 Key : Analysis.IO.Other.Mb Value: 0 Key : Analysis.IO.Read.Mb Value: 0 Key : Analysis.IO.Write.Mb Value: 0 Key : Analysis.Init.CPU.mSec Value: 280 Key : Analysis.Init.Elapsed.mSec Value: 675 Key : Analysis.Memory.CommitPeak.Mb Value: 82 Key : Bugcheck.Code.LegacyAPI Value: 0x50 Key : Bugcheck.Code.TargetModel Value: 0x50 Key : Failure.Bucket Value: AV_W_(null)_nvlddmkm!unknown_function Key : Failure.Hash Value: {838100fa-f28b-2ef7-d702-e31713cb338c} Key : WER.OS.Branch Value: vb_release Key : WER.OS.Version Value: 10.0.19041.1 BUGCHECK_CODE: 50 BUGCHECK_P1: ffffc5fe1b7017b8 BUGCHECK_P2: 2 BUGCHECK_P3: fffff80692befdd7 BUGCHECK_P4: 2 FILE_IN_CAB: 081624-7484-01.dmp FAULTING_THREAD: ffffcc8f9148d040 READ_ADDRESS: fffff805634fb390: Unable to get MiVisibleState Unable to get NonPagedPoolStart Unable to get NonPagedPoolEnd Unable to get PagedPoolStart Unable to get PagedPoolEnd unable to get nt!MmSpecialPagesInUse ffffc5fe1b7017b8 MM_INTERNAL_CODE: 2 BLACKBOXBSD: 1 (!blackboxbsd) BLACKBOXNTFS: 1 (!blackboxntfs) BLACKBOXPNP: 1 (!blackboxpnp) BLACKBOXWINLOGON: 1 CUSTOMER_CRASH_COUNT: 1 PROCESS_NAME: System TRAP_FRAME: ffff85862a119910 -- (.trap 0xffff85862a119910) NOTE: The trap frame does not contain all registers. Some register values may be zeroed or incorrect. rax=ffffc5fd88a00000 rbx=0000000000000000 rcx=0000000024b405ee rdx=0000000092d017b8 rsi=0000000000000000 rdi=0000000000000000 rip=fffff80692befdd7 rsp=ffff85862a119aa0 rbp=000000002b139d30 r8=000000002b139d30 r9=ffff85862a119ac0 r10=ffffcc8f94621380 r11=ffff85862a119ac0 r12=0000000000000000 r13=0000000000000000 r14=0000000000000000 r15=0000000000000000 iopl=0 nv up ei pl nz na po nc nvlddmkm+0x8fdd7: fffff806`92befdd7 891c88 mov dword ptr [rax+rcx*4],ebx ds:ffffc5fe`1b7017b8=???????? Resetting default scope STACK_TEXT: ffff8586`2a119668 fffff805`62c4ac53 : 00000000`00000050 ffffc5fe`1b7017b8 00000000`00000002 ffff8586`2a119910 : nt!KeBugCheckEx ffff8586`2a119670 fffff805`62a6e7b0 : ffff8586`2a119878 00000000`00000002 ffff8586`2a119990 00000000`00000000 : nt!MiSystemFault+0x1b2273 ffff8586`2a119770 fffff805`62c0b7d8 : ffff8586`2a1199b9 fffff806`92c064cf ffffcc8f`94487000 ffffcc8f`9448898c : nt!MmAccessFault+0x400 ffff8586`2a119910 fffff806`92befdd7 : 00000000`2b139d30 00000000`2b139d30 ffffcc8f`9461fa40 ffffcc8f`9461fa40 : nt!KiPageFault+0x358 ffff8586`2a119aa0 00000000`2b139d30 : 00000000`2b139d30 ffffcc8f`9461fa40 ffffcc8f`9461fa40 00000000`92d01700 : nvlddmkm+0x8fdd7 ffff8586`2a119aa8 00000000`2b139d30 : ffffcc8f`9461fa40 ffffcc8f`9461fa40 00000000`92d01700 00000000`00000000 : 0x2b139d30 ffff8586`2a119ab0 ffffcc8f`9461fa40 : ffffcc8f`9461fa40 00000000`92d01700 00000000`00000000 00000000`00000020 : 0x2b139d30 ffff8586`2a119ab8 ffffcc8f`9461fa40 : 00000000`92d01700 00000000`00000000 00000000`00000020 fffff806`92ce5229 : 0xffffcc8f`9461fa40 ffff8586`2a119ac0 00000000`92d01700 : 00000000`00000000 00000000`00000020 fffff806`92ce5229 00000000`92d017b8 : 0xffffcc8f`9461fa40 ffff8586`2a119ac8 00000000`00000000 : 00000000`00000020 fffff806`92ce5229 00000000`92d017b8 ffffcc8f`9461f000 : 0x92d01700 SYMBOL_NAME: nvlddmkm+8fdd7 MODULE_NAME: nvlddmkm IMAGE_NAME: nvlddmkm.sys STACK_COMMAND: .process /r /p 0xffffcc8f880b31c0; .thread 0xffffcc8f9148d040 ; kb BUCKET_ID_FUNC_OFFSET: 8fdd7 FAILURE_BUCKET_ID: AV_W_(null)_nvlddmkm!unknown_function OS_VERSION: 10.0.19041.1 BUILDLAB_STR: vb_release OSPLATFORM_TYPE: x64 OSNAME: Windows 10 FAILURE_ID_HASH: {838100fa-f28b-2ef7-d702-e31713cb338c} Followup: MachineOwner --------- PnpActivityId : {00000000-0000-0000-0000-000000000000} PnpActivityTime : 133682974323825554 PnpEventInformation: 2 PnpEventInProgress : 0 PnpProblemCode : 24 PnpVetoType : 0 DeviceId : ROOT\BERTREADER\0000 VetoString : [SMBIOS Data Tables v3.0] [DMI Version - 0] [2.0 Calling Convention - No] [Table Size - 3894 bytes] [BIOS Information (Type 0) - Length 24 - Handle 0000h] Vendor LENOVO BIOS Version 8TCN61WW BIOS Starting Address Segment e000 BIOS Release Date 05/19/2021 BIOS ROM Size 5f0000 BIOS Characteristics 07: - PCI Supported 11: - Upgradeable FLASH BIOS 12: - BIOS Shadowing Supported 15: - CD-Boot Supported 16: - Selectable Boot Supported 19: - EDD Supported 20: - NEC 9800 J-Floppy Supported 21: - Toshiba J-Floppy Supported 22: - 360KB Floppy Supported 23: - 1.2MB Floppy Supported 24: - 720KB Floppy Supported 25: - 2.88MB Floppy Supported 27: - Keyboard Services Supported 30: - CGA/Mono Services Supported 49: - System Vendor Reserved 51: - System Vendor Reserved 52: - System Vendor Reserved BIOS Characteristic Extensions 00: - ACPI Supported 01: - USB Legacy Supported 08: - BIOS Boot Specification Supported 10: - Enable Targeted Content Distribution 11: - UEFI Specification Supported BIOS Major Revision 1 BIOS Minor Revision 61 EC Firmware Major Revision 1 EC Firmware Minor Revision 61 [System Information (Type 1) - Length 27 - Handle 0001h] Manufacturer LENOVO Product Name 81DM Version Lenovo ideapad 330-17IKB Serial Number PF195AY1 UUID 00000000-0000-0000-0000-000000000000 Wakeup Type Power Switch SKUNumber LENOVO_MT_81DM_BU_idea_FM_ideapad 330-17IKB Family ideapad 330-17IKB [BaseBoard Information (Type 2) - Length 15 - Handle 0002h] Manufacturer LENOVO Product LNVNB161216 Version SDK0J40679 WIN Serial Number PF195AY1 Asset Tag Feature Flags 09h 00: - Motherboard 03: - Replaceable Location Type2 - Board Chassis Location Chassis Handle 0003h Board Type 0ah - Processor/Memory Module Number of Child Handles 0 [System Enclosure (Type 3) - Length 22 - Handle 0003h] Manufacturer LENOVO Chassis Type Notebook Version Lenovo ideapad 330-17IKB Serial Number Asset Tag Number Bootup State Safe Power Supply State Safe Thermal State Safe Security Status None OEM Defined 0 Height 0U Number of Power Cords 1 Number of Contained Elements 0 Contained Element Size 0 [Processor Information (Type 4) - Length 48 - Handle 0004h] Socket Designation U3E1 Processor Type Central Processor Processor Family cdh - Intel Core 2 Solo processor Processor Manufacturer Intel(R) Corporation Processor ID ea060800fffbebbf Processor Version Intel(R) Core(TM) i5-8250U CPU @ 1.60GHz Processor Voltage 86h - 0.6V External Clock 100MHz Max Speed 3400MHz Current Speed 1500MHz Status Enabled Populated Processor Upgrade Socket BGA1356 L1 Cache Handle 0005h L2 Cache Handle 0006h L3 Cache Handle 0007h Serial Number Asset Tag Number Part Number To Be Filled By O.E.M. Core Count 4 Core Enabled 4 Thread Count 8 Processor Characteristics fc Enabled Characteristics: 0x 2: 64-bit Capable 0x 3: Multi-Core 0x 4: Hardware Thread 0x 5: Execute Protection 0x 6: Enhanced Virtualization 0x 7: Power/Performance Control Processor Family 2 00cdh - Intel Core 2 Solo processor Core Count 2 4 Core Enabled 2 4 Thread Count 2 8 [Cache Information (Type 7) - Length 19 - Handle 0005h] Socket Designation L1 Cache Cache Configuration 0180h - WBEnabled Int NonSocketed L1 Maximum Cache Size 0100h - 256K Installed Size 0100h - 256K Supported SRAM Type 0020h - Synchronous Current SRAM Type 0020h - Synchronous Cache Speed 0ns Error Correction Type ParitySingle-Bit ECC System Cache Type Unified Associativity 8-way Set-Associative Maximum Cache Size 2 4320314c - 1126183244l Kb [Cache Information (Type 7) - Length 19 - Handle 0006h] Socket Designation L2 Cache Cache Configuration 0181h - WBEnabled Int NonSocketed L2 Maximum Cache Size 0400h - 1024K Installed Size 0400h - 1024K Supported SRAM Type 0020h - Synchronous Current SRAM Type 0020h - Synchronous Cache Speed 0ns Error Correction Type Multi-Bit ECC System Cache Type Unified Associativity 4-way Set-Associative Maximum Cache Size 2 4320324c - 1126183500l Kb [Cache Information (Type 7) - Length 19 - Handle 0007h] Socket Designation L3 Cache Cache Configuration 0182h - WBEnabled Int NonSocketed L3 Maximum Cache Size 1800h - 6144K Installed Size 1800h - 6144K Supported SRAM Type 0020h - Synchronous Current SRAM Type 0020h - Synchronous Cache Speed 0ns Error Correction Type Specification Reserved System Cache Type Unified Associativity 12-way Set-Associative Maximum Cache Size 2 4320334c - 1126183756l Kb [OEM Strings (Type 11) - Length 5 - Handle 001eh] Number of Strings 3 1 OemString1 2 OemString2 3 OemString3 [System Configuration Options (Type 12) - Length 5 - Handle 001fh] [Physical Memory Array (Type 16) - Length 23 - Handle 0025h] Location 03h - SystemBoard/Motherboard Use 03h - System Memory Memory Error Correction 03h - None Maximum Capacity 33554432KB Memory Error Inf Handle [No Errors] Number of Memory Devices 2 [Memory Device (Type 17) - Length 40 - Handle 0026h] Memory Error Info Handle [No Errors] Total Width 64 bits Data Width 64 bits Size 4096MB Form Factor 0dh - SODIMM Device Set [None] Device Locator ChannelA-DIMM0 Bank Locator BANK 0 Memory Type 1ah - DDR4 Type Detail 4080h - Synchronous Unbuffered (Unregistered) Speed 2133MHz Manufacturer Samsung Serial Number Asset Tag Number Part Number M471A5244CB0-CRC Attributes 1 Extended Size 0 Configured Memory Speed 2133 Minimum Voltage 1500 Maximum Voltage 1500 Configured Voltage 1200 [Memory Device (Type 17) - Length 40 - Handle 0027h] Memory Error Info Handle [No Errors] Total Width 64 bits Data Width 64 bits Size 8192MB Form Factor 0dh - SODIMM Device Set [None] Device Locator ChannelB-DIMM0 Bank Locator BANK 2 Memory Type 1ah - DDR4 Type Detail 4080h - Synchronous Unbuffered (Unregistered) Speed 2133MHz Manufacturer SK Hynix Serial Number Asset Tag Number Part Number HMA81GS6CJR8N-VK Attributes 1 Extended Size 0 Configured Memory Speed 2133 Minimum Voltage 1250 Maximum Voltage 1500 Configured Voltage 1200 [Memory Array Mapped Address (Type 19) - Length 31 - Handle 0028h] Starting Address 00000000h Ending Address 00bfffffh Memory Array Handle 0025h Partition Width 02 Extended Starting Address 0000000000000000h Extended Ending Address 0000000000000000h [Memory Device Mapped Address (Type 20) - Length 35 - Handle 0029h] Starting Address 00000000h Ending Address ffffffffh Memory Device Handle 0026h Mem Array Mapped Adr Handle 0028h Partition Row Position [Unknown] Extended Starting Address 0000000000000000h Extended Ending Address 0000000000000000h [Memory Device Mapped Address (Type 20) - Length 35 - Handle 002ah] Starting Address 00000000h Ending Address ffffffffh Memory Device Handle 0027h Mem Array Mapped Adr Handle 0028h Partition Row Position [Unknown] Extended Starting Address 0000000000000000h Extended Ending Address 0000000000000000h [ (Type 256) - Length 17 - Handle 0033h] [ (Type 256) - Length 11 - Handle 0034h] [ (Type 256) - Length 8 - Handle 0035h] [ (Type 256) - Length 8 - Handle 0036h] [ (Type 256) - Length 20 - Handle 0037h] [ (Type 256) - Length 64 - Handle 0038h] [ (Type 256) - Length 5 - Handle 0039h] [ (Type 256) - Length 6 - Handle 003ah] [ (Type 256) - Length 81 - Handle 003ch] [ (Type 256) - Length 26 - Handle 003dh] [ (Type 256) - Length 26 - Handle 003eh] [ (Type 256) - Length 75 - Handle 003fh] [ (Type 256) - Length 54 - Handle 0040h] [ (Type 256) - Length 103 - Handle 0041h] [ (Type 256) - Length 14 - Handle 0042h] [ (Type 256) - Length 18 - Handle 0043h] [ (Type 256) - Length 4 - Handle feffh] PAGE_FAULT_IN_NONPAGED_AREA (50) Invalid system memory was referenced. This cannot be protected by try-except. Typically the address is just plain bad or it is pointing at freed memory. Arguments: Arg1: ffffd0ffaf2d17b8, memory referenced. Arg2: 0000000000000002, X64: bit 0 set if the fault was due to a not-present PTE. bit 1 is set if the fault was due to a write, clear if a read. bit 3 is set if the processor decided the fault was due to a corrupted PTE. bit 4 is set if the fault was due to attempted execute of a no-execute PTE. - ARM64: bit 1 is set if the fault was due to a write, clear if a read. bit 3 is set if the fault was due to attempted execute of a no-execute PTE. Arg3: fffff805507bfdd7, If non-zero, the instruction address which referenced the bad memory address. Arg4: 0000000000000002, (reserved) Debugging Details: ------------------ *** WARNING: Unable to verify timestamp for nvlddmkm.sys KEY_VALUES_STRING: 1 Key : AV.Type Value: Write Key : Analysis.CPU.mSec Value: 1296 Key : Analysis.Elapsed.mSec Value: 7956 Key : Analysis.IO.Other.Mb Value: 0 Key : Analysis.IO.Read.Mb Value: 0 Key : Analysis.IO.Write.Mb Value: 0 Key : Analysis.Init.CPU.mSec Value: 233 Key : Analysis.Init.Elapsed.mSec Value: 675 Key : Analysis.Memory.CommitPeak.Mb Value: 82 Key : Bugcheck.Code.LegacyAPI Value: 0x50 Key : Bugcheck.Code.TargetModel Value: 0x50 Key : Failure.Bucket Value: AV_W_(null)_nvlddmkm!unknown_function Key : Failure.Hash Value: {838100fa-f28b-2ef7-d702-e31713cb338c} Key : WER.OS.Branch Value: vb_release Key : WER.OS.Version Value: 10.0.19041.1 BUGCHECK_CODE: 50 BUGCHECK_P1: ffffd0ffaf2d17b8 BUGCHECK_P2: 2 BUGCHECK_P3: fffff805507bfdd7 BUGCHECK_P4: 2 FILE_IN_CAB: 081624-7640-01.dmp FAULTING_THREAD: ffffd50577bef040 READ_ADDRESS: fffff805188fb390: Unable to get MiVisibleState Unable to get NonPagedPoolStart Unable to get NonPagedPoolEnd Unable to get PagedPoolStart Unable to get PagedPoolEnd unable to get nt!MmSpecialPagesInUse ffffd0ffaf2d17b8 MM_INTERNAL_CODE: 2 BLACKBOXBSD: 1 (!blackboxbsd) BLACKBOXNTFS: 1 (!blackboxntfs) BLACKBOXPNP: 1 (!blackboxpnp) BLACKBOXWINLOGON: 1 CUSTOMER_CRASH_COUNT: 1 PROCESS_NAME: System TRAP_FRAME: ffffbd88de125910 -- (.trap 0xffffbd88de125910) NOTE: The trap frame does not contain all registers. Some register values may be zeroed or incorrect. rax=ffffd0ff5ea00000 rbx=0000000000000000 rcx=00000000142345ee rdx=00000000508d17b8 rsi=0000000000000000 rdi=0000000000000000 rip=fffff805507bfdd7 rsp=ffffbd88de125aa0 rbp=00000000df135d30 r8=00000000df135d30 r9=ffffbd88de125ac0 r10=ffffd50573b52380 r11=ffffbd88de125ac0 r12=0000000000000000 r13=0000000000000000 r14=0000000000000000 r15=0000000000000000 iopl=0 nv up ei pl nz na po nc nvlddmkm+0x8fdd7: fffff805`507bfdd7 891c88 mov dword ptr [rax+rcx*4],ebx ds:ffffd0ff`af2d17b8=???????? Resetting default scope STACK_TEXT: ffffbd88`de125668 fffff805`1804ac53 : 00000000`00000050 ffffd0ff`af2d17b8 00000000`00000002 ffffbd88`de125910 : nt!KeBugCheckEx ffffbd88`de125670 fffff805`17e6e7b0 : ffffbd88`de125878 00000000`00000002 ffffbd88`de125990 00000000`00000000 : nt!MiSystemFault+0x1b2273 ffffbd88`de125770 fffff805`1800b7d8 : ffffbd88`de1259b9 fffff805`507d64cf ffffd505`7a44e000 ffffd505`7a44f98c : nt!MmAccessFault+0x400 ffffbd88`de125910 fffff805`507bfdd7 : 00000000`df135d30 00000000`df135d30 ffffd505`73b50a40 ffffd505`73b50a40 : nt!KiPageFault+0x358 ffffbd88`de125aa0 00000000`df135d30 : 00000000`df135d30 ffffd505`73b50a40 ffffd505`73b50a40 00000000`508d1700 : nvlddmkm+0x8fdd7 ffffbd88`de125aa8 00000000`df135d30 : ffffd505`73b50a40 ffffd505`73b50a40 00000000`508d1700 00000000`00000000 : 0xdf135d30 ffffbd88`de125ab0 ffffd505`73b50a40 : ffffd505`73b50a40 00000000`508d1700 00000000`00000000 00000000`00000020 : 0xdf135d30 ffffbd88`de125ab8 ffffd505`73b50a40 : 00000000`508d1700 00000000`00000000 00000000`00000020 fffff805`508b5229 : 0xffffd505`73b50a40 ffffbd88`de125ac0 00000000`508d1700 : 00000000`00000000 00000000`00000020 fffff805`508b5229 00000000`508d17b8 : 0xffffd505`73b50a40 ffffbd88`de125ac8 00000000`00000000 : 00000000`00000020 fffff805`508b5229 00000000`508d17b8 ffffd505`73b50000 : 0x508d1700 SYMBOL_NAME: nvlddmkm+8fdd7 MODULE_NAME: nvlddmkm IMAGE_NAME: nvlddmkm.sys STACK_COMMAND: .process /r /p 0xffffd5056e6ce080; .thread 0xffffd50577bef040 ; kb BUCKET_ID_FUNC_OFFSET: 8fdd7 FAILURE_BUCKET_ID: AV_W_(null)_nvlddmkm!unknown_function OS_VERSION: 10.0.19041.1 BUILDLAB_STR: vb_release OSPLATFORM_TYPE: x64 OSNAME: Windows 10 FAILURE_ID_HASH: {838100fa-f28b-2ef7-d702-e31713cb338c} Followup: MachineOwner --------- PnpActivityId : {00000000-0000-0000-0000-000000000000} PnpActivityTime : 133682971356365207 PnpEventInformation: 0 PnpEventInProgress : 0 PnpProblemCode : 21 PnpVetoType : 0 DeviceId : PCI\VEN_10DE&DEV_1D10&SUBSYS_396317AA&REV_A1\4&143356b3&0&00E0 VetoString : [SMBIOS Data Tables v3.0] [DMI Version - 0] [2.0 Calling Convention - No] [Table Size - 3894 bytes] [BIOS Information (Type 0) - Length 24 - Handle 0000h] Vendor LENOVO BIOS Version 8TCN61WW BIOS Starting Address Segment e000 BIOS Release Date 05/19/2021 BIOS ROM Size 5f0000 BIOS Characteristics 07: - PCI Supported 11: - Upgradeable FLASH BIOS 12: - BIOS Shadowing Supported 15: - CD-Boot Supported 16: - Selectable Boot Supported 19: - EDD Supported 20: - NEC 9800 J-Floppy Supported 21: - Toshiba J-Floppy Supported 22: - 360KB Floppy Supported 23: - 1.2MB Floppy Supported 24: - 720KB Floppy Supported 25: - 2.88MB Floppy Supported 27: - Keyboard Services Supported 30: - CGA/Mono Services Supported 49: - System Vendor Reserved 51: - System Vendor Reserved 52: - System Vendor Reserved BIOS Characteristic Extensions 00: - ACPI Supported 01: - USB Legacy Supported 08: - BIOS Boot Specification Supported 10: - Enable Targeted Content Distribution 11: - UEFI Specification Supported BIOS Major Revision 1 BIOS Minor Revision 61 EC Firmware Major Revision 1 EC Firmware Minor Revision 61 [System Information (Type 1) - Length 27 - Handle 0001h] Manufacturer LENOVO Product Name 81DM Version Lenovo ideapad 330-17IKB Serial Number PF195AY1 UUID 00000000-0000-0000-0000-000000000000 Wakeup Type Power Switch SKUNumber LENOVO_MT_81DM_BU_idea_FM_ideapad 330-17IKB Family ideapad 330-17IKB [BaseBoard Information (Type 2) - Length 15 - Handle 0002h] Manufacturer LENOVO Product LNVNB161216 Version SDK0J40679 WIN Serial Number PF195AY1 Asset Tag Feature Flags 09h 00: - Motherboard 03: - Replaceable Location Type2 - Board Chassis Location Chassis Handle 0003h Board Type 0ah - Processor/Memory Module Number of Child Handles 0 [System Enclosure (Type 3) - Length 22 - Handle 0003h] Manufacturer LENOVO Chassis Type Notebook Version Lenovo ideapad 330-17IKB Serial Number Asset Tag Number Bootup State Safe Power Supply State Safe Thermal State Safe Security Status None OEM Defined 0 Height 0U Number of Power Cords 1 Number of Contained Elements 0 Contained Element Size 0 [Processor Information (Type 4) - Length 48 - Handle 0004h] Socket Designation U3E1 Processor Type Central Processor Processor Family cdh - Intel Core 2 Solo processor Processor Manufacturer Intel(R) Corporation Processor ID ea060800fffbebbf Processor Version Intel(R) Core(TM) i5-8250U CPU @ 1.60GHz Processor Voltage 86h - 0.6V External Clock 100MHz Max Speed 3400MHz Current Speed 1500MHz Status Enabled Populated Processor Upgrade Socket BGA1356 L1 Cache Handle 0005h L2 Cache Handle 0006h L3 Cache Handle 0007h Serial Number Asset Tag Number Part Number To Be Filled By O.E.M. Core Count 4 Core Enabled 4 Thread Count 8 Processor Characteristics fc Enabled Characteristics: 0x 2: 64-bit Capable 0x 3: Multi-Core 0x 4: Hardware Thread 0x 5: Execute Protection 0x 6: Enhanced Virtualization 0x 7: Power/Performance Control Processor Family 2 00cdh - Intel Core 2 Solo processor Core Count 2 4 Core Enabled 2 4 Thread Count 2 8 [Cache Information (Type 7) - Length 19 - Handle 0005h] Socket Designation L1 Cache Cache Configuration 0180h - WBEnabled Int NonSocketed L1 Maximum Cache Size 0100h - 256K Installed Size 0100h - 256K Supported SRAM Type 0020h - Synchronous Current SRAM Type 0020h - Synchronous Cache Speed 0ns Error Correction Type ParitySingle-Bit ECC System Cache Type Unified Associativity 8-way Set-Associative Maximum Cache Size 2 4320314c - 1126183244l Kb [Cache Information (Type 7) - Length 19 - Handle 0006h] Socket Designation L2 Cache Cache Configuration 0181h - WBEnabled Int NonSocketed L2 Maximum Cache Size 0400h - 1024K Installed Size 0400h - 1024K Supported SRAM Type 0020h - Synchronous Current SRAM Type 0020h - Synchronous Cache Speed 0ns Error Correction Type Multi-Bit ECC System Cache Type Unified Associativity 4-way Set-Associative Maximum Cache Size 2 4320324c - 1126183500l Kb [Cache Information (Type 7) - Length 19 - Handle 0007h] Socket Designation L3 Cache Cache Configuration 0182h - WBEnabled Int NonSocketed L3 Maximum Cache Size 1800h - 6144K Installed Size 1800h - 6144K Supported SRAM Type 0020h - Synchronous Current SRAM Type 0020h - Synchronous Cache Speed 0ns Error Correction Type Specification Reserved System Cache Type Unified Associativity 12-way Set-Associative Maximum Cache Size 2 4320334c - 1126183756l Kb [OEM Strings (Type 11) - Length 5 - Handle 001eh] Number of Strings 3 1 OemString1 2 OemString2 3 OemString3 [System Configuration Options (Type 12) - Length 5 - Handle 001fh] [Physical Memory Array (Type 16) - Length 23 - Handle 0025h] Location 03h - SystemBoard/Motherboard Use 03h - System Memory Memory Error Correction 03h - None Maximum Capacity 33554432KB Memory Error Inf Handle [No Errors] Number of Memory Devices 2 [Memory Device (Type 17) - Length 40 - Handle 0026h] Memory Error Info Handle [No Errors] Total Width 64 bits Data Width 64 bits Size 4096MB Form Factor 0dh - SODIMM Device Set [None] Device Locator ChannelA-DIMM0 Bank Locator BANK 0 Memory Type 1ah - DDR4 Type Detail 4080h - Synchronous Unbuffered (Unregistered) Speed 2133MHz Manufacturer Samsung Serial Number Asset Tag Number Part Number M471A5244CB0-CRC Attributes 1 Extended Size 0 Configured Memory Speed 2133 Minimum Voltage 1500 Maximum Voltage 1500 Configured Voltage 1200 [Memory Device (Type 17) - Length 40 - Handle 0027h] Memory Error Info Handle [No Errors] Total Width 64 bits Data Width 64 bits Size 8192MB Form Factor 0dh - SODIMM Device Set [None] Device Locator ChannelB-DIMM0 Bank Locator BANK 2 Memory Type 1ah - DDR4 Type Detail 4080h - Synchronous Unbuffered (Unregistered) Speed 2133MHz Manufacturer SK Hynix Serial Number Asset Tag Number Part Number HMA81GS6CJR8N-VK Attributes 1 Extended Size 0 Configured Memory Speed 2133 Minimum Voltage 1250 Maximum Voltage 1500 Configured Voltage 1200 [Memory Array Mapped Address (Type 19) - Length 31 - Handle 0028h] Starting Address 00000000h Ending Address 00bfffffh Memory Array Handle 0025h Partition Width 02 Extended Starting Address 0000000000000000h Extended Ending Address 0000000000000000h [Memory Device Mapped Address (Type 20) - Length 35 - Handle 0029h] Starting Address 00000000h Ending Address ffffffffh Memory Device Handle 0026h Mem Array Mapped Adr Handle 0028h Partition Row Position [Unknown] Extended Starting Address 0000000000000000h Extended Ending Address 0000000000000000h [Memory Device Mapped Address (Type 20) - Length 35 - Handle 002ah] Starting Address 00000000h Ending Address ffffffffh Memory Device Handle 0027h Mem Array Mapped Adr Handle 0028h Partition Row Position [Unknown] Extended Starting Address 0000000000000000h Extended Ending Address 0000000000000000h [ (Type 256) - Length 17 - Handle 0033h] [ (Type 256) - Length 11 - Handle 0034h] [ (Type 256) - Length 8 - Handle 0035h] [ (Type 256) - Length 8 - Handle 0036h] [ (Type 256) - Length 20 - Handle 0037h] [ (Type 256) - Length 64 - Handle 0038h] [ (Type 256) - Length 5 - Handle 0039h] [ (Type 256) - Length 6 - Handle 003ah] [ (Type 256) - Length 81 - Handle 003ch] [ (Type 256) - Length 26 - Handle 003dh] [ (Type 256) - Length 26 - Handle 003eh] [ (Type 256) - Length 75 - Handle 003fh] [ (Type 256) - Length 54 - Handle 0040h] [ (Type 256) - Length 103 - Handle 0041h] [ (Type 256) - Length 14 - Handle 0042h] [ (Type 256) - Length 18 - Handle 0043h] [ (Type 256) - Length 4 - Handle feffh] PAGE_FAULT_IN_NONPAGED_AREA (50) Invalid system memory was referenced. This cannot be protected by try-except. Typically the address is just plain bad or it is pointing at freed memory. Arguments: Arg1: ffff9f7b72d79ee8, memory referenced. Arg2: 0000000000000002, X64: bit 0 set if the fault was due to a not-present PTE. bit 1 is set if the fault was due to a write, clear if a read. bit 3 is set if the processor decided the fault was due to a corrupted PTE. bit 4 is set if the fault was due to attempted execute of a no-execute PTE. - ARM64: bit 1 is set if the fault was due to a write, clear if a read. bit 3 is set if the fault was due to attempted execute of a no-execute PTE. Arg3: fffff8040e15bfc2, If non-zero, the instruction address which referenced the bad memory address. Arg4: 0000000000000002, (reserved) Debugging Details: ------------------ *** WARNING: Unable to verify timestamp for nvlddmkm.sys KEY_VALUES_STRING: 1 Key : AV.Type Value: Write Key : Analysis.CPU.mSec Value: 1187 Key : Analysis.Elapsed.mSec Value: 9627 Key : Analysis.IO.Other.Mb Value: 0 Key : Analysis.IO.Read.Mb Value: 0 Key : Analysis.IO.Write.Mb Value: 0 Key : Analysis.Init.CPU.mSec Value: 218 Key : Analysis.Init.Elapsed.mSec Value: 665 Key : Analysis.Memory.CommitPeak.Mb Value: 82 Key : Bugcheck.Code.LegacyAPI Value: 0x50 Key : Bugcheck.Code.TargetModel Value: 0x50 Key : Failure.Bucket Value: AV_W_(null)_nvlddmkm!unknown_function Key : Failure.Hash Value: {838100fa-f28b-2ef7-d702-e31713cb338c} Key : WER.OS.Branch Value: vb_release Key : WER.OS.Version Value: 10.0.19041.1 BUGCHECK_CODE: 50 BUGCHECK_P1: ffff9f7b72d79ee8 BUGCHECK_P2: 2 BUGCHECK_P3: fffff8040e15bfc2 BUGCHECK_P4: 2 FILE_IN_CAB: 081624-9593-01.dmp FAULTING_THREAD: ffffcb088e275040 READ_ADDRESS: fffff80275afb390: Unable to get MiVisibleState Unable to get NonPagedPoolStart Unable to get NonPagedPoolEnd Unable to get PagedPoolStart Unable to get PagedPoolEnd unable to get nt!MmSpecialPagesInUse ffff9f7b72d79ee8 MM_INTERNAL_CODE: 2 BLACKBOXBSD: 1 (!blackboxbsd) BLACKBOXNTFS: 1 (!blackboxntfs) BLACKBOXPNP: 1 (!blackboxpnp) BLACKBOXWINLOGON: 1 CUSTOMER_CRASH_COUNT: 1 PROCESS_NAME: System TRAP_FRAME: ffffdb08e9e1e9b0 -- (.trap 0xffffdb08e9e1e9b0) NOTE: The trap frame does not contain all registers. Some register values may be zeroed or incorrect. rax=0000000095cf5000 rbx=0000000000000000 rcx=ffff9f7b64c00000 rdx=000000000385e7ba rsi=0000000000000000 rdi=0000000000000000 rip=fffff8040e15bfc2 rsp=ffffdb08e9e1eb48 rbp=0000000000000000 r8=ffffcb0895cc61d8 r9=000000000e179eeb r10=ffffcb0895cc5000 r11=ffffdb08e9e1eb30 r12=0000000000000000 r13=0000000000000000 r14=0000000000000000 r15=0000000000000000 iopl=0 nv up ei pl nz na pe cy nvlddmkm+0xfbfc2: fffff804`0e15bfc2 890491 mov dword ptr [rcx+rdx*4],eax ds:ffff9f7b`72d79ee8=???????? Resetting default scope STACK_TEXT: ffffdb08`e9e1e708 fffff802`7524ac53 : 00000000`00000050 ffff9f7b`72d79ee8 00000000`00000002 ffffdb08`e9e1e9b0 : nt!KeBugCheckEx ffffdb08`e9e1e710 fffff802`7506e7b0 : 00000000`00000000 00000000`00000002 ffffdb08`e9e1ea30 00000000`00000000 : nt!MiSystemFault+0x1b2273 ffffdb08`e9e1e810 fffff802`7520b7d8 : 00000000`00000000 ffffdb08`e9e1ea98 fffff804`0e475342 00000000`00000002 : nt!MmAccessFault+0x400 ffffdb08`e9e1e9b0 fffff804`0e15bfc2 : fffff804`0e57ab34 00000000`95cf5000 00000000`00000000 00000000`0e179eeb : nt!KiPageFault+0x358 ffffdb08`e9e1eb48 fffff804`0e57ab34 : 00000000`95cf5000 00000000`00000000 00000000`0e179eeb fffff804`0e15f16e : nvlddmkm+0xfbfc2 ffffdb08`e9e1eb50 00000000`95cf5000 : 00000000`00000000 00000000`0e179eeb fffff804`0e15f16e ffffcb08`95cf5000 : nvlddmkm+0x51ab34 ffffdb08`e9e1eb58 00000000`00000000 : 00000000`0e179eeb fffff804`0e15f16e ffffcb08`95cf5000 fffff804`00000020 : 0x95cf5000 SYMBOL_NAME: nvlddmkm+fbfc2 MODULE_NAME: nvlddmkm IMAGE_NAME: nvlddmkm.sys STACK_COMMAND: .process /r /p 0xffffcb0885e9b040; .thread 0xffffcb088e275040 ; kb BUCKET_ID_FUNC_OFFSET: fbfc2 FAILURE_BUCKET_ID: AV_W_(null)_nvlddmkm!unknown_function OS_VERSION: 10.0.19041.1 BUILDLAB_STR: vb_release OSPLATFORM_TYPE: x64 OSNAME: Windows 10 FAILURE_ID_HASH: {838100fa-f28b-2ef7-d702-e31713cb338c} Followup: MachineOwner --------- PnpActivityId : {00000000-0000-0000-0000-000000000000} PnpActivityTime : 133682899479655301 PnpEventInformation: 3 PnpEventInProgress : 0 PnpProblemCode : 24 PnpVetoType : 0 DeviceId : SW\{96E080C7-143C-11D1-B40F-00A0C9223196}\{3C0D501A-140B-11D1-B40F-00A0C9223196} VetoString : [SMBIOS Data Tables v3.0] [DMI Version - 0] [2.0 Calling Convention - No] [Table Size - 3894 bytes] [BIOS Information (Type 0) - Length 24 - Handle 0000h] Vendor LENOVO BIOS Version 8TCN61WW BIOS Starting Address Segment e000 BIOS Release Date 05/19/2021 BIOS ROM Size 5f0000 BIOS Characteristics 07: - PCI Supported 11: - Upgradeable FLASH BIOS 12: - BIOS Shadowing Supported 15: - CD-Boot Supported 16: - Selectable Boot Supported 19: - EDD Supported 20: - NEC 9800 J-Floppy Supported 21: - Toshiba J-Floppy Supported 22: - 360KB Floppy Supported 23: - 1.2MB Floppy Supported 24: - 720KB Floppy Supported 25: - 2.88MB Floppy Supported 27: - Keyboard Services Supported 30: - CGA/Mono Services Supported 49: - System Vendor Reserved 51: - System Vendor Reserved 52: - System Vendor Reserved BIOS Characteristic Extensions 00: - ACPI Supported 01: - USB Legacy Supported 08: - BIOS Boot Specification Supported 10: - Enable Targeted Content Distribution 11: - UEFI Specification Supported BIOS Major Revision 1 BIOS Minor Revision 61 EC Firmware Major Revision 1 EC Firmware Minor Revision 61 [System Information (Type 1) - Length 27 - Handle 0001h] Manufacturer LENOVO Product Name 81DM Version Lenovo ideapad 330-17IKB Serial Number PF195AY1 UUID 00000000-0000-0000-0000-000000000000 Wakeup Type Power Switch SKUNumber LENOVO_MT_81DM_BU_idea_FM_ideapad 330-17IKB Family ideapad 330-17IKB [BaseBoard Information (Type 2) - Length 15 - Handle 0002h] Manufacturer LENOVO Product LNVNB161216 Version SDK0J40679 WIN Serial Number PF195AY1 Asset Tag Feature Flags 09h 00: - Motherboard 03: - Replaceable Location Type2 - Board Chassis Location Chassis Handle 0003h Board Type 0ah - Processor/Memory Module Number of Child Handles 0 [System Enclosure (Type 3) - Length 22 - Handle 0003h] Manufacturer LENOVO Chassis Type Notebook Version Lenovo ideapad 330-17IKB Serial Number Asset Tag Number Bootup State Safe Power Supply State Safe Thermal State Safe Security Status None OEM Defined 0 Height 0U Number of Power Cords 1 Number of Contained Elements 0 Contained Element Size 0 [Processor Information (Type 4) - Length 48 - Handle 0004h] Socket Designation U3E1 Processor Type Central Processor Processor Family cdh - Intel Core 2 Solo processor Processor Manufacturer Intel(R) Corporation Processor ID ea060800fffbebbf Processor Version Intel(R) Core(TM) i5-8250U CPU @ 1.60GHz Processor Voltage 86h - 0.6V External Clock 100MHz Max Speed 3400MHz Current Speed 1500MHz Status Enabled Populated Processor Upgrade Socket BGA1356 L1 Cache Handle 0005h L2 Cache Handle 0006h L3 Cache Handle 0007h Serial Number Asset Tag Number Part Number To Be Filled By O.E.M. Core Count 4 Core Enabled 4 Thread Count 8 Processor Characteristics fc Enabled Characteristics: 0x 2: 64-bit Capable 0x 3: Multi-Core 0x 4: Hardware Thread 0x 5: Execute Protection 0x 6: Enhanced Virtualization 0x 7: Power/Performance Control Processor Family 2 00cdh - Intel Core 2 Solo processor Core Count 2 4 Core Enabled 2 4 Thread Count 2 8 [Cache Information (Type 7) - Length 19 - Handle 0005h] Socket Designation L1 Cache Cache Configuration 0180h - WBEnabled Int NonSocketed L1 Maximum Cache Size 0100h - 256K Installed Size 0100h - 256K Supported SRAM Type 0020h - Synchronous Current SRAM Type 0020h - Synchronous Cache Speed 0ns Error Correction Type ParitySingle-Bit ECC System Cache Type Unified Associativity 8-way Set-Associative Maximum Cache Size 2 4320314c - 1126183244l Kb [Cache Information (Type 7) - Length 19 - Handle 0006h] Socket Designation L2 Cache Cache Configuration 0181h - WBEnabled Int NonSocketed L2 Maximum Cache Size 0400h - 1024K Installed Size 0400h - 1024K Supported SRAM Type 0020h - Synchronous Current SRAM Type 0020h - Synchronous Cache Speed 0ns Error Correction Type Multi-Bit ECC System Cache Type Unified Associativity 4-way Set-Associative Maximum Cache Size 2 4320324c - 1126183500l Kb [Cache Information (Type 7) - Length 19 - Handle 0007h] Socket Designation L3 Cache Cache Configuration 0182h - WBEnabled Int NonSocketed L3 Maximum Cache Size 1800h - 6144K Installed Size 1800h - 6144K Supported SRAM Type 0020h - Synchronous Current SRAM Type 0020h - Synchronous Cache Speed 0ns Error Correction Type Specification Reserved System Cache Type Unified Associativity 12-way Set-Associative Maximum Cache Size 2 4320334c - 1126183756l Kb [OEM Strings (Type 11) - Length 5 - Handle 001eh] Number of Strings 3 1 OemString1 2 OemString2 3 OemString3 [System Configuration Options (Type 12) - Length 5 - Handle 001fh] [Physical Memory Array (Type 16) - Length 23 - Handle 0025h] Location 03h - SystemBoard/Motherboard Use 03h - System Memory Memory Error Correction 03h - None Maximum Capacity 33554432KB Memory Error Inf Handle [No Errors] Number of Memory Devices 2 [Memory Device (Type 17) - Length 40 - Handle 0026h] Memory Error Info Handle [No Errors] Total Width 64 bits Data Width 64 bits Size 4096MB Form Factor 0dh - SODIMM Device Set [None] Device Locator ChannelA-DIMM0 Bank Locator BANK 0 Memory Type 1ah - DDR4 Type Detail 4080h - Synchronous Unbuffered (Unregistered) Speed 2133MHz Manufacturer Samsung Serial Number Asset Tag Number Part Number M471A5244CB0-CRC Attributes 1 Extended Size 0 Configured Memory Speed 2133 Minimum Voltage 1500 Maximum Voltage 1500 Configured Voltage 1200 [Memory Device (Type 17) - Length 40 - Handle 0027h] Memory Error Info Handle [No Errors] Total Width 64 bits Data Width 64 bits Size 8192MB Form Factor 0dh - SODIMM Device Set [None] Device Locator ChannelB-DIMM0 Bank Locator BANK 2 Memory Type 1ah - DDR4 Type Detail 4080h - Synchronous Unbuffered (Unregistered) Speed 2133MHz Manufacturer SK Hynix Serial Number Asset Tag Number Part Number HMA81GS6CJR8N-VK Attributes 1 Extended Size 0 Configured Memory Speed 2133 Minimum Voltage 1250 Maximum Voltage 1500 Configured Voltage 1200 [Memory Array Mapped Address (Type 19) - Length 31 - Handle 0028h] Starting Address 00000000h Ending Address 00bfffffh Memory Array Handle 0025h Partition Width 02 Extended Starting Address 0000000000000000h Extended Ending Address 0000000000000000h [Memory Device Mapped Address (Type 20) - Length 35 - Handle 0029h] Starting Address 00000000h Ending Address ffffffffh Memory Device Handle 0026h Mem Array Mapped Adr Handle 0028h Partition Row Position [Unknown] Extended Starting Address 0000000000000000h Extended Ending Address 0000000000000000h [Memory Device Mapped Address (Type 20) - Length 35 - Handle 002ah] Starting Address 00000000h Ending Address ffffffffh Memory Device Handle 0027h Mem Array Mapped Adr Handle 0028h Partition Row Position [Unknown] Extended Starting Address 0000000000000000h Extended Ending Address 0000000000000000h [ (Type 256) - Length 17 - Handle 0033h] [ (Type 256) - Length 11 - Handle 0034h] [ (Type 256) - Length 8 - Handle 0035h] [ (Type 256) - Length 8 - Handle 0036h] [ (Type 256) - Length 20 - Handle 0037h] [ (Type 256) - Length 64 - Handle 0038h] [ (Type 256) - Length 5 - Handle 0039h] [ (Type 256) - Length 6 - Handle 003ah] [ (Type 256) - Length 81 - Handle 003ch] [ (Type 256) - Length 26 - Handle 003dh] [ (Type 256) - Length 26 - Handle 003eh] [ (Type 256) - Length 75 - Handle 003fh] [ (Type 256) - Length 54 - Handle 0040h] [ (Type 256) - Length 103 - Handle 0041h] [ (Type 256) - Length 14 - Handle 0042h] [ (Type 256) - Length 18 - Handle 0043h] [ (Type 256) - Length 4 - Handle feffh]
Tamir edilebilir. Reballing yapılır ama MX150 için değer mi ona bakmak lazım. Servisten fiyat alıp siz karar verin.
We use cookies and similar technologies for the following purposes:
Do you accept cookies and these technologies?
