14: kd> k
# Child-SP RetAddr Call Site
00 ffffc280`09b3f158 fffff802`7eafbc2e nt!KeBugCheckEx
01 ffffc280`09b3f160 fffff802`7ea08692 nt!HvlpVtlCallExceptionHandler+0x22
02 ffffc280`09b3f1a0 fffff802`7e95f917 nt!RtlpExecuteHandlerForException+0x12
03 ffffc280`09b3f1d0 fffff802`7e95d846 nt!RtlDispatchException+0x297
04 ffffc280`09b3f8f0 fffff802`7e9fecb2 nt!KiDispatchException+0x186
05 ffffc280`09b3ffb0 fffff802`7e9fec80 nt!KxExceptionDispatchOnExceptionStack+0x12
06 ffffe40c`826df288 fffff802`7ea124e5 nt!KiExceptionDispatchOnExceptionStackContinue
07 ffffe40c`826df290 fffff802`7ea0d8ef nt!KiExceptionDispatch+0x125
08 ffffe40c`826df470 fffff802`7e84dcf0 nt!KiGeneralProtectionFault+0x32f
09 ffffe40c`826df600 00000000`ffffffff nt!KiCheckForTimerExpiration
0a ffffe40c`826df608 ffffffff`ffffffff amdppm!C2Idle+0x87
0b ffffe40c`826df610 00000000`00000002 nt!PpmIdleUpdateConcurrency+0x73
10.0.19041.4522KMODE_EXCEPTION_NOT_HANDLED (1e)
This is a very common BugCheck. Usually the exception address pinpoints
the driver/function that caused the problem. Always note this address
as well as the link date of the driver/image that contains this address.
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff8061540b975, The address that the exception occurred at
Arg3: 0000000000000000, Parameter 0 of the exception
Arg4: 000000000000ac00, Parameter 1 of the exception
Debugging Details:
*** Either you specified an unqualified symbol, or your debugger ***
*** doesn't have full symbol information. Unqualified symbol ***
*** resolution is turned off by default. Please either specify a ***
*** fully qualified symbol module!symbolname, or enable resolution ***
*** of unqualified symbols by typing ".symopt- 100". Note that ***
*** enabling unqualified symbol resolution with network symbol ***
*** server shares in the symbol path may cause the debugger to ***
*** appear to hang for long periods of time when an incorrect ***
*** symbol name is typed or the network symbol server is down. ***
*** For some commands to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: ExceptionRecord ***
*** work. ***
*** Type referenced: ContextRecord ***
KEY_VALUES_STRING: 1
Key : Analysis.CPU.mSec
Value: 2530
Key : Analysis.Elapsed.mSec
Value: 12129
Key : Analysis.IO.Other.Mb
Value: 7
Key : Analysis.IO.Read.Mb
Value: 0
Key : Analysis.IO.Write.Mb
Value: 18
Key : Analysis.Init.CPU.mSec
Value: 968
Value: 181289
Value: 83
Key : Bugcheck.Code.LegacyAPI
Value: 0x1e
Key : Bugcheck.Code.TargetModel
Value: 0x1e
Key : Failure.Bucket
Value: AV_R_nt!MiStoreCheckCandidatePage
Key : Failure.Hash
Value: {915aa067-ef20-d6c5-fc70-bf83e248aade}
Key : WER.OS.Branch
Value: vb_release
Key : WER.OS.Version
Value: 10.0.19041.1
BUGCHECK_CODE: 1e
BUGCHECK_P1: ffffffffc0000005
BUGCHECK_P2: fffff8061540b975
BUGCHECK_P3: 0
BUGCHECK_P4: ac00
FILE_IN_CAB: 061224-11062-01.dmp
EXCEPTION_PARAMETER1: 0000000000000000
EXCEPTION_PARAMETER2: 000000000000ac00
READ_ADDRESS: fffff80615efb390: Unable to get MiVisibleState
Unable to get NonPagedPoolStart
Unable to get NonPagedPoolEnd
Unable to get PagedPoolStart
Unable to get PagedPoolEnd
unable to get nt!MmSpecialPagesInUse
000000000000ac00
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: System
TRAP_FRAME: ffff800000000000 -- (.trap 0xffff800000000000)
Unable to read trap frame at ffff8000`00000000
STACK_TEXT:
fffff387`5b81ad18 fffff806`1569d1f7 : 00000000`0000001e ffffffff`c0000005 fffff806`1540b975 00000000`00000000 : nt!KeBugCheckEx
fffff387`5b81ad20 fffff806`156124ec : 00000000`00001000 fffff387`5b81b5c0 ffff8000`00000000 00000000`00000000 : nt!KiDispatchException+0x13fb37
fffff387`5b81b3e0 fffff806`1560dd52 : 00000000`00000000 00000000`00000000 fffff806`15f23ec8 00000000`00000000 : nt!KiExceptionDispatch+0x12c
fffff387`5b81b5c0 fffff806`1540b975 : fffff806`1540b1b8 00000000`00000000 fffff806`1540b8ae 00000000`00004e91 : nt!KiPageFault+0x452
fffff387`5b81b758 000001c0`00000084 : fffff387`5b81b879 00000000`00004e91 00000000`00004e91 00000000`00000001 : nt!MiStoreCheckCandidatePage+0x69
fffff387`5b81b7b8 fffff387`5b81b879 : 00000000`00004e91 00000000`00004e91 00000000`00000001 00000000`0000ac00 : 0x000001c0`00000084
fffff387`5b81b7c0 00000000`00004e91 : 00000000`00004e91 00000000`00000001 00000000`0000ac00 ffffb90f`20004e91 : 0xfffff387`5b81b879
fffff387`5b81b7c8 00000000`00004e91 : 00000000`00000001 00000000`0000ac00 ffffb90f`20004e91 00000000`00000001 : 0x4e91
fffff387`5b81b7d0 00000000`00000001 : 00000000`0000ac00 ffffb90f`20004e91 00000000`00000001 00000068`00000000 : 0x4e91
fffff387`5b81b7d8 00000000`0000ac00 : ffffb90f`20004e91 00000000`00000001 00000068`00000000 00000100`00000000 : 0x1
fffff387`5b81b7e0 ffffb90f`20004e91 : 00000000`00000001 00000068`00000000 00000100`00000000 ffffb90f`6c495770 : 0xac00
fffff387`5b81b7e8 00000000`00000001 : 00000068`00000000 00000100`00000000 ffffb90f`6c495770 00000000`00000000 : 0xffffb90f`20004e91
fffff387`5b81b7f0 00000068`00000000 : 00000100`00000000 ffffb90f`6c495770 00000000`00000000 00000000`00000011 : 0x1
fffff387`5b81b7f8 00000100`00000000 : ffffb90f`6c495770 00000000`00000000 00000000`00000011 00000000`0000ac00 : 0x00000068`00000000
fffff387`5b81b800 ffffb90f`6c495770 : 00000000`00000000 00000000`00000011 00000000`0000ac00 ffffb90f`7bec9450 : 0x00000100`00000000
fffff387`5b81b808 00000000`00000000 : 00000000`00000011 00000000`0000ac00 ffffb90f`7bec9450 20000000`00004e91 : 0xffffb90f`6c495770
SYMBOL_NAME: nt!MiStoreCheckCandidatePage+69
MODULE_NAME: nt
IMAGE_VERSION: 10.0.19041.4522
STACK_COMMAND: .cxr; .ecxr ; kb
IMAGE_NAME: ntkrnlmp.exe
BUCKET_ID_FUNC_OFFSET: 69
FAILURE_BUCKET_ID: AV_R_nt!MiStoreCheckCandidatePage
OS_VERSION: 10.0.19041.1
BUILDLAB_STR: vb_release
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {915aa067-ef20-d6c5-fc70-bf83e248aade}
Followup: MachineOwner
PnpActivityId : {00000000-0000-0000-0000-000000000000}
PnpActivityTime : 133626715178458823
PnpEventInformation: 3
PnpEventInProgress : 0
PnpProblemCode : 24
PnpVetoType : 0
DeviceId : SW\{96E080C7-143C-11D1-B40F-00A0C9223196}\{3C0D501A-140B-11D1-B40F-00A0C9223196}
VetoString :
start end module name
ffffa22e`76600000 ffffa22e`768cd000 win32kbase (deferred)
ffffa22e`768d0000 ffffa22e`76c80000 win32kfull (deferred)
ffffa22e`76c90000 ffffa22e`76cd9000 cdd (deferred)
ffffa22e`77560000 ffffa22e`775fb000 win32k (deferred)
fffff806`11230000 fffff806`11258000 mcupdate_AuthenticAMD (deferred)
fffff806`11260000 fffff806`11266000 hal (deferred)
fffff806`11270000 fffff806`1127b000 kd (deferred)
fffff806`11280000 fffff806`112a8000 tm (deferred)
fffff806`112b0000 fffff806`1131e000 CLFS (deferred)
fffff806`11320000 fffff806`1133a000 PSHED (deferred)
fffff806`11340000 fffff806`1134b000 BOOTVID (deferred)
fffff806`11350000 fffff806`11467000 clipsp (deferred)
fffff806`11470000 fffff806`114de000 FLTMGR (deferred)
fffff806`114e0000 fffff806`11509000 ksecdd (deferred)
fffff806`11510000 fffff806`11573000 msrpc (deferred)
fffff806`11580000 fffff806`1158e000 cmimcext (deferred)
fffff806`11590000 fffff806`115a1000 werkernel (deferred)
fffff806`115b0000 fffff806`115bc000 ntosext (deferred)
fffff806`115c0000 fffff806`115d3000 WDFLDR (deferred)
fffff806`115e0000 fffff806`115ef000 SleepStudyHelper (deferred)
fffff806`115f0000 fffff806`11601000 WppRecorder (deferred)
fffff806`11610000 fffff806`1162a000 SgrmAgent (deferred)
fffff806`15200000 fffff806`16246000 nt (pdb symbols) C:\ProgramData\Dbg\sym\ntkrnlmp.pdb\ADCC367AF84D728686C57E76F105B7911\ntkrnlmp.pdb
fffff806`16c00000 fffff806`16cec000 CI (deferred)
fffff806`16cf0000 fffff806`16dab000 cng (deferred)
fffff806`16db0000 fffff806`16e81000 Wdf01000 (deferred)
fffff806`16e90000 fffff806`16eb6000 acpiex (deferred)
fffff806`16ec0000 fffff806`16f8c000 ACPI (deferred)
fffff806`16f90000 fffff806`16f9c000 WMILIB (deferred)
fffff806`16fa0000 fffff806`16fab000 msisadrv (deferred)
fffff806`16fb0000 fffff806`17028000 pci (deferred)
fffff806`17030000 fffff806`17075000 tpm (deferred)
fffff806`17090000 fffff806`170fb000 intelpep (deferred)
fffff806`17100000 fffff806`17117000 WindowsTrustedRT (deferred)
fffff806`17120000 fffff806`1712b000 IntelTA (deferred)
fffff806`17130000 fffff806`1713b000 WindowsTrustedRTProxy (deferred)
fffff806`17140000 fffff806`17154000 pcw (deferred)
fffff806`17160000 fffff806`171be000 klupd_K4W_21_17_arkmon (deferred)
fffff806`171c0000 fffff806`171d5000 vdrvroot (deferred)
fffff806`171e0000 fffff806`1721a000 cm_km (deferred)
fffff806`17220000 fffff806`1724f000 pdc (deferred)
fffff806`17250000 fffff806`17269000 CEA (deferred)
fffff806`17270000 fffff806`172a1000 partmgr (deferred)
fffff806`172b0000 fffff806`1735b000 spaceport (deferred)
fffff806`17360000 fffff806`17379000 volmgr (deferred)
fffff806`17380000 fffff806`173e3000 volmgrx (deferred)
fffff806`173f0000 fffff806`173fd000 Fs_Rec (deferred)
fffff806`17400000 fffff806`1741e000 mountmgr (deferred)
fffff806`17420000 fffff806`17452000 storahci (deferred)
fffff806`17460000 fffff806`17515000 storport (deferred)
fffff806`17520000 fffff806`1754f000 stornvme (deferred)
fffff806`17550000 fffff806`1756c000 EhStorClass (deferred)
fffff806`17570000 fffff806`1758a000 fileinfo (deferred)
fffff806`17590000 fffff806`175d0000 Wof (deferred)
fffff806`175e0000 fffff806`1774f000 ndis (deferred)
fffff806`17750000 fffff806`177ec000 NETIO (deferred)
fffff806`177f0000 fffff806`177fb000 volume (deferred)
fffff806`17800000 fffff806`17ad7000 Ntfs (deferred)
fffff806`17ae0000 fffff806`17b12000 ksecpkg (deferred)
fffff806`17b20000 fffff806`17b41000 amdpsp (deferred)
fffff806`17b50000 fffff806`17e3d000 tcpip (deferred)
fffff806`17e40000 fffff806`17ebf000 fwpkclnt (deferred)
fffff806`17ec0000 fffff806`17ef0000 wfplwfs (deferred)
fffff806`17f00000 fffff806`17fc9000 fvevol (deferred)
fffff806`17fd0000 fffff806`1803d000 volsnap (deferred)
fffff806`18040000 fffff806`18090000 rdyboost (deferred)
fffff806`180a0000 fffff806`180c6000 mup (deferred)
fffff806`180d0000 fffff806`180fa000 klupd_K4W_21_17_klbg (deferred)
fffff806`18100000 fffff806`18112000 iorate (deferred)
fffff806`18140000 fffff806`1815f000 disk (deferred)
fffff806`18160000 fffff806`181d3000 CLASSPNP (deferred)
fffff806`1fa70000 fffff806`1fa85000 klbackupdisk (deferred)
fffff806`1fa90000 fffff806`1fb46000 klflt (deferred)
fffff806`1fb50000 fffff806`1fb80000 cdrom (deferred)
fffff806`1fb90000 fffff806`1fbcc000 klbackupflt (deferred)
fffff806`1fbd0000 fffff806`1fbe5000 filecrypt (deferred)
fffff806`1fbf0000 fffff806`1fbfe000 tbs (deferred)
fffff806`1fc00000 fffff806`1fc4e000 ahcache (deferred)
fffff806`1fc50000 fffff806`1fc8c000 amdppm (deferred)
fffff806`1fd70000 fffff806`1fd8e000 crashdmp (deferred)
fffff806`26800000 fffff806`26a25000 klhk (deferred)
fffff806`26a30000 fffff806`26a3d000 klpd (deferred)
fffff806`26a40000 fffff806`26b0d000 klgse (deferred)
fffff806`26b10000 fffff806`26b20000 UCPD (deferred)
fffff806`26b30000 fffff806`26b4a000 kldisk (deferred)
fffff806`26b50000 fffff806`26b5a000 Null (deferred)
fffff806`26b60000 fffff806`26b6a000 Beep (deferred)
fffff806`26b70000 fffff806`26f1a000 dxgkrnl (deferred)
fffff806`26f20000 fffff806`26f38000 watchdog (deferred)
fffff806`26f40000 fffff806`26f56000 BasicDisplay (deferred)
fffff806`26f60000 fffff806`26f71000 BasicRender (deferred)
fffff806`26f80000 fffff806`26f9c000 Npfs (deferred)
fffff806`26fa0000 fffff806`26fb1000 Msfs (deferred)
fffff806`26fc0000 fffff806`26fde000 CimFS (deferred)
fffff806`26fe0000 fffff806`27002000 tdx (deferred)
fffff806`27010000 fffff806`27020000 TDI (deferred)
fffff806`27030000 fffff806`2708c000 netbt (deferred)
fffff806`27090000 fffff806`270a4000 afunix (deferred)
fffff806`270b0000 fffff806`27156000 afd (deferred)
fffff806`27160000 fffff806`271e0000 klwtp (deferred)
fffff806`271f0000 fffff806`27204000 klim6 (deferred)
fffff806`27210000 fffff806`2722a000 vwififlt (deferred)
fffff806`27230000 fffff806`2725b000 pacer (deferred)
fffff806`27260000 fffff806`27274000 ndiscap (deferred)
fffff806`27280000 fffff806`27294000 netbios (deferred)
fffff806`272a0000 fffff806`27341000 Vid (deferred)
fffff806`27350000 fffff806`27374000 winhvr (deferred)
fffff806`27380000 fffff806`27393000 klpnpflt (deferred)
fffff806`273a0000 fffff806`273b8000 klkbdflt (deferred)
fffff806`273c0000 fffff806`2743b000 rdbss (deferred)
fffff806`27440000 fffff806`27452000 nsiproxy (deferred)
fffff806`27460000 fffff806`2746e000 npsvctrig (deferred)
fffff806`27470000 fffff806`27480000 mssmbios (deferred)
fffff806`27490000 fffff806`2766c000 kneps (deferred)
fffff806`27670000 fffff806`2767d000 kdnic (deferred)
fffff806`27680000 fffff806`27695000 umbus (deferred)
fffff806`276a0000 fffff806`27801000 klif (deferred)
fffff806`27810000 fffff806`27888000 ks (deferred)
fffff806`278d0000 fffff806`278da000 gpuenergydrv (deferred)
fffff806`278e0000 fffff806`2790d000 dfsc (deferred)
fffff806`27910000 fffff806`27925000 CAD (deferred)
fffff806`27930000 fffff806`2799c000 fastfat (deferred)
fffff806`279a0000 fffff806`279b7000 bam (deferred)
fffff806`279c0000 fffff806`279ca000 wintun (deferred)
fffff806`279d0000 fffff806`279dc000 tap0901 (deferred)
fffff806`279e0000 fffff806`279f2000 CompositeBus (deferred)
fffff806`37200000 fffff806`37221000 drmk (deferred)
fffff806`37230000 fffff806`3734c000 rt640x64 (deferred)
fffff806`37830000 fffff806`3b333000 nvlddmkm (deferred)
fffff806`3b340000 fffff806`3b365000 HDAudBus (deferred)
fffff806`3b370000 fffff806`3b3d6000 portcls (deferred)
fffff806`43c00000 fffff806`43cd6000 peauth (deferred)
fffff806`43ce0000 fffff806`43d01000 rasl2tp (deferred)
fffff806`43d10000 fffff806`43d31000 raspptp (deferred)
fffff806`43d40000 fffff806`43d5c000 raspppoe (deferred)
fffff806`43d60000 fffff806`43d9a000 ndiswan (deferred)
fffff806`43da0000 fffff806`43df7000 klupd_K4W_21_17_klark (deferred)
fffff806`43e00000 fffff806`43e41000 klupd_K4W_21_17_mark (deferred)
fffff806`43e50000 fffff806`43e62000 condrv (deferred)
fffff806`43e70000 fffff806`43eaa000 klids (deferred)
fffff806`43f40000 fffff806`44a81000 rtwlane (deferred)
fffff806`44a90000 fffff806`44b82000 wdiwifi (deferred)
fffff806`44b90000 fffff806`44b9e000 vwifibus (deferred)
fffff806`51e00000 fffff806`51e44000 ucx01000 (deferred)
fffff806`51e50000 fffff806`52520000 amdacpbus (deferred)
fffff806`52530000 fffff806`52551000 i8042prt (deferred)
fffff806`52560000 fffff806`52574000 kbdclass (deferred)
fffff806`52580000 fffff806`5258f000 CmBatt (deferred)
fffff806`52590000 fffff806`525a0000 BATTC (deferred)
fffff806`525b0000 fffff806`525c4000 AcpiVpc (deferred)
fffff806`525d0000 fffff806`525dc000 wmiacpi (deferred)
fffff806`525e0000 fffff806`525ed000 amdgpio2 (deferred)
fffff806`525f0000 fffff806`52623000 msgpioclx (deferred)
fffff806`52630000 fffff806`52642000 amdi2c (deferred)
fffff806`52650000 fffff806`5266a000 SpbCx (deferred)
fffff806`52670000 fffff806`5267e000 UEFI (deferred)
fffff806`52680000 fffff806`52695000 kltun (deferred)
fffff806`526a0000 fffff806`526af000 nvvad64v (deferred)
fffff806`526b0000 fffff806`526c1000 ksthunk (deferred)
fffff806`526d0000 fffff806`526dd000 NvModuleTracker (deferred)
fffff806`526e0000 fffff806`526f0000 nvvhci (deferred)
fffff806`52700000 fffff806`5270d000 NdisVirtualBus (deferred)
fffff806`52710000 fffff806`5271c000 swenum (deferred)
fffff806`52720000 fffff806`5272e000 rdpbus (deferred)
fffff806`52730000 fffff806`52742000 MSKSSRV (deferred)
fffff806`52750000 fffff806`52765000 hidi2c (deferred)
fffff806`52770000 fffff806`5277b000 mshidkmdf (deferred)
fffff806`52780000 fffff806`527c1000 HIDCLASS (deferred)
fffff806`527d0000 fffff806`527e3000 HIDPARSE (deferred)
fffff806`527f0000 fffff806`52893000 UsbHub3 (deferred)
fffff806`528a0000 fffff806`528ae000 USBD (deferred)
fffff806`528b0000 fffff806`528c0000 mouhid (deferred)
fffff806`528d0000 fffff806`528e7000 klmouflt (deferred)
fffff806`528f0000 fffff806`52903000 mouclass (deferred)
fffff806`52910000 fffff806`5291c000 MTConfig (deferred)
fffff806`52930000 fffff806`56d3a000 amdkmdag (deferred)
fffff806`56d40000 fffff806`56ddd000 USBXHCI (deferred)
fffff806`56de0000 fffff806`56dfe000 nvhda64v (deferred)
fffff806`5e400000 fffff806`5e4d0000 RtkBtfilter (deferred)
fffff806`5e4e0000 fffff806`5e501000 BTHUSB (deferred)
fffff806`5e510000 fffff806`5e697000 BTHport (deferred)
fffff806`5e6a0000 fffff806`5e6af000 ndistapi (deferred)
fffff806`5e6b0000 fffff806`5e704000 usbvideo (deferred)
fffff806`5e710000 fffff806`5e74d000 rfcomm (deferred)
fffff806`5e750000 fffff806`5e772000 BthEnum (deferred)
fffff806`5e780000 fffff806`5e7a6000 bthpan (deferred)
fffff806`5e7b0000 fffff806`5e7d1000 Microsoft_Bluetooth_Legacy_LEEnumerator (deferred)
fffff806`5e7e0000 fffff806`5e7f2000 hidusb (deferred)
fffff806`5e800000 fffff806`5e811000 kbdhid (deferred)
fffff806`5e830000 fffff806`5e83f000 dump_dumpstorport (deferred)
fffff806`5e870000 fffff806`5e89f000 dump_stornvme (deferred)
fffff806`5e8c0000 fffff806`5e8dd000 dump_dumpfve (deferred)
fffff806`5e8e0000 fffff806`5e9c0000 dxgmms2 (deferred)
fffff806`5e9d0000 fffff806`5e9eb000 monitor (deferred)
fffff806`5e9f0000 fffff806`5ea1b000 luafv (deferred)
fffff806`5ea20000 fffff806`5ea57000 wcifs (deferred)
fffff806`5ea60000 fffff806`5eae2000 cldflt (deferred)
fffff806`5eaf0000 fffff806`5eb04000 mmcss (deferred)
fffff806`5eb10000 fffff806`5eb2a000 storqosflt (deferred)
fffff806`5eb30000 fffff806`5eb57000 bindflt (deferred)
fffff806`5eb60000 fffff806`5eb78000 lltdio (deferred)
fffff806`5eb80000 fffff806`5eb98000 mslldp (deferred)
fffff806`5eba0000 fffff806`5ebbb000 rspndr (deferred)
fffff806`5ebc0000 fffff806`5ebdd000 wanarp (deferred)
fffff806`5ebe0000 fffff806`5ebf8000 ndisuio (deferred)
fffff806`5ec00000 fffff806`5ecc0000 nwifi (deferred)
fffff806`5ecd0000 fffff806`5ed26000 msquic (deferred)
fffff806`5ed30000 fffff806`5eeb8000 HTTP (deferred)
fffff806`5eec0000 fffff806`5eee5000 bowser (deferred)
fffff806`5eef0000 fffff806`5ef0a000 mpsdrv (deferred)
fffff806`5ef10000 fffff806`5efa4000 mrxsmb (deferred)
fffff806`5efb0000 fffff806`5eff5000 mrxsmb20 (deferred)
fffff806`5f000000 fffff806`5f013000 vwifimp (deferred)
fffff806`5f020000 fffff806`5f076000 srvnet (deferred)
fffff806`5f080000 fffff806`5f148000 srv2 (deferred)
fffff806`5f150000 fffff806`5f1a2000 mrxsmb10 (deferred)
fffff806`5f1b0000 fffff806`5f1d7000 Ndu (deferred)
fffff806`5f1e0000 fffff806`5f1ef000 FBNetFlt (deferred)
fffff806`5f1f0000 fffff806`5f92b000 RTKVHD64 (deferred)
fffff806`5f930000 fffff806`5f964000 usbccgp (deferred)
fffff806`5f970000 fffff806`5f985000 tcpipreg (deferred)
fffff806`5f990000 fffff806`5f9ad000 rassstp (deferred)
fffff806`5f9b0000 fffff806`5f9cd000 NDProxy (deferred)
fffff806`5f9d0000 fffff806`5f9f8000 AgileVpn (deferred)
Unloaded modules:
fffff806`52730000 fffff806`52743000 MSKSSRV.sys
fffff806`27890000 fffff806`278cb000 klids.sys
fffff806`1fda0000 fffff806`1fdb0000 dump_storpor
fffff806`1fa00000 fffff806`1fa30000 dump_stornvm
fffff806`1fa50000 fffff806`1fa6e000 dump_dumpfve
fffff806`5e6a0000 fffff806`5e6ac000 WdmCompanion
fffff806`27910000 fffff806`2792c000 dam.sys
fffff806`277f0000 fffff806`298b4000 vgk.sys
fffff806`17080000 fffff806`1708f000 klelam.sys
fffff806`18120000 fffff806`18131000 hwpolicy.sys
# Child-SP RetAddr : Args to Child : Call Site
00 fffff387`5b81ad18 fffff806`1569d1f7 : 00000000`0000001e ffffffff`c0000005 fffff806`1540b975 00000000`00000000 : nt!KeBugCheckEx
01 fffff387`5b81ad20 fffff806`156124ec : 00000000`00001000 fffff387`5b81b5c0 ffff8000`00000000 00000000`00000000 : nt!KiDispatchException+0x13fb37
02 fffff387`5b81b3e0 fffff806`1560dd52 : 00000000`00000000 00000000`00000000 fffff806`15f23ec8 00000000`00000000 : nt!KiExceptionDispatch+0x12c
03 fffff387`5b81b5c0 fffff806`1540b975 : fffff806`1540b1b8 00000000`00000000 fffff806`1540b8ae 00000000`00004e91 : nt!KiPageFault+0x452 (TrapFrame @ fffff387`5b81b5c0)
04 fffff387`5b81b758 000001c0`00000084 : fffff387`5b81b879 00000000`00004e91 00000000`00004e91 00000000`00000001 : nt!MiStoreCheckCandidatePage+0x69
05 fffff387`5b81b7b8 fffff387`5b81b879 : 00000000`00004e91 00000000`00004e91 00000000`00000001 00000000`0000ac00 : 0x000001c0`00000084
06 fffff387`5b81b7c0 00000000`00004e91 : 00000000`00004e91 00000000`00000001 00000000`0000ac00 ffffb90f`20004e91 : 0xfffff387`5b81b879
07 fffff387`5b81b7c8 00000000`00004e91 : 00000000`00000001 00000000`0000ac00 ffffb90f`20004e91 00000000`00000001 : 0x4e91
08 fffff387`5b81b7d0 00000000`00000001 : 00000000`0000ac00 ffffb90f`20004e91 00000000`00000001 00000068`00000000 : 0x4e91
09 fffff387`5b81b7d8 00000000`0000ac00 : ffffb90f`20004e91 00000000`00000001 00000068`00000000 00000100`00000000 : 0x1
0a fffff387`5b81b7e0 ffffb90f`20004e91 : 00000000`00000001 00000068`00000000 00000100`00000000 ffffb90f`6c495770 : 0xac00
0b fffff387`5b81b7e8 00000000`00000001 : 00000068`00000000 00000100`00000000 ffffb90f`6c495770 00000000`00000000 : 0xffffb90f`20004e91
0c fffff387`5b81b7f0 00000068`00000000 : 00000100`00000000 ffffb90f`6c495770 00000000`00000000 00000000`00000011 : 0x1
0d fffff387`5b81b7f8 00000100`00000000 : ffffb90f`6c495770 00000000`00000000 00000000`00000011 00000000`0000ac00 : 0x00000068`00000000
0e fffff387`5b81b800 ffffb90f`6c495770 : 00000000`00000000 00000000`00000011 00000000`0000ac00 ffffb90f`7bec9450 : 0x00000100`00000000
0f fffff387`5b81b808 00000000`00000000 : 00000000`00000011 00000000`0000ac00 ffffb90f`7bec9450 20000000`00004e91 : 0xffffb90f`6c495770
Machine ID Information [From Smbios 3.2, DMIVersion 0, Size=2546]
BiosMajorRelease = 1
BiosMinorRelease = 21
FirmwareMajorRelease = 1
FirmwareMinorRelease = 21
BiosVendor = LENOVO
BiosVersion = FCCN21WW
BiosReleaseDate = 09/20/2023
SystemManufacturer = LENOVO
SystemProductName = 82EY
SystemFamily = IdeaPad Gaming 3 15ARH05
SystemVersion = IdeaPad Gaming 3 15ARH05
SystemSKU = LENOVO_MT_82EY_BU_idea_FM_IdeaPad Gaming 3 15ARH05
BaseBoardManufacturer = LENOVO
BaseBoardProduct = LNVNB161216
BaseBoardVersion = NO DPK
[SMBIOS Data Tables v3.2]
[DMI Version - 0]
[2.0 Calling Convention - No]
[Table Size - 2546 bytes]
Vendor LENOVO
BIOS Version FCCN21WW
BIOS Starting Address Segment e000
BIOS Release Date 09/20/2023
BIOS ROM Size f20000
BIOS Characteristics
07: - PCI Supported
11: - Upgradeable FLASH BIOS
15: - CD-Boot Supported
19: - EDD Supported
22: - 360KB Floppy Supported
23: - 1.2MB Floppy Supported
24: - 720KB Floppy Supported
25: - 2.88MB Floppy Supported
27: - Keyboard Services Supported
49: - System Vendor Reserved
51: - System Vendor Reserved
52: - System Vendor Reserved
00: - ACPI Supported
01: - USB Legacy Supported
BIOS Major Revision 1
BIOS Minor Revision 21
EC Firmware Major Revision 1
EC Firmware Minor Revision 21
Extended BIOS ROM Size 0 MB
Manufacturer LENOVO
Product Name 82EY
Version IdeaPad Gaming 3 15ARH05
Serial Number PF2N5SKE
UUID 00000000-0000-0000-0000-000000000000
Wakeup Type Power Switch
SKUNumber LENOVO_MT_82EY_BU_idea_FM_IdeaPad Gaming 3 15ARH05
Family IdeaPad Gaming 3 15ARH05
[BaseBoard Information (Type 2) - Length 16 - Handle 0002h]
Manufacturer LENOVO
Product LNVNB161216
Version NO DPK
Asset Tag
Feature Flags 09h
00: - Motherboard
03: - Replaceable
Location Base Board Chassis Location
Chassis Handle 0003h
Board Type 0ah - Processor/Memory Module
Number of Child Handles 0
[System Enclosure (Type 3) - Length 23 - Handle 0003h]
Manufacturer LENOVO
Chassis Type Notebook
Serial Number
Asset Tag Number
Bootup State Safe
Power Supply State Safe
Thermal State Safe
Security Status None
OEM Defined 0
Height 0U
Number of Power Cords 1
Number of Contained Elements 0
Contained Element Size 0
SKU Number Chassis SKU
[Processor Information (Type 4) - Length 48 - Handle 0004h]
Socket Designation FP6
Processor Type Central Processor
Processor Family 6bh - AMD Zen Processor Family
Processor Manufacturer Advanced Micro Devices, Inc.
Processor ID 10f8600fffb8b17
Processor Version AMD Ryzen 7 4800H with Radeon Graphics
Processor Voltage 8ch - 1.2V
External Clock 100MHz
Max Speed 4300MHz
Current Speed 2900MHz
Status Enabled Populated
Processor Upgrade None
L1 Cache Handle 0005h
L2 Cache Handle 0006h
L3 Cache Handle 0007h
Serial Number
Asset Tag Number
Part Number Unknown
Core Count 8
Core Enabled 8
Thread Count 16
Processor Characteristics fc
Enabled Characteristics:
0x 2: 64-bit Capable
0x 3: Multi-Core
0x 4: Hardware Thread
0x 5: Execute Protection
0x 6: Enhanced Virtualization
Processor Family 2 006bh - AMD Zen Processor Family
Core Count 2 8
Core Enabled 2 8
Thread Count 2 16
[Cache Information (Type 7) - Length 27 - Handle 0005h]
Socket Designation L1 - Cache
Cache Configuration 0180h - WBEnabled Int NonSocketed L1
Maximum Cache Size 0200h - 512K
Installed Size 0200h - 512K
Supported SRAM Type 0010h - Pipeline-Burst
Current SRAM Type 0010h - Pipeline-Burst
Cache Speed 1ns
Error Correction Type Specification Reserved
System Cache Type Unified
Associativity 8-way Set-Associative
Maximum Cache Size 2 200 - 00000512l Kb
Installed Cache Size 2 200 - 00000512l Kb
[Cache Information (Type 7) - Length 27 - Handle 0006h]
Socket Designation L2 - Cache
Cache Configuration 0181h - WBEnabled Int NonSocketed L2
Maximum Cache Size 1000h - 4096K
Installed Size 1000h - 4096K
Cache Speed 1ns
Maximum Cache Size 2 1000 - 00004096l Kb
Installed Cache Size 2 1000 - 00004096l Kb
[Cache Information (Type 7) - Length 27 - Handle 0007h]
Socket Designation L3 - Cache
Cache Configuration 0182h - WBEnabled Int NonSocketed L3
Maximum Cache Size 2000h - 8192K
Installed Size 2000h - 8192K
Cache Speed 1ns
Associativity 16-way Set-Associative
Maximum Cache Size 2 2000 - 00008192l Kb
Installed Cache Size 2 2000 - 00008192l Kb
[OEM Strings (Type 11) - Length 5 - Handle 001fh]
Number of Strings 1
1 Modern Preload
[System Configuration Options (Type 12) - Length 5 - Handle 0020h]
[Physical Memory Array (Type 16) - Length 23 - Handle 0022h]
Location 03h - SystemBoard/Motherboard
Use 03h - System Memory
Memory Error Correction 03h - None
Maximum Capacity 33554432KB
Memory Error Inf Handle 0025h
Number of Memory Devices 2
[Memory Device (Type 17) - Length 84 - Handle 0023h]
Memory Error Info Handle 0026h
Total Width 64 bits
Data Width 64 bits
This is a very common BugCheck. Usually the exception address pinpoints.
the driver/function that caused the problem. Always note this address.
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled.
Arg2: fffff8061540b975, The address that the exception occurred at.
Arg3: 0000000000000000, Parameter 0 of the exception.
Arg4: 000000000000ac00, Parameter 1 of the exception.
14: kd> ln fffff8061540b975.
Browse module.
Set bu breakpoint.
(fffff806`1540b90c) nt!MiStoreCheckCandidatePage+0x69 | (fffff806`1540bb54) nt!HvpGenerateLogEntryDirtyData
nt!MiStoreCheckCandidatePage+0x69 fonksiyonu RAM'in sınıra geldiğini, yani yeterince yoğun olduğunu ve bu sebeple de bellek sayfalarının sayfa dosyası gibi ikincil depolamaya taşınmaya uygunluğunu belirlemek için incelenmesini içeriyor.nt!HvpGenerateLogEntryDirtyData Fonksiyonu da ismindeki "Dirty" takısından ve Hvp gibi kısaltmalardan anlayacağımız gibi Windows'un registry kısmındaki bir takım veriyi işaret ediyor.14: kd> KnL.
00 fffff387'5b81ad30 fffff8061'540b975 nt!MiStoreCheckCandidatePage+0x69
01 fffff387'5b81ade8 fffff361'5b81b758 nt!MiStoreWriteIssue+0xb8 *
02 fffff387'5b81ae48 fffff806'1540b975 nt!MiStoreCheckCandidatePage+0x69
03 fffff387'5b81aec8 fffff806'155a9a69 nt!EtwpCCSwapTrace+0x1a9
04 fffff387'5b81aed0 fffff806'155656b0 nt!HalpTscQueryCounterOrdered
05 fffff387'5b81aed8 fffff806'154b5b9f nt!KeQueryPerformanceCounter+0x5f
06 fffff387'5b81aee8 fffff806'154c7ef2 nt!KiInsertDeferredReadyList+0x12
07 fffff387'5b81b008 fffff806'15606a34 nt!SwapContext+0x614
08 fffff387'5b81b048 fffff806'15606146 nt!KiSwapContext+0x76
09 fffff387'5b81b188 fffff806'15438a30 nt!KiSwapThread+0x500
0a fffff387'5b81b1b8 fffff806'154d2a66 nt!KiUpdateTotalCyclesCurrentThread+0x86
0b fffff387'5b81b1d8 fffff806'1555ea76 nt!RtlGetExtendedContextLength2+0x46
0c fffff387'5b81b1e8 fffff806'15536e41 nt!KiReduceByEffectiveIdleSmtSet+0x79
0d fffff387'5b81b3d8 fffff806'156124ec nt!KiExceptionDispatch+0x12c
0e fffff387'5b81b4b8 fffff387'5b81b5d0 nt!SmGlobals+0x508
0f fffff387'5b81b4c8 fffff806'1540a7ca nt!SMKM_STORE_MGR<SM_TRAITS>::SmFeAddInitiate+0x3a6
10 fffff387'5b81b508 fffff806'15e50c40 nt!MiSystemPartition
11 fffff387'5b81b528 fffff806'1540b975 nt!MiStoreCheckCandidatePage+0x69
12 fffff387'5b81b5b8 fffff806'1560dd52 nt!KiPageFault+0x452
13 fffff387'5b81b5d0 fffff806'15f23ec8 nt!SmGlobals+0x508
14 fffff387'5b81b5e0 fffff806'155f9c00 nt!HalpApic1EndOfInterrupt
15 fffff387'5b81b6f8 fffff806'1540b056 nt!SmpPageWrite+0xca
16 fffff387'5b81b728 fffff806'1540b975 nt!MiStoreCheckCandidatePage+0x69
17 fffff387'5b81b740 fffff387'5b81b758 nt!MiStoreWriteIssue+0xb8
18 fffff387'5b81b750 fffff806'1540b969 nt!MiStoreCheckCandidatePage+0x5d
19 fffff387'5b81b758 fffff806'1540b1b8 nt!MiStoreWriteIssue+0xb8
20 fffff387'5b81b768 fffff806'1540b8ae nt!MiUpdatePfnBackingStore+0x66
21 fffff387'5b81b978 fffff806'1554fe1f nt!SMKM_STORE_MGR<SM_TRAITS>::SmDrainSList+0x2f
22 fffff387'5b81b9d8 fffff806'155bf0d9 nt!MiModifiedPageWriter+0x299
23 fffff387'5b81bad8 fffff806'155a9a69 nt!EtwpCCSwapTrace+0x1a9
24 fffff387'5b81bbd8 fffff806'155a9713 nt!EtwTraceContextSwap+0x83
25 fffff387'5b81bc08 fffff806'15548da5 nt!PspSystemThreadStartup+0x55
26 fffff387'5b81bc28 fffff806'155bee40 nt!MiModifiedPageWriter
27 fffff387'5b81bc58 fffff806'15606b58 nt!KiStartSystemThread+0x28
28 fffff387'5b81bc70 fffff806'15548d50 nt!PspSystemThreadStartup
14: kd> k
00 fffff387`610c79a0 fffff806`174986ab storport!StorEtwMiniportEvent+0x83d
01 fffff387`610c7cb0 fffff806`17470e17 storport!StorEtwMiniportEventProxy+0xff
02 fffff387`610c7de0 fffff806`17523f60 storport!StorPortExtendedFunction+0x1797
03 fffff387`610c7eb0 fffff806`17523a84 stornvme!ProcessCommandTrace+0x1f0
04 fffff387`610c7ff0 fffff806`17522f81 stornvme!ProcessCommandInSpecificQueue+0x254
05 fffff387`610c80b0 fffff806`1746556e stornvme!NVMeHwStartIo+0x1e1
06 fffff387`610c8110 fffff806`17464262 storport!RaidAdapterPostScatterGatherExecute+0x55e
07 fffff387`610c8190 fffff806`1746a4a3 storport!RaUnitStartIo+0x842
08 fffff387`610c82a0 fffff806`17469d6c storport!RaidStartIoPacket+0x4f3
09 fffff387`610c83d0 fffff806`17469b0a storport!RaUnitScsiIrp+0x21c
0a fffff387`610c8470 fffff806`1542d3f5 storport!RaDriverScsiIrp+0x5a
0b fffff387`610c84b0 fffff806`17555c33 nt!IofCallDriver+0x55
0c fffff387`610c84f0 fffff806`16dbaa16 EhStorClass!FilterDeviceEvtWdmIoctlIrpPreprocess+0x263
0d (Inline Function) --------`-------- Wdf01000!PreprocessIrp+0x2d
0e (Inline Function) --------`-------- Wdf01000!DispatchWorker+0x17a
0f (Inline Function) --------`-------- Wdf01000!FxDevice::Dispatch+0x198
10 fffff387`610c8540 fffff806`1542d3f5 Wdf01000!FxDevice::DispatchWithLock+0x266
11 fffff387`610c85a0 fffff806`1816822d nt!IofCallDriver+0x55
12 fffff387`610c85e0 fffff806`181675ec CLASSPNP!SubmitTransferPacket+0x29d
13 fffff387`610c8630 fffff806`181673a2 CLASSPNP!ServiceTransferRequest+0x21c
14 fffff387`610c86c0 fffff806`1816a213 CLASSPNP!ClassReadWrite+0x2e2
15 fffff387`610c8710 fffff806`1542d3f5 CLASSPNP!ClassGlobalDispatch+0x23
16 fffff387`610c8740 fffff806`1727188e nt!IofCallDriver+0x55
17 fffff387`610c8780 fffff806`17271f1f partmgr!PmWrite+0x10e
18 fffff387`610c8800 fffff806`1542d3f5 partmgr!PmGlobalDispatch+0x1f
19 fffff387`610c8830 fffff806`17271754 nt!IofCallDriver+0x55
1a fffff387`610c8870 fffff806`1727156e partmgr!PartitionIo+0x1d4
1b fffff387`610c8920 fffff806`17271f1f partmgr!PartitionWrite+0x1e
1c fffff387`610c8950 fffff806`1542d3f5 partmgr!PmGlobalDispatch+0x1f
1d fffff387`610c8980 fffff806`17361109 nt!IofCallDriver+0x55
*** WARNING: Unable to verify timestamp for klbackupdisk.sys < !
1e fffff387`610c89c0 fffff806`1fa74aeb volmgr!VmReadWrite+0xf9
1f fffff387`610c8a00 fffff387`610c8af9 klbackupdisk+0x4aeb
25 fffff387`610c8a30 fffff806`17f15ece nt!IofCallDriver+0x55
26 fffff387`610c8a70 fffff806`17f15b1c fvevol!FveFilterRundownReadWrite+0x33e
27 fffff387`610c8b60 fffff806`1fa74aeb fvevol!FveFilterRundownWrite+0x4c
28 fffff387`610c8c00 ffffb90f`6ff3f030 klbackupdisk+0x4aeb
Rich (BB code):KMODE_EXCEPTION_NOT_HANDLED (1e) This is a very common BugCheck. Usually the exception address pinpoints. the driver/function that caused the problem. Always note this address. as well as the link date of the driver/image that contains this address. Arguments: Arg1: ffffffffc0000005, The exception code that was not handled. Arg2: fffff8061540b975, The address that the exception occurred at. Arg3: 0000000000000000, Parameter 0 of the exception. Arg4: 000000000000ac00, Parameter 1 of the exception.
2.parametre bu dosyayı açıklamak için yeterli gibi.
Rich (BB code):14: kd> ln fffff8061540b975. Browse module. Set bu breakpoint. (fffff806`1540b90c) nt!MiStoreCheckCandidatePage+0x69 | (fffff806`1540bb54) nt!HvpGenerateLogEntryDirtyData
İlk ve 2.parametrelere bakınmak lazım. İlk parametrede (ve neredeyse bu dosyadaki her yerde karşıma çıkan) gördüğümüz sistem işlevi Store Manager. 7'den beri var olan ama bugüne kadar Microsoft'un hakkında tek bir kelime etmediği, isminin de Storage kısaltılması yani depolama birimleriyle alakalı olduğu da aşikar.
Store'SAR, USB flash bellek veya anakart gibi uygun herhangi NVM türü RAM biçimi olabilir. Her Store daha sonra Store sayfaları adı verilen bir sürü sayfa içeriyor. Bu sayfalar bellek yöneticisi tarafından kullanılan sayfalarla aynı ancak bunları yönetmekten kimin sorumlu olduğunu ayırt etmek için uygun bir şekilde Store Manager olarak adlandırılmışlar. Store Manager hangi sayfaların hangi Store üzerinde olduğunu takip ediyor ve her sayfa bir Store anahtarı ile sadece o Store'a ait olacak bir şekilde tanımlanıyor.
Her Storage'in sanal ve fiziksel bir bölümü oluyor. Sanal kısım yalnızca bir sayfa dosyası tarafından desteklenen verileri içeriyor. Buna bağlı olarak sayfa dosyası destekli veriler, yalnızca fiziksel bellekte bulunduğu için buradaki durumu destekliyor. Herhangi bir noktada diske işlenmiyorlar.
Öte yandan, fiziksel kısım statik (static) ve dinamik (volatile) önbellekler olarak ikiye ayrılıyor. Statik önbellek, Store Manager'ın kullanıcı modu bölümü tarafından yönetiliyor ve onu dolduran veriler, genellikle hangi dosyalara en sık erişildiğini belirlemek için erişim günlüklerinin kullanılması yoluyla bu hizmet tarafından belirleniyor.
Eki Görüntüle 55856
Unified Caching Mechanism
For those who think it's easier to annoy you than to Google 'Unified caching mechanism' themselves.letmegooglethat.com
Aslında buradakint!MiStoreCheckCandidatePage+0x69fonksiyonu RAM'in sınıra geldiğini, yani yeterince yoğun olduğunu ve bu sebeple de bellek sayfalarının sayfa dosyası gibi ikincil depolamaya taşınmaya uygunluğunu belirlemek için incelenmesini içeriyor.
Bu arada sistem bu çağrıda çöküyor. Bu da bellek yönetimiyle ilgili bir sorun olabileceğini düşündürdü açıkçası. Bundan önce, mavi ekranlar ya da garip sorunları yaşayıp yaşamadığını da belirtmeni isterim bir noktada.
Diğernt!HvpGenerateLogEntryDirtyDatafonksiyonu da ismindeki "dirty" takısından ve hvp gibi kısaltmalardan anlayacağımız gibi Windows'un registry kısmındaki bir takım veriyi işaret ediyor.
Daha doğrusu dirty veriler (yapılan ancak henüz diske işlenmemiş değişiklikler) için günlük girdileri oluşturmaktan sorumlu oluyor. Kayıt defterindeki tüm değişikliklerin düzgün bir şekilde kaydedilmesini sağlayarak sistem arızaları durumunda işlem desteği ve kurtarmaya olanak tanıyor. Bu girdinin burada olma sebebi çökme anındaki bir takım değişikliklerin kaydedilmesi olduğunu düşünüyorum.
Aşağıdaki yığına bak bir sürü st Manager girdisi göreceksin. Bir takım yazma hataları da göreceksin. Fiziksel bellekten çağrılma gibi bir sürü işlev de cabası.
Rich (BB code):14: kd> KnL. 00 fffff387'5b81ad30 fffff8061'540b975 nt!MiStoreCheckCandidatePage+0x69 01 fffff387'5b81ade8 fffff361'5b81b758 nt!MiStoreWriteIssue+0xb8 * 02 fffff387'5b81ae48 fffff806'1540b975 nt!MiStoreCheckCandidatePage+0x69 03 fffff387'5b81aec8 fffff806'155a9a69 nt!EtwpCCSwapTrace+0x1a9 04 fffff387'5b81aed0 fffff806'155656b0 nt!HalpTscQueryCounterOrdered 05 fffff387'5b81aed8 fffff806'154b5b9f nt!KeQueryPerformanceCounter+0x5f 06 fffff387'5b81aee8 fffff806'154c7ef2 nt!KiInsertDeferredReadyList+0x12 07 fffff387'5b81b008 fffff806'15606a34 nt!SwapContext+0x614 08 fffff387'5b81b048 fffff806'15606146 nt!KiSwapContext+0x76 09 fffff387'5b81b188 fffff806'15438a30 nt!KiSwapThread+0x500 0a fffff387'5b81b1b8 fffff806'154d2a66 nt!KiUpdateTotalCyclesCurrentThread+0x86 0b fffff387'5b81b1d8 fffff806'1555ea76 nt!RtlGetExtendedContextLength2+0x46 0c fffff387'5b81b1e8 fffff806'15536e41 nt!KiReduceByEffectiveIdleSmtSet+0x79 0d fffff387'5b81b3d8 fffff806'156124ec nt!KiExceptionDispatch+0x12c 0e fffff387'5b81b4b8 fffff387'5b81b5d0 nt!SmGlobals+0x508 0f fffff387'5b81b4c8 fffff806'1540a7ca nt!SMKM_STORE_MGR<SM_TRAITS>::SmFeAddInitiate+0x3a6 10 fffff387'5b81b508 fffff806'15e50c40 nt!MiSystemPartition 11 fffff387'5b81b528 fffff806'1540b975 nt!MiStoreCheckCandidatePage+0x69 12 fffff387'5b81b5b8 fffff806'1560dd52 nt!KiPageFault+0x452 13 fffff387'5b81b5d0 fffff806'15f23ec8 nt!SmGlobals+0x508 14 fffff387'5b81b5e0 fffff806'155f9c00 nt!HalpApic1EndOfInterrupt 15 fffff387'5b81b6f8 fffff806'1540b056 nt!SmpPageWrite+0xca 16 fffff387'5b81b728 fffff806'1540b975 nt!MiStoreCheckCandidatePage+0x69 17 fffff387'5b81b740 fffff387'5b81b758 nt!MiStoreWriteIssue+0xb8 18 fffff387'5b81b750 fffff806'1540b969 nt!MiStoreCheckCandidatePage+0x5d 19 fffff387'5b81b758 fffff806'1540b1b8 nt!MiStoreWriteIssue+0xb8 20 fffff387'5b81b768 fffff806'1540b8ae nt!MiUpdatePfnBackingStore+0x66 21 fffff387'5b81b978 fffff806'1554fe1f nt!SMKM_STORE_MGR<SM_TRAITS>::SmDrainSList+0x2f 22 fffff387'5b81b9d8 fffff806'155bf0d9 nt!MiModifiedPageWriter+0x299 23 fffff387'5b81bad8 fffff806'155a9a69 nt!EtwpCCSwapTrace+0x1a9 24 fffff387'5b81bbd8 fffff806'155a9713 nt!EtwTraceContextSwap+0x83 25 fffff387'5b81bc08 fffff806'15548da5 nt!PspSystemThreadStartup+0x55 26 fffff387'5b81bc28 fffff806'155bee40 nt!MiModifiedPageWriter 27 fffff387'5b81bc58 fffff806'15606b58 nt!KiStartSystemThread+0x28 28 fffff387'5b81bc70 fffff806'15548d50 nt!PspSystemThreadStartup
Asıl bu dosyada göze çarpan şey Kaspersky oldu:
Kod:14: kd> k # Child-SP RetAddr Call Site. 00 fffff387`610c79a0 fffff806`174986ab storport!StorEtwMiniportEvent+0x83d 01 fffff387`610c7cb0 fffff806`17470e17 storport!StorEtwMiniportEventProxy+0xff 02 fffff387`610c7de0 fffff806`17523f60 storport!StorPortExtendedFunction+0x1797 03 fffff387`610c7eb0 fffff806`17523a84 stornvme!ProcessCommandTrace+0x1f0 04 fffff387`610c7ff0 fffff806`17522f81 stornvme!ProcessCommandInSpecificQueue+0x254 05 fffff387`610c80b0 fffff806`1746556e stornvme!NVMeHwStartIo+0x1e1 06 fffff387`610c8110 fffff806`17464262 storport!RaidAdapterPostScatterGatherExecute+0x55e 07 fffff387`610c8190 fffff806`1746a4a3 storport!RaUnitStartIo+0x842 08 fffff387`610c82a0 fffff806`17469d6c storport!RaidStartIoPacket+0x4f3 09 fffff387`610c83d0 fffff806`17469b0a storport!RaUnitScsiIrp+0x21c 0a fffff387`610c8470 fffff806`1542d3f5 storport!RaDriverScsiIrp+0x5a 0b fffff387`610c84b0 fffff806`17555c33 nt!IofCallDriver+0x55 0c fffff387`610c84f0 fffff806`16dbaa16 EhStorClass!FilterDeviceEvtWdmIoctlIrpPreprocess+0x263 0d (Inline Function) --------`-------- Wdf01000!PreprocessIrp+0x2d 0e (Inline Function) --------`-------- Wdf01000!DispatchWorker+0x17a 0f (Inline Function) --------`-------- Wdf01000!FxDevice::Dispatch+0x198 10 fffff387`610c8540 fffff806`1542d3f5 Wdf01000!FxDevice::DispatchWithLock+0x266 11 fffff387`610c85a0 fffff806`1816822d nt!IofCallDriver+0x55 12 fffff387`610c85e0 fffff806`181675ec CLASSPNP!SubmitTransferPacket+0x29d 13 fffff387`610c8630 fffff806`181673a2 CLASSPNP!ServiceTransferRequest+0x21c 14 fffff387`610c86c0 fffff806`1816a213 CLASSPNP!ClassReadWrite+0x2e2 15 fffff387`610c8710 fffff806`1542d3f5 CLASSPNP!ClassGlobalDispatch+0x23 16 fffff387`610c8740 fffff806`1727188e nt!IofCallDriver+0x55 17 fffff387`610c8780 fffff806`17271f1f partmgr!PmWrite+0x10e 18 fffff387`610c8800 fffff806`1542d3f5 partmgr!PmGlobalDispatch+0x1f 19 fffff387`610c8830 fffff806`17271754 nt!IofCallDriver+0x55 1a fffff387`610c8870 fffff806`1727156e partmgr!PartitionIo+0x1d4 1b fffff387`610c8920 fffff806`17271f1f partmgr!PartitionWrite+0x1e 1c fffff387`610c8950 fffff806`1542d3f5 partmgr!PmGlobalDispatch+0x1f 1d fffff387`610c8980 fffff806`17361109 nt!IofCallDriver+0x55 *** WARNING: Unable to verify timestamp for klbackupdisk.sys < ! 1e fffff387`610c89c0 fffff806`1fa74aeb volmgr!VmReadWrite+0xf9 1f fffff387`610c8a00 fffff387`610c8af9 klbackupdisk+0x4aeb 25 fffff387`610c8a30 fffff806`17f15ece nt!IofCallDriver+0x55 26 fffff387`610c8a70 fffff806`17f15b1c fvevol!FveFilterRundownReadWrite+0x33e 27 fffff387`610c8b60 fffff806`1fa74aeb fvevol!FveFilterRundownWrite+0x4c 28 fffff387`610c8c00 ffffb90f`6ff3f030 klbackupdisk+0x4aeb
klbackupdisk.sys, Kaspersky'ın Backup disk filter işlevine ait bir sürücü. Ardından gelen bir takım işlevler, diske işaret eden stor sürücüleri de ortadalar. Cihazın tam sorununu açıklamadığın için Kaspersky'ı kaldırmanı istiyorum bu noktada. Bunun yanında "özel görünümler" başlığı altından "yönetim olayları" raporunu kaydedip paylaşman da iyi olabilir.
Eki Görüntüle 55859
BIOS zaten güncel. Harici GPU kapatıp kullanmanız mümkün mü bir süre?
Bir de Windows sürümünüz eski gibi, her ne kadar soruna bunun sebep olduğunu düşünmesem de.
10.0.19041.4522
Kod:KMODE_EXCEPTION_NOT_HANDLED (1e) This is a very common BugCheck. Usually the exception address pinpoints. the driver/function that caused the problem. Always note this address. as well as the link date of the driver/image that contains this address. Arguments: Arg1: ffffffffc0000005, The exception code that was not handled. Arg2: fffff8061540b975, The address that the exception occurred at. Arg3: 0000000000000000, Parameter 0 of the exception. Arg4: 000000000000ac00, Parameter 1 of the exception. Debugging Details: ------------------ ************************************************************************* *** *** *** *** *** Either you specified an unqualified symbol, or your debugger *** *** doesn't have full symbol information. Unqualified symbol *** *** resolution is turned off by default. Please either specify a *** *** fully qualified symbol module!symbolname, or enable resolution *** *** of unqualified symbols by typing ".symopt- 100". Note that *** *** enabling unqualified symbol resolution with network symbol *** *** server shares in the symbol path may cause the debugger to *** *** appear to hang for long periods of time when an incorrect *** *** symbol name is typed or the network symbol server is down. *** *** *** *** For some commands to work properly, your symbol path *** *** must point to .pdb files that have full type information. *** *** *** *** Certain .pdb files (such as the public OS symbols) do not *** *** contain the required information. Contact the group that *** *** provided you with these symbols if you need this command to *** *** work. *** *** *** *** Type referenced: ExceptionRecord *** *** *** ************************************************************************* ************************************************************************* *** *** *** *** *** Either you specified an unqualified symbol, or your debugger *** *** doesn't have full symbol information. Unqualified symbol *** *** resolution is turned off by default. Please either specify a *** *** fully qualified symbol module!symbolname, or enable resolution *** *** of unqualified symbols by typing ".symopt- 100". Note that *** *** enabling unqualified symbol resolution with network symbol *** *** server shares in the symbol path may cause the debugger to *** *** appear to hang for long periods of time when an incorrect *** *** symbol name is typed or the network symbol server is down. *** *** *** *** For some commands to work properly, your symbol path *** *** must point to .pdb files that have full type information. *** *** *** *** Certain .pdb files (such as the public OS symbols) do not *** *** contain the required information. Contact the group that *** *** provided you with these symbols if you need this command to *** *** work. *** *** *** *** Type referenced: ContextRecord *** *** *** ************************************************************************* KEY_VALUES_STRING: 1 Key : Analysis.CPU.mSec Value: 2530. Key : Analysis.Elapsed.mSec Value: 12129. Key : Analysis.IO.Other.Mb Value: 7 Key : Analysis.IO.Read.Mb Value: 0 Key : Analysis.IO.Write.Mb Value: 18. Key : Analysis.Init.CPU.mSec Value: 968. Key : Analysis.Init.Elapsed.mSec Value: 181289. Key : Analysis.Memory.CommitPeak.Mb Value: 83. Key : Bugcheck.Code.LegacyAPI Value: 0x1e. Key : Bugcheck.Code.TargetModel Value: 0x1e. Key : Failure.Bucket Value: AV_R_nt!MiStoreCheckCandidatePage Key : Failure.Hash Value: {915aa067-ef20-d6c5-fc70-bf83e248aade} Key : WER.OS.Branch Value: vb_release. Key : WER.OS.Version Value: 10.0.19041.1 BUGCHECK_CODE: 1e. BUGCHECK_P1: ffffffffc0000005. BUGCHECK_P2: fffff8061540b975. BUGCHECK_P3: 0 BUGCHECK_P4: ac00. FILE_IN_CAB: 061224-11062-01.dmp EXCEPTION_PARAMETER1: 0000000000000000. EXCEPTION_PARAMETER2: 000000000000ac00. READ_ADDRESS: fffff80615efb390: Unable to get MiVisibleState. Unable to get NonPagedPoolStart. Unable to get NonPagedPoolEnd. Unable to get PagedPoolStart. Unable to get PagedPoolEnd. unable to get nt!MmSpecialPagesInUse 000000000000ac00. BLACKBOXBSD: 1 (!blackboxbsd) BLACKBOXNTFS: 1 (!blackboxntfs) BLACKBOXPNP: 1 (!blackboxpnp) BLACKBOXWINLOGON: 1 CUSTOMER_CRASH_COUNT: 1 PROCESS_NAME: System. TRAP_FRAME: ffff800000000000 -- (.trap 0xffff800000000000) Unable to read trap frame at ffff8000`00000000 STACK_TEXT: fffff387`5b81ad18 fffff806`1569d1f7 : 00000000`0000001e ffffffff`c0000005 fffff806`1540b975 00000000`00000000 : nt!KeBugCheckEx fffff387`5b81ad20 fffff806`156124ec : 00000000`00001000 fffff387`5b81b5c0 ffff8000`00000000 00000000`00000000 : nt!KiDispatchException+0x13fb37 fffff387`5b81b3e0 fffff806`1560dd52 : 00000000`00000000 00000000`00000000 fffff806`15f23ec8 00000000`00000000 : nt!KiExceptionDispatch+0x12c fffff387`5b81b5c0 fffff806`1540b975 : fffff806`1540b1b8 00000000`00000000 fffff806`1540b8ae 00000000`00004e91 : nt!KiPageFault+0x452 fffff387`5b81b758 000001c0`00000084 : fffff387`5b81b879 00000000`00004e91 00000000`00004e91 00000000`00000001 : nt!MiStoreCheckCandidatePage+0x69 fffff387`5b81b7b8 fffff387`5b81b879 : 00000000`00004e91 00000000`00004e91 00000000`00000001 00000000`0000ac00 : 0x000001c0`00000084 fffff387`5b81b7c0 00000000`00004e91 : 00000000`00004e91 00000000`00000001 00000000`0000ac00 ffffb90f`20004e91 : 0xfffff387`5b81b879 fffff387`5b81b7c8 00000000`00004e91 : 00000000`00000001 00000000`0000ac00 ffffb90f`20004e91 00000000`00000001 : 0x4e91. fffff387`5b81b7d0 00000000`00000001 : 00000000`0000ac00 ffffb90f`20004e91 00000000`00000001 00000068`00000000 : 0x4e91. fffff387`5b81b7d8 00000000`0000ac00 : ffffb90f`20004e91 00000000`00000001 00000068`00000000 00000100`00000000 : 0x1. fffff387`5b81b7e0 ffffb90f`20004e91 : 00000000`00000001 00000068`00000000 00000100`00000000 ffffb90f`6c495770 : 0xac00. fffff387`5b81b7e8 00000000`00000001 : 00000068`00000000 00000100`00000000 ffffb90f`6c495770 00000000`00000000 : 0xffffb90f`20004e91 fffff387`5b81b7f0 00000068`00000000 : 00000100`00000000 ffffb90f`6c495770 00000000`00000000 00000000`00000011 : 0x1. fffff387`5b81b7f8 00000100`00000000 : ffffb90f`6c495770 00000000`00000000 00000000`00000011 00000000`0000ac00 : 0x00000068`00000000 fffff387`5b81b800 ffffb90f`6c495770 : 00000000`00000000 00000000`00000011 00000000`0000ac00 ffffb90f`7bec9450 : 0x00000100`00000000 fffff387`5b81b808 00000000`00000000 : 00000000`00000011 00000000`0000ac00 ffffb90f`7bec9450 20000000`00004e91 : 0xffffb90f`6c495770 SYMBOL_NAME: nt!MiStoreCheckCandidatePage+69 MODULE_NAME: nt. IMAGE_VERSION: 10.0.19041.4522 STACK_COMMAND: .cxr; .ecxr ; kb. IMAGE_NAME: ntkrnlmp.exe BUCKET_ID_FUNC_OFFSET: 69. FAILURE_BUCKET_ID: AV_R_nt!MiStoreCheckCandidatePage OS_VERSION: 10.0.19041.1 BUILDLAB_STR: vb_release. OSPLATFORM_TYPE: x64. OSNAME: Windows 10. FAILURE_ID_HASH: {915aa067-ef20-d6c5-fc70-bf83e248aade} Followup: MachineOwner. --------- PnpActivityId : {00000000-0000-0000-0000-000000000000} PnpActivityTime : 133626715178458823. PnpEventInformation: 3 PnpEventInProgress : 0 PnpProblemCode : 24. PnpVetoType : 0 DeviceId : SW\{96E080C7-143C-11D1-B40F-00A0C9223196}\{3C0D501A-140B-11D1-B40F-00A0C9223196} VetoString : start end module name. ffffa22e`76600000 ffffa22e`768cd000 win32kbase (deferred) ffffa22e`768d0000 ffffa22e`76c80000 win32kfull (deferred) ffffa22e`76c90000 ffffa22e`76cd9000 cdd (deferred) ffffa22e`77560000 ffffa22e`775fb000 win32k (deferred) fffff806`11230000 fffff806`11258000 mcupdate_AuthenticAMD (deferred) fffff806`11260000 fffff806`11266000 hal (deferred) fffff806`11270000 fffff806`1127b000 kd (deferred) fffff806`11280000 fffff806`112a8000 tm (deferred) fffff806`112b0000 fffff806`1131e000 CLFS (deferred) fffff806`11320000 fffff806`1133a000 PSHED (deferred) fffff806`11340000 fffff806`1134b000 BOOTVID (deferred) fffff806`11350000 fffff806`11467000 clipsp (deferred) fffff806`11470000 fffff806`114de000 FLTMGR (deferred) fffff806`114e0000 fffff806`11509000 ksecdd (deferred) fffff806`11510000 fffff806`11573000 msrpc (deferred) fffff806`11580000 fffff806`1158e000 cmimcext (deferred) fffff806`11590000 fffff806`115a1000 werkernel (deferred) fffff806`115b0000 fffff806`115bc000 ntosext (deferred) fffff806`115c0000 fffff806`115d3000 WDFLDR (deferred) fffff806`115e0000 fffff806`115ef000 SleepStudyHelper (deferred) fffff806`115f0000 fffff806`11601000 WppRecorder (deferred) fffff806`11610000 fffff806`1162a000 SgrmAgent (deferred) fffff806`15200000 fffff806`16246000 nt (pdb symbols) C:\ProgramData\Dbg\sym\ntkrnlmp.pdb\ADCC367AF84D728686C57E76F105B7911\ntkrnlmp.pdb fffff806`16c00000 fffff806`16cec000 CI (deferred) fffff806`16cf0000 fffff806`16dab000 cng (deferred) fffff806`16db0000 fffff806`16e81000 Wdf01000 (deferred) fffff806`16e90000 fffff806`16eb6000 acpiex (deferred) fffff806`16ec0000 fffff806`16f8c000 ACPI (deferred) fffff806`16f90000 fffff806`16f9c000 WMILIB (deferred) fffff806`16fa0000 fffff806`16fab000 msisadrv (deferred) fffff806`16fb0000 fffff806`17028000 pci (deferred) fffff806`17030000 fffff806`17075000 tpm (deferred) fffff806`17090000 fffff806`170fb000 intelpep (deferred) fffff806`17100000 fffff806`17117000 WindowsTrustedRT (deferred) fffff806`17120000 fffff806`1712b000 IntelTA (deferred) fffff806`17130000 fffff806`1713b000 WindowsTrustedRTProxy (deferred) fffff806`17140000 fffff806`17154000 pcw (deferred) fffff806`17160000 fffff806`171be000 klupd_K4W_21_17_arkmon (deferred) fffff806`171c0000 fffff806`171d5000 vdrvroot (deferred) fffff806`171e0000 fffff806`1721a000 cm_km (deferred) fffff806`17220000 fffff806`1724f000 pdc (deferred) fffff806`17250000 fffff806`17269000 CEA (deferred) fffff806`17270000 fffff806`172a1000 partmgr (deferred) fffff806`172b0000 fffff806`1735b000 spaceport (deferred) fffff806`17360000 fffff806`17379000 volmgr (deferred) fffff806`17380000 fffff806`173e3000 volmgrx (deferred) fffff806`173f0000 fffff806`173fd000 Fs_Rec (deferred) fffff806`17400000 fffff806`1741e000 mountmgr (deferred) fffff806`17420000 fffff806`17452000 storahci (deferred) fffff806`17460000 fffff806`17515000 storport (deferred) fffff806`17520000 fffff806`1754f000 stornvme (deferred) fffff806`17550000 fffff806`1756c000 EhStorClass (deferred) fffff806`17570000 fffff806`1758a000 fileinfo (deferred) fffff806`17590000 fffff806`175d0000 Wof (deferred) fffff806`175e0000 fffff806`1774f000 ndis (deferred) fffff806`17750000 fffff806`177ec000 NETIO (deferred) fffff806`177f0000 fffff806`177fb000 volume (deferred) fffff806`17800000 fffff806`17ad7000 Ntfs (deferred) fffff806`17ae0000 fffff806`17b12000 ksecpkg (deferred) fffff806`17b20000 fffff806`17b41000 amdpsp (deferred) fffff806`17b50000 fffff806`17e3d000 tcpip (deferred) fffff806`17e40000 fffff806`17ebf000 fwpkclnt (deferred) fffff806`17ec0000 fffff806`17ef0000 wfplwfs (deferred) fffff806`17f00000 fffff806`17fc9000 fvevol (deferred) fffff806`17fd0000 fffff806`1803d000 volsnap (deferred) fffff806`18040000 fffff806`18090000 rdyboost (deferred) fffff806`180a0000 fffff806`180c6000 mup (deferred) fffff806`180d0000 fffff806`180fa000 klupd_K4W_21_17_klbg (deferred) fffff806`18100000 fffff806`18112000 iorate (deferred) fffff806`18140000 fffff806`1815f000 disk (deferred) fffff806`18160000 fffff806`181d3000 CLASSPNP (deferred) fffff806`1fa70000 fffff806`1fa85000 klbackupdisk (deferred) fffff806`1fa90000 fffff806`1fb46000 klflt (deferred) fffff806`1fb50000 fffff806`1fb80000 cdrom (deferred) fffff806`1fb90000 fffff806`1fbcc000 klbackupflt (deferred) fffff806`1fbd0000 fffff806`1fbe5000 filecrypt (deferred) fffff806`1fbf0000 fffff806`1fbfe000 tbs (deferred) fffff806`1fc00000 fffff806`1fc4e000 ahcache (deferred) fffff806`1fc50000 fffff806`1fc8c000 amdppm (deferred) fffff806`1fd70000 fffff806`1fd8e000 crashdmp (deferred) fffff806`26800000 fffff806`26a25000 klhk (deferred) fffff806`26a30000 fffff806`26a3d000 klpd (deferred) fffff806`26a40000 fffff806`26b0d000 klgse (deferred) fffff806`26b10000 fffff806`26b20000 UCPD (deferred) fffff806`26b30000 fffff806`26b4a000 kldisk (deferred) fffff806`26b50000 fffff806`26b5a000 Null (deferred) fffff806`26b60000 fffff806`26b6a000 Beep (deferred) fffff806`26b70000 fffff806`26f1a000 dxgkrnl (deferred) fffff806`26f20000 fffff806`26f38000 watchdog (deferred) fffff806`26f40000 fffff806`26f56000 BasicDisplay (deferred) fffff806`26f60000 fffff806`26f71000 BasicRender (deferred) fffff806`26f80000 fffff806`26f9c000 Npfs (deferred) fffff806`26fa0000 fffff806`26fb1000 Msfs (deferred) fffff806`26fc0000 fffff806`26fde000 CimFS (deferred) fffff806`26fe0000 fffff806`27002000 tdx (deferred) fffff806`27010000 fffff806`27020000 TDI (deferred) fffff806`27030000 fffff806`2708c000 netbt (deferred) fffff806`27090000 fffff806`270a4000 afunix (deferred) fffff806`270b0000 fffff806`27156000 afd (deferred) fffff806`27160000 fffff806`271e0000 klwtp (deferred) fffff806`271f0000 fffff806`27204000 klim6 (deferred) fffff806`27210000 fffff806`2722a000 vwififlt (deferred) fffff806`27230000 fffff806`2725b000 pacer (deferred) fffff806`27260000 fffff806`27274000 ndiscap (deferred) fffff806`27280000 fffff806`27294000 netbios (deferred) fffff806`272a0000 fffff806`27341000 Vid (deferred) fffff806`27350000 fffff806`27374000 winhvr (deferred) fffff806`27380000 fffff806`27393000 klpnpflt (deferred) fffff806`273a0000 fffff806`273b8000 klkbdflt (deferred) fffff806`273c0000 fffff806`2743b000 rdbss (deferred) fffff806`27440000 fffff806`27452000 nsiproxy (deferred) fffff806`27460000 fffff806`2746e000 npsvctrig (deferred) fffff806`27470000 fffff806`27480000 mssmbios (deferred) fffff806`27490000 fffff806`2766c000 kneps (deferred) fffff806`27670000 fffff806`2767d000 kdnic (deferred) fffff806`27680000 fffff806`27695000 umbus (deferred) fffff806`276a0000 fffff806`27801000 klif (deferred) fffff806`27810000 fffff806`27888000 ks (deferred) fffff806`278d0000 fffff806`278da000 gpuenergydrv (deferred) fffff806`278e0000 fffff806`2790d000 dfsc (deferred) fffff806`27910000 fffff806`27925000 CAD (deferred) fffff806`27930000 fffff806`2799c000 fastfat (deferred) fffff806`279a0000 fffff806`279b7000 bam (deferred) fffff806`279c0000 fffff806`279ca000 wintun (deferred) fffff806`279d0000 fffff806`279dc000 tap0901 (deferred) fffff806`279e0000 fffff806`279f2000 CompositeBus (deferred) fffff806`37200000 fffff806`37221000 drmk (deferred) fffff806`37230000 fffff806`3734c000 rt640x64 (deferred) fffff806`37830000 fffff806`3b333000 nvlddmkm (deferred) fffff806`3b340000 fffff806`3b365000 HDAudBus (deferred) fffff806`3b370000 fffff806`3b3d6000 portcls (deferred) fffff806`43c00000 fffff806`43cd6000 peauth (deferred) fffff806`43ce0000 fffff806`43d01000 rasl2tp (deferred) fffff806`43d10000 fffff806`43d31000 raspptp (deferred) fffff806`43d40000 fffff806`43d5c000 raspppoe (deferred) fffff806`43d60000 fffff806`43d9a000 ndiswan (deferred) fffff806`43da0000 fffff806`43df7000 klupd_K4W_21_17_klark (deferred) fffff806`43e00000 fffff806`43e41000 klupd_K4W_21_17_mark (deferred) fffff806`43e50000 fffff806`43e62000 condrv (deferred) fffff806`43e70000 fffff806`43eaa000 klids (deferred) fffff806`43f40000 fffff806`44a81000 rtwlane (deferred) fffff806`44a90000 fffff806`44b82000 wdiwifi (deferred) fffff806`44b90000 fffff806`44b9e000 vwifibus (deferred) fffff806`51e00000 fffff806`51e44000 ucx01000 (deferred) fffff806`51e50000 fffff806`52520000 amdacpbus (deferred) fffff806`52530000 fffff806`52551000 i8042prt (deferred) fffff806`52560000 fffff806`52574000 kbdclass (deferred) fffff806`52580000 fffff806`5258f000 CmBatt (deferred) fffff806`52590000 fffff806`525a0000 BATTC (deferred) fffff806`525b0000 fffff806`525c4000 AcpiVpc (deferred) fffff806`525d0000 fffff806`525dc000 wmiacpi (deferred) fffff806`525e0000 fffff806`525ed000 amdgpio2 (deferred) fffff806`525f0000 fffff806`52623000 msgpioclx (deferred) fffff806`52630000 fffff806`52642000 amdi2c (deferred) fffff806`52650000 fffff806`5266a000 SpbCx (deferred) fffff806`52670000 fffff806`5267e000 UEFI (deferred) fffff806`52680000 fffff806`52695000 kltun (deferred) fffff806`526a0000 fffff806`526af000 nvvad64v (deferred) fffff806`526b0000 fffff806`526c1000 ksthunk (deferred) fffff806`526d0000 fffff806`526dd000 NvModuleTracker (deferred) fffff806`526e0000 fffff806`526f0000 nvvhci (deferred) fffff806`52700000 fffff806`5270d000 NdisVirtualBus (deferred) fffff806`52710000 fffff806`5271c000 swenum (deferred) fffff806`52720000 fffff806`5272e000 rdpbus (deferred) fffff806`52730000 fffff806`52742000 MSKSSRV (deferred) fffff806`52750000 fffff806`52765000 hidi2c (deferred) fffff806`52770000 fffff806`5277b000 mshidkmdf (deferred) fffff806`52780000 fffff806`527c1000 HIDCLASS (deferred) fffff806`527d0000 fffff806`527e3000 HIDPARSE (deferred) fffff806`527f0000 fffff806`52893000 UsbHub3 (deferred) fffff806`528a0000 fffff806`528ae000 USBD (deferred) fffff806`528b0000 fffff806`528c0000 mouhid (deferred) fffff806`528d0000 fffff806`528e7000 klmouflt (deferred) fffff806`528f0000 fffff806`52903000 mouclass (deferred) fffff806`52910000 fffff806`5291c000 MTConfig (deferred) fffff806`52930000 fffff806`56d3a000 amdkmdag (deferred) fffff806`56d40000 fffff806`56ddd000 USBXHCI (deferred) fffff806`56de0000 fffff806`56dfe000 nvhda64v (deferred) fffff806`5e400000 fffff806`5e4d0000 RtkBtfilter (deferred) fffff806`5e4e0000 fffff806`5e501000 BTHUSB (deferred) fffff806`5e510000 fffff806`5e697000 BTHport (deferred) fffff806`5e6a0000 fffff806`5e6af000 ndistapi (deferred) fffff806`5e6b0000 fffff806`5e704000 usbvideo (deferred) fffff806`5e710000 fffff806`5e74d000 rfcomm (deferred) fffff806`5e750000 fffff806`5e772000 BthEnum (deferred) fffff806`5e780000 fffff806`5e7a6000 bthpan (deferred) fffff806`5e7b0000 fffff806`5e7d1000 Microsoft_Bluetooth_Legacy_LEEnumerator (deferred) fffff806`5e7e0000 fffff806`5e7f2000 hidusb (deferred) fffff806`5e800000 fffff806`5e811000 kbdhid (deferred) fffff806`5e830000 fffff806`5e83f000 dump_dumpstorport (deferred) fffff806`5e870000 fffff806`5e89f000 dump_stornvme (deferred) fffff806`5e8c0000 fffff806`5e8dd000 dump_dumpfve (deferred) fffff806`5e8e0000 fffff806`5e9c0000 dxgmms2 (deferred) fffff806`5e9d0000 fffff806`5e9eb000 monitor (deferred) fffff806`5e9f0000 fffff806`5ea1b000 luafv (deferred) fffff806`5ea20000 fffff806`5ea57000 wcifs (deferred) fffff806`5ea60000 fffff806`5eae2000 cldflt (deferred) fffff806`5eaf0000 fffff806`5eb04000 mmcss (deferred) fffff806`5eb10000 fffff806`5eb2a000 storqosflt (deferred) fffff806`5eb30000 fffff806`5eb57000 bindflt (deferred) fffff806`5eb60000 fffff806`5eb78000 lltdio (deferred) fffff806`5eb80000 fffff806`5eb98000 mslldp (deferred) fffff806`5eba0000 fffff806`5ebbb000 rspndr (deferred) fffff806`5ebc0000 fffff806`5ebdd000 wanarp (deferred) fffff806`5ebe0000 fffff806`5ebf8000 ndisuio (deferred) fffff806`5ec00000 fffff806`5ecc0000 nwifi (deferred) fffff806`5ecd0000 fffff806`5ed26000 msquic (deferred) fffff806`5ed30000 fffff806`5eeb8000 HTTP (deferred) fffff806`5eec0000 fffff806`5eee5000 bowser (deferred) fffff806`5eef0000 fffff806`5ef0a000 mpsdrv (deferred) fffff806`5ef10000 fffff806`5efa4000 mrxsmb (deferred) fffff806`5efb0000 fffff806`5eff5000 mrxsmb20 (deferred) fffff806`5f000000 fffff806`5f013000 vwifimp (deferred) fffff806`5f020000 fffff806`5f076000 srvnet (deferred) fffff806`5f080000 fffff806`5f148000 srv2 (deferred) fffff806`5f150000 fffff806`5f1a2000 mrxsmb10 (deferred) fffff806`5f1b0000 fffff806`5f1d7000 Ndu (deferred) fffff806`5f1e0000 fffff806`5f1ef000 FBNetFlt (deferred) fffff806`5f1f0000 fffff806`5f92b000 RTKVHD64 (deferred) fffff806`5f930000 fffff806`5f964000 usbccgp (deferred) fffff806`5f970000 fffff806`5f985000 tcpipreg (deferred) fffff806`5f990000 fffff806`5f9ad000 rassstp (deferred) fffff806`5f9b0000 fffff806`5f9cd000 NDProxy (deferred) fffff806`5f9d0000 fffff806`5f9f8000 AgileVpn (deferred) Unloaded modules: fffff806`52730000 fffff806`52743000 MSKSSRV.sys fffff806`27890000 fffff806`278cb000 klids.sys fffff806`1fda0000 fffff806`1fdb0000 dump_storpor. fffff806`1fa00000 fffff806`1fa30000 dump_stornvm. fffff806`1fa50000 fffff806`1fa6e000 dump_dumpfve. fffff806`5e6a0000 fffff806`5e6ac000 WdmCompanion. fffff806`27910000 fffff806`2792c000 dam.sys fffff806`277f0000 fffff806`298b4000 vgk.sys fffff806`17080000 fffff806`1708f000 klelam.sys fffff806`18120000 fffff806`18131000 hwpolicy.sys # Child-SP RetAddr : Args to Child : Call Site. 00 fffff387`5b81ad18 fffff806`1569d1f7 : 00000000`0000001e ffffffff`c0000005 fffff806`1540b975 00000000`00000000 : nt!KeBugCheckEx 01 fffff387`5b81ad20 fffff806`156124ec : 00000000`00001000 fffff387`5b81b5c0 ffff8000`00000000 00000000`00000000 : nt!KiDispatchException+0x13fb37 02 fffff387`5b81b3e0 fffff806`1560dd52 : 00000000`00000000 00000000`00000000 fffff806`15f23ec8 00000000`00000000 : nt!KiExceptionDispatch+0x12c 03 fffff387`5b81b5c0 fffff806`1540b975 : fffff806`1540b1b8 00000000`00000000 fffff806`1540b8ae 00000000`00004e91 : nt!KiPageFault+0x452 (TrapFrame @ fffff387`5b81b5c0) 04 fffff387`5b81b758 000001c0`00000084 : fffff387`5b81b879 00000000`00004e91 00000000`00004e91 00000000`00000001 : nt!MiStoreCheckCandidatePage+0x69 05 fffff387`5b81b7b8 fffff387`5b81b879 : 00000000`00004e91 00000000`00004e91 00000000`00000001 00000000`0000ac00 : 0x000001c0`00000084 06 fffff387`5b81b7c0 00000000`00004e91 : 00000000`00004e91 00000000`00000001 00000000`0000ac00 ffffb90f`20004e91 : 0xfffff387`5b81b879 07 fffff387`5b81b7c8 00000000`00004e91 : 00000000`00000001 00000000`0000ac00 ffffb90f`20004e91 00000000`00000001 : 0x4e91. 08 fffff387`5b81b7d0 00000000`00000001 : 00000000`0000ac00 ffffb90f`20004e91 00000000`00000001 00000068`00000000 : 0x4e91. 09 fffff387`5b81b7d8 00000000`0000ac00 : ffffb90f`20004e91 00000000`00000001 00000068`00000000 00000100`00000000 : 0x1. 0a fffff387`5b81b7e0 ffffb90f`20004e91 : 00000000`00000001 00000068`00000000 00000100`00000000 ffffb90f`6c495770 : 0xac00. 0b fffff387`5b81b7e8 00000000`00000001 : 00000068`00000000 00000100`00000000 ffffb90f`6c495770 00000000`00000000 : 0xffffb90f`20004e91 0c fffff387`5b81b7f0 00000068`00000000 : 00000100`00000000 ffffb90f`6c495770 00000000`00000000 00000000`00000011 : 0x1. 0d fffff387`5b81b7f8 00000100`00000000 : ffffb90f`6c495770 00000000`00000000 00000000`00000011 00000000`0000ac00 : 0x00000068`00000000 0e fffff387`5b81b800 ffffb90f`6c495770 : 00000000`00000000 00000000`00000011 00000000`0000ac00 ffffb90f`7bec9450 : 0x00000100`00000000 0f fffff387`5b81b808 00000000`00000000 : 00000000`00000011 00000000`0000ac00 ffffb90f`7bec9450 20000000`00004e91 : 0xffffb90f`6c495770 Machine ID Information [From Smbios 3.2, DMIVersion 0, Size=2546] BiosMajorRelease = 1 BiosMinorRelease = 21. FirmwareMajorRelease = 1 FirmwareMinorRelease = 21. BiosVendor = LENOVO. BiosVersion = FCCN21WW. BiosReleaseDate = 09/20/2023 SystemManufacturer = LENOVO. SystemProductName = 82EY. SystemFamily = IdeaPad Gaming 3 15ARH05. SystemVersion = IdeaPad Gaming 3 15ARH05. SystemSKU = LENOVO_MT_82EY_BU_idea_FM_IdeaPad Gaming 3 15ARH05. BaseBoardManufacturer = LENOVO. BaseBoardProduct = LNVNB161216. BaseBoardVersion = NO DPK. [SMBIOS Data Tables v3.2] [DMI Version - 0] [2.0 Calling Convention - No] [Table Size - 2546 bytes] [BIOS Information (Type 0) - Length 26 - Handle 0000h] Vendor LENOVO. BIOS Version FCCN21WW. BIOS Starting Address Segment e000. BIOS Release Date 09/20/2023 BIOS ROM Size f20000. BIOS Characteristics. 07: - PCI Supported. 11: - Upgradeable FLASH BIOS. 12: - BIOS Shadowing Supported. 15: - CD-Boot Supported. 16: - Selectable Boot Supported. 19: - EDD Supported. 20: - NEC 9800 J-Floppy Supported. 21: - Toshiba J-Floppy Supported. 22: - 360KB Floppy Supported. 23: - 1.2MB Floppy Supported. 24: - 720KB Floppy Supported. 25: - 2.88MB Floppy Supported. 27: - Keyboard Services Supported. 30: - CGA/Mono Services Supported. 49: - System Vendor Reserved. 51: - System Vendor Reserved. 52: - System Vendor Reserved. BIOS Characteristic Extensions. 00: - ACPI Supported. 01: - USB Legacy Supported. 08: - BIOS Boot Specification Supported. 10: - Enable Targeted Content Distribution. 11: - UEFI Specification Supported. BIOS Major Revision 1 BIOS Minor Revision 21. EC Firmware Major Revision 1 EC Firmware Minor Revision 21. Extended BIOS ROM Size 0 MB. [System Information (Type 1) - Length 27 - Handle 0001h] Manufacturer LENOVO. Product Name 82EY. Version IdeaPad Gaming 3 15ARH05. Serial Number PF2N5SKE. UUID 00000000-0000-0000-0000-000000000000 Wakeup Type Power Switch. SKUNumber LENOVO_MT_82EY_BU_idea_FM_IdeaPad Gaming 3 15ARH05. Family IdeaPad Gaming 3 15ARH05. [BaseBoard Information (Type 2) - Length 16 - Handle 0002h] Manufacturer LENOVO. Product LNVNB161216. Version NO DPK. Serial Number PF2N5SKE. Asset Tag Feature Flags 09h. 00: - Motherboard. 03: - Replaceable. Location Base Board Chassis Location. Chassis Handle 0003h. Board Type 0ah - Processor/Memory Module. Number of Child Handles 0 [System Enclosure (Type 3) - Length 23 - Handle 0003h] Manufacturer LENOVO. Chassis Type Notebook. Version IdeaPad Gaming 3 15ARH05. Serial Number Asset Tag Number Bootup State Safe. Power Supply State Safe. Thermal State Safe. Security Status None. OEM Defined 0 Height 0U. Number of Power Cords 1 Number of Contained Elements 0 Contained Element Size 0 SKU Number Chassis SKU. [Processor Information (Type 4) - Length 48 - Handle 0004h] Socket Designation FP6. Processor Type Central Processor. Processor Family 6bh - AMD Zen Processor Family. Processor Manufacturer Advanced Micro Devices, Inc. Processor ID 10f8600fffb8b17. Processor Version AMD Ryzen 7 4800H with Radeon Graphics Processor Voltage 8ch - 1.2V External Clock 100MHz. Max Speed 4300MHz. Current Speed 2900MHz. Status Enabled Populated. Processor Upgrade None. L1 Cache Handle 0005h. L2 Cache Handle 0006h. L3 Cache Handle 0007h. Serial Number Asset Tag Number Part Number Unknown. Core Count 8 Core Enabled 8 Thread Count 16. Processor Characteristics fc. Enabled Characteristics: 0x 2: 64-bit Capable. 0x 3: Multi-Core 0x 4: Hardware Thread. 0x 5: Execute Protection. 0x 6: Enhanced Virtualization. 0x 7: Power/Performance Control. Processor Family 2 006bh - AMD Zen Processor Family. Core Count 2 8 Core Enabled 2 8 Thread Count 2 16. [Cache Information (Type 7) - Length 27 - Handle 0005h] Socket Designation L1 - Cache. Cache Configuration 0180h - WBEnabled Int NonSocketed L1. Maximum Cache Size 0200h - 512K. Installed Size 0200h - 512K. Supported SRAM Type 0010h - Pipeline-Burst Current SRAM Type 0010h - Pipeline-Burst Cache Speed 1ns. Error Correction Type Specification Reserved. System Cache Type Unified. Associativity 8-way Set-Associative Maximum Cache Size 2 200 - 00000512l Kb. Installed Cache Size 2 200 - 00000512l Kb. [Cache Information (Type 7) - Length 27 - Handle 0006h] Socket Designation L2 - Cache. Cache Configuration 0181h - WBEnabled Int NonSocketed L2. Maximum Cache Size 1000h - 4096K. Installed Size 1000h - 4096K. Supported SRAM Type 0010h - Pipeline-Burst Current SRAM Type 0010h - Pipeline-Burst Cache Speed 1ns. Error Correction Type Specification Reserved. System Cache Type Unified. Associativity 8-way Set-Associative Maximum Cache Size 2 1000 - 00004096l Kb. Installed Cache Size 2 1000 - 00004096l Kb. [Cache Information (Type 7) - Length 27 - Handle 0007h] Socket Designation L3 - Cache. Cache Configuration 0182h - WBEnabled Int NonSocketed L3. Maximum Cache Size 2000h - 8192K. Installed Size 2000h - 8192K. Supported SRAM Type 0010h - Pipeline-Burst Current SRAM Type 0010h - Pipeline-Burst Cache Speed 1ns. Error Correction Type Specification Reserved. System Cache Type Unified. Associativity 16-way Set-Associative Maximum Cache Size 2 2000 - 00008192l Kb. Installed Cache Size 2 2000 - 00008192l Kb. [OEM Strings (Type 11) - Length 5 - Handle 001fh] Number of Strings 1 1 Modern Preload. [System Configuration Options (Type 12) - Length 5 - Handle 0020h] [Physical Memory Array (Type 16) - Length 23 - Handle 0022h] Location 03h - SystemBoard/Motherboard Use 03h - System Memory. Memory Error Correction 03h - None. Maximum Capacity 33554432KB. Memory Error Inf Handle 0025h. Number of Memory Devices 2 [Memory Device (Type 17) - Length 84 - Handle 0023h] Memory Error Info Handle 0026h. Total Width 64 bits. Data Width 64 bits
Özür dilenecek bir nokta değil. Sorun değil yani.İlk öncelikle şunu söyleyeyim metinde önceden mavi ekran alıp almadığınız hakkında bilgi vermemişsiniz demiştiniz onun için özür diliyorum belirtmemişim.
Linux deneyimin sorunsuzdu galiba, anladığım kadarıyla. Hangi donanım parçalarını kullandığın da önemli bu noktada.Linux kullanıyordum Windows 10'a geçtim ve yaklaşık bir hafta içinde 5-6 kez mavi ekran aldım.
Bellek yönetimi RAM'i değil, dahasını da kapsayan bir mekanizma. Yine de Laptop bu. Yani geçtiği her test, normal kullanımdaki reaksiyonlarına göre değerlendirilir.Ayrıca bellek yönetim sorunlarından bahsetmişsiniz ancak hem Memtest'ten hem de Windows'un kendi bellek testinden geçti. Kaspersky'ı kaldırabilirim.
Dosyada erişim engeli var, yani link sadece sana açık. Onu kaldırmadan önce GIF üzerindeki dosyayı da eklemeni isterim.(Not: RAR'ın içinde 3 minidump dosyası var. Toplamda 5 tane mavi ekran hatası aldım bir tanesi açılmıyor diğerini ise konu başında vermiştim geriye kalan 3 minidump dosyası burada)
Performans olarak hayır. Ayrıca sürücüsü 4 yıllık, yani Windows'un kurduğu sürücü. Lakin cihazda MUX ya da dahili grafik kartını doğrudan kapatacak bir BIOS ayarı yoksa görüntü bozulamaları da yaşayabilirsin.Tabii kapatabilirim ancak oyun falan da oynuyorum bir sıkıntı çıkarmaz mı performans açısından?
Bellek yönetimi RAM'i değil, dahasını da kapsayan bir mekanizma. Yine de laptop bu. Yani geçtiği her test, normal kullanımdaki reaksiyonlarına göre değerlendirilir.
Performans olarak hayır. Ayrıca sürücüsü 4 yıllık, yani Windows'un kurduğu sürücü. Lakin cihazda MUX yoksa görüntü bozulamaları da yaşayacaksın.
Ayrıca Linux kullandığım zamandan bu yana hiçbir donanım parçası falan değiştirmedim.
EXCEPTION_RECORD: ffff8b89e859b768 -- (.exr 0xffff8b89e859b768)
ExceptionAddress: fffff80696aad198 (cldflt!HsmiFltPreECPCREATE+0x0000000000000128)
ExceptionCode: c0000005 (Access violation)
ExceptionFlags: 00000000
NumberParameters: 2
Parameter[0]: 0000000000000000
Parameter[1]: 0000000000000018
Attempt to read from address 0000000000000018
.trap 0xffff8804fdca7120
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=ffff8c87f9be1a10 rbx=0000000000000000 rcx=ffff8c87f9be1a08
rdx=0000000000000001 rsi=0000000000000000 rdi=0000000000000000
rip=fffff801407e7e8f rsp=ffff8804fdca72b8 rbp=0000000000000008
r8=0000000000000000 r9=0000000000000000 r10=fffff801436ea030
r11=ffffa87841c00000 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei pl nz na pe nc
FLTMGR!FltpAllocateIrpCtrlInternal+0x18f:
fffff801`407e7e8f 4183ff01 cmp r15d,1
Resetting default scope
TRAP_FRAME: ffffb80d0c27d300 -- (.trap 0xffffb80d0c27d300)
rax=0000000000000000 rbx=0000000000000000 rcx=ffffb80d0c27d4c8
rdx=0000000000000000 rsi=0000000000000000 rdi=0000000000000000
rip=fffff805780c7075 rsp=ffffb80d0c27d498 rbp=ffffb80d0c27d579
r8=0000000000000000 r9=0000000000004016 r10=fffff805780c7060
r11=ffffb80d0c27d388 r12=0000000000000000 r13=0000000000000000
iopl=0 nv up ei pl zr na po nc
ndis!NdisAdjustNetBufferCurrentMdl+0x15:
fffff805`780c7075 48894108 mov qword ptr [rcx+8],rax ds:ffffb80d`0c27d4d0=0000000000000000
0xffff8b89e859be28 : 0xfffff80696b317a2 : bindflt!BfPreReleaseForSectionSynchronization+0x42
0xffff8b89e859bf08 : 0xfffff8064d9db932 : Ntfs!NtfsMarkUnusedContextPreTrimProcessing+0x42
0xffff8b89e859bf48 : 0xfffff8064b8e8547 : nt!IopParseFile+0xc7
0xffff8b89e859bfc0 : 0xfffff8064b8e8480 : nt!IopParseFile
0xffff8b89e859c018 : 0xfffff8064b43c54d : nt!FsRtlLookupPerStreamContextInternal+0x8d
0xffff8b89e859c038 : 0xffffdf0dbff60560 : !du ""PROGRAM FILES\NVIDIA CORPORATION\NVIDIA GEFORCE EXPERIENCE\CEF_EXTENSIONS.PAK""
0xffff8b89e859c0b0 : 0xffffdf0dbb7ec674 : !du ""PROGRAM FILES\NVIDIA CORPORATION\NVIDIA GEFORCE EXPERIENCE\CEF_EXTENSIONS.PAK""
0xffff8b89e859c188 : 0xfffff8064b83be2a : nt!ObOpenObjectByNameEx+0x1fa
0xffff8b89e859c230 : 0xffffdf0dbff60560 : !du ""PROGRAM FILES\NVIDIA CORPORATION\NVIDIA GEFORCE EXPERIENCE\CEF_EXTENSIONS.PAK""
*** WARNING: Unable to verify timestamp for rtwlane.sys <<<<<
14: kd> k
00 ffffb80d`0bc60630 0000ffff`ffffffff rtwlane+0x19479b
01 ffffb80d`0bc60638 ffff4146`a7011554 0x0000ffff`ffffffff
02 ffffb80d`0bc60640 ffffffff`ffffffff 0xffff4146`a7011554
03 ffffb80d`0bc60648 ffff4146`a7011564 0xffffffff`ffffffff
04 ffffb80d`0bc60650 ffffe70c`bb400000 0xffff4146`a7011564
05 ffffb80d`0bc60658 fffff805`a6d73879 0xffffe70c`bb400000
06 ffffb80d`0bc60660 ffffe70c`bae19680 rtwlane+0x193879
07 ffffb80d`0bc60668 00000000`00000000 0xffffe70c`bae19680
Demek istediğim o değildi. Linux kullanırken herhangi bir sorun yaşıyor muydun demeye çalışıyorum.
Tüm dosyalar direkt dosya sistemine ya da dosya sistemiyle ilişkili birimlere yönlendiriyor:
Kod:EXCEPTION_RECORD: ffff8b89e859b768 -- (.exr 0xffff8b89e859b768) ExceptionAddress: fffff80696aad198 (cldflt!HsmiFltPreECPCREATE+0x0000000000000128) ExceptionCode: c0000005 (Access violation) ExceptionFlags: 00000000. NumberParameters: 2 Parameter[0]: 0000000000000000. Parameter[1]: 0000000000000018. Attempt to read from address 0000000000000018.
Örneğin, OneDrive bulut sistemine ait bir işlev sırasında sistem geçersiz bir adresi referans göstererek çöküyor. Memory leak problemi aslına bakarsan. Bir sayfa hatası bile yok ne yazık ki.
Not: Arka planında çok fazla Kaspersky hatası olduğunu tespitledim. Kaldırmanı da söylemiştim zati.
Kod:.trap 0xffff8804fdca7120. NOTE: The trap frame does not contain all registers. Some register values may be zeroed or incorrect. rax=ffff8c87f9be1a10 rbx=0000000000000000 rcx=ffff8c87f9be1a08 rdx=0000000000000001 rsi=0000000000000000 rdi=0000000000000000 rip=fffff801407e7e8f rsp=ffff8804fdca72b8 rbp=0000000000000008 r8=0000000000000000 r9=0000000000000000 r10=fffff801436ea030 r11=ffffa87841c00000 r12=0000000000000000 r13=0000000000000000 r14=0000000000000000 r15=0000000000000000 iopl=0 nv up ei pl nz na pe nc. FLTMGR!FltpAllocateIrpCtrlInternal+0x18f: fffff801`407e7e8f 4183ff01 cmp r15d,1 Resetting default scope.
Dosya filtreleme sürücüsüne ait G/Ç işlemlerini tanımlamak ve yönetmek için kullanılan ırp'ler için kontrol yapılarının tahsisini gerçekleştiren fonskiyon sırasında null reference var ve sistem çöküyor. Sebep dosya filtreleme sürücüsü. Aynı şekil de bu da bir Memory leak problemi.
Windows'a ait işlemlerin ve sürücülerin sorumlu tutulması işi çok nadir olur.
Kod:TRAP_FRAME: ffffb80d0c27d300 -- (.trap 0xffffb80d0c27d300) NOTE: The trap frame does not contain all registers. Some register values may be zeroed or incorrect. rax=0000000000000000 rbx=0000000000000000 rcx=ffffb80d0c27d4c8 rdx=0000000000000000 rsi=0000000000000000 rdi=0000000000000000 rip=fffff805780c7075 rsp=ffffb80d0c27d498 rbp=ffffb80d0c27d579 r8=0000000000000000 r9=0000000000004016 r10=fffff805780c7060 r11=ffffb80d0c27d388 r12=0000000000000000 r13=0000000000000000 r14=0000000000000000 r15=0000000000000000 iopl=0 nv up ei pl zr na po nc. ndis!NdisAdjustNetBufferCurrentMdl+0x15: fffff805`780c7075 48894108 mov qword ptr [rcx+8],rax ds:ffffb80d`0c27d4d0=0000000000000000 Resetting default scope.
Ağ sürücülerine ait bir işlem sırasında sistem paging işlemini tamamlayamıyor çünkü yüksek kesme istek düzeyinde bunu tamamlayacak bir kodlaması yok. Bu da Pagefile'da olan bir işlev dolayısıyla geçersiz referanstan dolayı sistemin çökmesine yol açıyor.
Luk at dis:
Kod:0xffff8b89e859be28 : 0xfffff80696b317a2 : bindflt!BfPreReleaseForSectionSynchronization+0x42 0xffff8b89e859bf08 : 0xfffff8064d9db932 : Ntfs!NtfsMarkUnusedContextPreTrimProcessing+0x42 0xffff8b89e859bf48 : 0xfffff8064b8e8547 : nt!IopParseFile+0xc7 0xffff8b89e859bfc0 : 0xfffff8064b8e8480 : nt!IopParseFile 0xffff8b89e859c018 : 0xfffff8064b43c54d : nt!FsRtlLookupPerStreamContextInternal+0x8d 0xffff8b89e859c038 : 0xffffdf0dbff60560 : !du ""PROGRAM FILES\NVIDIA CORPORATION\NVIDIA GEFORCE EXPERIENCE\CEF_EXTENSIONS.PAK"" 0xffff8b89e859c0b0 : 0xffffdf0dbb7ec674 : !du ""PROGRAM FILES\NVIDIA CORPORATION\NVIDIA GEFORCE EXPERIENCE\CEF_EXTENSIONS.PAK"" 0xffff8b89e859c188 : 0xfffff8064b83be2a : nt!ObOpenObjectByNameEx+0x1fa 0xffff8b89e859c230 : 0xffffdf0dbff60560 : !du ""PROGRAM FILES\NVIDIA CORPORATION\NVIDIA GEFORCE EXPERIENCE\CEF_EXTENSIONS.PAK""
Senden istediğim ek olarak GeForce Experience adlı arkadaşı da kaldırman. Cihazın sürücülerini manuel olarak kurabilirsin. Wi-Fi sürücünü de güncellemelisin.
Kod:*** WARNING: Unable to verify timestamp for rtwlane.sys <<<<< 14: kd> k # Child-SP RetAddr Call Site. 00 ffffb80d`0bc60630 0000ffff`ffffffff rtwlane+0x19479b 01 ffffb80d`0bc60638 ffff4146`a7011554 0x0000ffff`ffffffff 02 ffffb80d`0bc60640 ffffffff`ffffffff 0xffff4146`a7011554 03 ffffb80d`0bc60648 ffff4146`a7011564 0xffffffff`ffffffff 04 ffffb80d`0bc60650 ffffe70c`bb400000 0xffff4146`a7011564 05 ffffb80d`0bc60658 fffff805`a6d73879 0xffffe70c`bb400000 06 ffffb80d`0bc60660 ffffe70c`bae19680 rtwlane+0x193879 07 ffffb80d`0bc60668 00000000`00000000 0xffffe70c`bae19680
14: kd> k
00 ffffc280`09b3f158 fffff802`7eafbc2e nt!KeBugCheckEx
01 ffffc280`09b3f160 fffff802`7ea08692 nt!HvlpVtlCallExceptionHandler+0x22
02 ffffc280`09b3f1a0 fffff802`7e95f917 nt!RtlpExecuteHandlerForException+0x12
03 ffffc280`09b3f1d0 fffff802`7e95d846 nt!RtlDispatchException+0x297
04 ffffc280`09b3f8f0 fffff802`7e9fecb2 nt!KiDispatchException+0x186
05 ffffc280`09b3ffb0 fffff802`7e9fec80 nt!KxExceptionDispatchOnExceptionStack+0x12
06 ffffe40c`826df288 fffff802`7ea124e5 nt!KiExceptionDispatchOnExceptionStackContinue
07 ffffe40c`826df290 fffff802`7ea0d8ef nt!KiExceptionDispatch+0x125
08 ffffe40c`826df470 fffff802`7e84dcf0 nt!KiGeneralProtectionFault+0x32f
09 ffffe40c`826df600 00000000`ffffffff nt!KiCheckForTimerExpiration
0a ffffe40c`826df608 ffffffff`ffffffff amdppm!C2Idle+0x87
0b ffffe40c`826df610 00000000`00000002 nt!PpmIdleUpdateConcurrency+0x73
Anlattıklarından zaten sorunun 2 3 program silince kaybolmayacağını anlamıştım. Benim istediğim, görünürde dosyalarda olan arkadaşlardan kurtulup artık dosyaların sisteme ait gerçek problemleri göstermesini sağlamaya çalışmaktı, son dosyan bir tık diğer dosyalara göre kafaya daha yatkın.
Kod:14: kd> k # Child-SP RetAddr Call Site. 00 ffffc280`09b3f158 fffff802`7eafbc2e nt!KeBugCheckEx 01 ffffc280`09b3f160 fffff802`7ea08692 nt!HvlpVtlCallExceptionHandler+0x22 02 ffffc280`09b3f1a0 fffff802`7e95f917 nt!RtlpExecuteHandlerForException+0x12 03 ffffc280`09b3f1d0 fffff802`7e95d846 nt!RtlDispatchException+0x297 04 ffffc280`09b3f8f0 fffff802`7e9fecb2 nt!KiDispatchException+0x186 05 ffffc280`09b3ffb0 fffff802`7e9fec80 nt!KxExceptionDispatchOnExceptionStack+0x12 06 ffffe40c`826df288 fffff802`7ea124e5 nt!KiExceptionDispatchOnExceptionStackContinue 07 ffffe40c`826df290 fffff802`7ea0d8ef nt!KiExceptionDispatch+0x125 08 ffffe40c`826df470 fffff802`7e84dcf0 nt!KiGeneralProtectionFault+0x32f 09 ffffe40c`826df600 00000000`ffffffff nt!KiCheckForTimerExpiration 0a ffffe40c`826df608 ffffffff`ffffffff amdppm!C2Idle+0x87 0b ffffe40c`826df610 00000000`00000002 nt!PpmIdleUpdateConcurrency+0x73
Sistem, işlemci güç planlarında değişiklik yapılırken çöküyor. Temelinde işlemcinin boşta olduğuna dair bir planı vurgulaması sonrası çöküyor diyebiliriz. Bu değişiklik sonrası da zaten mavi ekrana kadar gidiyor bu sıralama, en sonda hypervisior çağrısında çöküyor.
Bu vesileyle, gelişmiş güç seçeneklerinden (daha önce herhangi bir ayarı değiştirdiysen normale alabilirsin)min - Max değerlerini 99-99 olarak ayarlamanı isteyeceğim. Pil ve şarj modları için de yapabilirsin lakin pil modunda çok çabuk enerji tüketecektir. Bu şekilde sistemini kontrol etmeni ve durum güncellemesi yapmanı isteyeceğim.
We use cookies and similar technologies for the following purposes:
Do you accept cookies and these technologies?
