Çözüldü Mavi ekran hatasına ne sebep olmuş olabilir?
Tahir.bin
1 Haziran 2024
Kayseri
İlk defa bilgisayarımda mavi ekran hatası aldım. Sebebi CS 2 güncellemesi olabilir mi? Onu bilmiyorum ama bir de Windows Update baktım bugün güncelleme olmuş. Sizde oldu mu mavi ekran sorunu?
Sebebi Intel GPU sürücüsü: igdkmdnd64.sys
Daha güncel sürüm varsa yüklemenizi öneririm.
Kod:
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED (7e)
This is a very common BugCheck.  Usually the exception address pinpoints
the driver/function that caused the problem.  Always note this address
as well as the link date of the driver/image that contains this address.
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff8023b7046f1, The address that the exception occurred at
Arg3: ffff8109a8c76568, Exception Record Address
Arg4: ffff8109a8c75da0, Context Record Address
Debugging Details:
KEY_VALUES_STRING: 1
    Key  : AV.Fault
    Value: Read
    Key  : Analysis.CPU.mSec
    Value: 875
    Key  : Analysis.Elapsed.mSec
    Value: 2850
    Key  : Analysis.IO.Other.Mb
    Value: 0
    Key  : Analysis.IO.Read.Mb
    Value: 1
    Key  : Analysis.IO.Write.Mb
    Value: 0
    Key  : Analysis.Init.CPU.mSec
    Value: 234
    Value: 1115
    Value: 91
    Value: 10.0.27725.1000
    Value: 10.2408.27.01 amd64fre
    Key  : Analysis.Version.Ext
    Value: 1.2408.27.1
    Value: 0x1000007e
    Value: 0x1000007e
    Key  : Failure.Bucket
    Value: AV_igdkmdnd64!unknown_function
    Key  : Failure.Hash
    Value: {f72986a3-e8f9-3600-9d7c-dd8a40f557df}
    Key  : WER.OS.Branch
    Value: vb_release
    Key  : WER.OS.Version
    Value: 10.0.19041.1
BUGCHECK_CODE:  7e
BUGCHECK_P1: ffffffffc0000005
BUGCHECK_P2: fffff8023b7046f1
BUGCHECK_P3: ffff8109a8c76568
BUGCHECK_P4: ffff8109a8c75da0
FILE_IN_CAB:  111524-8312-01.dmp
FAULTING_THREAD:  ffff95089bdb1280
EXCEPTION_RECORD:  ffff8109a8c76568 -- (.exr 0xffff8109a8c76568)
ExceptionAddress: fffff8023b7046f1 (igdkmdnd64+0x00000000004746f1)
   ExceptionCode: c0000005 (Access violation)
  ExceptionFlags: 00000000
NumberParameters: 2
   Parameter[0]: 0000000000000000
   Parameter[1]: 0000000000000514
Attempt to read from address 0000000000000514
CONTEXT:  ffff8109a8c75da0 -- (.cxr 0xffff8109a8c75da0)
rax=ffff64bb31458c49 rbx=ffff8109a8c76b78 rcx=ffff8109a8c76b78
rdx=ffff9508a6de4000 rsi=ffff95089c27c000 rdi=ffff9508a6de4000
rip=fffff8023b7046f1 rsp=ffff8109a8c767a0 rbp=ffff8109a8c76b50
 r8=0000000000000004  r9=0000000000000014 r10=0000000000000004
r11=ffff8109a8c768d8 r12=ffff9508a1cfdde0 r13=ffff9508a341d010
r14=ffff9508a371c010 r15=ffff95089cdf5000
iopl=0         nv up ei pl zr na po nc
cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00050246
igdkmdnd64+0x4746f1:
fffff802`3b7046f1 498b8810050000  mov     rcx,qword ptr [r8+510h] ds:002b:00000000`00000514=????????????????
Resetting default scope
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  System
READ_ADDRESS: fffff802126fb390: Unable to get MiVisibleState
Unable to get NonPagedPoolStart
Unable to get NonPagedPoolEnd
Unable to get PagedPoolStart
Unable to get PagedPoolEnd
unable to get nt!MmSpecialPagesInUse
 0000000000000514
ERROR_CODE: (NTSTATUS) 0xc0000005 - 0x%p adresindeki y nerge 0x%p adresindeki belle e ba vurdu. Bellek  u olamaz %s.
EXCEPTION_CODE_STR:  c0000005
EXCEPTION_PARAMETER1:  0000000000000000
EXCEPTION_PARAMETER2:  0000000000000514
EXCEPTION_STR:  0xc0000005
STACK_TEXT:
ffff8109`a8c767a0 00000004`f7e2984a     : 00000000`00000003 ffff8109`a8c76b78 ffff9508`9bb1b010 00000000`00000001 : igdkmdnd64+0x4746f1
ffff8109`a8c767a8 00000000`00000003     : ffff8109`a8c76b78 ffff9508`9bb1b010 00000000`00000001 00000000`00000001 : 0x00000004`f7e2984a
ffff8109`a8c767b0 ffff8109`a8c76b78     : ffff9508`9bb1b010 00000000`00000001 00000000`00000001 ffff9508`a341d010 : 0x3
ffff8109`a8c767b8 ffff9508`9bb1b010     : 00000000`00000001 00000000`00000001 ffff9508`a341d010 00000000`00000000 : 0xffff8109`a8c76b78
ffff8109`a8c767c0 00000000`00000001     : 00000000`00000001 ffff9508`a341d010 00000000`00000000 00000000`00000002 : 0xffff9508`9bb1b010
ffff8109`a8c767c8 00000000`00000001     : ffff9508`a341d010 00000000`00000000 00000000`00000002 00000000`40000100 : 0x1
ffff8109`a8c767d0 ffff9508`a341d010     : 00000000`00000000 00000000`00000002 00000000`40000100 00000000`00000001 : 0x1
ffff8109`a8c767d8 00000000`00000000     : 00000000`00000002 00000000`40000100 00000000`00000001 fffff802`3b521965 : 0xffff9508`a341d010
SYMBOL_NAME:  igdkmdnd64+4746f1
MODULE_NAME: igdkmdnd64
IMAGE_NAME:  igdkmdnd64.sys
STACK_COMMAND:  .cxr 0xffff8109a8c75da0 ; kb
BUCKET_ID_FUNC_OFFSET:  4746f1
FAILURE_BUCKET_ID:  AV_igdkmdnd64!unknown_function
OS_VERSION:  10.0.19041.1
BUILDLAB_STR:  vb_release
OSPLATFORM_TYPE:  x64
OSNAME:  Windows 10
FAILURE_ID_HASH:  {f72986a3-e8f9-3600-9d7c-dd8a40f557df}
Followup:     MachineOwner
    PnpActivityId      : {00000000-0000-0000-0000-000000000000}
    PnpActivityTime    : 133761362343766868
    PnpEventInformation: 3
    PnpEventInProgress : 0
    PnpProblemCode     : 24
    PnpVetoType        : 0
    DeviceId           : SW\{96E080C7-143C-11D1-B40F-00A0C9223196}\{3C0D501A-140B-11D1-B40F-00A0C9223196}
    VetoString         :
[SMBIOS Data Tables v3.6]
[DMI Version - 0]
[2.0 Calling Convention - No]
[Table Size - 4696 bytes]
  Vendor                        American Megatrends International, LLC.
  BIOS Version                  1009
  BIOS Release Date             09/20/2024
  BIOS ROM Size                 1000000
  BIOS Characteristics
       07: - PCI Supported
       11: - Upgradeable FLASH BIOS
       15: - CD-Boot Supported
       17: - BIOS ROM Socketed
       19: - EDD Supported
       22: - 360KB Floppy Supported
       23: - 1.2MB Floppy Supported
       24: - 720KB Floppy Supported
       25: - 2.88MB Floppy Supported
       27: - Keyboard Services Supported
       32: - BIOS Vendor Reserved
       00: - ACPI Supported
       01: - USB Legacy Supported
  BIOS Major Revision           5
  BIOS Minor Revision           27
  EC Firmware Major Revision    255
  EC Firmware Minor Revision    255
  Extended BIOS ROM Size        16 MB
  Manufacturer                  Colorful Technology And Development Co.,LTD
  Product Name                  H610M-E M.2
  Version                       Default string
  Serial Number                 Default string
  SKUNumber                     Default string
  Family                        Default string
  Product                       H610M-E M.2
  Version                       V20
  Asset Tag
       00: - Motherboard
       03: - Replaceable
  Location                      Default string
  Chassis Type                  Desktop
  Serial Number
  Asset Tag Number
  Contained Element Size        3
[Onboard Devices Information (Type 10) - Length 6 - Handle 0021h]
Note: The On Board Device Information (Type 10) struct is obsolete as of SMBIOs spec v2.6  Number of Devices             1
  01: Type                      Video [enabled]
  01: Description                  To Be Filled By O.E.M.
[OEM Strings (Type 11) - Length 5 - Handle 0022h]
  Number of Strings             1
   1                            Default string
[System Configuration Options (Type 12) - Length 5 - Handle 0023h]
[ (Type 256) - Length 9 - Handle 003ah]
[Physical Memory Array (Type 16) - Length 23 - Handle 003bh]
  Maximum Capacity              67108864KB
  Memory Error Inf Handle       [Not Provided]
  Number of Memory Devices      2
[Memory Device (Type 17) - Length 92 - Handle 003ch]
  Memory Error Info Handle      [Not Provided]
  Size                          8192MB
  Form Factor                   09h - DIMM
  Device Locator                Controller0-ChannelA-DIMM0
  Bank Locator                  BANK 0
  Memory Type                   1ah - DDR4
  Type Detail                   0080h - Synchronous
  Speed                         3200MHz
  Manufacturer                  Apacer Technology
  Serial Number
  Asset Tag Number
  Part Number                   GD2.1827CS.007
  Attributes                    1
  Configured Memory Speed       3200
  Minimum Voltage               1200
  Maximum Voltage               1350
  Configured Voltage            1350
  Memory Technology             3
  Memory Operating Mode Capability     8
  Firmware Version              0
  Module Manufacturer Id        31233
  Module Product Id             0
  Memory Subsystem Controller Manufacturer Id  0
  Memory Subsystem Controller Product Id       0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
  Extended Configured Memory Speed     0
[Memory Device (Type 17) - Length 92 - Handle 003dh]
  Size                          8192MB
  Device Locator                Controller1-ChannelA-DIMM0
  Bank Locator                  BANK 0
  Speed                         3200MHz
  Serial Number
  Asset Tag Number
  Attributes                    1
  Memory Technology             3
  Firmware Version              0
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
[Memory Array Mapped Address (Type 19) - Length 31 - Handle 003eh]
  Ending Address                00ffffffh
  Memory Array Handle           003bh
[ (Type 256) - Length 31 - Handle 003fh]
[ (Type 256) - Length 26 - Handle 0040h]
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 0041h]
  Ending Address                007fffffh
  Memory Device Handle          003ch
  Mem Array Mapped Adr Handle   003eh
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 0042h]
  Starting Address              00800000h
  Memory Device Handle          003dh
[ (Type 256) - Length 12 - Handle 0043h]
[ (Type 256) - Length 26 - Handle 0044h]
[ (Type 256) - Length 26 - Handle 0045h]
[ (Type 256) - Length 47 - Handle 0046h]
[ (Type 256) - Length 82 - Handle 0047h]
[Cache Information (Type 7) - Length 27 - Handle 0048h]
  Socket Designation            L1 Cache
  Maximum Cache Size            00c0h - 192K
  Installed Size                00c0h - 192K
  Supported SRAM Type           0020h - Synchronous
  Current SRAM Type             0020h - Synchronous
  Cache Speed                   0ns
  Error Correction Type         ParitySingle-Bit ECC
  System Cache Type             Data
  Associativity                 12-way Set-Associative
  Maximum Cache Size 2          c0 - 00000192l Kb
  Installed Cache Size 2        c0 - 00000192l Kb
[Cache Information (Type 7) - Length 27 - Handle 0049h]
  Maximum Cache Size            0080h - 128K
  Installed Size                0080h - 128K
  Cache Speed                   0ns
  System Cache Type             Instruction
  Maximum Cache Size 2          80 - 00000128l Kb
  Installed Cache Size 2        80 - 00000128l Kb
[Cache Information (Type 7) - Length 27 - Handle 004ah]
  Socket Designation            L2 Cache
  Maximum Cache Size            1400h - 5120K
  Installed Size                1400h - 5120K
  Cache Speed                   0ns
  Error Correction Type         Multi-Bit ECC
  Associativity                 Other
  Maximum Cache Size 2          1400 - 00005120l Kb
  Installed Cache Size 2        1400 - 00005120l Kb
[Cache Information (Type 7) - Length 27 - Handle 004bh]
  Socket Designation            L3 Cache
  Maximum Cache Size            3000h - 12288K
  Installed Size                3000h - 12288K
  Cache Speed                   0ns
  Maximum Cache Size 2          3000 - 00012288l Kb
  Installed Cache Size 2        3000 - 00012288l Kb
[Processor Information (Type 4) - Length 48 - Handle 004ch]
  Socket Designation            U3E1
  Processor Family              ceh - Intel Core 2 Extreme processor
  Processor Manufacturer        Intel(R) Corporation
  Processor ID                   75060900fffbebbf
  Processor Version             12th Gen Intel(R) Core(TM) i3-12100F
  Processor Voltage             8ah - 1.0V
  Max Speed                     4300MHz
  Current Speed                 4059MHz
  Processor Upgrade             Specification Reserved
  L1 Cache Handle               0049h
  L2 Cache Handle               004ah
  L3 Cache Handle               004bh
  Serial Number
  Asset Tag Number
  Part Number                   To Be Filled By O.E.M.
  Core Count                    4
  Core Enabled                  4
  Thread Count                  8
  Processor Characteristics     fc
  Enabled Characteristics:
       0x 2: 64-bit Capable
       0x 3: Multi-Core
       0x 4: Hardware Thread
       0x 5: Execute Protection
       0x 6: Enhanced Virtualization
  Processor Family 2            00ceh - Intel Core 2 Extreme processor
  Core Count 2                  4
  Core Enabled 2                4
  Thread Count 2                8
[ (Type 256) - Length 64 - Handle 004dh]
[ (Type 256) - Length 11 - Handle 004eh]
[ (Type 256) - Length 11 - Handle 004fh]
[ (Type 256) - Length 11 - Handle 0050h]
[ (Type 256) - Length 11 - Handle 0051h]
[ (Type 256) - Length 11 - Handle 0052h]
[ (Type 256) - Length 11 - Handle 0053h]
[ (Type 256) - Length 11 - Handle 0054h]
[ (Type 256) - Length 11 - Handle 0055h]
[ (Type 256) - Length 11 - Handle 0056h]
[ (Type 256) - Length 11 - Handle 0057h]
[ (Type 256) - Length 11 - Handle 0058h]
[ (Type 256) - Length 82 - Handle 0059h]
[ (Type 256) - Length 44 - Handle 005ah]
[ (Type 256) - Length 8 - Handle 005bh]
[ (Type 256) - Length 106 - Handle 005eh]
[ (Type 256) - Length 6 - Handle 005fh]
[ (Type 256) - Length 4 - Handle 0061h]
Bu konuya bakıp dosya atmanız lazım.
Bakayım teşekkürler.
Ben bundan bir şey anlamadım sadece bir dosya var ve bunu ne yapacağız en ufak bilgim yok.
Kod:
Arguments:
Debugging Details:
    Key  : AV.Fault
    Value: Read
    Value: 875
    Value: 2850
    Value: 0
    Value: 1
    Value: 0
    Value: 234
    Value: 1115
    Value: 91
    Value: 1.2408.27.1
    Value: 0x1000007e
    Value: 0x1000007e
    Key  : Failure.Hash
    Key  : WER.OS.Branch
    Value: vb_release
    Value: 10.0.19041.1
BUGCHECK_CODE:  7e
NumberParameters: 2
BLACKBOXWINLOGON: 1
 0000000000000514
STACK_TEXT:
OSNAME:  Windows 10
    PnpProblemCode     : 24
    PnpVetoType        : 0
    VetoString         :
[DMI Version - 0]
  BIOS Version                  1009
       07: - PCI Supported
       19: - EDD Supported
  Product                       H610M-E M.2
  Version                       V20
  Asset Tag
       00: - Motherboard
       03: - Replaceable
  Serial Number
  Asset Tag Number
  Number of Strings             1
   1                            Default string
  Size                          8192MB
  Bank Locator                  BANK 0
  Speed                         3200MHz
  Serial Number
  Asset Tag Number
  Attributes                    1
  Memory Technology             3
  Firmware Version              0
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
  Size                          8192MB
  Bank Locator                  BANK 0
  Speed                         3200MHz
  Serial Number
  Asset Tag Number
  Attributes                    1
  Memory Technology             3
  Firmware Version              0
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
  Cache Speed                   0ns
  Cache Speed                   0ns
  Cache Speed                   0ns
  Associativity                 Other
  Cache Speed                   0ns
  Max Speed                     4300MHz
  Serial Number
  Asset Tag Number
  Core Count                    4
  Core Enabled                  4
  Thread Count                  8
       0x 3: Multi-Core
  Core Count 2                  4
  Core Enabled 2                4
  Thread Count 2                8
Vallahi Recep abi sağolasın mavi ekran sorunu çözüldü. 3 gün önce yeni driver gelmiş.
