MSI VECTOR 16 HX AI A2XWHG-091XTR laptopta mavi ekran hatası
Petyhorcy
3 Eylül 2025
Merhalar Laptobumda mavi ekran hatası alıyorum. Yardımcı olabilir misiniz teşekkür ederim windvg den aldığım bilgiyi aşağıya ekliyorum. Bakarsanız sevinirim
  • İşlemci: Intel Core 255HX Ultra
  • Ekran Kartı: NVIDIA RTX 5070 Ti 12 GB (Mobile)
  • İşletim Sistemi: Windows 11
Kod:
************* Preparing the environment for Debugger Extensions Gallery repositories **************
   ExtensionRepository : Implicit
   UseExperimentalFeatureForNugetShare : true
   AllowNugetExeUpdate : true
   NonInteractiveNuget : true
   AllowNugetMSCredentialProviderInstall : true
   AllowParallelInitializationOfLocalRepositories : true
   EnableRedirectToChakraJsProvider : false
   -- Configuring repositories
      ----> Repository : LocalInstalled, Enabled: true
      ----> Repository : UserExtensions, Enabled: true
[QUOTE]
[QUOTE]>>>>>>>>>>> Preparing the environment for Debugger Extensions Gallery repositories completed, duration 0.000 seconds[/QUOTE]
[/QUOTE]
************* Waiting for Debugger Extensions Gallery to Initialize **************
[QUOTE]
[QUOTE]>>>>>>>>>>> Waiting for Debugger Extensions Gallery to Initialize completed, duration 0.016 seconds[/QUOTE]
[/QUOTE]
   ----> Repository : UserExtensions, Enabled: true, Packages count: 0
   ----> Repository : LocalInstalled, Enabled: true, Packages count: 45
Microsoft (R) Windows Debugger Version 10.0.27871.1001 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Users\Eneshan\Downloads\090325-24781-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
************* Path validation summary **************
Response                         Time (ms)     Location
Deferred                                       srv*
Symbol search path is: srv*
Executable search path is:
Windows 10 Kernel Version 26100 MP (20 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Kernel base = 0xfffff800`a6000000 PsLoadedModuleList = 0xfffff800`a6ef4c40
Debug session time: Wed Sep  3 15:29:11.680 2025 (UTC + 3:00)
System Uptime: 0 days 21:58:19.006
Loading Kernel Symbols
Press ctrl-c (cdb, kd, ntsd) or ctrl-break (windbg) to abort symbol loads that take too long.
Run !sym noisy before .reload to track down problems loading symbols.
Loading User Symbols
Loading unloaded module list
For analysis of this file, run !analyze -v
nt!KeBugCheckEx:
fffff800`a65005d0 48894c2408      mov     qword ptr [rsp+8],rcx ss:0018:ffffbd03`412677e0=0000000000000116
1: kd> !analyze -v
[LIST]
[*]Bugcheck Analysis                                    *
[/LIST]
VIDEO_TDR_FAILURE (116)
Attempt to reset the display driver and recover from timeout failed.
Arguments:
Arg1: ffffc10e952db460, Optional pointer to internal TDR recovery context (TDR_RECOVERY_CONTEXT).
Arg2: fffff8005ba35a50, The pointer into responsible device driver module (e.g. owner tag).
Arg3: ffffffffc000009a, Optional error code (NTSTATUS) of the last failed operation.
Arg4: 0000000000000004, Optional internal context dependent data.
Debugging Details:
Unable to load image nvlddmkm.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for nvlddmkm.sys
KEY_VALUES_STRING: 1
    Key  : Analysis.CPU.mSec
    Value: 1234
    Key  : Analysis.Elapsed.mSec
    Value: 5104
    Key  : Analysis.IO.Other.Mb
    Value: 0
    Key  : Analysis.IO.Read.Mb
    Value: 1
    Key  : Analysis.IO.Write.Mb
    Value: 0
    Key  : Analysis.Init.CPU.mSec
    Value: 781
    Value: 91287
    Value: 122
    Value: 10.0.27871.1001
    Value: 10.2505.01.02 amd64fre
    Key  : Analysis.Version.Ext
    Value: 1.2505.1.2
    Value: 0x116
    Value: 0x116
    Value: 0x21808
    Value: 1
    Value: 0x0
    Value: 1
    Value: 0
    Key  : Failure.Bucket
    Value: 0x116_IMAGE_nvlddmkm.sys
    Key  : Failure.Exception.IP.Address
    Value: 0xfffff8005ba35a50
    Key  : Failure.Exception.IP.Module
    Value: nvlddmkm
    Key  : Failure.Exception.IP.Offset
    Value: 0x1a45a50
    Key  : Failure.Hash
    Value: {c89bfe8c-ed39-f658-ef27-f2898997fdbd}
    Key  : Hypervisor.Enlightenments.ValueHex
    Value: 0x7417df84
    Key  : Hypervisor.Flags.AnyHypervisorPresent
    Value: 1
    Key  : Hypervisor.Flags.ApicEnlightened
    Value: 0
    Key  : Hypervisor.Flags.ApicVirtualizationAvailable
    Value: 1
    Key  : Hypervisor.Flags.AsyncMemoryHint
    Value: 0
    Key  : Hypervisor.Flags.CoreSchedulerRequested
    Value: 0
    Key  : Hypervisor.Flags.CpuManager
    Value: 1
    Key  : Hypervisor.Flags.DeprecateAutoEoi
    Value: 1
    Key  : Hypervisor.Flags.DynamicCpuDisabled
    Value: 1
    Key  : Hypervisor.Flags.Epf
    Value: 0
    Key  : Hypervisor.Flags.ExtendedProcessorMasks
    Value: 1
    Key  : Hypervisor.Flags.HardwareMbecAvailable
    Value: 1
    Key  : Hypervisor.Flags.MaxBankNumber
    Value: 0
    Key  : Hypervisor.Flags.MemoryZeroingControl
    Value: 0
    Key  : Hypervisor.Flags.NoExtendedRangeFlush
    Value: 0
    Key  : Hypervisor.Flags.NoNonArchCoreSharing
    Value: 1
    Key  : Hypervisor.Flags.Phase0InitDone
    Value: 1
    Key  : Hypervisor.Flags.PowerSchedulerQos
    Value: 0
    Key  : Hypervisor.Flags.RootScheduler
    Value: 0
    Key  : Hypervisor.Flags.SynicAvailable
    Value: 1
    Key  : Hypervisor.Flags.UseQpcBias
    Value: 0
    Key  : Hypervisor.Flags.Value
    Value: 55185662
    Key  : Hypervisor.Flags.ValueHex
    Value: 0x34a10fe
    Key  : Hypervisor.Flags.VpAssistPage
    Value: 1
    Key  : Hypervisor.Flags.VsmAvailable
    Value: 1
    Key  : Hypervisor.RootFlags.AccessStats
    Value: 1
    Key  : Hypervisor.RootFlags.CrashdumpEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.CreateVirtualProcessor
    Value: 1
    Key  : Hypervisor.RootFlags.DisableHyperthreading
    Value: 0
    Key  : Hypervisor.RootFlags.HostTimelineSync
    Value: 1
    Key  : Hypervisor.RootFlags.HypervisorDebuggingEnabled
    Value: 0
    Key  : Hypervisor.RootFlags.IsHyperV
    Value: 1
    Key  : Hypervisor.RootFlags.LivedumpEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.MapDeviceInterrupt
    Value: 1
    Key  : Hypervisor.RootFlags.MceEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.Nested
    Value: 0
    Key  : Hypervisor.RootFlags.StartLogicalProcessor
    Value: 1
    Key  : Hypervisor.RootFlags.Value
    Value: 1015
    Key  : Hypervisor.RootFlags.ValueHex
    Value: 0x3f7
BUGCHECK_CODE:  116
BUGCHECK_P1: ffffc10e952db460
BUGCHECK_P2: fffff8005ba35a50
BUGCHECK_P3: ffffffffc000009a
BUGCHECK_P4: 4
FILE_IN_CAB:  090325-24781-01.dmp
TAG_NOT_DEFINED_202b:  *** Unknown TAG in analysis list 202b
DUMP_FILE_ATTRIBUTES: 0x21808
  Kernel Generated Triage Dump
FAULTING_THREAD:  ffffc10e8aaa9040
VIDEO_TDR_CONTEXT: dt dxgkrnl!_TDR_RECOVERY_CONTEXT ffffc10e952db460
Symbol dxgkrnl!_TDR_RECOVERY_CONTEXT not found.
PROCESS_OBJECT: 0000000000000004
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  System
STACK_TEXT:
ffffbd03`412677d8 fffff800`3813375d     : 00000000`00000116 ffffc10e`952db460 fffff800`5ba35a50 ffffffff`c000009a : nt!KeBugCheckEx
ffffbd03`412677e0 fffff800`383a7be6     : fffff800`5ba35a50 ffffc10e`6aefd7e0 00000000`00000004 ffffc10e`952db460 : dxgkrnl!TdrBugcheckOnTimeout+0x101
ffffbd03`41267820 fffff800`381424be     : 00000000`00000000 00000000`00002000 00000000`00000004 00000000`00000004 : dxgkrnl!ADAPTER_RENDER::Reset+0x232
ffffbd03`41267850 fffff800`38179375     : ffffc10e`00000100 00000000`00000000 ffffbd03`00000000 00000000`00000000 : dxgkrnl!DXGADAPTER::Reset+0x59a
ffffbd03`412678e0 fffff800`381794d2     : ffffc10e`6d3450d8 00000000`00000000 ffff9881`973a5100 fffff800`a6fcfbc0 : dxgkrnl!TdrResetFromTimeout+0x15
ffffbd03`41267910 fffff800`a623072c     : ffffc10e`8aaa9040 ffffc10e`40562be0 fffff800`a6a52400 fffff800`a6211c00 : dxgkrnl!TdrResetFromTimeoutWorkItem+0x22
ffffbd03`41267950 fffff800`a649e2da     : ffffc10e`8aaa9040 ffffc10e`8aaa9040 fffff800`a6230140 ffffc10e`40562be0 : nt!ExpWorkerThread+0x5ec
ffffbd03`41267b30 fffff800`a66a67e4     : ffff9881`973a5180 ffffc10e`8aaa9040 fffff800`a649e280 0000023f`52ec5e00 : nt!PspSystemThreadStartup+0x5a
ffffbd03`41267b80 00000000`00000000     : ffffbd03`41268000 ffffbd03`41261000 00000000`00000000 00000000`00000000 : nt!KiStartSystemThread+0x34
SYMBOL_NAME:  nvlddmkm+1a45a50
MODULE_NAME: nvlddmkm
IMAGE_NAME:  nvlddmkm.sys
STACK_COMMAND: .process /r /p 0xffffc10e404ee040; .thread 0xffffc10e8aaa9040 ; kb
FAILURE_BUCKET_ID:  0x116_IMAGE_nvlddmkm.sys
OSPLATFORM_TYPE:  x64
OSNAME:  Windows 10
FAILURE_ID_HASH:  {c89bfe8c-ed39-f658-ef27-f2898997fdbd}
Followup:     MachineOwner
