* Bugcheck Analysis *
IRQL_NOT_LESS_OR_EQUAL (a)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: 0000000000000060, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, bitfield :
bit 0 : value 0 = read operation, 1 = write operation
bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
Arg4: fffff80128f48dc6, address which referenced memory
Debugging Details:
KEY_VALUES_STRING: 1
Key : Analysis.CPU.mSec
Value: 608
Key : Analysis.Elapsed.mSec
Value: 14622
Key : Analysis.IO.Other.Mb
Value: 18
Key : Analysis.IO.Read.Mb
Value: 0
Key : Analysis.IO.Write.Mb
Value: 22
Key : Analysis.Init.CPU.mSec
Value: 265
Value: 9322
Value: 81
Key : Bugcheck.Code.LegacyAPI
Value: 0xa
Key : Bugcheck.Code.TargetModel
Value: 0xa
Key : Failure.Bucket
Value: AV_nt!MiMakeProtoPrivate
Key : Failure.Hash
Value: {79ccbbf1-a05d-4c4c-d95f-1ef76ba669b9}
Key : WER.OS.Branch
Value: vb_release
Key : WER.OS.Version
Value: 10.0.19041.1
BUGCHECK_CODE: a
BUGCHECK_P1: 60
BUGCHECK_P2: 2
BUGCHECK_P3: 0
BUGCHECK_P4: fffff80128f48dc6
FILE_IN_CAB: 091724-6500-01.dmp
FAULTING_THREAD: ffffab8ffda0f080
READ_ADDRESS: fffff801296fb390: Unable to get MiVisibleState
Unable to get NonPagedPoolStart
Unable to get NonPagedPoolEnd
Unable to get PagedPoolStart
Unable to get PagedPoolEnd
unable to get nt!MmSpecialPagesInUse
0000000000000060
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: Discord.exe
TRAP_FRAME: ffffd7026867f170 -- (.trap 0xffffd7026867f170)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=ffffab8ffc74dd20 rbx=0000000000000000 rcx=0000000000000000
rdx=0000000000000000 rsi=0000000000000000 rdi=0000000000000000
rip=fffff80128f48dc6 rsp=ffffd7026867f300 rbp=ffffd7026867f450
r8=ffffef810a85f340 r9=ffffab8ffc74d700 r10=ffffeff7fbfdffff
r11=ffffeff7c0000000 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei pl zr na po nc
nt!MiMakeProtoPrivate+0xb2:
fffff801`28f48dc6 48394a60 cmp qword ptr [rdx+60h],rcx ds:00000000`00000060=????????????????
Resetting default scope
STACK_TEXT:
ffffd702`6867f028 fffff801`28e12ba9 : 00000000`0000000a 00000000`00000060 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
ffffd702`6867f030 fffff801`28e0e578 : ffffd702`6867f350 fffff801`28cc28c5 ffffab8f`fc74d700 ffffab8f`fc74d700 : nt!KiBugCheckDispatch+0x69
ffffd702`6867f170 fffff801`28f48dc6 : ffffd702`6867f4f8 ffffef81`0a85f200 ffffef81`0a85f3f8 ffffab8f`fc74d700 : nt!KiPageFault+0x478
ffffd702`6867f300 fffff801`28cc1966 : ffffec00`03000000 ffffd702`6867f450 00000001`00000001 ffffd702`6867f300 : nt!MiMakeProtoPrivate+0xb2
ffffd702`6867f350 fffff801`29027a1b : ffffd702`6867f730 00000000`00000004 00000215`0be7ffff ffffd702`6867f860 : nt!MiProtectPrivateMemory+0x576
ffffd702`6867f500 fffff801`290261c9 : ffffab8f`fc74d080 ffffab8f`fc74d080 ffffd702`6867f6d8 ffffd702`6867f6d0 : nt!MmProtectVirtualMemory+0x42b
ffffd702`6867f630 fffff801`29026c3f : ffffab8f`00000000 fffff801`00000000 00000000`00000000 00000000`00000001 : nt!MiAllocateVirtualMemory+0x5e9
ffffd702`6867f7b0 fffff801`29026a61 : ffffffff`ffffffff ffffab8f`fda0f080 000000d6`23dfe838 ffffab8f`00001000 : nt!MmAllocateVirtualMemory+0x1cf
ffffd702`6867f960 fffff801`28e12305 : 00000000`00000000 00000000`00000000 00000000`00000000 ffffab8f`fd015b60 : nt!NtAllocateVirtualMemoryEx+0x51
ffffd702`6867f9d0 00007ffa`3d24e414 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x25
000000d6`23dfe818 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ffa`3d24e414
SYMBOL_NAME: nt!MiMakeProtoPrivate+b2
MODULE_NAME: nt
IMAGE_VERSION: 10.0.19041.4894
STACK_COMMAND: .process /r /p 0xffffab8ffc74d080; .thread 0xffffab8ffda0f080 ; kb
IMAGE_NAME: ntkrnlmp.exe
BUCKET_ID_FUNC_OFFSET: b2
FAILURE_BUCKET_ID: AV_nt!MiMakeProtoPrivate
OS_VERSION: 10.0.19041.1
BUILDLAB_STR: vb_release
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {79ccbbf1-a05d-4c4c-d95f-1ef76ba669b9}
Followup: MachineOwner
PnpActivityId : {00000000-0000-0000-0000-000000000000}
PnpActivityTime : 133710551399626688
PnpEventInformation: 3
PnpEventInProgress : 0
PnpProblemCode : 24
PnpVetoType : 0
DeviceId : SWD\MMDEVAPI\{0.0.1.00000000}.{0524ae5e-d243-4c1e-b1b1-e241c31abc29}
VetoString :
start end module name
ffffa6d1`b4400000 ffffa6d1`b46cc000 win32kbase (deferred)
ffffa6d1`b48f0000 ffffa6d1`b498b000 win32k (deferred)
ffffa6d1`b5510000 ffffa6d1`b58c1000 win32kfull (deferred)
ffffa6d1`b58d0000 ffffa6d1`b5919000 cdd (deferred)
fffff801`26860000 fffff801`26aef000 mcupdate_GenuineIntel (deferred)
fffff801`26af0000 fffff801`26af6000 hal (deferred)
fffff801`26b00000 fffff801`26b0b000 kd (deferred)
fffff801`26b10000 fffff801`26b38000 tm (deferred)
fffff801`26b40000 fffff801`26bae000 CLFS (deferred)
fffff801`26bb0000 fffff801`26bca000 PSHED (deferred)
fffff801`26bd0000 fffff801`26bdb000 BOOTVID (deferred)
fffff801`26be0000 fffff801`26c4e000 FLTMGR (deferred)
fffff801`26c50000 fffff801`26c5e000 cmimcext (deferred)
fffff801`28a00000 fffff801`29a46000 nt (pdb symbols) C:\ProgramData\Dbg\sym\ntkrnlmp.pdb\9F65CD18C2F36F88B2D0CE8A7BFE2BB71\ntkrnlmp.pdb
fffff801`2c200000 fffff801`2c318000 clipsp (deferred)
fffff801`2c320000 fffff801`2c349000 ksecdd (deferred)
fffff801`2c350000 fffff801`2c3b3000 msrpc (deferred)
fffff801`2c3c0000 fffff801`2c3d1000 werkernel (deferred)
fffff801`2c3e0000 fffff801`2c3ec000 ntosext (deferred)
fffff801`2c3f0000 fffff801`2c4dc000 CI (deferred)
fffff801`2c4e0000 fffff801`2c59b000 cng (deferred)
fffff801`2c5a0000 fffff801`2c671000 Wdf01000 (deferred)
fffff801`2c680000 fffff801`2c693000 WDFLDR (deferred)
fffff801`2c6a0000 fffff801`2c6af000 SleepStudyHelper (deferred)
fffff801`2c6b0000 fffff801`2c6c1000 WppRecorder (deferred)
fffff801`2c6d0000 fffff801`2c6f6000 acpiex (deferred)
fffff801`2c700000 fffff801`2c71a000 SgrmAgent (deferred)
fffff801`2c720000 fffff801`2c7ec000 ACPI (deferred)
fffff801`2c7f0000 fffff801`2c7fc000 WMILIB (deferred)
fffff801`2c800000 fffff801`2c80b000 msisadrv (deferred)
fffff801`2c810000 fffff801`2c888000 pci (deferred)
fffff801`2c890000 fffff801`2c8d5000 tpm (deferred)
fffff801`2c900000 fffff801`2c96b000 intelpep (deferred)
fffff801`2c970000 fffff801`2c987000 WindowsTrustedRT (deferred)
fffff801`2c990000 fffff801`2c99b000 IntelTA (deferred)
fffff801`2c9a0000 fffff801`2c9ab000 WindowsTrustedRTProxy (deferred)
fffff801`2c9b0000 fffff801`2c9c4000 pcw (deferred)
fffff801`2c9d0000 fffff801`2c9e5000 vdrvroot (deferred)
fffff801`2c9f0000 fffff801`2c9fd000 Fs_Rec (deferred)
fffff801`2ca00000 fffff801`2ca30000 pdc (deferred)
fffff801`2ca40000 fffff801`2ca59000 CEA (deferred)
fffff801`2ca60000 fffff801`2ca91000 partmgr (deferred)
fffff801`2caa0000 fffff801`2cb4b000 spaceport (deferred)
fffff801`2cb50000 fffff801`2cb69000 volmgr (deferred)
fffff801`2cb70000 fffff801`2cbd3000 volmgrx (deferred)
fffff801`2cbe0000 fffff801`2cbfe000 mountmgr (deferred)
fffff801`2cc00000 fffff801`2cc32000 storahci (deferred)
fffff801`2cc40000 fffff801`2ccf5000 storport (deferred)
fffff801`2cd00000 fffff801`2cd2f000 stornvme (deferred)
fffff801`2cd30000 fffff801`2cd4c000 EhStorClass (deferred)
fffff801`2cd50000 fffff801`2cd6a000 fileinfo (deferred)
fffff801`2cd70000 fffff801`2cdb0000 Wof (deferred)
fffff801`2ce20000 fffff801`2d0f7000 Ntfs (deferred)
fffff801`2d100000 fffff801`2d270000 ndis (deferred)
fffff801`2d280000 fffff801`2d31c000 NETIO (deferred)
fffff801`2d320000 fffff801`2d352000 ksecpkg (deferred)
fffff801`2d360000 fffff801`2d64d000 tcpip (deferred)
fffff801`2d650000 fffff801`2d6cf000 fwpkclnt (deferred)
fffff801`2d6d0000 fffff801`2d700000 wfplwfs (deferred)
fffff801`2d710000 fffff801`2d7d9000 fvevol (deferred)
fffff801`2d7e0000 fffff801`2d7eb000 volume (deferred)
fffff801`2d7f0000 fffff801`2d85d000 volsnap (deferred)
fffff801`2d860000 fffff801`2d8b0000 rdyboost (deferred)
fffff801`2d8c0000 fffff801`2d8e6000 mup (deferred)
fffff801`2d8f0000 fffff801`2d902000 iorate (deferred)
fffff801`2d930000 fffff801`2d94d000 disk (deferred)
fffff801`2d950000 fffff801`2d9c2000 CLASSPNP (deferred)
fffff801`40020000 fffff801`40050000 cdrom (deferred)
fffff801`40060000 fffff801`40075000 filecrypt (deferred)
fffff801`40080000 fffff801`4008e000 tbs (deferred)
fffff801`40090000 fffff801`400a5000 UCPD (deferred)
fffff801`400b0000 fffff801`400ba000 Null (deferred)
fffff801`400c0000 fffff801`400ca000 Beep (deferred)
fffff801`400d0000 fffff801`4047a000 dxgkrnl (deferred)
fffff801`40480000 fffff801`40498000 watchdog (deferred)
fffff801`404a0000 fffff801`404b6000 BasicDisplay (deferred)
fffff801`404c0000 fffff801`404d1000 BasicRender (deferred)
fffff801`404e0000 fffff801`404fc000 Npfs (deferred)
fffff801`40500000 fffff801`40511000 Msfs (deferred)
fffff801`40520000 fffff801`4053e000 CimFS (deferred)
fffff801`40540000 fffff801`40562000 tdx (deferred)
fffff801`40570000 fffff801`40580000 TDI (deferred)
fffff801`40590000 fffff801`405ec000 netbt (deferred)
fffff801`405f0000 fffff801`40604000 afunix (deferred)
fffff801`40610000 fffff801`406b8000 afd (deferred)
fffff801`406c0000 fffff801`406da000 vwififlt (deferred)
fffff801`406e0000 fffff801`4070b000 pacer (deferred)
fffff801`40710000 fffff801`40724000 ndiscap (deferred)
fffff801`40730000 fffff801`40744000 netbios (deferred)
fffff801`40750000 fffff801`407f1000 Vid (deferred)
fffff801`40800000 fffff801`40824000 winhvr (deferred)
fffff801`40830000 fffff801`408ab000 rdbss (deferred)
fffff801`408b0000 fffff801`408c2000 nsiproxy (deferred)
fffff801`408d0000 fffff801`408de000 npsvctrig (deferred)
fffff801`408e0000 fffff801`408f0000 mssmbios (deferred)
fffff801`40900000 fffff801`4090a000 gpuenergydrv (deferred)
fffff801`40910000 fffff801`4093d000 dfsc (deferred)
fffff801`40960000 fffff801`409cd000 fastfat (deferred)
fffff801`409d0000 fffff801`409e7000 bam (deferred)
fffff801`409f0000 fffff801`40a42000 ahcache (deferred)
fffff801`40a50000 fffff801`40a62000 CompositeBus (deferred)
fffff801`40a70000 fffff801`40a7d000 kdnic (deferred)
fffff801`40a80000 fffff801`40a95000 umbus (deferred)
fffff801`40aa0000 fffff801`40af6000 srvnet (deferred)
fffff801`40b40000 fffff801`40b5e000 crashdmp (deferred)
fffff801`40b60000 fffff801`40bb2000 mrxsmb10 (deferred)
fffff801`50200000 fffff801`5029d000 USBXHCI (deferred)
fffff801`502a0000 fffff801`502e4000 ucx01000 (deferred)
fffff801`502f0000 fffff801`5033f000 TeeDriverW10x64 (deferred)
fffff801`50340000 fffff801`5046a000 rt640x64 (deferred)
fffff801`50470000 fffff801`5048c000 serial (deferred)
fffff801`50490000 fffff801`5049f000 serenum (deferred)
fffff801`504a0000 fffff801`504ac000 acpitime (deferred)
fffff801`504b0000 fffff801`504f1000 intelppm (deferred)
fffff801`50500000 fffff801`5050b000 acpipagr (deferred)
fffff801`50510000 fffff801`5051c000 wmiacpi (deferred)
fffff801`50520000 fffff801`50537000 HidEventFilter (deferred)
fffff801`50540000 fffff801`5054b000 mshidkmdf (deferred)
fffff801`50550000 fffff801`50591000 HIDCLASS (deferred)
fffff801`505a0000 fffff801`505b3000 HIDPARSE (deferred)
fffff801`505c0000 fffff801`505ce000 UEFI (deferred)
fffff801`505d0000 fffff801`505dd000 NdisVirtualBus (deferred)
fffff801`505e0000 fffff801`505ec000 swenum (deferred)
fffff801`505f0000 fffff801`505fe000 rdpbus (deferred)
fffff801`50600000 fffff801`50611000 kbdhid (deferred)
fffff801`50620000 fffff801`50634000 kbdclass (deferred)
fffff801`50640000 fffff801`50652000 buttonconverter (deferred)
fffff801`50660000 fffff801`50703000 UsbHub3 (deferred)
fffff801`50710000 fffff801`5071e000 USBD (deferred)
fffff801`50720000 fffff801`5073e000 nvhda64v (deferred)
fffff801`50740000 fffff801`50751000 ksthunk (deferred)
fffff801`50760000 fffff801`50840000 dxgmms2 (deferred)
fffff801`50850000 fffff801`50887000 wcifs (deferred)
fffff801`50890000 fffff801`50912000 cldflt (deferred)
fffff801`50920000 fffff801`50948000 bindflt (deferred)
fffff801`50950000 fffff801`50968000 lltdio (deferred)
fffff801`50970000 fffff801`50988000 mslldp (deferred)
fffff801`50990000 fffff801`509ab000 rspndr (deferred)
fffff801`509b0000 fffff801`509cd000 wanarp (deferred)
fffff801`509d0000 fffff801`50a26000 msquic (deferred)
fffff801`50a30000 fffff801`50bb7000 HTTP (deferred)
fffff801`50bc0000 fffff801`50be5000 bowser (deferred)
fffff801`50bf0000 fffff801`50c0a000 mpsdrv (deferred)
fffff801`50c10000 fffff801`50ca4000 mrxsmb (deferred)
fffff801`50cb0000 fffff801`50cf5000 mrxsmb20 (deferred)
fffff801`50d00000 fffff801`54653000 nvlddmkm (deferred)
fffff801`54660000 fffff801`54685000 HDAudBus (deferred)
fffff801`54690000 fffff801`546f8000 portcls (deferred)
fffff801`54700000 fffff801`54721000 drmk (deferred)
fffff801`54730000 fffff801`547a8000 ks (deferred)
fffff801`547b0000 fffff801`547d7000 Ndu (deferred)
fffff801`5b000000 fffff801`5b034000 usbccgp (deferred)
fffff801`5b080000 fffff801`5b093000 mouclass (deferred)
fffff801`5b0a0000 fffff801`5b0d8000 usbaudio (deferred)
fffff801`5b0f0000 fffff801`5b0ff000 dump_dumpstorport (deferred)
fffff801`5b130000 fffff801`5b15f000 dump_stornvme (deferred)
fffff801`5b180000 fffff801`5b19d000 dump_dumpfve (deferred)
fffff801`5b1a0000 fffff801`5b1bb000 monitor (deferred)
fffff801`5b1c0000 fffff801`5b1ed000 luafv (deferred)
fffff801`5b1f0000 fffff801`5b7d0000 RTKVHD64 (deferred)
fffff801`5b7e0000 fffff801`5b7fa000 storqosflt (deferred)
fffff801`83600000 fffff801`8361c000 raspppoe (deferred)
fffff801`83620000 fffff801`8362f000 ndistapi (deferred)
fffff801`83630000 fffff801`8366a000 ndiswan (deferred)
fffff801`83680000 fffff801`83692000 condrv (deferred)
fffff801`83710000 fffff801`837a6000 WdFilter (deferred)
fffff801`837b0000 fffff801`837cd000 WdNisDrv (deferred)
fffff801`83890000 fffff801`838a1000 RzDev_00b8 (deferred)
fffff801`838b0000 fffff801`838c2000 hidusb (deferred)
fffff801`838d0000 fffff801`838e0000 mouhid (deferred)
fffff801`838f0000 fffff801`83901000 RzDev_02a1 (deferred)
fffff801`83910000 fffff801`83920000 RzCommon (deferred)
fffff801`83930000 fffff801`83959000 RZTHXSpatial (deferred)
fffff801`83960000 fffff801`8396e000 gdrv3 (deferred)
fffff801`84330000 fffff801`84406000 peauth (deferred)
fffff801`84410000 fffff801`84424000 mmcss (deferred)
fffff801`84430000 fffff801`84445000 tcpipreg (deferred)
fffff801`84450000 fffff801`84518000 srv2 (deferred)
fffff801`84520000 fffff801`8453d000 rassstp (deferred)
fffff801`84540000 fffff801`8455d000 NDProxy (deferred)
fffff801`84560000 fffff801`84588000 AgileVpn (deferred)
fffff801`84590000 fffff801`845b1000 rasl2tp (deferred)
fffff801`845c0000 fffff801`845e1000 raspptp (deferred)
Unloaded modules:
fffff801`83670000 fffff801`83680000 gdrv3.sys
fffff801`83830000 fffff801`83843000 hidusb.sys
fffff801`83810000 fffff801`83822000 RzDev_02a1.s
fffff801`83850000 fffff801`83861000 mouhid.sys
fffff801`83870000 fffff801`83881000 RzCommon.sys
fffff801`837d0000 fffff801`837e3000 hidusb.sys
fffff801`837f0000 fffff801`83801000 mouhid.sys
fffff801`5b040000 fffff801`5b053000 hidusb.sys
fffff801`5b060000 fffff801`5b071000 mouhid.sys
fffff801`2cdc0000 fffff801`2ce1b000 WdFilter.sys
fffff801`836c0000 fffff801`83706000 MpKslDrv.sys
fffff801`836a0000 fffff801`836b3000 WdNisDrv.sys
fffff801`40b70000 fffff801`40b80000 dump_storpor
fffff801`40bb0000 fffff801`40be0000 dump_stornvm
fffff801`40000000 fffff801`4001e000 dump_dumpfve
fffff801`40940000 fffff801`4095c000 dam.sys
fffff801`2c8e0000 fffff801`2c8f1000 WdBoot.sys
fffff801`2d910000 fffff801`2d921000 hwpolicy.sys
# RetAddr : Args to Child : Call Site
00 fffff801`28e12ba9 : 00000000`0000000a 00000000`00000060 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
01 fffff801`28e0e578 : ffffd702`6867f350 fffff801`28cc28c5 ffffab8f`fc74d700 ffffab8f`fc74d700 : nt!KiBugCheckDispatch+0x69
02 fffff801`28f48dc6 : ffffd702`6867f4f8 ffffef81`0a85f200 ffffef81`0a85f3f8 ffffab8f`fc74d700 : nt!KiPageFault+0x478
03 fffff801`28cc1966 : ffffec00`03000000 ffffd702`6867f450 00000001`00000001 ffffd702`6867f300 : nt!MiMakeProtoPrivate+0xb2
04 fffff801`29027a1b : ffffd702`6867f730 00000000`00000004 00000215`0be7ffff ffffd702`6867f860 : nt!MiProtectPrivateMemory+0x576
05 fffff801`290261c9 : ffffab8f`fc74d080 ffffab8f`fc74d080 ffffd702`6867f6d8 ffffd702`6867f6d0 : nt!MmProtectVirtualMemory+0x42b
06 fffff801`29026c3f : ffffab8f`00000000 fffff801`00000000 00000000`00000000 00000000`00000001 : nt!MiAllocateVirtualMemory+0x5e9
07 fffff801`29026a61 : ffffffff`ffffffff ffffab8f`fda0f080 000000d6`23dfe838 ffffab8f`00001000 : nt!MmAllocateVirtualMemory+0x1cf
08 fffff801`28e12305 : 00000000`00000000 00000000`00000000 00000000`00000000 ffffab8f`fd015b60 : nt!NtAllocateVirtualMemoryEx+0x51
09 00007ffa`3d24e414 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x25
0a 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ffa`3d24e414
Machine ID Information [From Smbios 3.6, DMIVersion 0, Size=5033]
BiosMajorRelease = 5
BiosMinorRelease = 27
BiosVendor = American Megatrends International, LLC.
BiosVersion = F4d
BiosReleaseDate = 08/09/2024
SystemManufacturer = Gigabyte Technology Co., Ltd.
SystemProductName = H610M H V2
SystemFamily = H610 MB
SystemVersion = -CF
SystemSKU = Default string
BaseBoardManufacturer = Gigabyte Technology Co., Ltd.
BaseBoardProduct = H610M H V2
BaseBoardVersion = x.x
[SMBIOS Data Tables v3.6]
[DMI Version - 0]
[2.0 Calling Convention - No]
[Table Size - 5033 bytes]
Vendor American Megatrends International, LLC.
BIOS Version F4d
BIOS Release Date 08/09/2024
BIOS ROM Size 1000000
BIOS Characteristics
07: - PCI Supported
11: - Upgradeable FLASH BIOS
15: - CD-Boot Supported
17: - BIOS ROM Socketed
19: - EDD Supported
22: - 360KB Floppy Supported
23: - 1.2MB Floppy Supported
24: - 720KB Floppy Supported
25: - 2.88MB Floppy Supported
32: - BIOS Vendor Reserved
00: - ACPI Supported
01: - USB Legacy Supported
BIOS Major Revision 5
BIOS Minor Revision 27
EC Firmware Major Revision 255
EC Firmware Minor Revision 255
Extended BIOS ROM Size 16 MB
Manufacturer Gigabyte Technology Co., Ltd.
Product Name H610M H V2
Version -CF
Serial Number Default string
UUID 00000000-0000-0000-0000-000000000000
Wakeup Type Power Switch
SKUNumber Default string
Family H610 MB
Product H610M H V2
Version x.x
Asset Tag
Feature Flags 09h
00: - Motherboard
03: - Replaceable
Location Default string
Chassis Handle 0003h
Board Type 0ah - Processor/Memory Module
Number of Child Handles 0
Manufacturer Default string
Chassis Type Desktop
Version Default string
Serial Number
Asset Tag Number
Bootup State Safe
Power Supply State Safe
Thermal State Safe
Security Status None
OEM Defined 0
Height 0U
Number of Power Cords 1
Number of Contained Elements 0
Contained Element Size 3
[Onboard Devices Information (Type 10) - Length 6 - Handle 0021h]
Note: The On Board Device Information (Type 10) struct is obsolete as of SMBIOs spec v2.6 Number of Devices 1
01: Type Video [enabled]
01: Description To Be Filled By O.E.M.
[OEM Strings (Type 11) - Length 5 - Handle 0022h]
Number of Strings 1
1 Default string
[System Configuration Options (Type 12) - Length 5 - Handle 0023h]
[ (Type 256) - Length 9 - Handle 003ah]
[Physical Memory Array (Type 16) - Length 23 - Handle 003bh]
Location 03h - SystemBoard/Motherboard
Use 03h - System Memory
Memory Error Correction 03h - None
Maximum Capacity 67108864KB
Memory Error Inf Handle [Not Provided]
Number of Memory Devices 2
[Memory Device (Type 17) - Length 92 - Handle 003ch]
Memory Error Info Handle [Not Provided]
Total Width 64 bits
Data Width 64 bits
Size 16384MB
Form Factor 09h - DIMM
Device Set [None]
Device Locator DDR5-A1
Bank Locator BANK 0
Memory Type 22h - DDR5
Type Detail 0080h - Synchronous
Speed 5600MHz
Manufacturer Crucial Technology
Serial Number
Asset Tag Number
Part Number CP16G56C46U5.C8B2
Attributes 1
Extended Size 0
Configured Memory Speed 4800
Minimum Voltage 1100
Maximum Voltage 2950
Configured Voltage 1100
Memory Technology 3
Memory Operating Mode Capability 8
Firmware Version 0
Module Manufacturer Id 39813
Module Product Id 0
Memory Subsystem Controller Manufacturer Id 0
Memory Subsystem Controller Product Id 0
Non-Volatile Size 0
Volatile Size 0
Cache Size 0
Logical Size 0
Extended Speed 0
Extended Configured Memory Speed 0
[Memory Device (Type 17) - Length 92 - Handle 003dh]
Total Width 64 bits
Data Width 64 bits
Size 16384MB
Device Set [None]
Device Locator DDR5-B1
Bank Locator BANK 0
Speed 5600MHz
Serial Number
Asset Tag Number
Attributes 1
Extended Size 0
Memory Technology 3
Firmware Version 0
Module Product Id 0
Non-Volatile Size 0
Volatile Size 0
Cache Size 0
Logical Size 0
Extended Speed 0
[Memory Array Mapped Address (Type 19) - Length 31 - Handle 003eh]
Starting Address 00000000h
Ending Address ffffffffh
Memory Array Handle 003bh
Partition Width 02
Extended Starting Address 0000000000000000h
Extended Ending Address 0000000000000000h
[ (Type 256) - Length 31 - Handle 003fh]
[ (Type 256) - Length 26 - Handle 0040h]
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 0041h]
Ending Address 00ffffffh
Memory Device Handle 003ch
Mem Array Mapped Adr Handle 003eh
Partition Row Position [Unknown]
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 0042h]
Starting Address 01000000h
Ending Address 01ffffffh
Memory Device Handle 003dh
[ (Type 256) - Length 12 - Handle 0043h]
[ (Type 256) - Length 26 - Handle 0044h]
[ (Type 256) - Length 26 - Handle 0045h]
[ (Type 256) - Length 47 - Handle 0046h]
[ (Type 256) - Length 82 - Handle 0047h]
[Cache Information (Type 7) - Length 27 - Handle 0048h]
Socket Designation L1 Cache
Cache Configuration 0180h - WBEnabled Int NonSocketed L1
Maximum Cache Size 0120h - 288K
Installed Size 0120h - 288K
Supported SRAM Type 0020h - Synchronous
Current SRAM Type 0020h - Synchronous
Cache Speed 0ns
Error Correction Type ParitySingle-Bit ECC
System Cache Type Data
Associativity 12-way Set-Associative
Maximum Cache Size 2 120 - 00000288l Kb
Installed Cache Size 2 120 - 00000288l Kb
[Cache Information (Type 7) - Length 27 - Handle 0049h]
Maximum Cache Size 00c0h - 192K
Installed Size 00c0h - 192K
Cache Speed 0ns
System Cache Type Instruction
Associativity 8-way Set-Associative
Maximum Cache Size 2 c0 - 00000192l Kb
Installed Cache Size 2 c0 - 00000192l Kb
[Cache Information (Type 7) - Length 27 - Handle 004ah]
Socket Designation L2 Cache
Cache Configuration 0181h - WBEnabled Int NonSocketed L2
Maximum Cache Size 1e00h - 7680K
Installed Size 1e00h - 7680K
Cache Speed 0ns
Error Correction Type Multi-Bit ECC
System Cache Type Unified
Associativity Other
Maximum Cache Size 2 1e00 - 00007680l Kb
Installed Cache Size 2 1e00 - 00007680l Kb
[Cache Information (Type 7) - Length 27 - Handle 004bh]
Socket Designation L3 Cache
Cache Configuration 0182h - WBEnabled Int NonSocketed L3
Maximum Cache Size 5000h - 20480K
Installed Size 5000h - 20480K
Cache Speed 0ns
Error Correction Type Specification Reserved
Associativity Other
Maximum Cache Size 2 5000 - 00020480l Kb
Installed Cache Size 2 5000 - 00020480l Kb
[Cache Information (Type 7) - Length 27 - Handle 004ch]
Maximum Cache Size 0080h - 128K
Installed Size 0080h - 128K
Cache Speed 0ns
Maximum Cache Size 2 80 - 00000128l Kb
Installed Cache Size 2 80 - 00000128l Kb
[Cache Information (Type 7) - Length 27 - Handle 004dh]
Maximum Cache Size 0100h - 256K
Installed Size 0100h - 256K
Cache Speed 0ns
Maximum Cache Size 2 100 - 00000256l Kb
Installed Cache Size 2 100 - 00000256l Kb
[Cache Information (Type 7) - Length 27 - Handle 004eh]
Maximum Cache Size 0800h - 2048K
Installed Size 0800h - 2048K
Cache Speed 0ns
Associativity 16-way Set-Associative
Maximum Cache Size 2 800 - 00002048l Kb
Installed Cache Size 2 800 - 00002048l Kb
[Cache Information (Type 7) - Length 27 - Handle 004fh]
Cache Speed 0ns
Associativity Other
[Processor Information (Type 4) - Length 48 - Handle 0050h]
Socket Designation U3E1
Processor Type Central Processor
Processor Family cdh - Intel Core 2 Solo processor
Processor Manufacturer Intel(R) Corporation
Processor ID 71060b00fffbebbf
Processor Version Intel(R) Core(TM) i5-14400F
Processor Voltage 89h - 0.9V
External Clock 100MHz
Max Speed 4700MHz
Current Speed 2475MHz
Status Enabled Populated
Processor Upgrade Specification Reserved
L1 Cache Handle 004dh
L2 Cache Handle 004eh
L3 Cache Handle 004fh
Serial Number
Asset Tag Number
Part Number To Be Filled By O.E.M.
Core Count 10
Core Enabled 10
Thread Count 16
Processor Characteristics fc
Enabled Characteristics:
0x 2: 64-bit Capable
0x 3: Multi-Core
0x 4: Hardware Thread
0x 5: Execute Protection
0x 6: Enhanced Virtualization
Processor Family 2 00cdh - Intel Core 2 Solo processor
Core Count 2 10
Core Enabled 2 10
Thread Count 2 16
[ (Type 256) - Length 64 - Handle 0051h]
[ (Type 256) - Length 11 - Handle 0052h]
[ (Type 256) - Length 11 - Handle 0053h]
[ (Type 256) - Length 11 - Handle 0054h]
[ (Type 256) - Length 11 - Handle 0055h]
[ (Type 256) - Length 11 - Handle 0056h]
[ (Type 256) - Length 11 - Handle 0057h]
[ (Type 256) - Length 11 - Handle 0058h]
[ (Type 256) - Length 11 - Handle 0059h]
[ (Type 256) - Length 11 - Handle 005ah]
[ (Type 256) - Length 11 - Handle 005bh]
[ (Type 256) - Length 11 - Handle 005ch]
[ (Type 256) - Length 11 - Handle 005dh]
[ (Type 256) - Length 11 - Handle 005eh]
[ (Type 256) - Length 11 - Handle 005fh]
[ (Type 256) - Length 11 - Handle 0060h]
[ (Type 256) - Length 103 - Handle 0061h]
[ (Type 256) - Length 44 - Handle 0062h]
[ (Type 256) - Length 8 - Handle 0063h]
[ (Type 256) - Length 106 - Handle 0067h]
[ (Type 256) - Length 6 - Handle 0068h]
[ (Type 256) - Length 4 - Handle 006ah]
THREAD ffffab8ffda0f080 Cid 32f4.29ac Teb: 000000d61e476000 Win32Thread: 0000000000000000 RUNNING on processor 8
Not impersonating
GetUlongFromAddress: unable to read from fffff8012961159c
Owning Process ffffab8ffc74d080 Image: Discord.exe
Attached Process N/A Image: N/A
fffff78000000000: Unable to get shared data
Wait Start TickCount 51925
Context Switch Count 6341 IdealProcessor: 3
ReadMemory error: Cannot get nt!KeMaximumIncrement value.
UserTime 00:00:00.000
KernelTime 00:00:00.000
Win32 Start Address 0x00007ff73cdce270
Stack Init ffffd7026867fbd0 Current ffffd7026867f5e0
Base ffffd70268680000 Limit ffffd70268679000 Call 0000000000000000
Priority 9 BasePriority 8 IoPriority 2 PagePriority 5
Child-SP RetAddr : Args to Child : Call Site
ffffd702`6867f170 fffff801`28f48dc6 : ffffd702`6867f4f8 ffffef81`0a85f200 ffffef81`0a85f3f8 ffffab8f`fc74d700 : nt!KiPageFault+0x478 (TrapFrame @ ffffd702`6867f170)
ffffd702`6867f9d0 00007ffa`3d24e414 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x25 (TrapFrame @ ffffd702`6867fa40)
MEMORY_MANAGEMENT (1a)
# Any other values for parameter 1 must be individually examined.
Arguments:
Arg1: 0000000000041792, A corrupt PTE has been detected. Parameter 2 contains the address of
the PTE. Parameters 3/4 contain the low/high parts of the PTE.
Arg2: ffffed813aae5480
Arg3: 0001000000000000
Arg4: 0000000000000000
Debugging Details:
Value: 499
Value: 3759
Value: 14
Value: 0
Value: 18
Value: 139
Value: 8711
Value: 81
Value: 0x1a
Value: 0x1a
Value: MEMORY_CORRUPTION_ONE_BIT
Key : Failure.Hash
Value: {e3faf315-c3d0-81db-819a-6c43d23c63a7}
Key : MemoryManagement.PFN
Value: 0
Key : WER.OS.Branch
Value: vb_release
Value: 10.0.19041.1
BUGCHECK_CODE: 1a
BUGCHECK_P1: 41792
BUGCHECK_P2: ffffed813aae5480
BUGCHECK_P3: 1000000000000
BUGCHECK_P4: 0
FILE_IN_CAB: 091824-13937-01.dmp
FAULTING_THREAD: ffff9c8230e04080
MEMORY_CORRUPTOR: ONE_BIT
BLACKBOXWINLOGON: 1
PROCESS_NAME: opera.exe
STACK_TEXT:
fffff40f`f794f048 fffff804`21aa04ca : 00000000`0000001a 00000000`00041792 ffffed81`3aae5480 00010000`00000000 : nt!KeBugCheckEx
fffff40f`f794f050 fffff804`21a38816 : 00000000`00000000 00000000`00000000 00000000`00006b2a ffffed81`3aae5480 : nt!MiDeleteVa+0x153a
fffff40f`f794f150 fffff804`21a3892b : ffffedf6`00000000 ffff9c82`30772700 fffff40f`00000000 fffff40f`f794f5c0 : nt!MiWalkPageTablesRecursively+0x776
fffff40f`f794f1f0 fffff804`21a3892b : ffffedf6`00000000 ffff9c82`30772700 fffff40f`00000001 fffff40f`f794f5d0 : nt!MiWalkPageTablesRecursively+0x88b
fffff40f`f794f290 fffff804`21a3892b : ffffedf6`fb604000 ffff9c82`30772700 fffff40f`00000002 fffff40f`f794f5e0 : nt!MiWalkPageTablesRecursively+0x88b
fffff40f`f794f330 fffff804`21a3592b : 00000000`c0000016 ffff9c82`30772700 00000000`00000003 fffff40f`f794f5f0 : nt!MiWalkPageTablesRecursively+0x88b
fffff40f`f794f3d0 fffff804`21a9ed61 : fffff40f`f794f570 ffff9c82`00000000 00000000`00000002 00000000`00000000 : nt!MiWalkPageTables+0x36b
fffff40f`f794f4d0 fffff804`21a48a68 : 00000000`00000001 ffff9c82`00000000 ffff9c82`30772550 ffff9c82`30e04080 : nt!MiDeletePagablePteRange+0x4f1
fffff40f`f794f7e0 fffff804`21e4f469 : fffff40f`00000000 00000000`00000000 00004f44`00000000 ffff9c82`30772080 : nt!MiDeleteVad+0x378
fffff40f`f794f8e0 fffff804`21e4f242 : ffff9c82`30f2d0a0 00000000`00000000 ffff9c82`30772080 00000000`00000000 : nt!MiUnmapVad+0x49
fffff40f`f794f910 fffff804`21e4f0b9 : 000000d5`a2dff428 7fffffff`00000004 00004f44`00290280 00000000`00000000 : nt!MiUnmapViewOfSection+0x152
fffff40f`f794f9f0 fffff804`21c12305 : ffff9c82`30e04080 00000275`55fa0000 fffff40f`f794fac0 ffff9c82`30772080 : nt!NtUnmapViewOfSectionEx+0x99
fffff40f`f794fa40 00007ff9`8e630f14 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x25
000000d5`a2dff358 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ff9`8e630f14
MODULE_NAME: hardware
IMAGE_NAME: memory_corruption
STACK_COMMAND: .process /r /p 0xffff9c8230772080; .thread 0xffff9c8230e04080 ; kb
FAILURE_BUCKET_ID: MEMORY_CORRUPTION_ONE_BIT
OSNAME: Windows 10
FAILURE_ID_HASH: {e3faf315-c3d0-81db-819a-6c43d23c63a7}
ffffae5d`ff600000 ffffae5d`ff69b000 win32k (deferred)
ffffae5d`ffba0000 ffffae5d`ffe6c000 win32kbase (deferred)
ffffae5e`00ca0000 ffffae5e`01051000 win32kfull (deferred)
ffffae5e`01060000 ffffae5e`010a9000 cdd (deferred)
fffff804`1ebf0000 fffff804`1ee7f000 mcupdate_GenuineIntel (deferred)
fffff804`1ee80000 fffff804`1ee86000 hal (deferred)
fffff804`1ee90000 fffff804`1ee9b000 kd (deferred)
fffff804`1eea0000 fffff804`1eec8000 tm (deferred)
fffff804`1eed0000 fffff804`1ef3e000 CLFS (deferred)
fffff804`1ef40000 fffff804`1ef5a000 PSHED (deferred)
fffff804`1ef60000 fffff804`1ef6b000 BOOTVID (deferred)
fffff804`1ef70000 fffff804`1efde000 FLTMGR (deferred)
fffff804`1efe0000 fffff804`1efee000 cmimcext (deferred)
fffff804`21800000 fffff804`22846000 nt (pdb symbols) C:\ProgramData\Dbg\sym\ntkrnlmp.pdb\9F65CD18C2F36F88B2D0CE8A7BFE2BB71\ntkrnlmp.pdb
fffff804`24400000 fffff804`24518000 clipsp (deferred)
fffff804`24520000 fffff804`24549000 ksecdd (deferred)
fffff804`24550000 fffff804`245b3000 msrpc (deferred)
fffff804`245c0000 fffff804`245d1000 werkernel (deferred)
fffff804`245e0000 fffff804`245ec000 ntosext (deferred)
fffff804`245f0000 fffff804`246dc000 CI (deferred)
fffff804`246e0000 fffff804`2479b000 cng (deferred)
fffff804`247a0000 fffff804`24871000 Wdf01000 (deferred)
fffff804`24880000 fffff804`24893000 WDFLDR (deferred)
fffff804`248a0000 fffff804`248af000 SleepStudyHelper (deferred)
fffff804`248b0000 fffff804`248c1000 WppRecorder (deferred)
fffff804`248d0000 fffff804`248f6000 acpiex (deferred)
fffff804`24900000 fffff804`2491a000 SgrmAgent (deferred)
fffff804`24920000 fffff804`249ec000 ACPI (deferred)
fffff804`249f0000 fffff804`249fc000 WMILIB (deferred)
fffff804`24a00000 fffff804`24a0b000 msisadrv (deferred)
fffff804`24a10000 fffff804`24a88000 pci (deferred)
fffff804`24a90000 fffff804`24ad5000 tpm (deferred)
fffff804`24af0000 fffff804`24b5b000 intelpep (deferred)
fffff804`24b60000 fffff804`24b77000 WindowsTrustedRT (deferred)
fffff804`24b80000 fffff804`24b8b000 IntelTA (deferred)
fffff804`24b90000 fffff804`24b9b000 WindowsTrustedRTProxy (deferred)
fffff804`24ba0000 fffff804`24bb4000 pcw (deferred)
fffff804`24bc0000 fffff804`24bd5000 vdrvroot (deferred)
fffff804`24be0000 fffff804`24bf9000 CEA (deferred)
fffff804`24c00000 fffff804`24c30000 pdc (deferred)
fffff804`24c40000 fffff804`24c71000 partmgr (deferred)
fffff804`24c80000 fffff804`24d2b000 spaceport (deferred)
fffff804`24d30000 fffff804`24d49000 volmgr (deferred)
fffff804`24d50000 fffff804`24db3000 volmgrx (deferred)
fffff804`24dc0000 fffff804`24dde000 mountmgr (deferred)
fffff804`24de0000 fffff804`24e12000 storahci (deferred)
fffff804`24e20000 fffff804`24ed5000 storport (deferred)
fffff804`24ee0000 fffff804`24f0f000 stornvme (deferred)
fffff804`24f10000 fffff804`24f2c000 EhStorClass (deferred)
fffff804`24f30000 fffff804`24f4a000 fileinfo (deferred)
fffff804`24f50000 fffff804`24f90000 Wof (deferred)
fffff804`24fa0000 fffff804`25036000 WdFilter (deferred)
fffff804`25040000 fffff804`25317000 Ntfs (deferred)
fffff804`25320000 fffff804`2532d000 Fs_Rec (deferred)
fffff804`25330000 fffff804`254a0000 ndis (deferred)
fffff804`254b0000 fffff804`2554c000 NETIO (deferred)
fffff804`25550000 fffff804`25582000 ksecpkg (deferred)
fffff804`25590000 fffff804`2587d000 tcpip (deferred)
fffff804`25880000 fffff804`258ff000 fwpkclnt (deferred)
fffff804`25900000 fffff804`25930000 wfplwfs (deferred)
fffff804`25940000 fffff804`25a09000 fvevol (deferred)
fffff804`25a10000 fffff804`25a1b000 volume (deferred)
fffff804`25a20000 fffff804`25a8d000 volsnap (deferred)
fffff804`25a90000 fffff804`25ae0000 rdyboost (deferred)
fffff804`25af0000 fffff804`25b16000 mup (deferred)
fffff804`25b20000 fffff804`25b32000 iorate (deferred)
fffff804`25b60000 fffff804`25b7d000 disk (deferred)
fffff804`25b80000 fffff804`25bf2000 CLASSPNP (deferred)
fffff804`38220000 fffff804`38800000 RTKVHD64 (deferred)
fffff804`38810000 fffff804`38997000 HTTP (deferred)
fffff804`389a0000 fffff804`38a34000 mrxsmb (deferred)
fffff804`38a40000 fffff804`38a85000 mrxsmb20 (deferred)
fffff804`38a90000 fffff804`38ae6000 srvnet (deferred)
fffff804`38b30000 fffff804`38b4e000 crashdmp (deferred)
fffff804`38b50000 fffff804`38ba2000 mrxsmb10 (deferred)
fffff804`38bb0000 fffff804`38bd7000 Ndu (deferred)
fffff804`3e400000 fffff804`3e7aa000 dxgkrnl (deferred)
fffff804`3e7b0000 fffff804`3e7c8000 watchdog (deferred)
fffff804`3e7d0000 fffff804`3e7e6000 BasicDisplay (deferred)
fffff804`3e7f0000 fffff804`3e801000 BasicRender (deferred)
fffff804`3e810000 fffff804`3e82c000 Npfs (deferred)
fffff804`3e830000 fffff804`3e841000 Msfs (deferred)
fffff804`3e850000 fffff804`3e86e000 CimFS (deferred)
fffff804`3e870000 fffff804`3e892000 tdx (deferred)
fffff804`3e8a0000 fffff804`3e8b0000 TDI (deferred)
fffff804`3e8c0000 fffff804`3e91c000 netbt (deferred)
fffff804`3e920000 fffff804`3e934000 afunix (deferred)
fffff804`3e940000 fffff804`3e9e8000 afd (deferred)
fffff804`3e9f0000 fffff804`3ea0a000 vwififlt (deferred)
fffff804`3ea10000 fffff804`3ea3b000 pacer (deferred)
fffff804`3ea40000 fffff804`3ea54000 ndiscap (deferred)
fffff804`3ea60000 fffff804`3ea74000 netbios (deferred)
fffff804`3ea80000 fffff804`3eb21000 Vid (deferred)
fffff804`3eb30000 fffff804`3eb54000 winhvr (deferred)
fffff804`3eb60000 fffff804`3ebdb000 rdbss (deferred)
fffff804`3ebe0000 fffff804`3ebf2000 nsiproxy (deferred)
fffff804`3ec00000 fffff804`3ec0e000 npsvctrig (deferred)
fffff804`3ec10000 fffff804`3ec20000 mssmbios (deferred)
fffff804`3ec30000 fffff804`3ec3a000 gpuenergydrv (deferred)
fffff804`3ec40000 fffff804`3ec6d000 dfsc (deferred)
fffff804`3ec90000 fffff804`3ecfd000 fastfat (deferred)
fffff804`3ed00000 fffff804`3ed17000 bam (deferred)
fffff804`3ed20000 fffff804`3ed72000 ahcache (deferred)
fffff804`3ed80000 fffff804`3ed92000 CompositeBus (deferred)
fffff804`3eda0000 fffff804`3edad000 kdnic (deferred)
fffff804`3edb0000 fffff804`3edc5000 umbus (deferred)
fffff804`3edf0000 fffff804`3ee0d000 dump_dumpfve (deferred)
fffff804`3ee10000 fffff804`3eef0000 dxgmms2 (deferred)
fffff804`3ef00000 fffff804`3ef1b000 monitor (deferred)
fffff804`3ef20000 fffff804`3ef4d000 luafv (deferred)
fffff804`3ef50000 fffff804`3ef87000 wcifs (deferred)
fffff804`3ef90000 fffff804`3f012000 cldflt (deferred)
fffff804`3f020000 fffff804`3f03a000 storqosflt (deferred)
fffff804`3f040000 fffff804`3f068000 bindflt (deferred)
fffff804`3f070000 fffff804`3f088000 lltdio (deferred)
fffff804`3f090000 fffff804`3f0a8000 mslldp (deferred)
fffff804`3f0b0000 fffff804`3f0cb000 rspndr (deferred)
fffff804`3f0d0000 fffff804`3f0ed000 wanarp (deferred)
fffff804`3f0f0000 fffff804`3f146000 msquic (deferred)
fffff804`3f150000 fffff804`3f162000 condrv (deferred)
fffff804`3f170000 fffff804`3f195000 bowser (deferred)
fffff804`3f1a0000 fffff804`3f1ba000 mpsdrv (deferred)
fffff804`3f1c0000 fffff804`3f1d4000 mmcss (deferred)
fffff804`3f1e0000 fffff804`40d35000 vgk (deferred)
fffff804`40d40000 fffff804`40d70000 cdrom (deferred)
fffff804`40d80000 fffff804`40d95000 filecrypt (deferred)
fffff804`40da0000 fffff804`40dae000 tbs (deferred)
fffff804`40db0000 fffff804`40dc5000 UCPD (deferred)
fffff804`40dd0000 fffff804`40dda000 Null (deferred)
fffff804`40de0000 fffff804`40dea000 Beep (deferred)
fffff804`50000000 fffff804`50068000 portcls (deferred)
fffff804`50070000 fffff804`50091000 drmk (deferred)
fffff804`500a0000 fffff804`50118000 ks (deferred)
fffff804`50120000 fffff804`501bd000 USBXHCI (deferred)
fffff804`501c0000 fffff804`50204000 ucx01000 (deferred)
fffff804`50210000 fffff804`5025f000 TeeDriverW10x64 (deferred)
fffff804`50260000 fffff804`5038a000 rt640x64 (deferred)
fffff804`50390000 fffff804`503ac000 serial (deferred)
fffff804`503b0000 fffff804`503bf000 serenum (deferred)
fffff804`503c0000 fffff804`503cc000 acpitime (deferred)
fffff804`503d0000 fffff804`50411000 intelppm (deferred)
fffff804`50420000 fffff804`5042b000 acpipagr (deferred)
fffff804`50430000 fffff804`5043c000 wmiacpi (deferred)
fffff804`50440000 fffff804`50457000 HidEventFilter (deferred)
fffff804`50460000 fffff804`5046b000 mshidkmdf (deferred)
fffff804`50470000 fffff804`504b1000 HIDCLASS (deferred)
fffff804`504c0000 fffff804`504d3000 HIDPARSE (deferred)
fffff804`504e0000 fffff804`504ee000 UEFI (deferred)
fffff804`504f0000 fffff804`504fd000 NdisVirtualBus (deferred)
fffff804`50500000 fffff804`50529000 RZTHXSpatial (deferred)
fffff804`50530000 fffff804`50541000 ksthunk (deferred)
fffff804`50550000 fffff804`5055c000 swenum (deferred)
fffff804`50560000 fffff804`5056e000 rdpbus (deferred)
fffff804`50570000 fffff804`50581000 kbdhid (deferred)
fffff804`50590000 fffff804`505a4000 kbdclass (deferred)
fffff804`505b0000 fffff804`505c2000 buttonconverter (deferred)
fffff804`505d0000 fffff804`50673000 UsbHub3 (deferred)
fffff804`50680000 fffff804`5068e000 USBD (deferred)
fffff804`50690000 fffff804`506ae000 nvhda64v (deferred)
fffff804`506b0000 fffff804`506e4000 usbccgp (deferred)
fffff804`506f0000 fffff804`50701000 RzDev_00b8 (deferred)
fffff804`50710000 fffff804`50722000 hidusb (deferred)
fffff804`50730000 fffff804`50741000 RzDev_02a1 (deferred)
fffff804`50750000 fffff804`50760000 mouhid (deferred)
fffff804`50770000 fffff804`50783000 mouclass (deferred)
fffff804`50790000 fffff804`507a0000 RzCommon (deferred)
fffff804`507b0000 fffff804`507e8000 usbaudio (deferred)
fffff804`50800000 fffff804`5080f000 dump_dumpstorport (deferred)
fffff804`50840000 fffff804`5086f000 dump_stornvme (deferred)
fffff804`50870000 fffff804`541c3000 nvlddmkm (deferred)
fffff804`541d0000 fffff804`541f5000 HDAudBus (deferred)
fffff804`8c600000 fffff804`8c621000 raspptp (deferred)
fffff804`8c630000 fffff804`8c64c000 raspppoe (deferred)
fffff804`8c650000 fffff804`8c65f000 gdrv3 (deferred)
fffff804`8c660000 fffff804`8c66f000 ndistapi (deferred)
fffff804`8c670000 fffff804`8c6aa000 ndiswan (deferred)
fffff804`8c6b0000 fffff804`8c6cd000 WdNisDrv (deferred)
fffff804`8c6d0000 fffff804`8c6e4000 qwavedrv (deferred)
fffff804`8cb80000 fffff804`8cc56000 peauth (deferred)
fffff804`8cc60000 fffff804`8cc75000 tcpipreg (deferred)
fffff804`8cc80000 fffff804`8cc9d000 rassstp (deferred)
fffff804`8cca0000 fffff804`8cd68000 srv2 (deferred)
fffff804`8cd70000 fffff804`8cd8d000 NDProxy (deferred)
fffff804`8cd90000 fffff804`8cdb8000 AgileVpn (deferred)
fffff804`8cdc0000 fffff804`8cde1000 rasl2tp (deferred)
Unloaded modules:
fffff804`38b60000 fffff804`38b70000 dump_storpor
fffff804`38ba0000 fffff804`38bd0000 dump_stornvm
fffff804`38200000 fffff804`3821e000 dump_dumpfve
fffff804`3ec70000 fffff804`3ec8c000 dam.sys
fffff804`24ae0000 fffff804`24aec000 WdBoot.sys
fffff804`25b40000 fffff804`25b51000 hwpolicy.sys
00 fffff804`21aa04ca : 00000000`0000001a 00000000`00041792 ffffed81`3aae5480 00010000`00000000 : nt!KeBugCheckEx
01 fffff804`21a38816 : 00000000`00000000 00000000`00000000 00000000`00006b2a ffffed81`3aae5480 : nt!MiDeleteVa+0x153a
02 fffff804`21a3892b : ffffedf6`00000000 ffff9c82`30772700 fffff40f`00000000 fffff40f`f794f5c0 : nt!MiWalkPageTablesRecursively+0x776
03 fffff804`21a3892b : ffffedf6`00000000 ffff9c82`30772700 fffff40f`00000001 fffff40f`f794f5d0 : nt!MiWalkPageTablesRecursively+0x88b
04 fffff804`21a3892b : ffffedf6`fb604000 ffff9c82`30772700 fffff40f`00000002 fffff40f`f794f5e0 : nt!MiWalkPageTablesRecursively+0x88b
05 fffff804`21a3592b : 00000000`c0000016 ffff9c82`30772700 00000000`00000003 fffff40f`f794f5f0 : nt!MiWalkPageTablesRecursively+0x88b
06 fffff804`21a9ed61 : fffff40f`f794f570 ffff9c82`00000000 00000000`00000002 00000000`00000000 : nt!MiWalkPageTables+0x36b
07 fffff804`21a48a68 : 00000000`00000001 ffff9c82`00000000 ffff9c82`30772550 ffff9c82`30e04080 : nt!MiDeletePagablePteRange+0x4f1
08 fffff804`21e4f469 : fffff40f`00000000 00000000`00000000 00004f44`00000000 ffff9c82`30772080 : nt!MiDeleteVad+0x378
09 fffff804`21e4f242 : ffff9c82`30f2d0a0 00000000`00000000 ffff9c82`30772080 00000000`00000000 : nt!MiUnmapVad+0x49
0a fffff804`21e4f0b9 : 000000d5`a2dff428 7fffffff`00000004 00004f44`00290280 00000000`00000000 : nt!MiUnmapViewOfSection+0x152
0b fffff804`21c12305 : ffff9c82`30e04080 00000275`55fa0000 fffff40f`f794fac0 ffff9c82`30772080 : nt!NtUnmapViewOfSectionEx+0x99
0c 00007ff9`8e630f14 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x25
0d 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ff9`8e630f14
BiosVersion = F4d
SystemVersion = -CF
[DMI Version - 0]
BIOS Version F4d
07: - PCI Supported
19: - EDD Supported
Version -CF
Family H610 MB
Product H610M H V2
Version x.x
Asset Tag
Feature Flags 09h
00: - Motherboard
03: - Replaceable
Serial Number
Asset Tag Number
Bootup State Safe
Thermal State Safe
OEM Defined 0
Height 0U
Number of Strings 1
1 Default string
Total Width 64 bits
Data Width 64 bits
Size 16384MB
Device Set [None]
Bank Locator BANK 0
Speed 5600MHz
Serial Number
Asset Tag Number
Attributes 1
Extended Size 0
Memory Technology 3
Firmware Version 0
Module Product Id 0
Non-Volatile Size 0
Volatile Size 0
Cache Size 0
Logical Size 0
Extended Speed 0
Total Width 64 bits
Data Width 64 bits
Size 16384MB
Device Set [None]
Bank Locator BANK 0
Speed 5600MHz
Serial Number
Asset Tag Number
Attributes 1
Extended Size 0
Memory Technology 3
Firmware Version 0
Module Product Id 0
Non-Volatile Size 0
Volatile Size 0
Cache Size 0
Logical Size 0
Extended Speed 0
Partition Width 02
Cache Speed 0ns
Cache Speed 0ns
Cache Speed 0ns
Associativity Other
Cache Speed 0ns
Associativity Other
Cache Speed 0ns
Cache Speed 0ns
Cache Speed 0ns
Cache Speed 0ns
Associativity Other
Max Speed 4700MHz
Serial Number
Asset Tag Number
Core Count 10
Core Enabled 10
Thread Count 16
0x 3: Multi-Core
Core Count 2 10
Core Enabled 2 10
Thread Count 2 16
THREAD ffff9c8230e04080 Cid 2d80.1d70 Teb: 000000d5a252d000 Win32Thread: 0000000000000000 RUNNING on processor 2
Impersonation token: ffffb00bef47a060 (Level Impersonation)
GetUlongFromAddress: unable to read from fffff8042241159c
Owning Process ffff9c8230772080 Image: opera.exe
Wait Start TickCount 282283
Context Switch Count 13 IdealProcessor: 2
Win32 Start Address 0x00007ff6fe85ea70
Stack Init fffff40ff794fbd0 Current fffff40ff794e9a0
Base fffff40ff7950000 Limit fffff40ff7949000 Call 0000000000000000
fffff40f`f794fa40 00007ff9`8e630f14 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x25 (TrapFrame @ fffff40f`f794fa40)
Arguments:
Debugging Details:
Value: 608
Value: 14622
Value: 18
Value: 0
Value: 22
Value: 265
Value: 9322
Value: 81
Value: 0xa
Value: 0xa
Key : Failure.Hash
Key : WER.OS.Branch
Value: vb_release
Value: 10.0.19041.1
BUGCHECK_CODE: a
BUGCHECK_P1: 60
BUGCHECK_P2: 2
BUGCHECK_P3: 0
0000000000000060
BLACKBOXWINLOGON: 1
STACK_TEXT:
MODULE_NAME: nt
OSNAME: Windows 10
PnpProblemCode : 24
PnpVetoType : 0
VetoString :
Unloaded modules:
BiosVersion = F4d
SystemVersion = -CF
[DMI Version - 0]
BIOS Version F4d
07: - PCI Supported
19: - EDD Supported
Version -CF
Family H610 MB
Product H610M H V2
Version x.x
Asset Tag
Feature Flags 09h
00: - Motherboard
03: - Replaceable
Serial Number
Asset Tag Number
Bootup State Safe
Thermal State Safe
OEM Defined 0
Height 0U
Number of Strings 1
1 Default string
Total Width 64 bits
Data Width 64 bits
Size 16384MB
Device Set [None]
Bank Locator BANK 0
Speed 5600MHz
Serial Number
Asset Tag Number
Attributes 1
Extended Size 0
Memory Technology 3
Firmware Version 0
Module Product Id 0
Non-Volatile Size 0
Volatile Size 0
Cache Size 0
Logical Size 0
Extended Speed 0
Total Width 64 bits
Data Width 64 bits
Size 16384MB
Device Set [None]
Bank Locator BANK 0
Speed 5600MHz
Serial Number
Asset Tag Number
Attributes 1
Extended Size 0
Memory Technology 3
Firmware Version 0
Module Product Id 0
Non-Volatile Size 0
Volatile Size 0
Cache Size 0
Logical Size 0
Extended Speed 0
Partition Width 02
Cache Speed 0ns
Cache Speed 0ns
Cache Speed 0ns
Associativity Other
Cache Speed 0ns
Associativity Other
Cache Speed 0ns
Cache Speed 0ns
Cache Speed 0ns
Cache Speed 0ns
Associativity Other
Max Speed 4700MHz
Serial Number
Asset Tag Number
Core Count 10
Core Enabled 10
Thread Count 16
0x 3: Multi-Core
Core Count 2 10
Core Enabled 2 10
Thread Count 2 16
Not impersonating
Arguments:
Debugging Details:
Value: 499
Value: 3759
Value: 14
Value: 0
Value: 18
Value: 139
Value: 8711
Value: 81
Value: 0x1a
Value: 0x1a
Key : Failure.Hash
Value: 0
Key : WER.OS.Branch
Value: vb_release
Value: 10.0.19041.1
BUGCHECK_CODE: 1a
BUGCHECK_P1: 41792
BUGCHECK_P4: 0
BLACKBOXWINLOGON: 1
STACK_TEXT:
OSNAME: Windows 10
Unloaded modules:
BiosVersion = F4d
SystemVersion = -CF
[DMI Version - 0]
BIOS Version F4d
07: - PCI Supported
19: - EDD Supported
Version -CF
Family H610 MB
Product H610M H V2
Version x.x
Asset Tag
Feature Flags 09h
00: - Motherboard
03: - Replaceable
Serial Number
Asset Tag Number
Bootup State Safe
Thermal State Safe
OEM Defined 0
Height 0U
Number of Strings 1
1 Default string
Total Width 64 bits
Data Width 64 bits
Size 16384MB
Device Set [None]
Bank Locator BANK 0
Speed 5600MHz
Serial Number
Asset Tag Number
Attributes 1
Extended Size 0
Memory Technology 3
Firmware Version 0
Module Product Id 0
Non-Volatile Size 0
Volatile Size 0
Cache Size 0
Logical Size 0
Extended Speed 0
Total Width 64 bits
Data Width 64 bits
Size 16384MB
Device Set [None]
Bank Locator BANK 0
Speed 5600MHz
Serial Number
Asset Tag Number
Attributes 1
Extended Size 0
Memory Technology 3
Firmware Version 0
Module Product Id 0
Non-Volatile Size 0
Volatile Size 0
Cache Size 0
Logical Size 0
Extended Speed 0
Partition Width 02
Cache Speed 0ns
Cache Speed 0ns
Cache Speed 0ns
Associativity Other
Cache Speed 0ns
Associativity Other
Cache Speed 0ns
Cache Speed 0ns
Cache Speed 0ns
Cache Speed 0ns
Associativity Other
Max Speed 4700MHz
Serial Number
Asset Tag Number
Core Count 10
Core Enabled 10
Thread Count 16
0x 3: Multi-Core
Core Count 2 10
Core Enabled 2 10
Thread Count 2 16
Tamamdır teşekkürler sorun bir arkadaşıma ait ileteceğim ona.1) BIOS'unuzu güncelleyin:
2) Gigabyte App Center'ı kaldırın.
Sorun devam ederse RAM'lerinizi MemTest86 ile test edin ve yeni dumpları paylaşın.
MemTest86
MEMTEST86, x86 ve ARM bilgisayarlar için orijinal, ücretsiz, bağımsız bellek test yazılımıdır. Bilgisayarınızdaki RAM'i hatalara karşı test etmek için USB flash sürücülerden önyüklenebilir. 20'den fazla yıldır geliştirilmekte olan algoritmaları...techolay.net
Sonucu paylaşırsanız sevinirim, iyi Sosyaller dilerim.
Kod:******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* IRQL_NOT_LESS_OR_EQUAL (a) An attempt was made to access a pageable (or completely invalid) address at an interrupt request level (IRQL) that is too high. This is usually caused by drivers using improper addresses. If a kernel debugger is available get the stack backtrace. Arguments: Arg1: 0000000000000060, memory referenced Arg2: 0000000000000002, IRQL Arg3: 0000000000000000, bitfield : bit 0 : value 0 = read operation, 1 = write operation bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status) Arg4: fffff80128f48dc6, address which referenced memory Debugging Details: ------------------ KEY_VALUES_STRING: 1 Key : Analysis.CPU.mSec Value: 608 Key : Analysis.Elapsed.mSec Value: 14622 Key : Analysis.IO.Other.Mb Value: 18 Key : Analysis.IO.Read.Mb Value: 0 Key : Analysis.IO.Write.Mb Value: 22 Key : Analysis.Init.CPU.mSec Value: 265 Key : Analysis.Init.Elapsed.mSec Value: 9322 Key : Analysis.Memory.CommitPeak.Mb Value: 81 Key : Bugcheck.Code.LegacyAPI Value: 0xa Key : Bugcheck.Code.TargetModel Value: 0xa Key : Failure.Bucket Value: AV_nt!MiMakeProtoPrivate Key : Failure.Hash Value: {79ccbbf1-a05d-4c4c-d95f-1ef76ba669b9} Key : WER.OS.Branch Value: vb_release Key : WER.OS.Version Value: 10.0.19041.1 BUGCHECK_CODE: a BUGCHECK_P1: 60 BUGCHECK_P2: 2 BUGCHECK_P3: 0 BUGCHECK_P4: fffff80128f48dc6 FILE_IN_CAB: 091724-6500-01.dmp FAULTING_THREAD: ffffab8ffda0f080 READ_ADDRESS: fffff801296fb390: Unable to get MiVisibleState Unable to get NonPagedPoolStart Unable to get NonPagedPoolEnd Unable to get PagedPoolStart Unable to get PagedPoolEnd unable to get nt!MmSpecialPagesInUse 0000000000000060 BLACKBOXBSD: 1 (!blackboxbsd) BLACKBOXNTFS: 1 (!blackboxntfs) BLACKBOXPNP: 1 (!blackboxpnp) BLACKBOXWINLOGON: 1 CUSTOMER_CRASH_COUNT: 1 PROCESS_NAME: Discord.exe TRAP_FRAME: ffffd7026867f170 -- (.trap 0xffffd7026867f170) NOTE: The trap frame does not contain all registers. Some register values may be zeroed or incorrect. rax=ffffab8ffc74dd20 rbx=0000000000000000 rcx=0000000000000000 rdx=0000000000000000 rsi=0000000000000000 rdi=0000000000000000 rip=fffff80128f48dc6 rsp=ffffd7026867f300 rbp=ffffd7026867f450 r8=ffffef810a85f340 r9=ffffab8ffc74d700 r10=ffffeff7fbfdffff r11=ffffeff7c0000000 r12=0000000000000000 r13=0000000000000000 r14=0000000000000000 r15=0000000000000000 iopl=0 nv up ei pl zr na po nc nt!MiMakeProtoPrivate+0xb2: fffff801`28f48dc6 48394a60 cmp qword ptr [rdx+60h],rcx ds:00000000`00000060=???????????????? Resetting default scope STACK_TEXT: ffffd702`6867f028 fffff801`28e12ba9 : 00000000`0000000a 00000000`00000060 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx ffffd702`6867f030 fffff801`28e0e578 : ffffd702`6867f350 fffff801`28cc28c5 ffffab8f`fc74d700 ffffab8f`fc74d700 : nt!KiBugCheckDispatch+0x69 ffffd702`6867f170 fffff801`28f48dc6 : ffffd702`6867f4f8 ffffef81`0a85f200 ffffef81`0a85f3f8 ffffab8f`fc74d700 : nt!KiPageFault+0x478 ffffd702`6867f300 fffff801`28cc1966 : ffffec00`03000000 ffffd702`6867f450 00000001`00000001 ffffd702`6867f300 : nt!MiMakeProtoPrivate+0xb2 ffffd702`6867f350 fffff801`29027a1b : ffffd702`6867f730 00000000`00000004 00000215`0be7ffff ffffd702`6867f860 : nt!MiProtectPrivateMemory+0x576 ffffd702`6867f500 fffff801`290261c9 : ffffab8f`fc74d080 ffffab8f`fc74d080 ffffd702`6867f6d8 ffffd702`6867f6d0 : nt!MmProtectVirtualMemory+0x42b ffffd702`6867f630 fffff801`29026c3f : ffffab8f`00000000 fffff801`00000000 00000000`00000000 00000000`00000001 : nt!MiAllocateVirtualMemory+0x5e9 ffffd702`6867f7b0 fffff801`29026a61 : ffffffff`ffffffff ffffab8f`fda0f080 000000d6`23dfe838 ffffab8f`00001000 : nt!MmAllocateVirtualMemory+0x1cf ffffd702`6867f960 fffff801`28e12305 : 00000000`00000000 00000000`00000000 00000000`00000000 ffffab8f`fd015b60 : nt!NtAllocateVirtualMemoryEx+0x51 ffffd702`6867f9d0 00007ffa`3d24e414 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x25 000000d6`23dfe818 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ffa`3d24e414 SYMBOL_NAME: nt!MiMakeProtoPrivate+b2 MODULE_NAME: nt IMAGE_VERSION: 10.0.19041.4894 STACK_COMMAND: .process /r /p 0xffffab8ffc74d080; .thread 0xffffab8ffda0f080 ; kb IMAGE_NAME: ntkrnlmp.exe BUCKET_ID_FUNC_OFFSET: b2 FAILURE_BUCKET_ID: AV_nt!MiMakeProtoPrivate OS_VERSION: 10.0.19041.1 BUILDLAB_STR: vb_release OSPLATFORM_TYPE: x64 OSNAME: Windows 10 FAILURE_ID_HASH: {79ccbbf1-a05d-4c4c-d95f-1ef76ba669b9} Followup: MachineOwner --------- PnpActivityId : {00000000-0000-0000-0000-000000000000} PnpActivityTime : 133710551399626688 PnpEventInformation: 3 PnpEventInProgress : 0 PnpProblemCode : 24 PnpVetoType : 0 DeviceId : SWD\MMDEVAPI\{0.0.1.00000000}.{0524ae5e-d243-4c1e-b1b1-e241c31abc29} VetoString : start end module name ffffa6d1`b4400000 ffffa6d1`b46cc000 win32kbase (deferred) ffffa6d1`b48f0000 ffffa6d1`b498b000 win32k (deferred) ffffa6d1`b5510000 ffffa6d1`b58c1000 win32kfull (deferred) ffffa6d1`b58d0000 ffffa6d1`b5919000 cdd (deferred) fffff801`26860000 fffff801`26aef000 mcupdate_GenuineIntel (deferred) fffff801`26af0000 fffff801`26af6000 hal (deferred) fffff801`26b00000 fffff801`26b0b000 kd (deferred) fffff801`26b10000 fffff801`26b38000 tm (deferred) fffff801`26b40000 fffff801`26bae000 CLFS (deferred) fffff801`26bb0000 fffff801`26bca000 PSHED (deferred) fffff801`26bd0000 fffff801`26bdb000 BOOTVID (deferred) fffff801`26be0000 fffff801`26c4e000 FLTMGR (deferred) fffff801`26c50000 fffff801`26c5e000 cmimcext (deferred) fffff801`28a00000 fffff801`29a46000 nt (pdb symbols) C:\ProgramData\Dbg\sym\ntkrnlmp.pdb\9F65CD18C2F36F88B2D0CE8A7BFE2BB71\ntkrnlmp.pdb fffff801`2c200000 fffff801`2c318000 clipsp (deferred) fffff801`2c320000 fffff801`2c349000 ksecdd (deferred) fffff801`2c350000 fffff801`2c3b3000 msrpc (deferred) fffff801`2c3c0000 fffff801`2c3d1000 werkernel (deferred) fffff801`2c3e0000 fffff801`2c3ec000 ntosext (deferred) fffff801`2c3f0000 fffff801`2c4dc000 CI (deferred) fffff801`2c4e0000 fffff801`2c59b000 cng (deferred) fffff801`2c5a0000 fffff801`2c671000 Wdf01000 (deferred) fffff801`2c680000 fffff801`2c693000 WDFLDR (deferred) fffff801`2c6a0000 fffff801`2c6af000 SleepStudyHelper (deferred) fffff801`2c6b0000 fffff801`2c6c1000 WppRecorder (deferred) fffff801`2c6d0000 fffff801`2c6f6000 acpiex (deferred) fffff801`2c700000 fffff801`2c71a000 SgrmAgent (deferred) fffff801`2c720000 fffff801`2c7ec000 ACPI (deferred) fffff801`2c7f0000 fffff801`2c7fc000 WMILIB (deferred) fffff801`2c800000 fffff801`2c80b000 msisadrv (deferred) fffff801`2c810000 fffff801`2c888000 pci (deferred) fffff801`2c890000 fffff801`2c8d5000 tpm (deferred) fffff801`2c900000 fffff801`2c96b000 intelpep (deferred) fffff801`2c970000 fffff801`2c987000 WindowsTrustedRT (deferred) fffff801`2c990000 fffff801`2c99b000 IntelTA (deferred) fffff801`2c9a0000 fffff801`2c9ab000 WindowsTrustedRTProxy (deferred) fffff801`2c9b0000 fffff801`2c9c4000 pcw (deferred) fffff801`2c9d0000 fffff801`2c9e5000 vdrvroot (deferred) fffff801`2c9f0000 fffff801`2c9fd000 Fs_Rec (deferred) fffff801`2ca00000 fffff801`2ca30000 pdc (deferred) fffff801`2ca40000 fffff801`2ca59000 CEA (deferred) fffff801`2ca60000 fffff801`2ca91000 partmgr (deferred) fffff801`2caa0000 fffff801`2cb4b000 spaceport (deferred) fffff801`2cb50000 fffff801`2cb69000 volmgr (deferred) fffff801`2cb70000 fffff801`2cbd3000 volmgrx (deferred) fffff801`2cbe0000 fffff801`2cbfe000 mountmgr (deferred) fffff801`2cc00000 fffff801`2cc32000 storahci (deferred) fffff801`2cc40000 fffff801`2ccf5000 storport (deferred) fffff801`2cd00000 fffff801`2cd2f000 stornvme (deferred) fffff801`2cd30000 fffff801`2cd4c000 EhStorClass (deferred) fffff801`2cd50000 fffff801`2cd6a000 fileinfo (deferred) fffff801`2cd70000 fffff801`2cdb0000 Wof (deferred) fffff801`2ce20000 fffff801`2d0f7000 Ntfs (deferred) fffff801`2d100000 fffff801`2d270000 ndis (deferred) fffff801`2d280000 fffff801`2d31c000 NETIO (deferred) fffff801`2d320000 fffff801`2d352000 ksecpkg (deferred) fffff801`2d360000 fffff801`2d64d000 tcpip (deferred) fffff801`2d650000 fffff801`2d6cf000 fwpkclnt (deferred) fffff801`2d6d0000 fffff801`2d700000 wfplwfs (deferred) fffff801`2d710000 fffff801`2d7d9000 fvevol (deferred) fffff801`2d7e0000 fffff801`2d7eb000 volume (deferred) fffff801`2d7f0000 fffff801`2d85d000 volsnap (deferred) fffff801`2d860000 fffff801`2d8b0000 rdyboost (deferred) fffff801`2d8c0000 fffff801`2d8e6000 mup (deferred) fffff801`2d8f0000 fffff801`2d902000 iorate (deferred) fffff801`2d930000 fffff801`2d94d000 disk (deferred) fffff801`2d950000 fffff801`2d9c2000 CLASSPNP (deferred) fffff801`40020000 fffff801`40050000 cdrom (deferred) fffff801`40060000 fffff801`40075000 filecrypt (deferred) fffff801`40080000 fffff801`4008e000 tbs (deferred) fffff801`40090000 fffff801`400a5000 UCPD (deferred) fffff801`400b0000 fffff801`400ba000 Null (deferred) fffff801`400c0000 fffff801`400ca000 Beep (deferred) fffff801`400d0000 fffff801`4047a000 dxgkrnl (deferred) fffff801`40480000 fffff801`40498000 watchdog (deferred) fffff801`404a0000 fffff801`404b6000 BasicDisplay (deferred) fffff801`404c0000 fffff801`404d1000 BasicRender (deferred) fffff801`404e0000 fffff801`404fc000 Npfs (deferred) fffff801`40500000 fffff801`40511000 Msfs (deferred) fffff801`40520000 fffff801`4053e000 CimFS (deferred) fffff801`40540000 fffff801`40562000 tdx (deferred) fffff801`40570000 fffff801`40580000 TDI (deferred) fffff801`40590000 fffff801`405ec000 netbt (deferred) fffff801`405f0000 fffff801`40604000 afunix (deferred) fffff801`40610000 fffff801`406b8000 afd (deferred) fffff801`406c0000 fffff801`406da000 vwififlt (deferred) fffff801`406e0000 fffff801`4070b000 pacer (deferred) fffff801`40710000 fffff801`40724000 ndiscap (deferred) fffff801`40730000 fffff801`40744000 netbios (deferred) fffff801`40750000 fffff801`407f1000 Vid (deferred) fffff801`40800000 fffff801`40824000 winhvr (deferred) fffff801`40830000 fffff801`408ab000 rdbss (deferred) fffff801`408b0000 fffff801`408c2000 nsiproxy (deferred) fffff801`408d0000 fffff801`408de000 npsvctrig (deferred) fffff801`408e0000 fffff801`408f0000 mssmbios (deferred) fffff801`40900000 fffff801`4090a000 gpuenergydrv (deferred) fffff801`40910000 fffff801`4093d000 dfsc (deferred) fffff801`40960000 fffff801`409cd000 fastfat (deferred) fffff801`409d0000 fffff801`409e7000 bam (deferred) fffff801`409f0000 fffff801`40a42000 ahcache (deferred) fffff801`40a50000 fffff801`40a62000 CompositeBus (deferred) fffff801`40a70000 fffff801`40a7d000 kdnic (deferred) fffff801`40a80000 fffff801`40a95000 umbus (deferred) fffff801`40aa0000 fffff801`40af6000 srvnet (deferred) fffff801`40b40000 fffff801`40b5e000 crashdmp (deferred) fffff801`40b60000 fffff801`40bb2000 mrxsmb10 (deferred) fffff801`50200000 fffff801`5029d000 USBXHCI (deferred) fffff801`502a0000 fffff801`502e4000 ucx01000 (deferred) fffff801`502f0000 fffff801`5033f000 TeeDriverW10x64 (deferred) fffff801`50340000 fffff801`5046a000 rt640x64 (deferred) fffff801`50470000 fffff801`5048c000 serial (deferred) fffff801`50490000 fffff801`5049f000 serenum (deferred) fffff801`504a0000 fffff801`504ac000 acpitime (deferred) fffff801`504b0000 fffff801`504f1000 intelppm (deferred) fffff801`50500000 fffff801`5050b000 acpipagr (deferred) fffff801`50510000 fffff801`5051c000 wmiacpi (deferred) fffff801`50520000 fffff801`50537000 HidEventFilter (deferred) fffff801`50540000 fffff801`5054b000 mshidkmdf (deferred) fffff801`50550000 fffff801`50591000 HIDCLASS (deferred) fffff801`505a0000 fffff801`505b3000 HIDPARSE (deferred) fffff801`505c0000 fffff801`505ce000 UEFI (deferred) fffff801`505d0000 fffff801`505dd000 NdisVirtualBus (deferred) fffff801`505e0000 fffff801`505ec000 swenum (deferred) fffff801`505f0000 fffff801`505fe000 rdpbus (deferred) fffff801`50600000 fffff801`50611000 kbdhid (deferred) fffff801`50620000 fffff801`50634000 kbdclass (deferred) fffff801`50640000 fffff801`50652000 buttonconverter (deferred) fffff801`50660000 fffff801`50703000 UsbHub3 (deferred) fffff801`50710000 fffff801`5071e000 USBD (deferred) fffff801`50720000 fffff801`5073e000 nvhda64v (deferred) fffff801`50740000 fffff801`50751000 ksthunk (deferred) fffff801`50760000 fffff801`50840000 dxgmms2 (deferred) fffff801`50850000 fffff801`50887000 wcifs (deferred) fffff801`50890000 fffff801`50912000 cldflt (deferred) fffff801`50920000 fffff801`50948000 bindflt (deferred) fffff801`50950000 fffff801`50968000 lltdio (deferred) fffff801`50970000 fffff801`50988000 mslldp (deferred) fffff801`50990000 fffff801`509ab000 rspndr (deferred) fffff801`509b0000 fffff801`509cd000 wanarp (deferred) fffff801`509d0000 fffff801`50a26000 msquic (deferred) fffff801`50a30000 fffff801`50bb7000 HTTP (deferred) fffff801`50bc0000 fffff801`50be5000 bowser (deferred) fffff801`50bf0000 fffff801`50c0a000 mpsdrv (deferred) fffff801`50c10000 fffff801`50ca4000 mrxsmb (deferred) fffff801`50cb0000 fffff801`50cf5000 mrxsmb20 (deferred) fffff801`50d00000 fffff801`54653000 nvlddmkm (deferred) fffff801`54660000 fffff801`54685000 HDAudBus (deferred) fffff801`54690000 fffff801`546f8000 portcls (deferred) fffff801`54700000 fffff801`54721000 drmk (deferred) fffff801`54730000 fffff801`547a8000 ks (deferred) fffff801`547b0000 fffff801`547d7000 Ndu (deferred) fffff801`5b000000 fffff801`5b034000 usbccgp (deferred) fffff801`5b080000 fffff801`5b093000 mouclass (deferred) fffff801`5b0a0000 fffff801`5b0d8000 usbaudio (deferred) fffff801`5b0f0000 fffff801`5b0ff000 dump_dumpstorport (deferred) fffff801`5b130000 fffff801`5b15f000 dump_stornvme (deferred) fffff801`5b180000 fffff801`5b19d000 dump_dumpfve (deferred) fffff801`5b1a0000 fffff801`5b1bb000 monitor (deferred) fffff801`5b1c0000 fffff801`5b1ed000 luafv (deferred) fffff801`5b1f0000 fffff801`5b7d0000 RTKVHD64 (deferred) fffff801`5b7e0000 fffff801`5b7fa000 storqosflt (deferred) fffff801`83600000 fffff801`8361c000 raspppoe (deferred) fffff801`83620000 fffff801`8362f000 ndistapi (deferred) fffff801`83630000 fffff801`8366a000 ndiswan (deferred) fffff801`83680000 fffff801`83692000 condrv (deferred) fffff801`83710000 fffff801`837a6000 WdFilter (deferred) fffff801`837b0000 fffff801`837cd000 WdNisDrv (deferred) fffff801`83890000 fffff801`838a1000 RzDev_00b8 (deferred) fffff801`838b0000 fffff801`838c2000 hidusb (deferred) fffff801`838d0000 fffff801`838e0000 mouhid (deferred) fffff801`838f0000 fffff801`83901000 RzDev_02a1 (deferred) fffff801`83910000 fffff801`83920000 RzCommon (deferred) fffff801`83930000 fffff801`83959000 RZTHXSpatial (deferred) fffff801`83960000 fffff801`8396e000 gdrv3 (deferred) fffff801`84330000 fffff801`84406000 peauth (deferred) fffff801`84410000 fffff801`84424000 mmcss (deferred) fffff801`84430000 fffff801`84445000 tcpipreg (deferred) fffff801`84450000 fffff801`84518000 srv2 (deferred) fffff801`84520000 fffff801`8453d000 rassstp (deferred) fffff801`84540000 fffff801`8455d000 NDProxy (deferred) fffff801`84560000 fffff801`84588000 AgileVpn (deferred) fffff801`84590000 fffff801`845b1000 rasl2tp (deferred) fffff801`845c0000 fffff801`845e1000 raspptp (deferred) Unloaded modules: fffff801`83670000 fffff801`83680000 gdrv3.sys fffff801`83830000 fffff801`83843000 hidusb.sys fffff801`83810000 fffff801`83822000 RzDev_02a1.s fffff801`83850000 fffff801`83861000 mouhid.sys fffff801`83870000 fffff801`83881000 RzCommon.sys fffff801`837d0000 fffff801`837e3000 hidusb.sys fffff801`837f0000 fffff801`83801000 mouhid.sys fffff801`5b040000 fffff801`5b053000 hidusb.sys fffff801`5b060000 fffff801`5b071000 mouhid.sys fffff801`2cdc0000 fffff801`2ce1b000 WdFilter.sys fffff801`836c0000 fffff801`83706000 MpKslDrv.sys fffff801`836a0000 fffff801`836b3000 WdNisDrv.sys fffff801`40b70000 fffff801`40b80000 dump_storpor fffff801`40bb0000 fffff801`40be0000 dump_stornvm fffff801`40000000 fffff801`4001e000 dump_dumpfve fffff801`40940000 fffff801`4095c000 dam.sys fffff801`2c8e0000 fffff801`2c8f1000 WdBoot.sys fffff801`2d910000 fffff801`2d921000 hwpolicy.sys # RetAddr : Args to Child : Call Site 00 fffff801`28e12ba9 : 00000000`0000000a 00000000`00000060 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx 01 fffff801`28e0e578 : ffffd702`6867f350 fffff801`28cc28c5 ffffab8f`fc74d700 ffffab8f`fc74d700 : nt!KiBugCheckDispatch+0x69 02 fffff801`28f48dc6 : ffffd702`6867f4f8 ffffef81`0a85f200 ffffef81`0a85f3f8 ffffab8f`fc74d700 : nt!KiPageFault+0x478 03 fffff801`28cc1966 : ffffec00`03000000 ffffd702`6867f450 00000001`00000001 ffffd702`6867f300 : nt!MiMakeProtoPrivate+0xb2 04 fffff801`29027a1b : ffffd702`6867f730 00000000`00000004 00000215`0be7ffff ffffd702`6867f860 : nt!MiProtectPrivateMemory+0x576 05 fffff801`290261c9 : ffffab8f`fc74d080 ffffab8f`fc74d080 ffffd702`6867f6d8 ffffd702`6867f6d0 : nt!MmProtectVirtualMemory+0x42b 06 fffff801`29026c3f : ffffab8f`00000000 fffff801`00000000 00000000`00000000 00000000`00000001 : nt!MiAllocateVirtualMemory+0x5e9 07 fffff801`29026a61 : ffffffff`ffffffff ffffab8f`fda0f080 000000d6`23dfe838 ffffab8f`00001000 : nt!MmAllocateVirtualMemory+0x1cf 08 fffff801`28e12305 : 00000000`00000000 00000000`00000000 00000000`00000000 ffffab8f`fd015b60 : nt!NtAllocateVirtualMemoryEx+0x51 09 00007ffa`3d24e414 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x25 0a 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ffa`3d24e414 Machine ID Information [From Smbios 3.6, DMIVersion 0, Size=5033] BiosMajorRelease = 5 BiosMinorRelease = 27 BiosVendor = American Megatrends International, LLC. BiosVersion = F4d BiosReleaseDate = 08/09/2024 SystemManufacturer = Gigabyte Technology Co., Ltd. SystemProductName = H610M H V2 SystemFamily = H610 MB SystemVersion = -CF SystemSKU = Default string BaseBoardManufacturer = Gigabyte Technology Co., Ltd. BaseBoardProduct = H610M H V2 BaseBoardVersion = x.x [SMBIOS Data Tables v3.6] [DMI Version - 0] [2.0 Calling Convention - No] [Table Size - 5033 bytes] [BIOS Information (Type 0) - Length 26 - Handle 0000h] Vendor American Megatrends International, LLC. BIOS Version F4d BIOS Starting Address Segment f000 BIOS Release Date 08/09/2024 BIOS ROM Size 1000000 BIOS Characteristics 07: - PCI Supported 11: - Upgradeable FLASH BIOS 12: - BIOS Shadowing Supported 15: - CD-Boot Supported 16: - Selectable Boot Supported 17: - BIOS ROM Socketed 19: - EDD Supported 20: - NEC 9800 J-Floppy Supported 21: - Toshiba J-Floppy Supported 22: - 360KB Floppy Supported 23: - 1.2MB Floppy Supported 24: - 720KB Floppy Supported 25: - 2.88MB Floppy Supported 26: - Print Screen Device Supported 28: - Serial Services Supported 29: - Printer Services Supported 30: - CGA/Mono Services Supported 32: - BIOS Vendor Reserved BIOS Characteristic Extensions 00: - ACPI Supported 01: - USB Legacy Supported 08: - BIOS Boot Specification Supported 10: - Enable Targeted Content Distribution 11: - UEFI Specification Supported BIOS Major Revision 5 BIOS Minor Revision 27 EC Firmware Major Revision 255 EC Firmware Minor Revision 255 Extended BIOS ROM Size 16 MB [System Information (Type 1) - Length 27 - Handle 0001h] Manufacturer Gigabyte Technology Co., Ltd. Product Name H610M H V2 Version -CF Serial Number Default string UUID 00000000-0000-0000-0000-000000000000 Wakeup Type Power Switch SKUNumber Default string Family H610 MB [BaseBoard Information (Type 2) - Length 15 - Handle 0002h] Manufacturer Gigabyte Technology Co., Ltd. Product H610M H V2 Version x.x Serial Number Default string Asset Tag Feature Flags 09h 00: - Motherboard 03: - Replaceable Location Default string Chassis Handle 0003h Board Type 0ah - Processor/Memory Module Number of Child Handles 0 [System Enclosure (Type 3) - Length 22 - Handle 0003h] Manufacturer Default string Chassis Type Desktop Version Default string Serial Number Asset Tag Number Bootup State Safe Power Supply State Safe Thermal State Safe Security Status None OEM Defined 0 Height 0U Number of Power Cords 1 Number of Contained Elements 0 Contained Element Size 3 [Onboard Devices Information (Type 10) - Length 6 - Handle 0021h] Note: The On Board Device Information (Type 10) struct is obsolete as of SMBIOs spec v2.6 Number of Devices 1 01: Type Video [enabled] 01: Description To Be Filled By O.E.M. [OEM Strings (Type 11) - Length 5 - Handle 0022h] Number of Strings 1 1 Default string [System Configuration Options (Type 12) - Length 5 - Handle 0023h] [ (Type 256) - Length 9 - Handle 003ah] [Physical Memory Array (Type 16) - Length 23 - Handle 003bh] Location 03h - SystemBoard/Motherboard Use 03h - System Memory Memory Error Correction 03h - None Maximum Capacity 67108864KB Memory Error Inf Handle [Not Provided] Number of Memory Devices 2 [Memory Device (Type 17) - Length 92 - Handle 003ch] Memory Error Info Handle [Not Provided] Total Width 64 bits Data Width 64 bits Size 16384MB Form Factor 09h - DIMM Device Set [None] Device Locator DDR5-A1 Bank Locator BANK 0 Memory Type 22h - DDR5 Type Detail 0080h - Synchronous Speed 5600MHz Manufacturer Crucial Technology Serial Number Asset Tag Number Part Number CP16G56C46U5.C8B2 Attributes 1 Extended Size 0 Configured Memory Speed 4800 Minimum Voltage 1100 Maximum Voltage 2950 Configured Voltage 1100 Memory Technology 3 Memory Operating Mode Capability 8 Firmware Version 0 Module Manufacturer Id 39813 Module Product Id 0 Memory Subsystem Controller Manufacturer Id 0 Memory Subsystem Controller Product Id 0 Non-Volatile Size 0 Volatile Size 0 Cache Size 0 Logical Size 0 Extended Speed 0 Extended Configured Memory Speed 0 [Memory Device (Type 17) - Length 92 - Handle 003dh] Memory Error Info Handle [Not Provided] Total Width 64 bits Data Width 64 bits Size 16384MB Form Factor 09h - DIMM Device Set [None] Device Locator DDR5-B1 Bank Locator BANK 0 Memory Type 22h - DDR5 Type Detail 0080h - Synchronous Speed 5600MHz Manufacturer Crucial Technology Serial Number Asset Tag Number Part Number CP16G56C46U5.C8B2 Attributes 1 Extended Size 0 Configured Memory Speed 4800 Minimum Voltage 1100 Maximum Voltage 2950 Configured Voltage 1100 Memory Technology 3 Memory Operating Mode Capability 8 Firmware Version 0 Module Manufacturer Id 39813 Module Product Id 0 Memory Subsystem Controller Manufacturer Id 0 Memory Subsystem Controller Product Id 0 Non-Volatile Size 0 Volatile Size 0 Cache Size 0 Logical Size 0 Extended Speed 0 Extended Configured Memory Speed 0 [Memory Array Mapped Address (Type 19) - Length 31 - Handle 003eh] Starting Address 00000000h Ending Address ffffffffh Memory Array Handle 003bh Partition Width 02 Extended Starting Address 0000000000000000h Extended Ending Address 0000000000000000h [ (Type 256) - Length 31 - Handle 003fh] [ (Type 256) - Length 26 - Handle 0040h] [Memory Device Mapped Address (Type 20) - Length 35 - Handle 0041h] Starting Address 00000000h Ending Address 00ffffffh Memory Device Handle 003ch Mem Array Mapped Adr Handle 003eh Partition Row Position [Unknown] Extended Starting Address 0000000000000000h Extended Ending Address 0000000000000000h [Memory Device Mapped Address (Type 20) - Length 35 - Handle 0042h] Starting Address 01000000h Ending Address 01ffffffh Memory Device Handle 003dh Mem Array Mapped Adr Handle 003eh Partition Row Position [Unknown] Extended Starting Address 0000000000000000h Extended Ending Address 0000000000000000h [ (Type 256) - Length 12 - Handle 0043h] [ (Type 256) - Length 26 - Handle 0044h] [ (Type 256) - Length 26 - Handle 0045h] [ (Type 256) - Length 47 - Handle 0046h] [ (Type 256) - Length 82 - Handle 0047h] [Cache Information (Type 7) - Length 27 - Handle 0048h] Socket Designation L1 Cache Cache Configuration 0180h - WBEnabled Int NonSocketed L1 Maximum Cache Size 0120h - 288K Installed Size 0120h - 288K Supported SRAM Type 0020h - Synchronous Current SRAM Type 0020h - Synchronous Cache Speed 0ns Error Correction Type ParitySingle-Bit ECC System Cache Type Data Associativity 12-way Set-Associative Maximum Cache Size 2 120 - 00000288l Kb Installed Cache Size 2 120 - 00000288l Kb [Cache Information (Type 7) - Length 27 - Handle 0049h] Socket Designation L1 Cache Cache Configuration 0180h - WBEnabled Int NonSocketed L1 Maximum Cache Size 00c0h - 192K Installed Size 00c0h - 192K Supported SRAM Type 0020h - Synchronous Current SRAM Type 0020h - Synchronous Cache Speed 0ns Error Correction Type ParitySingle-Bit ECC System Cache Type Instruction Associativity 8-way Set-Associative Maximum Cache Size 2 c0 - 00000192l Kb Installed Cache Size 2 c0 - 00000192l Kb [Cache Information (Type 7) - Length 27 - Handle 004ah] Socket Designation L2 Cache Cache Configuration 0181h - WBEnabled Int NonSocketed L2 Maximum Cache Size 1e00h - 7680K Installed Size 1e00h - 7680K Supported SRAM Type 0020h - Synchronous Current SRAM Type 0020h - Synchronous Cache Speed 0ns Error Correction Type Multi-Bit ECC System Cache Type Unified Associativity Other Maximum Cache Size 2 1e00 - 00007680l Kb Installed Cache Size 2 1e00 - 00007680l Kb [Cache Information (Type 7) - Length 27 - Handle 004bh] Socket Designation L3 Cache Cache Configuration 0182h - WBEnabled Int NonSocketed L3 Maximum Cache Size 5000h - 20480K Installed Size 5000h - 20480K Supported SRAM Type 0020h - Synchronous Current SRAM Type 0020h - Synchronous Cache Speed 0ns Error Correction Type Specification Reserved System Cache Type Unified Associativity Other Maximum Cache Size 2 5000 - 00020480l Kb Installed Cache Size 2 5000 - 00020480l Kb [Cache Information (Type 7) - Length 27 - Handle 004ch] Socket Designation L1 Cache Cache Configuration 0180h - WBEnabled Int NonSocketed L1 Maximum Cache Size 0080h - 128K Installed Size 0080h - 128K Supported SRAM Type 0020h - Synchronous Current SRAM Type 0020h - Synchronous Cache Speed 0ns Error Correction Type ParitySingle-Bit ECC System Cache Type Data Associativity 8-way Set-Associative Maximum Cache Size 2 80 - 00000128l Kb Installed Cache Size 2 80 - 00000128l Kb [Cache Information (Type 7) - Length 27 - Handle 004dh] Socket Designation L1 Cache Cache Configuration 0180h - WBEnabled Int NonSocketed L1 Maximum Cache Size 0100h - 256K Installed Size 0100h - 256K Supported SRAM Type 0020h - Synchronous Current SRAM Type 0020h - Synchronous Cache Speed 0ns Error Correction Type ParitySingle-Bit ECC System Cache Type Instruction Associativity 8-way Set-Associative Maximum Cache Size 2 100 - 00000256l Kb Installed Cache Size 2 100 - 00000256l Kb [Cache Information (Type 7) - Length 27 - Handle 004eh] Socket Designation L2 Cache Cache Configuration 0181h - WBEnabled Int NonSocketed L2 Maximum Cache Size 0800h - 2048K Installed Size 0800h - 2048K Supported SRAM Type 0020h - Synchronous Current SRAM Type 0020h - Synchronous Cache Speed 0ns Error Correction Type Multi-Bit ECC System Cache Type Unified Associativity 16-way Set-Associative Maximum Cache Size 2 800 - 00002048l Kb Installed Cache Size 2 800 - 00002048l Kb [Cache Information (Type 7) - Length 27 - Handle 004fh] Socket Designation L3 Cache Cache Configuration 0182h - WBEnabled Int NonSocketed L3 Maximum Cache Size 5000h - 20480K Installed Size 5000h - 20480K Supported SRAM Type 0020h - Synchronous Current SRAM Type 0020h - Synchronous Cache Speed 0ns Error Correction Type Specification Reserved System Cache Type Unified Associativity Other Maximum Cache Size 2 5000 - 00020480l Kb Installed Cache Size 2 5000 - 00020480l Kb [Processor Information (Type 4) - Length 48 - Handle 0050h] Socket Designation U3E1 Processor Type Central Processor Processor Family cdh - Intel Core 2 Solo processor Processor Manufacturer Intel(R) Corporation Processor ID 71060b00fffbebbf Processor Version Intel(R) Core(TM) i5-14400F Processor Voltage 89h - 0.9V External Clock 100MHz Max Speed 4700MHz Current Speed 2475MHz Status Enabled Populated Processor Upgrade Specification Reserved L1 Cache Handle 004dh L2 Cache Handle 004eh L3 Cache Handle 004fh Serial Number Asset Tag Number Part Number To Be Filled By O.E.M. Core Count 10 Core Enabled 10 Thread Count 16 Processor Characteristics fc Enabled Characteristics: 0x 2: 64-bit Capable 0x 3: Multi-Core 0x 4: Hardware Thread 0x 5: Execute Protection 0x 6: Enhanced Virtualization 0x 7: Power/Performance Control Processor Family 2 00cdh - Intel Core 2 Solo processor Core Count 2 10 Core Enabled 2 10 Thread Count 2 16 [ (Type 256) - Length 64 - Handle 0051h] [ (Type 256) - Length 11 - Handle 0052h] [ (Type 256) - Length 11 - Handle 0053h] [ (Type 256) - Length 11 - Handle 0054h] [ (Type 256) - Length 11 - Handle 0055h] [ (Type 256) - Length 11 - Handle 0056h] [ (Type 256) - Length 11 - Handle 0057h] [ (Type 256) - Length 11 - Handle 0058h] [ (Type 256) - Length 11 - Handle 0059h] [ (Type 256) - Length 11 - Handle 005ah] [ (Type 256) - Length 11 - Handle 005bh] [ (Type 256) - Length 11 - Handle 005ch] [ (Type 256) - Length 11 - Handle 005dh] [ (Type 256) - Length 11 - Handle 005eh] [ (Type 256) - Length 11 - Handle 005fh] [ (Type 256) - Length 11 - Handle 0060h] [ (Type 256) - Length 103 - Handle 0061h] [ (Type 256) - Length 44 - Handle 0062h] [ (Type 256) - Length 8 - Handle 0063h] [ (Type 256) - Length 106 - Handle 0067h] [ (Type 256) - Length 6 - Handle 0068h] [ (Type 256) - Length 4 - Handle 006ah] THREAD ffffab8ffda0f080 Cid 32f4.29ac Teb: 000000d61e476000 Win32Thread: 0000000000000000 RUNNING on processor 8 Not impersonating GetUlongFromAddress: unable to read from fffff8012961159c Owning Process ffffab8ffc74d080 Image: Discord.exe Attached Process N/A Image: N/A fffff78000000000: Unable to get shared data Wait Start TickCount 51925 Context Switch Count 6341 IdealProcessor: 3 ReadMemory error: Cannot get nt!KeMaximumIncrement value. UserTime 00:00:00.000 KernelTime 00:00:00.000 Win32 Start Address 0x00007ff73cdce270 Stack Init ffffd7026867fbd0 Current ffffd7026867f5e0 Base ffffd70268680000 Limit ffffd70268679000 Call 0000000000000000 Priority 9 BasePriority 8 IoPriority 2 PagePriority 5 Child-SP RetAddr : Args to Child : Call Site ffffd702`6867f028 fffff801`28e12ba9 : 00000000`0000000a 00000000`00000060 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx ffffd702`6867f030 fffff801`28e0e578 : ffffd702`6867f350 fffff801`28cc28c5 ffffab8f`fc74d700 ffffab8f`fc74d700 : nt!KiBugCheckDispatch+0x69 ffffd702`6867f170 fffff801`28f48dc6 : ffffd702`6867f4f8 ffffef81`0a85f200 ffffef81`0a85f3f8 ffffab8f`fc74d700 : nt!KiPageFault+0x478 (TrapFrame @ ffffd702`6867f170) ffffd702`6867f300 fffff801`28cc1966 : ffffec00`03000000 ffffd702`6867f450 00000001`00000001 ffffd702`6867f300 : nt!MiMakeProtoPrivate+0xb2 ffffd702`6867f350 fffff801`29027a1b : ffffd702`6867f730 00000000`00000004 00000215`0be7ffff ffffd702`6867f860 : nt!MiProtectPrivateMemory+0x576 ffffd702`6867f500 fffff801`290261c9 : ffffab8f`fc74d080 ffffab8f`fc74d080 ffffd702`6867f6d8 ffffd702`6867f6d0 : nt!MmProtectVirtualMemory+0x42b ffffd702`6867f630 fffff801`29026c3f : ffffab8f`00000000 fffff801`00000000 00000000`00000000 00000000`00000001 : nt!MiAllocateVirtualMemory+0x5e9 ffffd702`6867f7b0 fffff801`29026a61 : ffffffff`ffffffff ffffab8f`fda0f080 000000d6`23dfe838 ffffab8f`00001000 : nt!MmAllocateVirtualMemory+0x1cf ffffd702`6867f960 fffff801`28e12305 : 00000000`00000000 00000000`00000000 00000000`00000000 ffffab8f`fd015b60 : nt!NtAllocateVirtualMemoryEx+0x51 ffffd702`6867f9d0 00007ffa`3d24e414 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x25 (TrapFrame @ ffffd702`6867fa40) 000000d6`23dfe818 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ffa`3d24e414 ******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* MEMORY_MANAGEMENT (1a) # Any other values for parameter 1 must be individually examined. Arguments: Arg1: 0000000000041792, A corrupt PTE has been detected. Parameter 2 contains the address of the PTE. Parameters 3/4 contain the low/high parts of the PTE. Arg2: ffffed813aae5480 Arg3: 0001000000000000 Arg4: 0000000000000000 Debugging Details: ------------------ KEY_VALUES_STRING: 1 Key : Analysis.CPU.mSec Value: 499 Key : Analysis.Elapsed.mSec Value: 3759 Key : Analysis.IO.Other.Mb Value: 14 Key : Analysis.IO.Read.Mb Value: 0 Key : Analysis.IO.Write.Mb Value: 18 Key : Analysis.Init.CPU.mSec Value: 139 Key : Analysis.Init.Elapsed.mSec Value: 8711 Key : Analysis.Memory.CommitPeak.Mb Value: 81 Key : Bugcheck.Code.LegacyAPI Value: 0x1a Key : Bugcheck.Code.TargetModel Value: 0x1a Key : Failure.Bucket Value: MEMORY_CORRUPTION_ONE_BIT Key : Failure.Hash Value: {e3faf315-c3d0-81db-819a-6c43d23c63a7} Key : MemoryManagement.PFN Value: 0 Key : WER.OS.Branch Value: vb_release Key : WER.OS.Version Value: 10.0.19041.1 BUGCHECK_CODE: 1a BUGCHECK_P1: 41792 BUGCHECK_P2: ffffed813aae5480 BUGCHECK_P3: 1000000000000 BUGCHECK_P4: 0 FILE_IN_CAB: 091824-13937-01.dmp FAULTING_THREAD: ffff9c8230e04080 MEMORY_CORRUPTOR: ONE_BIT BLACKBOXBSD: 1 (!blackboxbsd) BLACKBOXNTFS: 1 (!blackboxntfs) BLACKBOXWINLOGON: 1 CUSTOMER_CRASH_COUNT: 1 PROCESS_NAME: opera.exe STACK_TEXT: fffff40f`f794f048 fffff804`21aa04ca : 00000000`0000001a 00000000`00041792 ffffed81`3aae5480 00010000`00000000 : nt!KeBugCheckEx fffff40f`f794f050 fffff804`21a38816 : 00000000`00000000 00000000`00000000 00000000`00006b2a ffffed81`3aae5480 : nt!MiDeleteVa+0x153a fffff40f`f794f150 fffff804`21a3892b : ffffedf6`00000000 ffff9c82`30772700 fffff40f`00000000 fffff40f`f794f5c0 : nt!MiWalkPageTablesRecursively+0x776 fffff40f`f794f1f0 fffff804`21a3892b : ffffedf6`00000000 ffff9c82`30772700 fffff40f`00000001 fffff40f`f794f5d0 : nt!MiWalkPageTablesRecursively+0x88b fffff40f`f794f290 fffff804`21a3892b : ffffedf6`fb604000 ffff9c82`30772700 fffff40f`00000002 fffff40f`f794f5e0 : nt!MiWalkPageTablesRecursively+0x88b fffff40f`f794f330 fffff804`21a3592b : 00000000`c0000016 ffff9c82`30772700 00000000`00000003 fffff40f`f794f5f0 : nt!MiWalkPageTablesRecursively+0x88b fffff40f`f794f3d0 fffff804`21a9ed61 : fffff40f`f794f570 ffff9c82`00000000 00000000`00000002 00000000`00000000 : nt!MiWalkPageTables+0x36b fffff40f`f794f4d0 fffff804`21a48a68 : 00000000`00000001 ffff9c82`00000000 ffff9c82`30772550 ffff9c82`30e04080 : nt!MiDeletePagablePteRange+0x4f1 fffff40f`f794f7e0 fffff804`21e4f469 : fffff40f`00000000 00000000`00000000 00004f44`00000000 ffff9c82`30772080 : nt!MiDeleteVad+0x378 fffff40f`f794f8e0 fffff804`21e4f242 : ffff9c82`30f2d0a0 00000000`00000000 ffff9c82`30772080 00000000`00000000 : nt!MiUnmapVad+0x49 fffff40f`f794f910 fffff804`21e4f0b9 : 000000d5`a2dff428 7fffffff`00000004 00004f44`00290280 00000000`00000000 : nt!MiUnmapViewOfSection+0x152 fffff40f`f794f9f0 fffff804`21c12305 : ffff9c82`30e04080 00000275`55fa0000 fffff40f`f794fac0 ffff9c82`30772080 : nt!NtUnmapViewOfSectionEx+0x99 fffff40f`f794fa40 00007ff9`8e630f14 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x25 000000d5`a2dff358 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ff9`8e630f14 MODULE_NAME: hardware IMAGE_NAME: memory_corruption STACK_COMMAND: .process /r /p 0xffff9c8230772080; .thread 0xffff9c8230e04080 ; kb FAILURE_BUCKET_ID: MEMORY_CORRUPTION_ONE_BIT OS_VERSION: 10.0.19041.1 BUILDLAB_STR: vb_release OSPLATFORM_TYPE: x64 OSNAME: Windows 10 FAILURE_ID_HASH: {e3faf315-c3d0-81db-819a-6c43d23c63a7} Followup: MachineOwner --------- start end module name ffffae5d`ff600000 ffffae5d`ff69b000 win32k (deferred) ffffae5d`ffba0000 ffffae5d`ffe6c000 win32kbase (deferred) ffffae5e`00ca0000 ffffae5e`01051000 win32kfull (deferred) ffffae5e`01060000 ffffae5e`010a9000 cdd (deferred) fffff804`1ebf0000 fffff804`1ee7f000 mcupdate_GenuineIntel (deferred) fffff804`1ee80000 fffff804`1ee86000 hal (deferred) fffff804`1ee90000 fffff804`1ee9b000 kd (deferred) fffff804`1eea0000 fffff804`1eec8000 tm (deferred) fffff804`1eed0000 fffff804`1ef3e000 CLFS (deferred) fffff804`1ef40000 fffff804`1ef5a000 PSHED (deferred) fffff804`1ef60000 fffff804`1ef6b000 BOOTVID (deferred) fffff804`1ef70000 fffff804`1efde000 FLTMGR (deferred) fffff804`1efe0000 fffff804`1efee000 cmimcext (deferred) fffff804`21800000 fffff804`22846000 nt (pdb symbols) C:\ProgramData\Dbg\sym\ntkrnlmp.pdb\9F65CD18C2F36F88B2D0CE8A7BFE2BB71\ntkrnlmp.pdb fffff804`24400000 fffff804`24518000 clipsp (deferred) fffff804`24520000 fffff804`24549000 ksecdd (deferred) fffff804`24550000 fffff804`245b3000 msrpc (deferred) fffff804`245c0000 fffff804`245d1000 werkernel (deferred) fffff804`245e0000 fffff804`245ec000 ntosext (deferred) fffff804`245f0000 fffff804`246dc000 CI (deferred) fffff804`246e0000 fffff804`2479b000 cng (deferred) fffff804`247a0000 fffff804`24871000 Wdf01000 (deferred) fffff804`24880000 fffff804`24893000 WDFLDR (deferred) fffff804`248a0000 fffff804`248af000 SleepStudyHelper (deferred) fffff804`248b0000 fffff804`248c1000 WppRecorder (deferred) fffff804`248d0000 fffff804`248f6000 acpiex (deferred) fffff804`24900000 fffff804`2491a000 SgrmAgent (deferred) fffff804`24920000 fffff804`249ec000 ACPI (deferred) fffff804`249f0000 fffff804`249fc000 WMILIB (deferred) fffff804`24a00000 fffff804`24a0b000 msisadrv (deferred) fffff804`24a10000 fffff804`24a88000 pci (deferred) fffff804`24a90000 fffff804`24ad5000 tpm (deferred) fffff804`24af0000 fffff804`24b5b000 intelpep (deferred) fffff804`24b60000 fffff804`24b77000 WindowsTrustedRT (deferred) fffff804`24b80000 fffff804`24b8b000 IntelTA (deferred) fffff804`24b90000 fffff804`24b9b000 WindowsTrustedRTProxy (deferred) fffff804`24ba0000 fffff804`24bb4000 pcw (deferred) fffff804`24bc0000 fffff804`24bd5000 vdrvroot (deferred) fffff804`24be0000 fffff804`24bf9000 CEA (deferred) fffff804`24c00000 fffff804`24c30000 pdc (deferred) fffff804`24c40000 fffff804`24c71000 partmgr (deferred) fffff804`24c80000 fffff804`24d2b000 spaceport (deferred) fffff804`24d30000 fffff804`24d49000 volmgr (deferred) fffff804`24d50000 fffff804`24db3000 volmgrx (deferred) fffff804`24dc0000 fffff804`24dde000 mountmgr (deferred) fffff804`24de0000 fffff804`24e12000 storahci (deferred) fffff804`24e20000 fffff804`24ed5000 storport (deferred) fffff804`24ee0000 fffff804`24f0f000 stornvme (deferred) fffff804`24f10000 fffff804`24f2c000 EhStorClass (deferred) fffff804`24f30000 fffff804`24f4a000 fileinfo (deferred) fffff804`24f50000 fffff804`24f90000 Wof (deferred) fffff804`24fa0000 fffff804`25036000 WdFilter (deferred) fffff804`25040000 fffff804`25317000 Ntfs (deferred) fffff804`25320000 fffff804`2532d000 Fs_Rec (deferred) fffff804`25330000 fffff804`254a0000 ndis (deferred) fffff804`254b0000 fffff804`2554c000 NETIO (deferred) fffff804`25550000 fffff804`25582000 ksecpkg (deferred) fffff804`25590000 fffff804`2587d000 tcpip (deferred) fffff804`25880000 fffff804`258ff000 fwpkclnt (deferred) fffff804`25900000 fffff804`25930000 wfplwfs (deferred) fffff804`25940000 fffff804`25a09000 fvevol (deferred) fffff804`25a10000 fffff804`25a1b000 volume (deferred) fffff804`25a20000 fffff804`25a8d000 volsnap (deferred) fffff804`25a90000 fffff804`25ae0000 rdyboost (deferred) fffff804`25af0000 fffff804`25b16000 mup (deferred) fffff804`25b20000 fffff804`25b32000 iorate (deferred) fffff804`25b60000 fffff804`25b7d000 disk (deferred) fffff804`25b80000 fffff804`25bf2000 CLASSPNP (deferred) fffff804`38220000 fffff804`38800000 RTKVHD64 (deferred) fffff804`38810000 fffff804`38997000 HTTP (deferred) fffff804`389a0000 fffff804`38a34000 mrxsmb (deferred) fffff804`38a40000 fffff804`38a85000 mrxsmb20 (deferred) fffff804`38a90000 fffff804`38ae6000 srvnet (deferred) fffff804`38b30000 fffff804`38b4e000 crashdmp (deferred) fffff804`38b50000 fffff804`38ba2000 mrxsmb10 (deferred) fffff804`38bb0000 fffff804`38bd7000 Ndu (deferred) fffff804`3e400000 fffff804`3e7aa000 dxgkrnl (deferred) fffff804`3e7b0000 fffff804`3e7c8000 watchdog (deferred) fffff804`3e7d0000 fffff804`3e7e6000 BasicDisplay (deferred) fffff804`3e7f0000 fffff804`3e801000 BasicRender (deferred) fffff804`3e810000 fffff804`3e82c000 Npfs (deferred) fffff804`3e830000 fffff804`3e841000 Msfs (deferred) fffff804`3e850000 fffff804`3e86e000 CimFS (deferred) fffff804`3e870000 fffff804`3e892000 tdx (deferred) fffff804`3e8a0000 fffff804`3e8b0000 TDI (deferred) fffff804`3e8c0000 fffff804`3e91c000 netbt (deferred) fffff804`3e920000 fffff804`3e934000 afunix (deferred) fffff804`3e940000 fffff804`3e9e8000 afd (deferred) fffff804`3e9f0000 fffff804`3ea0a000 vwififlt (deferred) fffff804`3ea10000 fffff804`3ea3b000 pacer (deferred) fffff804`3ea40000 fffff804`3ea54000 ndiscap (deferred) fffff804`3ea60000 fffff804`3ea74000 netbios (deferred) fffff804`3ea80000 fffff804`3eb21000 Vid (deferred) fffff804`3eb30000 fffff804`3eb54000 winhvr (deferred) fffff804`3eb60000 fffff804`3ebdb000 rdbss (deferred) fffff804`3ebe0000 fffff804`3ebf2000 nsiproxy (deferred) fffff804`3ec00000 fffff804`3ec0e000 npsvctrig (deferred) fffff804`3ec10000 fffff804`3ec20000 mssmbios (deferred) fffff804`3ec30000 fffff804`3ec3a000 gpuenergydrv (deferred) fffff804`3ec40000 fffff804`3ec6d000 dfsc (deferred) fffff804`3ec90000 fffff804`3ecfd000 fastfat (deferred) fffff804`3ed00000 fffff804`3ed17000 bam (deferred) fffff804`3ed20000 fffff804`3ed72000 ahcache (deferred) fffff804`3ed80000 fffff804`3ed92000 CompositeBus (deferred) fffff804`3eda0000 fffff804`3edad000 kdnic (deferred) fffff804`3edb0000 fffff804`3edc5000 umbus (deferred) fffff804`3edf0000 fffff804`3ee0d000 dump_dumpfve (deferred) fffff804`3ee10000 fffff804`3eef0000 dxgmms2 (deferred) fffff804`3ef00000 fffff804`3ef1b000 monitor (deferred) fffff804`3ef20000 fffff804`3ef4d000 luafv (deferred) fffff804`3ef50000 fffff804`3ef87000 wcifs (deferred) fffff804`3ef90000 fffff804`3f012000 cldflt (deferred) fffff804`3f020000 fffff804`3f03a000 storqosflt (deferred) fffff804`3f040000 fffff804`3f068000 bindflt (deferred) fffff804`3f070000 fffff804`3f088000 lltdio (deferred) fffff804`3f090000 fffff804`3f0a8000 mslldp (deferred) fffff804`3f0b0000 fffff804`3f0cb000 rspndr (deferred) fffff804`3f0d0000 fffff804`3f0ed000 wanarp (deferred) fffff804`3f0f0000 fffff804`3f146000 msquic (deferred) fffff804`3f150000 fffff804`3f162000 condrv (deferred) fffff804`3f170000 fffff804`3f195000 bowser (deferred) fffff804`3f1a0000 fffff804`3f1ba000 mpsdrv (deferred) fffff804`3f1c0000 fffff804`3f1d4000 mmcss (deferred) fffff804`3f1e0000 fffff804`40d35000 vgk (deferred) fffff804`40d40000 fffff804`40d70000 cdrom (deferred) fffff804`40d80000 fffff804`40d95000 filecrypt (deferred) fffff804`40da0000 fffff804`40dae000 tbs (deferred) fffff804`40db0000 fffff804`40dc5000 UCPD (deferred) fffff804`40dd0000 fffff804`40dda000 Null (deferred) fffff804`40de0000 fffff804`40dea000 Beep (deferred) fffff804`50000000 fffff804`50068000 portcls (deferred) fffff804`50070000 fffff804`50091000 drmk (deferred) fffff804`500a0000 fffff804`50118000 ks (deferred) fffff804`50120000 fffff804`501bd000 USBXHCI (deferred) fffff804`501c0000 fffff804`50204000 ucx01000 (deferred) fffff804`50210000 fffff804`5025f000 TeeDriverW10x64 (deferred) fffff804`50260000 fffff804`5038a000 rt640x64 (deferred) fffff804`50390000 fffff804`503ac000 serial (deferred) fffff804`503b0000 fffff804`503bf000 serenum (deferred) fffff804`503c0000 fffff804`503cc000 acpitime (deferred) fffff804`503d0000 fffff804`50411000 intelppm (deferred) fffff804`50420000 fffff804`5042b000 acpipagr (deferred) fffff804`50430000 fffff804`5043c000 wmiacpi (deferred) fffff804`50440000 fffff804`50457000 HidEventFilter (deferred) fffff804`50460000 fffff804`5046b000 mshidkmdf (deferred) fffff804`50470000 fffff804`504b1000 HIDCLASS (deferred) fffff804`504c0000 fffff804`504d3000 HIDPARSE (deferred) fffff804`504e0000 fffff804`504ee000 UEFI (deferred) fffff804`504f0000 fffff804`504fd000 NdisVirtualBus (deferred) fffff804`50500000 fffff804`50529000 RZTHXSpatial (deferred) fffff804`50530000 fffff804`50541000 ksthunk (deferred) fffff804`50550000 fffff804`5055c000 swenum (deferred) fffff804`50560000 fffff804`5056e000 rdpbus (deferred) fffff804`50570000 fffff804`50581000 kbdhid (deferred) fffff804`50590000 fffff804`505a4000 kbdclass (deferred) fffff804`505b0000 fffff804`505c2000 buttonconverter (deferred) fffff804`505d0000 fffff804`50673000 UsbHub3 (deferred) fffff804`50680000 fffff804`5068e000 USBD (deferred) fffff804`50690000 fffff804`506ae000 nvhda64v (deferred) fffff804`506b0000 fffff804`506e4000 usbccgp (deferred) fffff804`506f0000 fffff804`50701000 RzDev_00b8 (deferred) fffff804`50710000 fffff804`50722000 hidusb (deferred) fffff804`50730000 fffff804`50741000 RzDev_02a1 (deferred) fffff804`50750000 fffff804`50760000 mouhid (deferred) fffff804`50770000 fffff804`50783000 mouclass (deferred) fffff804`50790000 fffff804`507a0000 RzCommon (deferred) fffff804`507b0000 fffff804`507e8000 usbaudio (deferred) fffff804`50800000 fffff804`5080f000 dump_dumpstorport (deferred) fffff804`50840000 fffff804`5086f000 dump_stornvme (deferred) fffff804`50870000 fffff804`541c3000 nvlddmkm (deferred) fffff804`541d0000 fffff804`541f5000 HDAudBus (deferred) fffff804`8c600000 fffff804`8c621000 raspptp (deferred) fffff804`8c630000 fffff804`8c64c000 raspppoe (deferred) fffff804`8c650000 fffff804`8c65f000 gdrv3 (deferred) fffff804`8c660000 fffff804`8c66f000 ndistapi (deferred) fffff804`8c670000 fffff804`8c6aa000 ndiswan (deferred) fffff804`8c6b0000 fffff804`8c6cd000 WdNisDrv (deferred) fffff804`8c6d0000 fffff804`8c6e4000 qwavedrv (deferred) fffff804`8cb80000 fffff804`8cc56000 peauth (deferred) fffff804`8cc60000 fffff804`8cc75000 tcpipreg (deferred) fffff804`8cc80000 fffff804`8cc9d000 rassstp (deferred) fffff804`8cca0000 fffff804`8cd68000 srv2 (deferred) fffff804`8cd70000 fffff804`8cd8d000 NDProxy (deferred) fffff804`8cd90000 fffff804`8cdb8000 AgileVpn (deferred) fffff804`8cdc0000 fffff804`8cde1000 rasl2tp (deferred) Unloaded modules: fffff804`38b60000 fffff804`38b70000 dump_storpor fffff804`38ba0000 fffff804`38bd0000 dump_stornvm fffff804`38200000 fffff804`3821e000 dump_dumpfve fffff804`3ec70000 fffff804`3ec8c000 dam.sys fffff804`24ae0000 fffff804`24aec000 WdBoot.sys fffff804`25b40000 fffff804`25b51000 hwpolicy.sys # RetAddr : Args to Child : Call Site 00 fffff804`21aa04ca : 00000000`0000001a 00000000`00041792 ffffed81`3aae5480 00010000`00000000 : nt!KeBugCheckEx 01 fffff804`21a38816 : 00000000`00000000 00000000`00000000 00000000`00006b2a ffffed81`3aae5480 : nt!MiDeleteVa+0x153a 02 fffff804`21a3892b : ffffedf6`00000000 ffff9c82`30772700 fffff40f`00000000 fffff40f`f794f5c0 : nt!MiWalkPageTablesRecursively+0x776 03 fffff804`21a3892b : ffffedf6`00000000 ffff9c82`30772700 fffff40f`00000001 fffff40f`f794f5d0 : nt!MiWalkPageTablesRecursively+0x88b 04 fffff804`21a3892b : ffffedf6`fb604000 ffff9c82`30772700 fffff40f`00000002 fffff40f`f794f5e0 : nt!MiWalkPageTablesRecursively+0x88b 05 fffff804`21a3592b : 00000000`c0000016 ffff9c82`30772700 00000000`00000003 fffff40f`f794f5f0 : nt!MiWalkPageTablesRecursively+0x88b 06 fffff804`21a9ed61 : fffff40f`f794f570 ffff9c82`00000000 00000000`00000002 00000000`00000000 : nt!MiWalkPageTables+0x36b 07 fffff804`21a48a68 : 00000000`00000001 ffff9c82`00000000 ffff9c82`30772550 ffff9c82`30e04080 : nt!MiDeletePagablePteRange+0x4f1 08 fffff804`21e4f469 : fffff40f`00000000 00000000`00000000 00004f44`00000000 ffff9c82`30772080 : nt!MiDeleteVad+0x378 09 fffff804`21e4f242 : ffff9c82`30f2d0a0 00000000`00000000 ffff9c82`30772080 00000000`00000000 : nt!MiUnmapVad+0x49 0a fffff804`21e4f0b9 : 000000d5`a2dff428 7fffffff`00000004 00004f44`00290280 00000000`00000000 : nt!MiUnmapViewOfSection+0x152 0b fffff804`21c12305 : ffff9c82`30e04080 00000275`55fa0000 fffff40f`f794fac0 ffff9c82`30772080 : nt!NtUnmapViewOfSectionEx+0x99 0c 00007ff9`8e630f14 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x25 0d 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ff9`8e630f14 Machine ID Information [From Smbios 3.6, DMIVersion 0, Size=5033] BiosMajorRelease = 5 BiosMinorRelease = 27 BiosVendor = American Megatrends International, LLC. BiosVersion = F4d BiosReleaseDate = 08/09/2024 SystemManufacturer = Gigabyte Technology Co., Ltd. SystemProductName = H610M H V2 SystemFamily = H610 MB SystemVersion = -CF SystemSKU = Default string BaseBoardManufacturer = Gigabyte Technology Co., Ltd. BaseBoardProduct = H610M H V2 BaseBoardVersion = x.x [SMBIOS Data Tables v3.6] [DMI Version - 0] [2.0 Calling Convention - No] [Table Size - 5033 bytes] [BIOS Information (Type 0) - Length 26 - Handle 0000h] Vendor American Megatrends International, LLC. BIOS Version F4d BIOS Starting Address Segment f000 BIOS Release Date 08/09/2024 BIOS ROM Size 1000000 BIOS Characteristics 07: - PCI Supported 11: - Upgradeable FLASH BIOS 12: - BIOS Shadowing Supported 15: - CD-Boot Supported 16: - Selectable Boot Supported 17: - BIOS ROM Socketed 19: - EDD Supported 20: - NEC 9800 J-Floppy Supported 21: - Toshiba J-Floppy Supported 22: - 360KB Floppy Supported 23: - 1.2MB Floppy Supported 24: - 720KB Floppy Supported 25: - 2.88MB Floppy Supported 26: - Print Screen Device Supported 28: - Serial Services Supported 29: - Printer Services Supported 30: - CGA/Mono Services Supported 32: - BIOS Vendor Reserved BIOS Characteristic Extensions 00: - ACPI Supported 01: - USB Legacy Supported 08: - BIOS Boot Specification Supported 10: - Enable Targeted Content Distribution 11: - UEFI Specification Supported BIOS Major Revision 5 BIOS Minor Revision 27 EC Firmware Major Revision 255 EC Firmware Minor Revision 255 Extended BIOS ROM Size 16 MB [System Information (Type 1) - Length 27 - Handle 0001h] Manufacturer Gigabyte Technology Co., Ltd. Product Name H610M H V2 Version -CF Serial Number Default string UUID 00000000-0000-0000-0000-000000000000 Wakeup Type Power Switch SKUNumber Default string Family H610 MB [BaseBoard Information (Type 2) - Length 15 - Handle 0002h] Manufacturer Gigabyte Technology Co., Ltd. Product H610M H V2 Version x.x Serial Number Default string Asset Tag Feature Flags 09h 00: - Motherboard 03: - Replaceable Location Default string Chassis Handle 0003h Board Type 0ah - Processor/Memory Module Number of Child Handles 0 [System Enclosure (Type 3) - Length 22 - Handle 0003h] Manufacturer Default string Chassis Type Desktop Version Default string Serial Number Asset Tag Number Bootup State Safe Power Supply State Safe Thermal State Safe Security Status None OEM Defined 0 Height 0U Number of Power Cords 1 Number of Contained Elements 0 Contained Element Size 3 [Onboard Devices Information (Type 10) - Length 6 - Handle 0021h] Note: The On Board Device Information (Type 10) struct is obsolete as of SMBIOs spec v2.6 Number of Devices 1 01: Type Video [enabled] 01: Description To Be Filled By O.E.M. [OEM Strings (Type 11) - Length 5 - Handle 0022h] Number of Strings 1 1 Default string [System Configuration Options (Type 12) - Length 5 - Handle 0023h] [ (Type 256) - Length 9 - Handle 003ah] [Physical Memory Array (Type 16) - Length 23 - Handle 003bh] Location 03h - SystemBoard/Motherboard Use 03h - System Memory Memory Error Correction 03h - None Maximum Capacity 67108864KB Memory Error Inf Handle [Not Provided] Number of Memory Devices 2 [Memory Device (Type 17) - Length 92 - Handle 003ch] Memory Error Info Handle [Not Provided] Total Width 64 bits Data Width 64 bits Size 16384MB Form Factor 09h - DIMM Device Set [None] Device Locator DDR5-A1 Bank Locator BANK 0 Memory Type 22h - DDR5 Type Detail 0080h - Synchronous Speed 5600MHz Manufacturer Crucial Technology Serial Number Asset Tag Number Part Number CP16G56C46U5.C8B2 Attributes 1 Extended Size 0 Configured Memory Speed 4800 Minimum Voltage 1100 Maximum Voltage 2950 Configured Voltage 1100 Memory Technology 3 Memory Operating Mode Capability 8 Firmware Version 0 Module Manufacturer Id 39813 Module Product Id 0 Memory Subsystem Controller Manufacturer Id 0 Memory Subsystem Controller Product Id 0 Non-Volatile Size 0 Volatile Size 0 Cache Size 0 Logical Size 0 Extended Speed 0 Extended Configured Memory Speed 0 [Memory Device (Type 17) - Length 92 - Handle 003dh] Memory Error Info Handle [Not Provided] Total Width 64 bits Data Width 64 bits Size 16384MB Form Factor 09h - DIMM Device Set [None] Device Locator DDR5-B1 Bank Locator BANK 0 Memory Type 22h - DDR5 Type Detail 0080h - Synchronous Speed 5600MHz Manufacturer Crucial Technology Serial Number Asset Tag Number Part Number CP16G56C46U5.C8B2 Attributes 1 Extended Size 0 Configured Memory Speed 4800 Minimum Voltage 1100 Maximum Voltage 2950 Configured Voltage 1100 Memory Technology 3 Memory Operating Mode Capability 8 Firmware Version 0 Module Manufacturer Id 39813 Module Product Id 0 Memory Subsystem Controller Manufacturer Id 0 Memory Subsystem Controller Product Id 0 Non-Volatile Size 0 Volatile Size 0 Cache Size 0 Logical Size 0 Extended Speed 0 Extended Configured Memory Speed 0 [Memory Array Mapped Address (Type 19) - Length 31 - Handle 003eh] Starting Address 00000000h Ending Address ffffffffh Memory Array Handle 003bh Partition Width 02 Extended Starting Address 0000000000000000h Extended Ending Address 0000000000000000h [ (Type 256) - Length 31 - Handle 003fh] [ (Type 256) - Length 26 - Handle 0040h] [Memory Device Mapped Address (Type 20) - Length 35 - Handle 0041h] Starting Address 00000000h Ending Address 00ffffffh Memory Device Handle 003ch Mem Array Mapped Adr Handle 003eh Partition Row Position [Unknown] Extended Starting Address 0000000000000000h Extended Ending Address 0000000000000000h [Memory Device Mapped Address (Type 20) - Length 35 - Handle 0042h] Starting Address 01000000h Ending Address 01ffffffh Memory Device Handle 003dh Mem Array Mapped Adr Handle 003eh Partition Row Position [Unknown] Extended Starting Address 0000000000000000h Extended Ending Address 0000000000000000h [ (Type 256) - Length 12 - Handle 0043h] [ (Type 256) - Length 26 - Handle 0044h] [ (Type 256) - Length 26 - Handle 0045h] [ (Type 256) - Length 47 - Handle 0046h] [ (Type 256) - Length 82 - Handle 0047h] [Cache Information (Type 7) - Length 27 - Handle 0048h] Socket Designation L1 Cache Cache Configuration 0180h - WBEnabled Int NonSocketed L1 Maximum Cache Size 0120h - 288K Installed Size 0120h - 288K Supported SRAM Type 0020h - Synchronous Current SRAM Type 0020h - Synchronous Cache Speed 0ns Error Correction Type ParitySingle-Bit ECC System Cache Type Data Associativity 12-way Set-Associative Maximum Cache Size 2 120 - 00000288l Kb Installed Cache Size 2 120 - 00000288l Kb [Cache Information (Type 7) - Length 27 - Handle 0049h] Socket Designation L1 Cache Cache Configuration 0180h - WBEnabled Int NonSocketed L1 Maximum Cache Size 00c0h - 192K Installed Size 00c0h - 192K Supported SRAM Type 0020h - Synchronous Current SRAM Type 0020h - Synchronous Cache Speed 0ns Error Correction Type ParitySingle-Bit ECC System Cache Type Instruction Associativity 8-way Set-Associative Maximum Cache Size 2 c0 - 00000192l Kb Installed Cache Size 2 c0 - 00000192l Kb [Cache Information (Type 7) - Length 27 - Handle 004ah] Socket Designation L2 Cache Cache Configuration 0181h - WBEnabled Int NonSocketed L2 Maximum Cache Size 1e00h - 7680K Installed Size 1e00h - 7680K Supported SRAM Type 0020h - Synchronous Current SRAM Type 0020h - Synchronous Cache Speed 0ns Error Correction Type Multi-Bit ECC System Cache Type Unified Associativity Other Maximum Cache Size 2 1e00 - 00007680l Kb Installed Cache Size 2 1e00 - 00007680l Kb [Cache Information (Type 7) - Length 27 - Handle 004bh] Socket Designation L3 Cache Cache Configuration 0182h - WBEnabled Int NonSocketed L3 Maximum Cache Size 5000h - 20480K Installed Size 5000h - 20480K Supported SRAM Type 0020h - Synchronous Current SRAM Type 0020h - Synchronous Cache Speed 0ns Error Correction Type Specification Reserved System Cache Type Unified Associativity Other Maximum Cache Size 2 5000 - 00020480l Kb Installed Cache Size 2 5000 - 00020480l Kb [Cache Information (Type 7) - Length 27 - Handle 004ch] Socket Designation L1 Cache Cache Configuration 0180h - WBEnabled Int NonSocketed L1 Maximum Cache Size 0080h - 128K Installed Size 0080h - 128K Supported SRAM Type 0020h - Synchronous Current SRAM Type 0020h - Synchronous Cache Speed 0ns Error Correction Type ParitySingle-Bit ECC System Cache Type Data Associativity 8-way Set-Associative Maximum Cache Size 2 80 - 00000128l Kb Installed Cache Size 2 80 - 00000128l Kb [Cache Information (Type 7) - Length 27 - Handle 004dh] Socket Designation L1 Cache Cache Configuration 0180h - WBEnabled Int NonSocketed L1 Maximum Cache Size 0100h - 256K Installed Size 0100h - 256K Supported SRAM Type 0020h - Synchronous Current SRAM Type 0020h - Synchronous Cache Speed 0ns Error Correction Type ParitySingle-Bit ECC System Cache Type Instruction Associativity 8-way Set-Associative Maximum Cache Size 2 100 - 00000256l Kb Installed Cache Size 2 100 - 00000256l Kb [Cache Information (Type 7) - Length 27 - Handle 004eh] Socket Designation L2 Cache Cache Configuration 0181h - WBEnabled Int NonSocketed L2 Maximum Cache Size 0800h - 2048K Installed Size 0800h - 2048K Supported SRAM Type 0020h - Synchronous Current SRAM Type 0020h - Synchronous Cache Speed 0ns Error Correction Type Multi-Bit ECC System Cache Type Unified Associativity 16-way Set-Associative Maximum Cache Size 2 800 - 00002048l Kb Installed Cache Size 2 800 - 00002048l Kb [Cache Information (Type 7) - Length 27 - Handle 004fh] Socket Designation L3 Cache Cache Configuration 0182h - WBEnabled Int NonSocketed L3 Maximum Cache Size 5000h - 20480K Installed Size 5000h - 20480K Supported SRAM Type 0020h - Synchronous Current SRAM Type 0020h - Synchronous Cache Speed 0ns Error Correction Type Specification Reserved System Cache Type Unified Associativity Other Maximum Cache Size 2 5000 - 00020480l Kb Installed Cache Size 2 5000 - 00020480l Kb [Processor Information (Type 4) - Length 48 - Handle 0050h] Socket Designation U3E1 Processor Type Central Processor Processor Family cdh - Intel Core 2 Solo processor Processor Manufacturer Intel(R) Corporation Processor ID 71060b00fffbebbf Processor Version Intel(R) Core(TM) i5-14400F Processor Voltage 89h - 0.9V External Clock 100MHz Max Speed 4700MHz Current Speed 2475MHz Status Enabled Populated Processor Upgrade Specification Reserved L1 Cache Handle 004dh L2 Cache Handle 004eh L3 Cache Handle 004fh Serial Number Asset Tag Number Part Number To Be Filled By O.E.M. Core Count 10 Core Enabled 10 Thread Count 16 Processor Characteristics fc Enabled Characteristics: 0x 2: 64-bit Capable 0x 3: Multi-Core 0x 4: Hardware Thread 0x 5: Execute Protection 0x 6: Enhanced Virtualization 0x 7: Power/Performance Control Processor Family 2 00cdh - Intel Core 2 Solo processor Core Count 2 10 Core Enabled 2 10 Thread Count 2 16 [ (Type 256) - Length 64 - Handle 0051h] [ (Type 256) - Length 11 - Handle 0052h] [ (Type 256) - Length 11 - Handle 0053h] [ (Type 256) - Length 11 - Handle 0054h] [ (Type 256) - Length 11 - Handle 0055h] [ (Type 256) - Length 11 - Handle 0056h] [ (Type 256) - Length 11 - Handle 0057h] [ (Type 256) - Length 11 - Handle 0058h] [ (Type 256) - Length 11 - Handle 0059h] [ (Type 256) - Length 11 - Handle 005ah] [ (Type 256) - Length 11 - Handle 005bh] [ (Type 256) - Length 11 - Handle 005ch] [ (Type 256) - Length 11 - Handle 005dh] [ (Type 256) - Length 11 - Handle 005eh] [ (Type 256) - Length 11 - Handle 005fh] [ (Type 256) - Length 11 - Handle 0060h] [ (Type 256) - Length 103 - Handle 0061h] [ (Type 256) - Length 44 - Handle 0062h] [ (Type 256) - Length 8 - Handle 0063h] [ (Type 256) - Length 106 - Handle 0067h] [ (Type 256) - Length 6 - Handle 0068h] [ (Type 256) - Length 4 - Handle 006ah] THREAD ffff9c8230e04080 Cid 2d80.1d70 Teb: 000000d5a252d000 Win32Thread: 0000000000000000 RUNNING on processor 2 Impersonation token: ffffb00bef47a060 (Level Impersonation) GetUlongFromAddress: unable to read from fffff8042241159c Owning Process ffff9c8230772080 Image: opera.exe Attached Process N/A Image: N/A fffff78000000000: Unable to get shared data Wait Start TickCount 282283 Context Switch Count 13 IdealProcessor: 2 ReadMemory error: Cannot get nt!KeMaximumIncrement value. UserTime 00:00:00.000 KernelTime 00:00:00.000 Win32 Start Address 0x00007ff6fe85ea70 Stack Init fffff40ff794fbd0 Current fffff40ff794e9a0 Base fffff40ff7950000 Limit fffff40ff7949000 Call 0000000000000000 Priority 9 BasePriority 8 IoPriority 2 PagePriority 5 Child-SP RetAddr : Args to Child : Call Site fffff40f`f794f048 fffff804`21aa04ca : 00000000`0000001a 00000000`00041792 ffffed81`3aae5480 00010000`00000000 : nt!KeBugCheckEx fffff40f`f794f050 fffff804`21a38816 : 00000000`00000000 00000000`00000000 00000000`00006b2a ffffed81`3aae5480 : nt!MiDeleteVa+0x153a fffff40f`f794f150 fffff804`21a3892b : ffffedf6`00000000 ffff9c82`30772700 fffff40f`00000000 fffff40f`f794f5c0 : nt!MiWalkPageTablesRecursively+0x776 fffff40f`f794f1f0 fffff804`21a3892b : ffffedf6`00000000 ffff9c82`30772700 fffff40f`00000001 fffff40f`f794f5d0 : nt!MiWalkPageTablesRecursively+0x88b fffff40f`f794f290 fffff804`21a3892b : ffffedf6`fb604000 ffff9c82`30772700 fffff40f`00000002 fffff40f`f794f5e0 : nt!MiWalkPageTablesRecursively+0x88b fffff40f`f794f330 fffff804`21a3592b : 00000000`c0000016 ffff9c82`30772700 00000000`00000003 fffff40f`f794f5f0 : nt!MiWalkPageTablesRecursively+0x88b fffff40f`f794f3d0 fffff804`21a9ed61 : fffff40f`f794f570 ffff9c82`00000000 00000000`00000002 00000000`00000000 : nt!MiWalkPageTables+0x36b fffff40f`f794f4d0 fffff804`21a48a68 : 00000000`00000001 ffff9c82`00000000 ffff9c82`30772550 ffff9c82`30e04080 : nt!MiDeletePagablePteRange+0x4f1 fffff40f`f794f7e0 fffff804`21e4f469 : fffff40f`00000000 00000000`00000000 00004f44`00000000 ffff9c82`30772080 : nt!MiDeleteVad+0x378 fffff40f`f794f8e0 fffff804`21e4f242 : ffff9c82`30f2d0a0 00000000`00000000 ffff9c82`30772080 00000000`00000000 : nt!MiUnmapVad+0x49 fffff40f`f794f910 fffff804`21e4f0b9 : 000000d5`a2dff428 7fffffff`00000004 00004f44`00290280 00000000`00000000 : nt!MiUnmapViewOfSection+0x152 fffff40f`f794f9f0 fffff804`21c12305 : ffff9c82`30e04080 00000275`55fa0000 fffff40f`f794fac0 ffff9c82`30772080 : nt!NtUnmapViewOfSectionEx+0x99 fffff40f`f794fa40 00007ff9`8e630f14 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x25 (TrapFrame @ fffff40f`f794fa40) 000000d5`a2dff358 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ff9`8e630f14
We use cookies and similar technologies for the following purposes:
Do you accept cookies and these technologies?
