MSI (s) (F4:90) [14:25:51:046]: MainEngineThread is returning 1603
MSI (s) (F4:BC) [14:25:51:051]: RESTART MANAGER: Session closed.
MSI (s) (F4:BC) [14:25:51:051]: No System Restore sequence number for this installation.
MSI (s) (F4:BC) [14:25:51:057]: User policy value 'DisableRollback' is 0
MSI (s) (F4:BC) [14:25:51:057]: Machine policy value 'DisableRollback' is 0
MSI (s) (F4:BC) [14:25:51:057]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (F4:BC) [14:25:51:057]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
MSI (s) (F4:BC) [14:25:51:059]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
MSI (s) (F4:BC) [14:25:51:060]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (s) (F4:BC) [14:25:51:062]: Destroying RemoteAPI object.
MSI (s) (F4:FC) [14:25:51:062]: Custom Action Manager thread ending.
MSI (c) (44:EC) [14:25:51:064]: Back from server. Return value: 1603
MSI (c) (44:EC) [14:25:51:066]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (c) (44:EC) [14:25:51:066]: PROPERTY CHANGE: Deleting SECONDSEQUENCE property. Its current value is '1'.
Action ended 14:25:51: ExecuteAction. Return value 3.
MSI (c) (44:EC) [14:25:51:066]: Doing action: FatalError
MSI (c) (44:EC) [14:25:51:066]: Note: 1: 2205 2: 3: ActionText
Action 14:25:51: FatalError.
Action start 14:25:51: FatalError.
Action 14:25:51: FatalError. Dialog created
Action ended 14:26:21: FatalError. Return value 2.
Action ended 14:26:21: INSTALL. Return value 3.
MSI (c) (44:EC) [14:26:21:663]: Destroying RemoteAPI object.
MSI (c) (44:08) [14:26:21:667]: Custom Action Manager thread ending.
Property(C): UpgradeCode = {BA4C629C-0F96-42AB-8E7F-6656B6BF3B5B}
Property(C): INSTALLFOLDER = C:\Users\emirc\AppData\Local\Programs\Paradox Interactive\launcher\
Property(C): LOCALAPPDATAFOLDER = C:\Users\emirc\AppData\Local\
Property(C): TEMPFOLDER = C:\Users\emirc\AppData\Local\Programs\Paradox Interactive\launcher\temp\
Property(C): LOCALAPPMANUFACTURERFOLDER = C:\Users\emirc\AppData\Local\Paradox Interactive\
Property(C): DesktopFolder = C:\Users\emirc\OneDrive\Masaüstü\
Property(C): ApplicationProgramsFolder = C:\Users\emirc\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Paradox Interactive\
Property(C): WixUIRMOption = UseRM
Property(C): WIXUI_INSTALLDIR = INSTALLFOLDER
Property(C): ALLUSERS = 2
Property(C): ARPNOMODIFY = 1
Property(C): FirstInstall = true
Property(C): LAUNCHERFOLDER = C:\Users\emirc\AppData\Local\Programs\Paradox Interactive\launcher\launcher-v2.2024.10\
Property(C): TARGETDIR = C:\
Property(C): PARADOXFOLDER = C:\Users\emirc\AppData\Local\Programs\Paradox Interactive\
Property(C): ProgramFiles64Folder = C:\Users\emirc\AppData\Local\Programs\
Property(C): ProgramMenuFolder = C:\Users\emirc\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\
Property(C): SourceDir = C:\
Property(C): MSIINSTALLPERUSER = 1
Property(C): ARPPRODUCTICON = ParadoxIcon
Property(C): LAUNCHERPATH_FILENAME = launcherpath
Property(C): BETA_BRANCH_NAME = none
Property(C): Manufacturer = Paradox Interactive
Property(C): ProductCode = {793B3A43-FAE3-4BAD-BA95-9D43E1F845F3}
Property(C): ProductLanguage = 1033
Property(C): ProductName = Paradox Launcher v2
Property(C): ProductVersion = 2.4.0
Property(C): DefaultUIFont = WixUI_Font_Normal
Property(C): WixUI_Mode = InstallDir
Property(C): ErrorDialog = ErrorDlg
Property(C): SecureCustomProperties = INSTALLFOLDER;OLD_INSTALLFOLDER;WIX_DOWNGRADE_DETECTED;WIX_UPGRADE_DETECTED
Property(C): TempFolder = C:\Users\emirc\AppData\Local\Temp\
Property(C): MsiLogFileLocation = C:\paradox.txt
Property(C): PackageCode = {42ABA535-DAD4-4612-AAB5-8B3DA570DCCE}
Property(C): ProductState = -1
Property(C): PackagecodeChanging = 1
Property(C): CURRENTDIRECTORY = C:\WINDOWS\system32
Property(C): CLIENTUILEVEL = 0
Property(C): CLIENTPROCESSID = 6212
Property(C): VersionDatabase = 200
Property(C): VersionMsi = 5.00
Property(C): VersionNT = 603
Property(C): VersionNT64 = 603
Property(C): WindowsBuild = 9600
Property(C): ServicePackLevel = 0
Property(C): ServicePackLevelMinor = 0
Property(C): MsiNTProductType = 1
Property(C): WindowsFolder = C:\WINDOWS\
Property(C): WindowsVolume = C:\
Property(C): System64Folder = C:\WINDOWS\system32\
Property(C): SystemFolder = C:\WINDOWS\SysWOW64\
Property(C): RemoteAdminTS = 1
Property(C): ProgramFilesFolder = C:\Users\emirc\AppData\Local\Programs\
Property(C): CommonFilesFolder = C:\Users\emirc\AppData\Local\Programs\Common\
Property(C): CommonFiles64Folder = C:\Users\emirc\AppData\Local\Programs\Common\
Property(C): AppDataFolder = C:\Users\emirc\AppData\Roaming\
Property(C): FavoritesFolder = C:\Users\emirc\Favorites\
Property(C): NetHoodFolder = C:\Users\emirc\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
Property(C): PersonalFolder = C:\Users\emirc\OneDrive\Belgeler\
Property(C): PrintHoodFolder = C:\Users\emirc\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
Property(C): RecentFolder = C:\Users\emirc\AppData\Roaming\Microsoft\Windows\Recent\
Property(C): SendToFolder = C:\Users\emirc\AppData\Roaming\Microsoft\Windows\SendTo\
Property(C): TemplateFolder = C:\Users\emirc\AppData\Roaming\Microsoft\Windows\Templates\
Property(C): CommonAppDataFolder = C:\ProgramData\
Property(C): LocalAppDataFolder = C:\Users\emirc\AppData\Local\
Property(C): MyPicturesFolder = C:\Users\emirc\OneDrive\Resimler\
Property(C): AdminToolsFolder = C:\Users\emirc\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
Property(C): StartupFolder = C:\Users\emirc\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\
Property(C): StartMenuFolder = C:\Users\emirc\AppData\Roaming\Microsoft\Windows\Start Menu\
Property(C): FontsFolder = C:\WINDOWS\Fonts\
Property(C): GPTSupport = 1
Property(C): OLEAdvtSupport = 1
Property(C): ShellAdvtSupport = 1
Property(C): MsiAMD64 = 6
Property(C): Msix64 = 6
Property(C): Intel = 6
Property(C): PhysicalMemory = 3917
Property(C): VirtualMemory = 1949
Property(C): LogonUser = emirc
Property(C): UserSID = S-1-5-21-4200721547-2697278659-3053462418-1001
Property(C): UserLanguageID = 1055
Property(C): ComputerName = EMIRPC
Property(C): SystemLanguageID = 1033
Property(C): ScreenX = 1280
Property(C): ScreenY = 1024
Property(C): CaptionHeight = 23
Property(C): BorderTop = 1
Property(C): BorderSide = 1
Property(C): TextHeight = 16
Property(C): TextInternalLeading = 3
Property(C): ColorBits = 32
Property(C): TTCSupport = 1
Property(C): Time = 14:26:21
Property(C): Date = 13.07.2024
Property(C): MsiNetAssemblySupport = 4.8.9037.0
Property(C): MsiWin32AssemblySupport = 6.3.19041.3636
Property(C): RedirectedDllSupport = 2
Property(C): USERNAME = emircanekinci650@outlook.com
Property(C): DATABASE = C:\paradox.msi
Property(C): OriginalDatabase = C:\paradox.msi
Property(C): SOURCEDIR = C:\
Property(C): VersionHandler = 5.00
Property(C): UILevel = 5
Property(C): ACTION = INSTALL
Property(C): EXECUTEACTION = INSTALL
Property(C): ROOTDRIVE = C:\
Property(C): CostingComplete = 1
Property(C): OutOfDiskSpace = 0
Property(C): OutOfNoRbDiskSpace = 0
Property(C): PrimaryVolumeSpaceAvailable = 0
Property(C): PrimaryVolumeSpaceRequired = 0
Property(C): PrimaryVolumeSpaceRemaining = 0
Property(C): INSTALLLEVEL = 1
Property(C): WIXUI_INSTALLDIR_VALID = 1
=== Logging stopped: 13.07.2024 14:26:21 ===
MSI (c) (44:EC) [14:26:21:691]: Note: 1: 1708
MSI (c) (44:EC) [14:26:21:692]: Note: 1: 2205 2: 3: Error
MSI (c) (44:EC) [14:26:21:692]: Note: 1: 2228 2: 3: Error 4: SELECT `Message` FROM `Error` WHERE `Error` = 1708
MSI (c) (44:EC) [14:26:21:692]: Note: 1: 2228 2: 3: Error 4: SELECT `Message` FROM `Error` WHERE `Error` = 1709
MSI (c) (44:EC) [14:26:21:692]: Product: Paradox Launcher v2 -- Installation failed.
MSI (c) (44:EC) [14:26:21:694]: Windows Installer installed the product. Product Name: Paradox Launcher v2. Product Version: 2.4.0. Product Language: 1033. Manufacturer: Paradox Interactive. Installation success or error status: 1603.
MSI (c) (44:EC) [14:26:21:696]: Grabbed execution mutex.
MSI (c) (44:EC) [14:26:21:696]: Cleaning up uninstalled install packages, if any exist
MSI (c) (44:EC) [14:26:21:697]: MainEngineThread is returning 1603
=== Verbose logging stopped: 13.07.2024 14:26:21 ===
