Rehber Popüler DNS sunucuları için ping testi
Merhaba Techolay ailesi, bugün sizlere popüler DNS sunucularının ping testini nasıl yapacağınızı göstereceğim.
Boş bir not defteri açarak aşağıdaki kodu yapıştırıyoruz.
Kod:
:Start
@Echo off
setlocal
call :setESC
title Techolay.net
ECHO.
ECHO. ------------------------------------------------
ECHO.                   TECHOLAY.NET
ECHO. ------------------------------------------------ && ECHO.     Populer DNS sunuculari icin ping testi
ECHO. ------------------------------------------------ && ECHO.  + CloudFlare
Call:CloudFlare 1.1.1.1
ECHO   %ESC%[96m DNS%ESC%[0m Gecikmesi:    %ESC%[95m %ESC%[95m %ms%%ESC%[0m%ESC%[0m
ECHO. ------------------------------------------------ && ECHO.  + Google
Call:Google 8.8.8.8
ECHO   %ESC%[96m DNS%ESC%[0m Gecikmesi:    %ESC%[95m %ms%%ESC%[0m
ECHO. ------------------------------------------------ && ECHO.  + YandexDNS
Call:YandexDNS 77.88.8.8
ECHO. ------------------------------------------------ && ECHO.  + Adguard
Call:Adguard 94.140.14.14
ECHO. ------------------------------------------------ && ECHO.  + Quad9
Call:Quad9 9.9.9.9
ECHO. ------------------------------------------------ && ECHO.  + Norton
Call:Norton 199.85.126.10
ECHO. ------------------------------------------------ && ECHO.  + Verisign
Call:Verisign 64.6.64.6
ECHO. ------------------------------------------------ && ECHO.  + OpenDNSHome
Call:OpenDNSHome 208.67.222.222
ECHO. ------------------------------------------------ && ECHO.  + ControlD
Call:ControlD 76.76.2.0
ECHO. ------------------------------------------------ && ECHO.  + Alternate
Call:Alternate 76.76.19.19
ECHO. ------------------------------------------------ && ECHO.  + CleanBrowsing
Call:CleanBrowsing 185.228.168.9
ECHO. ------------------------------------------------ && ECHO.  + Level3
Call:Level3 209.244.0.3
ECHO. ------------------------------------------------ && ECHO.  + DNSWATCH
Call:DNSWATCH 84.200.69.80
ECHO. ------------------------------------------------ && ECHO.  + Advantage
Call:Advantage 156.154.70.1
ECHO. Bu Scripti kapatabilirsiniz...
pause
cls
goto Start
:CloudFlare
:Google
:YandexDNS
:Adguard
:Quad9
:Norton
:Verisign
:OpenDNSHome
:ControlD
:Alternate
:CleanBrowsing
:Level3
:DNSWATCH
:Advantage
SET ms=Hata
FOR /F "tokens=4 delims==" %%i IN ('ping.exe -n 1 %1 ^| FIND "ms"') DO SET ms=%%i
GOTO:EOF
:setESC
for /F "tokens=1,2 delims=#" %%a in ('"prompt #$H#$E# & echo on & for %%b in (1) do rem"') do (
  set ESC=%%b
  exit /B 0
exit /B 0
Kodu yapıştırdıktan sonra "Dosya > Farklı kaydet" seçeneğine tıklıyoruz.
Açılan pencerede,
Dosya adı: Herhangibirsey.bat (uzantısı mutlaka .bat olmalı).
Kayıt türü: Tüm dosyalar (.).
Bu şekilde kaydettikten sonra .bat dosyamızı çalıştırıyoruz.
Evet artık en çok tercih edilen DNS sunucularına bağlantı gecikmelerinizi görebilir ve tercihinize göre DNS adresinizi değiştirebilirsiniz.
Yorumlarınızı ve beğenilerinizi bekliyorum. İyi sosyaller!
Harika bir rehber. Cloudflare 17 ms gözüküyor. Hemen geçiş yaptım.
Goodbye Yandex kullanıyor ping değerleri havada uçuyor. Birkaç kurcalama ile Cloudflare'ye çektim.
Güzel DNS benchmark rehberi olmuş, eline sağlık.
Teşekkür ederim. Aklıma gelen adresler şu anlık bunlar.
İsteğe bağlı arkadaşlar internet üzerinden farklı DNS sağlayıcılarına bakıp kod içerisine ekleyebilirler.
Program açılmıyor, tıkladığımda açılıp hemen kapanıyor. Ayrıca not defterini açınca her şey silinmiş görünüyor. Nerede hata yapıyorum?
En başta "iki nokta" var onu eklememiş olabilir misiniz?
Evet, onu koymayı unutmuşum. Program şu an açıldı. En düşük ping Cloudflare'de 3 ms olarak görünüyor, zaten onu kullanıyorum. Program gerçekten işe yarıyor, teşekkür ederim. Bu tür faydalı programların devamı gelsin.
Nasıl yapıldığını rehber olarak paylaşırsanız çok iyi olur hocam, herkes bilgilenir.
Elinize sağlık, bilgilendirici bir rehber olmuş.
