ATTEMPTED_WRITE_TO_READONLY_MEMORY (be)
An attempt was made to write to readonly memory. The guilty driver is on the
stack trace (and is typically the current instruction pointer).
When possible, the guilty driver's name (Unicode string) is printed on
the BugCheck screen and saved in KiBugCheckDriver.
Arguments:
Arg1: ffffd8fc0f615000, Virtual address for the attempted write.
Arg2: 8a00000004100121, PTE contents.
Arg3: ffffde0b0de6eba0, (reserved)
Arg4: 000000000000000b, (reserved)
6: kd> !pte ffffd8fc0f615000
VA ffffd8fc0f615000
PXE at FFFFF67B3D9ECD88 PPE at FFFFF67B3D9B1F80 PDE at FFFFF67B363F03D8 PTE at FFFFF66C7E07B0A8
contains 0A0000000083D863 contains 0A0000043A2D6863 contains 1A0000043A278863 contains 8A00000004100121 / 2.parametre değeri
pfn 83d ---DA--KWEV pfn 43a2d6 ---DA--KWEV pfn 43a278 ---DA--KWEV pfn 4100 -G--A--KR-V
6: kd> k
# Child-SP RetAddr Call Site
00 ffffde0b`0de6e8f8 fffff806`22e45667 nt!KeBugCheckEx
01 ffffde0b`0de6e900 fffff806`22c39790 nt!MiSystemFault+0x1cd107
02 ffffde0b`0de6ea00 fffff806`22e0e46d nt!MmAccessFault+0x400 < Geçersiz erişim!
03 ffffde0b`0de6eba0 fffff806`22e145f0 nt!KiPageFault+0x36d < Çökme
04 ffffde0b`0de6ed38 fffff806`22cbc6d8 nt!memset+0x30
05 ffffde0b`0de6ed40 fffff806`232d3537 nt!RtlClearBitsEx+0x98 < Belirtilen bellek aralığını temizle
06 ffffde0b`0de6ed70 fffff806`232d34bc nt!MiMarkRetpolineBits+0x63
07 ffffde0b`0de6eda0 fffff806`23212ec8 nt!MiMarkKernelImageRetpolineBits+0x34 ???
08 ffffde0b`0de6edd0 fffff806`23161361 nt!MiUnloadSystemImage+0x15e000 <
09 ffffde0b`0de6ef70 fffff806`2316128e nt!MmUnloadSystemImage+0x41 < Sistem imajını sil. Memory manager
0a ffffde0b`0de6efa0 fffff806`2302d970 nt!IopDeleteDriver+0x4e
0b ffffde0b`0de6eff0 fffff806`22c5ac67 nt!ObpRemoveObjectRoutine+0x80
0c ffffde0b`0de6f050 fffff806`22e20b7a nt!ObfDereferenceObjectWithTag+0xc7
0d ffffde0b`0de6f090 fffff806`22c49a32 nt!IopCompleteUnloadOrDelete+0x21da0a < İlgili objenin kaldırıldığını bildir
0e ffffde0b`0de6f150 fffff806`2302a2c0 nt!IopDecrementDeviceObjectRef+0x162 < Device Object referansını düşür. Objenin kullanılmadığını bildir
0f ffffde0b`0de6f1b0 fffff806`2302d970 nt!IopDeleteFile+0x210 < Dosyayı kaldır
10 ffffde0b`0de6f230 fffff806`22c5ac67 nt!ObpRemoveObjectRoutine+0x80 < Objeyi Kaldır
11 ffffde0b`0de6f290 fffff806`230331d9 nt!ObfDereferenceObjectWithTag+0xc7 < Objeyi 0'a ayarla
12 ffffde0b`0de6f2d0 fffff806`2302df1c nt!ObCloseHandleTableEntry+0x6c9 < NtClose tarafından çağırılan ve handle tablo girişini kapatır
13 ffffde0b`0de6f410 fffff806`22e12b0b nt!NtClose+0xec < İlgili objenin handle'ını kapat
14 ffffde0b`0de6f480 00007fff`c6f8d744 nt!KiSystemServiceExitPico+0x41f
15 0000007b`15bfe528 00000000`00000000 0x00007fff`c6f8d744 < Kullanıcı modundan gelen bir çağrı
nt!IopDeleteDriver fonksiyonu ile beraber tutulanan sürücü nesnesinden bulabiliriz.07 ffffde0b0de6efa0 nt!IopDeleteDriver+8x
Parameter[0] = ffffb30468fdf530 < Sürücü nesnesi.
Parameter[1] = (unknown)
Parameter[2] = (unknown)
Parameter[3] = (unknown)
6: kd> !drvobj ffffb30468fdf530
Driver object (ffffb30468fdf530) is for:
\FileSystem\EAAntiCheat
Driver Extension List: (id , addr)
6: kd> lmvmEAAntiCheat
Browse full module list
start end module name
fffff80a`7e4f0000 fffff80a`80491000 eaanticheat T (no symbols)
Loaded symbol image file: eaanticheat.sys
Image path: \SystemRoot\system32\drivers\eaanticheat.sys
Image name: eaanticheat.sys
Browse all global symbols functions data
Timestamp: Fri Sep 6 05:24:14 2024 (66DA67CE)
CheckSum: 01FE3103
ImageSize: 01FA1000
Translations: 0000.04b0 0000.04e4 0409.04b0 0409.04e4
Information from resource tables:
* Bugcheck Analysis *
Arguments:
Debugging Details:
KEY_VALUES_STRING: 1
Key : Analysis.CPU.mSec
Value: 3468
Key : Analysis.Elapsed.mSec
Value: 19800
Key : Analysis.IO.Other.Mb
Value: 0
Key : Analysis.IO.Read.Mb
Value: 0
Key : Analysis.IO.Write.Mb
Value: 0
Key : Analysis.Init.CPU.mSec
Value: 312
Value: 2725
Value: 82
Key : Analysis.Version.DbgEng
Value: 10.0.27704.1001
Key : Analysis.Version.Description
Value: 10.2408.27.01 amd64fre
Key : Analysis.Version.Ext
Value: 1.2408.27.1
Key : Bugcheck.Code.LegacyAPI
Value: 0xbe
Key : Bugcheck.Code.TargetModel
Value: 0xbe
Key : Failure.Bucket
Value: AV_nt!MiSystemFault
Key : Failure.Hash
Value: {d80c40a2-5000-439f-696b-1bd8abb14be3}
Key : WER.OS.Branch
Value: vb_release
Key : WER.OS.Version
Value: 10.0.19041.1
BUGCHECK_CODE: be
BUGCHECK_P1: ffffd8fc0f615000
BUGCHECK_P2: 8a00000004100121
BUGCHECK_P3: ffffde0b0de6eba0
BUGCHECK_P4: b
FILE_IN_CAB: 100724-11156-01.dmp
FAULTING_THREAD: ffffb3046d298080
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: EAAntiCheat.GameService.exe
TRAP_FRAME: ffffde0b0de6eba0 -- (.trap 0xffffde0b0de6eba0)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=ffffd8fc0f614fca rbx=0000000000000000 rcx=ffffd8fc0f615002
rdx=0000000000000000 rsi=0000000000000000 rdi=0000000000000000
rip=fffff80622e145f0 rsp=ffffde0b0de6ed38 rbp=ffffde0b0de6eed0
r8=000000000000003f r9=0000000000000038 r10=ffffd8fc0f615008
r11=00000000780a8049 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei ng nz ac pe nc
nt!memset+0x30:
fffff806`22e145f0 4a895408f8 mov qword ptr [rax+r9-8],rdx ds:ffffd8fc`0f614ffa=????????????????
Resetting default scope
STACK_TEXT:
ffffde0b`0de6e8f8 fffff806`22e45667 : 00000000`000000be ffffd8fc`0f615000 8a000000`04100121 ffffde0b`0de6eba0 : nt!KeBugCheckEx
ffffde0b`0de6e900 fffff806`22c39790 : 00000000`00000005 00000000`00000003 ffffde0b`0de6ec20 00000000`00000000 : nt!MiSystemFault+0x1cd107
ffffde0b`0de6ea00 fffff806`22e0e46d : ffffffff`ffffffff 00000000`00000001 ffffc900`4b640180 fffff806`22ca3d05 : nt!MmAccessFault+0x400
ffffde0b`0de6eba0 fffff806`22e145f0 : fffff806`22cbc6d8 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiPageFault+0x36d
ffffde0b`0de6ed38 fffff806`22cbc6d8 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!memset+0x30
ffffde0b`0de6ed40 fffff806`232d3537 : 00000000`000001fb 00000000`780a804a 00000000`780a7e4f 00000000`0000000f : nt!RtlClearBitsEx+0x98
ffffde0b`0de6ed70 fffff806`232d34bc : ffffb304`6de24a20 00000000`00000001 00000000`00000000 00000000`00001fa1 : nt!MiMarkRetpolineBits+0x63
ffffde0b`0de6eda0 fffff806`23212ec8 : ffffb304`6de24a20 ffffb304`6de24a20 ffffde0b`0de6eed0 00000000`00000001 : nt!MiMarkKernelImageRetpolineBits+0x34
ffffde0b`0de6edd0 fffff806`23161361 : 00000000`00000000 fffff806`ffffffff ffff98ff`00000001 ffffe307`1b690cc0 : nt!MiUnloadSystemImage+0x15e000
ffffde0b`0de6ef70 fffff806`2316128e : ffffb304`68fdf500 ffffde0b`0de6f110 00000000`00000000 ffffb304`68fdf530 : nt!MmUnloadSystemImage+0x41
ffffde0b`0de6efa0 fffff806`2302d970 : ffffb304`68fdf500 ffffde0b`0de6f110 fffff806`23725400 ffffde0b`0de6f010 : nt!IopDeleteDriver+0x4e
ffffde0b`0de6eff0 fffff806`22c5ac67 : 00000000`00000000 00000000`00000000 ffffde0b`0de6f110 ffffb304`68fdf530 : nt!ObpRemoveObjectRoutine+0x80
ffffde0b`0de6f050 fffff806`22e20b7a : 00000000`00000000 ffffb304`68fdf530 369634f3`00000000 ffffde0b`0de6ef00 : nt!ObfDereferenceObjectWithTag+0xc7
ffffde0b`0de6f090 fffff806`22c49a32 : ffffb304`52ffcf00 ffffb304`6a8ab000 ffffc900`4b4e4910 fffff806`22c4ad55 : nt!IopCompleteUnloadOrDelete+0x21da0a
ffffde0b`0de6f150 fffff806`2302a2c0 : ffffb304`78355610 00000000`00000000 00000000`00000000 fffff806`22c52a59 : nt!IopDecrementDeviceObjectRef+0x162
ffffde0b`0de6f1b0 fffff806`2302d970 : ffffb304`52ffcf00 00000000`00000001 ffffb304`783555e0 ffffb304`675ef740 : nt!IopDeleteFile+0x210
ffffde0b`0de6f230 fffff806`22c5ac67 : 00000000`00000000 00000000`00000000 ffffde0b`0de6f3b9 ffffb304`78355610 : nt!ObpRemoveObjectRoutine+0x80
ffffde0b`0de6f290 fffff806`230331d9 : ffffb304`783555e0 00000000`00000000 ffffe306`00000000 ffffb304`783555e0 : nt!ObfDereferenceObjectWithTag+0xc7
ffffde0b`0de6f2d0 fffff806`2302df1c : 00000000`00000688 ffff98ff`95c9e15e ffffb304`6d298080 fffff806`22e12ae6 : nt!ObCloseHandleTableEntry+0x6c9
ffffde0b`0de6f410 fffff806`22e12b0b : ffffb304`6d298000 000001bb`8da00000 ffffde0b`0de6f500 ffffffff`fe363c80 : nt!NtClose+0xec
ffffde0b`0de6f480 00007fff`c6f8d744 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceExitPico+0x41f
0000007b`15bfe528 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007fff`c6f8d744
SYMBOL_NAME: nt!MiSystemFault+1cd107
MODULE_NAME: nt
IMAGE_VERSION: 10.0.19041.4894
STACK_COMMAND: .process /r /p 0xffffb3046a3ee080; .thread 0xffffb3046d298080 ; kb
IMAGE_NAME: ntkrnlmp.exe
BUCKET_ID_FUNC_OFFSET: 1cd107
FAILURE_BUCKET_ID: AV_nt!MiSystemFault
OS_VERSION: 10.0.19041.1
BUILDLAB_STR: vb_release
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {d80c40a2-5000-439f-696b-1bd8abb14be3}
Followup: MachineOwner
PnpActivityId : {00000000-0000-0000-0000-000000000000}
PnpActivityTime : 133727946613053254
PnpEventInformation: 3
PnpEventInProgress : 0
PnpProblemCode : 24
PnpVetoType : 0
DeviceId : USB\VID_0B05&PID_196E\6&419c674&0&1
VetoString :
fffff31a`e3c00000 fffff31a`e3ecc000 win32kbase (deferred)
fffff31a`e41c0000 fffff31a`e425b000 win32k (deferred)
fffff31a`e4650000 fffff31a`e4a01000 win32kfull (deferred)
fffff31a`e4a60000 fffff31a`e4aa9000 cdd (deferred)
fffff806`21740000 fffff806`21768000 mcupdate_AuthenticAMD (deferred)
fffff806`21770000 fffff806`21776000 hal (deferred)
fffff806`21780000 fffff806`2178b000 kd (deferred)
fffff806`21790000 fffff806`217b8000 tm (deferred)
fffff806`217c0000 fffff806`2182e000 CLFS (deferred)
fffff806`21830000 fffff806`2184a000 PSHED (deferred)
fffff806`21850000 fffff806`2185b000 BOOTVID (deferred)
fffff806`21860000 fffff806`21978000 clipsp (deferred)
fffff806`21980000 fffff806`219ee000 FLTMGR (deferred)
fffff806`219f0000 fffff806`21a19000 ksecdd (deferred)
fffff806`21a20000 fffff806`21a83000 msrpc (deferred)
fffff806`21a90000 fffff806`21a9e000 cmimcext (deferred)
fffff806`21aa0000 fffff806`21ab1000 werkernel (deferred)
fffff806`21ac0000 fffff806`21acc000 ntosext (deferred)
fffff806`21ad0000 fffff806`21ae3000 WDFLDR (deferred)
fffff806`21af0000 fffff806`21aff000 SleepStudyHelper (deferred)
fffff806`21b00000 fffff806`21b11000 WppRecorder (deferred)
fffff806`21b20000 fffff806`21b2d000 msseccore (deferred)
fffff806`21b30000 fffff806`21b3c000 WMILIB (deferred)
fffff806`22a00000 fffff806`23a46000 nt (pdb symbols) C:\ProgramData\Dbg\sym\ntkrnlmp.pdb\9F65CD18C2F36F88B2D0CE8A7BFE2BB71\ntkrnlmp.pdb
fffff806`27000000 fffff806`270ec000 CI (deferred)
fffff806`270f0000 fffff806`271ab000 cng (deferred)
fffff806`271b0000 fffff806`27281000 Wdf01000 (deferred)
fffff806`27290000 fffff806`272b6000 acpiex (deferred)
fffff806`272c0000 fffff806`272da000 SgrmAgent (deferred)
fffff806`272e0000 fffff806`273ac000 ACPI (deferred)
fffff806`273b0000 fffff806`273bb000 msisadrv (deferred)
fffff806`273d0000 fffff806`273e7000 WindowsTrustedRT (deferred)
fffff806`273f0000 fffff806`273fb000 IntelTA (deferred)
fffff806`27400000 fffff806`27478000 pci (deferred)
fffff806`27480000 fffff806`274c5000 tpm (deferred)
fffff806`274d0000 fffff806`2753b000 intelpep (deferred)
fffff806`27540000 fffff806`2754b000 WindowsTrustedRTProxy (deferred)
fffff806`27550000 fffff806`27564000 pcw (deferred)
fffff806`27570000 fffff806`27585000 vdrvroot (deferred)
fffff806`27590000 fffff806`275a9000 amdkmpfd (deferred)
fffff806`275b0000 fffff806`275e0000 pdc (deferred)
fffff806`275f0000 fffff806`27609000 CEA (deferred)
fffff806`27610000 fffff806`27641000 partmgr (deferred)
fffff806`27650000 fffff806`276fb000 spaceport (deferred)
fffff806`27700000 fffff806`27719000 volmgr (deferred)
fffff806`27720000 fffff806`27783000 volmgrx (deferred)
fffff806`27790000 fffff806`277ae000 mountmgr (deferred)
fffff806`277b0000 fffff806`277e2000 storahci (deferred)
fffff806`277f0000 fffff806`278a5000 storport (deferred)
fffff806`278b0000 fffff806`278cc000 EhStorClass (deferred)
fffff806`278d0000 fffff806`278ea000 fileinfo (deferred)
fffff806`278f0000 fffff806`27930000 Wof (deferred)
fffff806`27940000 fffff806`279d6000 WdFilter (deferred)
fffff806`279e0000 fffff806`27cb7000 Ntfs (deferred)
fffff806`27cc0000 fffff806`27ccd000 Fs_Rec (deferred)
fffff806`27cd0000 fffff806`27e40000 ndis (deferred)
fffff806`27e50000 fffff806`27eec000 NETIO (deferred)
fffff806`27ef0000 fffff806`27f22000 ksecpkg (deferred)
fffff806`27f30000 fffff806`27f40000 amdpsp (deferred)
fffff806`27f50000 fffff806`27fcf000 fwpkclnt (deferred)
fffff806`27fd0000 fffff806`27fdb000 volume (deferred)
fffff806`27fe0000 fffff806`27ff2000 iorate (deferred)
fffff806`28000000 fffff806`282ed000 tcpip (deferred)
fffff806`282f0000 fffff806`28320000 wfplwfs (deferred)
fffff806`28330000 fffff806`283f9000 fvevol (deferred)
fffff806`28400000 fffff806`2846d000 volsnap (deferred)
fffff806`28470000 fffff806`284c0000 rdyboost (deferred)
fffff806`284d0000 fffff806`284f6000 mup (deferred)
fffff806`28520000 fffff806`2853d000 disk (deferred)
fffff806`28540000 fffff806`285b2000 CLASSPNP (deferred)
fffff806`6b000000 fffff806`6b094000 mrxsmb (deferred)
fffff806`6b0e0000 fffff806`6b158000 ks (deferred)
fffff806`6b160000 fffff806`6b1fd000 USBXHCI (deferred)
fffff806`6b200000 fffff806`6b213000 mouclass (deferred)
fffff806`6b220000 fffff806`6b23c000 serial (deferred)
fffff806`6b240000 fffff806`6b24c000 wmiacpi (deferred)
fffff806`6b250000 fffff806`6b25d000 amdgpio2 (deferred)
fffff806`6b260000 fffff806`6b292000 msgpioclx (deferred)
fffff806`6b2a0000 fffff806`6b2dc000 amdppm (deferred)
fffff806`6b2e0000 fffff806`6b2ea000 amdgpio3 (deferred)
fffff806`6b2f0000 fffff806`6b2fe000 UEFI (deferred)
fffff806`6b300000 fffff806`6b30a000 amdfendrmgr (deferred)
fffff806`6b310000 fffff806`6b31d000 NdisVirtualBus (deferred)
fffff806`6b320000 fffff806`6b32c000 swenum (deferred)
fffff806`6b330000 fffff806`6b33e000 rdpbus (deferred)
fffff806`6b340000 fffff806`6b3e3000 UsbHub3 (deferred)
fffff806`6b3f0000 fffff806`6b3fe000 USBD (deferred)
fffff806`6b400000 fffff806`6b43e000 AtihdWT6 (deferred)
fffff806`6b440000 fffff806`6b4af000 HdAudio (deferred)
fffff806`6b4f0000 fffff806`6b522000 dump_storahci (deferred)
fffff806`6b550000 fffff806`6b56d000 dump_dumpfve (deferred)
fffff806`6b570000 fffff806`6b583000 hidparse (deferred)
fffff806`6b710000 fffff806`6b744000 usbccgp (deferred)
fffff806`6b750000 fffff806`6b762000 hidusb (deferred)
fffff806`6b770000 fffff806`6b7b1000 HIDCLASS (deferred)
fffff806`6b7e0000 fffff806`6b7fe000 crashdmp (deferred)
fffff806`71000000 fffff806`713aa000 dxgkrnl (deferred)
fffff806`713b0000 fffff806`713c8000 watchdog (deferred)
fffff806`713d0000 fffff806`713e6000 BasicDisplay (deferred)
fffff806`713f0000 fffff806`71401000 BasicRender (deferred)
fffff806`71410000 fffff806`7142c000 Npfs (deferred)
fffff806`71430000 fffff806`71441000 Msfs (deferred)
fffff806`71450000 fffff806`7146e000 CimFS (deferred)
fffff806`71470000 fffff806`71492000 tdx (deferred)
fffff806`714a0000 fffff806`714b0000 TDI (deferred)
fffff806`714c0000 fffff806`7151c000 netbt (deferred)
fffff806`71520000 fffff806`71534000 afunix (deferred)
fffff806`71540000 fffff806`715e8000 afd (deferred)
fffff806`715f0000 fffff806`7160a000 vwififlt (deferred)
fffff806`71610000 fffff806`7163b000 pacer (deferred)
fffff806`71640000 fffff806`71654000 ndiscap (deferred)
fffff806`71660000 fffff806`71674000 netbios (deferred)
fffff806`71680000 fffff806`71721000 Vid (deferred)
fffff806`71730000 fffff806`71754000 winhvr (deferred)
fffff806`71760000 fffff806`717db000 rdbss (deferred)
fffff806`717e0000 fffff806`71875000 csc (deferred)
fffff806`71880000 fffff806`71892000 nsiproxy (deferred)
fffff806`718a0000 fffff806`718ae000 npsvctrig (deferred)
fffff806`718b0000 fffff806`718c0000 mssmbios (deferred)
fffff806`718d0000 fffff806`718d7000 MsIo64 (deferred)
fffff806`718e0000 fffff806`718ea000 gpuenergydrv (deferred)
fffff806`718f0000 fffff806`7191d000 dfsc (deferred)
fffff806`71920000 fffff806`71935000 umbus (deferred)
fffff806`71940000 fffff806`719ad000 fastfat (deferred)
fffff806`719b0000 fffff806`719bb000 CtiAIo64 (deferred)
fffff806`719c0000 fffff806`719d7000 bam (deferred)
fffff806`719e0000 fffff806`719ef000 AsIO3 (deferred)
fffff806`719f0000 fffff806`71a42000 ahcache (deferred)
fffff806`71a50000 fffff806`71a5f000 amdxe (deferred)
fffff806`71a60000 fffff806`71aba000 amdfendr (deferred)
fffff806`71ac0000 fffff806`71ad2000 CompositeBus (deferred)
fffff806`71ae0000 fffff806`71aed000 kdnic (deferred)
fffff806`71af0000 fffff806`71b0c000 amdsafd (deferred)
fffff806`71b20000 fffff806`71b2f000 dump_diskdump (deferred)
fffff806`71b40000 fffff806`71b54000 kbdclass (deferred)
fffff806`71b60000 fffff806`73688000 vgk (deferred)
fffff806`73690000 fffff806`736c0000 cdrom (deferred)
fffff806`736d0000 fffff806`736e5000 filecrypt (deferred)
fffff806`736f0000 fffff806`736fe000 tbs (deferred)
fffff806`73700000 fffff806`73715000 UCPD (deferred)
fffff806`73720000 fffff806`7372a000 Null (deferred)
fffff806`73730000 fffff806`7373a000 Beep (deferred)
fffff806`73740000 fffff806`737a8000 portcls (deferred)
fffff806`737b0000 fffff806`737d1000 drmk (deferred)
fffff806`737e0000 fffff806`737f1000 ksthunk (deferred)
fffff806`8ca00000 fffff806`8ca25000 HDAudBus (deferred)
fffff806`8ca30000 fffff806`8cb74000 rt640x64 (deferred)
fffff806`8cb80000 fffff806`8cbc4000 ucx01000 (deferred)
fffff806`8cbd0000 fffff806`935d0000 amdkmdag (deferred)
fffff806`935e0000 fffff806`935eb000 AMDPCIDev (deferred)
fffff806`935f0000 fffff806`935ff000 serenum (deferred)
fffff806`9c400000 fffff806`9c482000 cldflt (deferred)
fffff806`9c490000 fffff806`9c4aa000 storqosflt (deferred)
fffff806`9c4b0000 fffff806`9c4d8000 bindflt (deferred)
fffff806`9c4e0000 fffff806`9c4f8000 mslldp (deferred)
fffff806`9c500000 fffff806`9c518000 lltdio (deferred)
fffff806`9c520000 fffff806`9c53d000 wanarp (deferred)
fffff806`9c540000 fffff806`9c55b000 rspndr (deferred)
fffff806`9c560000 fffff806`9c5b6000 msquic (deferred)
fffff806`9c5c0000 fffff806`9c747000 HTTP (deferred)
fffff806`9c750000 fffff806`9c775000 bowser (deferred)
fffff806`9c780000 fffff806`9c860000 dxgmms2 (deferred)
fffff806`9c870000 fffff806`9c8a8000 usbaudio (deferred)
fffff806`9c8b0000 fffff806`9c8c1000 kbdhid (deferred)
fffff806`9c8d0000 fffff806`9c8e0000 mouhid (deferred)
fffff806`9c930000 fffff806`9c95d000 luafv (deferred)
fffff806`9c960000 fffff806`9c997000 wcifs (deferred)
fffff806`9c9a0000 fffff806`9c9ba000 mpsdrv (deferred)
fffff806`ca800000 fffff806`ca827000 Ndu (deferred)
fffff806`ca830000 fffff806`ca906000 peauth (deferred)
fffff806`ca910000 fffff806`ca925000 tcpipreg (deferred)
fffff806`ca930000 fffff806`ca94d000 rassstp (deferred)
fffff806`ca950000 fffff806`caa18000 srv2 (deferred)
fffff806`caa20000 fffff806`caa3d000 NDProxy (deferred)
fffff806`caa40000 fffff806`caa68000 AgileVpn (deferred)
fffff806`caa70000 fffff806`caa91000 rasl2tp (deferred)
fffff806`caaa0000 fffff806`caac1000 raspptp (deferred)
fffff806`caad0000 fffff806`caaec000 raspppoe (deferred)
fffff806`caaf0000 fffff806`caaff000 ndistapi (deferred)
fffff806`cab00000 fffff806`cab3a000 ndiswan (deferred)
fffff806`cab40000 fffff806`cab52000 condrv (deferred)
fffff806`cab60000 fffff806`cab6e000 IOMap64 (deferred)
fffff806`cab70000 fffff806`cab8d000 WdNisDrv (deferred)
fffff806`cab90000 fffff806`cab9d000 rdpvideominiport (deferred)
fffff806`cac10000 fffff806`cac55000 MpKslDrv (deferred)
fffff806`cb060000 fffff806`cb07b000 monitor (deferred)
fffff806`cb2d0000 fffff806`cb315000 mrxsmb20 (deferred)
fffff806`cb320000 fffff806`cb350000 AMDRyzenMasterDriver (deferred)
fffff806`cb360000 fffff806`cb3b6000 srvnet (deferred)
fffff806`cb3c0000 fffff806`cb3d4000 mmcss (deferred)
fffff80a`7e4f0000 fffff80a`80491000 eaanticheat (deferred)
Unloaded modules:
fffff80a`7dc70000 fffff80a`7f5fc000 eaanticheat.
fffff806`cb040000 fffff806`cb05c000 monitor.sys
fffff806`cb020000 fffff806`cb03c000 monitor.sys
fffff806`cb000000 fffff806`cb01c000 monitor.sys
fffff806`cafe0000 fffff806`caffc000 monitor.sys
fffff806`cafc0000 fffff806`cafdc000 monitor.sys
fffff806`cafa0000 fffff806`cafbc000 monitor.sys
fffff806`caf80000 fffff806`caf9c000 monitor.sys
fffff806`caf60000 fffff806`caf7c000 monitor.sys
fffff806`caf40000 fffff806`caf5c000 monitor.sys
fffff806`caf20000 fffff806`caf3c000 monitor.sys
fffff806`caf00000 fffff806`caf1c000 monitor.sys
fffff806`caee0000 fffff806`caefc000 monitor.sys
fffff806`caec0000 fffff806`caedc000 monitor.sys
fffff806`caea0000 fffff806`caebc000 monitor.sys
fffff806`cae80000 fffff806`cae9c000 monitor.sys
fffff806`cae60000 fffff806`cae7c000 monitor.sys
fffff806`cae40000 fffff806`cae5c000 monitor.sys
fffff806`cae20000 fffff806`cae3c000 monitor.sys
fffff806`cae00000 fffff806`cae1c000 monitor.sys
fffff806`cade0000 fffff806`cadfc000 monitor.sys
fffff806`cadc0000 fffff806`caddc000 monitor.sys
fffff806`cada0000 fffff806`cadbc000 monitor.sys
fffff806`cad80000 fffff806`cad9c000 monitor.sys
fffff806`cad60000 fffff806`cad7c000 monitor.sys
fffff806`cad40000 fffff806`cad5c000 monitor.sys
fffff806`cad20000 fffff806`cad3c000 monitor.sys
fffff806`cad00000 fffff806`cad1c000 monitor.sys
fffff806`cace0000 fffff806`cacfc000 monitor.sys
fffff806`cacc0000 fffff806`cacdc000 monitor.sys
fffff806`caca0000 fffff806`cacbc000 monitor.sys
fffff806`cac80000 fffff806`cac9c000 monitor.sys
fffff806`cac60000 fffff806`cac7c000 monitor.sys
fffff806`9c8f0000 fffff806`9c90c000 monitor.sys
fffff806`caba0000 fffff806`cabb0000 hiber_storpo
fffff806`cabb0000 fffff806`cabe3000 hiber_storah
fffff806`cabf0000 fffff806`cac0e000 hiber_dumpfv
fffff806`6b5b0000 fffff806`6b6e5000 xboxgip.sys
fffff806`6b6f0000 fffff806`6b704000 DevAuthE.sys
fffff806`6b590000 fffff806`6b5a7000 dc1-controll
fffff806`9c910000 fffff806`9c928000 xinputhid.sy
fffff806`71b10000 fffff806`71b32000 i8042prt.sys
fffff806`6b010000 fffff806`6b020000 dump_storpor
fffff806`6b060000 fffff806`6b093000 dump_storahc
fffff806`6b0c0000 fffff806`6b0de000 dump_dumpfve
fffff806`71920000 fffff806`7193c000 dam.sys
fffff806`273c0000 fffff806`273cc000 WdBoot.sys
fffff806`28500000 fffff806`28511000 hwpolicy.sys
# RetAddr : Args to Child : Call Site
00 fffff806`22e45667 : 00000000`000000be ffffd8fc`0f615000 8a000000`04100121 ffffde0b`0de6eba0 : nt!KeBugCheckEx
01 fffff806`22c39790 : 00000000`00000005 00000000`00000003 ffffde0b`0de6ec20 00000000`00000000 : nt!MiSystemFault+0x1cd107
02 fffff806`22e0e46d : ffffffff`ffffffff 00000000`00000001 ffffc900`4b640180 fffff806`22ca3d05 : nt!MmAccessFault+0x400
03 fffff806`22e145f0 : fffff806`22cbc6d8 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiPageFault+0x36d
04 fffff806`22cbc6d8 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!memset+0x30
05 fffff806`232d3537 : 00000000`000001fb 00000000`780a804a 00000000`780a7e4f 00000000`0000000f : nt!RtlClearBitsEx+0x98
06 fffff806`232d34bc : ffffb304`6de24a20 00000000`00000001 00000000`00000000 00000000`00001fa1 : nt!MiMarkRetpolineBits+0x63
07 fffff806`23212ec8 : ffffb304`6de24a20 ffffb304`6de24a20 ffffde0b`0de6eed0 00000000`00000001 : nt!MiMarkKernelImageRetpolineBits+0x34
08 fffff806`23161361 : 00000000`00000000 fffff806`ffffffff ffff98ff`00000001 ffffe307`1b690cc0 : nt!MiUnloadSystemImage+0x15e000
09 fffff806`2316128e : ffffb304`68fdf500 ffffde0b`0de6f110 00000000`00000000 ffffb304`68fdf530 : nt!MmUnloadSystemImage+0x41
0a fffff806`2302d970 : ffffb304`68fdf500 ffffde0b`0de6f110 fffff806`23725400 ffffde0b`0de6f010 : nt!IopDeleteDriver+0x4e
0b fffff806`22c5ac67 : 00000000`00000000 00000000`00000000 ffffde0b`0de6f110 ffffb304`68fdf530 : nt!ObpRemoveObjectRoutine+0x80
0c fffff806`22e20b7a : 00000000`00000000 ffffb304`68fdf530 369634f3`00000000 ffffde0b`0de6ef00 : nt!ObfDereferenceObjectWithTag+0xc7
0d fffff806`22c49a32 : ffffb304`52ffcf00 ffffb304`6a8ab000 ffffc900`4b4e4910 fffff806`22c4ad55 : nt!IopCompleteUnloadOrDelete+0x21da0a
0e fffff806`2302a2c0 : ffffb304`78355610 00000000`00000000 00000000`00000000 fffff806`22c52a59 : nt!IopDecrementDeviceObjectRef+0x162
0f fffff806`2302d970 : ffffb304`52ffcf00 00000000`00000001 ffffb304`783555e0 ffffb304`675ef740 : nt!IopDeleteFile+0x210
10 fffff806`22c5ac67 : 00000000`00000000 00000000`00000000 ffffde0b`0de6f3b9 ffffb304`78355610 : nt!ObpRemoveObjectRoutine+0x80
11 fffff806`230331d9 : ffffb304`783555e0 00000000`00000000 ffffe306`00000000 ffffb304`783555e0 : nt!ObfDereferenceObjectWithTag+0xc7
12 fffff806`2302df1c : 00000000`00000688 ffff98ff`95c9e15e ffffb304`6d298080 fffff806`22e12ae6 : nt!ObCloseHandleTableEntry+0x6c9
13 fffff806`22e12b0b : ffffb304`6d298000 000001bb`8da00000 ffffde0b`0de6f500 ffffffff`fe363c80 : nt!NtClose+0xec
14 00007fff`c6f8d744 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceExitPico+0x41f
15 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007fff`c6f8d744
Machine ID Information [From Smbios 3.7, DMIVersion 0, Size=2055]
BiosMajorRelease = 5
BiosMinorRelease = 35
BiosVendor = American Megatrends International, LLC.
BiosVersion = 1.E0
BiosReleaseDate = 07/23/2024
SystemManufacturer = Micro-Star International Co., Ltd.
SystemProductName = MS-7E28
SystemFamily = To be filled by O.E.M.
SystemVersion = 1.0
SystemSKU = To be filled by O.E.M.
BaseBoardManufacturer = Micro-Star International Co., Ltd.
BaseBoardProduct = PRO A620M-E (MS-7E28)
BaseBoardVersion = 1.0
[SMBIOS Data Tables v3.7]
[DMI Version - 0]
[2.0 Calling Convention - No]
[Table Size - 2055 bytes]
Vendor American Megatrends International, LLC.
BIOS Version 1.E0
BIOS Release Date 07/23/2024
BIOS ROM Size 1000000
BIOS Characteristics
07: - PCI Supported
11: - Upgradeable FLASH BIOS
15: - CD-Boot Supported
17: - BIOS ROM Socketed
19: - EDD Supported
22: - 360KB Floppy Supported
23: - 1.2MB Floppy Supported
24: - 720KB Floppy Supported
25: - 2.88MB Floppy Supported
27: - Keyboard Services Supported
32: - BIOS Vendor Reserved
00: - ACPI Supported
01: - USB Legacy Supported
BIOS Major Revision 5
BIOS Minor Revision 35
EC Firmware Major Revision 255
EC Firmware Minor Revision 255
Extended BIOS ROM Size 32 MB
Manufacturer Micro-Star International Co., Ltd.
Product Name MS-7E28
Version 1.0
Serial Number To be filled by O.E.M.
UUID 00000000-0000-0000-0000-000000000000
Wakeup Type Power Switch
SKUNumber To be filled by O.E.M.
Family To be filled by O.E.M.
Product PRO A620M-E (MS-7E28)
Version 1.0
Serial Number 07E2810_O11B120387
Asset Tag
Feature Flags 09h
00: - Motherboard
03: - Replaceable
Location To be filled by O.E.M.
Chassis Handle 0003h
Board Type 0ah - Processor/Memory Module
Number of Child Handles 0
Chassis Type Desktop
Version 1.0
Serial Number
Asset Tag Number
Bootup State Safe
Power Supply State Safe
Thermal State Safe
Security Status None
OEM Defined 0
Height 0U
Number of Power Cords 1
Number of Contained Elements 0
Contained Element Size 3
[OEM Strings (Type 11) - Length 5 - Handle 0004h]
Number of Strings 1
1 To be filled by O.E.M.
[System Configuration Options (Type 12) - Length 5 - Handle 0005h]
[ (Type 256) - Length 9 - Handle 0007h]
[ (Type 256) - Length 31 - Handle 0008h]
[ (Type 256) - Length 26 - Handle 0009h]
[Cache Information (Type 7) - Length 27 - Handle 000ah]
Socket Designation L1 - Cache
Cache Configuration 0180h - WBEnabled Int NonSocketed L1
Maximum Cache Size 0180h - 384K
Installed Size 0180h - 384K
Supported SRAM Type 0010h - Pipeline-Burst
Current SRAM Type 0010h - Pipeline-Burst
Cache Speed 1ns
Error Correction Type Specification Reserved
System Cache Type Unified
Associativity 8-way Set-Associative
Maximum Cache Size 2 180 - 00000384l Kb
Installed Cache Size 2 180 - 00000384l Kb
[Cache Information (Type 7) - Length 27 - Handle 000bh]
Socket Designation L2 - Cache
Cache Configuration 0181h - WBEnabled Int NonSocketed L2
Maximum Cache Size 1800h - 6144K
Installed Size 1800h - 6144K
Cache Speed 1ns
Maximum Cache Size 2 1800 - 00006144l Kb
Installed Cache Size 2 1800 - 00006144l Kb
[Cache Information (Type 7) - Length 27 - Handle 000ch]
Socket Designation L3 - Cache
Cache Configuration 0182h - WBEnabled Int NonSocketed L3
Maximum Cache Size 8200h - 32768K
Installed Size 8200h - 32768K
Cache Speed 1ns
Associativity 16-way Set-Associative
Maximum Cache Size 2 80000200 - 00032768l Kb
Installed Cache Size 2 80000200 - 00032768l Kb
[Processor Information (Type 4) - Length 48 - Handle 000dh]
Socket Designation AM5
Processor Type Central Processor
Processor Family 6bh - AMD Zen Processor Family
Processor Manufacturer Advanced Micro Devices, Inc.
Processor ID 120fa600fffb8b17
Processor Version AMD Ryzen 5 7500F 6-Core Processor
Processor Voltage 8dh - 1.3V
External Clock 100MHz
Max Speed 5050MHz
Current Speed 3700MHz
Status Enabled Populated
Processor Upgrade Specification Reserved
L1 Cache Handle 000ah
L2 Cache Handle 000bh
L3 Cache Handle 000ch
Serial Number
Asset Tag Number
Part Number Unknown
Core Count 6
Core Enabled 6
Thread Count 12
Processor Characteristics fc
Enabled Characteristics:
0x 2: 64-bit Capable
0x 3: Multi-Core
0x 4: Hardware Thread
0x 5: Execute Protection
0x 6: Enhanced Virtualization
Processor Family 2 006bh - AMD Zen Processor Family
Core Count 2 6
Core Enabled 2 6
Thread Count 2 12
[ (Type 256) - Length 9 - Handle 000eh]
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 000fh]
[Physical Memory Array (Type 16) - Length 23 - Handle 0010h]
Location 03h - SystemBoard/Motherboard
Use 03h - System Memory
Memory Error Correction 03h - None
Maximum Capacity 134217728KB
Memory Error Inf Handle 000fh
Number of Memory Devices 2
[Memory Array Mapped Address (Type 19) - Length 31 - Handle 0011h]
Starting Address 00000000h
Ending Address 00ffffffh
Memory Array Handle 0010h
Partition Width 02
Extended Starting Address 0000000000000000h
Extended Ending Address 0000000000000000h
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 0012h]
[Memory Device (Type 17) - Length 100 - Handle 0013h]
Memory Error Info Handle 0012h
Total Width 64 bits
Data Width 64 bits
Size 8192MB
Form Factor 09h - DIMM
Device Set [None]
Device Locator DIMMA1
Bank Locator P0 CHANNEL A
Memory Type 22h - DDR5
Type Detail 4080h - Synchronous Unbuffered (Unregistered)
Speed 4800MHz
Manufacturer Unknown
Serial Number
Asset Tag Number [String Not Specified]
Part Number UD5-5600
Attributes 1
Extended Size 0
Configured Memory Speed 6000
Minimum Voltage 1100
Maximum Voltage 1100
Configured Voltage 1100
Memory Technology 3
Memory Operating Mode Capability 8
Firmware Version 6
Module Manufacturer Id 61188
Module Product Id 0
Memory Subsystem Controller Manufacturer Id 0
Memory Subsystem Controller Product Id 0
Non-Volatile Size 0
Volatile Size 0
Cache Size 0
Logical Size 0
Extended Speed 0
Extended Configured Memory Speed 0
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 0014h]
Ending Address 007fffffh
Memory Device Handle 0013h
Mem Array Mapped Adr Handle 0011h
Partition Row Position [Unknown]
Interleave Position [Unknown]
Interleave Data Depth [Unknown]
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 0015h]
[Memory Device (Type 17) - Length 100 - Handle 0016h]
Memory Error Info Handle 0015h
Total Width 64 bits
Data Width 64 bits
Size 8192MB
Device Set [None]
Device Locator DIMMB1
Bank Locator P0 CHANNEL B
Speed 4800MHz
Serial Number
Attributes 1
Extended Size 0
Memory Technology 3
Firmware Version 6
Module Product Id 0
Non-Volatile Size 0
Volatile Size 0
Cache Size 0
Logical Size 0
Extended Speed 0
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 0017h]
Starting Address 00800000h
Memory Device Handle 0016h
[ (Type 256) - Length 14 - Handle 0018h]
[ (Type 256) - Length 11 - Handle 0026h]
[ (Type 256) - Length 16 - Handle 0027h]
[ (Type 256) - Length 4 - Handle 0028h]
THREAD ffffb3046d298080 Cid 439c.4d74 Teb: 0000007b13ebf000 Win32Thread: ffffb3046cfc83c0 RUNNING on processor 6
IRP List:
Unable to read nt!_IRP @ ffffb30466af5a20
Not impersonating
GetUlongFromAddress: unable to read from fffff8062361159c
Owning Process ffffb3046a3ee080 Image: EAAntiCheat.GameService.exe
Attached Process N/A Image: N/A
fffff78000000000: Unable to get shared data
Wait Start TickCount 3469117
Context Switch Count 1185 IdealProcessor: 4
ReadMemory error: Cannot get nt!KeMaximumIncrement value.
UserTime 00:00:00.000
KernelTime 00:00:00.000
Win32 Start Address 0x00007fffc4f2dfb0
Stack Init ffffde0b0de6f610 Current ffffde0b0de6ecd0
Base ffffde0b0de70000 Limit ffffde0b0de69000 Call 0000000000000000
Priority 15 BasePriority 15 IoPriority 2 PagePriority 5
Child-SP RetAddr : Args to Child : Call Site
ffffde0b`0de6eba0 fffff806`22e145f0 : fffff806`22cbc6d8 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiPageFault+0x36d (TrapFrame @ ffffde0b`0de6eba0)
ffffde0b`0de6f480 00007fff`c6f8d744 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceExitPico+0x41f (TrapFrame @ ffffde0b`0de6f480)
Ayarları yalama gibi oynamıştım, portları da aynı şekilde, büyük ihtimal ondan oldu. Teşekkürler.Xbox o sıra bağlı değilse bir bug bile oluşmuş olabilir, emin değilim. Kulaklığın ayarlarını bir yere kaydedip varsayılanda oynayabilirsin ya da direkt Armoury Crate'i devre dışı bırakıp oynayabilirsin.
Arguments:
VA ffffd8fc0f615000
6: kd> k
CheckSum: 01FE3103
ImageSize: 01FA1000
BF5'i yükleyince otomatik olarak anti cheat onunla beraber yükleniyor, tıpki Valorant'ı yüklerken Vanguard'ın yüklenmesi gibi. Güncel olmama durumu yok, sanırım aldığım mavi ekran çok kutuplu. Bu arada hiçbir sürücüyü kaldırmaya çalışmadım, yukarıda anlatığım gibi oyunu indirip giriş yaptım, çıkınca da mavi ekran.Sürücüsü güncel galiba.?
AC bir program ve ona bağlı bir sürücüsü mevcut. Vanguard VGK, VGC adlı 2 sürücüyü kullanır. EAC kendi özel sürücüsünü kullanır ve bunlar güncellenir. Sen fark etmesen de. FACEIT geçen günlerde güncelleme yaptığı AC programında kendi sürücüsünün NVIDIA sürücüsüyle uyumsuzluk yaratması nedeniyle mavi ekranlara sebep oldu örneğin. Keza Vanguard da sık güncellenen hatta sanırsam en sık güncellenen AC yazılımı. Bunlar yükledim oldu şeyler değil. O yüzden spesifik olarak EAC, güncellenmesi nispeten önemli bir AC. Sanırsam sende zaten güncel o yüzden bu hatayı şimdilik verdiği anlık bir refleks olarak görüyorum. Bir sürücünün 2 kere kaldırılması daha önce de gördüğüm bir şey. Sorun devam etmediği takdirde günlük kullanımına olduğu gibi devam edebilirsin.BF5'i yükleyince otomatik olarak anti cheat onunla beraber yükleniyor, tıpki Valorant'ı yüklerken Vanguard'ın yüklenmesi gibi. Güncel olmama durumu yok, sanırım aldığım mavi ekran çok kutuplu. Bu arada hiçbir sürücüyü kaldırmaya çalışmadım, yukarıda anlatığım gibi oyunu indirip giriş yaptım, çıkınca da mavi ekran.
We use cookies and similar technologies for the following purposes:
Do you accept cookies and these technologies?
