PlayStation 3 13
- 6 Nisan 2025
DPC_WATCHDOG_VIOLATION (133)
The DPC watchdog detected a prolonged run time at an IRQL of DISPATCH_LEVEL
or above.
Arguments:
Arg1: 0000000000000001, The system cumulatively spent an extended period of time at
DISPATCH_LEVEL or above.
Arg2: 0000000000001e00, The watchdog period (in ticks).
Arg3: fffff802c91c43b0, cast to nt!DPC_WATCHDOG_GLOBAL_TRIAGE_BLOCK, which contains
additional information regarding the cumulative timeout
Arg4: 0000000000000000
Debugging Details:
*** Either you specified an unqualified symbol, or your debugger ***
*** doesn't have full symbol information. Unqualified symbol ***
*** resolution is turned off by default. Please either specify a ***
*** fully qualified symbol module!symbolname, or enable resolution ***
*** of unqualified symbols by typing ".symopt- 100". Note that ***
*** enabling unqualified symbol resolution with network symbol ***
*** server shares in the symbol path may cause the debugger to ***
*** appear to hang for long periods of time when an incorrect ***
*** symbol name is typed or the network symbol server is down. ***
*** For some commands to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: TickPeriods ***
KEY_VALUES_STRING: 1
Key : Analysis.CPU.mSec
Value: 1234
Key : Analysis.Elapsed.mSec
Value: 19405
Key : Analysis.IO.Other.Mb
Value: 1
Key : Analysis.IO.Read.Mb
Value: 1
Key : Analysis.IO.Write.Mb
Value: 13
Key : Analysis.Init.CPU.mSec
Value: 343
Value: 1558
Value: 103
Key : Analysis.Version.DbgEng
Value: 10.0.27829.1001
Key : Analysis.Version.Description
Value: 10.2503.24.01 amd64fre
Key : Analysis.Version.Ext
Value: 1.2503.24.1
Key : Bugcheck.Code.LegacyAPI
Value: 0x133
Key : Bugcheck.Code.TargetModel
Value: 0x133
Key : Dump.Attributes.AsUlong
Value: 0x21808
Key : Dump.Attributes.DiagDataWrittenToHeader
Value: 1
Key : Dump.Attributes.ErrorCode
Value: 0x0
Key : Dump.Attributes.KernelGeneratedTriageDump
Value: 1
Key : Dump.Attributes.LastLine
Key : Dump.Attributes.ProgressPercentage
Value: 0
Key : Failure.Bucket
Value: 0x133_ISR_msgpioclx!GpiopUpdateStatusAndMaskInformation
Key : Failure.Hash
Value: {e3358d00-0b58-4535-5751-c25c6fecdf14}
Key : Hypervisor.Enlightenments.ValueHex
Value: 0x7497cf94
Key : Hypervisor.Flags.AnyHypervisorPresent
Value: 1
Key : Hypervisor.Flags.ApicEnlightened
Value: 1
Key : Hypervisor.Flags.ApicVirtualizationAvailable
Value: 0
Key : Hypervisor.Flags.AsyncMemoryHint
Value: 0
Key : Hypervisor.Flags.CoreSchedulerRequested
Value: 0
Key : Hypervisor.Flags.CpuManager
Value: 1
Key : Hypervisor.Flags.DeprecateAutoEoi
Value: 0
Key : Hypervisor.Flags.DynamicCpuDisabled
Value: 1
Key : Hypervisor.Flags.Epf
Value: 0
Key : Hypervisor.Flags.ExtendedProcessorMasks
Value: 1
Key : Hypervisor.Flags.HardwareMbecAvailable
Value: 1
Key : Hypervisor.Flags.MaxBankNumber
Value: 0
Key : Hypervisor.Flags.MemoryZeroingControl
Value: 0
Key : Hypervisor.Flags.NoExtendedRangeFlush
Value: 0
Key : Hypervisor.Flags.NoNonArchCoreSharing
Value: 1
Key : Hypervisor.Flags.Phase0InitDone
Value: 1
Key : Hypervisor.Flags.PowerSchedulerQos
Value: 0
Key : Hypervisor.Flags.RootScheduler
Value: 0
Key : Hypervisor.Flags.SynicAvailable
Value: 1
Key : Hypervisor.Flags.UseQpcBias
Value: 0
Key : Hypervisor.Flags.Value
Value: 38408431
Key : Hypervisor.Flags.ValueHex
Value: 0x24a10ef
Key : Hypervisor.Flags.VpAssistPage
Value: 1
Key : Hypervisor.Flags.VsmAvailable
Value: 1
Key : Hypervisor.RootFlags.AccessStats
Value: 1
Key : Hypervisor.RootFlags.CrashdumpEnlightened
Value: 1
Key : Hypervisor.RootFlags.CreateVirtualProcessor
Value: 1
Key : Hypervisor.RootFlags.DisableHyperthreading
Value: 0
Key : Hypervisor.RootFlags.HostTimelineSync
Value: 1
Key : Hypervisor.RootFlags.HypervisorDebuggingEnabled
Value: 0
Key : Hypervisor.RootFlags.IsHyperV
Value: 1
Key : Hypervisor.RootFlags.LivedumpEnlightened
Value: 1
Key : Hypervisor.RootFlags.MapDeviceInterrupt
Value: 1
Key : Hypervisor.RootFlags.MceEnlightened
Value: 1
Key : Hypervisor.RootFlags.Nested
Value: 0
Key : Hypervisor.RootFlags.StartLogicalProcessor
Value: 1
Key : Hypervisor.RootFlags.Value
Value: 1015
Key : Hypervisor.RootFlags.ValueHex
Value: 0x3f7
Key : Stack.Pointer
Value: ISR
BUGCHECK_CODE: 133
BUGCHECK_P1: 1
BUGCHECK_P2: 1e00
BUGCHECK_P3: fffff802c91c43b0
BUGCHECK_P4: 0
FILE_IN_CAB: 072925-12718-01.dmp
TAG_NOT_DEFINED_202b: *** Unknown TAG in analysis list 202b
DUMP_FILE_ATTRIBUTES: 0x21808
Kernel Generated Triage Dump
FAULTING_THREAD: ffff938af0df90c0
DPC_TIMEOUT_TYPE: DPC_QUEUE_EXECUTION_TIMEOUT_EXCEEDED
BLACKBOXBSD: 1 (!blackboxbsd)
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: System
STACK_TEXT:
fffff802`5ae7c5b8 fffff802`c8489236 : 00000000`00000133 00000000`00000001 00000000`00001e00 fffff802`c91c43b0 : nt!KeBugCheckEx
fffff802`5ae7c5c0 fffff802`c848876a : 00000000`00000000 ffffbb81`ac214400 fffff780`00000320 fffff802`57f76180 : nt!KeAccumulateTicks+0x596
fffff802`5ae7c630 fffff802`c848843c : 00000000`00000010 00000000`00000001 00000000`000012bd fffff802`57f76180 : nt!KiUpdateRunTime+0xca
fffff802`5ae7c7f0 fffff802`c848ecc9 : 00000000`0000000d fffff802`5ae7cb00 fffff802`57f76180 00000000`0000000f : nt!KiUpdateTime+0x37c
fffff802`5ae7c9b0 fffff802`c848f76b : fffff802`c9010ba0 00000000`00000000 fffff802`c9010c50 fffff802`c918e6a8 : nt!KeClockInterruptNotify+0x2e9
fffff802`5ae7caa0 fffff802`c88a782e : ffff938a`f1833a0a fffff802`c9010ba0 0000003d`ec860a12 00000000`4af96298 : nt!KiCallInterruptServiceRoutine+0x31b
fffff802`5ae7cb00 fffff802`c88a803c : 00000000`00000000 00000000`00000000 00000000`00000000 fffff802`622e54e0 : nt!KiInterruptSubDispatchNoLockNoEtw+0x4e
fffff802`5ae7cb50 fffff802`62304f99 : 00000000`00000000 ffff938a`0000001f fffff802`5ae7ce09 fffff802`62305712 : nt!KiInterruptDispatchNoLockNoEtw+0x3c
fffff802`5ae7cce0 fffff802`62304177 : 00000000`00000002 00000000`00000014 00000000`00000001 00000000`00500a02 : msgpioclx!GpiopUpdateStatusAndMaskInformation+0x175
fffff802`5ae7cd80 fffff802`62303cc0 : 00000000`00000000 ffffb789`00000000 00000000`00000000 00000000`00000005 : msgpioclx!GpiopServiceInterrupt+0xa3
fffff802`5ae7ce70 fffff802`6230311a : ffff938a`f1833a90 fffff802`57f7f700 00000000`00000000 00000000`00000000 : msgpioclx!GpiopInterruptBankIsr+0x60
fffff802`5ae7cea0 fffff802`5a80d886 : 00006c75`0e7cbd98 00000000`00000004 00000000`00000000 fffff802`c85718df : msgpioclx!GpioClxEvtInterruptIsr+0x13a
fffff802`5ae7ced0 fffff802`c848f987 : 00000000`00000000 00000000`00500a02 fffff802`5a80d810 00000000`0000a000 : Wdf01000!FxInterrupt::_InterruptThunk+0x76 [minkernel\wdf\framework\shared\irphandlers\pnp\km\interruptobjectkm.cpp @ 374]
fffff802`5ae7cf10 fffff802`c88a7610 : ffffbb81`ac214508 ffffbb81`ac214500 0000003d`ec85e276 00000000`00000000 : nt!KiCallInterruptServiceRoutine+0x537
fffff802`5ae7cf70 fffff802`c88a71cc : 00000000`4af960ff ffffb789`2fa5eb90 00000000`4af961df 0000003a`74d71bde : nt!KiScanInterruptObjectList+0xa0
ffffb789`2fa5eb10 fffff802`581b001c : fffff802`c88a0cbb 00000000`00000000 ffffb789`2fa5eed0 00000000`00000000 : nt!KiChainedDispatch+0x3c
ffffb789`2fa5eca8 fffff802`c88a0cbb : 00000000`00000000 ffffb789`2fa5eed0 00000000`00000000 00000000`00000000 : 0xfffff802`581b001c
ffffb789`2fa5ecb0 fffff802`c855a067 : ffff938a`f135c4e0 00000000`00080000 ffffb789`2fa5ef90 00000003`0db937d2 : nt!HvlSwitchToVsmVtl1+0xab
ffffb789`2fa5edf0 fffff802`c85af0bd : 81726179`b26689f9 20354f15`d4ccc98b 00000000`00000000 00000000`00000000 : nt!VslpEnterIumSecureMode+0x137
ffffb789`2fa5eeb0 fffff802`c84bea02 : 00000000`00000803 20354f15`d4ccc98b ffffb789`2fa5efa8 00000000`00000000 : nt!VslSetPrivilegedPte+0x65
ffffb789`2fa5ef80 fffff802`c8469f86 : fffff802`c9037a80 ffffa3fc`012e58a8 ffffdc80`10cfc1d0 ffffb789`00000000 : nt!MiAllocateWsle+0x6f2
ffffb789`2fa5f050 fffff802`c846add8 : ffffb789`2fa5f330 00000000`0059a95f 00000000`00000000 20354f15`00000000 : nt!MiCompleteProtoPteFault+0x476
ffffb789`2fa5f140 fffff802`c84173c8 : a78f0a2c`00000000 ffffa78f`0a2c75d8 0a000005`9a95f121 00000000`00000000 : nt!MiResolveTransitionFault+0x3d8
ffffb789`2fa5f220 fffff802`c8416a0d : 00000000`00000000 00000000`00000000 ffffb789`2fa5f2e8 fffff802`5cb15300 : nt!MiResolveProtoPteFault+0x288
ffffb789`2fa5f2b0 fffff802`c84ae33c : ff000000`ff000000 ffff8000`00000000 fffff802`5cb15300 0000007f`fffffff8 : nt!MiDispatchFault+0x1dd
ffffb789`2fa5f420 fffff802`c88b48cb : ffff938a`ea402000 20354f15`d4ccc98b ffff938a`f12bbc70 000004d0`fffffb30 : nt!MmAccessFault+0x20c
ffffb789`2fa5f590 fffff802`5cb15300 : fffff802`5cab1b4e ff000000`ff000000 ff000000`ff000000 ff000000`ff000000 : nt!KiPageFault+0x38b
ffffb789`2fa5f728 fffff802`5cab1b4e : ff000000`ff000000 ff000000`ff000000 ff000000`ff000000 ff000000`ff000000 : netbt!TdiBindHandler
ffffb789`2fa5f730 fffff802`5cab3a3f : fffff802`5caba3d0 ffffb789`00000000 00000000`00000001 00000000`00000000 : TDI!TdiNotifyPnpClientList+0x3de
ffffb789`2fa5f7c0 fffff802`5cab33c6 : 00000000`00000013 ffff938a`f0df90c0 00000000`00000000 20354f15`d4ccc98b : TDI!TdiExecuteRequest+0x42f
ffffb789`2fa5f820 fffff802`5cab521e : 00000000`00000001 00000000`00000000 fffff802`5cab521e fffff802`5ca91372 : TDI!TdiHandleSerializedRequest+0x136
ffffb789`2fa5f890 fffff802`5ca91372 : 00000000`00000000 00000000`00000000 ffffffff`ffffffa0 fffff802`5ca93ce2 : TDI!TdiProviderReady+0xe
ffffb789`2fa5f8c0 fffff802`5ca93d2c : 00000000`00000003 ffffb789`2fa5f990 ffff938a`ea602ae0 00000000`00000000 : tdx!TdxDecrementNotReadyInterfaceCount+0x86
ffffb789`2fa5f900 fffff802`c855f252 : ffff938a`f0859e00 ffff938a`f0819d10 00000000`00000000 00000000`00000000 : tdx!TdxProviderReadyWorkItemRoutine+0x13c
ffffb789`2fa5f940 fffff802`c84302e3 : ffff938a`f0df90c0 ffff938a`ea602ae0 ffffbb81`a9998100 ffff938a`f0df90c0 : nt!IopProcessWorkItem+0x502
ffffb789`2fa5f9d0 fffff802`c869e2da : ffff938a`f0df90c0 ffff938a`f0df90c0 fffff802`c8430140 ffff938a`ea602ae0 : nt!ExpWorkerThread+0x1a3
ffffb789`2fa5fbb0 fffff802`c88a67e4 : ffffbb81`a9998180 ffff938a`f0df90c0 fffff802`c869e280 00000000`00000000 : nt!PspSystemThreadStartup+0x5a
ffffb789`2fa5fc00 00000000`00000000 : ffffb789`2fa60000 ffffb789`2fa59000 00000000`00000000 00000000`00000000 : nt!KiStartSystemThread+0x34
SYMBOL_NAME: msgpioclx!GpiopUpdateStatusAndMaskInformation+175
MODULE_NAME: msgpioclx
IMAGE_NAME: msgpioclx.sys
IMAGE_VERSION: 10.0.26100.4484
STACK_COMMAND: .process /r /p 0xffff938aea4a4040; .thread 0xffff938af0df90c0 ; kb
BUCKET_ID_FUNC_OFFSET: 175
FAILURE_BUCKET_ID: 0x133_ISR_msgpioclx!GpiopUpdateStatusAndMaskInformation
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {e3358d00-0b58-4535-5751-c25c6fecdf14}
Followup: MachineOwner
[SMBIOS Data Tables v3.3]
[DMI Version - 0]
[2.0 Calling Convention - No]
[Table Size - 2063 bytes]
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 0000h]
[Physical Memory Array (Type 16) - Length 23 - Handle 0001h]
Location 03h - SystemBoard/Motherboard
Use 03h - System Memory
Memory Error Correction 03h - None
Maximum Capacity 67108864KB
Memory Error Inf Handle 0000h
Number of Memory Devices 2
[Memory Array Mapped Address (Type 19) - Length 31 - Handle 0002h]
Starting Address 00000000h
Ending Address 017fffffh
Memory Array Handle 0001h
Partition Width 02
Extended Starting Address 0000000000000000h
Extended Ending Address 0000000000000000h
[Cache Information (Type 7) - Length 27 - Handle 0003h]
Socket Designation L1 - Cache
Cache Configuration 0180h - WBEnabled Int NonSocketed L1
Maximum Cache Size 0200h - 512K
Installed Size 0200h - 512K
Supported SRAM Type 0010h - Pipeline-Burst
Current SRAM Type 0010h - Pipeline-Burst
Cache Speed 1ns
Error Correction Type Specification Reserved
System Cache Type Unified
Associativity 8-way Set-Associative
Maximum Cache Size 2 200 - 00000512l Kb
Installed Cache Size 2 200 - 00000512l Kb
[Cache Information (Type 7) - Length 27 - Handle 0004h]
Socket Designation L2 - Cache
Cache Configuration 0181h - WBEnabled Int NonSocketed L2
Maximum Cache Size 1000h - 4096K
Installed Size 1000h - 4096K
Cache Speed 1ns
Maximum Cache Size 2 1000 - 00004096l Kb
Installed Cache Size 2 1000 - 00004096l Kb
[Cache Information (Type 7) - Length 27 - Handle 0005h]
Socket Designation L3 - Cache
Cache Configuration 0182h - WBEnabled Int NonSocketed L3
Maximum Cache Size 4000h - 16384K
Installed Size 4000h - 16384K
Cache Speed 1ns
Associativity 16-way Set-Associative
Maximum Cache Size 2 4000 - 00016384l Kb
Installed Cache Size 2 4000 - 00016384l Kb
[Processor Information (Type 4) - Length 48 - Handle 0006h]
Socket Designation FP6
Processor Type Central Processor
Processor Family 6bh - AMD Zen Processor Family
Processor Manufacturer Advanced Micro Devices, Inc.
Processor ID fa500fffb8b17
Processor Version AMD Ryzen 7 5825U with Radeon Graphics
Processor Voltage 8ch - 1.2V
External Clock 100MHz
Max Speed 4550MHz
Current Speed 2000MHz
Status Enabled Populated
Processor Upgrade None
L1 Cache Handle 0003h
L2 Cache Handle 0004h
L3 Cache Handle 0005h
Serial Number
Asset Tag Number
Part Number Null
Core Count 8
Core Enabled 8
Thread Count 16
Processor Characteristics fc
Enabled Characteristics:
0x 2: 64-bit Capable
0x 3: Multi-Core
0x 4: Hardware Thread
0x 5: Execute Protection
0x 6: Enhanced Virtualization
Processor Family 2 006bh - AMD Zen Processor Family
Core Count 2 8
Core Enabled 2 8
Thread Count 2 16
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 0007h]
[Memory Device (Type 17) - Length 92 - Handle 0008h]
Memory Error Info Handle 0007h
Total Width 64 bits
Data Width 64 bits
Size 16384MB
Form Factor 0dh - SODIMM
Device Set [None]
Device Locator DIMM 0
Bank Locator P0 CHANNEL A
Memory Type 1ah - DDR4
Type Detail 4080h - Synchronous Unbuffered (Unregistered)
Speed 3200MHz
Manufacturer Micron Technology
Serial Number
Asset Tag Number [String Not Specified]
Part Number CT16G4SFRA32A.C16FR
Attributes 2
Extended Size 0
Configured Memory Speed 3200
Minimum Voltage 1200
Maximum Voltage 1200
Configured Voltage 1200
Memory Technology 3
Memory Operating Mode Capability 8
Firmware Version 6
Module Manufacturer Id 11392
Module Product Id 0
Memory Subsystem Controller Manufacturer Id 0
Memory Subsystem Controller Product Id 0
Non-Volatile Size 0
Volatile Size 0
Cache Size 0
Logical Size 0
Extended Speed 0
Extended Configured Memory Speed 0
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 0009h]
Memory Device Handle 0008h
Mem Array Mapped Adr Handle 0002h
Partition Row Position [Unknown]
Interleave Position [Unknown]
Interleave Data Depth [Unknown]
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 000ah]
[Memory Device (Type 17) - Length 92 - Handle 000bh]
Memory Error Info Handle 000ah
Total Width 64 bits
Data Width 64 bits
Size 8192MB
Form Factor 0bh - Row of chips
Device Set [None]
Bank Locator P0 CHANNEL B
Speed 3200MHz
Manufacturer Hynix
Serial Number
Part Number HMAA1GS6CJR6N-XN
Attributes 1
Extended Size 0
Memory Technology 3
Firmware Version 6
Module Manufacturer Id 44416
Module Product Id 0
Non-Volatile Size 0
Volatile Size 0
Cache Size 0
Logical Size 0
Extended Speed 0
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 000ch]
Ending Address 00ffffffh
Memory Device Handle 000bh
[Onboard Devices Information (Type 10) - Length 6 - Handle 0028h]
Note: The On Board Device Information (Type 10) struct is obsolete as of SMBIOs spec v2.6 Number of Devices 1
01: Type Video [enabled]
01: Description AMD Renoir FP6 GPU
[Onboard Devices Information (Type 10) - Length 6 - Handle 0029h]
01: Type Sound [enabled]
01: Description AZALIA HD Audio
[Onboard Devices Information (Type 10) - Length 6 - Handle 002ah]
01: Type Specification Reserved [enabled]
[Onboard Devices Information (Type 10) - Length 6 - Handle 002bh]
01: Type Unknown [enabled]
01: Description ST TPM ST33TPMESPI
[ (Type 256) - Length 21 - Handle 0030h]
[ (Type 256) - Length 5 - Handle 0032h]
[ (Type 256) - Length 18 - Handle 0033h]
[OEM Strings (Type 11) - Length 5 - Handle 002ch]
Number of Strings 1
1 Modern Preload
[BIOS Information (Type 0) - Length 24 - Handle 000dh]
Vendor LENOVO
BIOS Version JTCN49WW
BIOS Starting Address Segment e000
BIOS Release Date 09/18/2023
BIOS ROM Size 1000000
BIOS Characteristics
00: - Reserved
01: - Reserved
07: - PCI Supported
08: - PCMCIA Supported
09: - Plug and Play Supported
10: - APM Supported
11: - Upgradeable FLASH BIOS
15: - CD-Boot Supported
19: - EDD Supported
27: - Keyboard Services Supported
49: - System Vendor Reserved
51: - System Vendor Reserved
52: - System Vendor Reserved
00: - ACPI Supported
01: - USB Legacy Supported
09: - Fn-Key NET-Boot Supported
BIOS Major Revision 1
BIOS Minor Revision 49
EC Firmware Major Revision 1
EC Firmware Minor Revision 49
[System Information (Type 1) - Length 27 - Handle 000eh]
Manufacturer LENOVO
Product Name 82TV
Version Lenovo V15 G3 ABA
Serial Number PF4T9SXW
UUID 00000000-0000-0000-0000-000000000000
Wakeup Type Power Switch
SKUNumber LENOVO_MT_82TV_BU_idea_FM_V15 G3 ABA
Family V15 G3 ABA
[BaseBoard Information (Type 2) - Length 15 - Handle 000fh]
Manufacturer LENOVO
Product LNVNB161216
Version NO DPK
Asset Tag
Feature Flags 09h
00: - Motherboard
03: - Replaceable
Location Base Board Chassis Location
Chassis Handle 0010h
Board Type 0ah - Processor/Memory Module
Number of Child Handles 0
[System Enclosure (Type 3) - Length 22 - Handle 0010h]
Manufacturer LENOVO
Chassis Type Notebook
Serial Number
Asset Tag Number
Bootup State Safe
Power Supply State Safe
Thermal State Other
Security Status Other
OEM Defined 0
Height 0U
Number of Power Cords 1
Number of Contained Elements 0
Contained Element Size 0
[ (Type 256) - Length 4 - Handle feffh]
or above.
Arguments:
Debugging Details:
*** work. ***
Value: 1234
Value: 19405
Value: 1
Value: 1
Value: 13
Value: 343
Value: 1558
Value: 103
Value: 1.2503.24.1
Value: 0x133
Value: 0x133
Value: 0x21808
Value: 1
Value: 0x0
Value: 1
Value: 0
Key : Failure.Hash
Value: 0x7497cf94
Value: 1
Value: 1
Value: 0
Value: 0
Value: 0
Value: 1
Value: 0
Value: 1
Value: 0
Value: 1
Value: 1
Value: 0
Value: 0
Value: 0
Value: 1
Value: 1
Value: 0
Value: 0
Value: 1
Value: 0
Value: 38408431
Value: 0x24a10ef
Value: 1
Value: 1
Value: 1
Value: 1
Value: 1
Value: 0
Value: 1
Value: 0
Value: 1
Value: 1
Value: 1
Value: 1
Value: 0
Value: 1
Value: 1015
Value: 0x3f7
Key : Stack.Pointer
Value: ISR
BUGCHECK_CODE: 133
BUGCHECK_P1: 1
BUGCHECK_P2: 1e00
BUGCHECK_P4: 0
STACK_TEXT:
OSNAME: Windows 10
[DMI Version - 0]
Partition Width 02
Cache Speed 1ns
Cache Speed 1ns
Cache Speed 1ns
Max Speed 4550MHz
Serial Number
Asset Tag Number
Part Number Null
Core Count 8
Core Enabled 8
Thread Count 16
0x 3: Multi-Core
Core Count 2 8
Core Enabled 2 8
Thread Count 2 16
Total Width 64 bits
Data Width 64 bits
Size 16384MB
Device Set [None]
Speed 3200MHz
Serial Number
Attributes 2
Extended Size 0
Memory Technology 3
Firmware Version 6
Module Product Id 0
Non-Volatile Size 0
Volatile Size 0
Cache Size 0
Logical Size 0
Extended Speed 0
Total Width 64 bits
Data Width 64 bits
Size 8192MB
Device Set [None]
Speed 3200MHz
Manufacturer Hynix
Serial Number
Attributes 1
Extended Size 0
Memory Technology 3
Firmware Version 6
Module Product Id 0
Non-Volatile Size 0
Volatile Size 0
Cache Size 0
Logical Size 0
Extended Speed 0
Number of Strings 1
1 Modern Preload
Vendor LENOVO
00: - Reserved
01: - Reserved
07: - PCI Supported
10: - APM Supported
19: - EDD Supported
Manufacturer LENOVO
Product Name 82TV
Family V15 G3 ABA
Manufacturer LENOVO
Product LNVNB161216
Version NO DPK
Asset Tag
Feature Flags 09h
00: - Motherboard
03: - Replaceable
Manufacturer LENOVO
Serial Number
Asset Tag Number
Bootup State Safe
Thermal State Other
OEM Defined 0
Height 0U
Chipset driveri kurmuştum. Güncel versiyonu olarak. BIOS'u güncelleyim. Chipset driveri lenovo sitesinde indireyim de hangisini indirmem gerekiyor hocam?Öncelikle aşağıdaki sürücüleri güncelleyin:
- Hata Kodu: 0x133
- Sebep: ISR (Interrupt Service Routine) veya DPC (Deferred Procedure Call) beklenenden uzun sürdü.
- Sorumlu sürücü: msgpioclx.sys
Bu sürücü Microsoft GPIO (General Purpose Input/Output) Class Extension Driver'dır. Genellikle sistem üzerindeki GPIO pinlerinin kontrolünde kullanılır ve donanım/anakart ile ilgilidir.- Sistem: Lenovo V15 G3 ABA, AMD Ryzen 7 5825U işlemci
- RAM: 16 GB Micron + 8 GB Hynix DDR4 (3200 MHz)
Özellikle:
- Chipset Driver: AMD'nin resmi sitesinden indirin
→ https://www.amd.com/en/support- Lenovo V15 G3 ABA destek sayfası
→ https://support.lenovo.com/tr/tr
- AMD GPIO Controller
- AMD PSP (Platform Security Processor)
- ACPI ve System cihazları altında yer alan sürücüler
- BIOS güncellemesi yapın (sizdeki BIOS: JTCN49WW, 18 Eylül 2023): https://support.lenovo.com/us/en/do...ad-3-15aba7-ideapad-1-14alc7-ideapad-1-15alc7
Kod:DPC_WATCHDOG_VIOLATION (133) The DPC watchdog detected a prolonged run time at an IRQL of DISPATCH_LEVEL or above. Arguments: Arg1: 0000000000000001, The system cumulatively spent an extended period of time at DISPATCH_LEVEL or above. Arg2: 0000000000001e00, The watchdog period (in ticks). Arg3: fffff802c91c43b0, cast to nt!DPC_WATCHDOG_GLOBAL_TRIAGE_BLOCK, which contains additional information regarding the cumulative timeout Arg4: 0000000000000000 Debugging Details: ------------------ ************************************************************************* *** *** *** *** *** Either you specified an unqualified symbol, or your debugger *** *** doesn't have full symbol information. Unqualified symbol *** *** resolution is turned off by default. Please either specify a *** *** fully qualified symbol module!symbolname, or enable resolution *** *** of unqualified symbols by typing ".symopt- 100". Note that *** *** enabling unqualified symbol resolution with network symbol *** *** server shares in the symbol path may cause the debugger to *** *** appear to hang for long periods of time when an incorrect *** *** symbol name is typed or the network symbol server is down. *** *** *** *** For some commands to work properly, your symbol path *** *** must point to .pdb files that have full type information. *** *** *** *** Certain .pdb files (such as the public OS symbols) do not *** *** contain the required information. Contact the group that *** *** provided you with these symbols if you need this command to *** *** work. *** *** *** *** Type referenced: TickPeriods *** *** *** ************************************************************************* KEY_VALUES_STRING: 1 Key : Analysis.CPU.mSec Value: 1234 Key : Analysis.Elapsed.mSec Value: 19405 Key : Analysis.IO.Other.Mb Value: 1 Key : Analysis.IO.Read.Mb Value: 1 Key : Analysis.IO.Write.Mb Value: 13 Key : Analysis.Init.CPU.mSec Value: 343 Key : Analysis.Init.Elapsed.mSec Value: 1558 Key : Analysis.Memory.CommitPeak.Mb Value: 103 Key : Analysis.Version.DbgEng Value: 10.0.27829.1001 Key : Analysis.Version.Description Value: 10.2503.24.01 amd64fre Key : Analysis.Version.Ext Value: 1.2503.24.1 Key : Bugcheck.Code.LegacyAPI Value: 0x133 Key : Bugcheck.Code.TargetModel Value: 0x133 Key : Dump.Attributes.AsUlong Value: 0x21808 Key : Dump.Attributes.DiagDataWrittenToHeader Value: 1 Key : Dump.Attributes.ErrorCode Value: 0x0 Key : Dump.Attributes.KernelGeneratedTriageDump Value: 1 Key : Dump.Attributes.LastLine Value: Dump completed successfully. Key : Dump.Attributes.ProgressPercentage Value: 0 Key : Failure.Bucket Value: 0x133_ISR_msgpioclx!GpiopUpdateStatusAndMaskInformation Key : Failure.Hash Value: {e3358d00-0b58-4535-5751-c25c6fecdf14} Key : Hypervisor.Enlightenments.ValueHex Value: 0x7497cf94 Key : Hypervisor.Flags.AnyHypervisorPresent Value: 1 Key : Hypervisor.Flags.ApicEnlightened Value: 1 Key : Hypervisor.Flags.ApicVirtualizationAvailable Value: 0 Key : Hypervisor.Flags.AsyncMemoryHint Value: 0 Key : Hypervisor.Flags.CoreSchedulerRequested Value: 0 Key : Hypervisor.Flags.CpuManager Value: 1 Key : Hypervisor.Flags.DeprecateAutoEoi Value: 0 Key : Hypervisor.Flags.DynamicCpuDisabled Value: 1 Key : Hypervisor.Flags.Epf Value: 0 Key : Hypervisor.Flags.ExtendedProcessorMasks Value: 1 Key : Hypervisor.Flags.HardwareMbecAvailable Value: 1 Key : Hypervisor.Flags.MaxBankNumber Value: 0 Key : Hypervisor.Flags.MemoryZeroingControl Value: 0 Key : Hypervisor.Flags.NoExtendedRangeFlush Value: 0 Key : Hypervisor.Flags.NoNonArchCoreSharing Value: 1 Key : Hypervisor.Flags.Phase0InitDone Value: 1 Key : Hypervisor.Flags.PowerSchedulerQos Value: 0 Key : Hypervisor.Flags.RootScheduler Value: 0 Key : Hypervisor.Flags.SynicAvailable Value: 1 Key : Hypervisor.Flags.UseQpcBias Value: 0 Key : Hypervisor.Flags.Value Value: 38408431 Key : Hypervisor.Flags.ValueHex Value: 0x24a10ef Key : Hypervisor.Flags.VpAssistPage Value: 1 Key : Hypervisor.Flags.VsmAvailable Value: 1 Key : Hypervisor.RootFlags.AccessStats Value: 1 Key : Hypervisor.RootFlags.CrashdumpEnlightened Value: 1 Key : Hypervisor.RootFlags.CreateVirtualProcessor Value: 1 Key : Hypervisor.RootFlags.DisableHyperthreading Value: 0 Key : Hypervisor.RootFlags.HostTimelineSync Value: 1 Key : Hypervisor.RootFlags.HypervisorDebuggingEnabled Value: 0 Key : Hypervisor.RootFlags.IsHyperV Value: 1 Key : Hypervisor.RootFlags.LivedumpEnlightened Value: 1 Key : Hypervisor.RootFlags.MapDeviceInterrupt Value: 1 Key : Hypervisor.RootFlags.MceEnlightened Value: 1 Key : Hypervisor.RootFlags.Nested Value: 0 Key : Hypervisor.RootFlags.StartLogicalProcessor Value: 1 Key : Hypervisor.RootFlags.Value Value: 1015 Key : Hypervisor.RootFlags.ValueHex Value: 0x3f7 Key : Stack.Pointer Value: ISR BUGCHECK_CODE: 133 BUGCHECK_P1: 1 BUGCHECK_P2: 1e00 BUGCHECK_P3: fffff802c91c43b0 BUGCHECK_P4: 0 FILE_IN_CAB: 072925-12718-01.dmp TAG_NOT_DEFINED_202b: *** Unknown TAG in analysis list 202b DUMP_FILE_ATTRIBUTES: 0x21808 Kernel Generated Triage Dump FAULTING_THREAD: ffff938af0df90c0 DPC_TIMEOUT_TYPE: DPC_QUEUE_EXECUTION_TIMEOUT_EXCEEDED BLACKBOXBSD: 1 (!blackboxbsd) BLACKBOXNTFS: 1 (!blackboxntfs) CUSTOMER_CRASH_COUNT: 1 PROCESS_NAME: System STACK_TEXT: fffff802`5ae7c5b8 fffff802`c8489236 : 00000000`00000133 00000000`00000001 00000000`00001e00 fffff802`c91c43b0 : nt!KeBugCheckEx fffff802`5ae7c5c0 fffff802`c848876a : 00000000`00000000 ffffbb81`ac214400 fffff780`00000320 fffff802`57f76180 : nt!KeAccumulateTicks+0x596 fffff802`5ae7c630 fffff802`c848843c : 00000000`00000010 00000000`00000001 00000000`000012bd fffff802`57f76180 : nt!KiUpdateRunTime+0xca fffff802`5ae7c7f0 fffff802`c848ecc9 : 00000000`0000000d fffff802`5ae7cb00 fffff802`57f76180 00000000`0000000f : nt!KiUpdateTime+0x37c fffff802`5ae7c9b0 fffff802`c848f76b : fffff802`c9010ba0 00000000`00000000 fffff802`c9010c50 fffff802`c918e6a8 : nt!KeClockInterruptNotify+0x2e9 fffff802`5ae7caa0 fffff802`c88a782e : ffff938a`f1833a0a fffff802`c9010ba0 0000003d`ec860a12 00000000`4af96298 : nt!KiCallInterruptServiceRoutine+0x31b fffff802`5ae7cb00 fffff802`c88a803c : 00000000`00000000 00000000`00000000 00000000`00000000 fffff802`622e54e0 : nt!KiInterruptSubDispatchNoLockNoEtw+0x4e fffff802`5ae7cb50 fffff802`62304f99 : 00000000`00000000 ffff938a`0000001f fffff802`5ae7ce09 fffff802`62305712 : nt!KiInterruptDispatchNoLockNoEtw+0x3c fffff802`5ae7cce0 fffff802`62304177 : 00000000`00000002 00000000`00000014 00000000`00000001 00000000`00500a02 : msgpioclx!GpiopUpdateStatusAndMaskInformation+0x175 fffff802`5ae7cd80 fffff802`62303cc0 : 00000000`00000000 ffffb789`00000000 00000000`00000000 00000000`00000005 : msgpioclx!GpiopServiceInterrupt+0xa3 fffff802`5ae7ce70 fffff802`6230311a : ffff938a`f1833a90 fffff802`57f7f700 00000000`00000000 00000000`00000000 : msgpioclx!GpiopInterruptBankIsr+0x60 fffff802`5ae7cea0 fffff802`5a80d886 : 00006c75`0e7cbd98 00000000`00000004 00000000`00000000 fffff802`c85718df : msgpioclx!GpioClxEvtInterruptIsr+0x13a fffff802`5ae7ced0 fffff802`c848f987 : 00000000`00000000 00000000`00500a02 fffff802`5a80d810 00000000`0000a000 : Wdf01000!FxInterrupt::_InterruptThunk+0x76 [minkernel\wdf\framework\shared\irphandlers\pnp\km\interruptobjectkm.cpp @ 374] fffff802`5ae7cf10 fffff802`c88a7610 : ffffbb81`ac214508 ffffbb81`ac214500 0000003d`ec85e276 00000000`00000000 : nt!KiCallInterruptServiceRoutine+0x537 fffff802`5ae7cf70 fffff802`c88a71cc : 00000000`4af960ff ffffb789`2fa5eb90 00000000`4af961df 0000003a`74d71bde : nt!KiScanInterruptObjectList+0xa0 ffffb789`2fa5eb10 fffff802`581b001c : fffff802`c88a0cbb 00000000`00000000 ffffb789`2fa5eed0 00000000`00000000 : nt!KiChainedDispatch+0x3c ffffb789`2fa5eca8 fffff802`c88a0cbb : 00000000`00000000 ffffb789`2fa5eed0 00000000`00000000 00000000`00000000 : 0xfffff802`581b001c ffffb789`2fa5ecb0 fffff802`c855a067 : ffff938a`f135c4e0 00000000`00080000 ffffb789`2fa5ef90 00000003`0db937d2 : nt!HvlSwitchToVsmVtl1+0xab ffffb789`2fa5edf0 fffff802`c85af0bd : 81726179`b26689f9 20354f15`d4ccc98b 00000000`00000000 00000000`00000000 : nt!VslpEnterIumSecureMode+0x137 ffffb789`2fa5eeb0 fffff802`c84bea02 : 00000000`00000803 20354f15`d4ccc98b ffffb789`2fa5efa8 00000000`00000000 : nt!VslSetPrivilegedPte+0x65 ffffb789`2fa5ef80 fffff802`c8469f86 : fffff802`c9037a80 ffffa3fc`012e58a8 ffffdc80`10cfc1d0 ffffb789`00000000 : nt!MiAllocateWsle+0x6f2 ffffb789`2fa5f050 fffff802`c846add8 : ffffb789`2fa5f330 00000000`0059a95f 00000000`00000000 20354f15`00000000 : nt!MiCompleteProtoPteFault+0x476 ffffb789`2fa5f140 fffff802`c84173c8 : a78f0a2c`00000000 ffffa78f`0a2c75d8 0a000005`9a95f121 00000000`00000000 : nt!MiResolveTransitionFault+0x3d8 ffffb789`2fa5f220 fffff802`c8416a0d : 00000000`00000000 00000000`00000000 ffffb789`2fa5f2e8 fffff802`5cb15300 : nt!MiResolveProtoPteFault+0x288 ffffb789`2fa5f2b0 fffff802`c84ae33c : ff000000`ff000000 ffff8000`00000000 fffff802`5cb15300 0000007f`fffffff8 : nt!MiDispatchFault+0x1dd ffffb789`2fa5f420 fffff802`c88b48cb : ffff938a`ea402000 20354f15`d4ccc98b ffff938a`f12bbc70 000004d0`fffffb30 : nt!MmAccessFault+0x20c ffffb789`2fa5f590 fffff802`5cb15300 : fffff802`5cab1b4e ff000000`ff000000 ff000000`ff000000 ff000000`ff000000 : nt!KiPageFault+0x38b ffffb789`2fa5f728 fffff802`5cab1b4e : ff000000`ff000000 ff000000`ff000000 ff000000`ff000000 ff000000`ff000000 : netbt!TdiBindHandler ffffb789`2fa5f730 fffff802`5cab3a3f : fffff802`5caba3d0 ffffb789`00000000 00000000`00000001 00000000`00000000 : TDI!TdiNotifyPnpClientList+0x3de ffffb789`2fa5f7c0 fffff802`5cab33c6 : 00000000`00000013 ffff938a`f0df90c0 00000000`00000000 20354f15`d4ccc98b : TDI!TdiExecuteRequest+0x42f ffffb789`2fa5f820 fffff802`5cab521e : 00000000`00000001 00000000`00000000 fffff802`5cab521e fffff802`5ca91372 : TDI!TdiHandleSerializedRequest+0x136 ffffb789`2fa5f890 fffff802`5ca91372 : 00000000`00000000 00000000`00000000 ffffffff`ffffffa0 fffff802`5ca93ce2 : TDI!TdiProviderReady+0xe ffffb789`2fa5f8c0 fffff802`5ca93d2c : 00000000`00000003 ffffb789`2fa5f990 ffff938a`ea602ae0 00000000`00000000 : tdx!TdxDecrementNotReadyInterfaceCount+0x86 ffffb789`2fa5f900 fffff802`c855f252 : ffff938a`f0859e00 ffff938a`f0819d10 00000000`00000000 00000000`00000000 : tdx!TdxProviderReadyWorkItemRoutine+0x13c ffffb789`2fa5f940 fffff802`c84302e3 : ffff938a`f0df90c0 ffff938a`ea602ae0 ffffbb81`a9998100 ffff938a`f0df90c0 : nt!IopProcessWorkItem+0x502 ffffb789`2fa5f9d0 fffff802`c869e2da : ffff938a`f0df90c0 ffff938a`f0df90c0 fffff802`c8430140 ffff938a`ea602ae0 : nt!ExpWorkerThread+0x1a3 ffffb789`2fa5fbb0 fffff802`c88a67e4 : ffffbb81`a9998180 ffff938a`f0df90c0 fffff802`c869e280 00000000`00000000 : nt!PspSystemThreadStartup+0x5a ffffb789`2fa5fc00 00000000`00000000 : ffffb789`2fa60000 ffffb789`2fa59000 00000000`00000000 00000000`00000000 : nt!KiStartSystemThread+0x34 SYMBOL_NAME: msgpioclx!GpiopUpdateStatusAndMaskInformation+175 MODULE_NAME: msgpioclx IMAGE_NAME: msgpioclx.sys IMAGE_VERSION: 10.0.26100.4484 STACK_COMMAND: .process /r /p 0xffff938aea4a4040; .thread 0xffff938af0df90c0 ; kb BUCKET_ID_FUNC_OFFSET: 175 FAILURE_BUCKET_ID: 0x133_ISR_msgpioclx!GpiopUpdateStatusAndMaskInformation OSPLATFORM_TYPE: x64 OSNAME: Windows 10 FAILURE_ID_HASH: {e3358d00-0b58-4535-5751-c25c6fecdf14} Followup: MachineOwner --------- [SMBIOS Data Tables v3.3] [DMI Version - 0] [2.0 Calling Convention - No] [Table Size - 2063 bytes] [32Bit Memory Error Information (Type 18) - Length 23 - Handle 0000h] [Physical Memory Array (Type 16) - Length 23 - Handle 0001h] Location 03h - SystemBoard/Motherboard Use 03h - System Memory Memory Error Correction 03h - None Maximum Capacity 67108864KB Memory Error Inf Handle 0000h Number of Memory Devices 2 [Memory Array Mapped Address (Type 19) - Length 31 - Handle 0002h] Starting Address 00000000h Ending Address 017fffffh Memory Array Handle 0001h Partition Width 02 Extended Starting Address 0000000000000000h Extended Ending Address 0000000000000000h [Cache Information (Type 7) - Length 27 - Handle 0003h] Socket Designation L1 - Cache Cache Configuration 0180h - WBEnabled Int NonSocketed L1 Maximum Cache Size 0200h - 512K Installed Size 0200h - 512K Supported SRAM Type 0010h - Pipeline-Burst Current SRAM Type 0010h - Pipeline-Burst Cache Speed 1ns Error Correction Type Specification Reserved System Cache Type Unified Associativity 8-way Set-Associative Maximum Cache Size 2 200 - 00000512l Kb Installed Cache Size 2 200 - 00000512l Kb [Cache Information (Type 7) - Length 27 - Handle 0004h] Socket Designation L2 - Cache Cache Configuration 0181h - WBEnabled Int NonSocketed L2 Maximum Cache Size 1000h - 4096K Installed Size 1000h - 4096K Supported SRAM Type 0010h - Pipeline-Burst Current SRAM Type 0010h - Pipeline-Burst Cache Speed 1ns Error Correction Type Specification Reserved System Cache Type Unified Associativity 8-way Set-Associative Maximum Cache Size 2 1000 - 00004096l Kb Installed Cache Size 2 1000 - 00004096l Kb [Cache Information (Type 7) - Length 27 - Handle 0005h] Socket Designation L3 - Cache Cache Configuration 0182h - WBEnabled Int NonSocketed L3 Maximum Cache Size 4000h - 16384K Installed Size 4000h - 16384K Supported SRAM Type 0010h - Pipeline-Burst Current SRAM Type 0010h - Pipeline-Burst Cache Speed 1ns Error Correction Type Specification Reserved System Cache Type Unified Associativity 16-way Set-Associative Maximum Cache Size 2 4000 - 00016384l Kb Installed Cache Size 2 4000 - 00016384l Kb [Processor Information (Type 4) - Length 48 - Handle 0006h] Socket Designation FP6 Processor Type Central Processor Processor Family 6bh - AMD Zen Processor Family Processor Manufacturer Advanced Micro Devices, Inc. Processor ID fa500fffb8b17 Processor Version AMD Ryzen 7 5825U with Radeon Graphics Processor Voltage 8ch - 1.2V External Clock 100MHz Max Speed 4550MHz Current Speed 2000MHz Status Enabled Populated Processor Upgrade None L1 Cache Handle 0003h L2 Cache Handle 0004h L3 Cache Handle 0005h Serial Number Asset Tag Number Part Number Null Core Count 8 Core Enabled 8 Thread Count 16 Processor Characteristics fc Enabled Characteristics: 0x 2: 64-bit Capable 0x 3: Multi-Core 0x 4: Hardware Thread 0x 5: Execute Protection 0x 6: Enhanced Virtualization 0x 7: Power/Performance Control Processor Family 2 006bh - AMD Zen Processor Family Core Count 2 8 Core Enabled 2 8 Thread Count 2 16 [32Bit Memory Error Information (Type 18) - Length 23 - Handle 0007h] [Memory Device (Type 17) - Length 92 - Handle 0008h] Memory Error Info Handle 0007h Total Width 64 bits Data Width 64 bits Size 16384MB Form Factor 0dh - SODIMM Device Set [None] Device Locator DIMM 0 Bank Locator P0 CHANNEL A Memory Type 1ah - DDR4 Type Detail 4080h - Synchronous Unbuffered (Unregistered) Speed 3200MHz Manufacturer Micron Technology Serial Number Asset Tag Number [String Not Specified] Part Number CT16G4SFRA32A.C16FR Attributes 2 Extended Size 0 Configured Memory Speed 3200 Minimum Voltage 1200 Maximum Voltage 1200 Configured Voltage 1200 Memory Technology 3 Memory Operating Mode Capability 8 Firmware Version 6 Module Manufacturer Id 11392 Module Product Id 0 Memory Subsystem Controller Manufacturer Id 0 Memory Subsystem Controller Product Id 0 Non-Volatile Size 0 Volatile Size 0 Cache Size 0 Logical Size 0 Extended Speed 0 Extended Configured Memory Speed 0 [Memory Device Mapped Address (Type 20) - Length 35 - Handle 0009h] Starting Address 00000000h Ending Address 017fffffh Memory Device Handle 0008h Mem Array Mapped Adr Handle 0002h Partition Row Position [Unknown] Interleave Position [Unknown] Interleave Data Depth [Unknown] Extended Starting Address 0000000000000000h Extended Ending Address 0000000000000000h [32Bit Memory Error Information (Type 18) - Length 23 - Handle 000ah] [Memory Device (Type 17) - Length 92 - Handle 000bh] Memory Error Info Handle 000ah Total Width 64 bits Data Width 64 bits Size 8192MB Form Factor 0bh - Row of chips Device Set [None] Device Locator DIMM 0 Bank Locator P0 CHANNEL B Memory Type 1ah - DDR4 Type Detail 4080h - Synchronous Unbuffered (Unregistered) Speed 3200MHz Manufacturer Hynix Serial Number Asset Tag Number [String Not Specified] Part Number HMAA1GS6CJR6N-XN Attributes 1 Extended Size 0 Configured Memory Speed 3200 Minimum Voltage 1200 Maximum Voltage 1200 Configured Voltage 1200 Memory Technology 3 Memory Operating Mode Capability 8 Firmware Version 6 Module Manufacturer Id 44416 Module Product Id 0 Memory Subsystem Controller Manufacturer Id 0 Memory Subsystem Controller Product Id 0 Non-Volatile Size 0 Volatile Size 0 Cache Size 0 Logical Size 0 Extended Speed 0 Extended Configured Memory Speed 0 [Memory Device Mapped Address (Type 20) - Length 35 - Handle 000ch] Starting Address 00000000h Ending Address 00ffffffh Memory Device Handle 000bh Mem Array Mapped Adr Handle 0002h Partition Row Position [Unknown] Interleave Position [Unknown] Interleave Data Depth [Unknown] Extended Starting Address 0000000000000000h Extended Ending Address 0000000000000000h [Onboard Devices Information (Type 10) - Length 6 - Handle 0028h] Note: The On Board Device Information (Type 10) struct is obsolete as of SMBIOs spec v2.6 Number of Devices 1 01: Type Video [enabled] 01: Description AMD Renoir FP6 GPU [Onboard Devices Information (Type 10) - Length 6 - Handle 0029h] Note: The On Board Device Information (Type 10) struct is obsolete as of SMBIOs spec v2.6 Number of Devices 1 01: Type Sound [enabled] 01: Description AZALIA HD Audio [Onboard Devices Information (Type 10) - Length 6 - Handle 002ah] Note: The On Board Device Information (Type 10) struct is obsolete as of SMBIOs spec v2.6 Number of Devices 1 01: Type Specification Reserved [enabled] 01: Description AMD Renoir FP6 [Onboard Devices Information (Type 10) - Length 6 - Handle 002bh] Note: The On Board Device Information (Type 10) struct is obsolete as of SMBIOs spec v2.6 Number of Devices 1 01: Type Unknown [enabled] 01: Description ST TPM ST33TPMESPI [ (Type 256) - Length 21 - Handle 0030h] [ (Type 256) - Length 5 - Handle 0032h] [ (Type 256) - Length 18 - Handle 0033h] [OEM Strings (Type 11) - Length 5 - Handle 002ch] Number of Strings 1 1 Modern Preload [BIOS Information (Type 0) - Length 24 - Handle 000dh] Vendor LENOVO BIOS Version JTCN49WW BIOS Starting Address Segment e000 BIOS Release Date 09/18/2023 BIOS ROM Size 1000000 BIOS Characteristics 00: - Reserved 01: - Reserved 07: - PCI Supported 08: - PCMCIA Supported 09: - Plug and Play Supported 10: - APM Supported 11: - Upgradeable FLASH BIOS 12: - BIOS Shadowing Supported 15: - CD-Boot Supported 16: - Selectable Boot Supported 19: - EDD Supported 26: - Print Screen Device Supported 27: - Keyboard Services Supported 28: - Serial Services Supported 29: - Printer Services Supported 30: - CGA/Mono Services Supported 49: - System Vendor Reserved 51: - System Vendor Reserved 52: - System Vendor Reserved BIOS Characteristic Extensions 00: - ACPI Supported 01: - USB Legacy Supported 08: - BIOS Boot Specification Supported 09: - Fn-Key NET-Boot Supported 10: - Enable Targeted Content Distribution 11: - UEFI Specification Supported BIOS Major Revision 1 BIOS Minor Revision 49 EC Firmware Major Revision 1 EC Firmware Minor Revision 49 [System Information (Type 1) - Length 27 - Handle 000eh] Manufacturer LENOVO Product Name 82TV Version Lenovo V15 G3 ABA Serial Number PF4T9SXW UUID 00000000-0000-0000-0000-000000000000 Wakeup Type Power Switch SKUNumber LENOVO_MT_82TV_BU_idea_FM_V15 G3 ABA Family V15 G3 ABA [BaseBoard Information (Type 2) - Length 15 - Handle 000fh] Manufacturer LENOVO Product LNVNB161216 Version NO DPK Serial Number PF4T9SXW Asset Tag Feature Flags 09h 00: - Motherboard 03: - Replaceable Location Base Board Chassis Location Chassis Handle 0010h Board Type 0ah - Processor/Memory Module Number of Child Handles 0 [System Enclosure (Type 3) - Length 22 - Handle 0010h] Manufacturer LENOVO Chassis Type Notebook Version Lenovo V15 G3 ABA Serial Number Asset Tag Number Bootup State Safe Power Supply State Safe Thermal State Other Security Status Other OEM Defined 0 Height 0U Number of Power Cords 1 Number of Contained Elements 0 Contained Element Size 0 [ (Type 256) - Length 4 - Handle feffh]
Evet hocam düzeldi. Yardımınız için teşekkürler.BIOS güncelleme fayda etmeli. Çipsetin AMD sitesinden indirilmesini öneririm.
Sanırım bu:
We use cookies and similar technologies for the following purposes:
Do you accept cookies and these technologies?
