Çözüldü RTX 3050 laptopta Valorant mavi ekran hatası
10710
16 Eylül 2024
富士山(Mount Fuji)
Merhaba. Oyuna güncelleme gelmişti. Ben de yaptım oyuna gireyim dediğim an mavi ekran hatası aldım. Ekrana çıkan kodu tepkimden dolayı hatırlamıyorum.
Minidump
Soruna Vanguard sebep olmuş. BIOS'u son sürüme çekin:
Windows 11 sürümünüz de eski, onu da 24H2 yapın.
Kod:
DPC_WATCHDOG_VIOLATION (133)
The DPC watchdog detected a prolonged run time at an IRQL of DISPATCH_LEVEL
or above.
Arguments:
Arg1: 0000000000000000, A single DPC or ISR exceeded its time allotment. The offending
    component can usually be identified with a stack trace.
Arg2: 0000000000000501, The DPC time count (in ticks).
Arg3: 0000000000000500, The DPC time allotment (in ticks).
Arg4: fffff8028191d340, cast to nt!DPC_WATCHDOG_GLOBAL_TRIAGE_BLOCK, which contains
    additional information regarding this single DPC timeout
Debugging Details:
***    Either you specified an unqualified symbol, or your debugger   ***
***    doesn't have full symbol information.  Unqualified symbol      ***
***    resolution is turned off by default. Please either specify a   ***
***    fully qualified symbol module!symbolname, or enable resolution ***
***    of unqualified symbols by typing ".symopt- 100". Note that     ***
***    enabling unqualified symbol resolution with network symbol     ***
***    server shares in the symbol path may cause the debugger to     ***
***    appear to hang for long periods of time when an incorrect      ***
***    symbol name is typed or the network symbol server is down.     ***
***    For some commands to work properly, your symbol path           ***
***    must point to .pdb files that have full type information.      ***
***    Certain .pdb files (such as the public OS symbols) do not      ***
***    contain the required information.  Contact the group that      ***
***    provided you with these symbols if you need this command to    ***
***    work.                                                          ***
***    Type referenced: TickPeriods                                   ***
KEY_VALUES_STRING: 1
    Key  : Analysis.CPU.mSec
    Value: 1703
    Key  : Analysis.Elapsed.mSec
    Value: 8094
    Key  : Analysis.IO.Other.Mb
    Value: 0
    Key  : Analysis.IO.Read.Mb
    Value: 0
    Key  : Analysis.IO.Write.Mb
    Value: 0
    Key  : Analysis.Init.CPU.mSec
    Value: 343
    Value: 1961
    Value: 88
    Value: 10.0.27704.1001
    Value: 10.2408.27.01 amd64fre
    Key  : Analysis.Version.Ext
    Value: 1.2408.27.1
    Value: 0x133
    Value: 0x133
    Key  : Failure.Bucket
    Value: 0x133_DPC_vgk!unknown_function
    Key  : Failure.Hash
    Value: {c6b0ff3e-a486-40ca-f153-c5b1572fe2c1}
    Key  : Stack.Pointer
    Value: ISR
    Key  : WER.OS.Branch
    Value: ni_release
    Key  : WER.OS.Version
    Value: 10.0.22621.1
BUGCHECK_CODE:  133
BUGCHECK_P1: 0
BUGCHECK_P2: 501
BUGCHECK_P3: 500
BUGCHECK_P4: fffff8028191d340
FILE_IN_CAB:  092724-11234-01.dmp
FAULTING_THREAD:  fffff8028194d700
DPC_TIMEOUT_TYPE:  SINGLE_DPC_TIMEOUT_EXCEEDED
TRAP_FRAME:  fffff8027d322890 -- (.trap 0xfffff8027d322890)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=0000000000000001 rbx=0000000000000000 rcx=fffff802af4a9cc8
rdx=ffffb50fbd1e0320 rsi=0000000000000000 rdi=0000000000000000
rip=fffff80280e4f7ef rsp=fffff8027d322a20 rbp=fffff8027d322b98
 r8=ffffb50fbd1e0338  r9=fffff8027d322b80 r10=0000fffff802d921
r11=fffff80280e4fe60 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0         nv up ei pl nz na pe nc
nt!KxWaitForSpinLockAndAcquire+0x1f:
fffff802`80e4f7ef 4885c0          test    rax,rax
Resetting default scope
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  System
STACK_TEXT:
fffff802`7d332c88 fffff802`80e2f6e5     : 00000000`00000133 00000000`00000000 00000000`00000501 00000000`00000500 : nt!KeBugCheckEx
fffff802`7d332c90 fffff802`80e2edb1     : 00001966`91b8fcfa 00000000`0058c764 00000000`0058c763 00000000`00000000 : nt!KeAccumulateTicks+0x3d5
fffff802`7d332cf0 fffff802`80e2ce41     : 00000000`00000000 ffffda80`0dd69300 fffff802`7cfb9180 00000000`00000000 : nt!KiUpdateRunTime+0xd1
fffff802`7d332ea0 fffff802`80e2c86a     : fffff802`8185ff10 ffffda80`0dd69330 ffffda80`0dd69330 00000000`00000002 : nt!KeClockInterruptNotify+0xc1
fffff802`7d332f40 fffff802`80eb76bc     : 000000d3`ad4cfe58 fffff802`8190d570 fffff802`8190d620 fffff802`81017fab : nt!HalpTimerClockInterrupt+0x10a
fffff802`7d332f70 fffff802`8101820a     : fffff802`7d322910 fffff802`8190d570 fffff802`af4a9cc8 00000000`00000000 : nt!KiCallInterruptServiceRoutine+0x9c
fffff802`7d332fb0 fffff802`81018ad7     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiInterruptSubDispatchNoLockNoEtw+0xfa
fffff802`7d322890 fffff802`80e4f7ef     : 00000000`05000000 00000000`000000c0 00000000`00000040 00000000`00000000 : nt!KiInterruptDispatchNoLockNoEtw+0x37
fffff802`7d322a20 fffff802`80e4fe80     : ffffb50f`bac87cb0 00000000`00000000 fffff802`7cfb9180 fffff802`7d322b80 : nt!KxWaitForSpinLockAndAcquire+0x1f
fffff802`7d322a50 fffff802`af483828     : fffff802`00000001 fffff802`7cfb9180 ffffda80`00000000 ffffda80`0d2a2180 : nt!KeAcquireSpinLockAtDpcLevel+0x20
fffff802`7d322a80 fffff802`00000001     : fffff802`7cfb9180 ffffda80`00000000 ffffda80`0d2a2180 fffff802`81118680 : vgk+0x63828
fffff802`7d322a88 fffff802`7cfb9180     : ffffda80`00000000 ffffda80`0d2a2180 fffff802`81118680 fffff802`80ec12de : 0xfffff802`00000001
fffff802`7d322a90 ffffda80`00000000     : ffffda80`0d2a2180 fffff802`81118680 fffff802`80ec12de 00000000`00000000 : 0xfffff802`7cfb9180
fffff802`7d322a98 ffffda80`0d2a2180     : fffff802`81118680 fffff802`80ec12de 00000000`00000000 fffff802`80e4fe60 : 0xffffda80`00000000
fffff802`7d322aa0 fffff802`8111867f     : fffff802`80ec12de 00000000`00000000 fffff802`80e4fe60 fffff802`7d322ba0 : 0xffffda80`0d2a2180
fffff802`7d322aa8 fffff802`80ec12de     : 00000000`00000000 fffff802`80e4fe60 fffff802`7d322ba0 fffff802`d91011bf : nt!HalpApic1WaitForIcr+0x1f
fffff802`7d322ab0 00000000`00000000     : ffffb50f`bd1e01c0 ffffb50f`c04a0580 00000000`00000002 fffff802`d91f3888 : nt!HalpApicRequestInterrupt+0x9e
SYMBOL_NAME:  vgk+63828
MODULE_NAME: vgk
IMAGE_NAME:  vgk.sys
STACK_COMMAND:  .process /r /p 0xfffff80281949f40; .thread 0xfffff8028194d700 ; kb
BUCKET_ID_FUNC_OFFSET:  63828
FAILURE_BUCKET_ID:  0x133_DPC_vgk!unknown_function
OS_VERSION:  10.0.22621.1
BUILDLAB_STR:  ni_release
OSPLATFORM_TYPE:  x64
OSNAME:  Windows 10
FAILURE_ID_HASH:  {c6b0ff3e-a486-40ca-f153-c5b1572fe2c1}
Followup:     MachineOwner
    PnpActivityId      : {00000000-0000-0000-0000-000000000000}
    PnpActivityTime    : 133719254260641415
    PnpEventInformation: 3
    PnpEventInProgress : 0
    PnpProblemCode     : 24
    PnpVetoType        : 0
    DeviceId           : SW\{96E080C7-143C-11D1-B40F-00A0C9223196}\{3C0D501A-140B-11D1-B40F-00A0C9223196}
    VetoString         :
[SMBIOS Data Tables v3.4]
[DMI Version - 0]
[2.0 Calling Convention - No]
[Table Size - 2307 bytes]
  Vendor                        LENOVO
  BIOS Version                  JNCN48WW(V2.08)
  BIOS Starting Address Segment e000
  BIOS Release Date             09/19/2023
  BIOS ROM Size                 1000000
  BIOS Characteristics
       07: - PCI Supported
       11: - Upgradeable FLASH BIOS
       15: - CD-Boot Supported
       19: - EDD Supported
       22: - 360KB Floppy Supported
       23: - 1.2MB Floppy Supported
       24: - 720KB Floppy Supported
       25: - 2.88MB Floppy Supported
       27: - Keyboard Services Supported
       49: - System Vendor Reserved
       51: - System Vendor Reserved
       52: - System Vendor Reserved
       00: - ACPI Supported
       01: - USB Legacy Supported
  BIOS Major Revision           1
  BIOS Minor Revision           48
  EC Firmware Major Revision    1
  EC Firmware Minor Revision    48
  Extended BIOS ROM Size        32 MB
  Manufacturer                  LENOVO
  Product Name                  82SB
  Version                       IdeaPad Gaming 3 15ARH7
  Serial Number                 MP2LV7GL
  SKUNumber                     LENOVO_MT_82SB_BU_idea_FM_IdeaPad Gaming 3 15ARH7
  Family                        IdeaPad Gaming 3 15ARH7
[BaseBoard Information (Type 2) - Length 16 - Handle 0002h]
  Manufacturer                  LENOVO
  Product                       LNVNB161216
  Version                       SDK0T76466 WIN
  Asset Tag
       00: - Motherboard
       03: - Replaceable
  Location                      Base Board Chassis Location
[System Enclosure (Type 3) - Length 23 - Handle 0003h]
  Manufacturer                  LENOVO
  Chassis Type                  Notebook
  Serial Number
  Asset Tag Number
  Contained Element Size        0
  SKU Number                    Chassis SKU
[Processor Information (Type 4) - Length 48 - Handle 0004h]
  Socket Designation            FP7
  Processor Family              6bh - AMD Zen Processor Family
  Processor Manufacturer        Advanced Micro Devices, Inc.
  Processor ID                   410fa400fffb8b17
  Processor Version             AMD Ryzen 5 6600H with Radeon Graphics
  Processor Voltage             8ch - 1.2V
  Max Speed                     4550MHz
  Current Speed                 3300MHz
  Processor Upgrade             None
  L1 Cache Handle               0005h
  L2 Cache Handle               0006h
  L3 Cache Handle               0007h
  Serial Number
  Asset Tag Number
  Part Number                   Unknown
  Core Count                    6
  Core Enabled                  6
  Thread Count                  12
  Processor Characteristics     fc
  Enabled Characteristics:
       0x 2: 64-bit Capable
       0x 3: Multi-Core
       0x 4: Hardware Thread
       0x 5: Execute Protection
       0x 6: Enhanced Virtualization
  Processor Family 2            006bh - AMD Zen Processor Family
  Core Count 2                  6
  Core Enabled 2                6
  Thread Count 2                12
[Cache Information (Type 7) - Length 27 - Handle 0005h]
  Socket Designation            L1 - Cache
  Maximum Cache Size            0180h - 384K
  Installed Size                0180h - 384K
  Supported SRAM Type           0010h - Pipeline-Burst
  Current SRAM Type             0010h - Pipeline-Burst
  Cache Speed                   1ns
  Maximum Cache Size 2          180 - 00000384l Kb
  Installed Cache Size 2        180 - 00000384l Kb
[Cache Information (Type 7) - Length 27 - Handle 0006h]
  Socket Designation            L2 - Cache
  Maximum Cache Size            0c00h - 3072K
  Installed Size                0c00h - 3072K
  Cache Speed                   1ns
  Maximum Cache Size 2          c00 - 00003072l Kb
  Installed Cache Size 2        c00 - 00003072l Kb
[Cache Information (Type 7) - Length 27 - Handle 0007h]
  Socket Designation            L3 - Cache
  Maximum Cache Size            4000h - 16384K
  Installed Size                4000h - 16384K
  Cache Speed                   1ns
  Associativity                 16-way Set-Associative
  Maximum Cache Size 2          4000 - 00016384l Kb
  Installed Cache Size 2        4000 - 00016384l Kb
[OEM Strings (Type 11) - Length 5 - Handle 001ah]
  Number of Strings             2
   1                            Country - ÿÿ
   2                            Modern Preload
[System Configuration Options (Type 12) - Length 5 - Handle 001bh]
[Physical Memory Array (Type 16) - Length 23 - Handle 001dh]
  Maximum Capacity              67108864KB
  Memory Error Inf Handle       0020h
  Number of Memory Devices      2
[Memory Device (Type 17) - Length 92 - Handle 001eh]
  Memory Error Info Handle      0021h
  Size                          8192MB
  Form Factor                   0dh - SODIMM
  Device Locator                DIMM 0
  Bank Locator                  P0 CHANNEL A
  Memory Type                   22h - DDR5
  Type Detail                   4080h - Synchronous Unbuffered (Unregistered)
  Speed                         4800MHz
  Manufacturer                  Samsung
  Serial Number
  Asset Tag Number              [String Not Specified]
  Part Number                   M425R1GB4BB0-CQKOL
  Attributes                    1
  Configured Memory Speed       4800
  Minimum Voltage               1100
  Maximum Voltage               1100
  Configured Voltage            1100
  Memory Technology             3
  Memory Operating Mode Capability     8
  Firmware Version              6
  Module Manufacturer Id        52864
  Module Product Id             0
  Memory Subsystem Controller Manufacturer Id  0
  Memory Subsystem Controller Product Id       0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
  Extended Configured Memory Speed     0
[Memory Device (Type 17) - Length 92 - Handle 001fh]
  Memory Error Info Handle      0022h
  Total Width                   [Unknown]
  Data Width                    [Unknown]
  Size                          [Not Populated]
  Form Factor                   02h - Unknown
  Bank Locator                  P0 CHANNEL B
  Memory Type                   02h - Unknown
  Type Detail                   0004h - Unknown
  Speed                         0MHz
  Manufacturer                  Unknown
  Serial Number
  Part Number                   Unknown
  Attributes                    0
  Minimum Voltage               0
  Maximum Voltage               0
  Configured Voltage            0
  Memory Technology             2
  Memory Operating Mode Capability     4
  Firmware Version              6
  Module Manufacturer Id        0
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 0020h]
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 0021h]
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 0022h]
[Memory Array Mapped Address (Type 19) - Length 31 - Handle 0023h]
  Ending Address                007fffffh
  Memory Array Handle           001dh
  Partition Width               01
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 0024h]
  Memory Device Handle          001eh
  Mem Array Mapped Adr Handle   0023h
  Interleave Position           [Unknown]
  Interleave Data Depth         [Unknown]
[ (Type 256) - Length 18 - Handle 002ah]
[ (Type 256) - Length 11 - Handle 002bh]
[ (Type 256) - Length 11 - Handle 002ch]
[ (Type 256) - Length 5 - Handle 002dh]
[ (Type 256) - Length 18 - Handle 002fh]
[ (Type 256) - Length 4 - Handle feffh]
Kod:
or above.
Arguments:
Debugging Details:
***    work.                                                          ***
    Value: 1703
    Value: 8094
    Value: 0
    Value: 0
    Value: 0
    Value: 343
    Value: 1961
    Value: 88
    Value: 1.2408.27.1
    Value: 0x133
    Value: 0x133
    Key  : Failure.Hash
    Key  : Stack.Pointer
    Value: ISR
    Key  : WER.OS.Branch
    Value: ni_release
    Value: 10.0.22621.1
BUGCHECK_CODE:  133
BUGCHECK_P1: 0
BUGCHECK_P2: 501
BUGCHECK_P3: 500
BLACKBOXWINLOGON: 1
STACK_TEXT:
MODULE_NAME: vgk
IMAGE_NAME:  vgk.sys
OSNAME:  Windows 10
    PnpProblemCode     : 24
    PnpVetoType        : 0
    VetoString         :
[DMI Version - 0]
  Vendor                        LENOVO
       07: - PCI Supported
       19: - EDD Supported
  Manufacturer                  LENOVO
  Product Name                  82SB
  Manufacturer                  LENOVO
  Product                       LNVNB161216
  Asset Tag
       00: - Motherboard
       03: - Replaceable
  Manufacturer                  LENOVO
  Serial Number
  Asset Tag Number
  Max Speed                     4550MHz
  Serial Number
  Asset Tag Number
  Part Number                   Unknown
  Core Count                    6
  Core Enabled                  6
  Thread Count                  12
       0x 3: Multi-Core
  Core Count 2                  6
  Core Enabled 2                6
  Thread Count 2                12
  Cache Speed                   1ns
  Cache Speed                   1ns
  Cache Speed                   1ns
  Number of Strings             2
   1                            Country - ÿÿ
   2                            Modern Preload
  Size                          8192MB
  Speed                         4800MHz
  Serial Number
  Attributes                    1
  Memory Technology             3
  Firmware Version              6
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
  Speed                         0MHz
  Serial Number
  Part Number                   Unknown
  Attributes                    0
  Minimum Voltage               0
  Maximum Voltage               0
  Memory Technology             2
  Firmware Version              6
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
  Partition Width               01
