Çözüldü Rust oyununa girince sistem mavi ekran veriyor
nemexuv
27 Temmuz 2024
Dün gece oyun oynadığımda bir sıkıntı yoktu saatlerce oynadım sabah uyandığımda oyuna girdim sunucuya girerken mavi ekran verdi sunucuya girmeden denedim ve yine mavi ekran verdi
Minidump dosyası aşağıda
Kod:
************* Preparing the environment for Debugger Extensions Gallery repositories **************
 ExtensionRepository : Implicit
 UseExperimentalFeatureForNugetShare : True
 AllowNugetExeUpdate : True
 NonInteractiveNuget : True
 AllowNugetMSCredentialProviderInstall : True
 AllowParallelInitializationOfLocalRepositories : True
 EnableRedirectToChakraJsProvider : False
 -- Configuring repositories
 ----> Repository : LocalInstalled, Enabled: True
 ----> Repository : UserExtensions, Enabled: True
[QUOTE]
>>>>>>>>>>>> Preparing the environment for Debugger Extensions Gallery repositories completed, duration 0.000 seconds
[/QUOTE]
************* Waiting for Debugger Extensions Gallery to Initialize **************
[QUOTE]
>>>>>>>>>>>> Waiting for Debugger Extensions Gallery to Initialize completed, duration 0.031 seconds
[/QUOTE]
----> Repository : UserExtensions, Enabled: True, Packages count: 0
 ----> Repository : LocalInstalled, Enabled: True, Packages count: 42
Microsoft (R) Windows Debugger Version 10.0.27668.1000 AMD64
Copyright (C) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\082224-12671-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
************* Path validation summary **************
Response Time (ms) Location
Deferred srv*
Symbol Search path is: Srv*
Executable Search path is:
Windows 10 Kernel Version 26100 MP (6 procs) Free X64
Product: WinNt, Suite: TerminalServer SingleUserTS
Kernel base = 0xfffff800`e9e00000 PsLoadedModuleList = 0xfffff800`eacf4520
Debug session time: Thu AUG 22 12:36:40.878 2024 (UTC + 3:00)
System Uptime: 0 days 0:07:30.571
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
For analysis of this file, run !analyze -v
NT!KeBugCheckEx:
Fffff800'EA2b96b0 48894C2408 mov qword ptr [rsp+8],rcx SS:0018:fffffa8C'ddc12C50 = 000000000000001E
1: Kd> !analyze -v
[LIST]
[*]Bugcheck Analysis *
[/LIST]
KMODE_EXCEPTION_NOT_HANDLED (1e)
This is a Very common BugCheck. Usually the exception address pinpoints
The driver/function that caused the problem. Always Note this address
As well as the link date of the driver/image that contains this address.
Arguments:
Arg1: FffffffFC0000005, The exception code that was not handled
Arg2: FffFF8008EA9089C, The address that the exception occurred at
Arg3: 0000000000000000, Parameter 0 of the exception
Arg4: 0000000000000000, Parameter 1 of the exception
Debugging Details:
* Either you specified an unqualified symbol, or your debugger *
* Doesn't have Full symbol information. Unqualified symbol *
* Resolution is turned off by default. Please either specify a *
* Fully qualified symbol module!symbolname, or enable resolution *
* Of unqualified symbols by typing ".symopt- 100". Note that *
* Enabling unqualified symbol resolution with network symbol *
* Server shares in the symbol path may cause the debugger to *
* Appear to hang for long periods of time when an incorrect *
* Symbol name is typed or the network symbol server is down. *
* For some commands to work properly, your symbol path *
* Must point to .pdb files that have Full type information. *
* Certain .pdb files (such as the public OS symbols) do not *
* Contain the required information. Contact the group that *
* Provided you with these symbols if you need this command to *
* Work. *
* Type referenced: ExceptionRecord *
* Work. *
* Type referenced: ContextRecord *
KEY_VALUES_STRING: 1
 Key : Analysis.CPU.mSec
 Value: 2624
 Key : Analysis.Elapsed.mSec
 Value: 3773
 Key : Analysis.IO.Other.MB
 Value: 0
 Key : Analysis.IO.Read.MB
 Value: 0
 Key : Analysis.IO.Write.MB
 Value: 0
 Key : Analysis.Init.CPU.mSec
 Value: 452
 Value: 4326
 Key : Analysis.Memory.CommitPeak.MB
 Value: 85
 Key : Bugcheck.Code.LegacyAPI
 Value: 0x1e
 Key : Bugcheck.Code.TargetModel
 Value: 0x1e
 Key : Dump.Attributes.AsUlong
 Value: 21008
 Key : Dump.Attributes.DiagDataWrittenToHeader
 Value: 1
 Key : Dump.Attributes.ErrorCode
 Value: 0
 Key : Dump.Attributes.KernelGeneratedTriageDump
 Value: 1
 Key : Dump.Attributes.LastLine
 Key : Dump.Attributes.ProgressPercentage
 Value: 0
 Key : Failure.Bucket
 Value: AV_R_EasyAntiCheat_EOS!unknown_function
 Key : Failure.Hash
 Value: {8df4E69C-3E53-D319-9673-fCC79043E032}
BUGCHECK_CODE: 1E
BUGCHECK_P1: FffffffFC0000005
BUGCHECK_P2: FffFF8008EA9089C
BUGCHECK_P3: 0
BUGCHECK_P4: 0
FILE_IN_CAB: 082224-12671-01.dmp
DUMP_FILE_ATTRIBUTES: 0x21008
 Kernel Generated Triage Dump
FAULTING_THREAD: FffFB80A8E70B080
EXCEPTION_PARAMETER1: 0000000000000000
EXCEPTION_PARAMETER2: 0000000000000000
READ_ADDRESS: FffFF800EADc34b0: Unable to get MiVisibleState
Unable to get NonPagedPoolStart
Unable to get NonPagedPoolEnd
Unable to get PagedPoolStart
Unable to get PagedPoolEnd
Unable to get NT!MmSpecialPagesInUse
 0000000000000000
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: System
STACK_TEXT:
Fffffa8C'ddc12C48 fffff800'EA1B13A6 : 00000000'0000001E ffffffff'C0000005 fffff800'8EA9089C 00000000'00000000 : NT!KeBugCheckEx
Fffffa8C'ddc12C50 fffff800'EA486745 : 00000000'C0000005 00000000'00000000 00000001'0000007C 01000230'006080E4 : NT!KiDispatchException+0xb16
Fffffa8C'ddc13360 fffff800'EA481882 : F94edb92'F9974A71 FF390514'F78D8966 F1bafc84'F8874871 FC48AFF5'FF7F31e3 : NT!KiExceptionDispatch+0x145
Fffffa8C'ddc13540 fffff800'8EA9089C : F5F9097a'F791AA0B ffffffff'EF06E8E8 FD02B02B'ffc7607a fce47903'F341237E : NT!KiPageFault+0x442
Fffffa8C'ddc136D8 F5F9097a'F791AA0B : Ffffffff'EF06E8E8 FD02B02B'ffc7607a fce47903'F341237E FA717CE5'F7F3daca : EasyAntiCheat_EOS+0x6a089C
Fffffa8C'ddc136e0 ffffffff'EF06E8E8 : FD02B02B'ffc7607a fce47903'F341237E FA717CE5'F7F3daca FA51ECB2'FA711A39 : 0xf5f9097a`f791aa0b
Fffffa8C'ddc136e8 FD02B02B'ffc7607a : Fce47903'F341237E FA717CE5'F7F3daca FA51ECB2'FA711A39 F12F12BF'F1984FD9 : 0xffffffff`ef06e8e8
Fffffa8C'ddc136F0 fce47903'F341237E : FA717CE5'F7F3daca FA51ECB2'FA711A39 F12F12BF'F1984FD9 F333DF7E'F8b4ed77 : 0xfd02b02b`ffc7607a
Fffffa8C'ddc136F8 FA717CE5'F7F3daca : FA51ECB2'FA711A39 F12F12BF'F1984FD9 F333DF7E'F8b4ed77 FB83F6F0'F54cb708 : 0xfce47903`f341237e
Fffffa8C'ddc13700 FA51ECB2'FA711A39 : F12F12BF'F1984FD9 F333DF7E'F8b4ed77 FB83F6F0'F54cb708 F55bdcd2'F820642B : 0xfa717ce5`f7f3daca
Fffffa8C'ddc13708 F12F12BF'F1984FD9 : F333DF7E'F8b4ed77 FB83F6F0'F54cb708 F55bdcd2'F820642B F374BEFB'FF7869CC : 0xfa51ecb2`fa711a39
Fffffa8C'ddc13710 F333DF7E'F8b4ed77 : FB83F6F0'F54cb708 F55bdcd2'F820642B F374BEFB'FF7869CC 2D754C4A'2E86C5A1 : 0xf12f12bf`f1984fd9
Fffffa8C'ddc13718 FB83F6F0'F54cB708 : F55bdcd2'F820642B F374BEFB'FF7869CC 2D754C4A'2E86C5A1 1CD3016e'2B0C7CC9 : 0xf333df7e`f8b4ed77
Fffffa8C'ddc13720 F55bdcd2'F820642B : F374BEFB'FF7869CC 2D754C4A'2E86C5A1 1CD3016e'2B0C7CC9 00000000'00000000 : 0xfb83f6f0`f54cb708
Fffffa8C'ddc13728 F374BEFB'FF7869CC : 2D754C4A'2E86C5A1 1CD3016e'2B0C7CC9 00000000'00000000 00000000'00000000 : 0xf55bdcd2`f820642b
Fffffa8C'ddc13730 2D754C4A'2E86C5A1 : 1CD3016e'2B0C7CC9 00000000'00000000 00000000'00000000 00000000'00000000 : 0xf374befb`ff7869cc
Fffffa8C'ddc13738 1CD3016e'2B0C7CC9 : 00000000'00000000 00000000'00000000 00000000'00000000 00000000'00000000 : 0x2d754c4a`2e86c5a1
Fffffa8C'ddc13740 00000000'00000000 : 00000000'00000000 00000000'00000000 00000000'00000000 00000000'0F0D30B1 : 0x1cd3016e`2b0c7cc9
SYMBOL_NAME: EasyAntiCheat_EOS+6A089C
MODULE_NAME: EasyAntiCheat_EOS
IMAGE_NAME: EasyAntiCheat_EOS.sys
STACK_COMMAND: .process /r /p 0xffffb80a786a4040; .thread 0xffffb80a8e70b080 ; KB
BUCKET_ID_FUNC_OFFSET: 6A089C
FAILURE_BUCKET_ID: AV_R_EasyAntiCheat_EOS!unknown_function
OSPLATFORM_TYPE: X64
OSNAME: Windows 10
FAILURE_ID_HASH: {8df4E69C-3E53-D319-9673-fCC79043E032}
Followup: MachineOwner
Sorun EAC kaynaklı. Araştırıyorum ama hala bir raporlama yok. Sana özgü bir sorun olduğunu düşünüyorum. AC motoruna ait verileri silip yeniden yüklemek veya bahsettiğim ayarı kapatıp oyuna girmek en mantıklı seçenekler.
Anticheatten dolayı mavi ekran almışsın. Fakat bu şekilde değil direkt copy paste yoluyla çözüme ulaşmak daha zor.
Minidump dosyasını buraya yükleyin.
Rich (BB code):
This is a very common BugCheck.  Usually the exception address pinpoints
the driver/function that caused the problem.  Always note this address
as well as the link date of the driver/image that contains this address.
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff8008ea9089c, The address that the exception occurred at
İşlenmeyen bir Kernel modu istisnası meydana geliyor bundan dolayı da söylenebilecek şeyler kısıtlanıyor:
1: kd> !error ffffffffc0000005
Error code: (NTSTATUS) 0xc0000005 (3221225477) - The instruction at 0x%p referenced memory at 0x%p. The memory could not be %s.
Bir bellek erişimi uyarısı atıyor sistem. Bu genellikle bir null pointer deference, bozuk bir adres ya da korumalı bir bellek bölgesi ile ilgilidir.
Rich (BB code):
1: kd> !stack
Call Stack : 18 frames
## Stack-Pointer    Return-Address   Call-Site
00 fffffa8cddc12c48 fffff800ea1b13a6 nt!KeBugCheckEx+0
01 fffffa8cddc12c50 fffff800ea486745 nt!KiDispatchException+b16
02 fffffa8cddc13360 fffff800ea481882 nt!KiExceptionDispatch+145
03 fffffa8cddc13540 fffff8008ea9089c nt!KiPageFault+442
04 fffffa8cddc136d8 f5f9097af791aa0b EasyAntiCheat_EOS+6a089c (leaf)
Hatanın sebebini de apaçık görebiliyoruz. Neden peki? Bunun için istisna kaydına bakıyorum. Aslında ham yığıtlardan ilerleyip bir tık daha detaya inebilirdim ama bu küçük dökümler üzerinde çalışmayan kodlar dolayısıyla yapılamaz bir durum.
Kod:
1: kd> .exr fffffa8cddc13498
ExceptionAddress: fffff8008ea9089c (EasyAntiCheat_EOS+0x00000000006a089c)
   ExceptionCode: c0000005 (Access violation)
  ExceptionFlags: 00000000
NumberParameters: 2
   Parameter[0]: 0000000000000000
   Parameter[1]: 0000000000000000
Attempt to read from address 0000000000000000
İstisna kaydını görüyoruz, EAC motoru bir null deference yapıyor ve bu yüzden direkt olarak sayfa hatasına düşüyor sistem. Beklenmedik bir istisna olması da cabası. Dün sorunsuz kullanırken bugün kullanamama sebebini düşündüm, Dikkatimi EAC motorunun sürüm tarihi çekti:
Image path: EasyAntiCheat_EOS.sys
Image name: EasyAntiCheat_EOS.sys
Browse all global symbols functions data
Timestamp: Thu Aug 22 10:28:00 2024 (66C6E880)
Oyunun AC motoru bugün güncelleme almış. Dolayısıyla da, sorunun direkt olarak bu kaynaklı olduğunu düşünüyorum çünkü biraz okuduğumda EAC ile ilgili yeniliklerin geldiğini de gördüm. Sisteminde çakışma yarattığı sürücüler olabilir. Bir noktada burda net çözüm vermek için biraz daha araştırma yapmak gerekiyor ama şimdilik Bellek Bütünlüğü ayarını açmak veya açıksa kapatmayı deneyebilirsin. Bu noktada henüz hiçbir raporlama görmedim bu konuda, sadece tahmine dayalı yorum yaptığımı da belirteyim.
Yardınmcı olmaya çalışmıssın teşekkür ederim ama bir türlü çözemedim oyunu komple kaldırdım geri kurdum denemediğim şey kalmadı ve hala aynı şekilde mavi ekran veriyor.
İfadeler: 99
Belek bütünlüğü kapalıydı, açtım mavi ekran vermeye devam etti. Kapattım sorun hala vardı ama öbür Steam hesabımla oyuna girince herhangi bir mavi ekran almadım. Tekrardan mavi ekran aldığım hesabıma girince düzeldi. Galiba Steam hesabım EAC güncellemesini yapamıyor, saçma bir durum var.
