aslayperson
- 8 Ocak 2024
MEMORY_MANAGEMENT (1a)
# Any other values for parameter 1 must be individually examined.
Arguments:
Arg1: 0000000000041792, A corrupt PTE has been detected. Parameter 2 contains the address of
the PTE. Parameters 3/4 contain the low/high parts of the PTE.
Arg2: ffffee016bede8e8
Arg3: 0000000002000000
Arg4: 0000000000000000
Debugging Details:
KEY_VALUES_STRING: 1
Key : Analysis.CPU.mSec
Value: 1187
Key : Analysis.Elapsed.mSec
Value: 7329
Key : Analysis.IO.Other.Mb
Value: 0
Key : Analysis.IO.Read.Mb
Value: 0
Key : Analysis.IO.Write.Mb
Value: 0
Key : Analysis.Init.CPU.mSec
Value: 218
Value: 568
Value: 83
Key : Bugcheck.Code.LegacyAPI
Value: 0x1a
Key : Bugcheck.Code.TargetModel
Value: 0x1a
Key : Failure.Bucket
Value: MEMORY_CORRUPTION_ONE_BIT
Key : Failure.Hash
Value: {e3faf315-c3d0-81db-819a-6c43d23c63a7}
Key : MemoryManagement.PFN
Value: 2000
Key : WER.OS.Branch
Value: vb_release
Key : WER.OS.Version
Value: 10.0.19041.1
BUGCHECK_CODE: 1a
BUGCHECK_P1: 41792
BUGCHECK_P2: ffffee016bede8e8
BUGCHECK_P3: 2000000
BUGCHECK_P4: 0
FILE_IN_CAB: 080624-7125-01.dmp
MEMORY_CORRUPTOR: ONE_BIT
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: msedge.exe
STACK_TEXT:
fffffe0e`50508d48 fffff802`5c682b6a : 00000000`0000001a 00000000`00041792 ffffee01`6bede8e8 00000000`02000000 : nt!KeBugCheckEx
fffffe0e`50508d50 fffff802`5c61aeb6 : 00000000`00000000 00000000`00000000 00000000`00000015 ffffee01`6bede8e8 : nt!MiDeleteVa+0x153a
fffffe0e`50508e50 fffff802`5c61afcb : ffffee77`00b5f6f0 ffff9588`d171d700 fffffe0e`00000000 fffffe0e`505092c0 : nt!MiWalkPageTablesRecursively+0x776
fffffe0e`50508ef0 fffff802`5c61afcb : ffffee77`00000000 ffff9588`d171d700 fffffe0e`00000001 fffffe0e`505092d0 : nt!MiWalkPageTablesRecursively+0x88b
fffffe0e`50508f90 fffff802`5c61afcb : ffffee77`3b805000 ffff9588`d171d700 fffffe0e`00000002 fffffe0e`505092e0 : nt!MiWalkPageTablesRecursively+0x88b
fffffe0e`50509030 fffff802`5c617fcb : fffffe0e`50509148 ffff9588`d171d700 fffffe0e`00000003 fffffe0e`505092f0 : nt!MiWalkPageTablesRecursively+0x88b
fffffe0e`505090d0 fffff802`5c681401 : fffffe0e`50509270 ffff9588`00000000 00000000`00000002 00000000`00000000 : nt!MiWalkPageTables+0x36b
fffffe0e`505091d0 fffff802`5c62b108 : 00000000`00000001 ffff9588`00000000 ffff9588`d171d550 ffff9588`d1bab040 : nt!MiDeletePagablePteRange+0x4f1
fffffe0e`505094e0 fffff802`5ca90329 : 00000000`00000000 00000000`00000000 00000000`00000000 ffff9588`d171d080 : nt!MiDeleteVad+0x378
fffffe0e`505095e0 fffff802`5ca8ef08 : ffff9588`d00262a0 ffff9588`d17a7bc0 ffff9588`d1bab040 00000000`00000000 : nt!MiUnmapVad+0x49
fffffe0e`50509610 fffff802`5ca30353 : ffff9588`d0550b00 ffff9588`d0550b00 ffff9588`d00262a0 ffff9588`d171d080 : nt!MiCleanVad+0x30
fffffe0e`50509640 fffff802`5cb13598 : ffffffff`00000000 ffffffff`ffffffff 00000000`00000001 ffff9588`d171d080 : nt!MmCleanProcessAddressSpace+0x137
fffffe0e`505096c0 fffff802`5ca8a7be : ffff9588`d171d080 ffffdc09`f63be060 fffffe0e`505098e9 00000000`00000000 : nt!PspRundownSingleProcess+0x20c
fffffe0e`50509750 fffff802`5cae8748 : ffff9588`c0000005 fffff802`5c610601 00000000`00000000 000000ed`7fa1e000 : nt!PspExitThread+0x5f6
fffffe0e`50509850 fffff802`5c6cd15d : 00000000`00000000 ffff9588`c0ae7a01 00000000`00000101 fffff802`00000010 : nt!KiSchedulerApcTerminate+0x38
fffffe0e`50509890 fffff802`5c803480 : 000002d7`daa06a00 fffffe0e`50509950 fffffe0e`50509b00 00000000`00000002 : nt!KiDeliverApc+0x60d
fffffe0e`50509950 fffff802`5c811daf : ffff9588`d1bab040 000000ed`07fff798 ffff9588`d1585060 000002d7`daa06b18 : nt!KiInitiateUserApc+0x70
fffffe0e`50509a90 00007ff9`2d470ff4 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceExit+0x9f
000000ed`07fff858 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ff9`2d470ff4
MODULE_NAME: hardware
IMAGE_NAME: memory_corruption
STACK_COMMAND: .cxr; .ecxr ; kb
FAILURE_BUCKET_ID: MEMORY_CORRUPTION_ONE_BIT
OS_VERSION: 10.0.19041.1
BUILDLAB_STR: vb_release
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {e3faf315-c3d0-81db-819a-6c43d23c63a7}
Followup: MachineOwner
PnpActivityId : {00000000-0000-0000-0000-000000000000}
PnpActivityTime : 133674392824420187
PnpEventInformation: 0
PnpEventInProgress : 0
PnpProblemCode : 22
PnpVetoType : 0
DeviceId : PCI\VEN_1002&DEV_AAF0&SUBSYS_AAF01043&REV_00\4&1fc990d7&0&0119
VetoString :
[SMBIOS Data Tables v2.8]
[DMI Version - 0]
[2.0 Calling Convention - No]
[Table Size - 2717 bytes]
Vendor American Megatrends International, LLC.
BIOS Version 3.I0
BIOS Release Date 10/14/2023
BIOS ROM Size 1000000
BIOS Characteristics
07: - PCI Supported
11: - Upgradeable FLASH BIOS
15: - CD-Boot Supported
17: - BIOS ROM Socketed
19: - EDD Supported
22: - 360KB Floppy Supported
23: - 1.2MB Floppy Supported
24: - 720KB Floppy Supported
25: - 2.88MB Floppy Supported
27: - Keyboard Services Supported
32: - BIOS Vendor Reserved
01: - USB Legacy Supported
BIOS Major Revision 5
BIOS Minor Revision 17
EC Firmware Major Revision 255
EC Firmware Minor Revision 255
Extended BIOS ROM Size 16 MB
Manufacturer Micro-Star International Co., Ltd
Product Name MS-7C02
Version 1.0
Serial Number To be filled by O.E.M.
UUID 00000000-0000-0000-0000-000000000000
Wakeup Type Power Switch
SKUNumber To be filled by O.E.M.
Family To be filled by O.E.M.
Product B450 TOMAHAWK MAX (MS-7C02)
Version 1.0
Asset Tag
Feature Flags 09h
00: - Motherboard
03: - Replaceable
Location To be filled by O.E.M.
Chassis Handle 0003h
Board Type 0ah - Processor/Memory Module
Number of Child Handles 0
Chassis Type Desktop
Version 1.0
Serial Number
Asset Tag Number
Bootup State Safe
Power Supply State Safe
Thermal State Safe
Security Status None
OEM Defined 0
Height 0U
Number of Power Cords 1
Number of Contained Elements 0
Contained Element Size 3
[OEM Strings (Type 11) - Length 5 - Handle 000bh]
Number of Strings 1
1 To be filled by O.E.M.
[System Configuration Options (Type 12) - Length 5 - Handle 000ch]
[ (Type 256) - Length 9 - Handle 000eh]
[ (Type 256) - Length 31 - Handle 000fh]
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 0010h]
[Physical Memory Array (Type 16) - Length 23 - Handle 0011h]
Location 03h - SystemBoard/Motherboard
Use 03h - System Memory
Memory Error Correction 03h - None
Maximum Capacity 134217728KB
Memory Error Inf Handle 0010h
Number of Memory Devices 4
[Memory Array Mapped Address (Type 19) - Length 31 - Handle 0012h]
Starting Address 00000000h
Ending Address 002fffffh
Memory Array Handle 0011h
Partition Width 04
Extended Starting Address 0000000000000000h
Extended Ending Address 0000000000000000h
[Memory Array Mapped Address (Type 19) - Length 31 - Handle 0013h]
Starting Address 00400000h
Ending Address 020fffffh
Partition Width 04
[Cache Information (Type 7) - Length 19 - Handle 0014h]
Socket Designation L1 - Cache
Cache Configuration 0180h - WBEnabled Int NonSocketed L1
Maximum Cache Size 0180h - 384K
Installed Size 0180h - 384K
Supported SRAM Type 0010h - Pipeline-Burst
Current SRAM Type 0010h - Pipeline-Burst
Cache Speed 1ns
Error Correction Type Specification Reserved
System Cache Type Unified
Associativity 8-way Set-Associative
Maximum Cache Size 2 2d20314c - 757084492l Kb
[Cache Information (Type 7) - Length 19 - Handle 0015h]
Socket Designation L2 - Cache
Cache Configuration 0181h - WBEnabled Int NonSocketed L2
Maximum Cache Size 0c00h - 3072K
Installed Size 0c00h - 3072K
Cache Speed 1ns
Maximum Cache Size 2 2d20324c - 757084748l Kb
[Cache Information (Type 7) - Length 19 - Handle 0016h]
Socket Designation L3 - Cache
Cache Configuration 0182h - WBEnabled Int NonSocketed L3
Maximum Cache Size 8200h - 32768K
Installed Size 8200h - 32768K
Cache Speed 1ns
Associativity 16-way Set-Associative
Maximum Cache Size 2 2d20334c - 757085004l Kb
[Processor Information (Type 4) - Length 48 - Handle 0017h]
Socket Designation AM4
Processor Type Central Processor
Processor Family 6bh - AMD Zen Processor Family
Processor Manufacturer Advanced Micro Devices, Inc.
Processor ID 100f8700fffb8b17
Processor Version AMD Ryzen 5 3600 6-Core Processor
Processor Voltage 8bh - 1.1V
External Clock 100MHz
Max Speed 4200MHz
Current Speed 4200MHz
Status Enabled Populated
Processor Upgrade Socket AM4
L1 Cache Handle 0014h
L2 Cache Handle 0015h
L3 Cache Handle 0016h
Serial Number
Asset Tag Number
Part Number Unknown
Core Count 6
Core Enabled 6
Thread Count 12
Processor Characteristics fc
Enabled Characteristics:
0x 2: 64-bit Capable
0x 3: Multi-Core
0x 4: Hardware Thread
0x 5: Execute Protection
0x 6: Enhanced Virtualization
Processor Family 2 006bh - AMD Zen Processor Family
Core Count 2 6
Core Enabled 2 6
Thread Count 2 12
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 0018h]
[Memory Device (Type 17) - Length 40 - Handle 0019h]
Memory Error Info Handle 0018h
Total Width 64 bits
Data Width 64 bits
Size 8192MB
Form Factor 09h - DIMM
Device Set [None]
Device Locator DIMM 0
Bank Locator P0 CHANNEL A
Memory Type 1ah - DDR4
Type Detail 4080h - Synchronous Unbuffered (Unregistered)
Speed 3600MHz
Manufacturer Kingston
Serial Number
Asset Tag Number [String Not Specified]
Part Number KF3600C17D4/8GX
Attributes 1
Extended Size 0
Configured Memory Speed 3600
Minimum Voltage 1200
Maximum Voltage 1200
Configured Voltage 1200
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 001ah]
Ending Address 01ffffffh
Memory Device Handle 0019h
Mem Array Mapped Adr Handle 0013h
Partition Row Position [Unknown]
Interleave Position [Unknown]
Interleave Data Depth [Unknown]
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 001bh]
[Memory Device (Type 17) - Length 40 - Handle 001ch]
Memory Error Info Handle 001bh
Total Width 64 bits
Data Width 64 bits
Size 8192MB
Device Set [None]
Device Locator DIMM 1
Speed 3600MHz
Serial Number
Attributes 1
Extended Size 0
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 001dh]
Memory Device Handle 001ch
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 001eh]
[Memory Device (Type 17) - Length 40 - Handle 001fh]
Memory Error Info Handle 001eh
Total Width 64 bits
Data Width 64 bits
Size 8192MB
Device Set [None]
Bank Locator P0 CHANNEL B
Speed 3600MHz
Serial Number
Attributes 1
Extended Size 0
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 0020h]
Memory Device Handle 001fh
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 0021h]
[Memory Device (Type 17) - Length 40 - Handle 0022h]
Memory Error Info Handle 0021h
Total Width 64 bits
Data Width 64 bits
Size 8192MB
Device Set [None]
Speed 3600MHz
Serial Number
Attributes 1
Extended Size 0
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 0023h]
Memory Device Handle 0022h
[ (Type 256) - Length 11 - Handle 003dh]
[ (Type 256) - Length 16 - Handle 003eh]
[ (Type 256) - Length 4 - Handle 003fh]
MemTest86x 11 Built 1000 versiyonu ile test etmiştim.Hangi sürümle test ettiniz? Belleklerde bariz bir sorun var gibi. Eğer ikit ane 8 GB modül varsa birini sökün bir süre.
Kod:MEMORY_MANAGEMENT (1a) # Any other values for parameter 1 must be individually examined. Arguments: Arg1: 0000000000041792, A corrupt PTE has been detected. Parameter 2 contains the address of the PTE. Parameters 3/4 contain the low/high parts of the PTE. Arg2: ffffee016bede8e8 Arg3: 0000000002000000 Arg4: 0000000000000000 Debugging Details: ------------------ KEY_VALUES_STRING: 1 Key : Analysis.CPU.mSec Value: 1187 Key : Analysis.Elapsed.mSec Value: 7329 Key : Analysis.IO.Other.Mb Value: 0 Key : Analysis.IO.Read.Mb Value: 0 Key : Analysis.IO.Write.Mb Value: 0 Key : Analysis.Init.CPU.mSec Value: 218 Key : Analysis.Init.Elapsed.mSec Value: 568 Key : Analysis.Memory.CommitPeak.Mb Value: 83 Key : Bugcheck.Code.LegacyAPI Value: 0x1a Key : Bugcheck.Code.TargetModel Value: 0x1a Key : Failure.Bucket Value: MEMORY_CORRUPTION_ONE_BIT Key : Failure.Hash Value: {e3faf315-c3d0-81db-819a-6c43d23c63a7} Key : MemoryManagement.PFN Value: 2000 Key : WER.OS.Branch Value: vb_release Key : WER.OS.Version Value: 10.0.19041.1 BUGCHECK_CODE: 1a BUGCHECK_P1: 41792 BUGCHECK_P2: ffffee016bede8e8 BUGCHECK_P3: 2000000 BUGCHECK_P4: 0 FILE_IN_CAB: 080624-7125-01.dmp MEMORY_CORRUPTOR: ONE_BIT BLACKBOXBSD: 1 (!blackboxbsd) BLACKBOXNTFS: 1 (!blackboxntfs) BLACKBOXPNP: 1 (!blackboxpnp) BLACKBOXWINLOGON: 1 CUSTOMER_CRASH_COUNT: 1 PROCESS_NAME: msedge.exe STACK_TEXT: fffffe0e`50508d48 fffff802`5c682b6a : 00000000`0000001a 00000000`00041792 ffffee01`6bede8e8 00000000`02000000 : nt!KeBugCheckEx fffffe0e`50508d50 fffff802`5c61aeb6 : 00000000`00000000 00000000`00000000 00000000`00000015 ffffee01`6bede8e8 : nt!MiDeleteVa+0x153a fffffe0e`50508e50 fffff802`5c61afcb : ffffee77`00b5f6f0 ffff9588`d171d700 fffffe0e`00000000 fffffe0e`505092c0 : nt!MiWalkPageTablesRecursively+0x776 fffffe0e`50508ef0 fffff802`5c61afcb : ffffee77`00000000 ffff9588`d171d700 fffffe0e`00000001 fffffe0e`505092d0 : nt!MiWalkPageTablesRecursively+0x88b fffffe0e`50508f90 fffff802`5c61afcb : ffffee77`3b805000 ffff9588`d171d700 fffffe0e`00000002 fffffe0e`505092e0 : nt!MiWalkPageTablesRecursively+0x88b fffffe0e`50509030 fffff802`5c617fcb : fffffe0e`50509148 ffff9588`d171d700 fffffe0e`00000003 fffffe0e`505092f0 : nt!MiWalkPageTablesRecursively+0x88b fffffe0e`505090d0 fffff802`5c681401 : fffffe0e`50509270 ffff9588`00000000 00000000`00000002 00000000`00000000 : nt!MiWalkPageTables+0x36b fffffe0e`505091d0 fffff802`5c62b108 : 00000000`00000001 ffff9588`00000000 ffff9588`d171d550 ffff9588`d1bab040 : nt!MiDeletePagablePteRange+0x4f1 fffffe0e`505094e0 fffff802`5ca90329 : 00000000`00000000 00000000`00000000 00000000`00000000 ffff9588`d171d080 : nt!MiDeleteVad+0x378 fffffe0e`505095e0 fffff802`5ca8ef08 : ffff9588`d00262a0 ffff9588`d17a7bc0 ffff9588`d1bab040 00000000`00000000 : nt!MiUnmapVad+0x49 fffffe0e`50509610 fffff802`5ca30353 : ffff9588`d0550b00 ffff9588`d0550b00 ffff9588`d00262a0 ffff9588`d171d080 : nt!MiCleanVad+0x30 fffffe0e`50509640 fffff802`5cb13598 : ffffffff`00000000 ffffffff`ffffffff 00000000`00000001 ffff9588`d171d080 : nt!MmCleanProcessAddressSpace+0x137 fffffe0e`505096c0 fffff802`5ca8a7be : ffff9588`d171d080 ffffdc09`f63be060 fffffe0e`505098e9 00000000`00000000 : nt!PspRundownSingleProcess+0x20c fffffe0e`50509750 fffff802`5cae8748 : ffff9588`c0000005 fffff802`5c610601 00000000`00000000 000000ed`7fa1e000 : nt!PspExitThread+0x5f6 fffffe0e`50509850 fffff802`5c6cd15d : 00000000`00000000 ffff9588`c0ae7a01 00000000`00000101 fffff802`00000010 : nt!KiSchedulerApcTerminate+0x38 fffffe0e`50509890 fffff802`5c803480 : 000002d7`daa06a00 fffffe0e`50509950 fffffe0e`50509b00 00000000`00000002 : nt!KiDeliverApc+0x60d fffffe0e`50509950 fffff802`5c811daf : ffff9588`d1bab040 000000ed`07fff798 ffff9588`d1585060 000002d7`daa06b18 : nt!KiInitiateUserApc+0x70 fffffe0e`50509a90 00007ff9`2d470ff4 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceExit+0x9f 000000ed`07fff858 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ff9`2d470ff4 MODULE_NAME: hardware IMAGE_NAME: memory_corruption STACK_COMMAND: .cxr; .ecxr ; kb FAILURE_BUCKET_ID: MEMORY_CORRUPTION_ONE_BIT OS_VERSION: 10.0.19041.1 BUILDLAB_STR: vb_release OSPLATFORM_TYPE: x64 OSNAME: Windows 10 FAILURE_ID_HASH: {e3faf315-c3d0-81db-819a-6c43d23c63a7} Followup: MachineOwner --------- PnpActivityId : {00000000-0000-0000-0000-000000000000} PnpActivityTime : 133674392824420187 PnpEventInformation: 0 PnpEventInProgress : 0 PnpProblemCode : 22 PnpVetoType : 0 DeviceId : PCI\VEN_1002&DEV_AAF0&SUBSYS_AAF01043&REV_00\4&1fc990d7&0&0119 VetoString : [SMBIOS Data Tables v2.8] [DMI Version - 0] [2.0 Calling Convention - No] [Table Size - 2717 bytes] [BIOS Information (Type 0) - Length 26 - Handle 0000h] Vendor American Megatrends International, LLC. BIOS Version 3.I0 BIOS Starting Address Segment f000 BIOS Release Date 10/14/2023 BIOS ROM Size 1000000 BIOS Characteristics 07: - PCI Supported 11: - Upgradeable FLASH BIOS 12: - BIOS Shadowing Supported 15: - CD-Boot Supported 16: - Selectable Boot Supported 17: - BIOS ROM Socketed 19: - EDD Supported 20: - NEC 9800 J-Floppy Supported 21: - Toshiba J-Floppy Supported 22: - 360KB Floppy Supported 23: - 1.2MB Floppy Supported 24: - 720KB Floppy Supported 25: - 2.88MB Floppy Supported 26: - Print Screen Device Supported 27: - Keyboard Services Supported 28: - Serial Services Supported 29: - Printer Services Supported 30: - CGA/Mono Services Supported 32: - BIOS Vendor Reserved BIOS Characteristic Extensions 01: - USB Legacy Supported 08: - BIOS Boot Specification Supported 10: - Enable Targeted Content Distribution 11: - UEFI Specification Supported BIOS Major Revision 5 BIOS Minor Revision 17 EC Firmware Major Revision 255 EC Firmware Minor Revision 255 Extended BIOS ROM Size 16 MB [System Information (Type 1) - Length 27 - Handle 0001h] Manufacturer Micro-Star International Co., Ltd Product Name MS-7C02 Version 1.0 Serial Number To be filled by O.E.M. UUID 00000000-0000-0000-0000-000000000000 Wakeup Type Power Switch SKUNumber To be filled by O.E.M. Family To be filled by O.E.M. [BaseBoard Information (Type 2) - Length 15 - Handle 0002h] Manufacturer Micro-Star International Co., Ltd Product B450 TOMAHAWK MAX (MS-7C02) Version 1.0 Serial Number To be filled by O.E.M. Asset Tag Feature Flags 09h 00: - Motherboard 03: - Replaceable Location To be filled by O.E.M. Chassis Handle 0003h Board Type 0ah - Processor/Memory Module Number of Child Handles 0 [System Enclosure (Type 3) - Length 22 - Handle 0003h] Manufacturer Micro-Star International Co., Ltd Chassis Type Desktop Version 1.0 Serial Number Asset Tag Number Bootup State Safe Power Supply State Safe Thermal State Safe Security Status None OEM Defined 0 Height 0U Number of Power Cords 1 Number of Contained Elements 0 Contained Element Size 3 [OEM Strings (Type 11) - Length 5 - Handle 000bh] Number of Strings 1 1 To be filled by O.E.M. [System Configuration Options (Type 12) - Length 5 - Handle 000ch] [ (Type 256) - Length 9 - Handle 000eh] [ (Type 256) - Length 31 - Handle 000fh] [32Bit Memory Error Information (Type 18) - Length 23 - Handle 0010h] [Physical Memory Array (Type 16) - Length 23 - Handle 0011h] Location 03h - SystemBoard/Motherboard Use 03h - System Memory Memory Error Correction 03h - None Maximum Capacity 134217728KB Memory Error Inf Handle 0010h Number of Memory Devices 4 [Memory Array Mapped Address (Type 19) - Length 31 - Handle 0012h] Starting Address 00000000h Ending Address 002fffffh Memory Array Handle 0011h Partition Width 04 Extended Starting Address 0000000000000000h Extended Ending Address 0000000000000000h [Memory Array Mapped Address (Type 19) - Length 31 - Handle 0013h] Starting Address 00400000h Ending Address 020fffffh Memory Array Handle 0011h Partition Width 04 Extended Starting Address 0000000000000000h Extended Ending Address 0000000000000000h [Cache Information (Type 7) - Length 19 - Handle 0014h] Socket Designation L1 - Cache Cache Configuration 0180h - WBEnabled Int NonSocketed L1 Maximum Cache Size 0180h - 384K Installed Size 0180h - 384K Supported SRAM Type 0010h - Pipeline-Burst Current SRAM Type 0010h - Pipeline-Burst Cache Speed 1ns Error Correction Type Specification Reserved System Cache Type Unified Associativity 8-way Set-Associative Maximum Cache Size 2 2d20314c - 757084492l Kb [Cache Information (Type 7) - Length 19 - Handle 0015h] Socket Designation L2 - Cache Cache Configuration 0181h - WBEnabled Int NonSocketed L2 Maximum Cache Size 0c00h - 3072K Installed Size 0c00h - 3072K Supported SRAM Type 0010h - Pipeline-Burst Current SRAM Type 0010h - Pipeline-Burst Cache Speed 1ns Error Correction Type Specification Reserved System Cache Type Unified Associativity 8-way Set-Associative Maximum Cache Size 2 2d20324c - 757084748l Kb [Cache Information (Type 7) - Length 19 - Handle 0016h] Socket Designation L3 - Cache Cache Configuration 0182h - WBEnabled Int NonSocketed L3 Maximum Cache Size 8200h - 32768K Installed Size 8200h - 32768K Supported SRAM Type 0010h - Pipeline-Burst Current SRAM Type 0010h - Pipeline-Burst Cache Speed 1ns Error Correction Type Specification Reserved System Cache Type Unified Associativity 16-way Set-Associative Maximum Cache Size 2 2d20334c - 757085004l Kb [Processor Information (Type 4) - Length 48 - Handle 0017h] Socket Designation AM4 Processor Type Central Processor Processor Family 6bh - AMD Zen Processor Family Processor Manufacturer Advanced Micro Devices, Inc. Processor ID 100f8700fffb8b17 Processor Version AMD Ryzen 5 3600 6-Core Processor Processor Voltage 8bh - 1.1V External Clock 100MHz Max Speed 4200MHz Current Speed 4200MHz Status Enabled Populated Processor Upgrade Socket AM4 L1 Cache Handle 0014h L2 Cache Handle 0015h L3 Cache Handle 0016h Serial Number Asset Tag Number Part Number Unknown Core Count 6 Core Enabled 6 Thread Count 12 Processor Characteristics fc Enabled Characteristics: 0x 2: 64-bit Capable 0x 3: Multi-Core 0x 4: Hardware Thread 0x 5: Execute Protection 0x 6: Enhanced Virtualization 0x 7: Power/Performance Control Processor Family 2 006bh - AMD Zen Processor Family Core Count 2 6 Core Enabled 2 6 Thread Count 2 12 [32Bit Memory Error Information (Type 18) - Length 23 - Handle 0018h] [Memory Device (Type 17) - Length 40 - Handle 0019h] Memory Error Info Handle 0018h Total Width 64 bits Data Width 64 bits Size 8192MB Form Factor 09h - DIMM Device Set [None] Device Locator DIMM 0 Bank Locator P0 CHANNEL A Memory Type 1ah - DDR4 Type Detail 4080h - Synchronous Unbuffered (Unregistered) Speed 3600MHz Manufacturer Kingston Serial Number Asset Tag Number [String Not Specified] Part Number KF3600C17D4/8GX Attributes 1 Extended Size 0 Configured Memory Speed 3600 Minimum Voltage 1200 Maximum Voltage 1200 Configured Voltage 1200 [Memory Device Mapped Address (Type 20) - Length 35 - Handle 001ah] Starting Address 00000000h Ending Address 01ffffffh Memory Device Handle 0019h Mem Array Mapped Adr Handle 0013h Partition Row Position [Unknown] Interleave Position [Unknown] Interleave Data Depth [Unknown] Extended Starting Address 0000000000000000h Extended Ending Address 0000000000000000h [32Bit Memory Error Information (Type 18) - Length 23 - Handle 001bh] [Memory Device (Type 17) - Length 40 - Handle 001ch] Memory Error Info Handle 001bh Total Width 64 bits Data Width 64 bits Size 8192MB Form Factor 09h - DIMM Device Set [None] Device Locator DIMM 1 Bank Locator P0 CHANNEL A Memory Type 1ah - DDR4 Type Detail 4080h - Synchronous Unbuffered (Unregistered) Speed 3600MHz Manufacturer Kingston Serial Number Asset Tag Number [String Not Specified] Part Number KF3600C17D4/8GX Attributes 1 Extended Size 0 Configured Memory Speed 3600 Minimum Voltage 1200 Maximum Voltage 1200 Configured Voltage 1200 [Memory Device Mapped Address (Type 20) - Length 35 - Handle 001dh] Starting Address 00000000h Ending Address 01ffffffh Memory Device Handle 001ch Mem Array Mapped Adr Handle 0013h Partition Row Position [Unknown] Interleave Position [Unknown] Interleave Data Depth [Unknown] Extended Starting Address 0000000000000000h Extended Ending Address 0000000000000000h [32Bit Memory Error Information (Type 18) - Length 23 - Handle 001eh] [Memory Device (Type 17) - Length 40 - Handle 001fh] Memory Error Info Handle 001eh Total Width 64 bits Data Width 64 bits Size 8192MB Form Factor 09h - DIMM Device Set [None] Device Locator DIMM 0 Bank Locator P0 CHANNEL B Memory Type 1ah - DDR4 Type Detail 4080h - Synchronous Unbuffered (Unregistered) Speed 3600MHz Manufacturer Kingston Serial Number Asset Tag Number [String Not Specified] Part Number KF3600C17D4/8GX Attributes 1 Extended Size 0 Configured Memory Speed 3600 Minimum Voltage 1200 Maximum Voltage 1200 Configured Voltage 1200 [Memory Device Mapped Address (Type 20) - Length 35 - Handle 0020h] Starting Address 00000000h Ending Address 01ffffffh Memory Device Handle 001fh Mem Array Mapped Adr Handle 0013h Partition Row Position [Unknown] Interleave Position [Unknown] Interleave Data Depth [Unknown] Extended Starting Address 0000000000000000h Extended Ending Address 0000000000000000h [32Bit Memory Error Information (Type 18) - Length 23 - Handle 0021h] [Memory Device (Type 17) - Length 40 - Handle 0022h] Memory Error Info Handle 0021h Total Width 64 bits Data Width 64 bits Size 8192MB Form Factor 09h - DIMM Device Set [None] Device Locator DIMM 1 Bank Locator P0 CHANNEL B Memory Type 1ah - DDR4 Type Detail 4080h - Synchronous Unbuffered (Unregistered) Speed 3600MHz Manufacturer Kingston Serial Number Asset Tag Number [String Not Specified] Part Number KF3600C17D4/8GX Attributes 1 Extended Size 0 Configured Memory Speed 3600 Minimum Voltage 1200 Maximum Voltage 1200 Configured Voltage 1200 [Memory Device Mapped Address (Type 20) - Length 35 - Handle 0023h] Starting Address 00000000h Ending Address 01ffffffh Memory Device Handle 0022h Mem Array Mapped Adr Handle 0013h Partition Row Position [Unknown] Interleave Position [Unknown] Interleave Data Depth [Unknown] Extended Starting Address 0000000000000000h Extended Ending Address 0000000000000000h [ (Type 256) - Length 11 - Handle 003dh] [ (Type 256) - Length 16 - Handle 003eh] [ (Type 256) - Length 4 - Handle 003fh]
We use cookies and similar technologies for the following purposes:
Do you accept cookies and these technologies?
