Vanguard patlatiyor diyor. Guvenli modda kaldirmayi deneyin.Bu sabah açtığımda mavi ekran yedim ara sıra olabilen bir şey mi yoksa bir sorun mu var.
- 5600X.
- RX6700 10GB.
- G.Skill 32 GB 3600MHz.
- ASRock B550M HDV.
************* Preparing the environment for Debugger Extensions Gallery repositories **************
ExtensionRepository : Implicit
UseExperimentalFeatureForNugetShare : true
AllowNugetExeUpdate : true
NonInteractiveNuget : true
AllowNugetMSCredentialProviderInstall : true
AllowParallelInitializationOfLocalRepositories : true
EnableRedirectToChakraJsProvider : false
-- Configuring repositories
----> Repository : LocalInstalled, Enabled: true
----> Repository : UserExtensions, Enabled: true
>>>>>>>>>>>>> Preparing the environment for Debugger Extensions Gallery repositories completed, duration 0.000 seconds
************* Waiting for Debugger Extensions Gallery to Initialize **************
>>>>>>>>>>>>> Waiting for Debugger Extensions Gallery to Initialize completed, duration 0.032 seconds
----> Repository : UserExtensions, Enabled: true, Packages count: 0
----> Repository : LocalInstalled, Enabled: true, Packages count: 42
Microsoft (R) Windows Debugger Version 10.0.27725.1000 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Users\rael\Downloads\112624-12765-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: srv*
Executable search path is:
Windows 10 Kernel Version 26100 MP (12 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Kernel base = 0xfffff802`bcc00000 PsLoadedModuleList = 0xfffff802`bdaf4830
Debug session time: Tue Nov 26 00:04:47.899 2024 (UTC + 3:00)
System Uptime: 0 days 0:24:52.625
Loading Kernel Symbols
Loading User Symbols
PEB is paged out (Peb.Ldr = 00000037`8b6bb018). Type ".hh dbgerr001" for details
Loading unloaded module list
For analysis of this file, run !analyze -v
nt!KeBugCheckEx:
fffff802`bd0b8550 48894c2408 mov qword ptr [rsp+8],rcx ss:0018:ffffc98f`21616680=0000000000000050
11: kd> !analyze -v
* Bugcheck Analysis *
PAGE_FAULT_IN_NONPAGED_AREA (50)
Invalid system memory was referenced. This cannot be protected by try-except.
Typically the address is just plain bad or it is pointing at freed memory.
Arguments:
Arg1: ffff938033360000, memory referenced.
Arg2: 0000000000000000, X64: bit 0 set if the fault was due to a not-present PTE.
bit 1 is set if the fault was due to a write, clear if a read.
bit 3 is set if the processor decided the fault was due to a corrupted PTE.
bit 4 is set if the fault was due to attempted execute of a no-execute PTE.
- ARM64: bit 1 is set if the fault was due to a write, clear if a read.
bit 3 is set if the fault was due to attempted execute of a no-execute PTE.
Arg3: fffff8025255924c, If non-zero, the instruction address which referenced the bad memory
address.
Arg4: 0000000000000000, (reserved)
Debugging Details:
KEY_VALUES_STRING: 1
Key : AV.Type
Value: Read
Key : Analysis.CPU.mSec
Value: 1500
Key : Analysis.Elapsed.mSec
Value: 5814
Key : Analysis.IO.Other.Mb
Value: 14
Key : Analysis.IO.Read.Mb
Value: 1
Key : Analysis.IO.Write.Mb
Value: 23
Key : Analysis.Init.CPU.mSec
Value: 734
Value: 22049
Value: 87
Key : Analysis.Version.DbgEng
Value: 10.0.27725.1000
Key : Analysis.Version.Description
Value: 10.2408.27.01 amd64fre
Key : Analysis.Version.Ext
Value: 1.2408.27.1
Key : Bugcheck.Code.LegacyAPI
Value: 0x50
Key : Bugcheck.Code.TargetModel
Value: 0x50
Key : Dump.Attributes.AsUlong
Value: 21808
Key : Dump.Attributes.DiagDataWrittenToHeader
Value: 1
Key : Dump.Attributes.ErrorCode
Value: 0
Key : Dump.Attributes.KernelGeneratedTriageDump
Value: 1
Key : Dump.Attributes.LastLine
Key : Dump.Attributes.ProgressPercentage
Value: 0
Key : Failure.Bucket
Value: AV_R_(null)_vgk!unknown_function
Key : Failure.Hash
Value: {2c74f9bf-c695-1cb8-996e-ae91d1a2ef92}
Key : Hypervisor.Enlightenments.ValueHex
Value: 7497cf94
Key : Hypervisor.Flags.AnyHypervisorPresent
Value: 1
Key : Hypervisor.Flags.ApicEnlightened
Value: 1
Key : Hypervisor.Flags.ApicVirtualizationAvailable
Value: 0
Key : Hypervisor.Flags.AsyncMemoryHint
Value: 0
Key : Hypervisor.Flags.CoreSchedulerRequested
Value: 0
Key : Hypervisor.Flags.CpuManager
Value: 1
Key : Hypervisor.Flags.DeprecateAutoEoi
Value: 0
Key : Hypervisor.Flags.DynamicCpuDisabled
Value: 1
Key : Hypervisor.Flags.Epf
Value: 0
Key : Hypervisor.Flags.ExtendedProcessorMasks
Value: 1
Key : Hypervisor.Flags.HardwareMbecAvailable
Value: 1
Key : Hypervisor.Flags.MaxBankNumber
Value: 0
Key : Hypervisor.Flags.MemoryZeroingControl
Value: 0
Key : Hypervisor.Flags.NoExtendedRangeFlush
Value: 0
Key : Hypervisor.Flags.NoNonArchCoreSharing
Value: 1
Key : Hypervisor.Flags.Phase0InitDone
Value: 1
Key : Hypervisor.Flags.PowerSchedulerQos
Value: 0
Key : Hypervisor.Flags.RootScheduler
Value: 0
Key : Hypervisor.Flags.SynicAvailable
Value: 1
Key : Hypervisor.Flags.UseQpcBias
Value: 0
Key : Hypervisor.Flags.Value
Value: 38408431
Key : Hypervisor.Flags.ValueHex
Value: 24a10ef
Key : Hypervisor.Flags.VpAssistPage
Value: 1
Key : Hypervisor.Flags.VsmAvailable
Value: 1
Key : Hypervisor.RootFlags.AccessStats
Value: 1
Key : Hypervisor.RootFlags.CrashdumpEnlightened
Value: 1
Key : Hypervisor.RootFlags.CreateVirtualProcessor
Value: 1
Key : Hypervisor.RootFlags.DisableHyperthreading
Value: 0
Key : Hypervisor.RootFlags.HostTimelineSync
Value: 1
Key : Hypervisor.RootFlags.HypervisorDebuggingEnabled
Value: 0
Key : Hypervisor.RootFlags.IsHyperV
Value: 1
Key : Hypervisor.RootFlags.LivedumpEnlightened
Value: 1
Key : Hypervisor.RootFlags.MapDeviceInterrupt
Value: 1
Key : Hypervisor.RootFlags.MceEnlightened
Value: 1
Key : Hypervisor.RootFlags.Nested
Value: 0
Key : Hypervisor.RootFlags.StartLogicalProcessor
Value: 1
Key : Hypervisor.RootFlags.Value
Value: 1015
Key : Hypervisor.RootFlags.ValueHex
Value: 3f7
BUGCHECK_CODE: 50
BUGCHECK_P1: ffff938033360000
BUGCHECK_P2: 0
BUGCHECK_P3: fffff8025255924c
BUGCHECK_P4: 0
FILE_IN_CAB: 112624-12765-01.dmp
TAG_NOT_DEFINED_202b: *** Unknown TAG in analysis list 202b
DUMP_FILE_ATTRIBUTES: 0x21808
Kernel Generated Triage Dump
FAULTING_THREAD: ffff830fc18d30c0
READ_ADDRESS: fffff802bdbc34b0: Unable to get MiVisibleState
Unable to get NonPagedPoolStart
Unable to get NonPagedPoolEnd
Unable to get PagedPoolStart
Unable to get PagedPoolEnd
unable to get nt!MmSpecialPagesInUse
ffff938033360000
MM_INTERNAL_CODE: 0
IMAGE_NAME: vgk.sys
MODULE_NAME: vgk
FAULTING_MODULE: fffff80252530000 vgk
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: vgc.exe
TRAP_FRAME: ffffc98f216168e0 -- (.trap 0xffffc98f216168e0)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=0000000000000000 rbx=0000000000000000 rcx=0000000000000000
rdx=ffffc98f21616ff2 rsi=0000000000000000 rdi=0000000000000000
rip=fffff8025255924c rsp=ffffc98f21616a70 rbp=0000000000000034
r8=0000000000000034 r9=ffff830fc289a400 r10=0000000000000000
r11=ffffc98f21616fc0 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei pl nz ac pe nc
vgk+0x2924c:
fffff802`5255924c 381418 cmp byte ptr [rax+rbx],dl ds:00000000`00000000=??
Resetting default scope
STACK_TEXT:
ffffc98f`21616678 fffff802`bd2a9858 : 00000000`00000050 ffff9380`33360000 00000000`00000000 ffffc98f`216168e0 : nt!KeBugCheckEx
ffffc98f`21616680 fffff802`bce7a51f : ffff9380`33360000 00000000`00001000 00000000`00000002 fffff802`bcc00000 : nt!MiSystemFault+0x3d6308
ffffc98f`21616770 fffff802`bd288ccb : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!MmAccessFault+0x2ff
ffffc98f`216168e0 fffff802`5255924c : ffaca32b`1d2b7700 00000000`00000000 ffff830f`b0ac0fb0 00000004`86ee3000 : nt!KiPageFault+0x38b
ffffc98f`21616a70 ffaca32b`1d2b7700 : 00000000`00000000 ffff830f`b0ac0fb0 00000004`86ee3000 ffff830f`b0ac0fb0 : vgk+0x2924c
ffffc98f`21616a78 00000000`00000000 : ffff830f`b0ac0fb0 00000004`86ee3000 ffff830f`b0ac0fb0 fffff802`5267b966 : 0xffaca32b`1d2b7700
SYMBOL_NAME: vgk+2924c
STACK_COMMAND: .process /r /p 0xffff830fc226b0c0; .thread 0xffff830fc18d30c0 ; kb
BUCKET_ID_FUNC_OFFSET: 2924c
FAILURE_BUCKET_ID: AV_R_(null)_vgk!unknown_function
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {2c74f9bf-c695-1cb8-996e-ae91d1a2ef92}
Followup: MachineOwner
11: kd> lmvm vgk
Browse full module list
start end module name
fffff802`52530000 fffff802`54306000 vgk T (no symbols)
Loaded symbol image file: vgk.sys
Image path: vgk.sys
Image name: vgk.sys
Browse all global symbols functions data Symbol Reload
Timestamp: Thu Nov 21 08:13:16 2024 (673EC16C)
CheckSum: 01E1AF84
ImageSize: 01DD6000
Translations: 0000.04b0 0000.04e4 0409.04b0 0409.04e4
Information from resource tables:
11: kd> !blackboxntfs
NTFS Blackbox Data
0 Slow I/O Timeout Records Found
0 Oplock Break Timeout Records Found
11: kd> !blackboxpnp
PnpActivityId : {00000000-0000-0000-0000-000000000000}
PnpActivityTime : 133770422614955295
PnpEventInformation: 3
PnpEventInProgress : 0
PnpProblemCode : 24
PnpVetoType : 0
DeviceId : SWD\DAFUPnPProvider\uuid:927b3cc0-92d1-4dec-8b3b-d3d9b7fa578b
VetoString :
- 5600X.
- RX6700 10GB.
- ASRock B550M HDV.
nt!KeBugCheckEx:
11: kd> !analyze -v
Arguments:
address.
Debugging Details:
Key : AV.Type
Value: Read
Value: 1500
Value: 5814
Value: 14
Value: 1
Value: 23
Value: 734
Value: 22049
Value: 87
Value: 1.2408.27.1
Value: 0x50
Value: 0x50
Value: 21808
Value: 1
Value: 0
Value: 1
Value: 0
Key : Failure.Hash
Value: 7497cf94
Value: 1
Value: 1
Value: 0
Value: 0
Value: 0
Value: 1
Value: 0
Value: 1
Value: 0
Value: 1
Value: 1
Value: 0
Value: 0
Value: 0
Value: 1
Value: 1
Value: 0
Value: 0
Value: 1
Value: 0
Value: 38408431
Value: 24a10ef
Value: 1
Value: 1
Value: 1
Value: 1
Value: 1
Value: 0
Value: 1
Value: 0
Value: 1
Value: 1
Value: 1
Value: 1
Value: 0
Value: 1
Value: 1015
Value: 3f7
BUGCHECK_CODE: 50
BUGCHECK_P2: 0
BUGCHECK_P4: 0
ffff938033360000
MM_INTERNAL_CODE: 0
IMAGE_NAME: vgk.sys
MODULE_NAME: vgk
BLACKBOXWINLOGON: 1
vgk+0x2924c:
STACK_TEXT:
OSNAME: Windows 10
11: kd> lmvm vgk
Image path: vgk.sys
Image name: vgk.sys
CheckSum: 01E1AF84
ImageSize: 01DD6000
NTFS Blackbox Data
PnpProblemCode : 24
PnpVetoType : 0
VetoString :
Kod:************* Preparing the environment for Debugger Extensions Gallery repositories ************** ExtensionRepository : Implicit UseExperimentalFeatureForNugetShare : true AllowNugetExeUpdate : true NonInteractiveNuget : true AllowNugetMSCredentialProviderInstall : true AllowParallelInitializationOfLocalRepositories : true EnableRedirectToChakraJsProvider : false -- Configuring repositories ----> Repository : LocalInstalled, Enabled: true ----> Repository : UserExtensions, Enabled: true >>>>>>>>>>>>> Preparing the environment for Debugger Extensions Gallery repositories completed, duration 0.000 seconds ************* Waiting for Debugger Extensions Gallery to Initialize ************** >>>>>>>>>>>>> Waiting for Debugger Extensions Gallery to Initialize completed, duration 0.032 seconds ----> Repository : UserExtensions, Enabled: true, Packages count: 0 ----> Repository : LocalInstalled, Enabled: true, Packages count: 42 Microsoft (R) Windows Debugger Version 10.0.27725.1000 AMD64 Copyright (c) Microsoft Corporation. All rights reserved. Loading Dump File [C:\Users\rael\Downloads\112624-12765-01.dmp] Mini Kernel Dump File: Only registers and stack trace are available Symbol search path is: srv* Executable search path is: Windows 10 Kernel Version 26100 MP (12 procs) Free x64 Product: WinNt, suite: TerminalServer SingleUserTS Kernel base = 0xfffff802`bcc00000 PsLoadedModuleList = 0xfffff802`bdaf4830 Debug session time: Tue Nov 26 00:04:47.899 2024 (UTC + 3:00) System Uptime: 0 days 0:24:52.625 Loading Kernel Symbols ............................................................... ................................................................ ................................................................ ................... Loading User Symbols PEB is paged out (Peb.Ldr = 00000037`8b6bb018). Type ".hh dbgerr001" for details Loading unloaded module list ............... For analysis of this file, run !analyze -v nt!KeBugCheckEx: fffff802`bd0b8550 48894c2408 mov qword ptr [rsp+8],rcx ss:0018:ffffc98f`21616680=0000000000000050 11: kd> !analyze -v ******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* PAGE_FAULT_IN_NONPAGED_AREA (50) Invalid system memory was referenced. This cannot be protected by try-except. Typically the address is just plain bad or it is pointing at freed memory. Arguments: Arg1: ffff938033360000, memory referenced. Arg2: 0000000000000000, X64: bit 0 set if the fault was due to a not-present PTE. bit 1 is set if the fault was due to a write, clear if a read. bit 3 is set if the processor decided the fault was due to a corrupted PTE. bit 4 is set if the fault was due to attempted execute of a no-execute PTE. - ARM64: bit 1 is set if the fault was due to a write, clear if a read. bit 3 is set if the fault was due to attempted execute of a no-execute PTE. Arg3: fffff8025255924c, If non-zero, the instruction address which referenced the bad memory address. Arg4: 0000000000000000, (reserved) Debugging Details: ------------------ KEY_VALUES_STRING: 1 Key : AV.Type Value: Read Key : Analysis.CPU.mSec Value: 1500 Key : Analysis.Elapsed.mSec Value: 5814 Key : Analysis.IO.Other.Mb Value: 14 Key : Analysis.IO.Read.Mb Value: 1 Key : Analysis.IO.Write.Mb Value: 23 Key : Analysis.Init.CPU.mSec Value: 734 Key : Analysis.Init.Elapsed.mSec Value: 22049 Key : Analysis.Memory.CommitPeak.Mb Value: 87 Key : Analysis.Version.DbgEng Value: 10.0.27725.1000 Key : Analysis.Version.Description Value: 10.2408.27.01 amd64fre Key : Analysis.Version.Ext Value: 1.2408.27.1 Key : Bugcheck.Code.LegacyAPI Value: 0x50 Key : Bugcheck.Code.TargetModel Value: 0x50 Key : Dump.Attributes.AsUlong Value: 21808 Key : Dump.Attributes.DiagDataWrittenToHeader Value: 1 Key : Dump.Attributes.ErrorCode Value: 0 Key : Dump.Attributes.KernelGeneratedTriageDump Value: 1 Key : Dump.Attributes.LastLine Value: Dump completed successfully. Key : Dump.Attributes.ProgressPercentage Value: 0 Key : Failure.Bucket Value: AV_R_(null)_vgk!unknown_function Key : Failure.Hash Value: {2c74f9bf-c695-1cb8-996e-ae91d1a2ef92} Key : Hypervisor.Enlightenments.ValueHex Value: 7497cf94 Key : Hypervisor.Flags.AnyHypervisorPresent Value: 1 Key : Hypervisor.Flags.ApicEnlightened Value: 1 Key : Hypervisor.Flags.ApicVirtualizationAvailable Value: 0 Key : Hypervisor.Flags.AsyncMemoryHint Value: 0 Key : Hypervisor.Flags.CoreSchedulerRequested Value: 0 Key : Hypervisor.Flags.CpuManager Value: 1 Key : Hypervisor.Flags.DeprecateAutoEoi Value: 0 Key : Hypervisor.Flags.DynamicCpuDisabled Value: 1 Key : Hypervisor.Flags.Epf Value: 0 Key : Hypervisor.Flags.ExtendedProcessorMasks Value: 1 Key : Hypervisor.Flags.HardwareMbecAvailable Value: 1 Key : Hypervisor.Flags.MaxBankNumber Value: 0 Key : Hypervisor.Flags.MemoryZeroingControl Value: 0 Key : Hypervisor.Flags.NoExtendedRangeFlush Value: 0 Key : Hypervisor.Flags.NoNonArchCoreSharing Value: 1 Key : Hypervisor.Flags.Phase0InitDone Value: 1 Key : Hypervisor.Flags.PowerSchedulerQos Value: 0 Key : Hypervisor.Flags.RootScheduler Value: 0 Key : Hypervisor.Flags.SynicAvailable Value: 1 Key : Hypervisor.Flags.UseQpcBias Value: 0 Key : Hypervisor.Flags.Value Value: 38408431 Key : Hypervisor.Flags.ValueHex Value: 24a10ef Key : Hypervisor.Flags.VpAssistPage Value: 1 Key : Hypervisor.Flags.VsmAvailable Value: 1 Key : Hypervisor.RootFlags.AccessStats Value: 1 Key : Hypervisor.RootFlags.CrashdumpEnlightened Value: 1 Key : Hypervisor.RootFlags.CreateVirtualProcessor Value: 1 Key : Hypervisor.RootFlags.DisableHyperthreading Value: 0 Key : Hypervisor.RootFlags.HostTimelineSync Value: 1 Key : Hypervisor.RootFlags.HypervisorDebuggingEnabled Value: 0 Key : Hypervisor.RootFlags.IsHyperV Value: 1 Key : Hypervisor.RootFlags.LivedumpEnlightened Value: 1 Key : Hypervisor.RootFlags.MapDeviceInterrupt Value: 1 Key : Hypervisor.RootFlags.MceEnlightened Value: 1 Key : Hypervisor.RootFlags.Nested Value: 0 Key : Hypervisor.RootFlags.StartLogicalProcessor Value: 1 Key : Hypervisor.RootFlags.Value Value: 1015 Key : Hypervisor.RootFlags.ValueHex Value: 3f7 BUGCHECK_CODE: 50 BUGCHECK_P1: ffff938033360000 BUGCHECK_P2: 0 BUGCHECK_P3: fffff8025255924c BUGCHECK_P4: 0 FILE_IN_CAB: 112624-12765-01.dmp TAG_NOT_DEFINED_202b: *** Unknown TAG in analysis list 202b DUMP_FILE_ATTRIBUTES: 0x21808 Kernel Generated Triage Dump FAULTING_THREAD: ffff830fc18d30c0 READ_ADDRESS: fffff802bdbc34b0: Unable to get MiVisibleState Unable to get NonPagedPoolStart Unable to get NonPagedPoolEnd Unable to get PagedPoolStart Unable to get PagedPoolEnd unable to get nt!MmSpecialPagesInUse ffff938033360000 MM_INTERNAL_CODE: 0 IMAGE_NAME: vgk.sys MODULE_NAME: vgk FAULTING_MODULE: fffff80252530000 vgk BLACKBOXBSD: 1 (!blackboxbsd) BLACKBOXNTFS: 1 (!blackboxntfs) BLACKBOXPNP: 1 (!blackboxpnp) BLACKBOXWINLOGON: 1 CUSTOMER_CRASH_COUNT: 1 PROCESS_NAME: vgc.exe TRAP_FRAME: ffffc98f216168e0 -- (.trap 0xffffc98f216168e0) NOTE: The trap frame does not contain all registers. Some register values may be zeroed or incorrect. rax=0000000000000000 rbx=0000000000000000 rcx=0000000000000000 rdx=ffffc98f21616ff2 rsi=0000000000000000 rdi=0000000000000000 rip=fffff8025255924c rsp=ffffc98f21616a70 rbp=0000000000000034 r8=0000000000000034 r9=ffff830fc289a400 r10=0000000000000000 r11=ffffc98f21616fc0 r12=0000000000000000 r13=0000000000000000 r14=0000000000000000 r15=0000000000000000 iopl=0 nv up ei pl nz ac pe nc vgk+0x2924c: fffff802`5255924c 381418 cmp byte ptr [rax+rbx],dl ds:00000000`00000000=?? Resetting default scope STACK_TEXT: ffffc98f`21616678 fffff802`bd2a9858 : 00000000`00000050 ffff9380`33360000 00000000`00000000 ffffc98f`216168e0 : nt!KeBugCheckEx ffffc98f`21616680 fffff802`bce7a51f : ffff9380`33360000 00000000`00001000 00000000`00000002 fffff802`bcc00000 : nt!MiSystemFault+0x3d6308 ffffc98f`21616770 fffff802`bd288ccb : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!MmAccessFault+0x2ff ffffc98f`216168e0 fffff802`5255924c : ffaca32b`1d2b7700 00000000`00000000 ffff830f`b0ac0fb0 00000004`86ee3000 : nt!KiPageFault+0x38b ffffc98f`21616a70 ffaca32b`1d2b7700 : 00000000`00000000 ffff830f`b0ac0fb0 00000004`86ee3000 ffff830f`b0ac0fb0 : vgk+0x2924c ffffc98f`21616a78 00000000`00000000 : ffff830f`b0ac0fb0 00000004`86ee3000 ffff830f`b0ac0fb0 fffff802`5267b966 : 0xffaca32b`1d2b7700 SYMBOL_NAME: vgk+2924c STACK_COMMAND: .process /r /p 0xffff830fc226b0c0; .thread 0xffff830fc18d30c0 ; kb BUCKET_ID_FUNC_OFFSET: 2924c FAILURE_BUCKET_ID: AV_R_(null)_vgk!unknown_function OSPLATFORM_TYPE: x64 OSNAME: Windows 10 FAILURE_ID_HASH: {2c74f9bf-c695-1cb8-996e-ae91d1a2ef92} Followup: MachineOwner --------- 11: kd> lmvm vgk Browse full module list start end module name fffff802`52530000 fffff802`54306000 vgk T (no symbols) Loaded symbol image file: vgk.sys Image path: vgk.sys Image name: vgk.sys Browse all global symbols functions data Symbol Reload Timestamp: Thu Nov 21 08:13:16 2024 (673EC16C) CheckSum: 01E1AF84 ImageSize: 01DD6000 Translations: 0000.04b0 0000.04e4 0409.04b0 0409.04e4 Information from resource tables: 11: kd> !blackboxntfs NTFS Blackbox Data 0 Slow I/O Timeout Records Found 0 Oplock Break Timeout Records Found 11: kd> !blackboxpnp PnpActivityId : {00000000-0000-0000-0000-000000000000} PnpActivityTime : 133770422614955295 PnpEventInformation: 3 PnpEventInProgress : 0 PnpProblemCode : 24 PnpVetoType : 0 DeviceId : SWD\DAFUPnPProvider\uuid:927b3cc0-92d1-4dec-8b3b-d3d9b7fa578b VetoString :
Kod:************* Preparing the environment for Debugger Extensions Gallery repositories ************** ExtensionRepository : Implicit. UseExperimentalFeatureForNugetShare : true. AllowNugetExeUpdate : true. NonInteractiveNuget : true. AllowNugetMSCredentialProviderInstall : true. AllowParallelInitializationOfLocalRepositories : true. EnableRedirectToChakraJsProvider : false. -- Configuring repositories. ----> Repository : LocalInstalled, Enabled: true. ----> Repository : UserExtensions, Enabled: true. >>>>>>>>>>>>> Preparing the environment for Debugger Extensions Gallery repositories completed, duration 0.000 seconds. ************* Waiting for Debugger Extensions Gallery to Initialize ************** >>>>>>>>>>>>> Waiting for Debugger Extensions Gallery to Initialize completed, duration 0.032 seconds. ----> Repository : UserExtensions, Enabled: true, Packages count: 0 ----> Repository : LocalInstalled, Enabled: true, Packages count: 42. Microsoft (R) Windows Debugger Version 10.0.27725.1000 AMD64. Copyright (c) Microsoft Corporation. All rights reserved. Loading Dump File [C:\Users\rael\Downloads\112624-12765-01.dmp] Mini Kernel Dump File: Only registers and stack trace are available. Symbol search path is: srv* Executable search path is: Windows 10 Kernel Version 26100 MP (12 procs) Free x64. Product: WinNt, suite: TerminalServer SingleUserTS. Kernel base = 0xfffff802`bcc00000 PsLoadedModuleList = 0xfffff802`bdaf4830 Debug session time: Tue Nov 26 00:04:47.899 2024 (UTC + 3:00) System Uptime: 0 days 0:24:52.625 Loading Kernel Symbols. ............................................................... ................................................................ ................................................................ ................... Loading User Symbols. PEB is paged out (Peb.Ldr = 00000037`8b6bb018). Type ".hh dbgerr001" for details. Loading unloaded module list. ............... For analysis of this file, run !analyze -v nt!KeBugCheckEx: fffff802`bd0b8550 48894c2408 mov qword ptr [rsp+8],rcx ss:0018:ffffc98f`21616680=0000000000000050 11: kd> !analyze -v ******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* PAGE_FAULT_IN_NONPAGED_AREA (50) Invalid system memory was referenced. This cannot be protected by try-except. Typically the address is just plain bad or it is pointing at freed memory. Arguments: Arg1: ffff938033360000, memory referenced. Arg2: 0000000000000000, X64: bit 0 set if the fault was due to a not-present PTE. bit 1 is set if the fault was due to a write, clear if a read. bit 3 is set if the processor decided the fault was due to a corrupted PTE. bit 4 is set if the fault was due to attempted execute of a no-execute PTE. - ARM64: bit 1 is set if the fault was due to a write, clear if a read. bit 3 is set if the fault was due to attempted execute of a no-execute PTE. Arg3: fffff8025255924c, If non-zero, the instruction address which referenced the bad memory. address. Arg4: 0000000000000000, (reserved) Debugging Details: ------------------ KEY_VALUES_STRING: 1 Key : AV.Type Value: Read. Key : Analysis.CPU.mSec Value: 1500. Key : Analysis.Elapsed.mSec Value: 5814. Key : Analysis.IO.Other.Mb Value: 14. Key : Analysis.IO.Read.Mb Value: 1 Key : Analysis.IO.Write.Mb Value: 23. Key : Analysis.Init.CPU.mSec Value: 734. Key : Analysis.Init.Elapsed.mSec Value: 22049. Key : Analysis.Memory.CommitPeak.Mb Value: 87. Key : Analysis.Version.DbgEng Value: 10.0.27725.1000 Key : Analysis.Version.Description Value: 10.2408.27.01 amd64fre. Key : Analysis.Version.Ext Value: 1.2408.27.1 Key : Bugcheck.Code.LegacyAPI Value: 0x50. Key : Bugcheck.Code.TargetModel Value: 0x50. Key : Dump.Attributes.AsUlong Value: 21808. Key : Dump.Attributes.DiagDataWrittenToHeader Value: 1 Key : Dump.Attributes.ErrorCode Value: 0 Key : Dump.Attributes.KernelGeneratedTriageDump Value: 1 Key : Dump.Attributes.LastLine Value: Dump completed successfully. Key : Dump.Attributes.ProgressPercentage Value: 0 Key : Failure.Bucket Value: AV_R_(null)_vgk!unknown_function Key : Failure.Hash Value: {2c74f9bf-c695-1cb8-996e-ae91d1a2ef92} Key : Hypervisor.Enlightenments.ValueHex Value: 7497cf94. Key : Hypervisor.Flags.AnyHypervisorPresent Value: 1 Key : Hypervisor.Flags.ApicEnlightened Value: 1 Key : Hypervisor.Flags.ApicVirtualizationAvailable Value: 0 Key : Hypervisor.Flags.AsyncMemoryHint Value: 0 Key : Hypervisor.Flags.CoreSchedulerRequested Value: 0 Key : Hypervisor.Flags.CpuManager Value: 1 Key : Hypervisor.Flags.DeprecateAutoEoi Value: 0 Key : Hypervisor.Flags.DynamicCpuDisabled Value: 1 Key : Hypervisor.Flags.Epf Value: 0 Key : Hypervisor.Flags.ExtendedProcessorMasks Value: 1 Key : Hypervisor.Flags.HardwareMbecAvailable Value: 1 Key : Hypervisor.Flags.MaxBankNumber Value: 0 Key : Hypervisor.Flags.MemoryZeroingControl Value: 0 Key : Hypervisor.Flags.NoExtendedRangeFlush Value: 0 Key : Hypervisor.Flags.NoNonArchCoreSharing Value: 1 Key : Hypervisor.Flags.Phase0InitDone Value: 1 Key : Hypervisor.Flags.PowerSchedulerQos Value: 0 Key : Hypervisor.Flags.RootScheduler Value: 0 Key : Hypervisor.Flags.SynicAvailable Value: 1 Key : Hypervisor.Flags.UseQpcBias Value: 0 Key : Hypervisor.Flags.Value Value: 38408431. Key : Hypervisor.Flags.ValueHex Value: 24a10ef. Key : Hypervisor.Flags.VpAssistPage Value: 1 Key : Hypervisor.Flags.VsmAvailable Value: 1 Key : Hypervisor.RootFlags.AccessStats Value: 1 Key : Hypervisor.RootFlags.CrashdumpEnlightened Value: 1 Key : Hypervisor.RootFlags.CreateVirtualProcessor Value: 1 Key : Hypervisor.RootFlags.DisableHyperthreading Value: 0 Key : Hypervisor.RootFlags.HostTimelineSync Value: 1 Key : Hypervisor.RootFlags.HypervisorDebuggingEnabled Value: 0 Key : Hypervisor.RootFlags.IsHyperV Value: 1 Key : Hypervisor.RootFlags.LivedumpEnlightened Value: 1 Key : Hypervisor.RootFlags.MapDeviceInterrupt Value: 1 Key : Hypervisor.RootFlags.MceEnlightened Value: 1 Key : Hypervisor.RootFlags.Nested Value: 0 Key : Hypervisor.RootFlags.StartLogicalProcessor Value: 1 Key : Hypervisor.RootFlags.Value Value: 1015. Key : Hypervisor.RootFlags.ValueHex Value: 3f7. BUGCHECK_CODE: 50. BUGCHECK_P1: ffff938033360000. BUGCHECK_P2: 0 BUGCHECK_P3: fffff8025255924c. BUGCHECK_P4: 0 FILE_IN_CAB: 112624-12765-01.dmp TAG_NOT_DEFINED_202b: *** Unknown TAG in analysis list 202b. DUMP_FILE_ATTRIBUTES: 0x21808. Kernel Generated Triage Dump. FAULTING_THREAD: ffff830fc18d30c0. READ_ADDRESS: fffff802bdbc34b0: Unable to get MiVisibleState. Unable to get NonPagedPoolStart. Unable to get NonPagedPoolEnd. Unable to get PagedPoolStart. Unable to get PagedPoolEnd. unable to get nt!MmSpecialPagesInUse ffff938033360000. MM_INTERNAL_CODE: 0 IMAGE_NAME: vgk.sys MODULE_NAME: vgk. FAULTING_MODULE: fffff80252530000 vgk. BLACKBOXBSD: 1 (!blackboxbsd) BLACKBOXNTFS: 1 (!blackboxntfs) BLACKBOXPNP: 1 (!blackboxpnp) BLACKBOXWINLOGON: 1 CUSTOMER_CRASH_COUNT: 1 PROCESS_NAME: vgc.exe TRAP_FRAME: ffffc98f216168e0 -- (.trap 0xffffc98f216168e0) NOTE: The trap frame does not contain all registers. Some register values may be zeroed or incorrect. rax=0000000000000000 rbx=0000000000000000 rcx=0000000000000000 rdx=ffffc98f21616ff2 rsi=0000000000000000 rdi=0000000000000000 rip=fffff8025255924c rsp=ffffc98f21616a70 rbp=0000000000000034 r8=0000000000000034 r9=ffff830fc289a400 r10=0000000000000000 r11=ffffc98f21616fc0 r12=0000000000000000 r13=0000000000000000 r14=0000000000000000 r15=0000000000000000 iopl=0 nv up ei pl nz ac pe nc. vgk+0x2924c: fffff802`5255924c 381418 cmp byte ptr [rax+rbx],dl ds:00000000`00000000=?? Resetting default scope. STACK_TEXT: ffffc98f`21616678 fffff802`bd2a9858 : 00000000`00000050 ffff9380`33360000 00000000`00000000 ffffc98f`216168e0 : nt!KeBugCheckEx ffffc98f`21616680 fffff802`bce7a51f : ffff9380`33360000 00000000`00001000 00000000`00000002 fffff802`bcc00000 : nt!MiSystemFault+0x3d6308 ffffc98f`21616770 fffff802`bd288ccb : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!MmAccessFault+0x2ff ffffc98f`216168e0 fffff802`5255924c : ffaca32b`1d2b7700 00000000`00000000 ffff830f`b0ac0fb0 00000004`86ee3000 : nt!KiPageFault+0x38b ffffc98f`21616a70 ffaca32b`1d2b7700 : 00000000`00000000 ffff830f`b0ac0fb0 00000004`86ee3000 ffff830f`b0ac0fb0 : vgk+0x2924c ffffc98f`21616a78 00000000`00000000 : ffff830f`b0ac0fb0 00000004`86ee3000 ffff830f`b0ac0fb0 fffff802`5267b966 : 0xffaca32b`1d2b7700 SYMBOL_NAME: vgk+2924c STACK_COMMAND: .process /r /p 0xffff830fc226b0c0; .thread 0xffff830fc18d30c0 ; kb. BUCKET_ID_FUNC_OFFSET: 2924c. FAILURE_BUCKET_ID: AV_R_(null)_vgk!unknown_function OSPLATFORM_TYPE: x64. OSNAME: Windows 10. FAILURE_ID_HASH: {2c74f9bf-c695-1cb8-996e-ae91d1a2ef92} Followup: MachineOwner. --------- 11: kd> lmvm vgk. Browse full module list. start end module name. fffff802`52530000 fffff802`54306000 vgk T (no symbols) Loaded symbol image file: vgk.sys Image path: vgk.sys Image name: vgk.sys Browse all global symbols functions data Symbol Reload. Timestamp: Thu Nov 21 08:13:16 2024 (673EC16C) CheckSum: 01E1AF84. ImageSize: 01DD6000. Translations: 0000.04b0 0000.04e4 0409.04b0 0409.04e4 Information from resource tables: 11: kd> !blackboxntfs NTFS Blackbox Data. 0 Slow I/O Timeout Records Found. 0 Oplock Break Timeout Records Found. 11: kd> !blackboxpnp PnpActivityId : {00000000-0000-0000-0000-000000000000} PnpActivityTime : 133770422614955295. PnpEventInformation: 3 PnpEventInProgress : 0 PnpProblemCode : 24. PnpVetoType : 0 DeviceId : SWD\DAFUPnPProvider\uuid:927b3cc0-92d1-4dec-8b3b-d3d9b7fa578b VetoString :
Spyware oyunlari birakin, Starcraft ve Diablo serilerini tadin, bir de sorunun valo oldugunu dogrulayalim da bi cozum yazilsin bana, bu gunluk bu kadar sevap yeter2. mavi ekranım Vanguard sağ olsun
Spyware oyunlari birakin, Starcraft ve Diablo serilerini tadin, bir de sorunun Valorant oldugunu dogrulayalim da bir cozum yazilsin bana, bu gunluk bu kadar sevap yeter
@5330, silince duzeldi mi acaba?
We use cookies and similar technologies for the following purposes:
Do you accept cookies and these technologies?
