Çözüldü SYSTEM_SERVICE_EXCEPTION (3b) hatası
  • Konuyu başlatan Konuyu başlatan Recep Baltaş
  • Mesaj Mesaj 4
  • Görüntüleme Görüntüleme 1B
3 Aralık 2023
İstanbul
Kod:
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000005, Exception code that caused the BugCheck
Arg2: fffff64d44a8f8c8, Address of the instruction which caused the BugCheck
Arg3: ffffb50d710fe890, Address of the context record for the exception that caused the BugCheck
Arg4: 0000000000000000, zero.
Debugging Details:
KEY_VALUES_STRING: 1
    Key  : Analysis.CPU.mSec
    Value: 2500
    Key  : Analysis.Elapsed.mSec
    Value: 3625
    Key  : Analysis.IO.Other.Mb
    Value: 4
    Key  : Analysis.IO.Read.Mb
    Value: 0
    Key  : Analysis.IO.Write.Mb
    Value: 18
    Key  : Analysis.Init.CPU.mSec
    Value: 1030
    Value: 89424
    Value: 103
    Value: 0x3b
    Value: 808
    Value: 1
    Key  : Failure.Bucket
    Value: AV_win32kbase!DirectComposition::CConnection::RetrieveBatches
    Key  : Failure.Hash
    Value: {91b3efb6-f877-a742-07a1-4232f8bc769f}
    Key  : Hypervisor.Enlightenments.ValueHex
    Value: 1497cf94
    Key  : Hypervisor.Flags.AnyHypervisorPresent
    Value: 1
    Key  : Hypervisor.Flags.ApicEnlightened
    Value: 1
    Key  : Hypervisor.Flags.ApicVirtualizationAvailable
    Value: 0
    Key  : Hypervisor.Flags.AsyncMemoryHint
    Value: 0
    Key  : Hypervisor.Flags.CoreSchedulerRequested
    Value: 0
    Key  : Hypervisor.Flags.CpuManager
    Value: 1
    Key  : Hypervisor.Flags.DeprecateAutoEoi
    Value: 0
    Key  : Hypervisor.Flags.DynamicCpuDisabled
    Value: 1
    Key  : Hypervisor.Flags.Epf
    Value: 0
    Key  : Hypervisor.Flags.ExtendedProcessorMasks
    Value: 1
    Key  : Hypervisor.Flags.HardwareMbecAvailable
    Value: 1
    Key  : Hypervisor.Flags.MaxBankNumber
    Value: 0
    Key  : Hypervisor.Flags.MemoryZeroingControl
    Value: 0
    Key  : Hypervisor.Flags.NoExtendedRangeFlush
    Value: 0
    Key  : Hypervisor.Flags.NoNonArchCoreSharing
    Value: 1
    Key  : Hypervisor.Flags.Phase0InitDone
    Value: 1
    Key  : Hypervisor.Flags.PowerSchedulerQos
    Value: 0
    Key  : Hypervisor.Flags.RootScheduler
    Value: 0
    Key  : Hypervisor.Flags.SynicAvailable
    Value: 1
    Key  : Hypervisor.Flags.UseQpcBias
    Value: 0
    Key  : Hypervisor.Flags.Value
    Value: 4853999
    Key  : Hypervisor.Flags.ValueHex
    Value: 4a10ef
    Key  : Hypervisor.Flags.VpAssistPage
    Value: 1
    Key  : Hypervisor.Flags.VsmAvailable
    Value: 1
    Key  : Hypervisor.RootFlags.AccessStats
    Value: 1
    Key  : Hypervisor.RootFlags.CrashdumpEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.CreateVirtualProcessor
    Value: 1
    Key  : Hypervisor.RootFlags.DisableHyperthreading
    Value: 0
    Key  : Hypervisor.RootFlags.HostTimelineSync
    Value: 1
    Key  : Hypervisor.RootFlags.HypervisorDebuggingEnabled
    Value: 0
    Key  : Hypervisor.RootFlags.IsHyperV
    Value: 1
    Key  : Hypervisor.RootFlags.LivedumpEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.MapDeviceInterrupt
    Value: 1
    Key  : Hypervisor.RootFlags.MceEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.Nested
    Value: 0
    Key  : Hypervisor.RootFlags.StartLogicalProcessor
    Value: 1
    Key  : Hypervisor.RootFlags.Value
    Value: 1015
    Key  : Hypervisor.RootFlags.ValueHex
    Value: 3f7
BUGCHECK_CODE:  3b
BUGCHECK_P1: c0000005
BUGCHECK_P2: fffff64d44a8f8c8
BUGCHECK_P3: ffffb50d710fe890
BUGCHECK_P4: 0
FILE_IN_CAB:  120223-14578-01.dmp
TAG_NOT_DEFINED_202b:  *** Unknown TAG in analysis list 202b
DUMP_FILE_ATTRIBUTES: 0x808
  Kernel Generated Triage Dump
CONTEXT:  ffffb50d710fe890 -- (.cxr 0xffffb50d710fe890)
rax=ffffba03e160b700 rbx=ffffba03d3dbb000 rcx=0000000000000200
rdx=0000000000000001 rsi=0000000000000000 rdi=ffff3a03dcbed830
rip=fffff64d44a8f8c8 rsp=ffffb50d710ff2b0 rbp=ffffb50d710ff359
 r8=ffffb50d710ff3e8  r9=0000000000000058 r10=0000fffff80767cb
r11=0000000000000000 r12=0000000000003c02 r13=0000000000000001
r14=0000000000000001 r15=0000000000000000
iopl=0         nv up ei pl nz na pe nc
cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00050202
win32kbase!DirectComposition::CConnection::RetrieveBatches+0xc8:
fffff64d`44a8f8c8 488b4730        mov     rax,qword ptr [rdi+30h] ds:002b:ffff3a03`dcbed860=????????????????
Resetting default scope
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  dwm.exe
STACK_TEXT:
ffffb50d`710ff2b0 fffff64d`44a8f76d     : 00000000`00000004 00000000`00003c02 ffffb50d`710ff3e8 ffffba03`e160b700 : win32kbase!DirectComposition::CConnection::RetrieveBatches+0xc8
ffffb50d`710ff3c0 fffff64d`4536fedd     : 00000000`00000004 ffff8f82`a37b80c0 0000004a`1299f4f8 ffffba03`e2d06010 : win32kbase!NtDCompositionGetConnectionBatch+0x20d
ffffb50d`710ff430 fffff807`3182b6e8     : ffff8f82`a37b80c0 ffff8f82`a37b80c0 0000015c`94768a38 00000000`00000000 : win32k!NtDCompositionGetConnectionBatch+0x15
ffffb50d`710ff460 00007ffd`c29439b4     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x28
0000004a`1299f488 00000000`00000000     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ffd`c29439b4
SYMBOL_NAME:  win32kbase!DirectComposition::CConnection::RetrieveBatches+c8
MODULE_NAME: win32kbase
IMAGE_NAME:  win32kbase.sys
IMAGE_VERSION:  10.0.22621.2715
STACK_COMMAND:  .cxr 0xffffb50d710fe890 ; kb
BUCKET_ID_FUNC_OFFSET:  c8
FAILURE_BUCKET_ID:  AV_win32kbase!DirectComposition::CConnection::RetrieveBatches
OSPLATFORM_TYPE:  x64
OSNAME:  Windows 10
FAILURE_ID_HASH:  {91b3efb6-f877-a742-07a1-4232f8bc769f}
IRQL_NOT_LESS_OR_EQUAL (a)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high.  This is usually
caused by drivers using improper addresses.
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: 0000000000000004, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, bitfield :
    bit 0 : value 0 = read operation, 1 = write operation
    bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
Arg4: fffff800330bf131, address which referenced memory
Debugging Details:
    Value: 2656
    Value: 11211
    Value: 4
    Value: 12
    Value: 37
    Value: 1031
    Value: 99459
    Value: 89
    Value: 0xa
    Value: 1808
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: AV_nt!MiLockLeafPage
    Key  : Failure.Hash
    Value: {c0731cf0-68ed-969a-f0ca-f4d9af8ec867}
    Value: 1497cf94
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 4853999
    Value: 4a10ef
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 1015
    Value: 3f7
BUGCHECK_CODE:  a
BUGCHECK_P1: 4
BUGCHECK_P2: 2
BUGCHECK_P3: 0
BUGCHECK_P4: fffff800330bf131
FILE_IN_CAB:  120223-14437-01.dmp
DUMP_FILE_ATTRIBUTES: 0x1808
READ_ADDRESS: fffff80033b1d470: Unable to get MiVisibleState
Unable to get NonPagedPoolStart
Unable to get NonPagedPoolEnd
Unable to get PagedPoolStart
Unable to get PagedPoolEnd
unable to get nt!MmSpecialPagesInUse
 0000000000000004
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
PROCESS_NAME:  System
TRAP_FRAME:  ffffcb09920b1860 -- (.trap 0xffffcb09920b1860)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=fffff80033a66fc0 rbx=0000000000000000 rcx=ffffea0010c51b60
rdx=0000000000000000 rsi=0000000000000000 rdi=0000000000000000
rip=fffff800330bf131 rsp=ffffcb09920b19f0 rbp=0000000000000001
 r8=ffffea0000000000  r9=7fffffffffffffff r10=0000000000000000
r11=0000000000000000 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
nt!MiLockLeafPage+0xc1:
fffff800`330bf131 8b4204          mov     eax,dword ptr [rdx+4] ds:00000000`00000004=????????
STACK_TEXT:
ffffcb09`920b1718 fffff800`3322bfa9     : 00000000`0000000a 00000000`00000004 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
ffffcb09`920b1720 fffff800`33227634     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiBugCheckDispatch+0x69
ffffcb09`920b1860 fffff800`330bf131     : 00000000`00000000 fffff800`33a680f0 00000000`00000002 00000000`0043543e : nt!KiPageFault+0x474
ffffcb09`920b19f0 fffff800`3341bb21     : 00000000`00000000 ffffcb09`920b1b09 00000000`00000165 ffff9980`2c5cbb28 : nt!MiLockLeafPage+0xc1
ffffcb09`920b1a40 fffff800`332f21ff     : ffffea00`17247ba0 00000000`007b6d3e 80000007`b6d3e963 ffffea00`17247ba0 : nt!MiReplacePageOfProtoPool+0x391
ffffcb09`920b1b70 fffff800`331b6f94     : fffff800`33a6b000 ffffea00`17247ba0 fffff800`00000001 ffffea00`17247ba0 : nt!MiStealPage+0x139c13
ffffcb09`920b1e20 fffff800`331b6a58     : fffff800`00000000 fffff800`00000000 ffffcb09`920b1fd8 00000000`ffffffff : nt!MiTradePage+0x424
ffffcb09`920b1ed0 fffff800`331b7630     : 00000000`00000000 00000000`00000000 00000000`ffffffff 00000000`00000000 : nt!MiClaimPhysicalRun+0xcc
ffffcb09`920b1f70 fffff800`332665be     : fffff800`33a6b000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!MiFindContiguousPagesEx+0x408
ffffcb09`920b21c0 fffff800`3345bcfb     : ffffed00`00000000 00000000`00000000 00000000`00000002 00000000`0000f97d : nt!MiRebuildLargePage+0x176
ffffcb09`920b22f0 fffff800`33034f85     : ffff8204`c5b2e800 fffff800`33a6b000 00000000`0000f97d 00000000`00000000 : nt!MiRebuildLargePages+0x2db
ffffcb09`920b2380 fffff800`33107287     : ffff8204`c5b66040 00000000`000002f0 ffff8204`c5b66040 fffff800`33034e30 : nt!ExpWorkerThread+0x155
ffffcb09`920b2570 fffff800`3321b8e4     : ffffab00`35ca2180 ffff8204`c5b66040 fffff800`33107230 00000000`00000000 : nt!PspSystemThreadStartup+0x57
ffffcb09`920b25c0 00000000`00000000     : ffffcb09`920b3000 ffffcb09`920ac000 00000000`00000000 00000000`00000000 : nt!KiStartSystemThread+0x34
SYMBOL_NAME:  nt!MiLockLeafPage+c1
MODULE_NAME: nt
STACK_COMMAND:  .cxr; .ecxr ; kb
IMAGE_NAME:  ntkrnlmp.exe
BUCKET_ID_FUNC_OFFSET:  c1
FAILURE_BUCKET_ID:  AV_nt!MiLockLeafPage
OSNAME:  Windows 10
FAILURE_ID_HASH:  {c0731cf0-68ed-969a-f0ca-f4d9af8ec867}
DRIVER_POWER_STATE_FAILURE (9f)
A driver has failed to complete a power IRP within a specific time.
Arguments:
Arg1: 0000000000000003, A device object has been blocking an IRP for too long a time
Arg2: ffff828e128e9050, Physical Device Object of the stack
Arg3: ffffcc05e64a7178, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the Functional Device Object of the stack
Arg4: ffff828e17a608a0, The blocked IRP
Debugging Details:
    Value: 2531
    Value: 14804
    Value: 4
    Value: 5
    Value: 25
    Value: 1093
    Value: 100349
    Value: 102
    Value: 0x9f
    Value: 1808
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 0x9F_3_IMAGE_storahci.sys
    Key  : Failure.Hash
    Value: {21defffd-4d1f-b62d-8f72-d4892aa9cff8}
    Value: 1497cf94
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 4853999
    Value: 4a10ef
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 1015
    Value: 3f7
BUGCHECK_CODE:  9f
BUGCHECK_P1: 3
BUGCHECK_P2: ffff828e128e9050
BUGCHECK_P3: ffffcc05e64a7178
BUGCHECK_P4: ffff828e17a608a0
FILE_IN_CAB:  120223-14281-01.dmp
DRVPOWERSTATE_SUBCODE:  3
DRIVER_OBJECT: ffff828e128b7060
IMAGE_NAME:  storahci.sys
MODULE_NAME: storahci
FAULTING_MODULE: fffff80614550000 storahci
BLACKBOXWINLOGON: 1
STACK_TEXT:
ffffcc05`e64a7128 fffff806`0ed811e6     : 00000000`0000009f 00000000`00000003 ffff828e`128e9050 ffffcc05`e64a7178 : nt!KeBugCheckEx
ffffcc05`e64a7130 fffff806`0ed810bc     : 00000000`00000002 ffffb481`1a1d1180 ffffb481`1a1d1180 00000000`00000000 : nt!PopIrpWatchdogBugcheck+0x122
ffffcc05`e64a71b0 fffff806`0ea7610b     : ffff828e`17eb8290 00000000`00000001 ffffcc05`e64a7478 00000000`00000002 : nt!PopIrpWatchdog+0xc
ffffcc05`e64a71e0 fffff806`0ea73cf4     : 00000000`00000000 00000000`00000000 00000000`00000000 fffff806`0ce4b548 : nt!KiProcessExpiredTimerList+0x1eb
ffffcc05`e64a7310 fffff806`0ec1b77e     : ffff828e`2934d080 ffffb481`1a1d1180 ffff828e`0efb5040 ffff828e`40f64040 : nt!KiRetireDpcList+0xaf4
ffffcc05`e64a75c0 00000000`00000000     : ffffcc05`e64a8000 ffffcc05`e64a1000 00000000`00000000 00000000`00000000 : nt!KiIdleLoop+0x9e
IMAGE_VERSION:  10.0.22621.2792
FAILURE_BUCKET_ID:  0x9F_3_IMAGE_storahci.sys
OSNAME:  Windows 10
FAILURE_ID_HASH:  {21defffd-4d1f-b62d-8f72-d4892aa9cff8}
Arguments:
Arg4: fffff804168aa9fb, address which referenced memory
Debugging Details:
    Value: 2577
    Value: 3956
    Value: 3
    Value: 2
    Value: 20
    Value: 999
    Value: 102447
    Value: 109
    Value: 0xa
    Value: 808
    Value: 1
    Value: AV_nt!MmPurgeSection
    Key  : Failure.Hash
    Value: {49ee7632-0167-6256-d052-16dfb3547071}
    Value: 1497cf94
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 4853999
    Value: 4a10ef
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 1015
    Value: 3f7
BUGCHECK_CODE:  a
BUGCHECK_P1: 4
BUGCHECK_P2: 2
BUGCHECK_P3: 0
BUGCHECK_P4: fffff804168aa9fb
FILE_IN_CAB:  120223-14000-01.dmp
READ_ADDRESS: fffff8041731d470: Unable to get MiVisibleState
 0000000000000004
PROCESS_NAME:  minecraft.exe
TRAP_FRAME:  fffffc086b33d9e0 -- (.trap 0xfffffc086b33d9e0)
rax=fffff80417266fc0 rbx=0000000000000000 rcx=000000ffffffffff
rip=fffff804168aa9fb rsp=fffffc086b33db70 rbp=fffffc086b33dc31
 r8=3fffffffffffffff  r9=0000000000000001 r10=0000000000000063
r11=0000003fffffffff r12=0000000000000000 r13=0000000000000000
nt!MmPurgeSection+0x2bb:
fffff804`168aa9fb 8b4204          mov     eax,dword ptr [rdx+4] ds:00000000`00000004=????????
STACK_TEXT:
fffffc08`6b33d898 fffff804`16a2bfa9     : 00000000`0000000a 00000000`00000004 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
fffffc08`6b33d8a0 fffff804`16a27634     : ffffc080`00023000 00000000`00000000 00000000`00000000 fffff804`1726ba80 : nt!KiBugCheckDispatch+0x69
fffffc08`6b33d9e0 fffff804`168aa9fb     : 00000000`00000000 00000000`00000000 ffffe009`f56a8611 00000000`00000001 : nt!KiPageFault+0x474
fffffc08`6b33db70 fffff804`168c5b08     : ffffad8e`1de69300 ffffad8e`1de69301 ffffad8e`1de69320 00000000`00000000 : nt!MmPurgeSection+0x2bb
fffffc08`6b33dc90 fffff804`168c6583     : ffffad8e`1c56fd18 00000000`00000000 00000000`00000000 00000000`00000000 : nt!CcPurgeCacheSection+0xc8
fffffc08`6b33dd50 fffff804`168c63cd     : ffffad8e`1de69320 00000000`00000000 fffffc08`00000001 ffffad8e`1de69320 : nt!CcPurgeAndClearCacheSection+0x6f
fffffc08`6b33de00 fffff804`1a28d86f     : 00000000`00000000 00000000`00000000 ffffad8e`1c56fd18 ffffad8e`079ebd20 : nt!CcSetFileSizesEx+0x1ed
fffffc08`6b33deb0 fffff804`1a368c40     : 00000000`0000f244 00000000`03a7325a 00000000`00000000 fffffc08`6b33df01 : Ntfs!NtfsSetBothCacheSizes+0x63
fffffc08`6b33df20 fffff804`1a3c7d82     : ffffad8e`2708c888 ffffad8e`1ee6cee0 ffffe009`f0beb700 00000000`00000000 : Ntfs!NtfsDeleteAllocation+0x2c8
fffffc08`6b33e010 fffff804`1a38db26     : ffffad8e`2708c888 ffffad8e`1db63e78 ffffe009`f0beb5a0 ffffe009`f0beb700 : Ntfs!NtfsReplaceAttribute+0x35a
fffffc08`6b33e110 fffff804`1a37f269     : 00000000`00000000 ffffad8e`1db63a90 ffffe009`f0beba00 ffffe009`f0beb500 : Ntfs!NtfsOverwriteAttr+0x10f6
fffffc08`6b33e2f0 fffff804`1a37da6c     : ffffad8e`2708c888 ffffe009`f0beba00 ffffe009`f0beb5a0 fffffc08`6b33e5b0 : Ntfs!NtfsOpenAttributeInExistingFile+0xc99
fffffc08`6b33e520 fffff804`1a35e762     : ffffad8e`2708c888 ffffad8e`106cb540 ffffe009`e050e7c0 ffffad8e`106caa05 : Ntfs!NtfsOpenExistingPrefixFcb+0x5ac
fffffc08`6b33e660 fffff804`1a35fa0d     : ffffad8e`2708c888 ffffad8e`1db63a90 00000000`f726ffff fffffc08`6b33e910 : Ntfs!NtfsFindStartingNode+0xfd2
fffffc08`6b33e730 fffff804`1a35af00     : 00000000`00000000 fffffc08`6b33eb46 fffffc08`6b33ebb8 ffffad8e`1034bd80 : Ntfs!NtfsCommonCreate+0x11dd
fffffc08`6b33e9f0 fffff804`168ec015     : ffffad8e`106ca030 ffffad8e`1db63a90 fffffc08`6b33ed00 ffffad8e`1ee675d0 : Ntfs!NtfsFsdCreate+0x200
fffffc08`6b33ec70 fffff804`13dfa1db     : ffffad8e`1db63a90 ffffad8e`1bacb5c0 fffffc08`6b33ed69 fffff804`13df90a1 : nt!IofCallDriver+0x55
fffffc08`6b33ecb0 fffff804`13e31f83     : fffffc08`6b33ed60 fffffc08`6b339000 ffffad8e`1034bd00 fffff804`16cf8ce3 : FLTMGR!FltpLegacyProcessingAfterPreCallbacksCompleted+0x15b
fffffc08`6b33ed20 fffff804`168ec015     : ffffad8e`1e484700 ffffad8e`1064ec40 00000000`00000000 00000000`00000000 : FLTMGR!FltpCreate+0x323
fffffc08`6b33edd0 fffff804`16cf754e     : ffffad8e`1064ec40 fffffc08`6b33f0e0 ffffad8e`1db63a90 ffffad8e`1ee675d0 : nt!IofCallDriver+0x55
fffffc08`6b33ee10 fffff804`16cf1f61     : fffffc08`6b33f208 ffffe009`dfe43e50 ffffad8e`1ee675d0 fffffc08`6b33f200 : nt!IopParseDevice+0x8be
fffffc08`6b33efe0 fffff804`16cf1232     : ffffad8e`1de79001 fffffc08`6b33f200 00000000`00000042 ffffad8e`07a497a0 : nt!ObpLookupObjectName+0x7e1
fffffc08`6b33f170 fffff804`16ceecc1     : 00000000`00000000 ffffad8e`1e4847e0 00000000`02e0e950 ffffad8e`1e4847f8 : nt!ObOpenObjectByNameEx+0x1f2
fffffc08`6b33f2a0 fffff804`16cee5b9     : 00000000`02e0e088 00000000`00000000 00000000`02e0e950 00000000`02e0e0a0 : nt!IopCreateFile+0x431
fffffc08`6b33f360 fffff804`16a2b6e8     : 00000000`76fb4770 00000000`02f0e634 00000000`02e0fda0 00000000`0046d000 : nt!NtCreateFile+0x79
fffffc08`6b33f3f0 00007ffd`67b8fe14     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x28
00000000`02e0e018 00000000`00000000     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ffd`67b8fe14
SYMBOL_NAME:  nt!MmPurgeSection+2bb
MODULE_NAME: nt
BUCKET_ID_FUNC_OFFSET:  2bb
FAILURE_BUCKET_ID:  AV_nt!MmPurgeSection
OSNAME:  Windows 10
FAILURE_ID_HASH:  {49ee7632-0167-6256-d052-16dfb3547071}
Arguments:
Arg1: 0000000000000010, memory referenced
Arg4: fffff80610e1eaac, address which referenced memory
Debugging Details:
    Value: 2530
    Value: 4387
    Value: 3
    Value: 1
    Value: 15
    Value: 937
    Value: 104937
    Value: 93
    Value: 0xa
    Value: 808
    Value: 1
    Value: AV_nt!MiInsertPageInFreeOrZeroedList
    Key  : Failure.Hash
    Value: {779c7427-9286-2607-95ab-7b33d42c5f3a}
    Value: 1497cf94
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 4853999
    Value: 4a10ef
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 1015
    Value: 3f7
BUGCHECK_CODE:  a
BUGCHECK_P1: 10
BUGCHECK_P2: 2
BUGCHECK_P3: 0
BUGCHECK_P4: fffff80610e1eaac
FILE_IN_CAB:  120223-13593-01.dmp
READ_ADDRESS: fffff8061191d470: Unable to get MiVisibleState
 0000000000000010
PROCESS_NAME:  RiotClientServ
TRAP_FRAME:  ffff848852f66600 -- (.trap 0xffff848852f66600)
rax=0000000000000046 rbx=0000000000000000 rcx=0000000000000008
rip=fffff80610e1eaac rsp=ffff848852f66790 rbp=ffff848852f669e0
 r8=0000000000000055  r9=fffff8061186ef28 r10=0000000000000000
r11=000000000000008e r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei pl zr ac po nc
nt!MiInsertPageInFreeOrZeroedList+0x8cc:
fffff806`10e1eaac 48035610        add     rdx,qword ptr [rsi+10h] ds:00000000`00000010=????????????????
STACK_TEXT:
ffff8488`52f664b8 fffff806`1102bfa9     : 00000000`0000000a 00000000`00000010 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
ffff8488`52f664c0 fffff806`11027634     : fffffe00`00151be8 fffff806`10e21870 fffffe7f`00000aa8 ffffe607`176d4740 : nt!KiBugCheckDispatch+0x69
ffff8488`52f66600 fffff806`10e1eaac     : aaaaaaaa`aaaaaaab ffff8980`12f1fae0 ffff8488`52f669e0 fffff806`1186b000 : nt!KiPageFault+0x474
ffff8488`52f66790 fffff806`10e20167     : 00000000`0000aa8e fffff806`10e4fdd0 00000000`00000001 00000000`00000001 : nt!MiInsertPageInFreeOrZeroedList+0x8cc
ffff8488`52f668e0 fffff806`10e4f638     : fffffe00`00176000 ffff8488`52f66ee0 fffffe00`00175ff8 ffff8488`52f66ee0 : nt!MiDeletePteRun+0x507
ffff8488`52f66ad0 fffff806`10e8a769     : ffff8488`52f66ee0 fffffe00`00175ff8 00000000`00000000 ffffe607`176d4740 : nt!MiDeleteVaTail+0x48
ffff8488`52f66b00 fffff806`10e8a8aa     : ffff8488`00000000 ffffe607`176d4740 fffffe7f`00000000 ffff8488`52f66f30 : nt!MiWalkPageTablesRecursively+0x4e9
ffff8488`52f66b90 fffff806`10e8a8aa     : ffff8488`52f66ee0 ffffe607`176d4740 fffffe7f`00000000 ffff8488`52f66f40 : nt!MiWalkPageTablesRecursively+0x62a
ffff8488`52f66c20 fffff806`10e8a8aa     : ffff8488`52f66ee0 ffffe607`176d4740 fffffe7f`00000000 ffff8488`52f66f50 : nt!MiWalkPageTablesRecursively+0x62a
ffff8488`52f66cb0 fffff806`10e8a181     : 00000000`00000000 ffffe607`176d4740 00000000`00000000 ffff8488`52f66f60 : nt!MiWalkPageTablesRecursively+0x62a
ffff8488`52f66d40 fffff806`10e506e2     : ffff8488`52f66ee0 00000000`00000001 00000000`00000002 00000000`00000000 : nt!MiWalkPageTables+0x371
ffff8488`52f66e40 fffff806`10e4a67a     : ffffe607`176d4590 ffffe607`136e5080 ffff8488`52f671e0 ffffe607`136e5780 : nt!MiDeletePagablePteRange+0x3c2
ffff8488`52f67150 fffff806`112e5117     : 00000000`00000000 ffffe607`00000001 00000000`00000000 fffff806`10e6dae4 : nt!MiDeleteVirtualAddresses+0x4e
ffff8488`52f671a0 fffff806`10ec69b7     : 00000000`2ead0000 00000000`00000000 ffffe607`176d4740 00000000`00000000 : nt!MiDeleteVad+0x1b7
ffff8488`52f67260 fffff806`11309370     : 00000000`00000000 00000000`00000000 ffff8488`52f673c0 00000000`00000000 : nt!MiFreeVadRange+0xa3
ffff8488`52f672c0 fffff806`11308f85     : 00000000`77404770 00000000`1a28f574 00000000`0deafda0 00000000`00000000 : nt!MmFreeVirtualMemory+0x3b0
ffff8488`52f67400 fffff806`1102b6e8     : ffffe607`136e5080 00000000`00000000 00000000`00000000 00000000`00001b84 : nt!NtFreeVirtualMemory+0x95
ffff8488`52f67460 00007ffe`ad14f734     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x28
00000000`0deae648 00000000`00000000     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ffe`ad14f734
SYMBOL_NAME:  nt!MiInsertPageInFreeOrZeroedList+8cc
MODULE_NAME: nt
BUCKET_ID_FUNC_OFFSET:  8cc
FAILURE_BUCKET_ID:  AV_nt!MiInsertPageInFreeOrZeroedList
OSNAME:  Windows 10
FAILURE_ID_HASH:  {779c7427-9286-2607-95ab-7b33d42c5f3a}
PC aldığımdan beri RAM'ler yanyana takılıymış. BIOS güncelleyince ekrana hata olarak resim geliyordu, yer değiştir diye, yaptım. 2 Minecraft açtım uzun süre açıktı çökmedi ama bunu yapmadan önce 3080 takmıştım. Galiba sorun RAM'lerdi.
Güncelleme:
İşlemci kablosundan birisi yanlış mı ne takılmış.
İşlemci 10 derece fazla ısınıyormuş.
Güncelleme 2:
RAM'lerin yerini değiştirmeye rağmen sorun çözülmemiş. RAM'lerde arıza olması muhtemel.
Son güncelleme: RAM değişimi sonrası sorunun çözüldüğü doğrulandı.
Güncelleme:
Güncelleme 2:
