BIOS version: 1007 (2024/07/24)
Optimize graphics card compatibility
Intel ekran kartı sürücüsünde sorun gözüküyor. Driver Booster gibi 3. parti yazılım ile yüklediyseniz silmenizi ve Intel'in sitesinden indirebilirsiniz.
Olmazsa BIOS üzerinden ReSize BAR'ı aktif hale getirmeyi deneyin.
Sürücüleri silmek için DriverStoreExplorer kullanabilirsiniz.
PC'ye yeni format attım neden mavi ekran yedim.
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED (7e)
This is a very common BugCheck. Usually the exception address pinpoints
the driver/function that caused the problem. Always note this address
as well as the link date of the driver/image that contains this address.
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff800a4de1f71, The address that the exception occurred at
Arg3: ffffa58f84769618, Exception Record Address
Arg4: ffffa58f84768e50, Context Record Address
Debugging Details:
KEY_VALUES_STRING: 1
Key : AV.Fault
Value: Read
Key : Analysis.CPU.mSec
Value: 1078
Key : Analysis.Elapsed.mSec
Value: 6380
Key : Analysis.IO.Other.Mb
Value: 0
Key : Analysis.IO.Read.Mb
Value: 1
Key : Analysis.IO.Write.Mb
Value: 0
Key : Analysis.Init.CPU.mSec
Value: 359
Value: 1840
Value: 91
Key : Analysis.Version.DbgEng
Value: 10.0.27725.1000
Key : Analysis.Version.Description
Value: 10.2408.27.01 amd64fre
Key : Analysis.Version.Ext
Value: 1.2408.27.1
Key : Bugcheck.Code.LegacyAPI
Value: 0x1000007e
Key : Bugcheck.Code.TargetModel
Value: 0x1000007e
Key : Failure.Bucket
Value: AV_igdkmdnd64!unknown_function
Key : Failure.Hash
Value: {f72986a3-e8f9-3600-9d7c-dd8a40f557df}
Key : WER.OS.Branch
Value: vb_release
Key : WER.OS.Version
Value: 10.0.19041.1
BUGCHECK_CODE: 7e
BUGCHECK_P1: ffffffffc0000005
BUGCHECK_P2: fffff800a4de1f71
BUGCHECK_P3: ffffa58f84769618
BUGCHECK_P4: ffffa58f84768e50
FILE_IN_CAB: 012425-4890-01.dmp
FAULTING_THREAD: ffffcd8e93e84280
EXCEPTION_RECORD: ffffa58f84769618 -- (.exr 0xffffa58f84769618)
ExceptionAddress: fffff800a4de1f71 (igdkmdnd64+0x00000000004e1f71)
ExceptionCode: c0000005 (Access violation)
ExceptionFlags: 00000000
NumberParameters: 2
Parameter[0]: 0000000000000000
Parameter[1]: 000000c800000510
Attempt to read from address 000000c800000510
CONTEXT: ffffa58f84768e50 -- (.cxr 0xffffa58f84768e50)
rax=ffffd1263ef533f4 rbx=ffffa58f84769c88 rcx=ffffa58f84769c88
rdx=ffffcd8e92a6a000 rsi=ffffcd8e97c5a010 rdi=ffffcd8e92a6a000
rip=fffff800a4de1f71 rsp=ffffa58f84769850 rbp=ffffa58f84769c00
r8=000000c800000000 r9=0000000000000014 r10=000000c800000000
r11=c1ce000010000002 r12=ffffcd8e92419210 r13=ffffa58f8476a370
r14=ffffcd8e9cf6d010 r15=ffffcd8ea427a000
iopl=0 nv up ei pl zr na po nc
cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00050246
igdkmdnd64+0x4e1f71:
fffff800`a4de1f71 498b8810050000 mov rcx,qword ptr [r8+510h] ds:002b:000000c8`00000510=????????????????
Resetting default scope
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: System
READ_ADDRESS: fffff8007cafb390: Unable to get MiVisibleState
Unable to get NonPagedPoolStart
Unable to get NonPagedPoolEnd
Unable to get PagedPoolStart
Unable to get PagedPoolEnd
unable to get nt!MmSpecialPagesInUse
000000c800000510
ERROR_CODE: (NTSTATUS) 0xc0000005 - 0x%p adresindeki y nerge 0x%p adresindeki belle e ba vurdu. Bellek u olamaz %s.
EXCEPTION_CODE_STR: c0000005
EXCEPTION_PARAMETER1: 0000000000000000
EXCEPTION_PARAMETER2: 000000c800000510
EXCEPTION_STR: 0xc0000005
STACK_TEXT:
ffffa58f`84769850 00000008`675d8d9a : 00000000`00000004 ffffa58f`84769c88 ffffcd8e`92977010 00000000`00000001 : igdkmdnd64+0x4e1f71
ffffa58f`84769858 00000000`00000004 : ffffa58f`84769c88 ffffcd8e`92977010 00000000`00000001 00000000`00000001 : 0x00000008`675d8d9a
ffffa58f`84769860 ffffa58f`84769c88 : ffffcd8e`92977010 00000000`00000001 00000000`00000001 ffffa58f`8476a370 : 0x4
ffffa58f`84769868 ffffcd8e`92977010 : 00000000`00000001 00000000`00000001 ffffa58f`8476a370 00000000`00000000 : 0xffffa58f`84769c88
ffffa58f`84769870 00000000`00000001 : 00000000`00000001 ffffa58f`8476a370 00000000`00000000 00000000`00000002 : 0xffffcd8e`92977010
ffffa58f`84769878 00000000`00000001 : ffffa58f`8476a370 00000000`00000000 00000000`00000002 00000000`40000100 : 0x1
ffffa58f`84769880 ffffa58f`8476a370 : 00000000`00000000 00000000`00000002 00000000`40000100 00000000`00000001 : 0x1
ffffa58f`84769888 00000000`00000000 : 00000000`00000002 00000000`40000100 00000000`00000001 fffff800`a4bd09a5 : 0xffffa58f`8476a370
SYMBOL_NAME: igdkmdnd64+4e1f71
MODULE_NAME: igdkmdnd64
IMAGE_NAME: igdkmdnd64.sys
STACK_COMMAND: .cxr 0xffffa58f84768e50 ; kb
BUCKET_ID_FUNC_OFFSET: 4e1f71
FAILURE_BUCKET_ID: AV_igdkmdnd64!unknown_function
OS_VERSION: 10.0.19041.1
BUILDLAB_STR: vb_release
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {f72986a3-e8f9-3600-9d7c-dd8a40f557df}
Followup: MachineOwner
PnpActivityId : {00000000-0000-0000-0000-000000000000}
PnpActivityTime : 133822028758093636
PnpEventInformation: 3
PnpEventInProgress : 0
PnpProblemCode : 24
PnpVetoType : 0
DeviceId : USB\VID_258A&PID_0049\5&2c359f98&0&7
VetoString :
[SMBIOS Data Tables v3.6]
[DMI Version - 0]
[2.0 Calling Convention - No]
[Table Size - 4696 bytes]
Vendor American Megatrends International, LLC.
BIOS Version 1009
BIOS Release Date 09/20/2024
BIOS ROM Size 1000000
BIOS Characteristics
07: - PCI Supported
11: - Upgradeable FLASH BIOS
15: - CD-Boot Supported
17: - BIOS ROM Socketed
19: - EDD Supported
22: - 360KB Floppy Supported
23: - 1.2MB Floppy Supported
24: - 720KB Floppy Supported
25: - 2.88MB Floppy Supported
27: - Keyboard Services Supported
32: - BIOS Vendor Reserved
00: - ACPI Supported
01: - USB Legacy Supported
BIOS Major Revision 5
BIOS Minor Revision 27
EC Firmware Major Revision 255
EC Firmware Minor Revision 255
Extended BIOS ROM Size 16 MB
Manufacturer Colorful Technology And Development Co.,LTD
Product Name H610M-E M.2
Version Default string
Serial Number Default string
UUID 00000000-0000-0000-0000-000000000000
Wakeup Type Power Switch
SKUNumber Default string
Family Default string
Product H610M-E M.2
Version V20
Asset Tag
Feature Flags 09h
00: - Motherboard
03: - Replaceable
Location Default string
Chassis Handle 0003h
Board Type 0ah - Processor/Memory Module
Number of Child Handles 0
Chassis Type Desktop
Serial Number
Asset Tag Number
Bootup State Safe
Power Supply State Safe
Thermal State Safe
Security Status None
OEM Defined 0
Height 0U
Number of Power Cords 1
Number of Contained Elements 0
Contained Element Size 3
[Onboard Devices Information (Type 10) - Length 6 - Handle 0021h]
Note: The On Board Device Information (Type 10) struct is obsolete as of SMBIOs spec v2.6 Number of Devices 1
01: Type Video [enabled]
01: Description To Be Filled By O.E.M.
[OEM Strings (Type 11) - Length 5 - Handle 0022h]
Number of Strings 1
1 Default string
[System Configuration Options (Type 12) - Length 5 - Handle 0023h]
[ (Type 256) - Length 9 - Handle 003ah]
[Physical Memory Array (Type 16) - Length 23 - Handle 003bh]
Location 03h - SystemBoard/Motherboard
Use 03h - System Memory
Memory Error Correction 03h - None
Maximum Capacity 67108864KB
Memory Error Inf Handle [Not Provided]
Number of Memory Devices 2
[Memory Device (Type 17) - Length 92 - Handle 003ch]
Memory Error Info Handle [Not Provided]
Total Width 64 bits
Data Width 64 bits
Size 8192MB
Form Factor 09h - DIMM
Device Set [None]
Device Locator Controller0-ChannelA-DIMM0
Bank Locator BANK 0
Memory Type 1ah - DDR4
Type Detail 0080h - Synchronous
Speed 3200MHz
Manufacturer Apacer Technology
Serial Number
Asset Tag Number
Part Number GD2.1827CS.007
Attributes 1
Extended Size 0
Configured Memory Speed 3200
Minimum Voltage 1200
Maximum Voltage 1350
Configured Voltage 1350
Memory Technology 3
Memory Operating Mode Capability 8
Firmware Version 0
Module Manufacturer Id 31233
Module Product Id 0
Memory Subsystem Controller Manufacturer Id 0
Memory Subsystem Controller Product Id 0
Non-Volatile Size 0
Volatile Size 0
Cache Size 0
Logical Size 0
Extended Speed 0
Extended Configured Memory Speed 0
[Memory Device (Type 17) - Length 92 - Handle 003dh]
Total Width 64 bits
Data Width 64 bits
Size 8192MB
Device Set [None]
Device Locator Controller1-ChannelA-DIMM0
Bank Locator BANK 0
Speed 3200MHz
Serial Number
Asset Tag Number
Attributes 1
Extended Size 0
Memory Technology 3
Firmware Version 0
Module Product Id 0
Non-Volatile Size 0
Volatile Size 0
Cache Size 0
Logical Size 0
Extended Speed 0
[Memory Array Mapped Address (Type 19) - Length 31 - Handle 003eh]
Starting Address 00000000h
Ending Address 00ffffffh
Memory Array Handle 003bh
Partition Width 02
Extended Starting Address 0000000000000000h
Extended Ending Address 0000000000000000h
[ (Type 256) - Length 31 - Handle 003fh]
[ (Type 256) - Length 26 - Handle 0040h]
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 0041h]
Ending Address 007fffffh
Memory Device Handle 003ch
Mem Array Mapped Adr Handle 003eh
Partition Row Position [Unknown]
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 0042h]
Starting Address 00800000h
Memory Device Handle 003dh
[ (Type 256) - Length 12 - Handle 0043h]
[ (Type 256) - Length 26 - Handle 0044h]
[ (Type 256) - Length 26 - Handle 0045h]
[ (Type 256) - Length 47 - Handle 0046h]
[ (Type 256) - Length 82 - Handle 0047h]
[Cache Information (Type 7) - Length 27 - Handle 0048h]
Socket Designation L1 Cache
Cache Configuration 0180h - WBEnabled Int NonSocketed L1
Maximum Cache Size 00c0h - 192K
Installed Size 00c0h - 192K
Supported SRAM Type 0020h - Synchronous
Current SRAM Type 0020h - Synchronous
Cache Speed 0ns
Error Correction Type ParitySingle-Bit ECC
System Cache Type Data
Associativity 12-way Set-Associative
Maximum Cache Size 2 c0 - 00000192l Kb
Installed Cache Size 2 c0 - 00000192l Kb
[Cache Information (Type 7) - Length 27 - Handle 0049h]
Maximum Cache Size 0080h - 128K
Installed Size 0080h - 128K
Cache Speed 0ns
System Cache Type Instruction
Associativity 8-way Set-Associative
Maximum Cache Size 2 80 - 00000128l Kb
Installed Cache Size 2 80 - 00000128l Kb
[Cache Information (Type 7) - Length 27 - Handle 004ah]
Socket Designation L2 Cache
Cache Configuration 0181h - WBEnabled Int NonSocketed L2
Maximum Cache Size 1400h - 5120K
Installed Size 1400h - 5120K
Cache Speed 0ns
Error Correction Type Multi-Bit ECC
System Cache Type Unified
Associativity Other
Maximum Cache Size 2 1400 - 00005120l Kb
Installed Cache Size 2 1400 - 00005120l Kb
[Cache Information (Type 7) - Length 27 - Handle 004bh]
Socket Designation L3 Cache
Cache Configuration 0182h - WBEnabled Int NonSocketed L3
Maximum Cache Size 3000h - 12288K
Installed Size 3000h - 12288K
Cache Speed 0ns
Error Correction Type Specification Reserved
Maximum Cache Size 2 3000 - 00012288l Kb
Installed Cache Size 2 3000 - 00012288l Kb
[Processor Information (Type 4) - Length 48 - Handle 004ch]
Socket Designation U3E1
Processor Type Central Processor
Processor Family ceh - Intel Core 2 Extreme processor
Processor Manufacturer Intel(R) Corporation
Processor ID 75060900fffbebbf
Processor Version 12th Gen Intel(R) Core(TM) i3-12100F
Processor Voltage 8ah - 1.0V
External Clock 100MHz
Max Speed 4300MHz
Current Speed 4059MHz
Status Enabled Populated
Processor Upgrade Specification Reserved
L1 Cache Handle 0049h
L2 Cache Handle 004ah
L3 Cache Handle 004bh
Serial Number
Asset Tag Number
Part Number To Be Filled By O.E.M.
Core Count 4
Core Enabled 4
Thread Count 8
Processor Characteristics fc
Enabled Characteristics:
0x 2: 64-bit Capable
0x 3: Multi-Core
0x 4: Hardware Thread
0x 5: Execute Protection
0x 6: Enhanced Virtualization
Processor Family 2 00ceh - Intel Core 2 Extreme processor
Core Count 2 4
Core Enabled 2 4
Thread Count 2 8
[ (Type 256) - Length 64 - Handle 004dh]
[ (Type 256) - Length 11 - Handle 004eh]
[ (Type 256) - Length 11 - Handle 004fh]
[ (Type 256) - Length 11 - Handle 0050h]
[ (Type 256) - Length 11 - Handle 0051h]
[ (Type 256) - Length 11 - Handle 0052h]
[ (Type 256) - Length 11 - Handle 0053h]
[ (Type 256) - Length 11 - Handle 0054h]
[ (Type 256) - Length 11 - Handle 0055h]
[ (Type 256) - Length 11 - Handle 0056h]
[ (Type 256) - Length 11 - Handle 0057h]
[ (Type 256) - Length 11 - Handle 0058h]
[ (Type 256) - Length 82 - Handle 0059h]
[ (Type 256) - Length 44 - Handle 005ah]
[ (Type 256) - Length 8 - Handle 005bh]
[ (Type 256) - Length 106 - Handle 005eh]
[ (Type 256) - Length 6 - Handle 005fh]
[ (Type 256) - Length 4 - Handle 0061h]
Dün format attım PC'de 3. parti bir yazılım hiç kullanmadım.
Tahir bin BSoD, o gün mavi ekran hatalrının Windows kaynaklı olmadığını öğrenecekti.
Hatada gözüken igdkmdnd64.sys, Intel GPU sürücüsü oluyor. Güncel değilse güncelle. Bir de harici ekran kartın yok mu senin? Dahili GPU neden devrede?
Kod:SYSTEM_THREAD_EXCEPTION_NOT_HANDLED (7e) This is a very common BugCheck. Usually the exception address pinpoints. the driver/function that caused the problem. Always note this address. as well as the link date of the driver/image that contains this address. Arguments: Arg1: ffffffffc0000005, The exception code that was not handled. Arg2: fffff800a4de1f71, The address that the exception occurred at. Arg3: ffffa58f84769618, Exception Record Address. Arg4: ffffa58f84768e50, Context Record Address. Debugging Details: ------------------ KEY_VALUES_STRING: 1 Key : AV.Fault Value: Read. Key : Analysis.CPU.mSec Value: 1078. Key : Analysis.Elapsed.mSec Value: 6380. Key : Analysis.IO.Other.Mb Value: 0 Key : Analysis.IO.Read.Mb Value: 1 Key : Analysis.IO.Write.Mb Value: 0 Key : Analysis.Init.CPU.mSec Value: 359. Key : Analysis.Init.Elapsed.mSec Value: 1840. Key : Analysis.Memory.CommitPeak.Mb Value: 91. Key : Analysis.Version.DbgEng Value: 10.0.27725.1000 Key : Analysis.Version.Description Value: 10.2408.27.01 amd64fre. Key : Analysis.Version.Ext Value: 1.2408.27.1 Key : Bugcheck.Code.LegacyAPI Value: 0x1000007e. Key : Bugcheck.Code.TargetModel Value: 0x1000007e. Key : Failure.Bucket Value: AV_igdkmdnd64!unknown_function Key : Failure.Hash Value: {f72986a3-e8f9-3600-9d7c-dd8a40f557df} Key : WER.OS.Branch Value: vb_release. Key : WER.OS.Version Value: 10.0.19041.1 BUGCHECK_CODE: 7e. BUGCHECK_P1: ffffffffc0000005. BUGCHECK_P2: fffff800a4de1f71. BUGCHECK_P3: ffffa58f84769618. BUGCHECK_P4: ffffa58f84768e50. FILE_IN_CAB: 012425-4890-01.dmp FAULTING_THREAD: ffffcd8e93e84280. EXCEPTION_RECORD: ffffa58f84769618 -- (.exr 0xffffa58f84769618) ExceptionAddress: fffff800a4de1f71 (igdkmdnd64+0x00000000004e1f71) ExceptionCode: c0000005 (Access violation) ExceptionFlags: 00000000. NumberParameters: 2 Parameter[0]: 0000000000000000. Parameter[1]: 000000c800000510. Attempt to read from address 000000c800000510. CONTEXT: ffffa58f84768e50 -- (.cxr 0xffffa58f84768e50) rax=ffffd1263ef533f4 rbx=ffffa58f84769c88 rcx=ffffa58f84769c88 rdx=ffffcd8e92a6a000 rsi=ffffcd8e97c5a010 rdi=ffffcd8e92a6a000 rip=fffff800a4de1f71 rsp=ffffa58f84769850 rbp=ffffa58f84769c00 r8=000000c800000000 r9=0000000000000014 r10=000000c800000000 r11=c1ce000010000002 r12=ffffcd8e92419210 r13=ffffa58f8476a370 r14=ffffcd8e9cf6d010 r15=ffffcd8ea427a000 iopl=0 nv up ei pl zr na po nc. cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00050246 igdkmdnd64+0x4e1f71: fffff800`a4de1f71 498b8810050000 mov rcx,qword ptr [r8+510h] ds:002b:000000c8`00000510=???????????????? Resetting default scope. BLACKBOXBSD: 1 (!blackboxbsd) BLACKBOXNTFS: 1 (!blackboxntfs) BLACKBOXPNP: 1 (!blackboxpnp) BLACKBOXWINLOGON: 1 CUSTOMER_CRASH_COUNT: 1 PROCESS_NAME: System. READ_ADDRESS: fffff8007cafb390: Unable to get MiVisibleState. Unable to get NonPagedPoolStart. Unable to get NonPagedPoolEnd. Unable to get PagedPoolStart. Unable to get PagedPoolEnd. unable to get nt!MmSpecialPagesInUse 000000c800000510. ERROR_CODE: (NTSTATUS) 0xc0000005 - 0x%p adresindeki y nerge 0x%p adresindeki belle e ba vurdu. Bellek u olamaz %s. EXCEPTION_CODE_STR: c0000005. EXCEPTION_PARAMETER1: 0000000000000000. EXCEPTION_PARAMETER2: 000000c800000510. EXCEPTION_STR: 0xc0000005. STACK_TEXT: ffffa58f`84769850 00000008`675d8d9a : 00000000`00000004 ffffa58f`84769c88 ffffcd8e`92977010 00000000`00000001 : igdkmdnd64+0x4e1f71 ffffa58f`84769858 00000000`00000004 : ffffa58f`84769c88 ffffcd8e`92977010 00000000`00000001 00000000`00000001 : 0x00000008`675d8d9a ffffa58f`84769860 ffffa58f`84769c88 : ffffcd8e`92977010 00000000`00000001 00000000`00000001 ffffa58f`8476a370 : 0x4. ffffa58f`84769868 ffffcd8e`92977010 : 00000000`00000001 00000000`00000001 ffffa58f`8476a370 00000000`00000000 : 0xffffa58f`84769c88 ffffa58f`84769870 00000000`00000001 : 00000000`00000001 ffffa58f`8476a370 00000000`00000000 00000000`00000002 : 0xffffcd8e`92977010 ffffa58f`84769878 00000000`00000001 : ffffa58f`8476a370 00000000`00000000 00000000`00000002 00000000`40000100 : 0x1. ffffa58f`84769880 ffffa58f`8476a370 : 00000000`00000000 00000000`00000002 00000000`40000100 00000000`00000001 : 0x1. ffffa58f`84769888 00000000`00000000 : 00000000`00000002 00000000`40000100 00000000`00000001 fffff800`a4bd09a5 : 0xffffa58f`8476a370 SYMBOL_NAME: igdkmdnd64+4e1f71 MODULE_NAME: igdkmdnd64. IMAGE_NAME: igdkmdnd64.sys STACK_COMMAND: .cxr 0xffffa58f84768e50 ; kb. BUCKET_ID_FUNC_OFFSET: 4e1f71. FAILURE_BUCKET_ID: AV_igdkmdnd64!unknown_function OS_VERSION: 10.0.19041.1 BUILDLAB_STR: vb_release. OSPLATFORM_TYPE: x64. OSNAME: Windows 10. FAILURE_ID_HASH: {f72986a3-e8f9-3600-9d7c-dd8a40f557df} Followup: MachineOwner. --------- PnpActivityId : {00000000-0000-0000-0000-000000000000} PnpActivityTime : 133822028758093636. PnpEventInformation: 3 PnpEventInProgress : 0 PnpProblemCode : 24. PnpVetoType : 0 DeviceId : USB\VID_258A&PID_0049\5&2c359f98&0&7 VetoString : [SMBIOS Data Tables v3.6] [DMI Version - 0] [2.0 Calling Convention - No] [Table Size - 4696 bytes] [BIOS Information (Type 0) - Length 26 - Handle 0000h] Vendor American Megatrends International, LLC. BIOS Version 1009. BIOS Starting Address Segment f000. BIOS Release Date 09/20/2024 BIOS ROM Size 1000000. BIOS Characteristics. 07: - PCI Supported. 11: - Upgradeable FLASH BIOS. 12: - BIOS Shadowing Supported. 15: - CD-Boot Supported. 16: - Selectable Boot Supported. 17: - BIOS ROM Socketed. 19: - EDD Supported. 20: - NEC 9800 J-Floppy Supported. 21: - Toshiba J-Floppy Supported. 22: - 360KB Floppy Supported. 23: - 1.2MB Floppy Supported. 24: - 720KB Floppy Supported. 25: - 2.88MB Floppy Supported. 26: - Print Screen Device Supported. 27: - Keyboard Services Supported. 28: - Serial Services Supported. 29: - Printer Services Supported. 30: - CGA/Mono Services Supported. 32: - BIOS Vendor Reserved. BIOS Characteristic Extensions. 00: - ACPI Supported. 01: - USB Legacy Supported. 08: - BIOS Boot Specification Supported. 10: - Enable Targeted Content Distribution. 11: - UEFI Specification Supported. BIOS Major Revision 5 BIOS Minor Revision 27. EC Firmware Major Revision 255. EC Firmware Minor Revision 255. Extended BIOS ROM Size 16 MB. [System Information (Type 1) - Length 27 - Handle 0001h] Manufacturer Colorful Technology And Development Co.,LTD Product Name H610M-E M.2 Version Default string. Serial Number Default string. UUID 00000000-0000-0000-0000-000000000000 Wakeup Type Power Switch. SKUNumber Default string. Family Default string. [BaseBoard Information (Type 2) - Length 15 - Handle 0002h] Manufacturer Colorful Technology And Development Co.,LTD Product H610M-E M.2 Version V20. Serial Number Default string. Asset Tag. Feature Flags 09h. 00: - Motherboard. 03: - Replaceable. Location Default string. Chassis Handle 0003h. Board Type 0ah - Processor/Memory Module. Number of Child Handles 0 [System Enclosure (Type 3) - Length 22 - Handle 0003h] Manufacturer Colorful Technology And Development Co.,LTD Chassis Type Desktop. Version Default string. Serial Number. Asset Tag Number. Bootup State Safe. Power Supply State Safe. Thermal State Safe. Security Status None. OEM Defined 0 Height 0U. Number of Power Cords 1 Number of Contained Elements 0 Contained Element Size 3 [Onboard Devices Information (Type 10) - Length 6 - Handle 0021h] Note: The On Board Device Information (Type 10) struct is obsolete as of SMBIOs spec v2.6 Number of Devices 1 01: Type Video [enabled] 01: Description To Be Filled By O.E.M. [OEM Strings (Type 11) - Length 5 - Handle 0022h] Number of Strings 1 1 Default string. [System Configuration Options (Type 12) - Length 5 - Handle 0023h] [ (Type 256) - Length 9 - Handle 003ah] [Physical Memory Array (Type 16) - Length 23 - Handle 003bh] Location 03h - SystemBoard/Motherboard Use 03h - System Memory. Memory Error Correction 03h - None. Maximum Capacity 67108864KB. Memory Error Inf Handle [Not Provided] Number of Memory Devices 2 [Memory Device (Type 17) - Length 92 - Handle 003ch] Memory Error Info Handle [Not Provided] Total Width 64 bits. Data Width 64 bits. Size 8192MB. Form Factor 09h - DIMM. Device Set [None] Device Locator Controller0-ChannelA-DIMM0 Bank Locator BANK 0 Memory Type 1ah - DDR4. Type Detail 0080h - Synchronous. Speed 3200MHz. Manufacturer Apacer Technology. Serial Number. Asset Tag Number. Part Number GD2.1827CS.007 Attributes 1 Extended Size 0 Configured Memory Speed 3200. Minimum Voltage 1200. Maximum Voltage 1350. Configured Voltage 1350. Memory Technology 3 Memory Operating Mode Capability 8 Firmware Version 0 Module Manufacturer Id 31233. Module Product Id 0 Memory Subsystem Controller Manufacturer Id 0 Memory Subsystem Controller Product Id 0 Non-Volatile Size 0 Volatile Size 0 Cache Size 0 Logical Size 0 Extended Speed 0 Extended Configured Memory Speed 0 [Memory Device (Type 17) - Length 92 - Handle 003dh] Memory Error Info Handle [Not Provided] Total Width 64 bits. Data Width 64 bits. Size 8192MB. Form Factor 09h - DIMM. Device Set [None] Device Locator Controller1-ChannelA-DIMM0 Bank Locator BANK 0 Memory Type 1ah - DDR4. Type Detail 0080h - Synchronous. Speed 3200MHz. Manufacturer Apacer Technology. Serial Number. Asset Tag Number. Part Number GD2.1827CS.007 Attributes 1 Extended Size 0 Configured Memory Speed 3200. Minimum Voltage 1200. Maximum Voltage 1350. Configured Voltage 1350. Memory Technology 3 Memory Operating Mode Capability 8 Firmware Version 0 Module Manufacturer Id 31233. Module Product Id 0 Memory Subsystem Controller Manufacturer Id 0 Memory Subsystem Controller Product Id 0 Non-Volatile Size 0 Volatile Size 0 Cache Size 0 Logical Size 0 Extended Speed 0 Extended Configured Memory Speed 0 [Memory Array Mapped Address (Type 19) - Length 31 - Handle 003eh] Starting Address 00000000h. Ending Address 00ffffffh. Memory Array Handle 003bh. Partition Width 02. Extended Starting Address 0000000000000000h. Extended Ending Address 0000000000000000h. [ (Type 256) - Length 31 - Handle 003fh] [ (Type 256) - Length 26 - Handle 0040h] [Memory Device Mapped Address (Type 20) - Length 35 - Handle 0041h] Starting Address 00000000h. Ending Address 007fffffh. Memory Device Handle 003ch. Mem Array Mapped Adr Handle 003eh. Partition Row Position [Unknown] Extended Starting Address 0000000000000000h. Extended Ending Address 0000000000000000h. [Memory Device Mapped Address (Type 20) - Length 35 - Handle 0042h] Starting Address 00800000h. Ending Address 00ffffffh. Memory Device Handle 003dh. Mem Array Mapped Adr Handle 003eh. Partition Row Position [Unknown] Extended Starting Address 0000000000000000h. Extended Ending Address 0000000000000000h. [ (Type 256) - Length 12 - Handle 0043h] [ (Type 256) - Length 26 - Handle 0044h] [ (Type 256) - Length 26 - Handle 0045h] [ (Type 256) - Length 47 - Handle 0046h] [ (Type 256) - Length 82 - Handle 0047h] [Cache Information (Type 7) - Length 27 - Handle 0048h] Socket Designation L1 Cache. Cache Configuration 0180h - WBEnabled Int NonSocketed L1. Maximum Cache Size 00c0h - 192K. Installed Size 00c0h - 192K. Supported SRAM Type 0020h - Synchronous. Current SRAM Type 0020h - Synchronous. Cache Speed 0ns. Error Correction Type ParitySingle-Bit ECC. System Cache Type Data. Associativity 12-way Set-Associative Maximum Cache Size 2 c0 - 00000192l Kb. Installed Cache Size 2 c0 - 00000192l Kb. [Cache Information (Type 7) - Length 27 - Handle 0049h] Socket Designation L1 Cache. Cache Configuration 0180h - WBEnabled Int NonSocketed L1. Maximum Cache Size 0080h - 128K. Installed Size 0080h - 128K. Supported SRAM Type 0020h - Synchronous. Current SRAM Type 0020h - Synchronous. Cache Speed 0ns. Error Correction Type ParitySingle-Bit ECC. System Cache Type Instruction. Associativity 8-way Set-Associative Maximum Cache Size 2 80 - 00000128l Kb. Installed Cache Size 2 80 - 00000128l Kb. [Cache Information (Type 7) - Length 27 - Handle 004ah] Socket Designation L2 Cache. Cache Configuration 0181h - WBEnabled Int NonSocketed L2. Maximum Cache Size 1400h - 5120K. Installed Size 1400h - 5120K. Supported SRAM Type 0020h - Synchronous. Current SRAM Type 0020h - Synchronous. Cache Speed 0ns. Error Correction Type Multi-Bit ECC. System Cache Type Unified. Associativity Other. Maximum Cache Size 2 1400 - 00005120l Kb. Installed Cache Size 2 1400 - 00005120l Kb. [Cache Information (Type 7) - Length 27 - Handle 004bh] Socket Designation L3 Cache. Cache Configuration 0182h - WBEnabled Int NonSocketed L3. Maximum Cache Size 3000h - 12288K. Installed Size 3000h - 12288K. Supported SRAM Type 0020h - Synchronous. Current SRAM Type 0020h - Synchronous. Cache Speed 0ns. Error Correction Type Specification Reserved. System Cache Type Unified. Associativity 12-way Set-Associative Maximum Cache Size 2 3000 - 00012288l Kb. Installed Cache Size 2 3000 - 00012288l Kb. [Processor Information (Type 4) - Length 48 - Handle 004ch] Socket Designation U3E1. Processor Type Central Processor. Processor Family ceh - Intel Core 2 Extreme processor. Processor Manufacturer Intel(R) Corporation. Processor ID 75060900fffbebbf. Processor Version 12th Gen Intel(R) Core(TM) i3-12100F Processor Voltage 8ah - 1.0V External Clock 100MHz. Max Speed 4300MHz. Current Speed 4059MHz. Status Enabled Populated. Processor Upgrade Specification Reserved. L1 Cache Handle 0049h. L2 Cache Handle 004ah. L3 Cache Handle 004bh. Serial Number. Asset Tag Number. Part Number To Be Filled By O.E.M. Core Count 4 Core Enabled 4 Thread Count 8 Processor Characteristics fc. Enabled Characteristics: 0x 2: 64-bit Capable. 0x 3: Multi-Core 0x 4: Hardware Thread. 0x 5: Execute Protection. 0x 6: Enhanced Virtualization. 0x 7: Power/Performance Control. Processor Family 2 00ceh - Intel Core 2 Extreme processor. Core Count 2 4 Core Enabled 2 4 Thread Count 2 8 [ (Type 256) - Length 64 - Handle 004dh] [ (Type 256) - Length 11 - Handle 004eh] [ (Type 256) - Length 11 - Handle 004fh] [ (Type 256) - Length 11 - Handle 0050h] [ (Type 256) - Length 11 - Handle 0051h] [ (Type 256) - Length 11 - Handle 0052h] [ (Type 256) - Length 11 - Handle 0053h] [ (Type 256) - Length 11 - Handle 0054h] [ (Type 256) - Length 11 - Handle 0055h] [ (Type 256) - Length 11 - Handle 0056h] [ (Type 256) - Length 11 - Handle 0057h] [ (Type 256) - Length 11 - Handle 0058h] [ (Type 256) - Length 82 - Handle 0059h] [ (Type 256) - Length 44 - Handle 005ah] [ (Type 256) - Length 8 - Handle 005bh] [ (Type 256) - Length 106 - Handle 005eh] [ (Type 256) - Length 6 - Handle 005fh] [ (Type 256) - Length 4 - Handle 0061h]
İşler gittikçe ilginç bir hal alıyor.Recep abi dahili bir GPU olamaz çünkü CPU i3 12100F. Bilmediğim bir GPU varsa söyleyin.
We use cookies and similar technologies for the following purposes:
Do you accept cookies and these technologies?
