Çözüldü SYSTEM_THREAD_EXCEPTION_NOT_HANDLED (7e) hatası
Zagii
Üyecik
29 Ocak 2025
Merhaba Techolay Ailesi;
Masaüstünde gezinirken bir anda mavi ekran hatası aldım. Sizinle dmp dosyasını paylaşıyorum. Sorunu ve çözümü sabırsızlıkla bekliyorum.
Şimdiden teşekkür ederim.
  • AMD Ryzen 7 5700X3D
  • Intel Arc A750 8GB
  • 32 GB GSKILL RIPJAWS RAM BELLEK
  • MPG B550 GAMING PLUS ANAKART
  • MLD M300 500GB M2.SDD
  • MSI MAG A650BN 650W
Net bir sebep yazmıyor dosyada ama BIOS sürümünüz güncel değil, güncelleyin.
Kod:
This is a very common BugCheck.  Usually the exception address pinpoints
the driver/function that caused the problem.  Always note this address
as well as the link date of the driver/image that contains this address.
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff8053632d8bf, The address that the exception occurred at
Arg3: ffff8005d7926ef8, Exception Record Address
Arg4: ffff8005d7926730, Context Record Address
Debugging Details:
KEY_VALUES_STRING: 1
    Key  : AV.Fault
    Value: Read
    Key  : Analysis.CPU.mSec
    Value: 921
    Key  : Analysis.Elapsed.mSec
    Value: 1006
    Key  : Analysis.IO.Other.Mb
    Value: 0
    Key  : Analysis.IO.Read.Mb
    Value: 1
    Key  : Analysis.IO.Write.Mb
    Value: 4
    Key  : Analysis.Init.CPU.mSec
    Value: 406
    Value: 6070
    Value: 105
    Value: 10.0.27725.1000
    Value: 10.2408.27.01 amd64fre
    Key  : Analysis.Version.Ext
    Value: 1.2408.27.1
    Value: 0x1000007e
    Value: 0x1000007e
    Value: 8
    Value: 1
    Key  : Failure.Bucket
    Value: AV_nt!FsRtlLookupBaseMcbEntry
    Key  : Failure.Hash
    Value: {a6fb2adc-1696-0a96-5e9c-56e4bea1c770}
BUGCHECK_CODE:  7e
BUGCHECK_P1: ffffffffc0000005
BUGCHECK_P2: fffff8053632d8bf
BUGCHECK_P3: ffff8005d7926ef8
BUGCHECK_P4: ffff8005d7926730
FILE_IN_CAB:  012925-5125-01.dmp
DUMP_FILE_ATTRIBUTES: 0x8
  Kernel Generated Triage Dump
FAULTING_THREAD:  ffffd50f736f3040
EXCEPTION_RECORD:  ffff8005d7926ef8 -- (.exr 0xffff8005d7926ef8)
ExceptionAddress: fffff8053632d8bf (nt!FsRtlLookupBaseMcbEntry+0x000000000000004f)
   ExceptionCode: c0000005 (Access violation)
  ExceptionFlags: 00000000
NumberParameters: 2
   Parameter[0]: 0000000000000000
   Parameter[1]: ffffffffffffffff
Attempt to read from address ffffffffffffffff
CONTEXT:  ffff8005d7926730 -- (.cxr 0xffff8005d7926730)
rax=0000000000000000 rbx=0000000000000000 rcx=0000000000000000
rdx=0000000000000000 rsi=0000000000000000 rdi=ffff9c80c6fd42d8
rip=fffff8053632d8bf rsp=ffff8005d7927138 rbp=0000000000000000
 r8=ffff8005d7927310  r9=0000000000000000 r10=ff7f9c80a233c980
r11=0000000000000000 r12=0000000000000000 r13=0000000000000000
r14=ffff8005d7927308 r15=ffff8005d7927310
iopl=0         nv up ei pl zr ac po nc
cs=0010  ss=0000  ds=002b  es=002b  fs=0053  gs=002b             efl=00050256
nt!FsRtlLookupBaseMcbEntry+0x4f:
fffff805`3632d8bf 418b14ca        mov     edx,dword ptr [r10+rcx*8] ds:002b:ff7f9c80`a233c980=????????
Resetting default scope
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  System
READ_ADDRESS: fffff80536cfb390: Unable to get MiVisibleState
Unable to get NonPagedPoolStart
Unable to get NonPagedPoolEnd
Unable to get PagedPoolStart
Unable to get PagedPoolEnd
unable to get nt!MmSpecialPagesInUse
 ffffffffffffffff
ERROR_CODE: (NTSTATUS) 0xc0000005 - 0x%p adresindeki y nerge 0x%p adresindeki belle e ba vurdu. Bellek  u olamaz %s.
EXCEPTION_CODE_STR:  c0000005
EXCEPTION_PARAMETER1:  0000000000000000
EXCEPTION_PARAMETER2:  ffffffffffffffff
EXCEPTION_STR:  0xc0000005
STACK_TEXT:
ffff8005`d7927138 fffff805`387fc277     : ffff9c80`c6fd42b0 00000000`00000000 00000000`00000000 00000000`00000000 : nt!FsRtlLookupBaseMcbEntry+0x4f
ffff8005`d7927150 fffff805`388fa571     : ffffd50f`6a4bd5a8 00000000`969ef960 ffff8005`d7927310 ffff8005`d7927308 : Ntfs!NtfsLookupNtfsMcbEntryWithSyncFlag+0xe7
ffff8005`d79271e0 fffff805`388df5d2     : 00000000`00000000 00000000`00000000 ffffd50f`6a4bd100 fffff805`388e1c00 : Ntfs!NtfsCheckpointVolume+0x1741
ffff8005`d79276f0 fffff805`388ddbac     : ffff8005`d7927890 ffffd50f`6a4bd180 ffff8005`d7927840 01db71ec`116d7b01 : Ntfs!NtfsCheckpointAllVolumesWorker+0xe2
ffff8005`d7927750 fffff805`388dd01b     : ffff8005`d7927890 00000000`00000000 00000000`00000000 fffff805`388df4f0 : Ntfs!NtfsForEachVcb+0x200
ffff8005`d7927800 fffff805`362171c5     : ffffd50f`736f3040 ffffd50f`736f3040 fffff805`38884cd0 00000000`00000000 : Ntfs!NtfsCheckpointAllVolumes+0x21b
ffff8005`d7927b30 fffff805`3635a165     : ffffd50f`736f3040 00000000`00000080 ffffd50f`646c1080 ffffffff`00000000 : nt!ExpWorkerThread+0x105
ffff8005`d7927bd0 fffff805`364078f8     : ffffbe81`912c0180 ffffd50f`736f3040 fffff805`3635a110 ffffffff`00000000 : nt!PspSystemThreadStartup+0x55
ffff8005`d7927c20 00000000`00000000     : ffff8005`d7928000 ffff8005`d7921000 00000000`00000000 00000000`00000000 : nt!KiStartSystemThread+0x28
SYMBOL_NAME:  nt!FsRtlLookupBaseMcbEntry+4f
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
IMAGE_VERSION:  10.0.19041.5369
STACK_COMMAND:  .cxr 0xffff8005d7926730 ; kb
BUCKET_ID_FUNC_OFFSET:  4f
FAILURE_BUCKET_ID:  AV_nt!FsRtlLookupBaseMcbEntry
OSPLATFORM_TYPE:  x64
OSNAME:  Windows 10
FAILURE_ID_HASH:  {a6fb2adc-1696-0a96-5e9c-56e4bea1c770}
Followup:     MachineOwner
[SMBIOS Data Tables v2.8]
[DMI Version - 0]
[2.0 Calling Convention - No]
[Table Size - 2646 bytes]
  Vendor                        American Megatrends International, LLC.
  BIOS Version                  1.I0
  BIOS Release Date             07/13/2024
  BIOS ROM Size                 1000000
  BIOS Characteristics
       07: - PCI Supported
       11: - Upgradeable FLASH BIOS
       15: - CD-Boot Supported
       17: - BIOS ROM Socketed
       19: - EDD Supported
       22: - 360KB Floppy Supported
       23: - 1.2MB Floppy Supported
       24: - 720KB Floppy Supported
       25: - 2.88MB Floppy Supported
       27: - Keyboard Services Supported
       32: - BIOS Vendor Reserved
       01: - USB Legacy Supported
  BIOS Major Revision           5
  BIOS Minor Revision           17
  EC Firmware Major Revision    255
  EC Firmware Minor Revision    255
  Extended BIOS ROM Size        32 MB
  Manufacturer                  Micro-Star International Co., Ltd.
  Product Name                  MS-7C56
  Version                       1.0
  Serial Number                 To be filled by O.E.M.
  SKUNumber                     To be filled by O.E.M.
  Family                        To be filled by O.E.M.
  Product                       MPG B550 GAMING PLUS (MS-7C56)
  Version                       1.0
  Serial Number                 07C5613_NC1E469812
  Asset Tag
       00: - Motherboard
       03: - Replaceable
  Location                      To be filled by O.E.M.
  Chassis Type                  Desktop
  Version                       1.0
  Serial Number
  Asset Tag Number
  Contained Element Size        3
[OEM Strings (Type 11) - Length 5 - Handle 000bh]
  Number of Strings             1
   1                            To be filled by O.E.M.
[System Configuration Options (Type 12) - Length 5 - Handle 000ch]
[ (Type 256) - Length 9 - Handle 000eh]
[ (Type 256) - Length 31 - Handle 000fh]
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 0010h]
[Physical Memory Array (Type 16) - Length 23 - Handle 0011h]
  Maximum Capacity              134217728KB
  Memory Error Inf Handle       0010h
  Number of Memory Devices      4
[Memory Array Mapped Address (Type 19) - Length 31 - Handle 0012h]
  Ending Address                0037ffffh
  Memory Array Handle           0011h
[Memory Array Mapped Address (Type 19) - Length 31 - Handle 0013h]
  Starting Address              00400000h
  Ending Address                0207ffffh
[Cache Information (Type 7) - Length 19 - Handle 0014h]
  Socket Designation            L1 - Cache
  Maximum Cache Size            0200h - 512K
  Installed Size                0200h - 512K
  Supported SRAM Type           0010h - Pipeline-Burst
  Current SRAM Type             0010h - Pipeline-Burst
  Cache Speed                   1ns
  Maximum Cache Size 2          2d20314c - 757084492l Kb
[Cache Information (Type 7) - Length 19 - Handle 0015h]
  Socket Designation            L2 - Cache
  Maximum Cache Size            1000h - 4096K
  Installed Size                1000h - 4096K
  Cache Speed                   1ns
  Maximum Cache Size 2          2d20324c - 757084748l Kb
[Cache Information (Type 7) - Length 19 - Handle 0016h]
  Socket Designation            L3 - Cache
  Maximum Cache Size            8600h - 98304K
  Installed Size                8600h - 98304K
  Cache Speed                   1ns
  Associativity                 16-way Set-Associative
  Maximum Cache Size 2          2d20334c - 757085004l Kb
[Processor Information (Type 4) - Length 48 - Handle 0017h]
  Socket Designation            AM4
  Processor Family              6bh - AMD Zen Processor Family
  Processor Manufacturer        Advanced Micro Devices, Inc.
  Processor ID                   120fa200fffb8b17
  Processor Version             AMD Ryzen 7 5700X3D 8-Core Processor
  Processor Voltage             8bh - 1.1V
  Max Speed                     3400MHz
  Current Speed                 3000MHz
  Processor Upgrade             Socket AM4
  L1 Cache Handle               0014h
  L2 Cache Handle               0015h
  L3 Cache Handle               0016h
  Serial Number
  Asset Tag Number
  Part Number                   Unknown
  Core Count                    8
  Core Enabled                  8
  Thread Count                  16
  Processor Characteristics     fc
  Enabled Characteristics:
       0x 2: 64-bit Capable
       0x 3: Multi-Core
       0x 4: Hardware Thread
       0x 5: Execute Protection
       0x 6: Enhanced Virtualization
  Processor Family 2            006bh - AMD Zen Processor Family
  Core Count 2                  8
  Core Enabled 2                8
  Thread Count 2                16
Kod:
Arguments:
Debugging Details:
    Key  : AV.Fault
    Value: Read
    Value: 921
    Value: 1006
    Value: 0
    Value: 1
    Value: 4
    Value: 406
    Value: 6070
    Value: 105
    Value: 1.2408.27.1
    Value: 0x1000007e
    Value: 0x1000007e
    Value: 8
    Value: 1
    Key  : Failure.Hash
BUGCHECK_CODE:  7e
NumberParameters: 2
BLACKBOXWINLOGON: 1
 ffffffffffffffff
STACK_TEXT:
MODULE_NAME: nt
OSNAME:  Windows 10
[DMI Version - 0]
  BIOS Version                  1.I0
       07: - PCI Supported
       19: - EDD Supported
  Version                       1.0
  Version                       1.0
  Asset Tag
       00: - Motherboard
       03: - Replaceable
  Version                       1.0
  Serial Number
  Asset Tag Number
  Number of Strings             1
  Cache Speed                   1ns
  Cache Speed                   1ns
  Cache Speed                   1ns
  Max Speed                     3400MHz
  Serial Number
  Asset Tag Number
  Part Number                   Unknown
  Core Count                    8
  Core Enabled                  8
  Thread Count                  16
       0x 3: Multi-Core
  Core Count 2                  8
  Core Enabled 2                8
  Thread Count 2                16
MSI anakart modelinin son BIOS sürümü (Beta version) 2024-09-05 olduğu için indirme yapmadım. İlk defa bu belirttiğim sistemde mavi ekran hatası aldım. Son olarak eklemek istiyorum: MSI, AMD'nin yeni chipset driver sürücüsünü sürdü (7.01.08.129), bu sürücüyü de indirmedim. Endişelenecek bir durum yok gibi sanırım. Cevabınız için teşekkür ederim Recep Bey. İyi Sosyaller
