Çözüldü Tom Clancy's Rainbow Six: Siege açılırken bilgisayar mavi ekran veriyor
21 Aralık 2023
Ankara
Tom Clancy's Rainbow Six: Siege açılırken bilgisayar mavi ekran veriyor. Bugüne kadar hiçbir şeyi yoktu, hatta 2 saat önce oynadım ama şimdi başlatılırken bilgisayar mavi ekran veriyor, başka hiçbir oyunda ya da programda olmuyor. Sebebi nedir?
Sorununuzun BattlEye anti-cheat yazılımından kaynaklandığı gözüküyor.
Kod:
KERNEL_MODE_HEAP_CORRUPTION (13a)
The kernel mode heap manager has detected corruption in a heap.
Arguments:
Arg1: 0000000000000011, Type of corruption detected
Arg2: ffffa682c0010140, Address of the heap that reported the corruption
Arg3: ffffa682d03cb770, Address at which the corruption was detected
Arg4: 0000000000000000
Debugging Details:
fffff8035651c470: Unable to get MiVisibleState
Unable to get NonPagedPoolStart
Unable to get NonPagedPoolEnd
Unable to get PagedPoolStart
Unable to get PagedPoolEnd
HeapDbgInitExtension Failed
KEY_VALUES_STRING: 1
    Key  : Analysis.CPU.mSec
    Value: 3734
    Key  : Analysis.Elapsed.mSec
    Value: 6310
    Key  : Analysis.IO.Other.Mb
    Value: 0
    Key  : Analysis.IO.Read.Mb
    Value: 0
    Key  : Analysis.IO.Write.Mb
    Value: 0
    Key  : Analysis.Init.CPU.mSec
    Value: 218
    Value: 3305
    Value: 100
    Value: 0x13a
    Value: 0x13a
    Value: 1808
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Key  : Failure.Bucket
    Value: 0x13a_11_BE___BEDaisy!unknown_function
    Key  : Failure.Hash
    Value: {6a85b8ad-f8a7-b71c-b9d1-e9d62252af2e}
    Key  : Hypervisor.Enlightenments.ValueHex
    Value: 1417df84
    Key  : Hypervisor.Flags.AnyHypervisorPresent
    Value: 1
    Key  : Hypervisor.Flags.ApicEnlightened
    Value: 0
    Key  : Hypervisor.Flags.ApicVirtualizationAvailable
    Value: 1
    Key  : Hypervisor.Flags.AsyncMemoryHint
    Value: 0
    Key  : Hypervisor.Flags.CoreSchedulerRequested
    Value: 0
    Key  : Hypervisor.Flags.CpuManager
    Value: 1
    Key  : Hypervisor.Flags.DeprecateAutoEoi
    Value: 1
    Key  : Hypervisor.Flags.DynamicCpuDisabled
    Value: 1
    Key  : Hypervisor.Flags.Epf
    Value: 0
    Key  : Hypervisor.Flags.ExtendedProcessorMasks
    Value: 1
    Key  : Hypervisor.Flags.HardwareMbecAvailable
    Value: 1
    Key  : Hypervisor.Flags.MaxBankNumber
    Value: 0
    Key  : Hypervisor.Flags.MemoryZeroingControl
    Value: 0
    Key  : Hypervisor.Flags.NoExtendedRangeFlush
    Value: 0
    Key  : Hypervisor.Flags.NoNonArchCoreSharing
    Value: 1
    Key  : Hypervisor.Flags.Phase0InitDone
    Value: 1
    Key  : Hypervisor.Flags.PowerSchedulerQos
    Value: 0
    Key  : Hypervisor.Flags.RootScheduler
    Value: 0
    Key  : Hypervisor.Flags.SynicAvailable
    Value: 1
    Key  : Hypervisor.Flags.UseQpcBias
    Value: 0
    Key  : Hypervisor.Flags.Value
    Value: 21631230
    Key  : Hypervisor.Flags.ValueHex
    Value: 14a10fe
    Key  : Hypervisor.Flags.VpAssistPage
    Value: 1
    Key  : Hypervisor.Flags.VsmAvailable
    Value: 1
    Key  : Hypervisor.RootFlags.AccessStats
    Value: 1
    Key  : Hypervisor.RootFlags.CrashdumpEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.CreateVirtualProcessor
    Value: 1
    Key  : Hypervisor.RootFlags.DisableHyperthreading
    Value: 0
    Key  : Hypervisor.RootFlags.HostTimelineSync
    Value: 1
    Key  : Hypervisor.RootFlags.HypervisorDebuggingEnabled
    Value: 0
    Key  : Hypervisor.RootFlags.IsHyperV
    Value: 1
    Key  : Hypervisor.RootFlags.LivedumpEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.MapDeviceInterrupt
    Value: 1
    Key  : Hypervisor.RootFlags.MceEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.Nested
    Value: 0
    Key  : Hypervisor.RootFlags.StartLogicalProcessor
    Value: 1
    Key  : Hypervisor.RootFlags.Value
    Value: 1015
    Key  : Hypervisor.RootFlags.ValueHex
    Value: 3f7
BUGCHECK_CODE:  13a
BUGCHECK_P1: 11
BUGCHECK_P2: ffffa682c0010140
BUGCHECK_P3: ffffa682d03cb770
BUGCHECK_P4: 0
FILE_IN_CAB:  030524-15750-01.dmp
TAG_NOT_DEFINED_202b:  *** Unknown TAG in analysis list 202b
DUMP_FILE_ATTRIBUTES: 0x1808
  Kernel Generated Triage Dump
POOL_ADDRESS: Unable to get NonPagedPoolStart
unable to get nt!MmSpecialPagesInUse
 ffffa682d03cb770
FREED_POOL_TAG:  BE__
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  RainbowSix.exe
STACK_TEXT:
ffffa50d`5cbf6888 fffff803`55db2954     : 00000000`0000013a 00000000`00000011 ffffa682`c0010140 ffffa682`d03cb770 : nt!KeBugCheckEx
ffffa50d`5cbf6890 fffff803`55db29b4     : 00000000`00000011 00000000`00000000 ffffa682`c0010140 ffffa682`e17a04d8 : nt!RtlpHeapHandleError+0x40
ffffa50d`5cbf68d0 fffff803`55db25d1     : 00000000`00f00030 ffffffff`ffffffff 00000000`00000000 ffffa682`e17a0080 : nt!RtlpHpHeapHandleError+0x58
ffffa50d`5cbf6900 fffff803`55cad59e     : ffffa50d`5cbf6b80 ffffa682`e17a0080 ffffa50d`5cbf6b80 00000000`00000002 : nt!RtlpLogHeapFailure+0x45
ffffa50d`5cbf6930 fffff803`55a7f219     : ffffa682`c0010380 00000000`000000ff ffff50f0`9a845b3c 00010001`00000000 : nt!RtlpHpLfhSubsegmentFreeBlock+0x1b31ce
ffffa50d`5cbf69c0 fffff803`562ac2b0     : ffffa682`d03cb770 00000000`00000002 00000000`ffffff8d 00000000`00000001 : nt!RtlpHpFreeHeap+0x159
ffffa50d`5cbf6a60 fffff803`d217d2d6     : ffffa50d`00004542 ffff800b`9c986240 ffff50f0`00000002 00000000`00000030 : nt!ExFreePoolWithTag+0x1a0
ffffa50d`5cbf6af0 ffffa50d`00004542     : ffff800b`9c986240 ffff50f0`00000002 00000000`00000030 00000000`00000000 : BEDaisy+0x4bd2d6
ffffa50d`5cbf6af8 ffff800b`9c986240     : ffff50f0`00000002 00000000`00000030 00000000`00000000 ffffa682`d3b38e10 : 0xffffa50d`00004542
ffffa50d`5cbf6b00 ffff50f0`00000002     : 00000000`00000030 00000000`00000000 ffffa682`d3b38e10 00000000`00000010 : 0xffff800b`9c986240
ffffa50d`5cbf6b08 00000000`00000030     : 00000000`00000000 ffffa682`d3b38e10 00000000`00000010 ffffa682`ccf749a0 : 0xffff50f0`00000002
ffffa50d`5cbf6b10 00000000`00000000     : ffffa682`d3b38e10 00000000`00000010 ffffa682`ccf749a0 fffff803`5650c550 : 0x30
SYMBOL_NAME:  BEDaisy+4bd2d6
MODULE_NAME: BEDaisy
IMAGE_NAME:  BEDaisy.sys
STACK_COMMAND:  .cxr; .ecxr ; kb
BUCKET_ID_FUNC_OFFSET:  4bd2d6
FAILURE_BUCKET_ID:  0x13a_11_BE___BEDaisy!unknown_function
OSPLATFORM_TYPE:  x64
OSNAME:  Windows 10
FAILURE_ID_HASH:  {6a85b8ad-f8a7-b71c-b9d1-e9d62252af2e}
Followup:     MachineOwner
Sorununuzun çözülebilmesi için bu adımları deneyebilirsiniz:
  • BattlEye anti-cheat yazılımını kaldırın. Oyunun dosya konumunda yazılımın yükleme, onarma aracı olmalı, oradan tekrar yükleyin. Yükledikten sonra onarım işlemi de yapabilirsiniz. Bu işlemlerden sonra sorun devam ediyorsa, BattlEye yazılımını tamamen kaldırın ve yüklü değilken oyuna giriş yapın.
  • Herhangi bir antivirüs yazılımı kullanıyorsanız devre dışı bırakmayı deneyin.
  • BIOS sürümünüzü güncelleyin. Bilgisayarınız için en son çıkış yapan BIOS sürümünün dosyasını buradan indirebilirsiniz: https://support.hp.com/tr-tr/driver...laptop-15-fa1000/model/2101561446?sku=7N9U9EA
BIOS güncellemesinin sorunsuz yapılabilmesi için işletim sisteminiz Windows 10 ise Windows 11'e yükseltin.
Adımları uyguladıktan sonra sorununuz çözülmezse ve tekrar mavi ekran hatası alırsanız belirtin.
Minidump paylaşın.
ZIP'e sıkıştır derken bu hatayı alıyorum.
BattlEye Anti-Cheat yazılımını kaldırın, ardından oyunun dosya bütünlüğünü doğrulamayı deneyin.
