Çözüldü Windows 10 "KMODE_EXCEPTION_NOT_HANDLED" mavi ekran hatası
Net bir bilgi edinemedim. Ne yaparken oldu hata?
Kod:
KMODE_EXCEPTION_NOT_HANDLED (1e)
This is a very common BugCheck.  Usually the exception address pinpoints
the driver/function that caused the problem.  Always note this address
as well as the link date of the driver/image that contains this address.
Arguments:
Arg1: ffffffffc0000096, The exception code that was not handled
Arg2: ffffa18df321cc15, The address that the exception occurred at
Arg3: 0000000000000000, Parameter 0 of the exception
Arg4: 0000000000000000, Parameter 1 of the exception
Debugging Details:
***    Either you specified an unqualified symbol, or your debugger   ***
***    doesn't have full symbol information.  Unqualified symbol      ***
***    resolution is turned off by default. Please either specify a   ***
***    fully qualified symbol module!symbolname, or enable resolution ***
***    of unqualified symbols by typing ".symopt- 100". Note that     ***
***    enabling unqualified symbol resolution with network symbol     ***
***    server shares in the symbol path may cause the debugger to     ***
***    appear to hang for long periods of time when an incorrect      ***
***    symbol name is typed or the network symbol server is down.     ***
***    For some commands to work properly, your symbol path           ***
***    must point to .pdb files that have full type information.      ***
***    Certain .pdb files (such as the public OS symbols) do not      ***
***    contain the required information.  Contact the group that      ***
***    provided you with these symbols if you need this command to    ***
***    work.                                                          ***
***    Type referenced: ExceptionRecord                               ***
***    work.                                                          ***
***    Type referenced: ContextRecord                                 ***
KEY_VALUES_STRING: 1
    Key  : Analysis.CPU.mSec
    Value: 1327
    Key  : Analysis.Elapsed.mSec
    Value: 4926
    Key  : Analysis.IO.Other.Mb
    Value: 0
    Key  : Analysis.IO.Read.Mb
    Value: 0
    Key  : Analysis.IO.Write.Mb
    Value: 0
    Key  : Analysis.Init.CPU.mSec
    Value: 264
    Value: 5029
    Value: 83
    Value: 0x1e
    Value: 0x1e
    Value: 8
    Value: 1
    Key  : Failure.Bucket
    Value: 0x1E_C0000096_nt!KiDispatchException
    Key  : Failure.Hash
    Value: {505cfaff-0bdc-8a96-0650-5a81952f0ba1}
BUGCHECK_CODE:  1e
BUGCHECK_P1: ffffffffc0000096
BUGCHECK_P2: ffffa18df321cc15
BUGCHECK_P3: 0
BUGCHECK_P4: 0
FILE_IN_CAB:  080724-11937-01.dmp
DUMP_FILE_ATTRIBUTES: 0x8
  Kernel Generated Triage Dump
EXCEPTION_PARAMETER1:  0000000000000000
EXCEPTION_PARAMETER2:  0000000000000000
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  System
STACK_TEXT:
ffffe681`1e7d58e8 fffff801`4529d3f7     : 00000000`0000001e ffffffff`c0000096 ffffa18d`f321cc15 00000000`00000000 : nt!KeBugCheckEx
ffffe681`1e7d58f0 fffff801`451fef42     : 00610063`007a0131 007600fc`00670020 00690064`006e0065 0069006e`0069011f : nt!KiDispatchException+0x13fd37
ffffe681`1e7d5fb0 fffff801`451fef10     : fffff801`452126e5 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxExceptionDispatchOnExceptionStack+0x12
ffffd382`6600ed58 fffff801`452126e5     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiExceptionDispatchOnExceptionStackContinue
ffffd382`6600ed60 fffff801`4520daef     : ffffd382`6600f110 00000000`00000006 00000000`00000005 00000000`00000000 : nt!KiExceptionDispatch+0x125
ffffd382`6600ef40 ffffa18d`f321cc15     : 00000000`0000000c ffffa18d`e8f7ccb8 00000000`00000002 fffff801`45161f3a : nt!KiGeneralProtectionFault+0x32f
ffffd382`6600f0d0 00000000`0000000c     : ffffa18d`e8f7ccb8 00000000`00000002 fffff801`45161f3a ffffa18d`e8f25400 : 0xffffa18d`f321cc15
ffffd382`6600f0d8 ffffa18d`e8f7ccb8     : 00000000`00000002 fffff801`45161f3a ffffa18d`e8f25400 ffffa18d`e8f7ccb0 : 0xc
ffffd382`6600f0e0 00000000`00000002     : fffff801`45161f3a ffffa18d`e8f25400 ffffa18d`e8f7ccb0 ffffe681`1f040180 : 0xffffa18d`e8f7ccb8
ffffd382`6600f0e8 fffff801`45161f3a     : ffffa18d`e8f25400 ffffa18d`e8f7ccb0 ffffe681`1f040180 fffff801`450c87c6 : 0x2
ffffd382`6600f0f0 00000000`00000001     : 00000000`00000002 00000000`00000000 ffffd382`6600f220 ffffa18d`f32023a8 : nt!KiUpdateSpeculationControl+0x9a
ffffd382`6600f190 00000000`00000002     : 00000000`00000000 ffffd382`6600f220 ffffa18d`f32023a8 00000000`00000001 : 0x1
ffffd382`6600f198 00000000`00000000     : ffffd382`6600f220 ffffa18d`f32023a8 00000000`00000001 00000000`00000001 : 0x2
SYMBOL_NAME:  nt!KiDispatchException+13fd37
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
IMAGE_VERSION:  10.0.19041.4648
STACK_COMMAND:  .cxr; .ecxr ; kb
BUCKET_ID_FUNC_OFFSET:  13fd37
FAILURE_BUCKET_ID:  0x1E_C0000096_nt!KiDispatchException
OSPLATFORM_TYPE:  x64
OSNAME:  Windows 10
FAILURE_ID_HASH:  {505cfaff-0bdc-8a96-0650-5a81952f0ba1}
Followup:     MachineOwner
    PnpActivityId      : {00000000-0000-0000-0000-000000000000}
    PnpActivityTime    : 133674628293080471
    PnpEventInformation: 3
    PnpEventInProgress : 0
    PnpProblemCode     : 24
    PnpVetoType        : 0
    DeviceId           : SWD\MMDEVAPI\{0.0.0.00000000}.{1272d6ec-42fd-404a-ab0f-295de46e1b45}
    VetoString         :
[SMBIOS Data Tables v3.6]
[DMI Version - 0]
[2.0 Calling Convention - No]
[Table Size - 2028 bytes]
  Vendor                        American Megatrends International, LLC.
  BIOS Version                  5.32
  BIOS Release Date             04/24/2024
  BIOS ROM Size                 1000000
  BIOS Characteristics
       07: - PCI Supported
       11: - Upgradeable FLASH BIOS
       15: - CD-Boot Supported
       17: - BIOS ROM Socketed
       19: - EDD Supported
       22: - 360KB Floppy Supported
       23: - 1.2MB Floppy Supported
       24: - 720KB Floppy Supported
       25: - 2.88MB Floppy Supported
       27: - Keyboard Services Supported
       32: - BIOS Vendor Reserved
       00: - ACPI Supported
       01: - USB Legacy Supported
  BIOS Major Revision           5
  BIOS Minor Revision           32
  EC Firmware Major Revision    255
  EC Firmware Minor Revision    255
  Extended BIOS ROM Size        0 MB
  Manufacturer                  BIOSTAR Group
  Product Name                  B650MP-E PRO
  Version
  Serial Number                 None
  SKUNumber                     None
  Family                        None
  Product                       B650MP-E PRO
  Version
  Serial Number                 None
  Asset Tag
       00: - Motherboard
       03: - Replaceable
  Location                      None
  Chassis Type                  Desktop
  Version
  Serial Number
  Asset Tag Number
  Contained Element Size        3
[ (Type 256) - Length 9 - Handle 000eh]
[ (Type 256) - Length 26 - Handle 000fh]
[ (Type 256) - Length 31 - Handle 0010h]
[ (Type 256) - Length 26 - Handle 0011h]
[Cache Information (Type 7) - Length 27 - Handle 0012h]
  Socket Designation            L1 - Cache
  Maximum Cache Size            0180h - 384K
  Installed Size                0180h - 384K
  Supported SRAM Type           0010h - Pipeline-Burst
  Current SRAM Type             0010h - Pipeline-Burst
  Cache Speed                   1ns
  Maximum Cache Size 2          180 - 00000384l Kb
  Installed Cache Size 2        180 - 00000384l Kb
[Cache Information (Type 7) - Length 27 - Handle 0013h]
  Socket Designation            L2 - Cache
  Maximum Cache Size            1800h - 6144K
  Installed Size                1800h - 6144K
  Cache Speed                   1ns
  Maximum Cache Size 2          1800 - 00006144l Kb
  Installed Cache Size 2        1800 - 00006144l Kb
[Cache Information (Type 7) - Length 27 - Handle 0014h]
  Socket Designation            L3 - Cache
  Maximum Cache Size            8200h - 32768K
  Installed Size                8200h - 32768K
  Cache Speed                   1ns
  Associativity                 16-way Set-Associative
  Maximum Cache Size 2          80000200 - 00032768l Kb
  Installed Cache Size 2        80000200 - 00032768l Kb
[Processor Information (Type 4) - Length 48 - Handle 0015h]
  Socket Designation            AM5
  Processor Family              6bh - AMD Zen Processor Family
  Processor Manufacturer        Advanced Micro Devices, Inc.
  Processor ID                   120fa600fffb8b17
  Processor Version             AMD Ryzen 5 7500F 6-Core Processor
  Processor Voltage             8dh - 1.3V
  Max Speed                     5050MHz
  Current Speed                 3700MHz
  Processor Upgrade             Specification Reserved
  L1 Cache Handle               0012h
  L2 Cache Handle               0013h
  L3 Cache Handle               0014h
  Serial Number
  Asset Tag Number
  Part Number                   Unknown
  Core Count                    6
  Core Enabled                  6
  Thread Count                  12
  Processor Characteristics     fc
  Enabled Characteristics:
       0x 2: 64-bit Capable
       0x 3: Multi-Core
       0x 4: Hardware Thread
       0x 5: Execute Protection
       0x 6: Enhanced Virtualization
  Processor Family 2            006bh - AMD Zen Processor Family
  Core Count 2                  6
  Core Enabled 2                6
  Thread Count 2                12
[ (Type 256) - Length 9 - Handle 0016h]
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 0017h]
[Physical Memory Array (Type 16) - Length 23 - Handle 0018h]
  Maximum Capacity              134217728KB
  Memory Error Inf Handle       0017h
  Number of Memory Devices      4
[Memory Array Mapped Address (Type 19) - Length 31 - Handle 0019h]
  Ending Address                01ffffffh
  Memory Array Handle           0018h
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 001ah]
[Memory Device (Type 17) - Length 92 - Handle 001bh]
  Memory Error Info Handle      001ah
  Total Width                   [Unknown]
  Data Width                    [Unknown]
  Size                          [Not Populated]
  Form Factor                   02h - Unknown
  Device Locator                DIMM 0
  Bank Locator                  P0 CHANNEL A
  Memory Type                   02h - Unknown
  Type Detail                   0004h - Unknown
  Speed                         0MHz
  Manufacturer                  Unknown
  Serial Number
  Asset Tag Number              [String Not Specified]
  Part Number                   Unknown
  Attributes                    0
  Configured Memory Speed       0
  Minimum Voltage               0
  Maximum Voltage               0
  Configured Voltage            0
  Memory Technology             2
  Memory Operating Mode Capability     4
  Firmware Version              6
  Module Manufacturer Id        0
  Module Product Id             0
  Memory Subsystem Controller Manufacturer Id  0
  Memory Subsystem Controller Product Id       0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
  Extended Configured Memory Speed     0
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 001ch]
[Memory Device (Type 17) - Length 92 - Handle 001dh]
  Memory Error Info Handle      001ch
  Size                          16384MB
  Form Factor                   09h - DIMM
  Device Locator                DIMM 1
  Memory Type                   22h - DDR5
  Type Detail                   4080h - Synchronous Unbuffered (Unregistered)
  Speed                         5600MHz
  Manufacturer                  Crucial Technology
  Serial Number
  Part Number                   CP16G56C46U5.M8B2
  Attributes                    1
  Configured Memory Speed       5200
  Minimum Voltage               1100
  Maximum Voltage               1100
  Configured Voltage            1100
  Memory Technology             3
  Memory Operating Mode Capability     8
  Firmware Version              6
  Module Manufacturer Id        39813
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 001eh]
  Ending Address                00ffffffh
  Memory Device Handle          001dh
  Mem Array Mapped Adr Handle   0019h
  Interleave Position           [Unknown]
  Interleave Data Depth         [Unknown]
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 001fh]
[Memory Device (Type 17) - Length 92 - Handle 0020h]
  Memory Error Info Handle      001fh
  Bank Locator                  P0 CHANNEL B
  Speed                         0MHz
  Serial Number
  Part Number                   Unknown
  Attributes                    0
  Minimum Voltage               0
  Maximum Voltage               0
  Memory Technology             2
  Firmware Version              6
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 0021h]
[Memory Device (Type 17) - Length 92 - Handle 0022h]
  Memory Error Info Handle      0021h
  Size                          16384MB
  Speed                         5600MHz
  Serial Number
  Attributes                    1
  Memory Technology             3
  Firmware Version              6
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 0023h]
  Starting Address              01000000h
  Memory Device Handle          0022h
[ (Type 256) - Length 14 - Handle 0024h]
[ (Type 256) - Length 4 - Handle 0025h]
@bicy
Hocam, arkada Valorant oynarken ekran kartını güncelledim ve sürücü crash verdi.
Kod:
Arguments:
Arg1: ffffffffc0000096, // istisna
Arg2: ffffa18df321cc15, // İstisna fonksiyonunun adresi
Dosya hiçbir bilgi sağlamıyor. Atılan istisnayı ve sistemin belli bir şekilde çöktüğü durumları görüyoruz sadece.
10: Kd>!error C0000096
Error code: (NTSTATUS) 0xc0000096 (3221225622) - {EXCEPTION} Privileged instruction.
Görünüşe göre bir ya da bazı sürücü/ler bazı ayrıcalıklı kodları çalıştırmaya çalışıyor.
Kod:
10: kd> k
 # Child-SP RetAddr Call Site
00 ffffe681`1e7d58e8 fffff801`4529d3f7 nt!KeBugCheckEx
01 ffffe681`1e7d58f0 fffff801`451fef42 nt!KiDispatchException+0x13fd37
02 ffffe681`1e7d5fb0 fffff801`451fef10 nt!KxExceptionDispatchOnExceptionStack+0x12
03 ffffd382`6600ed58 fffff801`452126e5 nt!KiExceptionDispatchOnExceptionStackContinue
04 ffffd382`6600ed60 fffff801`4520daef nt!KiExceptionDispatch+0x125
05 ffffd382`6600ef40 ffffa18d`f321cc15 nt!KiGeneralProtectionFault+0x32f
06 ffffd382`6600f0d0 00000000`0000000c 0xffffa18d`f321cc15
07 ffffd382`6600f0d8 ffffa18d`e8f7ccb8 0xc
08 ffffd382`6600f0e0 00000000`00000002 0xffffa18d`e8f7ccb8
09 ffffd382`6600f0e8 fffff801`45161f3a 0x2
0a ffffd382`6600f0f0 00000000`00000001 0x9a
0b ffffd382`6600f190 00000000`00000002 0x1
0c ffffd382`6600f198 00000000`00000000 0x2
Çağrı yığınında da genel bir koruma hatası aldığını fark ediyoruz çünkü ilk kod içeriğindeki 3 ve 4.parametrelerden de gördüğümüz gibi erişilen adresler geçersiz durumdalar. Bu da genel koruma hatasını doğrular.
Sorunun kaynağını tespitlemek için yapılabilecek en mantıklı şey sürücü doğrulayıcı çalıştırmak olacak gibi görünüyor... https://techolay.net/sosyal/konu/windows-11-icin-driver-verifier-sueruecue-dogrulayici.36609/
Bundan bağımsız olarak, iş parçacığı yığınında kaspersky hatası görüyorum. Sürücü doğrulayıcı da bunu onaylarsa kaspersky hatası diyebiliriz.
0xffffd3826600e3d8 : 0xfffff8014502ee99 : nt!RtlpHpLfhSlotAllocate+0x179
0xffffd3826600e448 : 0xfffff8014502ee99 : nt!RtlpHpLfhSlotAllocate+0x179
0xffffd3826600e4b8 : 0xfffff8014502ee99 : nt!RtlpHpLfhSlotAllocate+0x179
0xffffd3826600e608 : 0xfffff8014502e3a1 : nt!ExAllocateHeapPool+0x2b1
0xffffd3826600e638 : 0xfffff8014504041a : nt!SeAccessCheckWithHintWithAdminlessChecks+0x5ba
0xffffd3826600e6e8 : 0xfffff80145033ab2 : nt!ExFreeHeapPool+0x362
0xffffd3826600e748 : 0xfffff8014503cd1b : nt!ExAcquirePushLockSharedEx+0xeb
0xffffd3826600e768 : 0xffffd3826600e9d8 : 0xfffff8014532046e : nt!KiConvertDynamicHeteroPolicy+0x1e
0xffffd3826600e7b0 : 0xffffd3826600e9d8 : 0xfffff8014532046e : nt!KiConvertDynamicHeteroPolicy+0x1e
0xffffd3826600e7c8 : 0xfffff801457b70b9 : nt!ExFreePool+0x9
0xffffd3826600e7f0 : 0xffffd3826600e9d8 : 0xfffff8014532046e : nt!KiConvertDynamicHeteroPolicy+0x1e
0xffffd3826600e7f8 : 0xfffff801456e0bd7 : nt!ObpCallPostOperationCallbacks+0x87
0xffffd3826600e818 : 0xfffff801453fa47a : nt!ObpPreInterceptHandleCreate+0xaa
0xffffd3826600e828 : 0xfffff801456e0c7e : nt!ObpPostInterceptHandleCreate+0x86
0xffffd3826600e848 : 0xfffff8014503cb5e : nt!ExAcquirePushLockExclusiveEx+0xee
0xffffd3826600e8b0 : 0xffffd3826600e9d8 : 0xfffff8014532046e : nt!KiConvertDynamicHeteroPolicy+0x1e
Unable to load image klflt.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for klflt.sys
0xffffd3826600ea08 : 0xfffff80145320bd6 : nt!KiHeteroChooseTargetProcessor+0x426
0xffffd3826600ea60 : 0xfffff8014511f000 : nt!HalpApic1WriteIcr
0xffffd3826600ea68 : 0xfffff8014511c530 : nt!HalpApicRequestInterrupt+0x90
0xffffd3826600ea88 : 0xfffff801450bf52c : nt!KiComputeThreadAffinity+0x64
0xffffd3826600ead8 : 0xfffff80145036176 : nt!KiDeferredReadySingleThread+0x566
0xffffd3826600eb08 : 0xfffff80145033ab2 : nt!ExFreeHeapPool+0x362
0xffffd3826600ebc0 : 0xfffff8014511f000 : nt!HalpApic1WriteIcr
0xffffd3826600ebc8 : 0xfffff8014511c530 : nt!HalpApicRequestInterrupt+0x90
0xffffd3826600ec38 : 0xfffff80145049aef : nt!HalpInterruptSendIpi+0x2df
0xffffd3826600ecf8 : 0xfffff801450d5e97 : nt!KiFastReadyThread+0xa3
0xffffd3826600ed58 : 0xfffff801452126e5 : nt!KiExceptionDispatch+0x125
0xffffd3826600ee30 : 0xfffff8014511f000 : nt!HalpApic1WriteIcr
Hocam Windows 10 için uygun mudur? Bir de tekrar çöktü lakin 2.dump dosyası ne analiz ediliyor ne de Drive'a yükleniyor.
Not: Hata almadan önce ekran kartı driver güncellemesi yaptım ve crash verdi.
Windows'un klasik izniniz yok uyarısını veriyorsa sıkıştırarak ya da direkt istediği izni vererek paylaşabilirsin.
Bunu 2.çökme için mi söyledin anlayamadım ama ikisi de ekran kartı sürücüsü güncellemesi sonrası olduysa ekran kartı sürücüsüne karışma.
Tabii ki. Konuyu oku iyice. Hiçbir uyarıyı göz ardı etme.
Hocam rehberiniz bana çok karışık geldi bu yüzden yapamadım.
Bu yeni dump dosyası.
Aldığın hata önceden de dediğim gibi pek bilgi sağlamıyor çünkü bir çekirdek modu programı, hata işleyicinin yakalayamadığı bir istisna oluşturuyor. Ham yığıtına bakamıyorum ve normal yığıtlar da pek bilgi sunmuyorlar.
Yani elde ettiğimiz çok bir bilgi yok. Sadece iş parçacığı yığınında DirectX çağrıları görüyoruz, bu da ekran kartı sürücünle ilgili bir soruna işaret ediyor olabilir.
Rich (BB code):
0xffffeb0af3efe418 : 0xfffff801810063d6 : nt!KiSwapContext+0x76
0xffffeb0af3efe438 : 0xfffff801810126e5 : nt!KiExceptionDispatch+0x125
0xffffeb0af3efe608 : 0xfffff80180e37f5f : nt!KiCommitThreadWait+0x14f
0xffffeb0af3efe618 : 0xfffff8018100daef : nt!KiGeneralProtectionFault+0x32f
0xffffeb0af3efe728 : 0xfffff801811b6faf : nt!ExpAcquireSpinLockSharedAtDpcLevelInstrumented+0x8b
0xffffeb0af3efe748 : 0xfffff80180f0873b : nt!MmAttachSession+0x9b
0xffffeb0af3efe758 : 0xfffff80180e595ec : nt!MmGetSessionById+0xac
0xffffeb0af3efe7a0 : 0xffffeb0af3efe7b0 : 0xfffff80181a00248 : nt!PsInvertedFunctionTable+0x238
0xffffeb0af3efe808 : 0xfffff8018304133c : "CI!wil_details_featureChangeNotification <PERF> (CI+0x4133c)"
0xffffeb0af3efe860 : 0xfffff801e0a52930 : dxgmms2!EventRecycleRangeTransition
0xffffeb0af3efe870 : 0xfffff8018304133c : "CI!wil_details_featureChangeNotification <PERF> (CI+0x4133c)"
0xffffeb0af3efe880 : 0xfffff8018303b000 : "CI!wil_details_featureChangeNotification <PERF> (CI+0x3b000)"
0xffffeb0af3efec48 : 0xfffff80180f58c79 : nt!PsGetCurrentServerSiloGlobals+0x9
0xffffeb0af3efecc8 : 0xfffff80180f58c79 : nt!PsGetCurrentServerSiloGlobals+0x9
0xffffeb0af3efed18 : 0xfffff801e0a54710 : dxgmms2!EventRecycleRangeCreate
0xffffeb0af3efed48 : 0xfffff80180f58c79 : nt!PsGetCurrentServerSiloGlobals+0x9
0xffffeb0af3efee18 : 0xfffff801e0a52930 : dxgmms2!EventRecycleRangeTransition
0xffffeb0af3eff0d0 : 0xfffff801e0a52930 : dxgmms2!EventRecycleRangeTransition
0xffffeb0af3eff0e8 : 0xfffff80180e46609 : nt!EtwWriteEx+0x119
0xffffeb0af3eff0f8 : 0xfffff80180f61f3a : nt!KiUpdateSpeculationControl+0x9a
0xffffeb0af3eff110 : 0xfffff801e0a52930 : dxgmms2!EventRecycleRangeTransition
0xffffeb0af3eff178 : 0xfffff80181927a00 : nt!KiInitialThread
0xffffeb0af3eff198 : 0xfffff80181006862 : nt!SwapContext+0x1b2
0xffffeb0af3eff1d8 : 0xfffff801810063d6 : nt!KiSwapContext+0x76
0xffffeb0af3eff208 : 0xfffff80180e464db : nt!EtwWriteTransfer+0x2b
0xffffeb0af3eff318 : 0xfffff80180e38a30 : nt!KiSwapThread+0x500
0xffffeb0af3eff378 : 0xfffff80180e3c9a3 : nt!ExReleasePushLockExclusiveEx+0x1a3
0xffffeb0af3eff3c8 : 0xfffff80180e37f5f : nt!KiCommitThreadWait+0x14f
0xffffeb0af3eff458 : 0xfffff80181925440 : nt!ExNode0
0xffffeb0af3eff4b8 : 0xfffff801e0a86041 : dxgmms2!VidMmRangeCurationThread+0x11
0xffffeb0af3eff4c0 : 0xfffff80181925440 : nt!ExNode0
0xffffeb0af3eff4e8 : 0xfffff80180ec90c5 : nt!ExpWorkerThread+0x105
0xffffeb0af3eff4f8 : 0xfffff801e0a86030 : dxgmms2!VidMmRangeCurationThread
0xffffeb0af3eff570 : 0xfffff80180ec8fc0 : nt!ExpWorkerThread
0xffffeb0af3eff588 : 0xfffff80180f48da5 : nt!PspSystemThreadStartup+0x55
0xffffeb0af3eff5d8 : 0xfffff80181006de8 : nt!KiStartSystemThread+0x28
Eğer ki sorun sürücüye karışmadıkça tekrarlamıyorsa bir sonraki sürücü güncellemesine kadar beklemeni öneririm. Bu şekilde dosyalardan ilerlemek zor ki zaten çok fazla bağlam değişimi işlemi yapıldığı için bilgi edinmeyi imkansız hale getiriyor.
Eski sürüme dönmek faydalı mı?
Şu anlık yapılabilecek en mantıklı şey bu. Sürücü doğrulayıcı rehberim karışık geldiyse YouTube üzerinden bununla alakalı çok rehber var. Yazdıklarımı videolarla destekleyerek iyice oturtabilirsin kafanda.
