Windows'de 11 "SYSTEM_SERVICE_EXCEPTION" siyah ekran hatası
firatyilmaz1903
23 Ekim 2025
  • Anakart:
  • İşlemci:
  • Ekran Kartı:
  • İşletim Sistemi:
  • İşlemci: Intel Core i7 14650HX
  • Ekran Kartı: Nvidia GeForce RTX5060 100W+15W 8GB
  • RAM: 32GB (2×16) 5600MHz DDR5
  • Depolama: 1TB NVMe M.2 SSD
Arkadaşlar merhaba. WİN 11 AOE4 oynarken aşağıdaki mavi ekran hatasını aldım.Yorumlarınızı ve çözüm yollarınızı rica ederim.
Kod:
************* Preparing the environment for Debugger Extensions Gallery repositories **************
   ExtensionRepository : Implicit
   UseExperimentalFeatureForNugetShare : true
   AllowNugetExeUpdate : true
   NonInteractiveNuget : true
   AllowNugetMSCredentialProviderInstall : true
   AllowParallelInitializationOfLocalRepositories : true
   EnableRedirectToChakraJsProvider : false
   -- Configuring repositories
      ----> Repository : LocalInstalled, Enabled: true
      ----> Repository : UserExtensions, Enabled: true
>>>>>>>>>>>> Preparing the environment for Debugger Extensions Gallery repositories completed, duration 0.000 seconds
************* Waiting for Debugger Extensions Gallery to Initialize **************
>>>>>>>>>>>> Waiting for Debugger Extensions Gallery to Initialize completed, duration 0.032 seconds
   ----> Repository : UserExtensions, Enabled: true, Packages count: 0
   ----> Repository : LocalInstalled, Enabled: true, Packages count: 46
Microsoft (R) Windows Debugger Version 10.0.29457.1000 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\112625-19078-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
************* Path validation summary **************
Response                         Time (ms)     Location
Deferred                                       srv*
Symbol search path is: srv*
Executable search path is:
Windows 10 Kernel Version 26100 MP (24 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Kernel base = 0xfffff801`8ce00000 PsLoadedModuleList = 0xfffff801`8dcf5030
Debug session time: Wed Nov 26 21:12:22.359 2025 (UTC + 3:00)
System Uptime: 3 days 21:31:13.298
Loading Kernel Symbols
Press ctrl-c (cdb, kd, ntsd) or ctrl-break (windbg) to abort symbol loads that take too long.
Run !sym noisy before .reload to track down problems loading symbols.
Loading User Symbols
PEB is paged out (Peb.Ldr = 000000fe`2fd06018).  Type ".hh dbgerr001" for details
Loading unloaded module list
For analysis of this file, run !analyze -v
nt!KeBugCheckEx:
fffff801`8d2f6880 48894c2408      mov     qword ptr [rsp+8],rcx ss:ffffa980`808d7fb0=????????????????
23: kd> !analyze -v
Bugcheck Analysis                                    *
SYSTEM_SERVICE_EXCEPTION (3b)
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000005, Exception code that caused the BugCheck
Arg2: fffff8018d20f218, Address of the instruction which caused the BugCheck
Arg3: ffffa980808d88f0, Address of the context record for the exception that caused the BugCheck
Arg4: 0000000000000000, zero.
Debugging Details:
KEY_VALUES_STRING: 1
    Key  : Analysis.CPU.mSec
    Value: 2812
    Key  : Analysis.Elapsed.mSec
    Value: 4554
    Key  : Analysis.IO.Other.Mb
    Value: 0
    Key  : Analysis.IO.Read.Mb
    Value: 1
    Key  : Analysis.IO.Write.Mb
    Value: 0
    Key  : Analysis.Init.CPU.mSec
    Value: 1343
    Value: 31363
    Value: 103
    Value: 10.0.29457.1000
    Value: 10.2506.23.01 amd64fre
    Key  : Analysis.Version.Ext
    Value: 1.2506.23.1
    Value: 0x3b
    Value: 0x3b
    Value: 0x21808
    Value: 1
    Value: 0x0
    Value: 1
    Value: 0
    Key  : Failure.Bucket
    Value: AV_nt!KxWaitForLockOwnerShipWithIrql
    Key  : Failure.Exception.IP.Address
    Value: 0xfffff8018d20f218
    Key  : Failure.Exception.IP.Module
    Value: nt
    Key  : Failure.Exception.IP.Offset
    Value: 0x40f218
    Key  : Failure.Hash
    Value: {a9412e74-fd67-6813-e6aa-afe17ba295d4}
    Key  : Hypervisor.Enlightenments.ValueHex
    Value: 0x7417df84
    Key  : Hypervisor.Flags.AnyHypervisorPresent
    Value: 1
    Key  : Hypervisor.Flags.ApicEnlightened
    Value: 0
    Key  : Hypervisor.Flags.ApicVirtualizationAvailable
    Value: 1
    Key  : Hypervisor.Flags.AsyncMemoryHint
    Value: 0
    Key  : Hypervisor.Flags.CoreSchedulerRequested
    Value: 0
    Key  : Hypervisor.Flags.CpuManager
    Value: 1
    Key  : Hypervisor.Flags.DeprecateAutoEoi
    Value: 1
    Key  : Hypervisor.Flags.DynamicCpuDisabled
    Value: 1
    Key  : Hypervisor.Flags.Epf
    Value: 0
    Key  : Hypervisor.Flags.ExtendedProcessorMasks
    Value: 1
    Key  : Hypervisor.Flags.HardwareMbecAvailable
    Value: 1
    Key  : Hypervisor.Flags.MaxBankNumber
    Value: 0
    Key  : Hypervisor.Flags.MemoryZeroingControl
    Value: 0
    Key  : Hypervisor.Flags.NoExtendedRangeFlush
    Value: 0
    Key  : Hypervisor.Flags.NoNonArchCoreSharing
    Value: 1
    Key  : Hypervisor.Flags.Phase0InitDone
    Value: 1
    Key  : Hypervisor.Flags.PowerSchedulerQos
    Value: 0
    Key  : Hypervisor.Flags.RootScheduler
    Value: 0
    Key  : Hypervisor.Flags.SynicAvailable
    Value: 1
    Key  : Hypervisor.Flags.UseQpcBias
    Value: 0
    Key  : Hypervisor.Flags.Value
    Value: 55185662
    Key  : Hypervisor.Flags.ValueHex
    Value: 0x34a10fe
    Key  : Hypervisor.Flags.VpAssistPage
    Value: 1
    Key  : Hypervisor.Flags.VsmAvailable
    Value: 1
    Key  : Hypervisor.RootFlags.AccessStats
    Value: 1
    Key  : Hypervisor.RootFlags.CrashdumpEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.CreateVirtualProcessor
    Value: 1
    Key  : Hypervisor.RootFlags.DisableHyperthreading
    Value: 0
    Key  : Hypervisor.RootFlags.HostTimelineSync
    Value: 1
    Key  : Hypervisor.RootFlags.HypervisorDebuggingEnabled
    Value: 0
    Key  : Hypervisor.RootFlags.IsHyperV
    Value: 1
    Key  : Hypervisor.RootFlags.LivedumpEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.MapDeviceInterrupt
    Value: 1
    Key  : Hypervisor.RootFlags.MceEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.Nested
    Value: 0
    Key  : Hypervisor.RootFlags.StartLogicalProcessor
    Value: 1
    Key  : Hypervisor.RootFlags.Value
    Value: 1015
    Key  : Hypervisor.RootFlags.ValueHex
    Value: 0x3f7
    Key  : Stack.Pointer
    Value: PRCBException
    Key  : WER.System.BIOSRevision
    Value: 5.32.0.0
BUGCHECK_CODE:  3b
BUGCHECK_P1: c0000005
BUGCHECK_P2: fffff8018d20f218
BUGCHECK_P3: ffffa980808d88f0
BUGCHECK_P4: 0
FILE_IN_CAB:  112625-19078-01.dmp
TAG_NOT_DEFINED_202b:  *** Unknown TAG in analysis list 202b
DUMP_FILE_ATTRIBUTES: 0x21808
  Kernel Generated Triage Dump
FAULTING_THREAD:  ffff9886449cc080
CONTEXT:  ffffa980808d88f0 -- (.cxr 0xffffa980808d88f0)
rax=0000000000000000 rbx=fffff6867188f7d0 rcx=fffff6867188f7c8
rdx=0000900000008e00 rsi=0000000000000000 rdi=0000000000000000
rip=fffff8018d20f218 rsp=fffff6867188f6c0 rbp=fffff6867188f730
 r8=0000000000000001  r9=0000000000000000 r10=ffff988639dea080
r11=0000000000000000 r12=0000000000000001 r13=ffffffffffffffff
r14=0000000000000000 r15=0000000000000000
iopl=0         nv up ei ng nz na pe nc
cs=0010  ss=0000  ds=002b  es=002b  fs=0053  gs=002b             efl=00050282
nt!KxWaitForLockOwnerShipWithIrql+0x48:
fffff801`8d20f218 48890a          mov     qword ptr [rdx],rcx ds:002b:00009000`00008e00=????????????????
Resetting default scope
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1 (!blackboxwinlogon)
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  WUDFHost.exe
STACK_TEXT:
fffff686`7188f6c0 fffff801`8d0d7b73     : ffff9886`3c3c7500 00000000`00000000 ffffa980`80861180 00000000`00000001 : nt!KxWaitForLockOwnerShipWithIrql+0x48
fffff686`7188f740 fffff801`8d140629     : ffff9886`3c3c75e0 fffff686`7188faa0 00000000`00000000 ffff9886`115b0c90 : nt!KiAcquireQueuedSpinLockInstrumented+0x73
fffff686`7188f780 fffff801`8d4b2255     : fffff686`7188faa0 00000280`dff8a460 fffff686`7188faa0 00000280`dff79330 : nt!NtWaitForWorkViaWorkerFactory+0xc79
fffff686`7188f9b0 00007ff9`20a65974     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x25
000000fe`2feffb88 00000000`00000000     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ff9`20a65974
SYMBOL_NAME:  nt!KxWaitForLockOwnerShipWithIrql+48
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
IMAGE_VERSION:  10.0.26100.7171
STACK_COMMAND: .cxr 0xffffa980808d88f0 ; kb
BUCKET_ID_FUNC_OFFSET:  48
FAILURE_BUCKET_ID:  AV_nt!KxWaitForLockOwnerShipWithIrql
OSPLATFORM_TYPE:  x64
OSNAME:  Windows 10
FAILURE_ID_HASH:  {a9412e74-fd67-6813-e6aa-afe17ba295d4}
Followup:     MachineOwner
yardımcı olabilicek yok mu
"MİCROSOFT (R) WINDOWS DEBUGGER" aldığı hataya göre "SYSTEM_SERVICE_EXCEPTION" hatası bir sistem servisi sırasında bir istisna yaşandığını gösteriyor. Bu hatanın çeşitli sebepleri olabilir. Aşağıda adım adım çözüm önerileri bulunmaktadır:
1. Güncelleştirmeleri Kontrol Et:
- Başlat menüsüne tıklayın ve "Ayarlar"ı açın.
- "Güncelleme ve Güvenlik" sekmesine gidin.
- "Güncellemeleri kontrol et" seçeneğine tıklayın ve güncellemeleri yükleyin.
2. Sürücüleri Güncelleyin:
- Başlat menüsüne sağ tıklayın ve "Aygıt Yöneticisi"ni seçin.
- Ekran kartı gibi ana bileşenlerin sürücülerini güncelleyin:
- Görüntü bağdaştırıcıları altında ekran kartınıza sağ tıklayın ve "Sürücüyü güncelle" seçeneğini seçin.
- Aynı işlemi diğer bileşenler, özellikle ağ, ses ve chipset sürücüleri için de yapın.
3. RAM Testi Yapın:
- Başlat menüsünü açın ve "Windows Bellek Tanılama" yazın.
- Uygulamanın talimatlarını izleyerek bilgisayarınızı yeniden başlatın ve bellek hatalarını kontrol edin.
4. Sabit Disk Kontrolü Yapın:
- Başlat menüsüne tıklayın, "cmd" yazın, sonuç üzerine sağ tıklayın ve "Yönetici olarak çalıştır" seçeneğini seçin.
- Komut istemine şunu yazın: chkdsk /f /r ve Enter'a basın.
- C sürücüsünü kontrol etmek için "Evet" seçeneğini seçin ve bilgisayarı yeniden başlatın.
5. Sistem Dosyalarını Kontrol Edin:
- Yukarıda olduğu gibi Komut İstemi’ni yönetici olarak açın ve şu komutu yazın: sfc /scannow.
- Tarama tamamlanana kadar bekleyin ve ardından bilgisayarı yeniden başlatın.
6. Oyun Dosyalarını Onarın:
- Eğer bu hata sadece oyun oynarken oluyorsa, oyunun dosya bütünlüğünü onarmayı deneyin.
- Oyun platformunu (örneğin Steam, Epic Games vb.) açın ve oyunu sağ tıklayarak dosyaları doğrulamayı seçin.
7. Hiper-V ve Sanallaştırmayı Kontrol Edin:
- Hiper-V veya diğer sanallaştırma yazılımlarını kullanıyorsanız, devre dışı bırakın.
- Denetim Masası'nın "Programlar ve Özellikler" kısmından "Windows Özelliklerini Aç veya Kapat" seçeneğine gidin ve Hiper-V seçeneğini kaldırın.
8. Önceki Sürücülere Dönün:
- Eğer sorun yeni bir güncellemeyle başladıysa, Aygıt Yöneticisi üzerinden sürücüyü sağ tıklayarak "Önceki sürüme dön" seçeneği ile eski sürüme geçmeyi deneyin.
Eğer yukarıdaki adımlar çözüm sağlamazsa, detaylı bir analiz için bir sistem bakımcı veya uzman ile irtibat kurmak iyi bir fikir olabilir.
