Kim cevapladı?- Bütçe
- 4.000 TL
AOC 23.8" 24G11ZE FAST IPS FHD 240HZ : Amazon.com.tr: Bilgisayar
www.amazon.com.tr
23.8" AOC 24G11ZE - Specifications
Specifications of AOC 24G11ZE. Display: 23.8 in, IPS, W-LED, 1920 x 1080 pixels, Viewing angles (H/V): 178 ° / 178 °, Brightness: 300 cd/m², Static contrast: 1000 : 1, Dynamic contrast: 80000000 : 1, Refresh rate: 48 Hz - 240 Hz, sRGB: 99 %, Dimensions: 539.7 x 320.8 x 51.1 mm, Weight: 2.67 kg.
www.displayspecifications.com
pivot şart mı?
pivot şartsa bu monitör ben de var güzel baya AOC 27G4HA 24.5 inc 200Hz 1ms HDMI DP G-Sync AdaptiveSync Pivot HDR10 FHD Fast IPS Gaming Monitör : Amazon.com.tr: Bilgisayar bütçeyi eğer arttırma şansınız varsa
27 inç ama 24'ünü alabilirsiniz.
AOC 24G4HA - 24 inch Full HD Gaming Monitor, Fast IPS, 200Hz, 1ms, G-Sync comp, HDR10, Height Adjust (1920x1080, 2x HDMI 2.0, 1x DisplayPort 1.4) : Amazon.com.tr: Bilgisayar
www.amazon.com.tr
kitty
- 5 Eylül 2024
24 inç. Oyun için
Yukarı aşağı inse tamam 360 yapmasına gerek yok. Bütçe arttıramam maalesef. En fazla 500 600 artar.AOC 23.8" 24G11ZE FAST IPS FHD 240HZ : Amazon.com.tr: Bilgisayar
AOC 23.8" 24G11ZE FAST IPS FHD 240HZ : Amazon.com.tr: Bilgisayarwww.amazon.com.tr
Specifications of AOC 24G11ZE. Display: 23.8 in, IPS, W-LED, 1920 x 1080 pixels, Viewing angles (H/V): 178 ° / 178 °, Brightness: 300 cd/m², Static contrast: 1000 : 1, Dynamic contrast: 80000000 : 1, Refresh rate: 48 Hz - 240 Hz, sRGB: 99 %, Dimensions: 539.7 x 320.8 x 51.1 mm, Weight: 2.67 kg.www.displayspecifications.com
pivot şart mı?
AOC 24G4HA - 24 inch Full HD Gaming Monitor, Fast IPS, 200Hz, 1ms, G-Sync comp, HDR10, Height Adjust (1920x1080, 2x HDMI 2.0, 1x DisplayPort 1.4) : Amazon.com.tr: Bilgisayarwww.amazon.com.tr
GodOfWar 59
LG 24.5" 25MS500-B 5Ms (GtG) 100Hz (HDMIx2) AMD FreeSync FHD IPS Panel Monitör : Amazon.com.tr: Bilgisayar
www.amazon.com.tr
AOC 23.8" IPS 24B3HA2 1MS 100hz HDMI Multimedya Monitör : Amazon.com.tr: Bilgisayar
www.amazon.com.tr
ASUS VY249HGR 23,8 inç Eye Care Oyun Monitörü (FHD (1920 x 1080), IPS, 120Hz (OC), SmoothMotion, 1ms (MPRT), Adaptive Sync, Eye Care Plus Teknolojisi, Mavi Işık Filtresi, Titreşimsiz : Amazon.com.tr: Bilgisayar
www.amazon.com.tr
KOORUI Monitör 24E3 23.8Inç, 165Hz, FHD, 1080p(1920*1080), 1ms, Ips, Adaptive Sync, Monitörler,Gaming, Hdmi 1.4*2, Dp 1.2*1, Eğilmek:-5~15°, Yukarı Ve Aşağı, Görme Açısı 178°, Vesa,75*75mm, Siyah : Amazon.com.tr: Bilgisayar
www.amazon.com.tr
Bütçeniz biraz daha artarsa attıklarımı değerlendirebilirsiniz.
Bakım Bargello parfümlerde alt limitsiz 100 TL indirim!
- Fırsat Ekibi
- Mesaj: 3
Üniversite aile evinde mi okunmalı, şehir dışında mı?
- XXXTentacion
- Mesaj: 12
