CRITICAL_PROCESS_DIED (ef)
A critical system process died
Arguments:
Arg1: ffffe2862e2ad080, Process object or thread object
Arg2: 0000000000000000, If this is 0, a process died. If this is 1, a thread died.
Arg3: 0000000000000000, The process object that initiated the termination.
Arg4: 0000000000000000
Debugging Details:
*** WARNING: Check Image - Checksum mismatch - Dump: 0x188be7, File: 0x18f723 - C:\ProgramData\Dbg\sym\HTTP.sys\43E8008A188000\HTTP.sys
KEY_VALUES_STRING: 1
Key : Analysis.CPU.mSec
Value: 1734
Key : Analysis.Elapsed.mSec
Value: 5416
Key : Analysis.IO.Other.Mb
Value: 0
Key : Analysis.IO.Read.Mb
Value: 1
Key : Analysis.IO.Write.Mb
Value: 0
Key : Analysis.Init.CPU.mSec
Value: 281
Value: 1149
Value: 87
Key : Analysis.Version.DbgEng
Value: 10.0.27725.1000
Key : Analysis.Version.Description
Value: 10.2408.27.01 amd64fre
Key : Analysis.Version.Ext
Value: 1.2408.27.1
Key : Bugcheck.Code.LegacyAPI
Value: 0xef
Key : Bugcheck.Code.TargetModel
Value: 0xef
Key : CriticalProcessDied.ExceptionCode
Value: 2e4b60c0
Key : CriticalProcessDied.Process
Value: wininit.exe
Key : Failure.Bucket
Value: 0xEF_wininit.exe_BUGCHECK_CRITICAL_PROCESS_2e4b60c0_nt!PspCatchCriticalBreak
Key : Failure.Hash
Value: {e1b3d406-b7e2-7b72-a432-e440ecbea5f2}
Key : WER.OS.Branch
Value: vb_release
Key : WER.OS.Version
Value: 10.0.19041.1
BUGCHECK_CODE: ef
BUGCHECK_P1: ffffe2862e2ad080
BUGCHECK_P2: 0
BUGCHECK_P3: 0
BUGCHECK_P4: 0
FILE_IN_CAB: 012825-19234-01.dmp
FAULTING_THREAD: ffffe2862e4b60c0
PROCESS_NAME: wininit.exe
CRITICAL_PROCESS: wininit.exe
ERROR_CODE: (NTSTATUS) 0x2e4b60c0 - <Unable to get error code text>
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT: 1
STACK_TEXT:
ffff8c87`90aa6ab8 fffff802`6e90ed12 : 00000000`000000ef ffffe286`2e2ad080 00000000`00000000 00000000`00000000 : nt!KeBugCheckEx
ffff8c87`90aa6ac0 fffff802`6e816e13 : ffffe286`2e4b60c0 ffffe286`2e2ad4b8 00000000`00000000 fffff802`6e584247 : nt!PspCatchCriticalBreak+0x10e
ffff8c87`90aa6b60 fffff802`6e6b0adf : 00000000`00000000 00000000`00000000 ffffe286`2e2ad080 00000000`00000000 : nt!PspTerminateAllThreads+0x15ab73
ffff8c87`90aa6bd0 fffff802`6e413108 : ffffe286`2e2ad080 ffffe286`2e4b60c0 ffff8c87`90aa6cc0 00000000`00000000 : nt!NtTerminateProcess+0x16f
ffff8c87`90aa6c40 00007ff9`de90da74 : 00007ff9`de8cef24 00000000`000000ff 00000000`00000000 00000000`00000000 : nt!KiSystemServiceExitPico+0x41c
0000002a`8552f628 00007ff9`de8cef24 : 00000000`000000ff 00000000`00000000 00000000`00000000 00007ff9`dc83cd80 : 0x00007ff9`de90da74
0000002a`8552f630 00000000`000000ff : 00000000`00000000 00000000`00000000 00007ff9`dc83cd80 00000000`00000005 : 0x00007ff9`de8cef24
0000002a`8552f638 00000000`00000000 : 00000000`00000000 00007ff9`dc83cd80 00000000`00000005 00007ff9`dc92e3eb : 0xff
SYMBOL_NAME: nt!PspCatchCriticalBreak+10e
MODULE_NAME: nt
IMAGE_NAME: ntkrnlmp.exe
IMAGE_VERSION: 10.0.19041.5369
STACK_COMMAND: .process /r /p 0xffffe2862e2ad080; .thread 0xffffe2862e4b60c0 ; kb
BUCKET_ID_FUNC_OFFSET: 10e
FAILURE_BUCKET_ID: 0xEF_wininit.exe_BUGCHECK_CRITICAL_PROCESS_2e4b60c0_nt!PspCatchCriticalBreak
OS_VERSION: 10.0.19041.1
BUILDLAB_STR: vb_release
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {e1b3d406-b7e2-7b72-a432-e440ecbea5f2}
Followup: MachineOwner
PnpActivityId : {00000000-0000-0000-0000-000000000000}
PnpActivityTime : 133825251810389013
PnpEventInformation: 3
PnpEventInProgress : 0
PnpProblemCode : 24
PnpVetoType : 0
DeviceId : SWD\RADIO\{0B9BFAA8-9DE4-44D8-ACBE-5F9FACC3A9BA}
VetoString :
[SMBIOS Data Tables v2.7]
[DMI Version - 0]
[2.0 Calling Convention - No]
[Table Size - 1825 bytes]
[BIOS Information (Type 0) - Length 24 - Handle 0000h]
Vendor Hewlett-Packard
BIOS Version F.34
BIOS Starting Address Segment ffe0
BIOS Release Date 07/27/2011
BIOS ROM Size 200000
BIOS Characteristics
07: - PCI Supported
11: - Upgradeable FLASH BIOS
15: - CD-Boot Supported
17: - BIOS ROM Socketed
19: - EDD Supported
22: - 360KB Floppy Supported
23: - 1.2MB Floppy Supported
24: - 720KB Floppy Supported
25: - 2.88MB Floppy Supported
27: - Keyboard Services Supported
32: - BIOS Vendor Reserved
52: - System Vendor Reserved
54: - System Vendor Reserved
00: - ACPI Supported
01: - USB Legacy Supported
BIOS Major Revision 15
BIOS Minor Revision 52
EC Firmware Major Revision 24
EC Firmware Minor Revision 54
Manufacturer Hewlett-Packard
Product Name HP 635 Notebook PC
Version 058A100000004C10002600000
Serial Number 5CB13839SJ
UUID 00000000-0000-0000-0000-000000000000
Wakeup Type Power Switch
SKUNumber A1E34EA#AB8
Family 103C_5336AN G=N L=SMB B=HP S=635
[BaseBoard Information (Type 2) - Length 16 - Handle 0002h]
Product 3577
Version 24.36
Serial Number PCGQQA37V1F2JS
Asset Tag
Feature Flags 09h
00: - Motherboard
03: - Replaceable
Location Base Board Chassis Location
Chassis Handle 0003h
Board Type 0ah - Processor/Memory Module
Number of Child Handles 0
[System Enclosure (Type 3) - Length 23 - Handle 0003h]
Chassis Type Notebook
Version Chassis Version
Serial Number
Asset Tag Number
Bootup State Safe
Power Supply State Safe
Thermal State Safe
Security Status None
OEM Defined 2380
Height 0U
Number of Power Cords 1
Number of Contained Elements 0
Contained Element Size 0
SKU Number Chassis SKU
[OEM Strings (Type 11) - Length 5 - Handle 0009h]
Number of Strings 4
1 $HP$
2 LOC#AB8
3 ABS 70/71 78 79 7A 7B
4 CNB1 058A100000004C10002600000
[ (Type 256) - Length 11 - Handle 001dh]
[Physical Memory Array (Type 16) - Length 23 - Handle 001eh]
Location 03h - SystemBoard/Motherboard
Use 03h - System Memory
Memory Error Correction 03h - None
Maximum Capacity 8388608KB
Memory Error Inf Handle 0025h
Number of Memory Devices 2
[Memory Device (Type 17) - Length 34 - Handle 001fh]
Memory Error Info Handle 0020h
Total Width 64 bits
Data Width 8 bits
Size 4096MB
Form Factor 0dh - SODIMM
Device Set [None]
Device Locator DIMM0
Bank Locator BANK0
Memory Type 18h - DDR3
Type Detail 0080h - Synchronous
Speed 1333MHz
Manufacturer Hynix Semiconductor
Serial Number
Asset Tag Number
Part Number HMT351S6CFR8C-PB
Attributes 2
Extended Size 0
Configured Memory Speed 667
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 0020h]
MEMORY_MANAGEMENT (1a)
# Any other values for parameter 1 must be individually examined.
Arguments:
Arg1: 0000000000061941, The subtype of the BugCheck.
Arg2: fffff8024bf91030
Arg3: 0000000000000009
Arg4: fffff8023fc82cd0
Debugging Details:
*** WARNING: Check Image - Checksum mismatch - Dump: 0x8f4d2, File: 0x8fc57 - C:\ProgramData\Dbg\sym\usbhub.sys\1229AD8A85000\usbhub.sys
Value: 1187
Value: 10043
Value: 0
Value: 1
Value: 1
Value: 328
Value: 2519
Value: 84
Value: 1.2408.27.1
Value: 0x1a
Value: 0x1a
Value: 0x1a_61941_PAGE_TABLE_RESERVED_BITS_SET_IMAGE_hardware_ram
Key : Failure.Hash
Value: {c6e5c6cf-692e-7852-5dc5-b74944540fc0}
Key : Stack.Pointer
Value: ISR
Key : WER.OS.Branch
Value: vb_release
Value: 10.0.19041.1
BUGCHECK_CODE: 1a
BUGCHECK_P1: 61941
BUGCHECK_P2: fffff8024bf91030
BUGCHECK_P3: 9
BUGCHECK_P4: fffff8023fc82cd0
FILE_IN_CAB: 020425-17093-01.dmp
FAULTING_THREAD: fffff8023bb27a00
BLACKBOXWINLOGON: 1
PROCESS_NAME: System
STACK_TEXT:
fffff802`3fc82b28 fffff802`3b233f2e : 00000000`0000001a 00000000`00061941 fffff802`4bf91030 00000000`00000009 : nt!KeBugCheckEx
fffff802`3fc82b30 fffff802`3b20ea6d : ffffda0f`cb74d488 00000000`00989680 00000000`00000001 00000000`00000000 : nt!MmAccessFault+0x1fb65e
fffff802`3fc82cd0 fffff802`4bf81180 : ffffda0f`cb75e500 00000000`00000000 fffff802`3fc82ed0 00000000`00000002 : nt!KiPageFault+0x36d
fffff802`3fc82e60 fffff802`4bf888fb : fffff802`4bf8f000 fffff802`3fc82f00 00000000`00000010 ffffda0f`c88dd000 : i8042prt!WPP_RECORDER_SF_+0x70
fffff802`3fc82ea0 fffff802`3b0d7e65 : ffff8c81`98c3fb40 00000000`00006000 fffff802`37702100 fffff802`3fc82f01 : i8042prt!I8042MouseInterruptService+0x6b
fffff802`3fc82f40 fffff802`3b2006af : fffff802`3fc74c90 ffff8c81`98c3fb40 00000000`0000099f fffff802`3b20092a : nt!KiCallInterruptServiceRoutine+0xa5
fffff802`3fc82f90 fffff802`3b200977 : fffff802`3fc74d30 00000000`00000001 00000000`00000046 fffff802`3b068718 : nt!KiInterruptSubDispatch+0x11f
fffff802`3fc74c10 fffff802`3b2033aa : 00000000`00000000 fffff802`3bb27a00 ffffda0f`ce731080 00000000`0000099f : nt!KiInterruptDispatch+0x37
fffff802`3fc74da0 00000000`00000000 : fffff802`3fc75000 fffff802`3fc6f000 00000000`00000000 00000000`00000000 : nt!KiIdleLoop+0x5a
MODULE_NAME: hardware
IMAGE_NAME: hardware_ram
STACK_COMMAND: .process /r /p 0xfffff8023bb24a00; .thread 0xfffff8023bb27a00 ; kb
FAILURE_BUCKET_ID: 0x1a_61941_PAGE_TABLE_RESERVED_BITS_SET_IMAGE_hardware_ram
OSNAME: Windows 10
FAILURE_ID_HASH: {c6e5c6cf-692e-7852-5dc5-b74944540fc0}
PnpActivityTime : 133831366242879078
PnpProblemCode : 24
PnpVetoType : 0
DeviceId : STORAGE\Volume\{323dd847-d195-11ef-832c-806e6f6e6963}#0000000EA4000000
VetoString :
Arguments:
Arg1: ffff928fbe3dd340, Process object or thread object
Debugging Details:
Value: 1781
Value: 7439
Value: 0
Value: 1
Value: 4
Value: 265
Value: 1412
Value: 90
Value: 1.2408.27.1
Value: 0xef
Value: 0xef
Value: bba75080
Value: wininit.exe
Value: 0xEF_wininit.exe_BUGCHECK_CRITICAL_PROCESS_bba75080_nt!PspCatchCriticalBreak
Key : Failure.Hash
Value: {f446fd33-a34c-fc31-43eb-fe1537f976c1}
Key : WER.OS.Branch
Value: vb_release
Value: 10.0.19041.1
BUGCHECK_CODE: ef
BUGCHECK_P1: ffff928fbe3dd340
BUGCHECK_P2: 0
BUGCHECK_P3: 0
BUGCHECK_P4: 0
FILE_IN_CAB: 020125-18968-01.dmp
FAULTING_THREAD: ffff928fbba75080
ERROR_CODE: (NTSTATUS) 0xbba75080 - <Unable to get error code text>
BLACKBOXWINLOGON: 1
STACK_TEXT:
ffff840d`67c46ab8 fffff806`7550ed12 : 00000000`000000ef ffff928f`be3dd340 00000000`00000000 00000000`00000000 : nt!KeBugCheckEx
ffff840d`67c46ac0 fffff806`75416e13 : ffff928f`bba75080 ffff928f`be3dd778 00000000`00000000 fffff806`75184247 : nt!PspCatchCriticalBreak+0x10e
ffff840d`67c46b60 fffff806`752b0adf : 00000000`00000000 00000000`00000000 ffff928f`be3dd340 00000000`00000000 : nt!PspTerminateAllThreads+0x15ab73
ffff840d`67c46bd0 fffff806`75013108 : ffff928f`be3dd340 ffff928f`bba75080 ffff840d`67c46cc0 00000000`00000000 : nt!NtTerminateProcess+0x16f
ffff840d`67c46c40 00007ffc`aceada74 : 00007ffc`ace6ef24 00000000`000000ff 00000000`00000000 00000000`00000000 : nt!KiSystemServiceExitPico+0x41c
00000016`be48f998 00007ffc`ace6ef24 : 00000000`000000ff 00000000`00000000 00000000`00000000 00007ffc`aa58cd80 : 0x00007ffc`aceada74
00000016`be48f9a0 00000000`000000ff : 00000000`00000000 00000000`00000000 00007ffc`aa58cd80 00000000`00000005 : 0x00007ffc`ace6ef24
00000016`be48f9a8 00000000`00000000 : 00000000`00000000 00007ffc`aa58cd80 00000000`00000005 00007ffc`aca5e3eb : 0xff
MODULE_NAME: nt
STACK_COMMAND: .process /r /p 0xffff928fbe3dd340; .thread 0xffff928fbba75080 ; kb
FAILURE_BUCKET_ID: 0xEF_wininit.exe_BUGCHECK_CRITICAL_PROCESS_bba75080_nt!PspCatchCriticalBreak
OSNAME: Windows 10
FAILURE_ID_HASH: {f446fd33-a34c-fc31-43eb-fe1537f976c1}
PnpActivityTime : 133828731149520028
PnpProblemCode : 24
PnpVetoType : 0
DeviceId : SW\{96E080C7-143C-11D1-B40F-00A0C9223196}\{3C0D501A-140B-11D1-B40F-00A0C9223196}
VetoString :
Arguments:
Arg1: ffff80045179c080, Process object or thread object
Debugging Details:
*** WARNING: Check Image - Checksum mismatch - Dump: 0x23298, File: 0x1d94d - C:\ProgramData\Dbg\sym\crashdmp.sys\F69BF9371e000\crashdmp.sys
Value: 1609
Value: 6238
Value: 0
Value: 1
Value: 0
Value: 218
Value: 1431
Value: 85
Value: 1.2408.27.1
Value: 0xef
Value: 0xef
Value: 595bf2c0
Value: wininit.exe
Value: 0xEF_wininit.exe_BUGCHECK_CRITICAL_PROCESS_595bf2c0_nt!PspCatchCriticalBreak
Key : Failure.Hash
Value: {23191bec-a281-461b-7282-91adb0e9854d}
Key : WER.OS.Branch
Value: vb_release
Value: 10.0.19041.1
BUGCHECK_CODE: ef
BUGCHECK_P1: ffff80045179c080
BUGCHECK_P2: 0
BUGCHECK_P3: 0
BUGCHECK_P4: 0
FILE_IN_CAB: 020225-22203-01.dmp
FAULTING_THREAD: ffff8004595bf2c0
ERROR_CODE: (NTSTATUS) 0x595bf2c0 - <Unable to get error code text>
BLACKBOXACPI: 1 (!blackboxacpi)
BLACKBOXWINLOGON: 1
STACK_TEXT:
fffff108`c419aab8 fffff800`76d0ed12 : 00000000`000000ef ffff8004`5179c080 00000000`00000000 00000000`00000000 : nt!KeBugCheckEx
fffff108`c419aac0 fffff800`76c16e13 : ffff8004`595bf2c0 ffff8004`5179c4b8 00000000`00000000 fffff800`76984247 : nt!PspCatchCriticalBreak+0x10e
fffff108`c419ab60 fffff800`76ab0adf : 00000000`00000000 00000000`00000000 ffff8004`5179c080 00000000`00000000 : nt!PspTerminateAllThreads+0x15ab73
fffff108`c419abd0 fffff800`76813108 : ffff8004`5179c080 ffff8004`595bf2c0 fffff108`c419acc0 00000000`00000000 : nt!NtTerminateProcess+0x16f
fffff108`c419ac40 00007ffb`1cc2da74 : 00007ffb`1cbeef24 00000000`000000ff 00000000`00000000 00000000`00000000 : nt!KiSystemServiceExitPico+0x41c
000000b6`4dcdfd08 00007ffb`1cbeef24 : 00000000`000000ff 00000000`00000000 00000000`00000000 00007ffb`1a3dcd80 : 0x00007ffb`1cc2da74
000000b6`4dcdfd10 00000000`000000ff : 00000000`00000000 00000000`00000000 00007ffb`1a3dcd80 00000000`00000005 : 0x00007ffb`1cbeef24
000000b6`4dcdfd18 00000000`00000000 : 00000000`00000000 00007ffb`1a3dcd80 00000000`00000005 00007ffb`1b4fe3eb : 0xff
MODULE_NAME: nt
STACK_COMMAND: .process /r /p 0xffff80045179c080; .thread 0xffff8004595bf2c0 ; kb
FAILURE_BUCKET_ID: 0xEF_wininit.exe_BUGCHECK_CRITICAL_PROCESS_595bf2c0_nt!PspCatchCriticalBreak
OSNAME: Windows 10
FAILURE_ID_HASH: {23191bec-a281-461b-7282-91adb0e9854d}
PnpActivityTime : 133829594787275483
PnpProblemCode : 24
PnpVetoType : 0
DeviceId : STORAGE\Volume\{516d7688-d290-11ef-833a-2c768ad85011}#00000030D3CBAE00
VetoString :
