MEMORY_MANAGEMENT (1a)
# Any other values for parameter 1 must be individually examined.
Arguments:
Arg1: 0000000000061941, The subtype of the BugCheck.
Arg2: 000048f00005c180
Arg3: 000000000000000d
Arg4: ffffd00b1ca1f460
Debugging Details:
KEY_VALUES_STRING: 1
Key : Analysis.CPU.mSec
Value: 843
Key : Analysis.Elapsed.mSec
Value: 2009
Key : Analysis.IO.Other.Mb
Value: 0
Key : Analysis.IO.Read.Mb
Value: 1
Key : Analysis.IO.Write.Mb
Value: 0
Key : Analysis.Init.CPU.mSec
Value: 312
Value: 3020
Value: 82
Key : Analysis.Version.DbgEng
Value: 10.0.27829.1001
Key : Analysis.Version.Description
Value: 10.2503.24.01 amd64fre
Key : Analysis.Version.Ext
Value: 1.2503.24.1
Key : Bugcheck.Code.LegacyAPI
Value: 0x1a
Key : Bugcheck.Code.TargetModel
Value: 0x1a
Key : Dump.Attributes.AsUlong
Value: 0x21808
Key : Dump.Attributes.DiagDataWrittenToHeader
Value: 1
Key : Dump.Attributes.ErrorCode
Value: 0x0
Key : Dump.Attributes.KernelGeneratedTriageDump
Value: 1
Key : Dump.Attributes.LastLine
Key : Dump.Attributes.ProgressPercentage
Value: 0
Key : Failure.Bucket
Value: 0x1a_61941_PAGE_TABLE_RESERVED_BITS_SET_IMAGE_hardware_ram
Key : Failure.Hash
Value: {c6e5c6cf-692e-7852-5dc5-b74944540fc0}
Key : Hypervisor.Enlightenments.ValueHex
Value: 0x7497cf94
Key : Hypervisor.Flags.AnyHypervisorPresent
Value: 1
Key : Hypervisor.Flags.ApicEnlightened
Value: 1
Key : Hypervisor.Flags.ApicVirtualizationAvailable
Value: 0
Key : Hypervisor.Flags.AsyncMemoryHint
Value: 0
Key : Hypervisor.Flags.CoreSchedulerRequested
Value: 0
Key : Hypervisor.Flags.CpuManager
Value: 1
Key : Hypervisor.Flags.DeprecateAutoEoi
Value: 0
Key : Hypervisor.Flags.DynamicCpuDisabled
Value: 1
Key : Hypervisor.Flags.Epf
Value: 0
Key : Hypervisor.Flags.ExtendedProcessorMasks
Value: 1
Key : Hypervisor.Flags.HardwareMbecAvailable
Value: 1
Key : Hypervisor.Flags.MaxBankNumber
Value: 0
Key : Hypervisor.Flags.MemoryZeroingControl
Value: 0
Key : Hypervisor.Flags.NoExtendedRangeFlush
Value: 0
Key : Hypervisor.Flags.NoNonArchCoreSharing
Value: 1
Key : Hypervisor.Flags.Phase0InitDone
Value: 1
Key : Hypervisor.Flags.PowerSchedulerQos
Value: 0
Key : Hypervisor.Flags.RootScheduler
Value: 0
Key : Hypervisor.Flags.SynicAvailable
Value: 1
Key : Hypervisor.Flags.UseQpcBias
Value: 0
Key : Hypervisor.Flags.Value
Value: 38408431
Key : Hypervisor.Flags.ValueHex
Value: 0x24a10ef
Key : Hypervisor.Flags.VpAssistPage
Value: 1
Key : Hypervisor.Flags.VsmAvailable
Value: 1
Key : Hypervisor.RootFlags.AccessStats
Value: 1
Key : Hypervisor.RootFlags.CrashdumpEnlightened
Value: 1
Key : Hypervisor.RootFlags.CreateVirtualProcessor
Value: 1
Key : Hypervisor.RootFlags.DisableHyperthreading
Value: 0
Key : Hypervisor.RootFlags.HostTimelineSync
Value: 1
Key : Hypervisor.RootFlags.HypervisorDebuggingEnabled
Value: 0
Key : Hypervisor.RootFlags.IsHyperV
Value: 1
Key : Hypervisor.RootFlags.LivedumpEnlightened
Value: 1
Key : Hypervisor.RootFlags.MapDeviceInterrupt
Value: 1
Key : Hypervisor.RootFlags.MceEnlightened
Value: 1
Key : Hypervisor.RootFlags.Nested
Value: 0
Key : Hypervisor.RootFlags.StartLogicalProcessor
Value: 1
Key : Hypervisor.RootFlags.Value
Value: 1015
Key : Hypervisor.RootFlags.ValueHex
Value: 0x3f7
BUGCHECK_CODE: 1a
BUGCHECK_P1: 61941
BUGCHECK_P2: 48f00005c180
BUGCHECK_P3: d
BUGCHECK_P4: ffffd00b1ca1f460
FILE_IN_CAB: 071625-16453-01.dmp
TAG_NOT_DEFINED_202b: *** Unknown TAG in analysis list 202b
DUMP_FILE_ATTRIBUTES: 0x21808
Kernel Generated Triage Dump
FAULTING_THREAD: ffff808d149cb080
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: Aura Wallpaper
STACK_TEXT:
ffffd00b`1ca1f2e8 fffff803`d0429a00 : 00000000`0000001a 00000000`00061941 000048f0`0005c180 00000000`0000000d : nt!KeBugCheckEx
ffffd00b`1ca1f2f0 fffff803`d08b47cb : ffff808d`149cb080 000048f0`0009c0e8 00000037`173ff3d0 00000000`00000000 : nt!MmAccessFault+0x5c0
ffffd00b`1ca1f460 00007ffe`e6646f80 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiPageFault+0x38b
00000037`173ff218 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ffe`e6646f80
MODULE_NAME: hardware
IMAGE_NAME: hardware_ram
STACK_COMMAND: .process /r /p 0xffff808d148bc080; .thread 0xffff808d149cb080 ; kb
FAILURE_BUCKET_ID: 0x1a_61941_PAGE_TABLE_RESERVED_BITS_SET_IMAGE_hardware_ram
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {c6e5c6cf-692e-7852-5dc5-b74944540fc0}
Arguments:
Arg2: 00000236b085003c
Arg3: 000000000000000f
Arg4: ffffc903345ff460
Debugging Details:
Value: 843
Value: 4130
Value: 2
Value: 1
Value: 24
Value: 343
Value: 11669
Value: 83
Value: 1.2503.24.1
Value: 0x1a
Value: 0x1a
Value: 0x21808
Value: 1
Value: 0x0
Value: 1
Value: 0
Key : Failure.Hash
Value: 0x7497cf94
Value: 1
Value: 1
Value: 0
Value: 0
Value: 0
Value: 1
Value: 0
Value: 1
Value: 0
Value: 1
Value: 1
Value: 0
Value: 0
Value: 0
Value: 1
Value: 1
Value: 0
Value: 0
Value: 1
Value: 0
Value: 38408431
Value: 0x24a10ef
Value: 1
Value: 1
Value: 1
Value: 1
Value: 1
Value: 0
Value: 1
Value: 0
Value: 1
Value: 1
Value: 1
Value: 1
Value: 0
Value: 1
Value: 1015
Value: 0x3f7
BUGCHECK_CODE: 1a
BUGCHECK_P1: 61941
BUGCHECK_P2: 236b085003c
BUGCHECK_P3: f
BUGCHECK_P4: ffffc903345ff460
FILE_IN_CAB: 072425-17062-01.dmp
FAULTING_THREAD: ffffde01e0013080
BLACKBOXWINLOGON: 1
PROCESS_NAME: cod.exe
STACK_TEXT:
ffffc903`345ff2e8 fffff805`922b0310 : 00000000`0000001a 00000000`00061941 00000236`b085003c 00000000`0000000f : nt!KeBugCheckEx
ffffc903`345ff2f0 fffff805`926b35cb : 00000028`57eb6b30 0000020a`f96f6c50 0000020a`f9730000 00007ff6`45178800 : nt!MmAccessFault+0x5c0
ffffc903`345ff460 00007ff6`3b579b2d : 0000020a`f972fe90 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiPageFault+0x38b
00000033`466fd990 0000020a`f972fe90 : 00000000`00000000 00000000`00000000 00000000`00000000 00000033`466fda30 : 0x00007ff6`3b579b2d
00000033`466fd998 00000000`00000000 : 00000000`00000000 00000000`00000000 00000033`466fda30 00000033`466fda40 : 0x0000020a`f972fe90
STACK_COMMAND: .process /r /p 0xffffde01e0cd0080; .thread 0xffffde01e0013080 ; kb
OSNAME: Windows 10
DRIVER_POWER_STATE_FAILURE (9f)
A driver has failed to complete a power IRP within a specific time.
Arguments:
Arg1: 0000000000000003, A device object has been blocking an IRP for too long a time
Arg2: ffffbc0685111060, Physical Device Object of the stack
Arg3: fffff980c2a8f000, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the Functional Device Object of the stack
Arg4: ffffbc068512eaa0, The blocked IRP
Debugging Details:
Value: 843
Value: 6899
Value: 0
Value: 1
Value: 3
Value: 468
Value: 3485
Value: 91
Value: 1.2503.24.1
Value: 0x9f
Value: 0x9f
Value: 0x21808
Value: 1
Value: 0x0
Value: 1
Value: 0
Value: 0x9F_3_AML!_SB.PCI0.GPP8.U4UP._STA_ACPI_IMAGE_pci.sys
Key : Failure.Hash
Value: {0591a21b-6ede-bd3f-5f3c-7dd9aa2b98ab}
Value: 0x7497cf94
Value: 1
Value: 1
Value: 0
Value: 0
Value: 0
Value: 1
Value: 0
Value: 1
Value: 0
Value: 1
Value: 1
Value: 0
Value: 0
Value: 0
Value: 1
Value: 1
Value: 0
Value: 0
Value: 1
Value: 0
Value: 38408431
Value: 0x24a10ef
Value: 1
Value: 1
Value: 1
Value: 1
Value: 1
Value: 0
Value: 1
Value: 0
Value: 1
Value: 1
Value: 1
Value: 1
Value: 0
Value: 1
Value: 1015
Value: 0x3f7
BUGCHECK_CODE: 9f
BUGCHECK_P1: 3
BUGCHECK_P2: ffffbc0685111060
BUGCHECK_P3: fffff980c2a8f000
BUGCHECK_P4: ffffbc068512eaa0
FILE_IN_CAB: 072325-14265-01.dmp
FAULTING_THREAD: ffffbc0683571040
DRVPOWERSTATE_SUBCODE: 3
IMAGE_NAME: pci.sys
MODULE_NAME: pci
FAULTING_MODULE: fffff8020e9f0000 pci
BLACKBOXACPI: 1 (!blackboxacpi)
BLACKBOXWINLOGON: 1
PROCESS_NAME: System
STACK_TEXT:
fffff980`c2a8efa8 fffff802`7c7cf3ed : 00000000`0000009f 00000000`00000003 ffffbc06`85111060 fffff980`c2a8f000 : nt!KeBugCheckEx
fffff980`c2a8efb0 fffff802`7c7cf1ec : ffffbc06`83571040 fffff980`c2a8f3e0 ffffbc06`852d1358 fffff980`c2a8f189 : nt!PopIrpWatchdogBugcheck+0x1f5
fffff980`c2a8f090 fffff802`7c551b12 : ffffe101`00000008 fffff802`00000001 fffff980`00000000 fffff802`00000002 : nt!PopIrpWatchdog+0xc
fffff980`c2a8f0c0 fffff802`7c5523f5 : 00000000`d146ac56 00000000`0000000f 00000000`daadfc85 ffffe101`25ea2180 : nt!KiProcessExpiredTimerList+0x502
fffff980`c2a8f1f0 fffff802`7c4c8235 : 00000000`00000000 00000000`00000000 ffffe101`25ea2180 ffffbc06`83571040 : nt!KiTimerExpiration+0x2b5
fffff980`c2a8f330 fffff802`7c8a66be : ffffe101`25ea2180 ffffe101`25ea2180 00000000`00000000 00000000`00000000 : nt!KiRetireDpcList+0xc45
fffff980`c2a8f5c0 00000000`00000000 : fffff980`c2a90000 fffff980`c2a89000 00000000`00000000 00000000`00000000 : nt!KiIdleLoop+0x9e
IMAGE_VERSION: 10.0.26100.4484
STACK_COMMAND: .process /r /p 0xfffff8027d1cef80; .thread 0xffffbc0683571040 ; kb
FAILURE_BUCKET_ID: 0x9F_3_AML!_SB.PCI0.GPP8.U4UP._STA_ACPI_IMAGE_pci.sys
OSNAME: Windows 10
FAILURE_ID_HASH: {0591a21b-6ede-bd3f-5f3c-7dd9aa2b98ab}
Followup: MachineOwner
[SMBIOS Data Tables v3.6]
[DMI Version - 0]
[2.0 Calling Convention - No]
[Table Size - 3424 bytes]
Vendor American Megatrends Inc.
BIOS Version 0227
BIOS Release Date 07/23/2024
BIOS ROM Size 1000000
BIOS Characteristics
07: - PCI Supported
11: - Upgradeable FLASH BIOS
15: - CD-Boot Supported
17: - BIOS ROM Socketed
19: - EDD Supported
22: - 360KB Floppy Supported
23: - 1.2MB Floppy Supported
24: - 720KB Floppy Supported
25: - 2.88MB Floppy Supported
32: - BIOS Vendor Reserved
00: - ACPI Supported
01: - USB Legacy Supported
BIOS Major Revision 2
BIOS Minor Revision 27
EC Firmware Major Revision 255
EC Firmware Minor Revision 255
Extended BIOS ROM Size 32 MB
Manufacturer ASUS
Product Name System Product Name
Version System Version
Serial Number System Serial Number
UUID 00000000-0000-0000-0000-000000000000
Wakeup Type Power Switch
SKUNumber SKU
Family To be filled by O.E.M.
Manufacturer ASUSTeK COMPUTER INC.
Product ROG STRIX X870-A GAMING WIFI
Version Rev 1.xx
Serial Number 240842605101071
Asset Tag
Feature Flags 09h
00: - Motherboard
03: - Replaceable
Location Default string
Chassis Handle 0003h
Board Type 0ah - Processor/Memory Module
Number of Child Handles 0
Manufacturer Default string
Chassis Type Desktop
Version Default string
Serial Number
Asset Tag Number
Bootup State Safe
Power Supply State Safe
Thermal State Safe
Security Status None
OEM Defined 0
Height 0U
Number of Power Cords 1
Number of Contained Elements 0
Contained Element Size 3
[Onboard Devices Information (Type 10) - Length 6 - Handle 0004h]
Note: The On Board Device Information (Type 10) struct is obsolete as of SMBIOs spec v2.6 Number of Devices 1
01: Type Video [enabled]
01: Description To Be Filled By O.E.M.
[OEM Strings (Type 11) - Length 5 - Handle 0005h]
Number of Strings 6
1 Default string
2 Default string
3 Default string
4 Default string
5 Default string
6 Default string
[System Configuration Options (Type 12) - Length 5 - Handle 0006h]
[ (Type 256) - Length 59 - Handle 0009h]
[ (Type 256) - Length 9 - Handle 000ah]
[ (Type 256) - Length 31 - Handle 000bh]
[ (Type 256) - Length 26 - Handle 000ch]
[Cache Information (Type 7) - Length 27 - Handle 000dh]
Socket Designation L1 - Cache
Cache Configuration 0180h - WBEnabled Int NonSocketed L1
Maximum Cache Size 0280h - 640K
Installed Size 0280h - 640K
Supported SRAM Type 0010h - Pipeline-Burst
Current SRAM Type 0010h - Pipeline-Burst
Cache Speed 1ns
Error Correction Type Specification Reserved
System Cache Type Unified
Associativity 8-way Set-Associative
Maximum Cache Size 2 280 - 00000640l Kb
Installed Cache Size 2 280 - 00000640l Kb
[Cache Information (Type 7) - Length 27 - Handle 000eh]
Socket Designation L2 - Cache
Cache Configuration 0181h - WBEnabled Int NonSocketed L2
Maximum Cache Size 2000h - 8192K
Installed Size 2000h - 8192K
Cache Speed 1ns
Associativity 16-way Set-Associative
Maximum Cache Size 2 2000 - 00008192l Kb
Installed Cache Size 2 2000 - 00008192l Kb
[Cache Information (Type 7) - Length 27 - Handle 000fh]
Socket Designation L3 - Cache
Cache Configuration 0182h - WBEnabled Int NonSocketed L3
Maximum Cache Size 8600h - 98304K
Installed Size 8600h - 98304K
Cache Speed 1ns
Maximum Cache Size 2 80000600 - 00098304l Kb
Installed Cache Size 2 80000600 - 00098304l Kb
[Processor Information (Type 4) - Length 48 - Handle 0010h]
Socket Designation AM5
Processor Type Central Processor
Processor Family 6bh - AMD Zen Processor Family
Processor Manufacturer Advanced Micro Devices, Inc.
Processor ID 400fb400fffb8b17
Processor Version AMD Ryzen 7 9800X3D 8-Core Processor
Processor Voltage 8dh - 1.3V
External Clock 100MHz
Max Speed 5250MHz
Current Speed 4700MHz
Status Enabled Populated
Processor Upgrade Specification Reserved
L1 Cache Handle 000dh
L2 Cache Handle 000eh
L3 Cache Handle 000fh
Serial Number
Asset Tag Number
Part Number Unknown
Core Count 8
Core Enabled 8
Thread Count 16
Processor Characteristics fc
Enabled Characteristics:
0x 2: 64-bit Capable
0x 3: Multi-Core
0x 4: Hardware Thread
0x 5: Execute Protection
0x 6: Enhanced Virtualization
Processor Family 2 006bh - AMD Zen Processor Family
Core Count 2 8
Core Enabled 2 8
Thread Count 2 16
[ (Type 256) - Length 9 - Handle 0011h]
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 0012h]
[Physical Memory Array (Type 16) - Length 23 - Handle 0013h]
Location 03h - SystemBoard/Motherboard
Use 03h - System Memory
Memory Error Correction 03h - None
Maximum Capacity 134217728KB
Memory Error Inf Handle 0012h
Number of Memory Devices 4
[Memory Array Mapped Address (Type 19) - Length 31 - Handle 0014h]
Starting Address 00000000h
Ending Address 01ffffffh
Memory Array Handle 0013h
Partition Width 02
Extended Starting Address 0000000000000000h
Extended Ending Address 0000000000000000h
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 0015h]
[Memory Device (Type 17) - Length 92 - Handle 0016h]
Memory Error Info Handle 0015h
Total Width [Unknown]
Data Width [Unknown]
Size [Not Populated]
Form Factor 02h - Unknown
Device Set [None]
Device Locator DIMM 0
Bank Locator P0 CHANNEL A
Memory Type 02h - Unknown
Type Detail 0004h - Unknown
Speed 0MHz
Manufacturer Unknown
Serial Number
Asset Tag Number [String Not Specified]
Part Number Unknown
Attributes 0
Extended Size 0
Configured Memory Speed 0
Minimum Voltage 0
Maximum Voltage 0
Configured Voltage 0
Memory Technology 2
Memory Operating Mode Capability 4
Firmware Version 6
Module Manufacturer Id 0
Module Product Id 0
Memory Subsystem Controller Manufacturer Id 0
Memory Subsystem Controller Product Id 0
Non-Volatile Size 0
Volatile Size 0
Cache Size 0
Logical Size 0
Extended Speed 0
Extended Configured Memory Speed 0
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 0017h]
[Memory Device (Type 17) - Length 92 - Handle 0018h]
Memory Error Info Handle 0017h
Total Width 64 bits
Data Width 64 bits
Size 16384MB
Form Factor 09h - DIMM
Device Set [None]
Device Locator DIMM 1
Memory Type 22h - DDR5
Type Detail 4080h - Synchronous Unbuffered (Unregistered)
Speed 4800MHz
Manufacturer G Skill Intl
Serial Number
Part Number F5-6000J2836G16G
Attributes 1
Extended Size 0
Configured Memory Speed 6000
Minimum Voltage 1100
Maximum Voltage 1100
Configured Voltage 1100
Memory Technology 3
Memory Operating Mode Capability 8
Firmware Version 6
Module Manufacturer Id 52484
Module Product Id 0
Non-Volatile Size 0
Volatile Size 0
Cache Size 0
Logical Size 0
Extended Speed 0
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 0019h]
Ending Address 00ffffffh
Memory Device Handle 0018h
Mem Array Mapped Adr Handle 0014h
Partition Row Position [Unknown]
Interleave Position [Unknown]
Interleave Data Depth [Unknown]
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 001ah]
[Memory Device (Type 17) - Length 92 - Handle 001bh]
Memory Error Info Handle 001ah
Device Set [None]
Bank Locator P0 CHANNEL B
Speed 0MHz
Serial Number
Part Number Unknown
Attributes 0
Extended Size 0
Minimum Voltage 0
Maximum Voltage 0
Memory Technology 2
Firmware Version 6
Module Product Id 0
Non-Volatile Size 0
Volatile Size 0
Cache Size 0
Logical Size 0
Extended Speed 0
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 001ch]
[Memory Device (Type 17) - Length 92 - Handle 001dh]
Memory Error Info Handle 001ch
Total Width 64 bits
Data Width 64 bits
Size 16384MB
Device Set [None]
Speed 4800MHz
Serial Number
Attributes 1
Extended Size 0
Memory Technology 3
Firmware Version 6
Module Product Id 0
Non-Volatile Size 0
Volatile Size 0
Cache Size 0
Logical Size 0
Extended Speed 0
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 001eh]
Starting Address 01000000h
Memory Device Handle 001dh
[ (Type 256) - Length 14 - Handle 001fh]
[ (Type 256) - Length 165 - Handle 0020h]
[ (Type 256) - Length 11 - Handle 004bh]
[ (Type 256) - Length 4 - Handle 004dh]
Arguments:
Debugging Details:
Value: 843
Value: 2009
Value: 0
Value: 1
Value: 0
Value: 312
Value: 3020
Value: 82
Value: 1.2503.24.1
Value: 0x1a
Value: 0x1a
Value: 0x21808
Value: 1
Value: 0x0
Value: 1
Value: 0
Key : Failure.Hash
Value: 0x7497cf94
Value: 1
Value: 1
Value: 0
Value: 0
Value: 0
Value: 1
Value: 0
Value: 1
Value: 0
Value: 1
Value: 1
Value: 0
Value: 0
Value: 0
Value: 1
Value: 1
Value: 0
Value: 0
Value: 1
Value: 0
Value: 38408431
Value: 0x24a10ef
Value: 1
Value: 1
Value: 1
Value: 1
Value: 1
Value: 0
Value: 1
Value: 0
Value: 1
Value: 1
Value: 1
Value: 1
Value: 0
Value: 1
Value: 1015
Value: 0x3f7
BUGCHECK_CODE: 1a
BUGCHECK_P1: 61941
BUGCHECK_P3: d
BLACKBOXWINLOGON: 1
STACK_TEXT:
OSNAME: Windows 10
Arguments:
Debugging Details:
Value: 843
Value: 4130
Value: 2
Value: 1
Value: 24
Value: 343
Value: 11669
Value: 83
Value: 1.2503.24.1
Value: 0x1a
Value: 0x1a
Value: 0x21808
Value: 1
Value: 0x0
Value: 1
Value: 0
Key : Failure.Hash
Value: 0x7497cf94
Value: 1
Value: 1
Value: 0
Value: 0
Value: 0
Value: 1
Value: 0
Value: 1
Value: 0
Value: 1
Value: 1
Value: 0
Value: 0
Value: 0
Value: 1
Value: 1
Value: 0
Value: 0
Value: 1
Value: 0
Value: 38408431
Value: 0x24a10ef
Value: 1
Value: 1
Value: 1
Value: 1
Value: 1
Value: 0
Value: 1
Value: 0
Value: 1
Value: 1
Value: 1
Value: 1
Value: 0
Value: 1
Value: 1015
Value: 0x3f7
BUGCHECK_CODE: 1a
BUGCHECK_P1: 61941
BUGCHECK_P3: f
BLACKBOXWINLOGON: 1
STACK_TEXT:
OSNAME: Windows 10
Arguments:
Debugging Details:
Value: 843
Value: 6899
Value: 0
Value: 1
Value: 3
Value: 468
Value: 3485
Value: 91
Value: 1.2503.24.1
Value: 0x9f
Value: 0x9f
Value: 0x21808
Value: 1
Value: 0x0
Value: 1
Value: 0
Key : Failure.Hash
Value: 0x7497cf94
Value: 1
Value: 1
Value: 0
Value: 0
Value: 0
Value: 1
Value: 0
Value: 1
Value: 0
Value: 1
Value: 1
Value: 0
Value: 0
Value: 0
Value: 1
Value: 1
Value: 0
Value: 0
Value: 1
Value: 0
Value: 38408431
Value: 0x24a10ef
Value: 1
Value: 1
Value: 1
Value: 1
Value: 1
Value: 0
Value: 1
Value: 0
Value: 1
Value: 1
Value: 1
Value: 1
Value: 0
Value: 1
Value: 1015
Value: 0x3f7
BUGCHECK_CODE: 9f
BUGCHECK_P1: 3
IMAGE_NAME: pci.sys
MODULE_NAME: pci
BLACKBOXWINLOGON: 1
STACK_TEXT:
OSNAME: Windows 10
[DMI Version - 0]
BIOS Version 0227
07: - PCI Supported
19: - EDD Supported
Manufacturer ASUS
SKUNumber SKU
Version Rev 1.xx
Asset Tag
Feature Flags 09h
00: - Motherboard
03: - Replaceable
Serial Number
Asset Tag Number
Bootup State Safe
Thermal State Safe
OEM Defined 0
Height 0U
Number of Strings 6
1 Default string
2 Default string
3 Default string
4 Default string
5 Default string
6 Default string
Cache Speed 1ns
Cache Speed 1ns
Cache Speed 1ns
Max Speed 5250MHz
Serial Number
Asset Tag Number
Part Number Unknown
Core Count 8
Core Enabled 8
Thread Count 16
0x 3: Multi-Core
Core Count 2 8
Core Enabled 2 8
Thread Count 2 16
Partition Width 02
Device Set [None]
Speed 0MHz
Serial Number
Part Number Unknown
Attributes 0
Extended Size 0
Minimum Voltage 0
Maximum Voltage 0
Memory Technology 2
Firmware Version 6
Module Product Id 0
Non-Volatile Size 0
Volatile Size 0
Cache Size 0
Logical Size 0
Extended Speed 0
Total Width 64 bits
Data Width 64 bits
Size 16384MB
Device Set [None]
Speed 4800MHz
Serial Number
Attributes 1
Extended Size 0
Memory Technology 3
Firmware Version 6
Module Product Id 0
Non-Volatile Size 0
Volatile Size 0
Cache Size 0
Logical Size 0
Extended Speed 0
Device Set [None]
Speed 0MHz
Serial Number
Part Number Unknown
Attributes 0
Extended Size 0
Minimum Voltage 0
Maximum Voltage 0
Memory Technology 2
Firmware Version 6
Module Product Id 0
Non-Volatile Size 0
Volatile Size 0
Cache Size 0
Logical Size 0
Extended Speed 0
Total Width 64 bits
Data Width 64 bits
Size 16384MB
Device Set [None]
Speed 4800MHz
Serial Number
Attributes 1
Extended Size 0
Memory Technology 3
Firmware Version 6
Module Product Id 0
Non-Volatile Size 0
Volatile Size 0
Cache Size 0
Logical Size 0
Extended Speed 0
Teşekkür ederim.BIOS sürümünüz güncel değil, güncelleyin. Sorun devam ederse bellek testi yapın.
Kod:MEMORY_MANAGEMENT (1a) # Any other values for parameter 1 must be individually examined. Arguments: Arg1: 0000000000061941, The subtype of the BugCheck. Arg2: 000048f00005c180 Arg3: 000000000000000d Arg4: ffffd00b1ca1f460 Debugging Details: ------------------ KEY_VALUES_STRING: 1 Key : Analysis.CPU.mSec Value: 843 Key : Analysis.Elapsed.mSec Value: 2009 Key : Analysis.IO.Other.Mb Value: 0 Key : Analysis.IO.Read.Mb Value: 1 Key : Analysis.IO.Write.Mb Value: 0 Key : Analysis.Init.CPU.mSec Value: 312 Key : Analysis.Init.Elapsed.mSec Value: 3020 Key : Analysis.Memory.CommitPeak.Mb Value: 82 Key : Analysis.Version.DbgEng Value: 10.0.27829.1001 Key : Analysis.Version.Description Value: 10.2503.24.01 amd64fre Key : Analysis.Version.Ext Value: 1.2503.24.1 Key : Bugcheck.Code.LegacyAPI Value: 0x1a Key : Bugcheck.Code.TargetModel Value: 0x1a Key : Dump.Attributes.AsUlong Value: 0x21808 Key : Dump.Attributes.DiagDataWrittenToHeader Value: 1 Key : Dump.Attributes.ErrorCode Value: 0x0 Key : Dump.Attributes.KernelGeneratedTriageDump Value: 1 Key : Dump.Attributes.LastLine Value: Dump completed successfully. Key : Dump.Attributes.ProgressPercentage Value: 0 Key : Failure.Bucket Value: 0x1a_61941_PAGE_TABLE_RESERVED_BITS_SET_IMAGE_hardware_ram Key : Failure.Hash Value: {c6e5c6cf-692e-7852-5dc5-b74944540fc0} Key : Hypervisor.Enlightenments.ValueHex Value: 0x7497cf94 Key : Hypervisor.Flags.AnyHypervisorPresent Value: 1 Key : Hypervisor.Flags.ApicEnlightened Value: 1 Key : Hypervisor.Flags.ApicVirtualizationAvailable Value: 0 Key : Hypervisor.Flags.AsyncMemoryHint Value: 0 Key : Hypervisor.Flags.CoreSchedulerRequested Value: 0 Key : Hypervisor.Flags.CpuManager Value: 1 Key : Hypervisor.Flags.DeprecateAutoEoi Value: 0 Key : Hypervisor.Flags.DynamicCpuDisabled Value: 1 Key : Hypervisor.Flags.Epf Value: 0 Key : Hypervisor.Flags.ExtendedProcessorMasks Value: 1 Key : Hypervisor.Flags.HardwareMbecAvailable Value: 1 Key : Hypervisor.Flags.MaxBankNumber Value: 0 Key : Hypervisor.Flags.MemoryZeroingControl Value: 0 Key : Hypervisor.Flags.NoExtendedRangeFlush Value: 0 Key : Hypervisor.Flags.NoNonArchCoreSharing Value: 1 Key : Hypervisor.Flags.Phase0InitDone Value: 1 Key : Hypervisor.Flags.PowerSchedulerQos Value: 0 Key : Hypervisor.Flags.RootScheduler Value: 0 Key : Hypervisor.Flags.SynicAvailable Value: 1 Key : Hypervisor.Flags.UseQpcBias Value: 0 Key : Hypervisor.Flags.Value Value: 38408431 Key : Hypervisor.Flags.ValueHex Value: 0x24a10ef Key : Hypervisor.Flags.VpAssistPage Value: 1 Key : Hypervisor.Flags.VsmAvailable Value: 1 Key : Hypervisor.RootFlags.AccessStats Value: 1 Key : Hypervisor.RootFlags.CrashdumpEnlightened Value: 1 Key : Hypervisor.RootFlags.CreateVirtualProcessor Value: 1 Key : Hypervisor.RootFlags.DisableHyperthreading Value: 0 Key : Hypervisor.RootFlags.HostTimelineSync Value: 1 Key : Hypervisor.RootFlags.HypervisorDebuggingEnabled Value: 0 Key : Hypervisor.RootFlags.IsHyperV Value: 1 Key : Hypervisor.RootFlags.LivedumpEnlightened Value: 1 Key : Hypervisor.RootFlags.MapDeviceInterrupt Value: 1 Key : Hypervisor.RootFlags.MceEnlightened Value: 1 Key : Hypervisor.RootFlags.Nested Value: 0 Key : Hypervisor.RootFlags.StartLogicalProcessor Value: 1 Key : Hypervisor.RootFlags.Value Value: 1015 Key : Hypervisor.RootFlags.ValueHex Value: 0x3f7 BUGCHECK_CODE: 1a BUGCHECK_P1: 61941 BUGCHECK_P2: 48f00005c180 BUGCHECK_P3: d BUGCHECK_P4: ffffd00b1ca1f460 FILE_IN_CAB: 071625-16453-01.dmp TAG_NOT_DEFINED_202b: *** Unknown TAG in analysis list 202b DUMP_FILE_ATTRIBUTES: 0x21808 Kernel Generated Triage Dump FAULTING_THREAD: ffff808d149cb080 BLACKBOXBSD: 1 (!blackboxbsd) BLACKBOXNTFS: 1 (!blackboxntfs) BLACKBOXPNP: 1 (!blackboxpnp) BLACKBOXWINLOGON: 1 CUSTOMER_CRASH_COUNT: 1 PROCESS_NAME: Aura Wallpaper STACK_TEXT: ffffd00b`1ca1f2e8 fffff803`d0429a00 : 00000000`0000001a 00000000`00061941 000048f0`0005c180 00000000`0000000d : nt!KeBugCheckEx ffffd00b`1ca1f2f0 fffff803`d08b47cb : ffff808d`149cb080 000048f0`0009c0e8 00000037`173ff3d0 00000000`00000000 : nt!MmAccessFault+0x5c0 ffffd00b`1ca1f460 00007ffe`e6646f80 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiPageFault+0x38b 00000037`173ff218 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ffe`e6646f80 MODULE_NAME: hardware IMAGE_NAME: hardware_ram STACK_COMMAND: .process /r /p 0xffff808d148bc080; .thread 0xffff808d149cb080 ; kb FAILURE_BUCKET_ID: 0x1a_61941_PAGE_TABLE_RESERVED_BITS_SET_IMAGE_hardware_ram OSPLATFORM_TYPE: x64 OSNAME: Windows 10 FAILURE_ID_HASH: {c6e5c6cf-692e-7852-5dc5-b74944540fc0} MEMORY_MANAGEMENT (1a) # Any other values for parameter 1 must be individually examined. Arguments: Arg1: 0000000000061941, The subtype of the BugCheck. Arg2: 00000236b085003c Arg3: 000000000000000f Arg4: ffffc903345ff460 Debugging Details: ------------------ KEY_VALUES_STRING: 1 Key : Analysis.CPU.mSec Value: 843 Key : Analysis.Elapsed.mSec Value: 4130 Key : Analysis.IO.Other.Mb Value: 2 Key : Analysis.IO.Read.Mb Value: 1 Key : Analysis.IO.Write.Mb Value: 24 Key : Analysis.Init.CPU.mSec Value: 343 Key : Analysis.Init.Elapsed.mSec Value: 11669 Key : Analysis.Memory.CommitPeak.Mb Value: 83 Key : Analysis.Version.DbgEng Value: 10.0.27829.1001 Key : Analysis.Version.Description Value: 10.2503.24.01 amd64fre Key : Analysis.Version.Ext Value: 1.2503.24.1 Key : Bugcheck.Code.LegacyAPI Value: 0x1a Key : Bugcheck.Code.TargetModel Value: 0x1a Key : Dump.Attributes.AsUlong Value: 0x21808 Key : Dump.Attributes.DiagDataWrittenToHeader Value: 1 Key : Dump.Attributes.ErrorCode Value: 0x0 Key : Dump.Attributes.KernelGeneratedTriageDump Value: 1 Key : Dump.Attributes.LastLine Value: Dump completed successfully. Key : Dump.Attributes.ProgressPercentage Value: 0 Key : Failure.Bucket Value: 0x1a_61941_PAGE_TABLE_RESERVED_BITS_SET_IMAGE_hardware_ram Key : Failure.Hash Value: {c6e5c6cf-692e-7852-5dc5-b74944540fc0} Key : Hypervisor.Enlightenments.ValueHex Value: 0x7497cf94 Key : Hypervisor.Flags.AnyHypervisorPresent Value: 1 Key : Hypervisor.Flags.ApicEnlightened Value: 1 Key : Hypervisor.Flags.ApicVirtualizationAvailable Value: 0 Key : Hypervisor.Flags.AsyncMemoryHint Value: 0 Key : Hypervisor.Flags.CoreSchedulerRequested Value: 0 Key : Hypervisor.Flags.CpuManager Value: 1 Key : Hypervisor.Flags.DeprecateAutoEoi Value: 0 Key : Hypervisor.Flags.DynamicCpuDisabled Value: 1 Key : Hypervisor.Flags.Epf Value: 0 Key : Hypervisor.Flags.ExtendedProcessorMasks Value: 1 Key : Hypervisor.Flags.HardwareMbecAvailable Value: 1 Key : Hypervisor.Flags.MaxBankNumber Value: 0 Key : Hypervisor.Flags.MemoryZeroingControl Value: 0 Key : Hypervisor.Flags.NoExtendedRangeFlush Value: 0 Key : Hypervisor.Flags.NoNonArchCoreSharing Value: 1 Key : Hypervisor.Flags.Phase0InitDone Value: 1 Key : Hypervisor.Flags.PowerSchedulerQos Value: 0 Key : Hypervisor.Flags.RootScheduler Value: 0 Key : Hypervisor.Flags.SynicAvailable Value: 1 Key : Hypervisor.Flags.UseQpcBias Value: 0 Key : Hypervisor.Flags.Value Value: 38408431 Key : Hypervisor.Flags.ValueHex Value: 0x24a10ef Key : Hypervisor.Flags.VpAssistPage Value: 1 Key : Hypervisor.Flags.VsmAvailable Value: 1 Key : Hypervisor.RootFlags.AccessStats Value: 1 Key : Hypervisor.RootFlags.CrashdumpEnlightened Value: 1 Key : Hypervisor.RootFlags.CreateVirtualProcessor Value: 1 Key : Hypervisor.RootFlags.DisableHyperthreading Value: 0 Key : Hypervisor.RootFlags.HostTimelineSync Value: 1 Key : Hypervisor.RootFlags.HypervisorDebuggingEnabled Value: 0 Key : Hypervisor.RootFlags.IsHyperV Value: 1 Key : Hypervisor.RootFlags.LivedumpEnlightened Value: 1 Key : Hypervisor.RootFlags.MapDeviceInterrupt Value: 1 Key : Hypervisor.RootFlags.MceEnlightened Value: 1 Key : Hypervisor.RootFlags.Nested Value: 0 Key : Hypervisor.RootFlags.StartLogicalProcessor Value: 1 Key : Hypervisor.RootFlags.Value Value: 1015 Key : Hypervisor.RootFlags.ValueHex Value: 0x3f7 BUGCHECK_CODE: 1a BUGCHECK_P1: 61941 BUGCHECK_P2: 236b085003c BUGCHECK_P3: f BUGCHECK_P4: ffffc903345ff460 FILE_IN_CAB: 072425-17062-01.dmp TAG_NOT_DEFINED_202b: *** Unknown TAG in analysis list 202b DUMP_FILE_ATTRIBUTES: 0x21808 Kernel Generated Triage Dump FAULTING_THREAD: ffffde01e0013080 BLACKBOXBSD: 1 (!blackboxbsd) BLACKBOXNTFS: 1 (!blackboxntfs) BLACKBOXPNP: 1 (!blackboxpnp) BLACKBOXWINLOGON: 1 CUSTOMER_CRASH_COUNT: 1 PROCESS_NAME: cod.exe STACK_TEXT: ffffc903`345ff2e8 fffff805`922b0310 : 00000000`0000001a 00000000`00061941 00000236`b085003c 00000000`0000000f : nt!KeBugCheckEx ffffc903`345ff2f0 fffff805`926b35cb : 00000028`57eb6b30 0000020a`f96f6c50 0000020a`f9730000 00007ff6`45178800 : nt!MmAccessFault+0x5c0 ffffc903`345ff460 00007ff6`3b579b2d : 0000020a`f972fe90 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiPageFault+0x38b 00000033`466fd990 0000020a`f972fe90 : 00000000`00000000 00000000`00000000 00000000`00000000 00000033`466fda30 : 0x00007ff6`3b579b2d 00000033`466fd998 00000000`00000000 : 00000000`00000000 00000000`00000000 00000033`466fda30 00000033`466fda40 : 0x0000020a`f972fe90 MODULE_NAME: hardware IMAGE_NAME: hardware_ram STACK_COMMAND: .process /r /p 0xffffde01e0cd0080; .thread 0xffffde01e0013080 ; kb FAILURE_BUCKET_ID: 0x1a_61941_PAGE_TABLE_RESERVED_BITS_SET_IMAGE_hardware_ram OSPLATFORM_TYPE: x64 OSNAME: Windows 10 FAILURE_ID_HASH: {c6e5c6cf-692e-7852-5dc5-b74944540fc0} DRIVER_POWER_STATE_FAILURE (9f) A driver has failed to complete a power IRP within a specific time. Arguments: Arg1: 0000000000000003, A device object has been blocking an IRP for too long a time Arg2: ffffbc0685111060, Physical Device Object of the stack Arg3: fffff980c2a8f000, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the Functional Device Object of the stack Arg4: ffffbc068512eaa0, The blocked IRP Debugging Details: ------------------ KEY_VALUES_STRING: 1 Key : Analysis.CPU.mSec Value: 843 Key : Analysis.Elapsed.mSec Value: 6899 Key : Analysis.IO.Other.Mb Value: 0 Key : Analysis.IO.Read.Mb Value: 1 Key : Analysis.IO.Write.Mb Value: 3 Key : Analysis.Init.CPU.mSec Value: 468 Key : Analysis.Init.Elapsed.mSec Value: 3485 Key : Analysis.Memory.CommitPeak.Mb Value: 91 Key : Analysis.Version.DbgEng Value: 10.0.27829.1001 Key : Analysis.Version.Description Value: 10.2503.24.01 amd64fre Key : Analysis.Version.Ext Value: 1.2503.24.1 Key : Bugcheck.Code.LegacyAPI Value: 0x9f Key : Bugcheck.Code.TargetModel Value: 0x9f Key : Dump.Attributes.AsUlong Value: 0x21808 Key : Dump.Attributes.DiagDataWrittenToHeader Value: 1 Key : Dump.Attributes.ErrorCode Value: 0x0 Key : Dump.Attributes.KernelGeneratedTriageDump Value: 1 Key : Dump.Attributes.LastLine Value: Dump completed successfully. Key : Dump.Attributes.ProgressPercentage Value: 0 Key : Failure.Bucket Value: 0x9F_3_AML!_SB.PCI0.GPP8.U4UP._STA_ACPI_IMAGE_pci.sys Key : Failure.Hash Value: {0591a21b-6ede-bd3f-5f3c-7dd9aa2b98ab} Key : Hypervisor.Enlightenments.ValueHex Value: 0x7497cf94 Key : Hypervisor.Flags.AnyHypervisorPresent Value: 1 Key : Hypervisor.Flags.ApicEnlightened Value: 1 Key : Hypervisor.Flags.ApicVirtualizationAvailable Value: 0 Key : Hypervisor.Flags.AsyncMemoryHint Value: 0 Key : Hypervisor.Flags.CoreSchedulerRequested Value: 0 Key : Hypervisor.Flags.CpuManager Value: 1 Key : Hypervisor.Flags.DeprecateAutoEoi Value: 0 Key : Hypervisor.Flags.DynamicCpuDisabled Value: 1 Key : Hypervisor.Flags.Epf Value: 0 Key : Hypervisor.Flags.ExtendedProcessorMasks Value: 1 Key : Hypervisor.Flags.HardwareMbecAvailable Value: 1 Key : Hypervisor.Flags.MaxBankNumber Value: 0 Key : Hypervisor.Flags.MemoryZeroingControl Value: 0 Key : Hypervisor.Flags.NoExtendedRangeFlush Value: 0 Key : Hypervisor.Flags.NoNonArchCoreSharing Value: 1 Key : Hypervisor.Flags.Phase0InitDone Value: 1 Key : Hypervisor.Flags.PowerSchedulerQos Value: 0 Key : Hypervisor.Flags.RootScheduler Value: 0 Key : Hypervisor.Flags.SynicAvailable Value: 1 Key : Hypervisor.Flags.UseQpcBias Value: 0 Key : Hypervisor.Flags.Value Value: 38408431 Key : Hypervisor.Flags.ValueHex Value: 0x24a10ef Key : Hypervisor.Flags.VpAssistPage Value: 1 Key : Hypervisor.Flags.VsmAvailable Value: 1 Key : Hypervisor.RootFlags.AccessStats Value: 1 Key : Hypervisor.RootFlags.CrashdumpEnlightened Value: 1 Key : Hypervisor.RootFlags.CreateVirtualProcessor Value: 1 Key : Hypervisor.RootFlags.DisableHyperthreading Value: 0 Key : Hypervisor.RootFlags.HostTimelineSync Value: 1 Key : Hypervisor.RootFlags.HypervisorDebuggingEnabled Value: 0 Key : Hypervisor.RootFlags.IsHyperV Value: 1 Key : Hypervisor.RootFlags.LivedumpEnlightened Value: 1 Key : Hypervisor.RootFlags.MapDeviceInterrupt Value: 1 Key : Hypervisor.RootFlags.MceEnlightened Value: 1 Key : Hypervisor.RootFlags.Nested Value: 0 Key : Hypervisor.RootFlags.StartLogicalProcessor Value: 1 Key : Hypervisor.RootFlags.Value Value: 1015 Key : Hypervisor.RootFlags.ValueHex Value: 0x3f7 BUGCHECK_CODE: 9f BUGCHECK_P1: 3 BUGCHECK_P2: ffffbc0685111060 BUGCHECK_P3: fffff980c2a8f000 BUGCHECK_P4: ffffbc068512eaa0 FILE_IN_CAB: 072325-14265-01.dmp TAG_NOT_DEFINED_202b: *** Unknown TAG in analysis list 202b DUMP_FILE_ATTRIBUTES: 0x21808 Kernel Generated Triage Dump FAULTING_THREAD: ffffbc0683571040 DRVPOWERSTATE_SUBCODE: 3 IMAGE_NAME: pci.sys MODULE_NAME: pci FAULTING_MODULE: fffff8020e9f0000 pci BLACKBOXACPI: 1 (!blackboxacpi) BLACKBOXBSD: 1 (!blackboxbsd) BLACKBOXNTFS: 1 (!blackboxntfs) BLACKBOXWINLOGON: 1 CUSTOMER_CRASH_COUNT: 1 PROCESS_NAME: System STACK_TEXT: fffff980`c2a8efa8 fffff802`7c7cf3ed : 00000000`0000009f 00000000`00000003 ffffbc06`85111060 fffff980`c2a8f000 : nt!KeBugCheckEx fffff980`c2a8efb0 fffff802`7c7cf1ec : ffffbc06`83571040 fffff980`c2a8f3e0 ffffbc06`852d1358 fffff980`c2a8f189 : nt!PopIrpWatchdogBugcheck+0x1f5 fffff980`c2a8f090 fffff802`7c551b12 : ffffe101`00000008 fffff802`00000001 fffff980`00000000 fffff802`00000002 : nt!PopIrpWatchdog+0xc fffff980`c2a8f0c0 fffff802`7c5523f5 : 00000000`d146ac56 00000000`0000000f 00000000`daadfc85 ffffe101`25ea2180 : nt!KiProcessExpiredTimerList+0x502 fffff980`c2a8f1f0 fffff802`7c4c8235 : 00000000`00000000 00000000`00000000 ffffe101`25ea2180 ffffbc06`83571040 : nt!KiTimerExpiration+0x2b5 fffff980`c2a8f330 fffff802`7c8a66be : ffffe101`25ea2180 ffffe101`25ea2180 00000000`00000000 00000000`00000000 : nt!KiRetireDpcList+0xc45 fffff980`c2a8f5c0 00000000`00000000 : fffff980`c2a90000 fffff980`c2a89000 00000000`00000000 00000000`00000000 : nt!KiIdleLoop+0x9e IMAGE_VERSION: 10.0.26100.4484 STACK_COMMAND: .process /r /p 0xfffff8027d1cef80; .thread 0xffffbc0683571040 ; kb FAILURE_BUCKET_ID: 0x9F_3_AML!_SB.PCI0.GPP8.U4UP._STA_ACPI_IMAGE_pci.sys OSPLATFORM_TYPE: x64 OSNAME: Windows 10 FAILURE_ID_HASH: {0591a21b-6ede-bd3f-5f3c-7dd9aa2b98ab} Followup: MachineOwner --------- [SMBIOS Data Tables v3.6] [DMI Version - 0] [2.0 Calling Convention - No] [Table Size - 3424 bytes] [BIOS Information (Type 0) - Length 26 - Handle 0000h] Vendor American Megatrends Inc. BIOS Version 0227 BIOS Starting Address Segment f000 BIOS Release Date 07/23/2024 BIOS ROM Size 1000000 BIOS Characteristics 07: - PCI Supported 11: - Upgradeable FLASH BIOS 12: - BIOS Shadowing Supported 15: - CD-Boot Supported 16: - Selectable Boot Supported 17: - BIOS ROM Socketed 19: - EDD Supported 20: - NEC 9800 J-Floppy Supported 21: - Toshiba J-Floppy Supported 22: - 360KB Floppy Supported 23: - 1.2MB Floppy Supported 24: - 720KB Floppy Supported 25: - 2.88MB Floppy Supported 26: - Print Screen Device Supported 28: - Serial Services Supported 29: - Printer Services Supported 30: - CGA/Mono Services Supported 32: - BIOS Vendor Reserved BIOS Characteristic Extensions 00: - ACPI Supported 01: - USB Legacy Supported 08: - BIOS Boot Specification Supported 10: - Enable Targeted Content Distribution 11: - UEFI Specification Supported BIOS Major Revision 2 BIOS Minor Revision 27 EC Firmware Major Revision 255 EC Firmware Minor Revision 255 Extended BIOS ROM Size 32 MB [System Information (Type 1) - Length 27 - Handle 0001h] Manufacturer ASUS Product Name System Product Name Version System Version Serial Number System Serial Number UUID 00000000-0000-0000-0000-000000000000 Wakeup Type Power Switch SKUNumber SKU Family To be filled by O.E.M. [BaseBoard Information (Type 2) - Length 15 - Handle 0002h] Manufacturer ASUSTeK COMPUTER INC. Product ROG STRIX X870-A GAMING WIFI Version Rev 1.xx Serial Number 240842605101071 Asset Tag Feature Flags 09h 00: - Motherboard 03: - Replaceable Location Default string Chassis Handle 0003h Board Type 0ah - Processor/Memory Module Number of Child Handles 0 [System Enclosure (Type 3) - Length 22 - Handle 0003h] Manufacturer Default string Chassis Type Desktop Version Default string Serial Number Asset Tag Number Bootup State Safe Power Supply State Safe Thermal State Safe Security Status None OEM Defined 0 Height 0U Number of Power Cords 1 Number of Contained Elements 0 Contained Element Size 3 [Onboard Devices Information (Type 10) - Length 6 - Handle 0004h] Note: The On Board Device Information (Type 10) struct is obsolete as of SMBIOs spec v2.6 Number of Devices 1 01: Type Video [enabled] 01: Description To Be Filled By O.E.M. [OEM Strings (Type 11) - Length 5 - Handle 0005h] Number of Strings 6 1 Default string 2 Default string 3 Default string 4 Default string 5 Default string 6 Default string [System Configuration Options (Type 12) - Length 5 - Handle 0006h] [ (Type 256) - Length 59 - Handle 0009h] [ (Type 256) - Length 9 - Handle 000ah] [ (Type 256) - Length 31 - Handle 000bh] [ (Type 256) - Length 26 - Handle 000ch] [Cache Information (Type 7) - Length 27 - Handle 000dh] Socket Designation L1 - Cache Cache Configuration 0180h - WBEnabled Int NonSocketed L1 Maximum Cache Size 0280h - 640K Installed Size 0280h - 640K Supported SRAM Type 0010h - Pipeline-Burst Current SRAM Type 0010h - Pipeline-Burst Cache Speed 1ns Error Correction Type Specification Reserved System Cache Type Unified Associativity 8-way Set-Associative Maximum Cache Size 2 280 - 00000640l Kb Installed Cache Size 2 280 - 00000640l Kb [Cache Information (Type 7) - Length 27 - Handle 000eh] Socket Designation L2 - Cache Cache Configuration 0181h - WBEnabled Int NonSocketed L2 Maximum Cache Size 2000h - 8192K Installed Size 2000h - 8192K Supported SRAM Type 0010h - Pipeline-Burst Current SRAM Type 0010h - Pipeline-Burst Cache Speed 1ns Error Correction Type Specification Reserved System Cache Type Unified Associativity 16-way Set-Associative Maximum Cache Size 2 2000 - 00008192l Kb Installed Cache Size 2 2000 - 00008192l Kb [Cache Information (Type 7) - Length 27 - Handle 000fh] Socket Designation L3 - Cache Cache Configuration 0182h - WBEnabled Int NonSocketed L3 Maximum Cache Size 8600h - 98304K Installed Size 8600h - 98304K Supported SRAM Type 0010h - Pipeline-Burst Current SRAM Type 0010h - Pipeline-Burst Cache Speed 1ns Error Correction Type Specification Reserved System Cache Type Unified Associativity 16-way Set-Associative Maximum Cache Size 2 80000600 - 00098304l Kb Installed Cache Size 2 80000600 - 00098304l Kb [Processor Information (Type 4) - Length 48 - Handle 0010h] Socket Designation AM5 Processor Type Central Processor Processor Family 6bh - AMD Zen Processor Family Processor Manufacturer Advanced Micro Devices, Inc. Processor ID 400fb400fffb8b17 Processor Version AMD Ryzen 7 9800X3D 8-Core Processor Processor Voltage 8dh - 1.3V External Clock 100MHz Max Speed 5250MHz Current Speed 4700MHz Status Enabled Populated Processor Upgrade Specification Reserved L1 Cache Handle 000dh L2 Cache Handle 000eh L3 Cache Handle 000fh Serial Number Asset Tag Number Part Number Unknown Core Count 8 Core Enabled 8 Thread Count 16 Processor Characteristics fc Enabled Characteristics: 0x 2: 64-bit Capable 0x 3: Multi-Core 0x 4: Hardware Thread 0x 5: Execute Protection 0x 6: Enhanced Virtualization 0x 7: Power/Performance Control Processor Family 2 006bh - AMD Zen Processor Family Core Count 2 8 Core Enabled 2 8 Thread Count 2 16 [ (Type 256) - Length 9 - Handle 0011h] [32Bit Memory Error Information (Type 18) - Length 23 - Handle 0012h] [Physical Memory Array (Type 16) - Length 23 - Handle 0013h] Location 03h - SystemBoard/Motherboard Use 03h - System Memory Memory Error Correction 03h - None Maximum Capacity 134217728KB Memory Error Inf Handle 0012h Number of Memory Devices 4 [Memory Array Mapped Address (Type 19) - Length 31 - Handle 0014h] Starting Address 00000000h Ending Address 01ffffffh Memory Array Handle 0013h Partition Width 02 Extended Starting Address 0000000000000000h Extended Ending Address 0000000000000000h [32Bit Memory Error Information (Type 18) - Length 23 - Handle 0015h] [Memory Device (Type 17) - Length 92 - Handle 0016h] Memory Error Info Handle 0015h Total Width [Unknown] Data Width [Unknown] Size [Not Populated] Form Factor 02h - Unknown Device Set [None] Device Locator DIMM 0 Bank Locator P0 CHANNEL A Memory Type 02h - Unknown Type Detail 0004h - Unknown Speed 0MHz Manufacturer Unknown Serial Number Asset Tag Number [String Not Specified] Part Number Unknown Attributes 0 Extended Size 0 Configured Memory Speed 0 Minimum Voltage 0 Maximum Voltage 0 Configured Voltage 0 Memory Technology 2 Memory Operating Mode Capability 4 Firmware Version 6 Module Manufacturer Id 0 Module Product Id 0 Memory Subsystem Controller Manufacturer Id 0 Memory Subsystem Controller Product Id 0 Non-Volatile Size 0 Volatile Size 0 Cache Size 0 Logical Size 0 Extended Speed 0 Extended Configured Memory Speed 0 [32Bit Memory Error Information (Type 18) - Length 23 - Handle 0017h] [Memory Device (Type 17) - Length 92 - Handle 0018h] Memory Error Info Handle 0017h Total Width 64 bits Data Width 64 bits Size 16384MB Form Factor 09h - DIMM Device Set [None] Device Locator DIMM 1 Bank Locator P0 CHANNEL A Memory Type 22h - DDR5 Type Detail 4080h - Synchronous Unbuffered (Unregistered) Speed 4800MHz Manufacturer G Skill Intl Serial Number Asset Tag Number [String Not Specified] Part Number F5-6000J2836G16G Attributes 1 Extended Size 0 Configured Memory Speed 6000 Minimum Voltage 1100 Maximum Voltage 1100 Configured Voltage 1100 Memory Technology 3 Memory Operating Mode Capability 8 Firmware Version 6 Module Manufacturer Id 52484 Module Product Id 0 Memory Subsystem Controller Manufacturer Id 0 Memory Subsystem Controller Product Id 0 Non-Volatile Size 0 Volatile Size 0 Cache Size 0 Logical Size 0 Extended Speed 0 Extended Configured Memory Speed 0 [Memory Device Mapped Address (Type 20) - Length 35 - Handle 0019h] Starting Address 00000000h Ending Address 00ffffffh Memory Device Handle 0018h Mem Array Mapped Adr Handle 0014h Partition Row Position [Unknown] Interleave Position [Unknown] Interleave Data Depth [Unknown] Extended Starting Address 0000000000000000h Extended Ending Address 0000000000000000h [32Bit Memory Error Information (Type 18) - Length 23 - Handle 001ah] [Memory Device (Type 17) - Length 92 - Handle 001bh] Memory Error Info Handle 001ah Total Width [Unknown] Data Width [Unknown] Size [Not Populated] Form Factor 02h - Unknown Device Set [None] Device Locator DIMM 0 Bank Locator P0 CHANNEL B Memory Type 02h - Unknown Type Detail 0004h - Unknown Speed 0MHz Manufacturer Unknown Serial Number Asset Tag Number [String Not Specified] Part Number Unknown Attributes 0 Extended Size 0 Configured Memory Speed 0 Minimum Voltage 0 Maximum Voltage 0 Configured Voltage 0 Memory Technology 2 Memory Operating Mode Capability 4 Firmware Version 6 Module Manufacturer Id 0 Module Product Id 0 Memory Subsystem Controller Manufacturer Id 0 Memory Subsystem Controller Product Id 0 Non-Volatile Size 0 Volatile Size 0 Cache Size 0 Logical Size 0 Extended Speed 0 Extended Configured Memory Speed 0 [32Bit Memory Error Information (Type 18) - Length 23 - Handle 001ch] [Memory Device (Type 17) - Length 92 - Handle 001dh] Memory Error Info Handle 001ch Total Width 64 bits Data Width 64 bits Size 16384MB Form Factor 09h - DIMM Device Set [None] Device Locator DIMM 1 Bank Locator P0 CHANNEL B Memory Type 22h - DDR5 Type Detail 4080h - Synchronous Unbuffered (Unregistered) Speed 4800MHz Manufacturer G Skill Intl Serial Number Asset Tag Number [String Not Specified] Part Number F5-6000J2836G16G Attributes 1 Extended Size 0 Configured Memory Speed 6000 Minimum Voltage 1100 Maximum Voltage 1100 Configured Voltage 1100 Memory Technology 3 Memory Operating Mode Capability 8 Firmware Version 6 Module Manufacturer Id 52484 Module Product Id 0 Memory Subsystem Controller Manufacturer Id 0 Memory Subsystem Controller Product Id 0 Non-Volatile Size 0 Volatile Size 0 Cache Size 0 Logical Size 0 Extended Speed 0 Extended Configured Memory Speed 0 [Memory Device Mapped Address (Type 20) - Length 35 - Handle 001eh] Starting Address 01000000h Ending Address 01ffffffh Memory Device Handle 001dh Mem Array Mapped Adr Handle 0014h Partition Row Position [Unknown] Interleave Position [Unknown] Interleave Data Depth [Unknown] Extended Starting Address 0000000000000000h Extended Ending Address 0000000000000000h [ (Type 256) - Length 14 - Handle 001fh] [ (Type 256) - Length 165 - Handle 0020h] [ (Type 256) - Length 11 - Handle 004bh] [ (Type 256) - Length 4 - Handle 004dh]
We use cookies and similar technologies for the following purposes:
Do you accept cookies and these technologies?
