Muhammed_ Ali
Gelişen
9 Aralık 2025
  • Anakart: Gigabyte B850 eagle Wi-Fi 6
  • İşlemci: Ryzen 7600X.
  • Ekran kartı: RX 6800 XT.
  • İşletim sistemi: Windows 11 Home.
DRIVER_POWER_STATE_FAILURE (9f) hatası ve ardından bilgisayar yeniden başlıyor. Bazen de hata vermeden kendi kendine "Display Port sinyal yok" diyerek kitleniyor. Reset atılmıyor, kapatıp yeniden açmak gerekiyor.
Kod:
Preparing the environment for Debugger Extensions Gallery repositories **************
   ExtensionRepository : Implicit
   UseExperimentalFeatureForNugetShare : true
   AllowNugetExeUpdate : true
   NonInteractiveNuget : true
   AllowNugetMSCredentialProviderInstall : true
   AllowParallelInitializationOfLocalRepositories : true
   EnableRedirectToChakraJsProvider : false
   -- Configuring repositories
      ----> Repository : LocalInstalled, Enabled: true
      ----> Repository : UserExtensions, Enabled: true
>>>>>>>>>>>> Preparing the environment for Debugger Extensions Gallery repositories completed, duration 0.000 seconds
************* Waiting for Debugger Extensions Gallery to Initialize **************
>>>>>>>>>>>> Waiting for Debugger Extensions Gallery to Initialize completed, duration 0.016 seconds
   ----> Repository : UserExtensions, Enabled: true, Packages count: 0
   ----> Repository : LocalInstalled, Enabled: true, Packages count: 46
Microsoft (R) Windows Debugger Version 10.0.29482.1003 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\120825-7593-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
************* Path validation summary **************
Response                         Time (ms)     Location
Deferred                                       srv*
Symbol search path is: srv*
Executable search path is:
Windows 10 Kernel Version 26100 MP (12 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Kernel base = 0xfffff807`8dc00000 PsLoadedModuleList = 0xfffff807`8eaf5030
Debug session time: Mon Dec  8 19:57:02.412 2025 (UTC + 3:00)
System Uptime: 0 days 1:27:26.271
Loading Kernel Symbols
Press ctrl-c (cdb, kd, ntsd) or ctrl-break (windbg) to abort symbol loads that take too long.
Run !sym noisy before .reload to track down problems loading symbols.
Loading User Symbols
Loading unloaded module list
For analysis of this file, run !analyze -v
nt!KeBugCheckEx:
fffff807`8e0f6880 48894c2408      mov     qword ptr [rsp+8],rcx ss:0018:ffffd189`696aefb0=000000000000009f
4: kd> !analyze -v
Bugcheck Analysis                                    *
A driver has failed to complete a power IRP within a specific time.
Arguments:
Arg1: 0000000000000003, A device object has been blocking an IRP for too long a time
Arg2: ffffd48644b020a0, Physical Device Object of the stack
Arg3: ffffd189696af000, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the Functional Device Object of the stack
Arg4: ffffd486449c6830, The blocked IRP
Debugging Details:
KEY_VALUES_STRING: 1
    Key  : Analysis.CPU.mSec
    Value: 1015
    Key  : Analysis.Elapsed.mSec
    Value: 2196
    Key  : Analysis.IO.Other.Mb
    Value: 0
    Key  : Analysis.IO.Read.Mb
    Value: 1
    Key  : Analysis.IO.Write.Mb
    Value: 0
    Key  : Analysis.Init.CPU.mSec
    Value: 421
    Value: 12185
    Value: 88
    Value: 10.0.29482.1003
    Value: 10.2509.29.03 amd64fre
    Key  : Analysis.Version.Ext
    Value: 1.2509.29.3
    Value: 0x9f
    Value: 0x9f
    Value: 0x21808
    Value: 1
    Value: 0x0
    Value: 1
    Value: 0
    Key  : Failure.Bucket
    Value: 0x9F_3_IMAGE_HDAudBus.sys
    Key  : Failure.Hash
    Value: {360d077d-1208-9ef3-2358-6a66e420c674}
    Key  : Hypervisor.Enlightenments.ValueHex
    Value: 0x7497cf94
    Key  : Hypervisor.Flags.AnyHypervisorPresent
    Value: 1
    Key  : Hypervisor.Flags.ApicEnlightened
    Value: 1
    Key  : Hypervisor.Flags.ApicVirtualizationAvailable
    Value: 0
    Key  : Hypervisor.Flags.AsyncMemoryHint
    Value: 0
    Key  : Hypervisor.Flags.CoreSchedulerRequested
    Value: 0
    Key  : Hypervisor.Flags.CpuManager
    Value: 1
    Key  : Hypervisor.Flags.DeprecateAutoEoi
    Value: 0
    Key  : Hypervisor.Flags.DynamicCpuDisabled
    Value: 1
    Key  : Hypervisor.Flags.Epf
    Value: 0
    Key  : Hypervisor.Flags.ExtendedProcessorMasks
    Value: 1
    Key  : Hypervisor.Flags.HardwareMbecAvailable
    Value: 1
    Key  : Hypervisor.Flags.MaxBankNumber
    Value: 0
    Key  : Hypervisor.Flags.MemoryZeroingControl
    Value: 0
    Key  : Hypervisor.Flags.NoExtendedRangeFlush
    Value: 0
    Key  : Hypervisor.Flags.NoNonArchCoreSharing
    Value: 1
    Key  : Hypervisor.Flags.Phase0InitDone
    Value: 1
    Key  : Hypervisor.Flags.PowerSchedulerQos
    Value: 0
    Key  : Hypervisor.Flags.RootScheduler
    Value: 0
    Key  : Hypervisor.Flags.SynicAvailable
    Value: 1
    Key  : Hypervisor.Flags.UseQpcBias
    Value: 0
    Key  : Hypervisor.Flags.Value
    Value: 38408431
    Key  : Hypervisor.Flags.ValueHex
    Value: 0x24a10ef
    Key  : Hypervisor.Flags.VpAssistPage
    Value: 1
    Key  : Hypervisor.Flags.VsmAvailable
    Value: 1
    Key  : Hypervisor.RootFlags.AccessStats
    Value: 1
    Key  : Hypervisor.RootFlags.CrashdumpEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.CreateVirtualProcessor
    Value: 1
    Key  : Hypervisor.RootFlags.DisableHyperthreading
    Value: 0
    Key  : Hypervisor.RootFlags.HostTimelineSync
    Value: 1
    Key  : Hypervisor.RootFlags.HypervisorDebuggingEnabled
    Value: 0
    Key  : Hypervisor.RootFlags.IsHyperV
    Value: 1
    Key  : Hypervisor.RootFlags.LivedumpEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.MapDeviceInterrupt
    Value: 1
    Key  : Hypervisor.RootFlags.MceEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.Nested
    Value: 0
    Key  : Hypervisor.RootFlags.StartLogicalProcessor
    Value: 1
    Key  : Hypervisor.RootFlags.Value
    Value: 1015
    Key  : Hypervisor.RootFlags.ValueHex
    Value: 0x3f7
    Key  : WER.System.BIOSRevision
    Value: 5.35.0.0
BUGCHECK_CODE:  9f
BUGCHECK_P1: 3
BUGCHECK_P2: ffffd48644b020a0
BUGCHECK_P3: ffffd189696af000
BUGCHECK_P4: ffffd486449c6830
FILE_IN_CAB:  120825-7593-01.dmp
TAG_NOT_DEFINED_202b:  *** Unknown TAG in analysis list 202b
DUMP_FILE_ATTRIBUTES: 0x21808
  Kernel Generated Triage Dump
FAULTING_THREAD:  ffffd48639644280
DRVPOWERSTATE_SUBCODE:  3
DRIVER_OBJECT: ffffd48640cf0d10
IMAGE_NAME:  HDAudBus.sys
MODULE_NAME: HDAudBus
FAULTING_MODULE: fffff8076c0e0000 HDAudBus
BLACKBOXACPI: 1 (!blackboxacpi)
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1 (!blackboxwinlogon)
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  System
STACK_TEXT:
ffffd189`696aefa8 fffff807`8e1c710d     : 00000000`0000009f 00000000`00000003 ffffd486`44b020a0 ffffd189`696af000 : nt!KeBugCheckEx
ffffd189`696aefb0 fffff807`8e1c6f0c     : ffffd486`39644280 ffffd189`696af3f0 ffffd486`47aa2870 ffffd189`696af189 : nt!PopIrpWatchdogBugcheck+0x1f5
ffffd189`696af090 fffff807`8deb1182     : ffffbe81`00000004 fffff807`00000001 ffffd189`00000000 fffff807`00000002 : nt!PopIrpWatchdog+0xc
ffffd189`696af0c0 fffff807`8deb1a65     : 0000000c`370572fe 00000000`0000000f 0000000c`476251a5 ffffbe81`e25a5180 : nt!KiProcessExpiredTimerList+0x502
ffffd189`696af1f0 fffff807`8de6fc36     : ffffd189`696af430 00000000`00000000 ffffbe81`e25a5180 ffffd486`39644280 : nt!KiTimerExpiration+0x2b5
ffffd189`696af330 fffff807`8e29fc4e     : ffffbe81`e25a5180 ffffbe81`e25a5180 ffffd486`39644280 ffffd486`61132040 : nt!KiRetireDpcList+0xc46
ffffd189`696af5c0 00000000`00000000     : ffffd189`696b0000 ffffd189`696a9000 00000000`00000000 00000000`00000000 : nt!KiIdleLoop+0x9e
IMAGE_VERSION:  10.0.26100.7019
STACK_COMMAND: .process /r /p 0xfffff8078ebcef00; .thread 0xffffd48639644280 ; kb
FAILURE_BUCKET_ID:  0x9F_3_IMAGE_HDAudBus.sys
OSPLATFORM_TYPE:  x64
OSNAME:  Windows 10
FAILURE_ID_HASH:  {360d077d-1208-9ef3-2358-6a66e420c674}
Followup:     MachineOwner
    156,2 KB · Görüntüleme: 31
    165,7 KB · Görüntüleme: 32
