Çözüldü "DRIVER_POWER_STATE_FAILURE (9f)" mavi ekran hatası
appenaunpo
24 Aralık 2024
Merhabalar. Bilgisayarı sorunsuz bir şekilde kapatıp uyumuştum. Tekrar açtığımda mavi ekran hatası aldım. Kendini yeniden başlattı ve tekrar hata vermedi. WinDbg'la baktığımda ise başlıktaki hatayı gördüm. Sorunun çözümünü bilen var mı?
i5 12400f
rtx 4060ti
Kod:
A driver has failed to complete a power IRP within a specific time.
Arguments:
Arg1: 0000000000000003, A device object has been blocking an IRP for too long a time
Arg2: ffffe40ad17d8cf0, Physical Device Object of the stack
Arg3: fffff80634cea5d0, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the Functional Device Object of the stack
Arg4: ffffe40ad6ec18a0, The blocked IRP
Debugging Details:
KEY_VALUES_STRING: 1
    Key  : Analysis.CPU.mSec
    Value: 1890
    Key  : Analysis.Elapsed.mSec
    Value: 32220
    Key  : Analysis.IO.Other.Mb
    Value: 16
    Key  : Analysis.IO.Read.Mb
    Value: 1
    Key  : Analysis.IO.Write.Mb
    Value: 29
    Key  : Analysis.Init.CPU.mSec
    Value: 1218
    Value: 48172
    Value: 98
    Value: 10.0.27725.1000
    Value: 10.2408.27.01 amd64fre
    Key  : Analysis.Version.Ext
    Value: 1.2408.27.1
    Value: 0x9f
    Value: 0x9f
    Key  : Failure.Bucket
    Value: 0x9F_3_netr28ux_IMAGE_UsbHub3.sys
    Key  : Failure.Hash
    Value: {8a545dcd-2452-7510-d521-0f174faeba03}
    Key  : Hypervisor.Enlightenments.ValueHex
    Value: 7417df84
    Key  : Hypervisor.Flags.AnyHypervisorPresent
    Value: 1
    Key  : Hypervisor.Flags.ApicEnlightened
    Value: 0
    Key  : Hypervisor.Flags.ApicVirtualizationAvailable
    Value: 1
    Key  : Hypervisor.Flags.AsyncMemoryHint
    Value: 0
    Key  : Hypervisor.Flags.CoreSchedulerRequested
    Value: 0
    Key  : Hypervisor.Flags.CpuManager
    Value: 1
    Key  : Hypervisor.Flags.DeprecateAutoEoi
    Value: 1
    Key  : Hypervisor.Flags.DynamicCpuDisabled
    Value: 1
    Key  : Hypervisor.Flags.Epf
    Value: 0
    Key  : Hypervisor.Flags.ExtendedProcessorMasks
    Value: 1
    Key  : Hypervisor.Flags.HardwareMbecAvailable
    Value: 1
    Key  : Hypervisor.Flags.MaxBankNumber
    Value: 0
    Key  : Hypervisor.Flags.MemoryZeroingControl
    Value: 0
    Key  : Hypervisor.Flags.NoExtendedRangeFlush
    Value: 0
    Key  : Hypervisor.Flags.NoNonArchCoreSharing
    Value: 1
    Key  : Hypervisor.Flags.Phase0InitDone
    Value: 1
    Key  : Hypervisor.Flags.PowerSchedulerQos
    Value: 0
    Key  : Hypervisor.Flags.RootScheduler
    Value: 0
    Key  : Hypervisor.Flags.SynicAvailable
    Value: 1
    Key  : Hypervisor.Flags.UseQpcBias
    Value: 0
    Key  : Hypervisor.Flags.Value
    Value: 55185662
    Key  : Hypervisor.Flags.ValueHex
    Value: 34a10fe
    Key  : Hypervisor.Flags.VpAssistPage
    Value: 1
    Key  : Hypervisor.Flags.VsmAvailable
    Value: 1
    Key  : Hypervisor.RootFlags.AccessStats
    Value: 1
    Key  : Hypervisor.RootFlags.CrashdumpEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.CreateVirtualProcessor
    Value: 1
    Key  : Hypervisor.RootFlags.DisableHyperthreading
    Value: 0
    Key  : Hypervisor.RootFlags.HostTimelineSync
    Value: 1
    Key  : Hypervisor.RootFlags.HypervisorDebuggingEnabled
    Value: 0
    Key  : Hypervisor.RootFlags.IsHyperV
    Value: 1
    Key  : Hypervisor.RootFlags.LivedumpEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.MapDeviceInterrupt
    Value: 1
    Key  : Hypervisor.RootFlags.MceEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.Nested
    Value: 0
    Key  : Hypervisor.RootFlags.StartLogicalProcessor
    Value: 1
    Key  : Hypervisor.RootFlags.Value
    Value: 1015
    Key  : Hypervisor.RootFlags.ValueHex
    Value: 3f7
    Key  : Stack.Pointer
    Value: NMI
    Key  : WER.OS.Branch
    Value: ge_release
    Key  : WER.OS.Version
    Value: 10.0.26100.1
BUGCHECK_CODE:  9f
BUGCHECK_P1: 3
BUGCHECK_P2: ffffe40ad17d8cf0
BUGCHECK_P3: fffff80634cea5d0
BUGCHECK_P4: ffffe40ad6ec18a0
FILE_IN_CAB:  122324-6968-01.dmp
TAG_NOT_DEFINED_202b:  *** Unknown TAG in analysis list 202b
FAULTING_THREAD:  fffff806a39d0640
DRVPOWERSTATE_SUBCODE:  3
IMAGE_NAME:  UsbHub3.sys
MODULE_NAME: UsbHub3
FAULTING_MODULE: fffff8064ac00000 UsbHub3
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  System
DPC_STACK_BASE:  FFFFF80634CF2FB0
STACK_TEXT:
fffff806`34cea578 fffff806`a2f8f10d     : 00000000`0000009f 00000000`00000003 ffffe40a`d17d8cf0 fffff806`34cea5d0 : nt!KeBugCheckEx
fffff806`34cea580 fffff806`a2f8ef0c     : fffff806`a39d0640 fffff806`34cea9a0 00000000`00000000 fffff806`34cea759 : nt!PopIrpWatchdogBugcheck+0x1f5
fffff806`34cea660 fffff806`a2cef83a     : fffff806`31c87180 00000000`000000ff fffff806`34cea9a8 fffff806`34cea808 : nt!PopIrpWatchdog+0xc
fffff806`34cea690 fffff806`a2cf0353     : fffff806`31c8b280 fffff806`a2d75e13 00000251`41cfdd50 fffff806`31c8eb00 : nt!KiProcessExpiredTimerList+0x26a
fffff806`34cea7c0 fffff806`a2cb9d61     : fffff806`31c87180 00000000`00000020 fffff806`31c87180 00000000`00000001 : nt!KiTimerExpiration+0x2e3
fffff806`34cea8f0 fffff806`a307ad2e     : fffff806`31c87180 fffff806`31c87180 00000000`001a7550 00000000`00000000 : nt!KiRetireDpcList+0xaf1
fffff806`34ceab80 00000000`00000000     : fffff806`34ceb000 fffff806`34ce4000 00000000`00000000 00000000`00000000 : nt!KiIdleLoop+0x9e
IMAGE_VERSION:  10.0.26100.1882
STACK_COMMAND:  .process /r /p 0xfffff806a39cdf80; .thread 0xfffff806a39d0640 ; kb
FAILURE_BUCKET_ID:  0x9F_3_netr28ux_IMAGE_UsbHub3.sys
OS_VERSION:  10.0.26100.1
BUILDLAB_STR:  ge_release
OSPLATFORM_TYPE:  x64
OSNAME:  Windows 10
FAILURE_ID_HASH:  {8a545dcd-2452-7510-d521-0f174faeba03}
Followup:     MachineOwner
Sistemde Broadcom WiFi 4323 USB WiFi adaptörü varsa söküp deneyin. Sorun adaptör kaynaklı gibi. Sürücü sürümünü güncellemek de fayda edebilir.
