muhammetaktas122
- 17 Mart 2025
* Bugcheck Analysis *
KMODE_EXCEPTION_NOT_HANDLED (1e)
This is a very common BugCheck. Usually the exception address pinpoints
the driver/function that caused the problem. Always note this address
as well as the link date of the driver/image that contains this address.
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff800d8cec31d, The address that the exception occurred at
Arg3: 0000000000000000, Parameter 0 of the exception
Arg4: ffffffffffffffff, Parameter 1 of the exception
Debugging Details:
Unable to load image aow_drv_x64_ev.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for aow_drv_x64_ev.sys
KEY_VALUES_STRING: 1
Key : Analysis.CPU.mSec
Value: 1406
Key : Analysis.Elapsed.mSec
Value: 7798
Key : Analysis.IO.Other.Mb
Value: 0
Key : Analysis.IO.Read.Mb
Value: 1
Key : Analysis.IO.Write.Mb
Value: 24
Key : Analysis.Init.CPU.mSec
Value: 921
Value: 30309
Value: 111
Key : Analysis.Version.DbgEng
Value: 10.0.29457.1000
Key : Analysis.Version.Description
Value: 10.2506.23.01 amd64fre
Key : Analysis.Version.Ext
Value: 1.2506.23.1
Key : Bugcheck.Code.LegacyAPI
Value: 0x1e
Key : Bugcheck.Code.TargetModel
Value: 0x1e
Key : Dump.Attributes.AsUlong
Value: 0x31808
Key : Dump.Attributes.DiagDataWrittenToHeader
Value: 1
Key : Dump.Attributes.ErrorCode
Value: 0x0
Key : Dump.Attributes.KernelGeneratedTriageDump
Value: 1
Key : Dump.Attributes.LastLine
Key : Dump.Attributes.ProgressPercentage
Value: 0
Key : Failure.Bucket
Value: AV_R_aow_drv_x64_ev!unknown_function
Key : Failure.Exception.IP.Address
Value: 0xfffff800d8cec31d
Key : Failure.Exception.IP.Module
Value: aow_drv_x64_ev
Key : Failure.Exception.IP.Offset
Value: 0x3c31d
Key : Failure.Hash
Value: {34147c9f-1b74-d9d6-2742-c1640ea00ee7}
Key : Hypervisor.Enlightenments.ValueHex
Value: 0x7497cf94
Key : Hypervisor.Flags.AnyHypervisorPresent
Value: 1
Key : Hypervisor.Flags.ApicEnlightened
Value: 1
Key : Hypervisor.Flags.ApicVirtualizationAvailable
Value: 0
Key : Hypervisor.Flags.AsyncMemoryHint
Value: 0
Key : Hypervisor.Flags.CoreSchedulerRequested
Value: 0
Key : Hypervisor.Flags.CpuManager
Value: 1
Key : Hypervisor.Flags.DeprecateAutoEoi
Value: 0
Key : Hypervisor.Flags.DynamicCpuDisabled
Value: 1
Key : Hypervisor.Flags.Epf
Value: 0
Key : Hypervisor.Flags.ExtendedProcessorMasks
Value: 1
Key : Hypervisor.Flags.HardwareMbecAvailable
Value: 1
Key : Hypervisor.Flags.MaxBankNumber
Value: 0
Key : Hypervisor.Flags.MemoryZeroingControl
Value: 0
Key : Hypervisor.Flags.NoExtendedRangeFlush
Value: 0
Key : Hypervisor.Flags.NoNonArchCoreSharing
Value: 1
Key : Hypervisor.Flags.Phase0InitDone
Value: 1
Key : Hypervisor.Flags.PowerSchedulerQos
Value: 0
Key : Hypervisor.Flags.RootScheduler
Value: 0
Key : Hypervisor.Flags.SynicAvailable
Value: 1
Key : Hypervisor.Flags.UseQpcBias
Value: 0
Key : Hypervisor.Flags.Value
Value: 38408431
Key : Hypervisor.Flags.ValueHex
Value: 0x24a10ef
Key : Hypervisor.Flags.VpAssistPage
Value: 1
Key : Hypervisor.Flags.VsmAvailable
Value: 1
Key : Hypervisor.RootFlags.AccessStats
Value: 1
Key : Hypervisor.RootFlags.CrashdumpEnlightened
Value: 1
Key : Hypervisor.RootFlags.CreateVirtualProcessor
Value: 1
Key : Hypervisor.RootFlags.DisableHyperthreading
Value: 0
Key : Hypervisor.RootFlags.HostTimelineSync
Value: 1
Key : Hypervisor.RootFlags.HypervisorDebuggingEnabled
Value: 0
Key : Hypervisor.RootFlags.IsHyperV
Value: 1
Key : Hypervisor.RootFlags.LivedumpEnlightened
Value: 1
Key : Hypervisor.RootFlags.MapDeviceInterrupt
Value: 1
Key : Hypervisor.RootFlags.MceEnlightened
Value: 1
Key : Hypervisor.RootFlags.Nested
Value: 0
Key : Hypervisor.RootFlags.StartLogicalProcessor
Value: 1
Key : Hypervisor.RootFlags.Value
Value: 1015
Key : Hypervisor.RootFlags.ValueHex
Value: 0x3f7
BUGCHECK_CODE: 1e
BUGCHECK_P1: ffffffffc0000005
BUGCHECK_P2: fffff800d8cec31d
BUGCHECK_P3: 0
BUGCHECK_P4: ffffffffffffffff
FILE_IN_CAB: 110925-14281-01.dmp
TAG_NOT_DEFINED_202b: *** Unknown TAG in analysis list 202b
DUMP_FILE_ATTRIBUTES: 0x31808
Kernel Generated Triage Dump
FAULTING_THREAD: ffff818b77f11080
EXCEPTION_PARAMETER1: 0000000000000000
EXCEPTION_PARAMETER2: ffffffffffffffff
READ_ADDRESS: fffff800eedc44c0: Unable to get MiVisibleState
Unable to get NonPagedPoolStart
Unable to get NonPagedPoolEnd
Unable to get PagedPoolStart
Unable to get PagedPoolEnd
unable to get nt!MmSpecialPagesInUse
ffffffffffffffff
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: aow_exe.exe
STACK_TEXT:
ffffbc08`cbbe4f88 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KeBugCheckEx
SYMBOL_NAME: aow_drv_x64_ev+3c31d
MODULE_NAME: aow_drv_x64_ev
IMAGE_NAME: aow_drv_x64_ev.sys
STACK_COMMAND: .process /r /p 0xffff818b788d7080; .thread 0xffff818b77f11080 ; kb
BUCKET_ID_FUNC_OFFSET: 3c31d
FAILURE_BUCKET_ID: AV_R_aow_drv_x64_ev!unknown_function
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {34147c9f-1b74-d9d6-2742-c1640ea00ee7}
Followup: MachineOwner
Arguments:
Debugging Details:
Value: 1406
Value: 7798
Value: 0
Value: 1
Value: 24
Value: 921
Value: 30309
Value: 111
Value: 1.2506.23.1
Value: 0x1e
Value: 0x1e
Value: 0x31808
Value: 1
Value: 0x0
Value: 1
Value: 0
Value: 0x3c31d
Key : Failure.Hash
Value: 0x7497cf94
Value: 1
Value: 1
Value: 0
Value: 0
Value: 0
Value: 1
Value: 0
Value: 1
Value: 0
Value: 1
Value: 1
Value: 0
Value: 0
Value: 0
Value: 1
Value: 1
Value: 0
Value: 0
Value: 1
Value: 0
Value: 38408431
Value: 0x24a10ef
Value: 1
Value: 1
Value: 1
Value: 1
Value: 1
Value: 0
Value: 1
Value: 0
Value: 1
Value: 1
Value: 1
Value: 1
Value: 0
Value: 1
Value: 1015
Value: 0x3f7
BUGCHECK_CODE: 1e
BUGCHECK_P3: 0
ffffffffffffffff
STACK_TEXT:
OSNAME: Windows 10
GameLoop kaynaklı bir hata gibi gözüküyor. Emülatörü kaldırıp en son sürümü tekrardan yüklemeyi dene. Olmazsa BlueStacks indir.
Kod:******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* KMODE_EXCEPTION_NOT_HANDLED (1e) This is a very common BugCheck. Usually the exception address pinpoints. the driver/function that caused the problem. Always note this address. as well as the link date of the driver/image that contains this address. Arguments: Arg1: ffffffffc0000005, The exception code that was not handled. Arg2: fffff800d8cec31d, The address that the exception occurred at. Arg3: 0000000000000000, Parameter 0 of the exception. Arg4: ffffffffffffffff, Parameter 1 of the exception. Debugging Details: ------------------ Unable to load image aow_drv_x64_ev.sys, Win32 error 0n2. *** WARNING: Unable to verify timestamp for aow_drv_x64_ev.sys KEY_VALUES_STRING: 1 Key : Analysis.CPU.mSec Value: 1406. Key : Analysis.Elapsed.mSec Value: 7798. Key : Analysis.IO.Other.Mb Value: 0 Key : Analysis.IO.Read.Mb Value: 1 Key : Analysis.IO.Write.Mb Value: 24. Key : Analysis.Init.CPU.mSec Value: 921. Key : Analysis.Init.Elapsed.mSec Value: 30309. Key : Analysis.Memory.CommitPeak.Mb Value: 111. Key : Analysis.Version.DbgEng Value: 10.0.29457.1000 Key : Analysis.Version.Description Value: 10.2506.23.01 amd64fre. Key : Analysis.Version.Ext Value: 1.2506.23.1 Key : Bugcheck.Code.LegacyAPI Value: 0x1e. Key : Bugcheck.Code.TargetModel Value: 0x1e. Key : Dump.Attributes.AsUlong Value: 0x31808. Key : Dump.Attributes.DiagDataWrittenToHeader Value: 1 Key : Dump.Attributes.ErrorCode Value: 0x0. Key : Dump.Attributes.KernelGeneratedTriageDump Value: 1 Key : Dump.Attributes.LastLine Value: Dump completed successfully. Key : Dump.Attributes.ProgressPercentage Value: 0 Key : Failure.Bucket Value: AV_R_aow_drv_x64_ev!unknown_function Key : Failure.Exception.IP.Address Value: 0xfffff800d8cec31d. Key : Failure.Exception.IP.Module Value: aow_drv_x64_ev. Key : Failure.Exception.IP.Offset Value: 0x3c31d. Key : Failure.Hash Value: {34147c9f-1b74-d9d6-2742-c1640ea00ee7} Key : Hypervisor.Enlightenments.ValueHex Value: 0x7497cf94. Key : Hypervisor.Flags.AnyHypervisorPresent Value: 1 Key : Hypervisor.Flags.ApicEnlightened Value: 1 Key : Hypervisor.Flags.ApicVirtualizationAvailable Value: 0 Key : Hypervisor.Flags.AsyncMemoryHint Value: 0 Key : Hypervisor.Flags.CoreSchedulerRequested Value: 0 Key : Hypervisor.Flags.CpuManager Value: 1 Key : Hypervisor.Flags.DeprecateAutoEoi Value: 0 Key : Hypervisor.Flags.DynamicCpuDisabled Value: 1 Key : Hypervisor.Flags.Epf Value: 0 Key : Hypervisor.Flags.ExtendedProcessorMasks Value: 1 Key : Hypervisor.Flags.HardwareMbecAvailable Value: 1 Key : Hypervisor.Flags.MaxBankNumber Value: 0 Key : Hypervisor.Flags.MemoryZeroingControl Value: 0 Key : Hypervisor.Flags.NoExtendedRangeFlush Value: 0 Key : Hypervisor.Flags.NoNonArchCoreSharing Value: 1 Key : Hypervisor.Flags.Phase0InitDone Value: 1 Key : Hypervisor.Flags.PowerSchedulerQos Value: 0 Key : Hypervisor.Flags.RootScheduler Value: 0 Key : Hypervisor.Flags.SynicAvailable Value: 1 Key : Hypervisor.Flags.UseQpcBias Value: 0 Key : Hypervisor.Flags.Value Value: 38408431. Key : Hypervisor.Flags.ValueHex Value: 0x24a10ef. Key : Hypervisor.Flags.VpAssistPage Value: 1 Key : Hypervisor.Flags.VsmAvailable Value: 1 Key : Hypervisor.RootFlags.AccessStats Value: 1 Key : Hypervisor.RootFlags.CrashdumpEnlightened Value: 1 Key : Hypervisor.RootFlags.CreateVirtualProcessor Value: 1 Key : Hypervisor.RootFlags.DisableHyperthreading Value: 0 Key : Hypervisor.RootFlags.HostTimelineSync Value: 1 Key : Hypervisor.RootFlags.HypervisorDebuggingEnabled Value: 0 Key : Hypervisor.RootFlags.IsHyperV Value: 1 Key : Hypervisor.RootFlags.LivedumpEnlightened Value: 1 Key : Hypervisor.RootFlags.MapDeviceInterrupt Value: 1 Key : Hypervisor.RootFlags.MceEnlightened Value: 1 Key : Hypervisor.RootFlags.Nested Value: 0 Key : Hypervisor.RootFlags.StartLogicalProcessor Value: 1 Key : Hypervisor.RootFlags.Value Value: 1015. Key : Hypervisor.RootFlags.ValueHex Value: 0x3f7. BUGCHECK_CODE: 1e. BUGCHECK_P1: ffffffffc0000005. BUGCHECK_P2: fffff800d8cec31d. BUGCHECK_P3: 0 BUGCHECK_P4: ffffffffffffffff. FILE_IN_CAB: 110925-14281-01.dmp TAG_NOT_DEFINED_202b: *** Unknown TAG in analysis list 202b. DUMP_FILE_ATTRIBUTES: 0x31808. Kernel Generated Triage Dump. FAULTING_THREAD: ffff818b77f11080. EXCEPTION_PARAMETER1: 0000000000000000. EXCEPTION_PARAMETER2: ffffffffffffffff. READ_ADDRESS: fffff800eedc44c0: Unable to get MiVisibleState. Unable to get NonPagedPoolStart. Unable to get NonPagedPoolEnd. Unable to get PagedPoolStart. Unable to get PagedPoolEnd. unable to get nt!MmSpecialPagesInUse ffffffffffffffff. CUSTOMER_CRASH_COUNT: 1 PROCESS_NAME: aow_exe.exe STACK_TEXT: ffffbc08`cbbe4f88 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KeBugCheckEx SYMBOL_NAME: aow_drv_x64_ev+3c31d MODULE_NAME: aow_drv_x64_ev. IMAGE_NAME: aow_drv_x64_ev.sys STACK_COMMAND: .process /r /p 0xffff818b788d7080; .thread 0xffff818b77f11080 ; kb. BUCKET_ID_FUNC_OFFSET: 3c31d. FAILURE_BUCKET_ID: AV_R_aow_drv_x64_ev!unknown_function OSPLATFORM_TYPE: x64. OSNAME: Windows 10. FAILURE_ID_HASH: {34147c9f-1b74-d9d6-2742-c1640ea00ee7} Followup: MachineOwner
