AnkiDaster 36
- 17 Eylül 2024
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED (7e)
This is a very common BugCheck. Usually the exception address pinpoints
the driver/function that caused the problem. Always note this address
as well as the link date of the driver/image that contains this address.
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff80475f6c4ea, The address that the exception occurred at
Arg3: ffffca064a0c1508, Exception Record Address
Arg4: ffffca064a0c0d40, Context Record Address
Debugging Details:
KEY_VALUES_STRING: 1
Key : AV.Type
Value: Execute
Key : Analysis.CPU.mSec
Value: 718
Key : Analysis.Elapsed.mSec
Value: 1209
Key : Analysis.IO.Other.Mb
Value: 0
Key : Analysis.IO.Read.Mb
Value: 1
Key : Analysis.IO.Write.Mb
Value: 0
Key : Analysis.Init.CPU.mSec
Value: 234
Value: 4293
Value: 85
Key : Analysis.Version.DbgEng
Value: 10.0.27829.1001
Key : Analysis.Version.Description
Value: 10.2503.24.01 amd64fre
Key : Analysis.Version.Ext
Value: 1.2503.24.1
Key : Bugcheck.Code.LegacyAPI
Value: 0x1000007e
Key : Bugcheck.Code.TargetModel
Value: 0x1000007e
Key : Dump.Attributes.AsUlong
Value: 0x8
Key : Dump.Attributes.KernelGeneratedTriageDump
Value: 1
Key : Failure.Bucket
Value: AV_UNLOADED_IP_BEDaisy.sys!Unloaded
Key : Failure.Exception.Code
Value: 0xc0000005
Key : Failure.Exception.IP.Address
Value: 0xfffff80475f6c4ea
Key : Failure.Exception.IP.Offset
Value: 0x76c4ea
Key : Failure.Exception.Record
Value: 0xffffca064a0c1508
Key : Failure.Hash
Value: {8255f976-0927-f004-99d3-7ebef7b48545}
Key : Faulting.IP.Type
Value: Unloaded
BUGCHECK_CODE: 7e
BUGCHECK_P1: ffffffffc0000005
BUGCHECK_P2: fffff80475f6c4ea
BUGCHECK_P3: ffffca064a0c1508
BUGCHECK_P4: ffffca064a0c0d40
FILE_IN_CAB: 050225-21000-01.dmp
DUMP_FILE_ATTRIBUTES: 0x8
Kernel Generated Triage Dump
FAULTING_THREAD: ffffe48e8f513080
EXCEPTION_RECORD: ffffca064a0c1508 -- (.exr 0xffffca064a0c1508)
ExceptionAddress: fffff80475f6c4ea (<Unloaded_BEDaisy.sys>+0x000000000076c4ea)
ExceptionCode: c0000005 (Access violation)
ExceptionFlags: 00000000
NumberParameters: 2
Parameter[0]: 0000000000000008
Parameter[1]: fffff80475f6c4ea
Attempt to execute non-executable address fffff80475f6c4ea
CONTEXT: ffffca064a0c0d40 -- (.cxr 0xffffca064a0c0d40)
rax=0000000000000009 rbx=ffffe48ea0b3a010 rcx=730cf2af6eba0000
rdx=0000000000000000 rsi=fffff80475811b84 rdi=ffffe48ea0b3a010
rip=fffff80475f6c4ea rsp=ffffca064a0c1740 rbp=ffffca064a0c17c9
r8=0000000000000004 r9=0000000000000000 r10=ffffca064a0c1c60
r11=0000000000000000 r12=0000000000000000 r13=ffffffffffffffff
r14=ffffe48e8f513118 r15=0000000000000000
iopl=0 nv up ei ng nz na pe nc
cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00010282
<Unloaded_BEDaisy.sys>+0x76c4ea:
fffff804`75f6c4ea ?? ???
Resetting default scope
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: System
EXECUTE_ADDRESS: fffff80475f6c4ea
FAILED_INSTRUCTION_ADDRESS:
<Unloaded_BEDaisy.sys>+76c4ea
ERROR_CODE: (NTSTATUS) 0xc0000005 - 0x%p adresindeki y nerge 0x%p adresindeki belle e ba vurdu. Bellek u olamaz %s.
EXCEPTION_CODE_STR: c0000005
EXCEPTION_PARAMETER1: 0000000000000008
EXCEPTION_PARAMETER2: fffff80475f6c4ea
IP_MODULE_UNLOADED:
EXCEPTION_STR: 0xc0000005
STACK_TEXT:
ffffca06`4a0c1740 ffffe48e`a0b3a010 : ffffca06`4a0c17c9 fffff804`75811b84 ffffca06`4a0bc000 ffffe48e`8f513080 : <Unloaded_BEDaisy.sys>+0x76c4ea
ffffca06`4a0c1748 ffffca06`4a0c17c9 : fffff804`75811b84 ffffca06`4a0bc000 ffffe48e`8f513080 fffff801`4c45141b : 0xffffe48e`a0b3a010
ffffca06`4a0c1750 fffff804`75811b84 : ffffca06`4a0bc000 ffffe48e`8f513080 fffff801`4c45141b 00000000`00000000 : 0xffffca06`4a0c17c9
ffffca06`4a0c1758 ffffca06`4a0bc000 : ffffe48e`8f513080 fffff801`4c45141b 00000000`00000000 00000000`00000000 : <Unloaded_BEDaisy.sys>+0x11b84
ffffca06`4a0c1760 ffffe48e`8f513080 : fffff801`4c45141b 00000000`00000000 00000000`00000000 00000000`00000000 : 0xffffca06`4a0bc000
ffffca06`4a0c1768 fffff801`4c45141b : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0xffffe48e`8f513080
ffffca06`4a0c1770 fffff801`4c42a7f7 : 00000000`00000000 00000000`00000000 00000000`00000000 ffffe48e`00000000 : nt!KiDeliverApc+0x27b
ffffca06`4a0c1830 fffff801`4c4299ff : ffffffff`00000003 00000000`00000002 ffffca06`4a0c19f0 00000000`00000000 : nt!KiSwapThread+0x827
ffffca06`4a0c18e0 fffff801`4c4292a3 : 00000000`00000000 fffff801`00000000 ffffaa81`6a600100 ffffe48e`8f5131c0 : nt!KiCommitThreadWait+0x14f
ffffca06`4a0c1980 fffff801`4c4749df : ffffe48e`8f48ab78 00000000`00000000 fffff801`00000000 ffffaa81`6a600100 : nt!KeWaitForSingleObject+0x233
ffffca06`4a0c1a70 fffff801`4c5af618 : ffffe48e`8f498690 ffffca06`00000000 fffff801`4ce50c00 00000000`00000008 : nt!MiZeroLargePages+0x2ef
ffffca06`4a0c1b60 fffff801`4c5347d5 : 00000000`00000000 ffffe48e`8f4971a0 ffffc880`00007000 fffff801`4ce50c00 : nt!MiZeroLargePageThread+0x88
ffffca06`4a0c1c10 fffff801`4c606f38 : ffffaa81`6a540180 ffffe48e`8f513080 fffff801`4c534780 00000000`00000000 : nt!PspSystemThreadStartup+0x55
ffffca06`4a0c1c60 00000000`00000000 : ffffca06`4a0c2000 ffffca06`4a0bc000 00000000`00000000 00000000`00000000 : nt!KiStartSystemThread+0x28
SYMBOL_NAME: BEDaisy.sys!Unloaded+76c4ea
MODULE_NAME: BEDaisy
IMAGE_NAME: BEDaisy.sys
STACK_COMMAND: .cxr 0xffffca064a0c0d40 ; kb
BUCKET_ID_FUNC_OFFSET: 76c4ea
FAILURE_BUCKET_ID: AV_UNLOADED_IP_BEDaisy.sys!Unloaded
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {8255f976-0927-f004-99d3-7ebef7b48545}
Followup: MachineOwner
[SMBIOS Data Tables v2.8]
[DMI Version - 0]
[2.0 Calling Convention - No]
[Table Size - 2840 bytes]
[BIOS Information (Type 0) - Length 24 - Handle 0000h]
Vendor AMI
BIOS Version 80.12
BIOS Release Date 08/06/2015
BIOS ROM Size 400000
BIOS Characteristics
07: - PCI Supported
09: - Plug and Play Supported
11: - Upgradeable FLASH BIOS
15: - CD-Boot Supported
19: - EDD Supported
27: - Keyboard Services Supported
32: - BIOS Vendor Reserved
48: - System Vendor Reserved
49: - System Vendor Reserved
50: - System Vendor Reserved
53: - System Vendor Reserved
00: - ACPI Supported
01: - USB Legacy Supported
09: - Fn-Key NET-Boot Supported
BIOS Major Revision 128
BIOS Minor Revision 18
EC Firmware Major Revision 255
EC Firmware Minor Revision 255
Manufacturer Hewlett-Packard
Product Name HP 280 G1 MT
Version
Serial Number TRF5380J0S
UUID 00000000-0000-0000-0000-000000000000
Wakeup Type Power Switch
SKUNumber K8K51ES#AB8
Family 103C_53307F G=D
Product 2B34
Version 2.10
Serial Number
Asset Tag
Feature Flags 0dh
00: - Motherboard
02: - Removeable
03: - Replaceable
Location
Chassis Handle 0003h
Board Type 0ah - Processor/Memory Module
Number of Child Handles 0
Chassis Type Desktop
Version
Serial Number
Asset Tag Number
Bootup State Safe
Power Supply State Safe
Thermal State Safe
Security Status None
OEM Defined 1146049119
Height 0U
Number of Power Cords 1
Number of Contained Elements 0
Contained Element Size 3
[OEM Strings (Type 11) - Length 5 - Handle 0007h]
Number of Strings 32
1 FBYTE#2U3E3N3R3Y4C4k5W656E6a6y727J7M7Q7T7W7Y7d8D94aJcZch.4N;BUIL
2 DID#14WWDORD302#SABB#DAB8;
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
[System Configuration Options (Type 12) - Length 5 - Handle 0008h]
[ (Type 256) - Length 11 - Handle 0020h]
[ (Type 256) - Length 11 - Handle 0021h]
[Processor Information (Type 4) - Length 42 - Handle 0022h]
Socket Designation CPU 1
Processor Type Central Processor
Processor Family ceh - Intel Core 2 Extreme processor
Processor Manufacturer Intel
Processor ID c3060300fffbebbf
Processor Version Intel(R) Core(TM) i3-4160 CPU @ 3.60GHz
Processor Voltage 8ch - 1.2V
External Clock 100MHz
Max Speed 3800MHz
Current Speed 3600MHz
Status Enabled Populated
Processor Upgrade Socket LGA1155
L1 Cache Handle 0023h
L2 Cache Handle 0024h
L3 Cache Handle 0025h
Serial Number [String Not Specified]
Asset Tag Number [String Not Specified]
Part Number [String Not Specified]
Core Count 2
Core Enabled 2
Thread Count 4
Processor Characteristics fc
Enabled Characteristics:
0x 2: 64-bit Capable
0x 3: Multi-Core
0x 4: Hardware Thread
0x 5: Execute Protection
0x 6: Enhanced Virtualization
Processor Family 2 00ceh - Intel Core 2 Extreme processor
[Cache Information (Type 7) - Length 19 - Handle 0023h]
Socket Designation CPU Internal L1
Cache Configuration 0180h - WBEnabled Int NonSocketed L1
Maximum Cache Size 0080h - 128K
Installed Size 0080h - 128K
Supported SRAM Type 0020h - Synchronous
Current SRAM Type 0020h - Synchronous
Cache Speed 0ns
Error Correction Type ParitySingle-Bit ECC
System Cache Type Other
Associativity 8-way Set-Associative
Maximum Cache Size 2 20555043 - 542462019l Kb
[Cache Information (Type 7) - Length 19 - Handle 0024h]
Socket Designation CPU Internal L2
Cache Configuration 0181h - WBEnabled Int NonSocketed L2
Maximum Cache Size 0200h - 512K
Installed Size 0200h - 512K
Cache Speed 0ns
Error Correction Type Multi-Bit ECC
System Cache Type Unified
[Cache Information (Type 7) - Length 19 - Handle 0025h]
Socket Designation CPU Internal L3
Cache Configuration 0182h - WBEnabled Int NonSocketed L3
Maximum Cache Size 0c00h - 3072K
Installed Size 0c00h - 3072K
Cache Speed 0ns
Error Correction Type Specification Reserved
Associativity 12-way Set-Associative
[Physical Memory Array (Type 16) - Length 23 - Handle 0027h]
Location 03h - SystemBoard/Motherboard
Use 03h - System Memory
Memory Error Correction 03h - None
Maximum Capacity 16777216KB
Memory Error Inf Handle [Not Provided]
Number of Memory Devices 2
[Memory Device (Type 17) - Length 40 - Handle 0028h]
Memory Error Info Handle [Not Provided]
Total Width 64 bits
Data Width 64 bits
Size 4096MB
Form Factor 09h - DIMM
Device Set [None]
Device Locator DIMM1
Bank Locator BANK 0
Memory Type 18h - DDR3
Type Detail 0080h - Synchronous
Speed 1333MHz
Manufacturer Samsung
Serial Number
Asset Tag Number
Part Number M378B5173EB0-YK0
Attributes 1
Extended Size 0
Configured Memory Speed 1333
Minimum Voltage 1350
Maximum Voltage 1500
Configured Voltage 1500
[Memory Device (Type 17) - Length 40 - Handle 0029h]
Total Width 64 bits
Data Width 64 bits
Size 4096MB
Device Set [None]
Device Locator DIMM2
Bank Locator BANK 2
Speed 1333MHz
Manufacturer 0000
Serial Number
Asset Tag Number
Part Number
Attributes 2
Extended Size 0
Minimum Voltage 1500
[Memory Array Mapped Address (Type 19) - Length 31 - Handle 002ah]
Starting Address 00000000h
Ending Address 007fffffh
Memory Array Handle 0027h
Partition Width 02
Extended Starting Address 0000000000000000h
Extended Ending Address 0000000000000000h
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 002bh]
Ending Address 003fffffh
Memory Device Handle 0028h
Mem Array Mapped Adr Handle 002ah
Partition Row Position 01
Interleave Position 01
Interleave Data Depth 01
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 002ch]
Starting Address 00400000h
Memory Device Handle 0029h
[ (Type 256) - Length 5 - Handle 002fh]
[ (Type 256) - Length 6 - Handle 0034h]
[ (Type 256) - Length 12 - Handle 0035h]
[ (Type 256) - Length 26 - Handle 0036h]
[ (Type 256) - Length 68 - Handle 0037h]
[ (Type 256) - Length 26 - Handle 0038h]
[ (Type 256) - Length 54 - Handle 0039h]
[ (Type 256) - Length 12 - Handle 003ah]
[ (Type 256) - Length 64 - Handle 003ch]
[ (Type 256) - Length 4 - Handle 003dh]
Arguments:
Debugging Details:
Key : AV.Type
Value: Execute
Value: 718
Value: 1209
Value: 0
Value: 1
Value: 0
Value: 234
Value: 4293
Value: 85
Value: 1.2503.24.1
Value: 0x1000007e
Value: 0x1000007e
Value: 0x8
Value: 1
Value: 0xc0000005
Value: 0x76c4ea
Key : Failure.Hash
Value: Unloaded
BUGCHECK_CODE: 7e
NumberParameters: 2
BLACKBOXWINLOGON: 1
IP_MODULE_UNLOADED:
STACK_TEXT:
OSNAME: Windows 10
[DMI Version - 0]
Vendor AMI
BIOS Version 80.12
07: - PCI Supported
19: - EDD Supported
Version
Product 2B34
Version 2.10
Serial Number
Asset Tag
Feature Flags 0dh
00: - Motherboard
02: - Removeable
03: - Replaceable
Location
Version
Serial Number
Asset Tag Number
Bootup State Safe
Thermal State Safe
Height 0U
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
Max Speed 3800MHz
Core Count 2
Core Enabled 2
Thread Count 4
0x 3: Multi-Core
Cache Speed 0ns
Cache Speed 0ns
Cache Speed 0ns
Total Width 64 bits
Data Width 64 bits
Size 4096MB
Device Set [None]
Bank Locator BANK 0
Speed 1333MHz
Serial Number
Asset Tag Number
Attributes 1
Extended Size 0
Total Width 64 bits
Data Width 64 bits
Size 4096MB
Device Set [None]
Bank Locator BANK 2
Speed 1333MHz
Manufacturer 0000
Serial Number
Asset Tag Number
Part Number
Attributes 2
Extended Size 0
Partition Width 02
Anladım Recep hocam cihaza format attım BIOS'u güncelleştirmeye çalışacağım.Bu sorun BattlEye anti-hile kaynklı gibi.
Öte yandan BIOS güncel değil gibi, güncellemenizi öneririm:
Kod:SYSTEM_THREAD_EXCEPTION_NOT_HANDLED (7e) This is a very common BugCheck. Usually the exception address pinpoints. the driver/function that caused the problem. Always note this address. as well as the link date of the driver/image that contains this address. Arguments: Arg1: ffffffffc0000005, The exception code that was not handled. Arg2: fffff80475f6c4ea, The address that the exception occurred at. Arg3: ffffca064a0c1508, Exception Record Address. Arg4: ffffca064a0c0d40, Context Record Address. Debugging Details: ------------------ KEY_VALUES_STRING: 1 Key : AV.Type Value: Execute. Key : Analysis.CPU.mSec Value: 718. Key : Analysis.Elapsed.mSec Value: 1209. Key : Analysis.IO.Other.Mb Value: 0 Key : Analysis.IO.Read.Mb Value: 1 Key : Analysis.IO.Write.Mb Value: 0 Key : Analysis.Init.CPU.mSec Value: 234. Key : Analysis.Init.Elapsed.mSec Value: 4293. Key : Analysis.Memory.CommitPeak.Mb Value: 85. Key : Analysis.Version.DbgEng Value: 10.0.27829.1001 Key : Analysis.Version.Description Value: 10.2503.24.01 amd64fre. Key : Analysis.Version.Ext Value: 1.2503.24.1 Key : Bugcheck.Code.LegacyAPI Value: 0x1000007e. Key : Bugcheck.Code.TargetModel Value: 0x1000007e. Key : Dump.Attributes.AsUlong Value: 0x8. Key : Dump.Attributes.KernelGeneratedTriageDump Value: 1 Key : Failure.Bucket Value: AV_UNLOADED_IP_BEDaisy.sys!Unloaded Key : Failure.Exception.Code Value: 0xc0000005. Key : Failure.Exception.IP.Address Value: 0xfffff80475f6c4ea. Key : Failure.Exception.IP.Offset Value: 0x76c4ea. Key : Failure.Exception.Record Value: 0xffffca064a0c1508. Key : Failure.Hash Value: {8255f976-0927-f004-99d3-7ebef7b48545} Key : Faulting.IP.Type Value: Unloaded. BUGCHECK_CODE: 7e. BUGCHECK_P1: ffffffffc0000005. BUGCHECK_P2: fffff80475f6c4ea. BUGCHECK_P3: ffffca064a0c1508. BUGCHECK_P4: ffffca064a0c0d40. FILE_IN_CAB: 050225-21000-01.dmp DUMP_FILE_ATTRIBUTES: 0x8. Kernel Generated Triage Dump. FAULTING_THREAD: ffffe48e8f513080. EXCEPTION_RECORD: ffffca064a0c1508 -- (.exr 0xffffca064a0c1508) ExceptionAddress: fffff80475f6c4ea (<Unloaded_BEDaisy.sys>+0x000000000076c4ea) ExceptionCode: c0000005 (Access violation) ExceptionFlags: 00000000. NumberParameters: 2 Parameter[0]: 0000000000000008. Parameter[1]: fffff80475f6c4ea. Attempt to execute non-executable address fffff80475f6c4ea. CONTEXT: ffffca064a0c0d40 -- (.cxr 0xffffca064a0c0d40) rax=0000000000000009 rbx=ffffe48ea0b3a010 rcx=730cf2af6eba0000 rdx=0000000000000000 rsi=fffff80475811b84 rdi=ffffe48ea0b3a010 rip=fffff80475f6c4ea rsp=ffffca064a0c1740 rbp=ffffca064a0c17c9 r8=0000000000000004 r9=0000000000000000 r10=ffffca064a0c1c60 r11=0000000000000000 r12=0000000000000000 r13=ffffffffffffffff r14=ffffe48e8f513118 r15=0000000000000000 iopl=0 nv up ei ng nz na pe nc. cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00010282 <Unloaded_BEDaisy.sys>+0x76c4ea: fffff804`75f6c4ea ?? ??? Resetting default scope. BLACKBOXBSD: 1 (!blackboxbsd) BLACKBOXNTFS: 1 (!blackboxntfs) BLACKBOXWINLOGON: 1 CUSTOMER_CRASH_COUNT: 1 PROCESS_NAME: System. EXECUTE_ADDRESS: fffff80475f6c4ea. FAILED_INSTRUCTION_ADDRESS: <Unloaded_BEDaisy.sys>+76c4ea fffff804`75f6c4ea ?? ??? ERROR_CODE: (NTSTATUS) 0xc0000005 - 0x%p adresindeki y nerge 0x%p adresindeki belle e ba vurdu. Bellek u olamaz %s. EXCEPTION_CODE_STR: c0000005. EXCEPTION_PARAMETER1: 0000000000000008. EXCEPTION_PARAMETER2: fffff80475f6c4ea. IP_MODULE_UNLOADED: <Unloaded_BEDaisy.sys>+76c4ea fffff804`75f6c4ea ?? ??? EXCEPTION_STR: 0xc0000005. STACK_TEXT: ffffca06`4a0c1740 ffffe48e`a0b3a010 : ffffca06`4a0c17c9 fffff804`75811b84 ffffca06`4a0bc000 ffffe48e`8f513080 : <Unloaded_BEDaisy.sys>+0x76c4ea ffffca06`4a0c1748 ffffca06`4a0c17c9 : fffff804`75811b84 ffffca06`4a0bc000 ffffe48e`8f513080 fffff801`4c45141b : 0xffffe48e`a0b3a010 ffffca06`4a0c1750 fffff804`75811b84 : ffffca06`4a0bc000 ffffe48e`8f513080 fffff801`4c45141b 00000000`00000000 : 0xffffca06`4a0c17c9 ffffca06`4a0c1758 ffffca06`4a0bc000 : ffffe48e`8f513080 fffff801`4c45141b 00000000`00000000 00000000`00000000 : <Unloaded_BEDaisy.sys>+0x11b84 ffffca06`4a0c1760 ffffe48e`8f513080 : fffff801`4c45141b 00000000`00000000 00000000`00000000 00000000`00000000 : 0xffffca06`4a0bc000 ffffca06`4a0c1768 fffff801`4c45141b : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0xffffe48e`8f513080 ffffca06`4a0c1770 fffff801`4c42a7f7 : 00000000`00000000 00000000`00000000 00000000`00000000 ffffe48e`00000000 : nt!KiDeliverApc+0x27b ffffca06`4a0c1830 fffff801`4c4299ff : ffffffff`00000003 00000000`00000002 ffffca06`4a0c19f0 00000000`00000000 : nt!KiSwapThread+0x827 ffffca06`4a0c18e0 fffff801`4c4292a3 : 00000000`00000000 fffff801`00000000 ffffaa81`6a600100 ffffe48e`8f5131c0 : nt!KiCommitThreadWait+0x14f ffffca06`4a0c1980 fffff801`4c4749df : ffffe48e`8f48ab78 00000000`00000000 fffff801`00000000 ffffaa81`6a600100 : nt!KeWaitForSingleObject+0x233 ffffca06`4a0c1a70 fffff801`4c5af618 : ffffe48e`8f498690 ffffca06`00000000 fffff801`4ce50c00 00000000`00000008 : nt!MiZeroLargePages+0x2ef ffffca06`4a0c1b60 fffff801`4c5347d5 : 00000000`00000000 ffffe48e`8f4971a0 ffffc880`00007000 fffff801`4ce50c00 : nt!MiZeroLargePageThread+0x88 ffffca06`4a0c1c10 fffff801`4c606f38 : ffffaa81`6a540180 ffffe48e`8f513080 fffff801`4c534780 00000000`00000000 : nt!PspSystemThreadStartup+0x55 ffffca06`4a0c1c60 00000000`00000000 : ffffca06`4a0c2000 ffffca06`4a0bc000 00000000`00000000 00000000`00000000 : nt!KiStartSystemThread+0x28 SYMBOL_NAME: BEDaisy.sys!Unloaded+76c4ea MODULE_NAME: BEDaisy. IMAGE_NAME: BEDaisy.sys STACK_COMMAND: .cxr 0xffffca064a0c0d40 ; kb. BUCKET_ID_FUNC_OFFSET: 76c4ea. FAILURE_BUCKET_ID: AV_UNLOADED_IP_BEDaisy.sys!Unloaded OSPLATFORM_TYPE: x64. OSNAME: Windows 10. FAILURE_ID_HASH: {8255f976-0927-f004-99d3-7ebef7b48545} Followup: MachineOwner. --------- [SMBIOS Data Tables v2.8] [DMI Version - 0] [2.0 Calling Convention - No] [Table Size - 2840 bytes] [BIOS Information (Type 0) - Length 24 - Handle 0000h] Vendor AMI. BIOS Version 80.12 BIOS Starting Address Segment f000. BIOS Release Date 08/06/2015 BIOS ROM Size 400000. BIOS Characteristics. 07: - PCI Supported. 09: - Plug and Play Supported. 11: - Upgradeable FLASH BIOS. 12: - BIOS Shadowing Supported. 15: - CD-Boot Supported. 16: - Selectable Boot Supported. 19: - EDD Supported. 26: - Print Screen Device Supported. 27: - Keyboard Services Supported. 28: - Serial Services Supported. 29: - Printer Services Supported. 32: - BIOS Vendor Reserved. 48: - System Vendor Reserved. 49: - System Vendor Reserved. 50: - System Vendor Reserved. 53: - System Vendor Reserved. BIOS Characteristic Extensions. 00: - ACPI Supported. 01: - USB Legacy Supported. 08: - BIOS Boot Specification Supported. 09: - Fn-Key NET-Boot Supported. 10: - Enable Targeted Content Distribution. 11: - UEFI Specification Supported. BIOS Major Revision 128. BIOS Minor Revision 18. EC Firmware Major Revision 255. EC Firmware Minor Revision 255. [System Information (Type 1) - Length 27 - Handle 0001h] Manufacturer Hewlett-Packard Product Name HP 280 G1 MT. Version Serial Number TRF5380J0S. UUID 00000000-0000-0000-0000-000000000000 Wakeup Type Power Switch. SKUNumber K8K51ES#AB8 Family 103C_53307F G=D [BaseBoard Information (Type 2) - Length 15 - Handle 0002h] Manufacturer Hewlett-Packard Product 2B34. Version 2.10 Serial Number Asset Tag Feature Flags 0dh. 00: - Motherboard. 02: - Removeable. 03: - Replaceable. Location Chassis Handle 0003h. Board Type 0ah - Processor/Memory Module. Number of Child Handles 0 [System Enclosure (Type 3) - Length 22 - Handle 0003h] Manufacturer Hewlett-Packard Chassis Type Desktop. Version Serial Number Asset Tag Number Bootup State Safe. Power Supply State Safe. Thermal State Safe. Security Status None. OEM Defined 1146049119. Height 0U. Number of Power Cords 1 Number of Contained Elements 0 Contained Element Size 3 [OEM Strings (Type 11) - Length 5 - Handle 0007h] Number of Strings 32. 1 FBYTE#2U3E3N3R3Y4C4k5W656E6a6y727J7M7Q7T7W7Y7d8D94aJcZch.4N;BUIL 2 DID#14WWDORD302#SABB#DAB8; 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 [System Configuration Options (Type 12) - Length 5 - Handle 0008h] [ (Type 256) - Length 11 - Handle 0020h] [ (Type 256) - Length 11 - Handle 0021h] [Processor Information (Type 4) - Length 42 - Handle 0022h] Socket Designation CPU 1 Processor Type Central Processor. Processor Family ceh - Intel Core 2 Extreme processor. Processor Manufacturer Intel. Processor ID c3060300fffbebbf. Processor Version Intel(R) Core(TM) i3-4160 CPU @ 3.60GHz Processor Voltage 8ch - 1.2V External Clock 100MHz. Max Speed 3800MHz. Current Speed 3600MHz. Status Enabled Populated. Processor Upgrade Socket LGA1155. L1 Cache Handle 0023h. L2 Cache Handle 0024h. L3 Cache Handle 0025h. Serial Number [String Not Specified] Asset Tag Number [String Not Specified] Part Number [String Not Specified] Core Count 2 Core Enabled 2 Thread Count 4 Processor Characteristics fc. Enabled Characteristics: 0x 2: 64-bit Capable. 0x 3: Multi-Core 0x 4: Hardware Thread. 0x 5: Execute Protection. 0x 6: Enhanced Virtualization. 0x 7: Power/Performance Control. Processor Family 2 00ceh - Intel Core 2 Extreme processor. [Cache Information (Type 7) - Length 19 - Handle 0023h] Socket Designation CPU Internal L1. Cache Configuration 0180h - WBEnabled Int NonSocketed L1. Maximum Cache Size 0080h - 128K. Installed Size 0080h - 128K. Supported SRAM Type 0020h - Synchronous. Current SRAM Type 0020h - Synchronous. Cache Speed 0ns. Error Correction Type ParitySingle-Bit ECC. System Cache Type Other. Associativity 8-way Set-Associative Maximum Cache Size 2 20555043 - 542462019l Kb. [Cache Information (Type 7) - Length 19 - Handle 0024h] Socket Designation CPU Internal L2. Cache Configuration 0181h - WBEnabled Int NonSocketed L2. Maximum Cache Size 0200h - 512K. Installed Size 0200h - 512K. Supported SRAM Type 0020h - Synchronous. Current SRAM Type 0020h - Synchronous. Cache Speed 0ns. Error Correction Type Multi-Bit ECC. System Cache Type Unified. Associativity 8-way Set-Associative Maximum Cache Size 2 20555043 - 542462019l Kb. [Cache Information (Type 7) - Length 19 - Handle 0025h] Socket Designation CPU Internal L3. Cache Configuration 0182h - WBEnabled Int NonSocketed L3. Maximum Cache Size 0c00h - 3072K. Installed Size 0c00h - 3072K. Supported SRAM Type 0020h - Synchronous. Current SRAM Type 0020h - Synchronous. Cache Speed 0ns. Error Correction Type Specification Reserved. System Cache Type Unified. Associativity 12-way Set-Associative Maximum Cache Size 2 20555043 - 542462019l Kb. [Physical Memory Array (Type 16) - Length 23 - Handle 0027h] Location 03h - SystemBoard/Motherboard Use 03h - System Memory. Memory Error Correction 03h - None. Maximum Capacity 16777216KB. Memory Error Inf Handle [Not Provided] Number of Memory Devices 2 [Memory Device (Type 17) - Length 40 - Handle 0028h] Memory Error Info Handle [Not Provided] Total Width 64 bits. Data Width 64 bits. Size 4096MB. Form Factor 09h - DIMM. Device Set [None] Device Locator DIMM1. Bank Locator BANK 0 Memory Type 18h - DDR3. Type Detail 0080h - Synchronous. Speed 1333MHz. Manufacturer Samsung. Serial Number Asset Tag Number Part Number M378B5173EB0-YK0 Attributes 1 Extended Size 0 Configured Memory Speed 1333. Minimum Voltage 1350. Maximum Voltage 1500. Configured Voltage 1500. [Memory Device (Type 17) - Length 40 - Handle 0029h] Memory Error Info Handle [Not Provided] Total Width 64 bits. Data Width 64 bits. Size 4096MB. Form Factor 09h - DIMM. Device Set [None] Device Locator DIMM2. Bank Locator BANK 2 Memory Type 18h - DDR3. Type Detail 0080h - Synchronous. Speed 1333MHz. Manufacturer 0000. Serial Number Asset Tag Number Part Number Attributes 2 Extended Size 0 Configured Memory Speed 1333. Minimum Voltage 1500. Maximum Voltage 1500. Configured Voltage 1500. [Memory Array Mapped Address (Type 19) - Length 31 - Handle 002ah] Starting Address 00000000h. Ending Address 007fffffh. Memory Array Handle 0027h. Partition Width 02. Extended Starting Address 0000000000000000h. Extended Ending Address 0000000000000000h. [Memory Device Mapped Address (Type 20) - Length 35 - Handle 002bh] Starting Address 00000000h. Ending Address 003fffffh. Memory Device Handle 0028h. Mem Array Mapped Adr Handle 002ah. Partition Row Position 01. Interleave Position 01. Interleave Data Depth 01. Extended Starting Address 0000000000000000h. Extended Ending Address 0000000000000000h. [Memory Device Mapped Address (Type 20) - Length 35 - Handle 002ch] Starting Address 00400000h. Ending Address 007fffffh. Memory Device Handle 0029h. Mem Array Mapped Adr Handle 002ah. Partition Row Position 01. Interleave Position 01. Interleave Data Depth 01. Extended Starting Address 0000000000000000h. Extended Ending Address 0000000000000000h. [ (Type 256) - Length 5 - Handle 002fh] [ (Type 256) - Length 6 - Handle 0034h] [ (Type 256) - Length 12 - Handle 0035h] [ (Type 256) - Length 26 - Handle 0036h] [ (Type 256) - Length 68 - Handle 0037h] [ (Type 256) - Length 26 - Handle 0038h] [ (Type 256) - Length 54 - Handle 0039h] [ (Type 256) - Length 12 - Handle 003ah] [ (Type 256) - Length 64 - Handle 003ch] [ (Type 256) - Length 4 - Handle 003dh]
