i5 12400F & RTX 4060 Ti sistemde mavi ekran hatası
serkaan24
Üyecik
8 Aralık 2024
Steam'de Ghost of Tsushima oynarken mavi ekran hatası ile karşılaştım. Windows 11 24H2 sürümünü kullanıyorum ilk defa böyle bir hata başıma geldi.
Sistemim:
  • i5 12400F.
  • ASUS H610M-K D4.
  • Zotac 4060 Ti 8 GB.
  • G.Skill 32 GB 3200MHz CL16.
  • Goodram M.2 SSD 500GB.
  • MLD M.2 SSD 1TB.
  • FSP 700W 80+
Minidump dosyası: 120824-10359-01
Mavi ekranın sebebi memory kaynaklı gözüküyor ama ciddi bir durum olmayabilir. Tekrar olursa bir daha minidump paylaşın.
Kod:
SYMBOL_NAME:  nt!PspCatchCriticalBreak+128
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
IMAGE_VERSION:  10.0.26100.2454
STACK_COMMAND:  .process /r /p 0xffffa704f7c240c0; .thread 0xffffa704fd8d90c0 ; kb
BUCKET_ID_FUNC_OFFSET:  128
FAILURE_BUCKET_ID:  0xEF_svchost.exe_BUGCHECK_CRITICAL_PROCESS_fd8d90c0_nt!PspCatchCriticalBreak
Kod:
1: kd> !analyze -v
*                        Bugcheck Analysis                                    *
CRITICAL_PROCESS_DIED (ef)
        A critical system process died
Arguments:
Arg1: ffffa704ede680c0, Process object or thread object
Arg2: 0000000000000000, If this is 0, a process died. If this is 1, a thread died.
Arg3: ffffa704f7c240c0, The process object that initiated the termination.
Arg4: 0000000000000000
Debugging Details:
KEY_VALUES_STRING: 1
    Key  : Analysis.CPU.mSec
    Value: 6359
    Key  : Analysis.Elapsed.mSec
    Value: 10152
    Key  : Analysis.IO.Other.Mb
    Value: 0
    Key  : Analysis.IO.Read.Mb
    Value: 0
    Key  : Analysis.IO.Write.Mb
    Value: 0
    Key  : Analysis.Init.CPU.mSec
    Value: 687
    Value: 3892
    Value: 87
    Value: 10.0.27704.1001
    Value: 10.2408.27.01 amd64fre
    Key  : Analysis.Version.Ext
    Value: 1.2408.27.1
    Value: 0xef
    Value: 0xef
    Key  : CriticalProcessDied.ExceptionCode
    Value: fd8d90c0
    Key  : CriticalProcessDied.Process
    Value: svchost.exe
    Value: 21808
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Key  : Failure.Bucket
    Value: 0xEF_svchost.exe_BUGCHECK_CRITICAL_PROCESS_fd8d90c0_nt!PspCatchCriticalBreak
    Key  : Failure.Hash
    Value: {1f8ab8b4-a813-c240-2bcb-d50ca0aec4e2}
    Key  : Hypervisor.Enlightenments.ValueHex
    Value: 7417df84
    Key  : Hypervisor.Flags.AnyHypervisorPresent
    Value: 1
    Key  : Hypervisor.Flags.ApicEnlightened
    Value: 0
    Key  : Hypervisor.Flags.ApicVirtualizationAvailable
    Value: 1
    Key  : Hypervisor.Flags.AsyncMemoryHint
    Value: 0
    Key  : Hypervisor.Flags.CoreSchedulerRequested
    Value: 0
    Key  : Hypervisor.Flags.CpuManager
    Value: 1
    Key  : Hypervisor.Flags.DeprecateAutoEoi
    Value: 1
    Key  : Hypervisor.Flags.DynamicCpuDisabled
    Value: 1
    Key  : Hypervisor.Flags.Epf
    Value: 0
    Key  : Hypervisor.Flags.ExtendedProcessorMasks
    Value: 1
    Key  : Hypervisor.Flags.HardwareMbecAvailable
    Value: 1
    Key  : Hypervisor.Flags.MaxBankNumber
    Value: 0
    Key  : Hypervisor.Flags.MemoryZeroingControl
    Value: 0
    Key  : Hypervisor.Flags.NoExtendedRangeFlush
    Value: 0
    Key  : Hypervisor.Flags.NoNonArchCoreSharing
    Value: 1
    Key  : Hypervisor.Flags.Phase0InitDone
    Value: 1
    Key  : Hypervisor.Flags.PowerSchedulerQos
    Value: 0
    Key  : Hypervisor.Flags.RootScheduler
    Value: 0
    Key  : Hypervisor.Flags.SynicAvailable
    Value: 1
    Key  : Hypervisor.Flags.UseQpcBias
    Value: 0
    Key  : Hypervisor.Flags.Value
    Value: 55185662
    Key  : Hypervisor.Flags.ValueHex
    Value: 34a10fe
    Key  : Hypervisor.Flags.VpAssistPage
    Value: 1
    Key  : Hypervisor.Flags.VsmAvailable
    Value: 1
    Key  : Hypervisor.RootFlags.AccessStats
    Value: 1
    Key  : Hypervisor.RootFlags.CrashdumpEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.CreateVirtualProcessor
    Value: 1
    Key  : Hypervisor.RootFlags.DisableHyperthreading
    Value: 0
    Key  : Hypervisor.RootFlags.HostTimelineSync
    Value: 1
    Key  : Hypervisor.RootFlags.HypervisorDebuggingEnabled
    Value: 0
    Key  : Hypervisor.RootFlags.IsHyperV
    Value: 1
    Key  : Hypervisor.RootFlags.LivedumpEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.MapDeviceInterrupt
    Value: 1
    Key  : Hypervisor.RootFlags.MceEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.Nested
    Value: 0
    Key  : Hypervisor.RootFlags.StartLogicalProcessor
    Value: 1
    Key  : Hypervisor.RootFlags.Value
    Value: 1015
    Key  : Hypervisor.RootFlags.ValueHex
    Value: 3f7
BUGCHECK_CODE:  ef
BUGCHECK_P1: ffffa704ede680c0
BUGCHECK_P2: 0
BUGCHECK_P3: ffffa704f7c240c0
BUGCHECK_P4: 0
FILE_IN_CAB:  120824-10359-01.dmp
TAG_NOT_DEFINED_202b:  *** Unknown TAG in analysis list 202b
DUMP_FILE_ATTRIBUTES: 0x21808
  Kernel Generated Triage Dump
FAULTING_THREAD:  ffffa704fd8d90c0
PROCESS_NAME:  svchost.exe
CRITICAL_PROCESS:  svchost.exe
ERROR_CODE: (NTSTATUS) 0xfd8d90c0 - <Unable to get error code text>
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT:  1
STACK_TEXT:
fffff989`bbf42838 fffff807`79953b30     : 00000000`000000ef ffffa704`ede680c0 00000000`00000000 ffffa704`f7c240c0 : nt!KeBugCheckEx
fffff989`bbf42840 fffff807`79b618df     : ffffa704`ede680c0 fffff807`794546f4 00000000`00000000 ffffa704`ede680c0 : nt!PspCatchCriticalBreak+0x128
fffff989`bbf428e0 fffff807`79b61277     : ffffa704`ede680c0 ffffa704`ede68288 ffffa704`ede680c0 00000000`00000000 : nt!PspTerminateAllThreads+0x27b
fffff989`bbf42960 fffff807`79b5f251     : ffffa704`ede680c0 00000000`00000001 ffffa704`fd8d90c0 ffffa704`f7c240c0 : nt!PspTerminateProcess+0xf7
fffff989`bbf429a0 fffff807`7988d155     : ffffa704`ede680c0 ffffa704`fd8d90c0 01db41d1`c6dd6dc8 00260000`00000010 : nt!NtTerminateProcess+0xd1
fffff989`bbf42a20 00000000`76f21f83     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x25
00000000`0206ef18 00000000`00000000     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x76f21f83
MODULE_NAME: nt
OSPLATFORM_TYPE:  x64
OSNAME:  Windows 10
FAILURE_ID_HASH:  {1f8ab8b4-a813-c240-2bcb-d50ca0aec4e2}
Followup:     MachineOwner
