Cantrepreneur
- 8 Nisan 2025
PUBG'de ve fark edebildiğim tüm yüke giren işlemlerde mikro takılmalar yaşıyorum (en barizi PUBG), aklıma gelen her çözümü denedim. Defalarca BIOS ayarlarını sıfırladım, tek tek işe yarayabilecek tüm ayarları aç/kapa yaptım. Ancak yine de günün sonunda mikro takılmalar devam ediyor. Diskleri taradım, Passmark ve Memtest yaptım. Sıcaklıkları kontrol ettim ve LatencyMon testi yaptım. Ayrıca BIOS'um ve ekran kartı sürücüm güncel. (BIOS: 3801 - GPU: 25.8.1)
Sistem:
PassMark raporu:
LatencyMon raporu:
Sistem:
- Prime B660 Plus D4
- i5 12400F
- 2x8G Corsair Vengeance LPX 3200MHz CL16
- 2x8G Patriot Viper Steel 3200MHz CL16
- (XMP profili aktif, 3200MHz'de çalışıyorlar. Command Rate 1T)
- Radeon RX 6800
- Kingston KC3000 1TB
- Kioxia Exceria G2 1TB.
- Sharkoon Coolzero 750W Gold
PassMark raporu:
LatencyMon raporu:
Kod:
_________________________________________________________________________________________________________
CONCLUSION
Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One or more DPC routines that belong to a driver running in your system appear to be executing for too long. At least one detected problem appears to be network related. In case you are using a WLAN adapter, try disabling it to get better results. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:21:11 (h:mm:ss) on processors 0,1,2,3,4 and 5.
SYSTEM INFORMATION
Computer name: DESKTOP
OS version: Windows 10, 10.0, version 2009, build: 19045 (x64)
Hardware: System Product Name, ASUS
BIOS: 3801
CPU: GenuineIntel 12th Gen Intel(R) Core(TM) i5-12400F
Logical processors: 12
Processor groups: 1
Processor group size: 12
RAM: 32581 MB total
CPU SPEED
Reported CPU speed (WMI): 250 MHz
Reported CPU speed (registry): 2496 MHz
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs): 6599,70
Average measured interrupt to process latency (µs): 7,456228
Highest measured interrupt to DPC latency (µs): 6595,80
Average measured interrupt to DPC latency (µs): 3,537723
REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 455,392628
Driver with highest ISR routine execution time: HDAudBus.sys - High Definition Audio Bus Driver, Microsoft Corporation
Highest reported total ISR routine time (%): 0,014513
Driver with highest ISR total time: HDAudBus.sys - High Definition Audio Bus Driver, Microsoft Corporation
Total time spent in ISRs (%) 0,017045
ISR count (execution time <250 µs): 396909
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-1000 µs): 5
ISR count (execution time 1000-2000 µs): 0
ISR count (execution time 2000-4000 µs): 0
ISR count (execution time >=4000 µs): 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs): 4866,205128
Driver with highest DPC routine execution time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Highest reported total DPC routine time (%): 0,168161
Driver with highest DPC total execution time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Total time spent in DPCs (%) 0,326260
DPC count (execution time <250 µs): 5585992
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-10000 µs): 653
DPC count (execution time 1000-2000 µs): 7
DPC count (execution time 2000-4000 µs): 0
DPC count (execution time >=4000 µs): 1
REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count: tslgame.exe
Total number of hard pagefaults 9435
Hard pagefault count of hardest hit process: 5115
Number of processes hit: 18
PER CPU DATA
CPU 0 Interrupt cycle time (s): 136,071099
CPU 0 ISR highest execution time (µs): 455,392628
CPU 0 ISR total execution time (s): 0,787636
CPU 0 ISR count: 91565
CPU 0 DPC highest execution time (µs): 4866,205128
CPU 0 DPC total execution time (s): 42,764028
CPU 0 DPC count: 4999734
CPU 1 Interrupt cycle time (s): 23,884364
CPU 1 ISR highest execution time (µs): 165,389022
CPU 1 ISR total execution time (s): 1,495747
CPU 1 ISR count: 284707
CPU 1 DPC highest execution time (µs): 544,636218
CPU 1 DPC total execution time (s): 6,116180
CPU 1 DPC count: 347992
CPU 2 Interrupt cycle time (s): 11,643283
CPU 2 ISR highest execution time (µs): 133,084535
CPU 2 ISR total execution time (s): 0,317402
CPU 2 ISR count: 20642
CPU 2 DPC highest execution time (µs): 1086,040064
CPU 2 DPC total execution time (s): 0,377580
CPU 2 DPC count: 81625
CPU 3 Interrupt cycle time (s): 9,788502
CPU 3 ISR highest execution time (µs): 0,0
CPU 3 ISR total execution time (s): 0,0
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 441,599359
CPU 3 DPC total execution time (s): 0,140435
CPU 3 DPC count: 37192
CPU 4 Interrupt cycle time (s): 10,383293
CPU 4 ISR highest execution time (µs): 0,0
CPU 4 ISR total execution time (s): 0,0
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 539,590144
CPU 4 DPC total execution time (s): 0,243274
CPU 4 DPC count: 75289
CPU 5 Interrupt cycle time (s): 9,044781
CPU 5 ISR highest execution time (µs): 0,0
CPU 5 ISR total execution time (s): 0,0
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 215,821715
CPU 5 DPC total execution time (s): 0,139775
CPU 5 DPC count: 44821
