Riddikulus
18 Şubat 2025
  • Anakart: Z790e 2ifi 2
  • İşlemci: i9 14900KF.
  • Ekran kartı: ASUS ROG 4090.
  • İşletim sistemi: Windows 11.
Devamlı mavi ekran hatsı alıyoruz. minidump dosyasını bırakıyorum.
  • Bugcheck Analysis *
ATTEMPTED_EXECUTE_OF_NOEXECUTE_MEMORY (fc)
An attempt was made to execute non-executable memory. The guilty driver
is on the stack trace (and is typically the current instruction pointer).
When possible, the guilty driver's name is printed on
the BugCheck screen and saved in KiBugCheckDriver.
Arguments:
Arg1: fffff805955e0b4c, Virtual address for the attempted execute.
Arg2: 890000084c95f121, PTE contents.
Arg3: ffffa3852d906e60, (reserved)
Arg4: 0000000000000002, (reserved)
Debugging Details:
*** WARNING: Check Image - Checksum mismatch - Dump: 0xc2ed94, File: 0xc31fe0 - C:\ProgramData\Dbg\sym\ntkrnlmp.exe\783A7A83144f000\ntkrnlmp.exe
KEY_VALUES_STRING: 1
Key : Analysis.CPU.mSec
Value: 1968
Key : Analysis.Elapsed.mSec
Value: 14531
Key : Analysis.IO.Other.Mb
Value: 10
Key : Analysis.IO.Read.Mb
Value: 1
Key : Analysis.IO.Write.Mb
Value: 35
Key : Analysis.Init.CPU.mSec
Value: 500
Value: 20812
Value: 89
Key : Analysis.Version.DbgEng
Value: 10.0.27793.1000
Key : Analysis.Version.Description
Value: 10.2410.02.02 amd64fre
Key : Analysis.Version.Ext
Value: 1.2410.2.2
Key : Bugcheck.Code.LegacyAPI
Value: 0xfc
Key : Bugcheck.Code.TargetModel
Value: 0xfc
Key : Dump.Attributes.AsUlong
Value: 0x21008
Key : Dump.Attributes.DiagDataWrittenToHeader
Value: 1
Key : Dump.Attributes.ErrorCode
Value: 0x0
Key : Dump.Attributes.KernelGeneratedTriageDump
Value: 1
Key : Dump.Attributes.LastLine
Key : Dump.Attributes.ProgressPercentage
Value: 0
Key : Failure.Bucket
Value: 0xFC_BEDaisy!unknown_function
Key : Failure.Hash
Value: {a24e0638-e198-51fb-c7bd-6e4a4908e6d3}
BUGCHECK_CODE: fc
BUGCHECK_P1: fffff805955e0b4c
BUGCHECK_P2: 890000084c95f121
BUGCHECK_P3: ffffa3852d906e60
BUGCHECK_P4: 2
FILE_IN_CAB: 032725-4781-01.dmp
DUMP_FILE_ATTRIBUTES: 0x21008
Kernel Generated Triage Dump
FAULTING_THREAD: ffffe509c2415540
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: System
TRAP_FRAME: ffffa3852d906e60 -- (.trap 0xffffa3852d906e60)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=00000002cf1c00fa rbx=0000000000000000 rcx=0100000038939c01
rdx=00000000ffffe703 rsi=0000000000000000 rdi=0000000000000000
rip=fffff805955e0b4c rsp=ffffa3852d906ff0 rbp=fffff8059833d7cf
r8=fffff805955e0b4c r9=000000025c8ddd39 r10=0000000038939c94
r11=00000000b6bc0e0a r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei pl nz na po cy
rhproxy!_report_gsfailure <PERF> (rhproxy+0xb4c):
fffff805`955e0b4c 0000 add byte ptr [rax],al ds:00000002`cf1c00fa=??
Resetting default scope
STACK_TEXT:
ffffa385`2d906ff0 00000000`00000018 : 00000000`000010f6 00000000`00000023 00000000`09ffff64 00000000`00000018 : rhproxy!_report_gsfailure <PERF> (rhproxy+0xb4c)
ffffa385`2d906ff8 00000000`000010f6 : 00000000`00000023 00000000`09ffff64 00000000`00000018 00000000`00000001 : 0x18
ffffa385`2d907000 00000000`00000023 : 00000000`09ffff64 00000000`00000018 00000000`00000001 ffffd08e`6bebded0 : 0x10f6
ffffa385`2d907008 00000000`09ffff64 : 00000000`00000018 00000000`00000001 ffffd08e`6bebded0 00000000`0000000f : 0x23
ffffa385`2d907010 00000000`00000018 : 00000000`00000001 ffffd08e`6bebded0 00000000`0000000f 00000000`80000003 : 0x9ffff64
ffffa385`2d907018 00000000`00000001 : ffffd08e`6bebded0 00000000`0000000f 00000000`80000003 ffffd08e`6bebded0 : 0x18
ffffa385`2d907020 ffffd08e`6bebded0 : 00000000`0000000f 00000000`80000003 ffffd08e`6bebded0 ffffd08e`677f0218 : 0x1
ffffa385`2d907028 00000000`0000000f : 00000000`80000003 ffffd08e`6bebded0 ffffd08e`677f0218 00000001`401fda08 : 0xffffd08e`6bebded0
ffffa385`2d907030 00000000`80000003 : ffffd08e`6bebded0 ffffd08e`677f0218 00000001`401fda08 00000000`00000023 : 0xf
ffffa385`2d907038 ffffd08e`6bebded0 : ffffd08e`677f0218 00000001`401fda08 00000000`00000023 00000000`fffffff5 : 0x80000003
ffffa385`2d907040 ffffd08e`677f0218 : 00000001`401fda08 00000000`00000023 00000000`fffffff5 00000000`00000023 : 0xffffd08e`6bebded0
ffffa385`2d907048 00000001`401fda08 : 00000000`00000023 00000000`fffffff5 00000000`00000023 ffffa385`2d9072e0 : 0xffffd08e`677f0218
ffffa385`2d907050 00000000`00000023 : 00000000`fffffff5 00000000`00000023 ffffa385`2d9072e0 00000000`00040202 : 0x00000001`401fda08
ffffa385`2d907058 00000000`fffffff5 : 00000000`00000023 ffffa385`2d9072e0 00000000`00040202 ffffd08e`68fc68a0 : 0x23
ffffa385`2d907060 00000000`00000023 : ffffa385`2d9072e0 00000000`00040202 ffffd08e`68fc68a0 00000000`00000022 : 0xfffffff5
ffffa385`2d907068 ffffa385`2d9072e0 : 00000000`00040202 ffffd08e`68fc68a0 00000000`00000022 00000000`00000002 : 0x23
ffffa385`2d907070 00000000`00040202 : ffffd08e`68fc68a0 00000000`00000022 00000000`00000002 fffff805`9833da08 : 0xffffa385`2d9072e0
ffffa385`2d907078 ffffd08e`68fc68a0 : 00000000`00000022 00000000`00000002 fffff805`9833da08 00000000`00000001 : 0x40202
ffffa385`2d907080 00000000`00000022 : 00000000`00000002 fffff805`9833da08 00000000`00000001 fffff804`58140000 : 0xffffd08e`68fc68a0
ffffa385`2d907088 00000000`00000002 : fffff805`9833da08 00000000`00000001 fffff804`58140000 00000000`00002001 : 0x22
ffffa385`2d907090 fffff805`9833da08 : 00000000`00000001 fffff804`58140000 00000000`00002001 00000000`09ffff38 : 0x2
ffffa385`2d907098 00000000`00000001 : fffff804`58140000 00000000`00002001 00000000`09ffff38 ffffd08e`00000018 : BEDaisy+0x1fda08
ffffa385`2d9070a0 fffff804`58140000 : 00000000`00002001 00000000`09ffff38 ffffd08e`00000018 00000001`401fda08 : 0x1
ffffa385`2d9070a8 00000000`00002001 : 00000000`09ffff38 ffffd08e`00000018 00000001`401fda08 00000000`00040283 : 0xfffff804`58140000
ffffa385`2d9070b0 00000000`09ffff38 : ffffd08e`00000018 00000001`401fda08 00000000`00040283 fffff805`98144f9f : 0x2001
ffffa385`2d9070b8 ffffd08e`00000018 : 00000001`401fda08 00000000`00040283 fffff805`98144f9f ffffa385`2d9072a0 : 0x9ffff38
ffffa385`2d9070c0 00000001`401fda08 : 00000000`00040283 fffff805`98144f9f ffffa385`2d9072a0 ffffa385`2d9072e0 : 0xffffd08e`00000018
ffffa385`2d9070c8 00000000`00040283 : fffff805`98144f9f ffffa385`2d9072a0 ffffa385`2d9072e0 ffffa385`2d907320 : 0x00000001`401fda08
ffffa385`2d9070d0 fffff805`98144f9f : ffffa385`2d9072a0 ffffa385`2d9072e0 ffffa385`2d907320 00000000`00000023 : 0x40283
ffffa385`2d9070d8 ffffa385`2d9072a0 : ffffa385`2d9072e0 ffffa385`2d907320 00000000`00000023 ffffd08e`68fc68a0 : BEDaisy+0x4f9f
ffffa385`2d9070e0 ffffa385`2d9072e0 : ffffa385`2d907320 00000000`00000023 ffffd08e`68fc68a0 00000000`00000000 : 0xffffa385`2d9072a0
ffffa385`2d9070e8 ffffa385`2d907320 : 00000000`00000023 ffffd08e`68fc68a0 00000000`00000000 00000000`00000000 : 0xffffa385`2d9072e0
ffffa385`2d9070f0 00000000`00000023 : ffffd08e`68fc68a0 00000000`00000000 00000000`00000000 00000000`00000000 : 0xffffa385`2d907320
ffffa385`2d9070f8 ffffd08e`68fc68a0 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000019 : 0x23
ffffa385`2d907100 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000019 00000000`00000018 : 0xffffd08e`68fc68a0
STACK_COMMAND: .trap 0xffffa3852d906e60 ; kb
SYMBOL_NAME: BEDaisy+1fda08
MODULE_NAME: BEDaisy
IMAGE_NAME: BEDaisy.sys
BUCKET_ID_FUNC_OFFSET: 1fda08
FAILURE_BUCKET_ID: 0xFC_BEDaisy!unknown_function
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {a24e0638-e198-51fb-c7bd-6e4a4908e6d3}
Followup: MachineOwner
Hata BEDaisy.sys sürücüsünden kaynaklanıyor. Yani, BattleEye ile alakalı bir mavi ekran alıyorsun. Sil ve tekrar yükle. Sorun çözülürse çözüm olarak işaretlerseniz diğer kullanıcılarda bu konudan faydalanabilir.
Arguments:
Debugging Details:
Value: 1968
Value: 14531
Value: 10
Value: 1
Value: 35
Value: 500
Value: 20812
Value: 89
Value: 1.2410.2.2
Value: 0xfc
Value: 0xfc
Value: 0x21008
Value: 1
Value: 0x0
Value: 1
Value: 0
Key : Failure.Hash
BUGCHECK_CODE: fc
BUGCHECK_P4: 2
BLACKBOXWINLOGON: 1
STACK_TEXT:
OSNAME: Windows 10
BattlEye hatası olarak gözükse de "Devamlı" ibaresi önemli. Ne kadar devamlı? Sadece BattlEye kullanan oyunlarda mı devamlı? Yoksa devamlı devamlı mı? Soru anlaşılmıştır umarım.
Bana kalırsa bu dosyadan bile donanımsal sorun var diyebilirim ama senin bu konuya aydınlık getirmen daha önemli.
  • Bugcheck analysis *
ATTEMPTED_EXECUTE_OF_NOEXECUTE_MEMORY (FC)
An attempt was made to execute non-executable Memory. The guilty driver.
İs on the stack trace (and is typically the current instruction pointer).
When possible, the guilty driver's name is printed on.
The bugcheck screen and saved in kibugcheckdriver.
Arguments:
Arg1: FffFF805955e0b4C, Virtual address for the attempted execute.
Arg2: 890000084C95F121, pte contents.
Arg3: FffFA3852D906e60, (reserved)
Debugging details:
*** Warnıng: Check ımage - checksum mismatch - dump: 0xc2ed94, file: 0xc31fe0 - C:\ProgramData\Dbg\sym\ntkrnlmp.exe\783A7A83144f000\ntkrnlmp.exe
Key_values_strıng: 1
Key: Analysis. CPU. Msec.
Value: 1968.
Key: Analysis. Elapsed. Msec.
Value: 14531.
Key: Analysis. IO. Other. MB.
Value: 10.
Key: Analysis. IO. Read. MB.
Value: 1
Key: Analysis. IO. Write. MB.
Value: 35.
Key: Analysis. Init. CPU. Msec.
Value: 500.
Key: Analysis. Init. Elapsed. Msec.
Value: 20812.
Key: Analysis. Memory.commitpeak. MB.
Value: 89.
Key: Analysis. Version. Dbgeng.
Key: Analysis. Version. Description.
Value: 10.2410.02.02 AMD64fre.
Key: Analysis. Version. Ext.
Value: 1.2410.2.2
Key: Bugcheck. Code. Legacyapı.
Value: 0xfc.
Key: Bugcheck. Code. Targetmodel.
Value: 0xfc.
Key: Dump. Attributes. Asulong.
Value: 0x21008.
Key: Dump. Attributes. Diagdatawrittentoheader
Value: 1
Key: Dump. Attributes. Errorcode.
Value: 0x0.
Key: Dump. Attributes. Kernelgeneratedtriagedump
Value: 1
Key: Dump. Attributes. Lastline.
Key: Dump. Attributes. Progresspercentage.
Value: 0
Key: Failure. Bucket.
Key: Failure. Hash.
Value: {A24E0638-E198-51FB-C7BD-6E4A4908E6D3}
Bugcheck_code: FC.
Bugcheck_p1: FffFF805955e0B4C.
Bugcheck_p2: 890000084C95F121.
Bugcheck_p3: FFFFA3852D906E60.
Bugcheck_p4: 2
Fıle_ın_cab: 032725-4781-01.dmp
Dump_fıle_attrıbutes: 0x21008.
Kernel generated triage dump.
Faultıng_thread: FFFFE509C2415540.
Blackboxbsd: 1 (!blackboxbsd)
Blackboxntfs: 1 (!blackboxntfs)
Blackboxpnp: 1 (!blackboxpnp)
Blackboxwınlogon: 1
Customer_crash_count: 1
Process_name: System.
Trap_frame: FFFFA3852D906E60 -- (.trap 0xffffa3852d906e60)
Note: The trap frame does not contain all registers.
Rax = 00000002CF1C00fa rbx = 0000000000000000 rcx = 0100000038939C01.
Rdx = 00000000ffffe703 rsi = 0000000000000000 rdi = 0000000000000000.
Rip = fffFF805955e0b4C rsp = fffFA3852D906ff0 rbp = fffFF8059833D7CF.
R8 = fffFF805955e0B4C R9 = 000000025C8ddd39 R10 = 0000000038939C94.
R11 = 00000000b6bc0e0a R12 = 0000000000000000 R13 = 0000000000000000.
R14 = 0000000000000000 R15 = 0000000000000000.
İopl = 0 nv up ei pl nzna po cy.
Rhproxy! _report_gsfailure <perf> (rhproxy+0xb4C):
Fffff805'955e0b4C 0000 add byte ptr [rax],al DS: 00000002'CF1C00fa=?
Resetting default scope.
Stack_text:
Ffffa385'2D906FF0 00000000'00000018: 00000000'000010F6 00000000'00000023 00000000'09ffff64 00000000'00000018: Rhproxy! _report_gsfailure <perf> (rhproxy+0xb4C)
Ffffa385'2D906FF8 00000000'000010F6: 00000000'00000023 00000000'09ffff64 00000000'00000018 00000000'00000001: 0x18.
Ffffa385'2D907000 00000000'00000023: 00000000'09ffff64 00000000'00000018 00000000'00000001 ffffd08e'6bebded0: 0x10f6.
Ffffa385'2D907008 00000000'09ffff64: 00000000'00000018 00000000'00000001 ffffd08e'6bebded0 00000000'0000000F: 0x23.
Ffffa385'2D907010 00000000'00000018: 00000000'00000001 ffffd08e'6bebded0 00000000'0000000F 00000000'80000003: 0x9ffff64.
Ffffa385'2D907018 00000000'00000001: Ffffd08e'6bebded0 00000000'0000000F 00000000'80000003 ffffd08e'6bebded0: 0x18.
Ffffa385'2D907020 ffffd08e'6bebded0: 00000000'0000000F 00000000'80000003 ffffd08e'6bebded0 ffffd08e'677F0218: 0x1.
Ffffa385'2D907028 00000000'0000000F: 00000000'80000003 ffffd08e'6bebded0 ffffd08e'677F0218 00000001'401fda08: 0xffffd08e`6bebded0
Ffffa385'2D907030 00000000'80000003: Ffffd08e'6bebded0 ffffd08e'677F0218 00000001'401fda08 00000000'00000023: 0xf.
Ffffa385'2D907038 ffffd08e'6bebded0: Ffffd08e'677F0218 00000001'401fda08 00000000'00000023 00000000'fffffff5: 0x80000003.
Ffffa385'2D907040 ffffd08e'677F0218: 00000001'401fda08 00000000'00000023 00000000'fffffff5 00000000'00000023: 0xffffd08e`6bebded0
Ffffa385'2D907048 00000001'401fda08: 00000000'00000023 00000000'fffffff5 00000000'00000023 ffffa385'2D9072E0: 0xffffd08e'677F0218.
Ffffa385'2D907050 00000000'00000023: 00000000'fffffff5 00000000'00000023 ffffa385'2D9072E0 00000000'00040202: 0x00000001'401fda08.
Ffffa385'2D907058 00000000'fffffff5: 00000000'00000023 ffffa385'2D9072E0 00000000'00040202 ffffd08e'68FC68a0: 0x23.
Ffffa385'2D907060 00000000'00000023: Ffffa385'2D9072E0 00000000'00040202 ffffd08e'68FC68a0 00000000'00000022: 0xfffffff5.
Ffffa385'2D907068 ffffa385'2D9072E0: 00000000'00040202 ffffd08e'68FC68a0 00000000'00000022 00000000'00000002: 0x23.
Ffffa385'2D907070 00000000'00040202: Ffffd08e'68FC68a0 00000000'00000022 00000000'00000002 fffff805'9833DA08: 0xffffa385'2D9072E0.
Ffffa385'2D907078 ffffd08e'68FC68a0: 00000000'00000022 00000000'00000002 fffff805'9833DA08 00000000'00000001: 0x40202.
Ffffa385'2D907080 00000000'00000022: 00000000'00000002 fffff805'9833DA08 00000000'00000001 fffff804'58140000: 0xffffd08e'68FC68a0.
Ffffa385'2D907088 00000000'00000002: Fffff805'9833DA08 00000000'00000001 fffff804'58140000 00000000'00002001: 0x22.
Ffffa385'2D907090 fffff805'9833DA08: 00000000'00000001 fffff804'58140000 00000000'00002001 00000000'09ffff38: 0x2.
Ffffa385'2D907098 00000000'00000001: Fffff804'58140000 00000000'00002001 00000000'09ffff38 ffffd08e'00000018: Bedaisy+0x1fda08
Ffffa385'2D9070A0 fffff804'58140000: 00000000'00002001 00000000'09ffff38 ffffd08e'00000018 00000001'401fda08: 0x1.
Ffffa385'2D9070A8 00000000'00002001: 00000000'09ffff38 ffffd08e'00000018 00000001'401fda08 00000000'00040283: 0xfffff804'58140000.
Ffffa385'2D9070B0 00000000'09ffff38: Ffffd08e'00000018 00000001'401fda08 00000000'00040283 fffff805'98144F9F: 0x2001.
Ffffa385'2D9070B8 ffffd08e'00000018: 00000001'401fda08 00000000'00040283 fffff805'98144F9F ffffa385'2D9072A0: 0x9ffff38.
Ffffa385'2D9070C0 00000001'401fda08: 00000000'00040283 fffff805'98144F9F ffffa385'2D9072A0 ffffa385'2D9072E0: 0xffffd08e'00000018.
Ffffa385'2D9070C8 00000000'00040283: Fffff805'98144F9F ffffa385'2D9072A0 ffffa385'2D9072E0 ffffa385'2D907320: 0x00000001'401fda08.
Ffffa385'2D9070D0 fffff805'98144F9F: Ffffa385'2D9072A0 ffffa385'2D9072E0 ffffa385'2D907320 00000000'00000023: 0x40283.
Ffffa385'2D9070D8 ffffa385'2D9072A0: Ffffa385'2D9072E0 ffffa385'2D907320 00000000'00000023 ffffd08e'68FC68a0: Bedaisy+0x4F9F
Ffffa385'2D9070E0 ffffa385'2D9072E0: Ffffa385'2D907320 00000000'00000023 ffffd08e'68FC68a0 00000000'00000000: 0xffffa385'2D9072A0.
Ffffa385'2D9070E8 ffffa385'2D907320: 00000000'00000023 ffffd08e'68FC68a0 00000000'00000000 00000000'00000000: 0xffffa385'2D9072E0.
Ffffa385'2D9070F0 00000000'00000023: Ffffd08e'68FC68a0 00000000'00000000 00000000'00000000 00000000'00000000: 0xffffa385'2D907320.
Ffffa385'2D9070F8 ffffd08e'68FC68a0: 00000000'00000000 00000000'00000000 00000000'00000000 00000000'00000019: 0x23.
Ffffa385'2D907100 00000000'00000000: 00000000'00000000 00000000'00000000 00000000'00000019 00000000'00000018: 0xffffd08e'68FC68a0.
Stack_command: Trap 0xfffFA3852D906e60; KB.
Symbol_name: Bedaisy+1fda08
Module_name: Bedaisy.
Image_name: BEDaisy.sys
Bucket_ıd_func_offset: 1fda08.
Faılure_bucket_ıd: 0xFC_BEDaisy!unknown_function
Osplatform_type: X64.
Osname: Windows 10.
Faılure_ıd_hash: {A24E0638-E198-51FB-C7BD-6E4A4908E6D3}
Followup: Machineowner.
Hata BEDaisy.sys sürücüsünden kaynaklanıyor. Yani, BattlEye ile alakalı bir mavi ekran alıyorsun. Sil ve tekrar yükle. Sorun çözülürse çözüm olarak işaretlerseniz diğer kullanıcılarda bu konudan faydalanabilir.
Aynen dediğiniz gibi BattlEye yuapıyormuş. Dosyalarını komple sildik. Birkaç gündür kullanıyor ve hiç mavi ekran hatası almadı.
BattlEye hatası olarak gözükse de "devamlı" ibaresi önemli. Ne kadar devamlı? Sadece BattlEye kullanan oyunlarda mı devamlı? Yoksa devamlı devamlı mı? Soru anlaşılmıştır umarım.
Dosyayı Conan exile oyununda buldum. Oyunu komple sildik hocam. Ondan sonra hiç hata almadık. Donanımdan olsa devam ederdi galiba ama çok şükür dediğiniz gibi BattlEye sorunmuş.
