Aykut551
27 Aralık 2023
  • Anakart: MSI MS-7817
  • İşlemci: i5 4590.
  • Ekran kartı: NVIDIA GT740 gk107.
  • İşletim sistemi: Windows 10 22h2.
Minidump.
Sistem temizliği yapıyordum bir anda mavi ekran verdi.
Fiziksel temizlik değil sistemsel temizlik. Geçen de daha boot etmeden mavi ekran verdi ve sınama modu açıldı.
Vanguard kaynaklı gibi bu hata. Bir de Windows'un güncel değil gibi: 10.0.19041.1
Kod:
IRQL_NOT_LESS_OR_EQUAL (a)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high.  This is usually
caused by drivers using improper addresses.
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: 0000000000000000, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, bitfield :
    bit 0 : value 0 = read operation, 1 = write operation
    bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
Arg4: fffff80747a37cf1, address which referenced memory
Debugging Details:
*** WARNING: Unable to verify timestamp for vgk.sys
KEY_VALUES_STRING: 1
    Key  : Analysis.CPU.mSec
    Value: 1202
    Key  : Analysis.Elapsed.mSec
    Value: 9131
    Key  : Analysis.IO.Other.Mb
    Value: 3
    Key  : Analysis.IO.Read.Mb
    Value: 0
    Key  : Analysis.IO.Write.Mb
    Value: 18
    Key  : Analysis.Init.CPU.mSec
    Value: 389
    Value: 11639
    Value: 82
    Value: 0xa
    Value: 0xa
    Key  : Failure.Bucket
    Value: AV_vgk!unknown_function
    Key  : Failure.Hash
    Value: {56c5cf79-d160-8711-720f-03c630d4c72b}
    Key  : WER.OS.Branch
    Value: vb_release
    Key  : WER.OS.Version
    Value: 10.0.19041.1
BUGCHECK_CODE:  a
BUGCHECK_P1: 0
BUGCHECK_P2: 2
BUGCHECK_P3: 0
BUGCHECK_P4: fffff80747a37cf1
FILE_IN_CAB:  051124-30406-01.dmp
READ_ADDRESS: fffff807484fb390: Unable to get MiVisibleState
Unable to get NonPagedPoolStart
Unable to get NonPagedPoolEnd
Unable to get PagedPoolStart
Unable to get PagedPoolEnd
unable to get nt!MmSpecialPagesInUse
 0000000000000000
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  System
TRAP_FRAME:  ffff8b0fe6fe8450 -- (.trap 0xffff8b0fe6fe8450)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=fffff80b64f260a0 rbx=0000000000000000 rcx=0000000000000000
rdx=0000000000000000 rsi=0000000000000000 rdi=0000000000000000
rip=fffff80747a37cf1 rsp=ffff8b0fe6fe85e0 rbp=ffff8b0fe6fe8671
 r8=0000000000000000  r9=0000000000000000 r10=0000000000000000
r11=fffff780000003b0 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0         nv up ei pl zr na po nc
nt!KeWaitForSingleObject+0x1e1:
fffff807`47a37cf1 483901          cmp     qword ptr [rcx],rax ds:00000000`00000000=????????????????
Resetting default scope
STACK_TEXT:
ffff8b0f`e6fe8308 fffff807`47c12269     : 00000000`0000000a 00000000`00000000 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
ffff8b0f`e6fe8310 fffff807`47c0dc34     : 00000000`00000001 00000000`00000170 ffff8b0f`e6fe88d0 00000000`00000000 : nt!KiBugCheckDispatch+0x69
ffff8b0f`e6fe8450 fffff807`47a37cf1     : 130737fa`f2960e3c ffff8b0f`e6fe88d8 00000000`00000180 00000000`00000100 : nt!KiPageFault+0x474
ffff8b0f`e6fe85e0 fffff807`47aefa3a     : fffff80b`64f26098 00000000`00000022 fffff80b`64f25b00 00000001`40315800 : nt!KeWaitForSingleObject+0x1e1
ffff8b0f`e6fe86d0 fffff807`47aed1cc     : ffffbd07`71af5690 ffff8b0f`e6fe89e0 00000000`00000000 ffff8b0f`00000000 : nt!ExpAcquireFastMutexContended+0x7a
ffff8b0f`e6fe8710 fffff80b`65114456     : ffffbd07`69eba850 00000000`00000001 e66f720b`fee888e7 ffff8b0f`e6fe8a80 : nt!KeAcquireGuardedMutex+0x6c
ffff8b0f`e6fe8740 ffffbd07`69eba850     : 00000000`00000001 e66f720b`fee888e7 ffff8b0f`e6fe8a80 fffff80b`64f19220 : vgk+0x274456
ffff8b0f`e6fe8748 00000000`00000001     : e66f720b`fee888e7 ffff8b0f`e6fe8a80 fffff80b`64f19220 ffffffff`ffffffff : 0xffffbd07`69eba850
ffff8b0f`e6fe8750 e66f720b`fee888e7     : ffff8b0f`e6fe8a80 fffff80b`64f19220 ffffffff`ffffffff ffffffff`ffffffff : 0x1
ffff8b0f`e6fe8758 ffff8b0f`e6fe8a80     : fffff80b`64f19220 ffffffff`ffffffff ffffffff`ffffffff fe8ff757`4ffb7bed : 0xe66f720b`fee888e7
ffff8b0f`e6fe8760 fffff80b`64f19220     : ffffffff`ffffffff ffffffff`ffffffff fe8ff757`4ffb7bed 00000000`c0000022 : 0xffff8b0f`e6fe8a80
ffff8b0f`e6fe8768 ffffffff`ffffffff     : ffffffff`ffffffff fe8ff757`4ffb7bed 00000000`c0000022 00000000`00000001 : vgk+0x79220
ffff8b0f`e6fe8770 ffffffff`ffffffff     : fe8ff757`4ffb7bed 00000000`c0000022 00000000`00000001 fffff80a`24ea0000 : 0xffffffff`ffffffff
ffff8b0f`e6fe8778 fe8ff757`4ffb7bed     : 00000000`c0000022 00000000`00000001 fffff80a`24ea0000 fffff80a`24ea0000 : 0xffffffff`ffffffff
ffff8b0f`e6fe8780 00000000`c0000022     : 00000000`00000001 fffff80a`24ea0000 fffff80a`24ea0000 00000000`00000008 : 0xfe8ff757`4ffb7bed
ffff8b0f`e6fe8788 00000000`00000001     : fffff80a`24ea0000 fffff80a`24ea0000 00000000`00000008 48bc31b6`37f9fb7f : 0xc0000022
ffff8b0f`e6fe8790 fffff80a`24ea0000     : fffff80a`24ea0000 00000000`00000008 48bc31b6`37f9fb7f 4cffb801`a0ed1eb3 : 0x1
ffff8b0f`e6fe8798 fffff80a`24ea0000     : 00000000`00000008 48bc31b6`37f9fb7f 4cffb801`a0ed1eb3 effaf44a`24e45e8f : 0xfffff80a`24ea0000
ffff8b0f`e6fe87a0 00000000`00000008     : 48bc31b6`37f9fb7f 4cffb801`a0ed1eb3 effaf44a`24e45e8f ffff8b0f`e6fe89a0 : 0xfffff80a`24ea0000
ffff8b0f`e6fe87a8 48bc31b6`37f9fb7f     : 4cffb801`a0ed1eb3 effaf44a`24e45e8f ffff8b0f`e6fe89a0 00000000`00000000 : 0x8
ffff8b0f`e6fe87b0 4cffb801`a0ed1eb3     : effaf44a`24e45e8f ffff8b0f`e6fe89a0 00000000`00000000 fffff80b`64f25ba8 : 0x48bc31b6`37f9fb7f
ffff8b0f`e6fe87b8 effaf44a`24e45e8f     : ffff8b0f`e6fe89a0 00000000`00000000 fffff80b`64f25ba8 00000000`00000000 : 0x4cffb801`a0ed1eb3
ffff8b0f`e6fe87c0 ffff8b0f`e6fe89a0     : 00000000`00000000 fffff80b`64f25ba8 00000000`00000000 f73d197f`a886b11b : 0xeffaf44a`24e45e8f
ffff8b0f`e6fe87c8 00000000`00000000     : fffff80b`64f25ba8 00000000`00000000 f73d197f`a886b11b 00000000`00000000 : 0xffff8b0f`e6fe89a0
SYMBOL_NAME:  vgk+274456
MODULE_NAME: vgk
IMAGE_NAME:  vgk.sys
STACK_COMMAND:  .cxr; .ecxr ; kb
BUCKET_ID_FUNC_OFFSET:  274456
FAILURE_BUCKET_ID:  AV_vgk!unknown_function
OS_VERSION:  10.0.19041.1
BUILDLAB_STR:  vb_release
OSPLATFORM_TYPE:  x64
OSNAME:  Windows 10
FAILURE_ID_HASH:  {56c5cf79-d160-8711-720f-03c630d4c72b}
Followup:     MachineOwner
    PnpActivityId      : {00000000-0000-0000-0000-000000000000}
    PnpActivityTime    : 133599057832008521
    PnpEventInformation: 3
    PnpEventInProgress : 0
    PnpProblemCode     : 24
    PnpVetoType        : 0
    DeviceId           : SWD\MMDEVAPI\{0.0.0.00000000}.{59cf594d-cb9d-41c2-8da2-86602ab1d454}
    VetoString         :
start             end                 module name
ffffbad8`c2a00000 ffffbad8`c2ccd000   win32kbase   (deferred)
ffffbad8`c2cd0000 ffffbad8`c3080000   win32kfull   (deferred)
ffffbad8`c31d0000 ffffbad8`c3219000   cdd        (deferred)
ffffbad8`c3540000 ffffbad8`c35db000   win32k     (deferred)
fffff807`467e0000 fffff807`46a6f000   mcupdate_GenuineIntel   (deferred)
fffff807`46a70000 fffff807`46a76000   hal        (deferred)
fffff807`46a80000 fffff807`46a8b000   kd         (deferred)
fffff807`46a90000 fffff807`46ab8000   tm         (deferred)
fffff807`46ac0000 fffff807`46b2e000   CLFS       (deferred)
fffff807`46b30000 fffff807`46b4a000   PSHED      (deferred)
fffff807`46b50000 fffff807`46b5b000   BOOTVID    (deferred)
fffff807`46b60000 fffff807`46bcd000   FLTMGR     (deferred)
fffff807`46bd0000 fffff807`46bde000   cmimcext   (deferred)
fffff807`47800000 fffff807`48846000   nt         (pdb symbols)          C:\ProgramData\Dbg\sym\ntkrnlmp.pdb\F6650B47E7E9D54F1FD4BC090DDACDD21\ntkrnlmp.pdb
fffff807`4c000000 fffff807`4c116000   clipsp     (deferred)
fffff807`4c120000 fffff807`4c149000   ksecdd     (deferred)
fffff807`4c150000 fffff807`4c1b3000   msrpc      (deferred)
fffff807`4c1c0000 fffff807`4c1d4000   werkernel   (deferred)
fffff807`4c1e0000 fffff807`4c1ec000   ntosext    (deferred)
fffff807`4c1f0000 fffff807`4c2dc000   CI         (deferred)
fffff807`4c2e0000 fffff807`4c39b000   cng        (deferred)
fffff807`4c3a0000 fffff807`4c471000   Wdf01000   (deferred)
fffff807`4c480000 fffff807`4c493000   WDFLDR     (deferred)
fffff807`4c4a0000 fffff807`4c4af000   SleepStudyHelper   (deferred)
fffff807`4c4b0000 fffff807`4c4c1000   WppRecorder   (deferred)
fffff807`4c4d0000 fffff807`4c4f6000   acpiex     (deferred)
fffff807`4c500000 fffff807`4c50d000   msseccore   (deferred)
fffff807`4c510000 fffff807`4c52a000   SgrmAgent   (deferred)
fffff807`4c530000 fffff807`4c5fc000   ACPI       (deferred)
fffff807`4c600000 fffff807`4c60c000   WMILIB     (deferred)
fffff807`4c610000 fffff807`4c61a000   WdBoot     (deferred)
fffff807`4c620000 fffff807`4c68b000   intelpep   (deferred)
fffff807`4c690000 fffff807`4c6a7000   WindowsTrustedRT   (deferred)
fffff807`4c6b0000 fffff807`4c6bb000   IntelTA    (deferred)
fffff807`4c6c0000 fffff807`4c6cb000   WindowsTrustedRTProxy   (deferred)
fffff807`4c6d0000 fffff807`4c6e4000   pcw        (deferred)
fffff807`4c6f0000 fffff807`4c6fb000   msisadrv   (deferred)
fffff807`4c700000 fffff807`4c778000   pci        (deferred)
fffff807`4c780000 fffff807`4c795000   vdrvroot   (deferred)
fffff807`4c7a0000 fffff807`4c7cf000   pdc        (deferred)
fffff807`4c7d0000 fffff807`4c7e9000   CEA        (deferred)
fffff807`4c7f0000 fffff807`4c7fd000   Fs_Rec     (deferred)
fffff807`4c800000 fffff807`4c831000   partmgr    (deferred)
fffff807`4c840000 fffff807`4c8eb000   spaceport   (deferred)
fffff807`4c8f0000 fffff807`4c909000   volmgr     (deferred)
fffff807`4c910000 fffff807`4c973000   volmgrx    (deferred)
fffff807`4c980000 fffff807`4c99e000   mountmgr   (deferred)
fffff807`4c9a0000 fffff807`4c9d2000   storahci   (deferred)
fffff807`4c9e0000 fffff807`4ca95000   storport   (deferred)
fffff807`4cac0000 fffff807`4cada000   fileinfo   (deferred)
fffff807`4cae0000 fffff807`4cb20000   Wof        (deferred)
fffff807`4cb30000 fffff807`4cbc6000   WdFilter   (deferred)
fffff807`4cbd0000 fffff807`4cea7000   Ntfs       (deferred)
fffff807`4ceb0000 fffff807`4d01f000   ndis       (deferred)
fffff807`4d020000 fffff807`4d0bc000   NETIO      (deferred)
fffff807`4d0c0000 fffff807`4d0f2000   ksecpkg    (deferred)
fffff807`4d100000 fffff807`4d3ed000   tcpip      (deferred)
fffff807`4d3f0000 fffff807`4d46f000   fwpkclnt   (deferred)
fffff807`4d470000 fffff807`4d4a0000   wfplwfs    (deferred)
fffff807`4d4b0000 fffff807`4d579000   fvevol     (deferred)
fffff807`4d580000 fffff807`4d58b000   volume     (deferred)
fffff807`4d590000 fffff807`4d5fd000   volsnap    (deferred)
fffff807`4d600000 fffff807`4d650000   rdyboost   (deferred)
fffff807`4d660000 fffff807`4d686000   mup        (deferred)
fffff807`4d690000 fffff807`4d6a2000   iorate     (deferred)
fffff807`4d6d0000 fffff807`4d6ef000   disk       (deferred)
fffff807`4d6f0000 fffff807`4d763000   CLASSPNP   (deferred)
fffff807`54400000 fffff807`54430000   cdrom      (deferred)
fffff807`54440000 fffff807`54455000   filecrypt   (deferred)
fffff807`54460000 fffff807`5446e000   tbs        (deferred)
fffff807`54470000 fffff807`54480000   UCPD       (deferred)
fffff807`54490000 fffff807`5449a000   Null       (deferred)
fffff807`544a0000 fffff807`544aa000   Beep       (deferred)
fffff807`544b0000 fffff807`54859000   dxgkrnl    (deferred)
fffff807`54860000 fffff807`54878000   watchdog   (deferred)
fffff807`54880000 fffff807`54896000   BasicDisplay   (deferred)
fffff807`548a0000 fffff807`548b1000   BasicRender   (deferred)
fffff807`548e0000 fffff807`548fe000   crashdmp   (deferred)
fffff807`549e0000 fffff807`549fc000   Npfs       (deferred)
fffff807`5d200000 fffff807`5d222000   tdx        (deferred)
fffff807`5d230000 fffff807`5d240000   TDI        (deferred)
fffff807`5d250000 fffff807`5d2ac000   netbt      (deferred)
fffff807`5d2b0000 fffff807`5d2c4000   afunix     (deferred)
fffff807`5d2d0000 fffff807`5d375000   afd        (deferred)
fffff807`5d380000 fffff807`5d39a000   vwififlt   (deferred)
fffff807`5d3a0000 fffff807`5d3cb000   pacer      (deferred)
fffff807`5d3d0000 fffff807`5d3e4000   ndiscap    (deferred)
fffff807`5d3f0000 fffff807`5d404000   netbios    (deferred)
fffff807`5d410000 fffff807`5d4b2000   Vid        (deferred)
fffff807`5d4c0000 fffff807`5d4e1000   winhvr     (deferred)
fffff807`5d4f0000 fffff807`5d56b000   rdbss      (deferred)
fffff807`5d570000 fffff807`5d607000   csc        (deferred)
fffff807`5d610000 fffff807`5d622000   nsiproxy   (deferred)
fffff807`5d630000 fffff807`5d63e000   npsvctrig   (deferred)
fffff807`5d640000 fffff807`5d650000   mssmbios   (deferred)
fffff807`5d660000 fffff807`5d66a000   gpuenergydrv   (deferred)
fffff807`5d670000 fffff807`5d69c000   dfsc       (deferred)
fffff807`5d6a0000 fffff807`5d6b2000   CompositeBus   (deferred)
fffff807`5d6c0000 fffff807`5d72d000   fastfat    (deferred)
fffff807`5d730000 fffff807`5d747000   bam        (deferred)
fffff807`5d750000 fffff807`5d79e000   ahcache    (deferred)
fffff807`5d7a0000 fffff807`5d7ad000   kdnic      (deferred)
fffff807`5d7b0000 fffff807`5d7c1000   Msfs       (deferred)
fffff807`5d7d0000 fffff807`5d7ee000   CimFS      (deferred)
fffff807`5d800000 fffff807`5d887000   usbhub     (deferred)
fffff807`5d890000 fffff807`5d8b3000   nvhda64v   (deferred)
fffff807`5d8c0000 fffff807`5d963000   UsbHub3    (deferred)
fffff807`5d970000 fffff807`5d98d000   NDProxy    (deferred)
fffff807`5d990000 fffff807`5d9b8000   AgileVpn   (deferred)
fffff807`5d9c0000 fffff807`5d9e1000   rasl2tp    (deferred)
fffff807`5d9f0000 fffff807`5da11000   raspptp    (deferred)
fffff807`5da20000 fffff807`5da3c000   raspppoe   (deferred)
fffff807`5da40000 fffff807`5da7a000   ndiswan    (deferred)
fffff807`5da80000 fffff807`5da92000   condrv     (deferred)
fffff807`5daa0000 fffff807`5dabd000   WdNisDrv   (deferred)
fffff807`5dac0000 fffff807`5dbaa000   xvdd       (deferred)
fffff807`5dbb0000 fffff807`5dbd4000   gameflt    (deferred)
fffff807`5dbe0000 fffff807`5dc18000   usbaudio   (deferred)
fffff807`5dc80000 fffff807`5dcec000   exfat      (deferred)
fffff807`5de00000 fffff807`5de0e000   asyncmac   (deferred)
fffff807`5de70000 fffff807`5de7d000   rdpvideominiport   (deferred)
fffff807`5dea0000 fffff807`5deb4000   qwavedrv   (deferred)
fffff807`5df80000 fffff807`5df95000   umbus      (deferred)
fffff807`65200000 fffff807`6529d000   USBXHCI    (deferred)
fffff807`652a0000 fffff807`652e4000   ucx01000   (deferred)
fffff807`652f0000 fffff807`65324000   TeeDriverW8x64   (deferred)
fffff807`65330000 fffff807`6534a000   usbehci    (deferred)
fffff807`65350000 fffff807`653c9000   USBPORT    (deferred)
fffff807`653d0000 fffff807`6550c000   rt640x64   (deferred)
fffff807`65510000 fffff807`6551c000   wmiacpi    (deferred)
fffff807`65520000 fffff807`65561000   intelppm   (deferred)
fffff807`65570000 fffff807`65580000   ISCTD      (deferred)
fffff807`65590000 fffff807`6559e000   UEFI       (deferred)
fffff807`655a0000 fffff807`655ad000   NdisVirtualBus   (deferred)
fffff807`655b0000 fffff807`655bc000   swenum     (deferred)
fffff807`655c0000 fffff807`655ce000   rdpbus     (deferred)
fffff807`655d0000 fffff807`67a78000   nvlddmkm   (deferred)
fffff807`67a80000 fffff807`67aa5000   HDAudBus   (deferred)
fffff807`67ab0000 fffff807`67b16000   portcls    (deferred)
fffff807`67b20000 fffff807`67b41000   drmk       (deferred)
fffff807`67b50000 fffff807`67bc6000   ks         (deferred)
fffff807`67bd0000 fffff807`67bde000   USBD       (deferred)
fffff807`67be0000 fffff807`67bef000   ksthunk    (deferred)
fffff807`67bf0000 fffff807`67bfa000   INETMON    (deferred)
fffff807`70e00000 fffff807`70e13000   mouclass   (deferred)
fffff807`70e30000 fffff807`70e3f000   dump_diskdump   (deferred)
fffff807`70e80000 fffff807`70eb2000   dump_storahci   (deferred)
fffff807`70ee0000 fffff807`70efd000   dump_dumpfve   (deferred)
fffff807`70f00000 fffff807`70fe1000   dxgmms2    (deferred)
fffff807`70ff0000 fffff807`7100b000   monitor    (deferred)
fffff807`71010000 fffff807`7103b000   luafv      (deferred)
fffff807`71040000 fffff807`71077000   wcifs      (deferred)
fffff807`71080000 fffff807`71103000   cldflt     (deferred)
fffff807`71110000 fffff807`7112a000   storqosflt   (deferred)
fffff807`71130000 fffff807`71157000   bindflt    (deferred)
fffff807`71160000 fffff807`71178000   mslldp     (deferred)
fffff807`71180000 fffff807`71198000   lltdio     (deferred)
fffff807`711a0000 fffff807`711bd000   wanarp     (deferred)
fffff807`711c0000 fffff807`711db000   rspndr     (deferred)
fffff807`711e0000 fffff807`71236000   msquic     (deferred)
fffff807`71240000 fffff807`713c8000   HTTP       (deferred)
fffff807`713d0000 fffff807`713f5000   bowser     (deferred)
fffff807`71400000 fffff807`7141a000   mpsdrv     (deferred)
fffff807`71420000 fffff807`714b4000   mrxsmb     (deferred)
fffff807`714c0000 fffff807`71505000   mrxsmb20   (deferred)
fffff807`71510000 fffff807`7153c000   idmwfp     (deferred)
fffff807`71540000 fffff807`71596000   srvnet     (deferred)
fffff807`715a0000 fffff807`715b4000   mmcss      (deferred)
fffff807`715c0000 fffff807`715e7000   Ndu        (deferred)
fffff807`715f0000 fffff807`716c6000   peauth     (deferred)
fffff807`716d0000 fffff807`716e5000   tcpipreg   (deferred)
fffff807`716f0000 fffff807`717b7000   srv2       (deferred)
fffff807`717c0000 fffff807`717dd000   rassstp    (deferred)
fffff807`717e0000 fffff807`71e9d000   RTKVHD64   (deferred)
fffff807`71ea0000 fffff807`71ed4000   usbccgp    (deferred)
fffff807`71ee0000 fffff807`71ef2000   hidusb     (deferred)
fffff807`71f00000 fffff807`71f41000   HIDCLASS   (deferred)
fffff807`71f50000 fffff807`71f63000   HIDPARSE   (deferred)
fffff807`71f70000 fffff807`71f81000   kbdhid     (deferred)
fffff807`71f90000 fffff807`71f99000   ikbevent   (deferred)
fffff807`71fa0000 fffff807`71fb4000   kbdclass   (deferred)
fffff807`71fc0000 fffff807`71fd0000   mouhid     (deferred)
fffff807`71fe0000 fffff807`71fe9000   imsevent   (deferred)
fffff807`71ff0000 fffff807`71fff000   ndistapi   (deferred)
fffff80b`64ea0000 fffff80b`6755c000   vgk      T (no symbols)
Unloaded modules:
fffff807`5dd10000 fffff807`5dd20000   hiber_storpo
fffff807`5dd20000 fffff807`5dd53000   hiber_storah
fffff807`5dd60000 fffff807`5dd7e000   hiber_dumpfv
fffff807`5dc20000 fffff807`5dc30000   hiber_storpo
fffff807`5dc30000 fffff807`5dc63000   hiber_storah
fffff807`5dcf0000 fffff807`5dd0e000   hiber_dumpfv
fffff807`5dfa0000 fffff807`5dfd9000   usbaudio.sys
fffff807`5dbe0000 fffff807`5dc19000   usbaudio.sys
fffff807`5dee0000 fffff807`5def0000   hiber_storpo
fffff807`5def0000 fffff807`5df23000   hiber_storah
fffff807`5df30000 fffff807`5df4e000   hiber_dumpfv
fffff807`5dd80000 fffff807`5dda7000   ssudbus2.sys
fffff807`5ddb0000 fffff807`5ddd1000   WinUSB.SYS
fffff807`5dec0000 fffff807`5dedd000   usbser.sys
fffff807`5de80000 fffff807`5de8f000   WpdUpFltr.sy
fffff807`5de10000 fffff807`5de65000   WUDFRd.sys
fffff807`5dd20000 fffff807`5dd47000   ssudbus2.sys
fffff807`5dd50000 fffff807`5dd71000   WinUSB.SYS
fffff807`5df50000 fffff807`5df77000   ssudbus2.sys
fffff807`5dfa0000 fffff807`5dfc1000   WinUSB.SYS
fffff807`5dd00000 fffff807`5dd1d000   usbser.sys
fffff807`5dcf0000 fffff807`5dcff000   WpdUpFltr.sy
fffff807`5dc20000 fffff807`5dc75000   WUDFRd.sys
fffff807`5def0000 fffff807`5df17000   ssudbus2.sys
fffff807`5df20000 fffff807`5df41000   WinUSB.SYS
fffff807`5de30000 fffff807`5de57000   ssudbus2.sys
fffff807`5dec0000 fffff807`5dee1000   WinUSB.SYS
fffff807`5de10000 fffff807`5de2d000   usbser.sys
fffff807`5dde0000 fffff807`5ddef000   WpdUpFltr.sy
fffff807`5dd80000 fffff807`5ddd5000   WUDFRd.sys
fffff807`5dc50000 fffff807`5dc77000   ssudbus2.sys
fffff807`5dcf0000 fffff807`5dd11000   WinUSB.SYS
fffff807`5dc30000 fffff807`5dc4d000   usbser.sys
fffff807`5dc20000 fffff807`5dc2f000   WpdUpFltr.sy
fffff807`5dfa0000 fffff807`5dff5000   WUDFRd.sys
fffff807`5de40000 fffff807`5de67000   ssudbus2.sys
fffff807`5ddc0000 fffff807`5dde7000   ssudbus2.sys
fffff807`5de10000 fffff807`5de31000   WinUSB.SYS
fffff807`5dd20000 fffff807`5dd41000   WinUSB.SYS
fffff807`5ddb0000 fffff807`5ddbf000   WpdUpFltr.sy
fffff807`5dd50000 fffff807`5dda5000   WUDFRd.sys
fffff807`5dc20000 fffff807`5dc47000   ssudbus2.sys
fffff807`5dc50000 fffff807`5dc71000   WinUSB.SYS
fffff807`5dc40000 fffff807`5dc79000   usbaudio.sys
 # Child-SP          RetAddr               : Args to Child                                                           : Call Site
00 ffff8b0f`e6fe8308 fffff807`47c12269     : 00000000`0000000a 00000000`00000000 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
01 ffff8b0f`e6fe8310 fffff807`47c0dc34     : 00000000`00000001 00000000`00000170 ffff8b0f`e6fe88d0 00000000`00000000 : nt!KiBugCheckDispatch+0x69
02 ffff8b0f`e6fe8450 fffff807`47a37cf1     : 130737fa`f2960e3c ffff8b0f`e6fe88d8 00000000`00000180 00000000`00000100 : nt!KiPageFault+0x474 (TrapFrame @ ffff8b0f`e6fe8450)
03 ffff8b0f`e6fe85e0 fffff807`47aefa3a     : fffff80b`64f26098 00000000`00000022 fffff80b`64f25b00 00000001`40315800 : nt!KeWaitForSingleObject+0x1e1
04 ffff8b0f`e6fe86d0 fffff807`47aed1cc     : ffffbd07`71af5690 ffff8b0f`e6fe89e0 00000000`00000000 ffff8b0f`00000000 : nt!ExpAcquireFastMutexContended+0x7a
05 ffff8b0f`e6fe8710 fffff80b`65114456     : ffffbd07`69eba850 00000000`00000001 e66f720b`fee888e7 ffff8b0f`e6fe8a80 : nt!KeAcquireGuardedMutex+0x6c
06 ffff8b0f`e6fe8740 ffffbd07`69eba850     : 00000000`00000001 e66f720b`fee888e7 ffff8b0f`e6fe8a80 fffff80b`64f19220 : vgk+0x274456
07 ffff8b0f`e6fe8748 00000000`00000001     : e66f720b`fee888e7 ffff8b0f`e6fe8a80 fffff80b`64f19220 ffffffff`ffffffff : 0xffffbd07`69eba850
08 ffff8b0f`e6fe8750 e66f720b`fee888e7     : ffff8b0f`e6fe8a80 fffff80b`64f19220 ffffffff`ffffffff ffffffff`ffffffff : 0x1
09 ffff8b0f`e6fe8758 ffff8b0f`e6fe8a80     : fffff80b`64f19220 ffffffff`ffffffff ffffffff`ffffffff fe8ff757`4ffb7bed : 0xe66f720b`fee888e7
0a ffff8b0f`e6fe8760 fffff80b`64f19220     : ffffffff`ffffffff ffffffff`ffffffff fe8ff757`4ffb7bed 00000000`c0000022 : 0xffff8b0f`e6fe8a80
0b ffff8b0f`e6fe8768 ffffffff`ffffffff     : ffffffff`ffffffff fe8ff757`4ffb7bed 00000000`c0000022 00000000`00000001 : vgk+0x79220
0c ffff8b0f`e6fe8770 ffffffff`ffffffff     : fe8ff757`4ffb7bed 00000000`c0000022 00000000`00000001 fffff80a`24ea0000 : 0xffffffff`ffffffff
0d ffff8b0f`e6fe8778 fe8ff757`4ffb7bed     : 00000000`c0000022 00000000`00000001 fffff80a`24ea0000 fffff80a`24ea0000 : 0xffffffff`ffffffff
0e ffff8b0f`e6fe8780 00000000`c0000022     : 00000000`00000001 fffff80a`24ea0000 fffff80a`24ea0000 00000000`00000008 : 0xfe8ff757`4ffb7bed
0f ffff8b0f`e6fe8788 00000000`00000001     : fffff80a`24ea0000 fffff80a`24ea0000 00000000`00000008 48bc31b6`37f9fb7f : 0xc0000022
10 ffff8b0f`e6fe8790 fffff80a`24ea0000     : fffff80a`24ea0000 00000000`00000008 48bc31b6`37f9fb7f 4cffb801`a0ed1eb3 : 0x1
11 ffff8b0f`e6fe8798 fffff80a`24ea0000     : 00000000`00000008 48bc31b6`37f9fb7f 4cffb801`a0ed1eb3 effaf44a`24e45e8f : 0xfffff80a`24ea0000
12 ffff8b0f`e6fe87a0 00000000`00000008     : 48bc31b6`37f9fb7f 4cffb801`a0ed1eb3 effaf44a`24e45e8f ffff8b0f`e6fe89a0 : 0xfffff80a`24ea0000
13 ffff8b0f`e6fe87a8 48bc31b6`37f9fb7f     : 4cffb801`a0ed1eb3 effaf44a`24e45e8f ffff8b0f`e6fe89a0 00000000`00000000 : 0x8
14 ffff8b0f`e6fe87b0 4cffb801`a0ed1eb3     : effaf44a`24e45e8f ffff8b0f`e6fe89a0 00000000`00000000 fffff80b`64f25ba8 : 0x48bc31b6`37f9fb7f
15 ffff8b0f`e6fe87b8 effaf44a`24e45e8f     : ffff8b0f`e6fe89a0 00000000`00000000 fffff80b`64f25ba8 00000000`00000000 : 0x4cffb801`a0ed1eb3
16 ffff8b0f`e6fe87c0 ffff8b0f`e6fe89a0     : 00000000`00000000 fffff80b`64f25ba8 00000000`00000000 f73d197f`a886b11b : 0xeffaf44a`24e45e8f
17 ffff8b0f`e6fe87c8 00000000`00000000     : fffff80b`64f25ba8 00000000`00000000 f73d197f`a886b11b 00000000`00000000 : 0xffff8b0f`e6fe89a0
Machine ID Information [From Smbios 2.8, DMIVersion 0, Size=2993]
BiosMajorRelease = 4
BiosMinorRelease = 6
BiosVendor = American Megatrends Inc.
BiosVersion = V1.10
BiosReleaseDate = 07/10/2018
SystemManufacturer = MSI
SystemProductName = MS-7817
SystemFamily = To be filled by O.E.M.
SystemVersion = 1.0
SystemSKU = To be filled by O.E.M.
BaseBoardManufacturer = MSI
BaseBoardProduct = H81M-P33 (MS-7817)
BaseBoardVersion = 1.0
[SMBIOS Data Tables v2.8]
[DMI Version - 0]
[2.0 Calling Convention - No]
[Table Size - 2993 bytes]
[BIOS Information (Type 0) - Length 24 - Handle 0000h]
  Vendor                        American Megatrends Inc.
  BIOS Version                  V1.10
  BIOS Release Date             07/10/2018
  BIOS ROM Size                 800000
  BIOS Characteristics
       07: - PCI Supported
       11: - Upgradeable FLASH BIOS
       15: - CD-Boot Supported
       17: - BIOS ROM Socketed
       19: - EDD Supported
       23: - 1.2MB Floppy Supported
       24: - 720KB Floppy Supported
       25: - 2.88MB Floppy Supported
       27: - Keyboard Services Supported
       32: - BIOS Vendor Reserved
       00: - ACPI Supported
       01: - USB Legacy Supported
  BIOS Major Revision           4
  BIOS Minor Revision           6
  EC Firmware Major Revision    255
  EC Firmware Minor Revision    255
  Manufacturer                  MSI
  Product Name                  MS-7817
  Version                       1.0
  Serial Number                 To be filled by O.E.M.
  SKUNumber                     To be filled by O.E.M.
  Family                        To be filled by O.E.M.
  Manufacturer                  MSI
  Product                       H81M-P33 (MS-7817)
  Version                       1.0
  Asset Tag
       00: - Motherboard
       03: - Replaceable
  Location                      To be filled by O.E.M.
[System Enclosure (Type 3) - Length 25 - Handle 0003h]
  Manufacturer                  MSI
  Chassis Type                  Desktop
  Version                       1.0
  Serial Number
  Asset Tag Number
  Number of Contained Elements  1
  Contained Element Size        3
  SKU Number                    [String Not Specified]
[OEM Strings (Type 11) - Length 5 - Handle 0021h]
  Number of Strings             1
   1                            To Be Filled By O.E.M.
[System Configuration Options (Type 12) - Length 5 - Handle 0022h]
[ (Type 256) - Length 11 - Handle 003ah]
[ (Type 256) - Length 11 - Handle 003bh]
[ (Type 256) - Length 11 - Handle 003ch]
[Processor Information (Type 4) - Length 42 - Handle 003dh]
  Socket Designation            SOCKET 0
  Processor Family              cdh - Intel Core 2 Solo processor
  Processor Manufacturer        Intel
  Processor ID                   c3060300fffbebbf
  Processor Version             Intel(R) Core(TM) i5-4590 CPU @ 3.30GHz
  Processor Voltage             8ch - 1.2V
  Max Speed                     3800MHz
  Current Speed                 3300MHz
  Processor Upgrade             Socket LGA1155
  L1 Cache Handle               003fh
  L2 Cache Handle               003eh
  L3 Cache Handle               0040h
  Serial Number                 [String Not Specified]
  Asset Tag Number
  Part Number                   Fill By OEM
  Core Count                    4
  Core Enabled                  4
  Thread Count                  4
  Processor Characteristics     4
  Enabled Characteristics:
       0x 2: 64-bit Capable
  Processor Family 2            00cdh - Intel Core 2 Solo processor
[Cache Information (Type 7) - Length 19 - Handle 003eh]
  Socket Designation            CPU Internal L2
  Maximum Cache Size            0400h - 1024K
  Installed Size                0400h - 1024K
  Supported SRAM Type           0002h - Unknown
  Current SRAM Type             0002h - Unknown
  Cache Speed                   0ns
  Error Correction Type         Multi-Bit ECC
  Maximum Cache Size 2          20555043 - 542462019l Kb
[Cache Information (Type 7) - Length 19 - Handle 003fh]
  Socket Designation            CPU Internal L1
  Maximum Cache Size            0100h - 256K
  Installed Size                0100h - 256K
  Cache Speed                   0ns
  System Cache Type             Other
[Cache Information (Type 7) - Length 19 - Handle 0040h]
  Socket Designation            CPU Internal L3
  Maximum Cache Size            1800h - 6144K
  Installed Size                1800h - 6144K
  Cache Speed                   0ns
  Associativity                 12-way Set-Associative
[Physical Memory Array (Type 16) - Length 23 - Handle 0041h]
  Maximum Capacity              33554432KB
  Memory Error Inf Handle       [Not Provided]
  Number of Memory Devices      4
[Memory Device (Type 17) - Length 40 - Handle 0042h]
  Memory Error Info Handle      [Not Provided]
  Size                          4096MB
  Form Factor                   09h - DIMM
  Device Locator                ChannelA-DIMM0
  Bank Locator                  BANK 0
  Memory Type                   18h - DDR3
  Type Detail                   0080h - Synchronous
  Speed                         1600MHz
  Manufacturer                  Hynix/Hyundai
  Serial Number
  Asset Tag Number
  Part Number                   HMT451U6BFR8A-PB
  Attributes                    1
  Configured Memory Speed       1600
  Minimum Voltage               1350
  Maximum Voltage               1500
  Configured Voltage            1500
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 0043h]
  Ending Address                003fffffh
  Memory Device Handle          0042h
  Mem Array Mapped Adr Handle   0048h
  Interleave Position           [Unknown]
  Interleave Data Depth         [Unknown]
[Memory Device (Type 17) - Length 40 - Handle 0044h]
  Total Width                   0 bits
  Data Width                    0 bits
  Size                          [Not Populated]
  Device Locator                ChannelA-DIMM1
  Bank Locator                  BANK 1
  Memory Type                   02h - Unknown
  Type Detail                   0000h -
  Speed                         0MHz
  Manufacturer                  [Empty]
  Serial Number
  Asset Tag Number
  Part Number                   [Empty]
  Attributes                    0
  Configured Memory Speed       0
  Minimum Voltage               0
  Maximum Voltage               0
  Configured Voltage            0
[Memory Device (Type 17) - Length 40 - Handle 0045h]
  Size                          8192MB
  Device Locator                ChannelB-DIMM0
  Bank Locator                  BANK 2
  Speed                         1333MHz
  Manufacturer                  0000
  Serial Number
  Asset Tag Number
  Part Number
  Attributes                    2
  Minimum Voltage               1500
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 0046h]
  Starting Address              00400000h
  Ending Address                00bfffffh
  Memory Device Handle          0045h
[Memory Device (Type 17) - Length 40 - Handle 0047h]
  Total Width                   0 bits
  Data Width                    0 bits
  Device Locator                ChannelB-DIMM1
  Bank Locator                  BANK 3
  Type Detail                   0000h -
  Speed                         0MHz
  Serial Number
  Asset Tag Number
  Part Number                   [Empty]
  Attributes                    0
  Minimum Voltage               0
  Maximum Voltage               0
[Memory Array Mapped Address (Type 19) - Length 31 - Handle 0048h]
  Memory Array Handle           0041h
  Partition Width               04
[ (Type 256) - Length 6 - Handle 004ch]
[ (Type 256) - Length 64 - Handle 004dh]
[ (Type 256) - Length 16 - Handle 004eh]
[ (Type 256) - Length 4 - Handle 0051h]
THREAD ffffbd0771af5040  Cid 0004.04a8  Teb: 0000000000000000 Win32Thread: 0000000000000000 WAIT: (WrFastMutex) KernelMode Non-Alertable
    fffff80b64f26098  NotificationEvent
Not impersonating
GetUlongFromAddress: unable to read from fffff8074841159c
Owning Process            ffffbd07666af040       Image:         System
Attached Process          N/A            Image:         N/A
fffff78000000000: Unable to get shared data
Wait Start TickCount      21926335
Context Switch Count      67556          IdealProcessor: 0
ReadMemory error: Cannot get nt!KeMaximumIncrement value.
UserTime                  00:00:00.000
KernelTime                00:00:00.000
Win32 Start Address nt!ExpWorkerThread (0xfffff80747ac3da0)
Stack Init ffff8b0fe6fe9c90 Current ffff8b0fe6fe7520
Base ffff8b0fe6fea000 Limit ffff8b0fe6fe4000 Call 0000000000000000
Priority 13  BasePriority 12  IoPriority 2  PagePriority 5
ffff8b0f`e6fe7560 00000000`00000000     : 00000000`00010000 00000000`00000803 fffff807`70e31e6f ffffbd07`694e6018 : 0xa
Kod:
Arguments:
Debugging Details:
    Value: 1202
    Value: 9131
    Value: 3
    Value: 0
    Value: 18
    Value: 389
    Value: 11639
    Value: 82
    Value: 0xa
    Value: 0xa
    Key  : Failure.Hash
    Key  : WER.OS.Branch
    Value: vb_release
    Value: 10.0.19041.1
BUGCHECK_CODE:  a
BUGCHECK_P1: 0
BUGCHECK_P2: 2
BUGCHECK_P3: 0
 0000000000000000
BLACKBOXWINLOGON: 1
STACK_TEXT:
MODULE_NAME: vgk
IMAGE_NAME:  vgk.sys
OSNAME:  Windows 10
    PnpProblemCode     : 24
    PnpVetoType        : 0
    VetoString         :
Unloaded modules:
BiosVersion = V1.10
SystemVersion = 1.0
[DMI Version - 0]
  BIOS Version                  V1.10
       07: - PCI Supported
       19: - EDD Supported
  Manufacturer                  MSI
  Version                       1.0
  Manufacturer                  MSI
  Version                       1.0
  Asset Tag
       00: - Motherboard
       03: - Replaceable
  Manufacturer                  MSI
  Version                       1.0
  Serial Number
  Asset Tag Number
  Number of Strings             1
  Max Speed                     3800MHz
  Asset Tag Number
  Core Count                    4
  Core Enabled                  4
  Thread Count                  4
  Cache Speed                   0ns
  Cache Speed                   0ns
  Cache Speed                   0ns
  Size                          4096MB
  Bank Locator                  BANK 0
  Speed                         1600MHz
  Serial Number
  Asset Tag Number
  Attributes                    1
  Total Width                   0 bits
  Data Width                    0 bits
  Bank Locator                  BANK 1
  Type Detail                   0000h -
  Speed                         0MHz
  Serial Number
  Asset Tag Number
  Part Number                   [Empty]
  Attributes                    0
  Minimum Voltage               0
  Maximum Voltage               0
  Size                          8192MB
  Bank Locator                  BANK 2
  Speed                         1333MHz
  Manufacturer                  0000
  Serial Number
  Asset Tag Number
  Part Number
  Attributes                    2
  Total Width                   0 bits
  Data Width                    0 bits
  Bank Locator                  BANK 3
  Type Detail                   0000h -
  Speed                         0MHz
  Serial Number
  Asset Tag Number
  Part Number                   [Empty]
  Attributes                    0
  Minimum Voltage               0
  Maximum Voltage               0
  Partition Width               04
Not impersonating
Kod:
An attempt was made to access a pageable (or completely invalid) address at an.
interrupt request level (IRQL) that is too high. This is usually.
Arguments:
Arg1: 0000000000000000, memory referenced.
Arg2: 0000000000000002, IRQL.
 bit 0 : value 0 = read operation, 1 = write operation.
Arg4: fffff80747a37cf1, address which referenced memory.
Debugging Details:
 Value: 1202.
 Value: 9131.
 Value: 3
 Value: 0
 Value: 18.
 Value: 389.
 Value: 11639.
 Value: 82.
 Value: 0xa.
 Value: 0xa.
 Key : Failure.Hash
 Key : WER.OS.Branch
 Value: vb_release.
 Value: 10.0.19041.1
BUGCHECK_CODE: a
BUGCHECK_P1: 0
BUGCHECK_P2: 2
BUGCHECK_P3: 0
BUGCHECK_P4: fffff80747a37cf1.
READ_ADDRESS: fffff807484fb390: Unable to get MiVisibleState.
Unable to get NonPagedPoolStart.
Unable to get NonPagedPoolEnd.
Unable to get PagedPoolStart.
Unable to get PagedPoolEnd.
 0000000000000000.
BLACKBOXWINLOGON: 1
PROCESS_NAME: System.
iopl=0 nv up ei pl zr na po nc.
Resetting default scope.
STACK_TEXT:
ffff8b0f`e6fe8750 e66f720b`fee888e7 : ffff8b0f`e6fe8a80 fffff80b`64f19220 ffffffff`ffffffff ffffffff`ffffffff : 0x1.
ffff8b0f`e6fe8788 00000000`00000001 : fffff80a`24ea0000 fffff80a`24ea0000 00000000`00000008 48bc31b6`37f9fb7f : 0xc0000022.
ffff8b0f`e6fe8790 fffff80a`24ea0000 : fffff80a`24ea0000 00000000`00000008 48bc31b6`37f9fb7f 4cffb801`a0ed1eb3 : 0x1.
ffff8b0f`e6fe87a8 48bc31b6`37f9fb7f : 4cffb801`a0ed1eb3 effaf44a`24e45e8f ffff8b0f`e6fe89a0 00000000`00000000 : 0x8.
MODULE_NAME: vgk.
IMAGE_NAME: vgk.sys
STACK_COMMAND: .cxr; .ecxr ; kb.
BUCKET_ID_FUNC_OFFSET: 274456.
BUILDLAB_STR: vb_release.
OSPLATFORM_TYPE: x64.
OSNAME: Windows 10.
Followup: MachineOwner.
 PnpActivityTime : 133599057832008521.
 PnpProblemCode : 24.
 PnpVetoType : 0
 VetoString :
start end module name.
Unloaded modules:
fffff807`5dd10000 fffff807`5dd20000 hiber_storpo.
fffff807`5dd20000 fffff807`5dd53000 hiber_storah.
fffff807`5dd60000 fffff807`5dd7e000 hiber_dumpfv.
fffff807`5dc20000 fffff807`5dc30000 hiber_storpo.
fffff807`5dc30000 fffff807`5dc63000 hiber_storah.
fffff807`5dcf0000 fffff807`5dd0e000 hiber_dumpfv.
fffff807`5dee0000 fffff807`5def0000 hiber_storpo.
fffff807`5def0000 fffff807`5df23000 hiber_storah.
fffff807`5df30000 fffff807`5df4e000 hiber_dumpfv.
 # Child-SP RetAddr : Args to Child : Call Site.
08 ffff8b0f`e6fe8750 e66f720b`fee888e7 : ffff8b0f`e6fe8a80 fffff80b`64f19220 ffffffff`ffffffff ffffffff`ffffffff : 0x1.
0f ffff8b0f`e6fe8788 00000000`00000001 : fffff80a`24ea0000 fffff80a`24ea0000 00000000`00000008 48bc31b6`37f9fb7f : 0xc0000022.
10 ffff8b0f`e6fe8790 fffff80a`24ea0000 : fffff80a`24ea0000 00000000`00000008 48bc31b6`37f9fb7f 4cffb801`a0ed1eb3 : 0x1.
13 ffff8b0f`e6fe87a8 48bc31b6`37f9fb7f : 4cffb801`a0ed1eb3 effaf44a`24e45e8f ffff8b0f`e6fe89a0 00000000`00000000 : 0x8.
BiosVersion = V1.10
SystemManufacturer = MSI.
SystemVersion = 1.0
BaseBoardManufacturer = MSI.
[DMI Version - 0]
 BIOS Version V1.10
 BIOS Starting Address Segment f000.
 BIOS ROM Size 800000.
 BIOS Characteristics.
 07: - PCI Supported.
 11: - Upgradeable FLASH BIOS.
 12: - BIOS Shadowing Supported.
 15: - CD-Boot Supported.
 16: - Selectable Boot Supported.
 17: - BIOS ROM Socketed.
 19: - EDD Supported.
 23: - 1.2MB Floppy Supported.
 24: - 720KB Floppy Supported.
 25: - 2.88MB Floppy Supported.
 26: - Print Screen Device Supported.
 27: - Keyboard Services Supported.
 28: - Serial Services Supported.
 29: - Printer Services Supported.
 32: - BIOS Vendor Reserved.
 BIOS Characteristic Extensions.
 00: - ACPI Supported.
 01: - USB Legacy Supported.
 08: - BIOS Boot Specification Supported.
 10: - Enable Targeted Content Distribution.
 11: - UEFI Specification Supported.
 EC Firmware Major Revision 255.
 EC Firmware Minor Revision 255.
 Manufacturer MSI.
 Version 1.0
 Wakeup Type Power Switch.
 Manufacturer MSI.
 Version 1.0
 Asset Tag.
 Feature Flags 09h.
 00: - Motherboard.
 03: - Replaceable.
 Chassis Handle 0003h.
 Board Type 0ah - Processor/Memory Module.
 Manufacturer MSI.
 Chassis Type Desktop.
 Version 1.0
 Serial Number.
 Asset Tag Number.
 Bootup State Safe.
 Power Supply State Safe.
 Thermal State Safe.
 Security Status None.
 OEM Defined 0
 Height 0U.
 Number of Strings 1
 Processor Type Central Processor.
 Processor Family cdh - Intel Core 2 Solo processor.
 Processor Manufacturer Intel.
 Processor ID c3060300fffbebbf.
 External Clock 100MHz.
 Max Speed 3800MHz.
 Current Speed 3300MHz.
 Status Enabled Populated.
 Processor Upgrade Socket LGA1155.
 L1 Cache Handle 003fh.
 L2 Cache Handle 003eh.
 L3 Cache Handle 0040h.
 Asset Tag Number.
 Part Number Fill By OEM.
 Core Count 4
 Core Enabled 4
 Thread Count 4
 0x 2: 64-bit Capable.
 Processor Family 2 00cdh - Intel Core 2 Solo processor.
 Socket Designation CPU Internal L2.
 Cache Configuration 0181h - WBEnabled Int NonSocketed L2.
 Maximum Cache Size 0400h - 1024K.
 Installed Size 0400h - 1024K.
 Supported SRAM Type 0002h - Unknown.
 Current SRAM Type 0002h - Unknown.
 Cache Speed 0ns.
 Error Correction Type Multi-Bit ECC.
 System Cache Type Unified.
 Maximum Cache Size 2 20555043 - 542462019l Kb.
 Socket Designation CPU Internal L1.
 Cache Configuration 0180h - WBEnabled Int NonSocketed L1.
 Maximum Cache Size 0100h - 256K.
 Installed Size 0100h - 256K.
 Cache Speed 0ns.
 System Cache Type Other.
 Socket Designation CPU Internal L3.
 Cache Configuration 0182h - WBEnabled Int NonSocketed L3.
 Maximum Cache Size 1800h - 6144K.
 Installed Size 1800h - 6144K.
 Cache Speed 0ns.
 Use 03h - System Memory.
 Memory Error Correction 03h - None.
 Maximum Capacity 33554432KB.
 Total Width 64 bits.
 Data Width 64 bits.
 Size 4096MB.
 Form Factor 09h - DIMM.
 Device Set [None]
 Bank Locator BANK 0
 Memory Type 18h - DDR3.
 Type Detail 0080h - Synchronous.
 Speed 1600MHz.
 Serial Number.
 Asset Tag Number.
 Attributes 1
 Extended Size 0
 Configured Memory Speed 1600.
 Minimum Voltage 1350.
 Maximum Voltage 1500.
 Configured Voltage 1500.
 Starting Address 00000000h.
 Ending Address 003fffffh.
 Memory Device Handle 0042h.
 Mem Array Mapped Adr Handle 0048h.
 Extended Starting Address 0000000000000000h.
 Extended Ending Address 0000000000000000h.
 Total Width 0 bits.
 Data Width 0 bits.
 Device Set [None]
 Bank Locator BANK 1
 Memory Type 02h - Unknown.
 Type Detail 0000h -
 Speed 0MHz.
 Serial Number.
 Asset Tag Number.
 Part Number [Empty]
 Attributes 0
 Extended Size 0
 Minimum Voltage 0
 Maximum Voltage 0
 Data Width 64 bits.
 Size 8192MB.
 Device Set [None]
 Bank Locator BANK 2
 Speed 1333MHz.
 Manufacturer 0000.
 Serial Number.
 Asset Tag Number.
 Part Number.
 Attributes 2
 Extended Size 0
 Minimum Voltage 1500.
 Starting Address 00400000h.
 Ending Address 00bfffffh.
 Memory Device Handle 0045h.
 Total Width 0 bits.
 Data Width 0 bits.
 Device Set [None]
 Bank Locator BANK 3
 Type Detail 0000h -
 Speed 0MHz.
 Serial Number.
 Asset Tag Number.
 Part Number [Empty]
 Attributes 0
 Extended Size 0
 Minimum Voltage 0
 Maximum Voltage 0
 Memory Array Handle 0041h.
 Partition Width 04.
 fffff80b64f26098 NotificationEvent.
Not impersonating.
GetUlongFromAddress: unable to read from fffff8074841159c.
Owning Process ffffbd07666af040 Image: System.
fffff78000000000: Unable to get shared data.
Wait Start TickCount 21926335.
Stack Init ffff8b0fe6fe9c90 Current ffff8b0fe6fe7520.
Base ffff8b0fe6fea000 Limit ffff8b0fe6fe4000 Call 0000000000000000.
ffff8b0f`e6fe7560 00000000`00000000 : 00000000`00010000 00000000`00000803 fffff807`70e31e6f ffffbd07`694e6018 : 0xa.
Vanguard'ı zaten son olaylardan sonra silecektim vesile oldu. :D
Windows güncel değil konusunda emin değilim sistemi temizlemeden önce 3.5 GB yer kalmıştı🥶
Az önce Riot Client'i açtığımda aynısı oldu sonrun Riot Games(Tencent) kaynaklı güvenli mooda sileceğim.
Teşekkürler Recep bey saygılarımı sunarım.
Bir de sınama modunu nasıl kapatabilirim?
Eki Görüntüle 45408
5 yıl önceki release'yi kullanıyorsun nasıl güncel olsun :thumbsdown:
Testing modu nasıl actiniz bilmiyorum ama aradiginiz şey "test mode" ise asagidaki komut isinizi gorebilir:
Kod:
bcdedit.exe -set loadoptions ENABLE_INTEGRITY_CHECKS
bcdedit.exe -set TESTSIGNING OFF.
Kendiliğinden açıldı zaten artık kapatmaya ihtiyacım yok Valorant gibi bir porblemim olmadı iöin Windows 11'e geçiş yapacağım.
