Kim cevapladı?- Hata Kodu (BugCheck): 0x1e
- Exception Code: 0xC0000005 → Erişim ihlali (yani bir kod parçası, geçersiz bir belleğe erişmeye çalıştı)
- Faulting Address: nt!KiRspInIstStack+0x40 → bu, doğrudan Windows çekirdeğinde (ntkrnlmp.exe) oldu.
- Etkin İşlem (Process Name): System
- BIOS Sürümü: 2402 (ASUS PRIME H510M-E, 18 Aralık 2023)
- RAM: 2x8GB G.Skill DDR4-3200
Çözüm önerilerim:
- XMP aktifse kapatıp standart JEDEC hızında çalıştırmayı deneyin.
- Hem işlemci hem de RAM tarafında OC varsa kapatın.
Kod:
KMODE_EXCEPTION_NOT_HANDLED (1e)
This is a very common BugCheck. Usually the exception address pinpoints
the driver/function that caused the problem. Always note this address
as well as the link date of the driver/image that contains this address.
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff80455118a08, The address that the exception occurred at
Arg3: 0000000000000000, Parameter 0 of the exception
Arg4: ffffffffffffffff, Parameter 1 of the exception
Debugging Details:
KEY_VALUES_STRING: 1
Key : Analysis.CPU.mSec
Value: 1437
Key : Analysis.Elapsed.mSec
Value: 1491
Key : Analysis.IO.Other.Mb
Value: 1
Key : Analysis.IO.Read.Mb
Value: 1
Key : Analysis.IO.Write.Mb
Value: 18
Key : Analysis.Init.CPU.mSec
Value: 500
Value: 11450
Value: 76
Key : Analysis.Version.DbgEng
Value: 10.0.27829.1001
Key : Analysis.Version.Description
Value: 10.2503.24.01 amd64fre
Key : Analysis.Version.Ext
Value: 1.2503.24.1
Key : Bugcheck.Code.LegacyAPI
Value: 0x1e
Key : Bugcheck.Code.TargetModel
Value: 0x1e
Key : Dump.Attributes.AsUlong
Value: 0x8
Key : Dump.Attributes.KernelGeneratedTriageDump
Value: 1
Key : Failure.Bucket
Value: AV_R_nt!KiRspInIstStack
Key : Failure.Exception.IP.Address
Value: 0xfffff80455118a08
Key : Failure.Exception.IP.Module
Value: nt
Key : Failure.Exception.IP.Offset
Value: 0x518a08
Key : Failure.Hash
Value: {f72f361e-f56a-2d15-acda-72d84d638abb}
Key : Stack.Pointer
Value: PRCBException
BUGCHECK_CODE: 1e
BUGCHECK_P1: ffffffffc0000005
BUGCHECK_P2: fffff80455118a08
BUGCHECK_P3: 0
BUGCHECK_P4: ffffffffffffffff
FILE_IN_CAB: 071425-6171-01.dmp
DUMP_FILE_ATTRIBUTES: 0x8
Kernel Generated Triage Dump
FAULTING_THREAD: ffffdf808112b340
EXCEPTION_PARAMETER1: 0000000000000000
EXCEPTION_PARAMETER2: ffffffffffffffff
READ_ADDRESS: fffff804558fb390: Unable to get MiVisibleState
Unable to get NonPagedPoolStart
Unable to get NonPagedPoolEnd
Unable to get PagedPoolStart
Unable to get PagedPoolEnd
unable to get nt!MmSpecialPagesInUse
ffffffffffffffff
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: System
TRAP_FRAME: fffff780000003d8 -- (.trap 0xfffff780000003d8)
Unable to read trap frame at fffff780`000003d8
Resetting default scope
STACK_TEXT:
ffffdf80`8117e468 fffff804`550750f2 : 00000000`0000001e ffffffff`c0000005 fffff804`55118a08 00000000`00000000 : nt!KeBugCheckEx
ffffdf80`8117e470 fffff804`55007eff : fffff804`54f1d59c 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiExceptionStackSwitchHandler+0x157b56
ffffdf80`8117e4b0 fffff804`54f3e857 : ffffdf80`8117ea20 00000000`00000000 ffffdf80`8117ffb0 fffff804`54ffe522 : nt!RtlpExecuteHandlerForException+0xf
ffffdf80`8117e4e0 fffff804`54f3c4f6 : ffffdf80`8117f3f8 ffffdf80`8117f130 ffffdf80`8117f3f8 00000000`00000000 : nt!RtlDispatchException+0x297
ffffdf80`8117ec00 fffff804`55011cec : ffffb47f`ffffffff 00000000`00000001 fffff780`000003d8 ffffdf80`8117ea60 : nt!KiDispatchException+0x186
ffffdf80`8117f2c0 fffff804`5500d0ef : 00000000`00000000 00000000`00000000 00040000`0026133c 01dbdfb7`c7d279d5 : nt!KiExceptionDispatch+0x12c
ffffdf80`8117f4a0 fffff804`55118a08 : fffff804`5505a4ff 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiGeneralProtectionFault+0x32f
ffffdf80`8117f638 fffff804`5505a4ff : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiRspInIstStack+0x40
ffffdf80`8117f640 fffff804`54f402e4 : ffffdf80`8117f920 ffffdf80`8112f708 ffffdf80`8117f710 ffffdf80`8117f870 : nt!KeQueryCurrentStackInformationEx+0x18988f
ffffdf80`8117f6a0 fffff804`54f3e6a1 : ffffdf80`8117f920 00000000`00000000 000004e8`fffffb30 000004d0`fffffb30 : nt!RtlpGetStackLimitsEx+0x14
ffffdf80`8117f6d0 fffff804`54f3c4f6 : ffffdf80`8112f708 ffffdf80`8117fe20 ffffdf80`8112f708 ffffcf03`71d1c000 : nt!RtlDispatchException+0xe1
ffffdf80`8117f8f0 fffff804`54ffe522 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiDispatchException+0x186
ffffdf80`8117ffb0 fffff804`54ffe4f0 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxExceptionDispatchOnExceptionStack+0x12
ffffdf80`8112f5c8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiExceptionDispatchOnExceptionStackContinue
SYMBOL_NAME: nt!KiRspInIstStack+40
MODULE_NAME: nt
IMAGE_NAME: ntkrnlmp.exe
IMAGE_VERSION: 10.0.19041.6093
STACK_COMMAND: .process /r /p 0xfffff80455924a00; .thread 0xffffdf808112b340 ; kb
BUCKET_ID_FUNC_OFFSET: 40
FAILURE_BUCKET_ID: AV_R_nt!KiRspInIstStack
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {f72f361e-f56a-2d15-acda-72d84d638abb}
Followup: MachineOwner
[SMBIOS Data Tables v3.3]
[DMI Version - 0]
[2.0 Calling Convention - No]
[Table Size - 4919 bytes]
Vendor American Megatrends Inc.
BIOS Version 2402
BIOS Release Date 12/18/2023
BIOS ROM Size 1000000
BIOS Characteristics
07: - PCI Supported
11: - Upgradeable FLASH BIOS
15: - CD-Boot Supported
17: - BIOS ROM Socketed
19: - EDD Supported
22: - 360KB Floppy Supported
23: - 1.2MB Floppy Supported
24: - 720KB Floppy Supported
25: - 2.88MB Floppy Supported
32: - BIOS Vendor Reserved
01: - USB Legacy Supported
BIOS Major Revision 24
BIOS Minor Revision 2
EC Firmware Major Revision 255
EC Firmware Minor Revision 255
Extended BIOS ROM Size 16 MB
Manufacturer ASUS
Product Name System Product Name
Version System Version
Serial Number System Serial Number
UUID 00000000-0000-0000-0000-000000000000
Wakeup Type Power Switch
SKUNumber SKU
Family To be filled by O.E.M.
Manufacturer ASUSTeK COMPUTER INC.
Product PRIME H510M-E
Version Rev 1.xx
Serial Number MB-1234567890
Asset Tag
Feature Flags 09h
00: - Motherboard
03: - Replaceable
Location Default string
Chassis Handle 0003h
Board Type 0ah - Processor/Memory Module
Number of Child Handles 0
Manufacturer Default string
Chassis Type Desktop
Version Default string
Serial Number
Asset Tag Number
Bootup State Safe
Power Supply State Safe
Thermal State Safe
Security Status None
OEM Defined 0
Height 0U
Number of Power Cords 1
Number of Contained Elements 0
Contained Element Size 3
[Onboard Devices Information (Type 10) - Length 6 - Handle 0020h]
Note: The On Board Device Information (Type 10) struct is obsolete as of SMBIOs spec v2.6 Number of Devices 1
01: Type Video [enabled]
01: Description To Be Filled By O.E.M.
[OEM Strings (Type 11) - Length 5 - Handle 0021h]
Number of Strings 6
1 Default string
2 Default string
3 EGGPLANT
4 Default string
5 Default string
6 Default string
[System Configuration Options (Type 12) - Length 5 - Handle 0022h]
[ (Type 256) - Length 50 - Handle 0039h]
[ (Type 256) - Length 9 - Handle 003ah]
[ (Type 256) - Length 31 - Handle 003bh]
[Physical Memory Array (Type 16) - Length 23 - Handle 003ch]
Location 03h - SystemBoard/Motherboard
Use 03h - System Memory
Memory Error Correction 03h - None
Maximum Capacity 33554432KB
Memory Error Inf Handle [Not Provided]
Number of Memory Devices 2
[Memory Array Mapped Address (Type 19) - Length 31 - Handle 003fh]
Starting Address 00000000h
Ending Address 00ffffffh
Memory Array Handle 003ch
Partition Width 02
Extended Starting Address 0000000000000000h
Extended Ending Address 0000000000000000h
[Memory Device (Type 17) - Length 92 - Handle 0040h]
Memory Error Info Handle [Not Provided]
Total Width 64 bits
Data Width 64 bits
Size 8192MB
Form Factor 09h - DIMM
Device Set [None]
Device Locator Controller0-ChannelA-DIMM0
Bank Locator BANK 0
Memory Type 1ah - DDR4
Type Detail 0080h - Synchronous
Speed 2133MHz
Manufacturer G Skill Intl
Serial Number
Asset Tag Number
Part Number F4-3200C16-8GVKB
Attributes 1
Extended Size 0
Configured Memory Speed 3200
Minimum Voltage 1200
Maximum Voltage 1200
Configured Voltage 1200
Memory Technology 3
Memory Operating Mode Capability 8
Firmware Version 0
Module Manufacturer Id 52484
Module Product Id 0
Memory Subsystem Controller Manufacturer Id 0
Memory Subsystem Controller Product Id 0
Non-Volatile Size 0
Volatile Size 0
Cache Size 0
Logical Size 0
Extended Speed 0
Extended Configured Memory Speed 0
[Memory Device (Type 17) - Length 92 - Handle 0041h]
Total Width 64 bits
Data Width 64 bits
Size 8192MB
Device Set [None]
Device Locator Controller0-ChannelB-DIMM0
Bank Locator BANK 1
Speed 2133MHz
Serial Number
Asset Tag Number
Attributes 1
Extended Size 0
Memory Technology 3
Firmware Version 0
Module Product Id 0
Non-Volatile Size 0
Volatile Size 0
Cache Size 0
Logical Size 0
Extended Speed 0
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 0042h]
Ending Address 007fffffh
Memory Device Handle 0040h
Mem Array Mapped Adr Handle 003fh
Partition Row Position [Unknown]
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 0043h]
Starting Address 00800000h
Memory Device Handle 0041h
[ (Type 256) - Length 26 - Handle 0044h]
[ (Type 256) - Length 26 - Handle 0045h]
[ (Type 256) - Length 47 - Handle 0046h]
[ (Type 256) - Length 82 - Handle 0047h]
[ (Type 256) - Length 12 - Handle 0048h]
[Cache Information (Type 7) - Length 27 - Handle 0049h]
Socket Designation L1 Cache
Cache Configuration 0180h - WBEnabled Int NonSocketed L1
Maximum Cache Size 0120h - 288K
Installed Size 0120h - 288K
Supported SRAM Type 0020h - Synchronous
Current SRAM Type 0020h - Synchronous
Cache Speed 0ns
Error Correction Type ParitySingle-Bit ECC
System Cache Type Data
Associativity 12-way Set-Associative
Maximum Cache Size 2 120 - 00000288l Kb
Installed Cache Size 2 120 - 00000288l Kb
[Cache Information (Type 7) - Length 27 - Handle 004ah]
Maximum Cache Size 00c0h - 192K
Installed Size 00c0h - 192K
Cache Speed 0ns
System Cache Type Instruction
Associativity 8-way Set-Associative
Maximum Cache Size 2 c0 - 00000192l Kb
Installed Cache Size 2 c0 - 00000192l Kb
[Cache Information (Type 7) - Length 27 - Handle 004bh]
Socket Designation L2 Cache
Cache Configuration 0181h - WBEnabled Int NonSocketed L2
Maximum Cache Size 0c00h - 3072K
Installed Size 0c00h - 3072K
Cache Speed 0ns
Error Correction Type Multi-Bit ECC
System Cache Type Unified
Maximum Cache Size 2 c00 - 00003072l Kb
Installed Cache Size 2 c00 - 00003072l Kb
[Cache Information (Type 7) - Length 27 - Handle 004ch]
Socket Designation L3 Cache
Cache Configuration 0182h - WBEnabled Int NonSocketed L3
Maximum Cache Size 3000h - 12288K
Installed Size 3000h - 12288K
Cache Speed 0ns
Error Correction Type Specification Reserved
Associativity 16-way Set-Associative
Maximum Cache Size 2 3000 - 00012288l Kb
Installed Cache Size 2 3000 - 00012288l Kb
[Processor Information (Type 4) - Length 48 - Handle 004dh]
Socket Designation LGA1200
Processor Type Central Processor
Processor Family cdh - Intel Core 2 Solo processor
Processor Manufacturer Intel(R) Corporation
Processor ID 71060a00fffbebbf
Processor Version 11th Gen Intel(R) Core(TM) i5-11400 @ 2.60GHz
Processor Voltage 88h - 0.8V
External Clock 100MHz
Max Speed 4400MHz
Current Speed 2574MHz
Status Enabled Populated
Processor Upgrade Socket LGA1200
L1 Cache Handle 004ah
L2 Cache Handle 004bh
L3 Cache Handle 004ch
Serial Number
Asset Tag Number
Part Number To Be Filled By O.E.M.
Core Count 6
Core Enabled 6
Thread Count 12
Processor Characteristics fc
Enabled Characteristics:
0x 2: 64-bit Capable
0x 3: Multi-Core
0x 4: Hardware Thread
0x 5: Execute Protection
0x 6: Enhanced Virtualization
Processor Family 2 00cdh - Intel Core 2 Solo processor
Core Count 2 6
Core Enabled 2 6
Thread Count 2 12
[ (Type 256) - Length 165 - Handle 004eh]
[ (Type 256) - Length 64 - Handle 004fh]
[ (Type 256) - Length 11 - Handle 0050h]
[ (Type 256) - Length 11 - Handle 0051h]
[ (Type 256) - Length 11 - Handle 0052h]
[ (Type 256) - Length 11 - Handle 0053h]
[ (Type 256) - Length 11 - Handle 0054h]
[ (Type 256) - Length 11 - Handle 0055h]
[ (Type 256) - Length 11 - Handle 0056h]
[ (Type 256) - Length 11 - Handle 0057h]
[ (Type 256) - Length 11 - Handle 0058h]
[ (Type 256) - Length 11 - Handle 0059h]
[ (Type 256) - Length 11 - Handle 005ah]
[ (Type 256) - Length 82 - Handle 005bh]
[ (Type 256) - Length 8 - Handle 005eh]
[ (Type 256) - Length 106 - Handle 0060h]
[ (Type 256) - Length 6 - Handle 0061h]
[ (Type 256) - Length 4 - Handle 0063h]
tunoz
- 26 Ocak 2025
- hata kodu (bugcheck): 0x1e.
- exception code: 0xC0000005 → erişim ihlali (yani bir kod parçası, geçersiz bir belleğe erişmeye çalıştı)
- faulting address: NT! Kirspınıststack+0x40 → bu, doğrudan Windows çekirdeğinde (ntkrnlmp.exe) oldu.
- etkin işlem (process name): System.
- BIOS sürümü: 2402 (ASUS Prime H510M-E, 18 Aralık 2023)
çözüm önerilerim:
Kod:KMODE_EXCEPTION_NOT_HANDLED (1e) This is a very common BugCheck. Usually the exception address pinpoints. the driver/function that caused the problem. Always note this address. as well as the link date of the driver/image that contains this address. Arguments: Arg1: ffffffffc0000005, The exception code that was not handled. Arg2: fffff80455118a08, The address that the exception occurred at. Arg3: 0000000000000000, Parameter 0 of the exception. Arg4: ffffffffffffffff, Parameter 1 of the exception. Debugging Details: ------------------ KEY_VALUES_STRING: 1 Key : Analysis.CPU.mSec Value: 1437. Key : Analysis.Elapsed.mSec Value: 1491. Key : Analysis.IO.Other.Mb Value: 1 Key : Analysis.IO.Read.Mb Value: 1 Key : Analysis.IO.Write.Mb Value: 18. Key : Analysis.Init.CPU.mSec Value: 500. Key : Analysis.Init.Elapsed.mSec Value: 11450. Key : Analysis.Memory.CommitPeak.Mb Value: 76. Key : Analysis.Version.DbgEng Value: 10.0.27829.1001 Key : Analysis.Version.Description Value: 10.2503.24.01 amd64fre. Key : Analysis.Version.Ext Value: 1.2503.24.1 Key : Bugcheck.Code.LegacyAPI Value: 0x1e. Key : Bugcheck.Code.TargetModel Value: 0x1e. Key : Dump.Attributes.AsUlong Value: 0x8. Key : Dump.Attributes.KernelGeneratedTriageDump Value: 1 Key : Failure.Bucket Value: AV_R_nt!KiRspInIstStack Key : Failure.Exception.IP.Address Value: 0xfffff80455118a08. Key : Failure.Exception.IP.Module Value: nt. Key : Failure.Exception.IP.Offset Value: 0x518a08. Key : Failure.Hash Value: {f72f361e-f56a-2d15-acda-72d84d638abb} Key : Stack.Pointer Value: PRCBException. BUGCHECK_CODE: 1e. BUGCHECK_P1: ffffffffc0000005. BUGCHECK_P2: fffff80455118a08. BUGCHECK_P3: 0 BUGCHECK_P4: ffffffffffffffff. FILE_IN_CAB: 071425-6171-01.dmp DUMP_FILE_ATTRIBUTES: 0x8. Kernel Generated Triage Dump. FAULTING_THREAD: ffffdf808112b340. EXCEPTION_PARAMETER1: 0000000000000000. EXCEPTION_PARAMETER2: ffffffffffffffff. READ_ADDRESS: fffff804558fb390: Unable to get MiVisibleState. Unable to get NonPagedPoolStart. Unable to get NonPagedPoolEnd. Unable to get PagedPoolStart. Unable to get PagedPoolEnd. unable to get nt!MmSpecialPagesInUse ffffffffffffffff. BLACKBOXBSD: 1 (!blackboxbsd) BLACKBOXNTFS: 1 (!blackboxntfs) BLACKBOXWINLOGON: 1 CUSTOMER_CRASH_COUNT: 1 PROCESS_NAME: System. TRAP_FRAME: fffff780000003d8 -- (.trap 0xfffff780000003d8) Unable to read trap frame at fffff780`000003d8 Resetting default scope. STACK_TEXT: ffffdf80`8117e468 fffff804`550750f2 : 00000000`0000001e ffffffff`c0000005 fffff804`55118a08 00000000`00000000 : nt!KeBugCheckEx ffffdf80`8117e470 fffff804`55007eff : fffff804`54f1d59c 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiExceptionStackSwitchHandler+0x157b56 ffffdf80`8117e4b0 fffff804`54f3e857 : ffffdf80`8117ea20 00000000`00000000 ffffdf80`8117ffb0 fffff804`54ffe522 : nt!RtlpExecuteHandlerForException+0xf ffffdf80`8117e4e0 fffff804`54f3c4f6 : ffffdf80`8117f3f8 ffffdf80`8117f130 ffffdf80`8117f3f8 00000000`00000000 : nt!RtlDispatchException+0x297 ffffdf80`8117ec00 fffff804`55011cec : ffffb47f`ffffffff 00000000`00000001 fffff780`000003d8 ffffdf80`8117ea60 : nt!KiDispatchException+0x186 ffffdf80`8117f2c0 fffff804`5500d0ef : 00000000`00000000 00000000`00000000 00040000`0026133c 01dbdfb7`c7d279d5 : nt!KiExceptionDispatch+0x12c ffffdf80`8117f4a0 fffff804`55118a08 : fffff804`5505a4ff 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiGeneralProtectionFault+0x32f ffffdf80`8117f638 fffff804`5505a4ff : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiRspInIstStack+0x40 ffffdf80`8117f640 fffff804`54f402e4 : ffffdf80`8117f920 ffffdf80`8112f708 ffffdf80`8117f710 ffffdf80`8117f870 : nt!KeQueryCurrentStackInformationEx+0x18988f ffffdf80`8117f6a0 fffff804`54f3e6a1 : ffffdf80`8117f920 00000000`00000000 000004e8`fffffb30 000004d0`fffffb30 : nt!RtlpGetStackLimitsEx+0x14 ffffdf80`8117f6d0 fffff804`54f3c4f6 : ffffdf80`8112f708 ffffdf80`8117fe20 ffffdf80`8112f708 ffffcf03`71d1c000 : nt!RtlDispatchException+0xe1 ffffdf80`8117f8f0 fffff804`54ffe522 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiDispatchException+0x186 ffffdf80`8117ffb0 fffff804`54ffe4f0 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxExceptionDispatchOnExceptionStack+0x12 ffffdf80`8112f5c8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiExceptionDispatchOnExceptionStackContinue SYMBOL_NAME: nt!KiRspInIstStack+40 MODULE_NAME: nt. IMAGE_NAME: ntkrnlmp.exe IMAGE_VERSION: 10.0.19041.6093 STACK_COMMAND: .process /r /p 0xfffff80455924a00; .thread 0xffffdf808112b340 ; kb. BUCKET_ID_FUNC_OFFSET: 40. FAILURE_BUCKET_ID: AV_R_nt!KiRspInIstStack OSPLATFORM_TYPE: x64. OSNAME: Windows 10. FAILURE_ID_HASH: {f72f361e-f56a-2d15-acda-72d84d638abb} Followup: MachineOwner. --------- [SMBIOS Data Tables v3.3] [DMI Version - 0] [2.0 Calling Convention - No] [Table Size - 4919 bytes] [BIOS Information (Type 0) - Length 26 - Handle 0000h] Vendor American Megatrends Inc. BIOS Version 2402. BIOS Starting Address Segment f000. BIOS Release Date 12/18/2023 BIOS ROM Size 1000000. BIOS Characteristics. 07: - PCI Supported. 11: - Upgradeable FLASH BIOS. 12: - BIOS Shadowing Supported. 15: - CD-Boot Supported. 16: - Selectable Boot Supported. 17: - BIOS ROM Socketed. 19: - EDD Supported. 20: - NEC 9800 J-Floppy Supported. 21: - Toshiba J-Floppy Supported. 22: - 360KB Floppy Supported. 23: - 1.2MB Floppy Supported. 24: - 720KB Floppy Supported. 25: - 2.88MB Floppy Supported. 26: - Print Screen Device Supported. 28: - Serial Services Supported. 29: - Printer Services Supported. 30: - CGA/Mono Services Supported. 32: - BIOS Vendor Reserved. BIOS Characteristic Extensions. 01: - USB Legacy Supported. 08: - BIOS Boot Specification Supported. 10: - Enable Targeted Content Distribution. 11: - UEFI Specification Supported. BIOS Major Revision 24. BIOS Minor Revision 2 EC Firmware Major Revision 255. EC Firmware Minor Revision 255. Extended BIOS ROM Size 16 MB. [System Information (Type 1) - Length 27 - Handle 0001h] Manufacturer ASUS. Product Name System Product Name. Version System Version. Serial Number System Serial Number. UUID 00000000-0000-0000-0000-000000000000 Wakeup Type Power Switch. SKUNumber SKU. Family To be filled by O.E.M. [BaseBoard Information (Type 2) - Length 15 - Handle 0002h] Manufacturer ASUSTeK COMPUTER INC. Product PRIME H510M-E Version Rev 1.xx Serial Number MB-1234567890 Asset Tag Feature Flags 09h. 00: - Motherboard. 03: - Replaceable. Location Default string. Chassis Handle 0003h. Board Type 0ah - Processor/Memory Module. Number of Child Handles 0 [System Enclosure (Type 3) - Length 22 - Handle 0003h] Manufacturer Default string. Chassis Type Desktop. Version Default string. Serial Number Asset Tag Number Bootup State Safe. Power Supply State Safe. Thermal State Safe. Security Status None. OEM Defined 0 Height 0U. Number of Power Cords 1 Number of Contained Elements 0 Contained Element Size 3 [Onboard Devices Information (Type 10) - Length 6 - Handle 0020h] Note: The On Board Device Information (Type 10) struct is obsolete as of SMBIOs spec v2.6 Number of Devices 1 01: Type Video [enabled] 01: Description To Be Filled By O.E.M. [OEM Strings (Type 11) - Length 5 - Handle 0021h] Number of Strings 6 1 Default string. 2 Default string. 3 EGGPLANT. 4 Default string. 5 Default string. 6 Default string. [System Configuration Options (Type 12) - Length 5 - Handle 0022h] [ (Type 256) - Length 50 - Handle 0039h] [ (Type 256) - Length 9 - Handle 003ah] [ (Type 256) - Length 31 - Handle 003bh] [Physical Memory Array (Type 16) - Length 23 - Handle 003ch] Location 03h - SystemBoard/Motherboard Use 03h - System Memory. Memory Error Correction 03h - None. Maximum Capacity 33554432KB. Memory Error Inf Handle [Not Provided] Number of Memory Devices 2 [Memory Array Mapped Address (Type 19) - Length 31 - Handle 003fh] Starting Address 00000000h. Ending Address 00ffffffh. Memory Array Handle 003ch. Partition Width 02. Extended Starting Address 0000000000000000h. Extended Ending Address 0000000000000000h. [Memory Device (Type 17) - Length 92 - Handle 0040h] Memory Error Info Handle [Not Provided] Total Width 64 bits. Data Width 64 bits. Size 8192MB. Form Factor 09h - DIMM. Device Set [None] Device Locator Controller0-ChannelA-DIMM0 Bank Locator BANK 0 Memory Type 1ah - DDR4. Type Detail 0080h - Synchronous. Speed 2133MHz. Manufacturer G Skill Intl. Serial Number Asset Tag Number Part Number F4-3200C16-8GVKB Attributes 1 Extended Size 0 Configured Memory Speed 3200. Minimum Voltage 1200. Maximum Voltage 1200. Configured Voltage 1200. Memory Technology 3 Memory Operating Mode Capability 8 Firmware Version 0 Module Manufacturer Id 52484. Module Product Id 0 Memory Subsystem Controller Manufacturer Id 0 Memory Subsystem Controller Product Id 0 Non-Volatile Size 0 Volatile Size 0 Cache Size 0 Logical Size 0 Extended Speed 0 Extended Configured Memory Speed 0 [Memory Device (Type 17) - Length 92 - Handle 0041h] Memory Error Info Handle [Not Provided] Total Width 64 bits. Data Width 64 bits. Size 8192MB. Form Factor 09h - DIMM. Device Set [None] Device Locator Controller0-ChannelB-DIMM0 Bank Locator BANK 1 Memory Type 1ah - DDR4. Type Detail 0080h - Synchronous. Speed 2133MHz. Manufacturer G Skill Intl. Serial Number Asset Tag Number Part Number F4-3200C16-8GVKB Attributes 1 Extended Size 0 Configured Memory Speed 3200. Minimum Voltage 1200. Maximum Voltage 1200. Configured Voltage 1200. Memory Technology 3 Memory Operating Mode Capability 8 Firmware Version 0 Module Manufacturer Id 52484. Module Product Id 0 Memory Subsystem Controller Manufacturer Id 0 Memory Subsystem Controller Product Id 0 Non-Volatile Size 0 Volatile Size 0 Cache Size 0 Logical Size 0 Extended Speed 0 Extended Configured Memory Speed 0 [Memory Device Mapped Address (Type 20) - Length 35 - Handle 0042h] Starting Address 00000000h. Ending Address 007fffffh. Memory Device Handle 0040h. Mem Array Mapped Adr Handle 003fh. Partition Row Position [Unknown] Extended Starting Address 0000000000000000h. Extended Ending Address 0000000000000000h. [Memory Device Mapped Address (Type 20) - Length 35 - Handle 0043h] Starting Address 00800000h. Ending Address 00ffffffh. Memory Device Handle 0041h. Mem Array Mapped Adr Handle 003fh. Partition Row Position [Unknown] Extended Starting Address 0000000000000000h. Extended Ending Address 0000000000000000h. [ (Type 256) - Length 26 - Handle 0044h] [ (Type 256) - Length 26 - Handle 0045h] [ (Type 256) - Length 47 - Handle 0046h] [ (Type 256) - Length 82 - Handle 0047h] [ (Type 256) - Length 12 - Handle 0048h] [Cache Information (Type 7) - Length 27 - Handle 0049h] Socket Designation L1 Cache. Cache Configuration 0180h - WBEnabled Int NonSocketed L1. Maximum Cache Size 0120h - 288K. Installed Size 0120h - 288K. Supported SRAM Type 0020h - Synchronous. Current SRAM Type 0020h - Synchronous. Cache Speed 0ns. Error Correction Type ParitySingle-Bit ECC. System Cache Type Data. Associativity 12-way Set-Associative Maximum Cache Size 2 120 - 00000288l Kb. Installed Cache Size 2 120 - 00000288l Kb. [Cache Information (Type 7) - Length 27 - Handle 004ah] Socket Designation L1 Cache. Cache Configuration 0180h - WBEnabled Int NonSocketed L1. Maximum Cache Size 00c0h - 192K. Installed Size 00c0h - 192K. Supported SRAM Type 0020h - Synchronous. Current SRAM Type 0020h - Synchronous. Cache Speed 0ns. Error Correction Type ParitySingle-Bit ECC. System Cache Type Instruction. Associativity 8-way Set-Associative Maximum Cache Size 2 c0 - 00000192l Kb. Installed Cache Size 2 c0 - 00000192l Kb. [Cache Information (Type 7) - Length 27 - Handle 004bh] Socket Designation L2 Cache. Cache Configuration 0181h - WBEnabled Int NonSocketed L2. Maximum Cache Size 0c00h - 3072K. Installed Size 0c00h - 3072K. Supported SRAM Type 0020h - Synchronous. Current SRAM Type 0020h - Synchronous. Cache Speed 0ns. Error Correction Type Multi-Bit ECC. System Cache Type Unified. Associativity 8-way Set-Associative Maximum Cache Size 2 c00 - 00003072l Kb. Installed Cache Size 2 c00 - 00003072l Kb. [Cache Information (Type 7) - Length 27 - Handle 004ch] Socket Designation L3 Cache. Cache Configuration 0182h - WBEnabled Int NonSocketed L3. Maximum Cache Size 3000h - 12288K. Installed Size 3000h - 12288K. Supported SRAM Type 0020h - Synchronous. Current SRAM Type 0020h - Synchronous. Cache Speed 0ns. Error Correction Type Specification Reserved. System Cache Type Unified. Associativity 16-way Set-Associative Maximum Cache Size 2 3000 - 00012288l Kb. Installed Cache Size 2 3000 - 00012288l Kb. [Processor Information (Type 4) - Length 48 - Handle 004dh] Socket Designation LGA1200. Processor Type Central Processor. Processor Family cdh - Intel Core 2 Solo processor. Processor Manufacturer Intel(R) Corporation. Processor ID 71060a00fffbebbf. Processor Version 11th Gen Intel(R) Core(TM) i5-11400 @ 2.60GHz Processor Voltage 88h - 0.8V External Clock 100MHz. Max Speed 4400MHz. Current Speed 2574MHz. Status Enabled Populated. Processor Upgrade Socket LGA1200. L1 Cache Handle 004ah. L2 Cache Handle 004bh. L3 Cache Handle 004ch. Serial Number Asset Tag Number Part Number To Be Filled By O.E.M. Core Count 6 Core Enabled 6 Thread Count 12. Processor Characteristics fc. Enabled Characteristics: 0x 2: 64-bit Capable. 0x 3: Multi-Core 0x 4: Hardware Thread. 0x 5: Execute Protection. 0x 6: Enhanced Virtualization. 0x 7: Power/Performance Control. Processor Family 2 00cdh - Intel Core 2 Solo processor. Core Count 2 6 Core Enabled 2 6 Thread Count 2 12. [ (Type 256) - Length 165 - Handle 004eh] [ (Type 256) - Length 64 - Handle 004fh] [ (Type 256) - Length 11 - Handle 0050h] [ (Type 256) - Length 11 - Handle 0051h] [ (Type 256) - Length 11 - Handle 0052h] [ (Type 256) - Length 11 - Handle 0053h] [ (Type 256) - Length 11 - Handle 0054h] [ (Type 256) - Length 11 - Handle 0055h] [ (Type 256) - Length 11 - Handle 0056h] [ (Type 256) - Length 11 - Handle 0057h] [ (Type 256) - Length 11 - Handle 0058h] [ (Type 256) - Length 11 - Handle 0059h] [ (Type 256) - Length 11 - Handle 005ah] [ (Type 256) - Length 82 - Handle 005bh] [ (Type 256) - Length 8 - Handle 005eh] [ (Type 256) - Length 106 - Handle 0060h] [ (Type 256) - Length 6 - Handle 0061h] [ (Type 256) - Length 4 - Handle 0063h]
PC başlangıçta açtığım zamanda tepki vermiyor klavye mouse ışıkları yanmıyor ekrana görüntü gitmiyor kapatıp açıyorum BIOS atıyor bilgisayar.
Nightography ve Astrography için hangi telefonlara ihtiyacımız var?
- THE KEROXEA
- Mesaj: 6
