Çözüldü Lenovo IdeaPad 3 laptop sürekli mavi ekran veriyor
Peker
22 Ocak 2024
  • Anakart: LENOVO IDEAPAD GAMING 3-15IHU6 ANAKART 5B21C73632
  • İşlemci:11th Gen Intel(R) Core(TM) i5-11300H @ 3.10GHz 3.11 GHz
  • Ekran Kartı:RTX 3050 TI LAPTOP 4 GB
  • İşletim Sistemi:Windows 11 Home
Neredeyse 6 aya yakındır sürekli mavi ekran veriyor. Son zamanlarda çok sıklaştı. RAM testini yaptım herhangi bir sorun çıkmadı.
Donanımsal bir soruna benziyor, servise yollamanızı öneririm.
Kod:
CRITICAL_PROCESS_DIED (ef)
        A critical system process died
Arguments:
Arg1: ffff8581e08e00c0, Process object or thread object
Arg2: 0000000000000000, If this is 0, a process died. If this is 1, a thread died.
Arg3: ffff8581e08e00c0, The process object that initiated the termination.
Arg4: 0000000000000000
Debugging Details:
KEY_VALUES_STRING: 1
    Key  : Analysis.CPU.mSec
    Value: 1656
    Key  : Analysis.Elapsed.mSec
    Value: 1711
    Key  : Analysis.IO.Other.Mb
    Value: 0
    Key  : Analysis.IO.Read.Mb
    Value: 0
    Key  : Analysis.IO.Write.Mb
    Value: 0
    Key  : Analysis.Init.CPU.mSec
    Value: 343
    Value: 4636
    Value: 89
    Value: 0xef
    Value: 0xef
    Key  : CriticalProcessDied.ExceptionCode
    Value: ec2c3040
    Key  : CriticalProcessDied.ImageName
    Value: unknown
    Key  : CriticalProcessDied.ImageOffset
    Value: 7ffcb5c16d43
    Key  : CriticalProcessDied.ImageSize
    Value: 0
    Key  : CriticalProcessDied.ImageTimestamp
    Value: 0
    Key  : CriticalProcessDied.Process
    Value: services.exe
    Key  : CriticalProcessDied.Symbol
    Value: unknown!
    Key  : CriticalProcessDied.WERReportId
    Value: 3aef775c-9cf4-4200-a1e9-7b8c7f105fe2
    Value: 1808
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Key  : Failure.Bucket
    Value: 0xEF_services.exe_BUGCHECK_CRITICAL_PROCESS_ec2c3040_unknown!_IMAGE_unknown
    Key  : Failure.Hash
    Value: {7cbe2ca9-22ca-5656-8f4e-649b0b26e67c}
    Key  : Hypervisor.Enlightenments.ValueHex
    Value: 1417df84
    Key  : Hypervisor.Flags.AnyHypervisorPresent
    Value: 1
    Key  : Hypervisor.Flags.ApicEnlightened
    Value: 0
    Key  : Hypervisor.Flags.ApicVirtualizationAvailable
    Value: 1
    Key  : Hypervisor.Flags.AsyncMemoryHint
    Value: 0
    Key  : Hypervisor.Flags.CoreSchedulerRequested
    Value: 0
    Key  : Hypervisor.Flags.CpuManager
    Value: 1
    Key  : Hypervisor.Flags.DeprecateAutoEoi
    Value: 1
    Key  : Hypervisor.Flags.DynamicCpuDisabled
    Value: 1
    Key  : Hypervisor.Flags.Epf
    Value: 0
    Key  : Hypervisor.Flags.ExtendedProcessorMasks
    Value: 1
    Key  : Hypervisor.Flags.HardwareMbecAvailable
    Value: 1
    Key  : Hypervisor.Flags.MaxBankNumber
    Value: 0
    Key  : Hypervisor.Flags.MemoryZeroingControl
    Value: 0
    Key  : Hypervisor.Flags.NoExtendedRangeFlush
    Value: 0
    Key  : Hypervisor.Flags.NoNonArchCoreSharing
    Value: 1
    Key  : Hypervisor.Flags.Phase0InitDone
    Value: 1
    Key  : Hypervisor.Flags.PowerSchedulerQos
    Value: 0
    Key  : Hypervisor.Flags.RootScheduler
    Value: 0
    Key  : Hypervisor.Flags.SynicAvailable
    Value: 1
    Key  : Hypervisor.Flags.UseQpcBias
    Value: 0
    Key  : Hypervisor.Flags.Value
    Value: 21631230
    Key  : Hypervisor.Flags.ValueHex
    Value: 14a10fe
    Key  : Hypervisor.Flags.VpAssistPage
    Value: 1
    Key  : Hypervisor.Flags.VsmAvailable
    Value: 1
    Key  : Hypervisor.RootFlags.AccessStats
    Value: 1
    Key  : Hypervisor.RootFlags.CrashdumpEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.CreateVirtualProcessor
    Value: 1
    Key  : Hypervisor.RootFlags.DisableHyperthreading
    Value: 0
    Key  : Hypervisor.RootFlags.HostTimelineSync
    Value: 1
    Key  : Hypervisor.RootFlags.HypervisorDebuggingEnabled
    Value: 0
    Key  : Hypervisor.RootFlags.IsHyperV
    Value: 1
    Key  : Hypervisor.RootFlags.LivedumpEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.MapDeviceInterrupt
    Value: 1
    Key  : Hypervisor.RootFlags.MceEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.Nested
    Value: 0
    Key  : Hypervisor.RootFlags.StartLogicalProcessor
    Value: 1
    Key  : Hypervisor.RootFlags.Value
    Value: 1015
    Key  : Hypervisor.RootFlags.ValueHex
    Value: 3f7
BUGCHECK_CODE:  ef
BUGCHECK_P1: ffff8581e08e00c0
BUGCHECK_P2: 0
BUGCHECK_P3: ffff8581e08e00c0
BUGCHECK_P4: 0
FILE_IN_CAB:  061624-22000-01.dmp
TAG_NOT_DEFINED_202b:  *** Unknown TAG in analysis list 202b
DUMP_FILE_ATTRIBUTES: 0x1808
  Kernel Generated Triage Dump
PROCESS_NAME:  services.exe
CRITICAL_PROCESS:  services.exe
EXCEPTION_RECORD:  0000000000000002 -- (.exr 0x2)
Cannot read Exception record @ 0000000000000002
ERROR_CODE: (NTSTATUS) 0xec2c3040 - <Unable to get error code text>
CRITICAL_PROCESS_REPORTGUID:  {3aef775c-9cf4-4200-a1e9-7b8c7f105fe2}
IMAGE_NAME:  unknown
MODULE_NAME: unknown
FAULTING_MODULE: 0000000000000000
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT:  1
STACK_TEXT:
ffff818b`68c25f78 fffff801`70db165b     : 00000000`000000ef ffff8581`e08e00c0 00000000`00000000 ffff8581`e08e00c0 : nt!KeBugCheckEx
ffff818b`68c25f80 fffff801`70ce2027     : ffff8581`e08e00c0 fffff801`706105cd 00000000`00000000 fffff801`7060fff7 : nt!PspCatchCriticalBreak+0x11b
ffff818b`68c26010 fffff801`70a85a8b     : ffff8581`e08e00c0 00000000`c0000005 ffff8581`e08e00c0 00000000`00000001 : nt!PspTerminateAllThreads+0x15ab67
ffff818b`68c26080 fffff801`70a85861     : ffffffff`ffffffff ffff8581`e08e00c0 ffff8581`ec2c3040 ffff8581`e08e00c0 : nt!PspTerminateProcess+0xe7
ffff818b`68c260c0 fffff801`7082f805     : ffff818b`00000408 ffff8581`ec2c3040 ffff8581`e08e00c0 fffff801`70d37327 : nt!NtTerminateProcess+0xb1
ffff818b`68c26140 fffff801`7081fd30     : fffff801`7086d79b ffffffff`ffffffff ffff818b`68c273e0 00000000`00000001 : nt!KiSystemServiceCopyEnd+0x25
ffff818b`68c262d8 fffff801`7086d79b     : ffffffff`ffffffff ffff818b`68c273e0 00000000`00000001 ffff818b`68c26310 : nt!KiServiceLinkage
ffff818b`68c262e0 fffff801`70976adf     : 00000000`00000002 00000072`fc890001 ffff818b`68c273e0 00000000`00000000 : nt!KiDispatchException+0x267a8b
ffff818b`68c27180 fffff801`7081ae96     : 00000000`00000001 00000000`00001000 00000000`00000001 fffff801`7064f9a2 : nt!KiRaiseException+0x10f
ffff818b`68c272a0 fffff801`7082f805     : 00000000`00000000 00000000`00000000 00000072`fcdfde10 00000000`00000000 : nt!NtRaiseException+0x96
ffff818b`68c273e0 00007ffc`b5c188a5     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x25
00000072`fcdff2d0 00000000`00000000     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ffc`b5c188a5
STACK_COMMAND:  .cxr; .ecxr ; kb
FAILURE_BUCKET_ID:  0xEF_services.exe_BUGCHECK_CRITICAL_PROCESS_ec2c3040_unknown!_IMAGE_unknown
OSPLATFORM_TYPE:  x64
OSNAME:  Windows 10
FAILURE_ID_HASH:  {7cbe2ca9-22ca-5656-8f4e-649b0b26e67c}
Followup:     MachineOwner
    PnpActivityId      : {00000000-0000-0000-0000-000000000000}
    PnpActivityTime    : 133630087657017665
    PnpEventInformation: 3
    PnpEventInProgress : 0
    PnpProblemCode     : 24
    PnpVetoType        : 0
    DeviceId           : SW\{96E080C7-143C-11D1-B40F-00A0C9223196}\{3C0D501A-140B-11D1-B40F-00A0C9223196}
    VetoString         :
[SMBIOS Data Tables v3.3]
[DMI Version - 0]
[2.0 Calling Convention - No]
[Table Size - 4035 bytes]
  Vendor                        LENOVO
  BIOS Version                  H4CN35WW(V2.04)
  BIOS Starting Address Segment e000
  BIOS Release Date             04/15/2024
  BIOS ROM Size                 e00000
  BIOS Characteristics
       07: - PCI Supported
       11: - Upgradeable FLASH BIOS
       15: - CD-Boot Supported
       19: - EDD Supported
       22: - 360KB Floppy Supported
       23: - 1.2MB Floppy Supported
       24: - 720KB Floppy Supported
       25: - 2.88MB Floppy Supported
       27: - Keyboard Services Supported
       49: - System Vendor Reserved
       51: - System Vendor Reserved
       52: - System Vendor Reserved
       00: - ACPI Supported
       01: - USB Legacy Supported
  BIOS Major Revision           2
  BIOS Minor Revision           35
  EC Firmware Major Revision    2
  EC Firmware Minor Revision    35
  Extended BIOS ROM Size        0 MB
  Manufacturer                  LENOVO
  Product Name                  82K1
  Version                       IdeaPad Gaming 3 15IHU6
  Serial Number                 MP25VSRF
  SKUNumber                     LENOVO_MT_82K1_BU_idea_FM_IdeaPad Gaming 3 15IHU6
  Family                        IdeaPad Gaming 3 15IHU6
  Manufacturer                  LENOVO
  Product                       LNVNB161216
  Version                       SDK0T76466 WIN
  Asset Tag
       00: - Motherboard
       03: - Replaceable
  Location                      Type2 - Board Chassis Location
  Manufacturer                  LENOVO
  Chassis Type                  Notebook
  Serial Number
  Asset Tag Number
  Contained Element Size        0
[Processor Information (Type 4) - Length 48 - Handle 0004h]
  Socket Designation            U3E1
  Processor Family              cdh - Intel Core 2 Solo processor
  Processor Manufacturer        Intel(R) Corporation
  Processor ID                   c1060800fffbebbf
  Processor Version             11th Gen Intel(R) Core(TM) i5-11300H @ 3.10GHz
  Processor Voltage             88h - 0.8V
  Max Speed                     4400MHz
  Current Speed                 3100MHz
  Processor Upgrade             Other
  L1 Cache Handle               0006h
  L2 Cache Handle               0007h
  L3 Cache Handle               0008h
  Serial Number
  Asset Tag Number
  Part Number                   To Be Filled By O.E.M.
  Core Count                    4
  Core Enabled                  4
  Thread Count                  8
  Processor Characteristics     fc
  Enabled Characteristics:
       0x 2: 64-bit Capable
       0x 3: Multi-Core
       0x 4: Hardware Thread
       0x 5: Execute Protection
       0x 6: Enhanced Virtualization
  Processor Family 2            00cdh - Intel Core 2 Solo processor
  Core Count 2                  4
  Core Enabled 2                4
  Thread Count 2                8
[Cache Information (Type 7) - Length 27 - Handle 0005h]
  Socket Designation            L1 Cache
  Maximum Cache Size            00c0h - 192K
  Installed Size                00c0h - 192K
  Supported SRAM Type           0020h - Synchronous
  Current SRAM Type             0020h - Synchronous
  Cache Speed                   0ns
  Error Correction Type         ParitySingle-Bit ECC
  System Cache Type             Data
  Associativity                 12-way Set-Associative
  Maximum Cache Size 2          0 - 00000000l Kb
  Installed Cache Size 2        0 - 00000000l Kb
[Cache Information (Type 7) - Length 27 - Handle 0006h]
  Maximum Cache Size            0080h - 128K
  Installed Size                0080h - 128K
  Cache Speed                   0ns
  System Cache Type             Instruction
[Cache Information (Type 7) - Length 27 - Handle 0007h]
  Socket Designation            L2 Cache
  Maximum Cache Size            1400h - 5120K
  Installed Size                1400h - 5120K
  Cache Speed                   0ns
  Error Correction Type         Multi-Bit ECC
  Associativity                 Other
[Cache Information (Type 7) - Length 27 - Handle 0008h]
  Socket Designation            L3 Cache
  Maximum Cache Size            2000h - 8192K
  Installed Size                2000h - 8192K
  Cache Speed                   0ns
[OEM Strings (Type 11) - Length 5 - Handle 001fh]
  Number of Strings             1
   1                            Modern Preload
[System Configuration Options (Type 12) - Length 5 - Handle 0020h]
[Physical Memory Array (Type 16) - Length 23 - Handle 0024h]
  Maximum Capacity              67108864KB
  Memory Error Inf Handle       [Not Provided]
  Number of Memory Devices      8
[Memory Device (Type 17) - Length 92 - Handle 0025h]
  Memory Error Info Handle      [Not Provided]
  Size                          8192MB
  Form Factor                   0dh - SODIMM
  Device Locator                Controller0-ChannelA-DIMM0
  Bank Locator                  BANK 0
  Memory Type                   1ah - DDR4
  Type Detail                   0080h - Synchronous
  Speed                         3200MHz
  Manufacturer                  Samsung
  Serial Number
  Asset Tag Number
  Part Number                   M471A1G44AB0-CWE
  Attributes                    1
  Configured Memory Speed       3200
  Minimum Voltage               0
  Maximum Voltage               0
  Configured Voltage            1200
  Memory Technology             3
  Memory Operating Mode Capability     8
  Firmware Version              0
  Module Manufacturer Id        52864
  Module Product Id             0
  Memory Subsystem Controller Manufacturer Id  0
  Memory Subsystem Controller Product Id       0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
  Extended Configured Memory Speed     0
[Memory Device (Type 17) - Length 92 - Handle 0026h]
  Size                          8192MB
  Device Locator                Controller1-ChannelA-DIMM0
  Bank Locator                  BANK 0
  Speed                         3200MHz
  Manufacturer                  Kingston
  Serial Number
  Asset Tag Number
  Part Number                   KVR32S22S8/8
  Attributes                    1
  Minimum Voltage               0
  Maximum Voltage               0
  Memory Technology             3
  Firmware Version              0
  Module Manufacturer Id        38913
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
[Memory Array Mapped Address (Type 19) - Length 31 - Handle 0027h]
  Ending Address                00ffffffh
  Memory Array Handle           0024h
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 0028h]
  Ending Address                007fffffh
  Memory Device Handle          0025h
  Mem Array Mapped Adr Handle   0027h
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 0029h]
  Memory Device Handle          0000h
[ (Type 256) - Length 17 - Handle 0032h]
[ (Type 256) - Length 11 - Handle 0033h]
[ (Type 256) - Length 31 - Handle 0034h]
[ (Type 256) - Length 8 - Handle 0035h]
[ (Type 256) - Length 8 - Handle 0036h]
[ (Type 256) - Length 64 - Handle 0037h]
[ (Type 256) - Length 5 - Handle 0038h]
[ (Type 256) - Length 6 - Handle 0039h]
[ (Type 256) - Length 106 - Handle 003bh]
[ (Type 256) - Length 26 - Handle 003ch]
[ (Type 256) - Length 26 - Handle 003dh]
[ (Type 256) - Length 47 - Handle 003eh]
[ (Type 256) - Length 82 - Handle 003fh]
[ (Type 256) - Length 12 - Handle 0040h]
[ (Type 256) - Length 89 - Handle 0041h]
[ (Type 256) - Length 18 - Handle 0042h]
[ (Type 256) - Length 4 - Handle feffh]
KMODE_EXCEPTION_NOT_HANDLED (1e)
This is a very common BugCheck.  Usually the exception address pinpoints
the driver/function that caused the problem.  Always note this address
as well as the link date of the driver/image that contains this address.
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff8022114bb51, The address that the exception occurred at
Arg3: 0000000000000000, Parameter 0 of the exception
Arg4: ffffffffffffffff, Parameter 1 of the exception
Debugging Details:
***    Either you specified an unqualified symbol, or your debugger   ***
***    doesn't have full symbol information.  Unqualified symbol      ***
***    resolution is turned off by default. Please either specify a   ***
***    fully qualified symbol module!symbolname, or enable resolution ***
***    of unqualified symbols by typing ".symopt- 100". Note that     ***
***    enabling unqualified symbol resolution with network symbol     ***
***    server shares in the symbol path may cause the debugger to     ***
***    appear to hang for long periods of time when an incorrect      ***
***    symbol name is typed or the network symbol server is down.     ***
***    For some commands to work properly, your symbol path           ***
***    must point to .pdb files that have full type information.      ***
***    Certain .pdb files (such as the public OS symbols) do not      ***
***    contain the required information.  Contact the group that      ***
***    provided you with these symbols if you need this command to    ***
***    work.                                                          ***
***    Type referenced: ExceptionRecord                               ***
***    work.                                                          ***
***    Type referenced: ContextRecord                                 ***
    Value: 1499
    Value: 8766
    Value: 0
    Value: 0
    Value: 1
    Value: 312
    Value: 8583
    Value: 92
    Value: 0x1e
    Value: 0x1e
    Value: 1808
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: AV_R_FLTMGR!TreeUnlinkMulti
    Key  : Failure.Hash
    Value: {f8f4c51b-319a-41f7-d0f6-f61760289098}
    Value: 1417df84
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 0
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 21631230
    Value: 14a10fe
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 1015
    Value: 3f7
BUGCHECK_CODE:  1e
BUGCHECK_P1: ffffffffc0000005
BUGCHECK_P2: fffff8022114bb51
BUGCHECK_P3: 0
BUGCHECK_P4: ffffffffffffffff
FILE_IN_CAB:  061624-21984-01.dmp
EXCEPTION_PARAMETER1:  0000000000000000
EXCEPTION_PARAMETER2:  ffffffffffffffff
READ_ADDRESS: fffff8022391c4a8: Unable to get MiVisibleState
Unable to get NonPagedPoolStart
Unable to get NonPagedPoolEnd
Unable to get PagedPoolStart
Unable to get PagedPoolEnd
unable to get nt!MmSpecialPagesInUse
 ffffffffffffffff
BLACKBOXWINLOGON: 1
PROCESS_NAME:  WerFault.exe
STACK_TEXT:
ffffbc04`6d72bda8 fffff802`2306d391     : 00000000`0000001e ffffffff`c0000005 fffff802`2114bb51 00000000`00000000 : nt!KeBugCheckEx
ffffbc04`6d72bdb0 fffff802`2303027c     : fffff802`20778180 00000000`00000000 00000000`00000000 ffffc405`a4445970 : nt!KiDispatchException+0x267681
ffffbc04`6d72c490 fffff802`2302b0d8     : ffffbc04`6d72c849 fffff802`23023b46 00000000`00000000 00000000`00000000 : nt!KiExceptionDispatch+0x13c
ffffbc04`6d72c670 fffff802`2114bb51     : ffffc405`85b99e30 fffff802`22e4a464 00000000`00000000 ffffc405`a71b59c0 : nt!KiGeneralProtectionFault+0x358
ffffbc04`6d72c800 fffff802`2118319f     : ffffc405`8599a0c0 ffffc405`00000000 ffffc405`85b99e30 ffffc405`8599a0c0 : FLTMGR!TreeUnlinkMulti+0x31
ffffbc04`6d72c850 fffff802`21149a95     : 00000000`00000000 ffffc405`a0859c60 ffffc405`00004000 00000000`00000000 : FLTMGR!FltpRemoveAllNamesCachedForFileObject+0x15f
ffffbc04`6d72c8d0 fffff802`211490c1     : ffffbc04`6d72caf0 ffffc405`85776a02 ffffc405`00000000 00000000`00000000 : FLTMGR!FltpPerformPreCallbacksWorker+0x7d5
ffffbc04`6d72c9e0 fffff802`21148049     : ffffbc04`6d72e000 ffffbc04`6d727000 ffffc405`a288dab0 ffffbc04`6d72cb00 : FLTMGR!FltpPassThroughInternal+0xd1
ffffbc04`6d72ca30 fffff802`21147e2b     : ffffffff`fffe7960 00000000`00000000 ffffc405`a0859c30 ffffc405`85905b50 : FLTMGR!FltpPassThrough+0x179
ffffbc04`6d72cad0 fffff802`22e49b05     : ffffc405`a0859c60 fffff802`22e48298 ffffc405`a18c10c0 fffff802`232ae1ce : FLTMGR!FltpDispatch+0x8b
ffffbc04`6d72cb30 fffff802`232ae3cc     : ffffc405`a0859c60 ffffc405`a288dab0 00000000`00000000 ffffc405`a18c10c0 : nt!IofCallDriver+0x55
ffffbc04`6d72cb70 fffff802`232baa3e     : ffffc405`81f88d20 ffffc405`a0859c60 ffffc405`a0859c30 ffff800a`12925800 : nt!IopDeleteFile+0x13c
ffffbc04`6d72cbf0 fffff802`22e4a237     : 00000000`00000000 00000000`00000000 ffff800a`12925800 ffffc405`a0859c60 : nt!ObpRemoveObjectRoutine+0x7e
ffffbc04`6d72cc50 fffff802`232fc16d     : 00000000`ffff8001 00000000`00000001 00000000`00007fff 00000000`00000000 : nt!ObfDereferenceObjectWithTag+0xc7
ffffbc04`6d72cc90 fffff802`232fbfd8     : ffffc405`a4445280 fffff802`22e57991 ffff800a`45ed19b0 00000000`00004140 : nt!ObCloseHandleTableEntry+0x109
ffffbc04`6d72cd50 fffff802`23341895     : 00000000`00000000 00000000`00000001 ffffffff`ffffff01 ffffc405`a18c10c0 : nt!ExSweepHandleTable+0xd8
ffffbc04`6d72ce00 fffff802`233411bd     : ffffffff`ffffffff ffffc405`a18c10c0 ffffffff`ffffffff fffff802`2335432c : nt!ObKillProcess+0x35
ffffbc04`6d72ce30 fffff802`232fdb92     : ffffc405`a18c10c0 ffff8009`fe5692a0 ffffbc04`6d72d059 00000000`00000000 : nt!PspRundownSingleProcess+0xb9
ffffbc04`6d72cec0 fffff802`233d7bd8     : 00000000`c0000409 00000000`00000001 ffffc405`a44452f4 0000005f`00220000 : nt!PspExitThread+0x64e
ffffbc04`6d72cfc0 fffff802`22e054dd     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSchedulerApcTerminate+0x38
ffffbc04`6d72d000 fffff802`23020680     : ffffbc04`6d72d301 ffffbc04`6d72d0c0 00000000`00000000 0000005f`001eedd0 : nt!KiDeliverApc+0x47d
ffffbc04`6d72d0c0 fffff802`230307af     : ffffc405`a439d710 fffff802`2386ac40 00000000`00000000 ffffbc04`6d72d250 : nt!KiInitiateUserApc+0x70
ffffbc04`6d72d200 fffff802`2302e3db     : ffffc405`a4445280 ffffc405`a4445280 00000000`00000000 ffffc405`00000000 : nt!KiFastFailDispatch+0x16f
ffffbc04`6d72d3e0 00007ffd`f59ff0bf     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiRaiseSecurityCheckFailure+0x35b
0000005f`001ee178 00000000`00000000     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ffd`f59ff0bf
SYMBOL_NAME:  FLTMGR!TreeUnlinkMulti+31
MODULE_NAME: FLTMGR
IMAGE_NAME:  FLTMGR.SYS
IMAGE_VERSION:  10.0.22621.3952
BUCKET_ID_FUNC_OFFSET:  31
FAILURE_BUCKET_ID:  AV_R_FLTMGR!TreeUnlinkMulti
OSNAME:  Windows 10
FAILURE_ID_HASH:  {f8f4c51b-319a-41f7-d0f6-f61760289098}
    PnpActivityTime    : 133630020765422504
    PnpProblemCode     : 24
    PnpVetoType        : 0
    VetoString         :
[DMI Version - 0]
  Vendor                        LENOVO
       07: - PCI Supported
       19: - EDD Supported
  Manufacturer                  LENOVO
  Product Name                  82K1
  Manufacturer                  LENOVO
  Product                       LNVNB161216
  Asset Tag
       00: - Motherboard
       03: - Replaceable
  Manufacturer                  LENOVO
  Serial Number
  Asset Tag Number
  Max Speed                     4400MHz
  Serial Number
  Asset Tag Number
  Core Count                    4
  Core Enabled                  4
  Thread Count                  8
       0x 3: Multi-Core
  Core Count 2                  4
  Core Enabled 2                4
  Thread Count 2                8
  Cache Speed                   0ns
  Cache Speed                   0ns
  Cache Speed                   0ns
  Associativity                 Other
  Cache Speed                   0ns
  Number of Strings             1
   1                            Modern Preload
  Size                          8192MB
  Bank Locator                  BANK 0
  Speed                         3200MHz
  Serial Number
  Asset Tag Number
  Attributes                    1
  Minimum Voltage               0
  Maximum Voltage               0
  Memory Technology             3
  Firmware Version              0
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
  Size                          8192MB
  Bank Locator                  BANK 0
  Speed                         3200MHz
  Serial Number
  Asset Tag Number
  Attributes                    1
  Minimum Voltage               0
  Maximum Voltage               0
  Memory Technology             3
  Firmware Version              0
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
ATTEMPTED_WRITE_TO_READONLY_MEMORY (be)
An attempt was made to write to readonly memory.  The guilty driver is on the
stack trace (and is typically the current instruction pointer).
When possible, the guilty driver's name (Unicode string) is printed on
the BugCheck screen and saved in KiBugCheckDriver.
Arguments:
Arg1: ffffb46a4f26e390, Virtual address for the attempted write.
Arg2: 810000010f54e021, PTE contents.
Arg3: fffffc8a1bed71b0, (reserved)
Arg4: 000000000000000b, (reserved)
Debugging Details:
    Value: 1202
    Value: 1904
    Value: 2
    Value: 0
    Value: 7
    Value: 437
    Value: 60570
    Value: 102
    Value: 0xbe
    Value: 0xbe
    Value: 1808
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: AV_win32kfull!NtUserSetCursorPos
    Key  : Failure.Hash
    Value: {e1ebd536-e38b-3aa4-2e0b-28d0e10c0c70}
    Value: 1417df84
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 0
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 21631230
    Value: 14a10fe
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 1015
    Value: 3f7
BUGCHECK_CODE:  be
BUGCHECK_P1: ffffb46a4f26e390
BUGCHECK_P2: 810000010f54e021
BUGCHECK_P3: fffffc8a1bed71b0
BUGCHECK_P4: b
FILE_IN_CAB:  061324-21468-01.dmp
BLACKBOXWINLOGON: 1
PROCESS_NAME:  VALORANT-Win64
TRAP_FRAME:  fffffc8a1bed71b0 -- (.trap 0xfffffc8a1bed71b0)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=ffffb46a4f13b970 rbx=0000000000000000 rcx=ffffb46a4f2bfcd0
rdx=0000000000000200 rsi=0000000000000000 rdi=0000000000000000
rip=ffffb46a4f13b9c5 rsp=fffffc8a1bed7340 rbp=fffffc8a1bed7460
 r8=000000000000020d  r9=000000000000020d r10=ffffb46a4f13b970
r11=0000000000000000 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0         nv up ei pl nz na pe nc
win32kfull!NtUserSetCursorPos+0x55:
ffffb46a`4f13b9c5 4c8d2dc4291300  lea     r13,[win32kfull!WPP_8c5e708b29aa3affec9993f25e4f3306_Traceguids (ffffb46a`4f26e390)]
Resetting default scope
STACK_TEXT:
fffffc8a`1bed6f88 fffff802`0967625b     : 00000000`000000be ffffb46a`4f26e390 81000001`0f54e021 fffffc8a`1bed71b0 : nt!KeBugCheckEx
fffffc8a`1bed6f90 fffff802`0944f9bc     : 00000000`00000000 00000000`00000003 00000000`00000000 ffffb46a`4f26e390 : nt!MiSystemFault+0x23ec5b
fffffc8a`1bed7090 fffff802`0962b47e     : 00000000`00000000 fffffc8a`1bed7248 00000000`49e0f7ca ffffb46a`4eec7ba0 : nt!MmAccessFault+0x29c
fffffc8a`1bed71b0 ffffb46a`4f13b9c5     : fffffc8a`1bed7460 ffff930d`00501802 00000000`00000f33 00000122`00501802 : nt!KiPageFault+0x37e
fffffc8a`1bed7340 ffffb46a`4f9349c6     : ffff8003`b70a1080 00000000`0000020d 00000000`0000020d 00000000`00000020 : win32kfull!NtUserSetCursorPos+0x55
fffffc8a`1bed73b0 fffff802`096300a4     : ffff8003`b70a1080 ffff8003`b52ce5e0 fffffc8a`00000000 ffff8003`00000000 : win32k!NtUserSetCursorPos+0x16
fffffc8a`1bed73e0 00007fff`ec71b9f4     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceExitPico+0x468
0000001f`0117e328 00000000`00000000     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007fff`ec71b9f4
SYMBOL_NAME:  win32kfull!NtUserSetCursorPos+55
MODULE_NAME: win32kfull
IMAGE_NAME:  win32kfull.sys
IMAGE_VERSION:  10.0.22621.3733
BUCKET_ID_FUNC_OFFSET:  55
FAILURE_BUCKET_ID:  AV_win32kfull!NtUserSetCursorPos
OSNAME:  Windows 10
FAILURE_ID_HASH:  {e1ebd536-e38b-3aa4-2e0b-28d0e10c0c70}
    PnpActivityTime    : 133627656529830385
    PnpProblemCode     : 24
    PnpVetoType        : 0
    VetoString         :
[DMI Version - 0]
  Vendor                        LENOVO
       07: - PCI Supported
       19: - EDD Supported
  Manufacturer                  LENOVO
  Product Name                  82K1
  Manufacturer                  LENOVO
  Product                       LNVNB161216
  Asset Tag
       00: - Motherboard
       03: - Replaceable
  Manufacturer                  LENOVO
  Serial Number
  Asset Tag Number
  Processor Voltage             8ah - 1.0V
  Max Speed                     4400MHz
  Current Speed                 4000MHz
  Serial Number
  Asset Tag Number
  Core Count                    4
  Core Enabled                  4
  Thread Count                  8
       0x 3: Multi-Core
  Core Count 2                  4
  Core Enabled 2                4
  Thread Count 2                8
  Cache Speed                   0ns
  Cache Speed                   0ns
  Cache Speed                   0ns
  Associativity                 Other
  Cache Speed                   0ns
  Number of Strings             1
   1                            Modern Preload
  Size                          8192MB
  Bank Locator                  BANK 0
  Speed                         3200MHz
  Serial Number
  Asset Tag Number
  Attributes                    1
  Minimum Voltage               0
  Maximum Voltage               0
  Memory Technology             3
  Firmware Version              0
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
  Size                          8192MB
  Bank Locator                  BANK 0
  Speed                         3200MHz
  Serial Number
  Asset Tag Number
  Attributes                    1
  Minimum Voltage               0
  Maximum Voltage               0
  Memory Technology             3
  Firmware Version              0
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
WIN32K_CRITICAL_FAILURE (164)
Win32k has encountered a critical failure.
Arguments:
Arg1: 0000000000000000, Type of the failure.
Debugging Details:
    Value: 1499
    Value: 12868
    Value: 0
    Value: 0
    Value: 0
    Value: 359
    Value: 4626
    Value: 104
    Value: 0x164
    Value: 0x164
    Value: 1808
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 0x164_0_win32kbase!IOCPDispatcher::SetupIOCPForDispatcherHandle
    Key  : Failure.Hash
    Value: {e246c09b-dc52-9baf-4627-2715610be5cc}
    Value: 1417df84
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 0
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 21631230
    Value: 14a10fe
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 1015
    Value: 3f7
BUGCHECK_CODE:  164
BUGCHECK_P1: 0
BUGCHECK_P2: 0
BUGCHECK_P3: 0
BUGCHECK_P4: 0
FILE_IN_CAB:  061324-21765-01.dmp
BLACKBOXWINLOGON: 1
PROCESS_NAME:  dwm.exe
STACK_TEXT:
ffffd008`d51af188 ffffb9d7`efb42d5c     : ffffbe81`ac0c80a0 ffffbe81`ac0c8050 ffffd008`d51af319 ffffb9d7`efa54502 : nt!KeBugCheck
ffffd008`d51af190 ffffb9d7`efab8cd2     : 00000000`00000001 ffffd008`d51af319 ffffbe81`ac0c8050 ffffbe81`ac0c8050 : win32kbase!IOCPDispatcher::SetupIOCPForDispatcherHandle+0x8a03c
ffffd008`d51af1e0 ffffb9d7`efa55fb5     : 00000000`00000000 00000000`00000000 00000000`00000000 ffffd008`d51af319 : win32kbase!IOCPDispatcher::HandleSensorDispatcherSignal+0x46
ffffd008`d51af240 ffffb9d7`efa55d60     : 00000000`00000001 00000000`00000001 00000000`00000000 00000000`00000000 : win32kbase!IOCPDispatcher::Dispatch+0x15
ffffd008`d51af2a0 ffffb9d7`efad2b21     : 00000000`00000000 000001cb`93c70590 00000000`00000020 00000000`00000002 : win32kbase!UserKSTWait+0x130
ffffd008`d51af380 ffffb9d7`f05a0aea     : 00007ff8`a4f3ff08 00000000`00000001 0000003c`399ffc80 0000003c`399ffc01 : win32kbase!NtKSTWait+0x21
ffffd008`d51af3b0 fffff803`6e8300a4     : ffffd601`7f094080 00000000`00000308 00000000`0000030c 00000000`00000001 : win32k!NtKSTWait+0x16
ffffd008`d51af3e0 00007ff8`aac27ab4     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceExitPico+0x468
0000003c`399ffc68 00000000`00000000     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ff8`aac27ab4
SYMBOL_NAME:  win32kbase!IOCPDispatcher::SetupIOCPForDispatcherHandle+8a03c
MODULE_NAME: win32kbase
IMAGE_NAME:  win32kbase.sys
BUCKET_ID_FUNC_OFFSET:  8a03c
FAILURE_BUCKET_ID:  0x164_0_win32kbase!IOCPDispatcher::SetupIOCPForDispatcherHandle
OSNAME:  Windows 10
FAILURE_ID_HASH:  {e246c09b-dc52-9baf-4627-2715610be5cc}
    PnpActivityTime    : 133627645655729299
    PnpProblemCode     : 24
    PnpVetoType        : 0
    DeviceId           : SW\{97ebaacc-95bd-11d0-a3ea-00a0c9223196}\{53172480-4791-11D0-A5D6-28DB04C10000}
    VetoString         :
[DMI Version - 0]
  Vendor                        LENOVO
       07: - PCI Supported
       19: - EDD Supported
  Manufacturer                  LENOVO
  Product Name                  82K1
  Manufacturer                  LENOVO
  Product                       LNVNB161216
  Asset Tag
       00: - Motherboard
       03: - Replaceable
  Manufacturer                  LENOVO
  Serial Number
  Asset Tag Number
  Max Speed                     4400MHz
  Serial Number
  Asset Tag Number
  Core Count                    4
  Core Enabled                  4
  Thread Count                  8
       0x 3: Multi-Core
  Core Count 2                  4
  Core Enabled 2                4
  Thread Count 2                8
  Cache Speed                   0ns
  Cache Speed                   0ns
  Cache Speed                   0ns
  Associativity                 Other
  Cache Speed                   0ns
  Number of Strings             1
   1                            Modern Preload
  Size                          8192MB
  Bank Locator                  BANK 0
  Speed                         3200MHz
  Serial Number
  Asset Tag Number
  Attributes                    1
  Minimum Voltage               0
  Maximum Voltage               0
  Memory Technology             3
  Firmware Version              0
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
  Size                          8192MB
  Bank Locator                  BANK 0
  Speed                         3200MHz
  Serial Number
  Asset Tag Number
  Attributes                    1
  Minimum Voltage               0
  Maximum Voltage               0
  Memory Technology             3
  Firmware Version              0
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED (7e)
Arguments:
Arg2: fffff801c12f8796, The address that the exception occurred at
Arg3: ffffe38d1058eb68, Exception Record Address
Arg4: ffffe38d1058e380, Context Record Address
Debugging Details:
    Key  : AV.Dereference
    Value: NullPtr
    Key  : AV.Fault
    Value: Read
    Value: 1531
    Value: 3965
    Value: 0
    Value: 0
    Value: 3
    Value: 421
    Value: 17804
    Value: 105
    Value: 0x1000007e
    Value: 0x1000007e
    Value: 1808
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: AV_dxgmms2!VidSchSubmitPagingCommand
    Key  : Failure.Hash
    Value: {d7d7457b-fa7b-cb3c-d738-9f954b7fc090}
    Value: 1417df84
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 0
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 21631230
    Value: 14a10fe
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 1015
    Value: 3f7
BUGCHECK_CODE:  7e
BUGCHECK_P2: fffff801c12f8796
BUGCHECK_P3: ffffe38d1058eb68
BUGCHECK_P4: ffffe38d1058e380
FILE_IN_CAB:  061424-22531-01.dmp
EXCEPTION_RECORD:  ffffe38d1058eb68 -- (.exr 0xffffe38d1058eb68)
ExceptionAddress: fffff801c12f8796 (dxgmms2!VidSchSubmitPagingCommand+0x000000000000008e)
   ExceptionCode: c0000005 (Access violation)
  ExceptionFlags: 00000000
NumberParameters: 2
   Parameter[0]: 0000000000000000
   Parameter[1]: 0000000000000000
Attempt to read from address 0000000000000000
CONTEXT:  ffffe38d1058e380 -- (.cxr 0xffffe38d1058e380)
rax=ffffe58faa7f5350 rbx=ffffe38d1058ee30 rcx=0000000000000000
rdx=0000000000000002 rsi=ffffe58faa8ed8b0 rdi=ffffe58faa8ea000
rip=fffff801c12f8796 rsp=ffffe38d1058eda0 rbp=ffffe38d1058eea1
 r8=ffffe58fa7ffcbc0  r9=7ffffffffffffffc r10=fffff8017284bfb0
r11=0000000000000000 r12=00000000000001de r13=ffffe58faa971478
iopl=0         nv up ei pl zr na po nc
cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00050246
dxgmms2!VidSchSubmitPagingCommand+0x8e:
fffff801`c12f8796 da01            fiadd   dword ptr [rcx] ds:002b:00000000`00000000=????????
BLACKBOXWINLOGON: 1
PROCESS_NAME:  System
READ_ADDRESS: fffff8017331c4a8: Unable to get MiVisibleState
 0000000000000000
ERROR_CODE: (NTSTATUS) 0xc0000005 - 0x%p adresindeki y nerge 0x%p adresindeki belle e ba vurdu. Bellek  u olamaz %s.
EXCEPTION_CODE_STR:  c0000005
EXCEPTION_PARAMETER2:  0000000000000000
EXCEPTION_STR:  0xc0000005
STACK_TEXT:
ffffe38d`1058eda0 fffff801`c12b7d93     : 00000000`00000878 00000000`00000000 ffffe58f`aa971000 00000000`00000000 : dxgmms2!VidSchSubmitPagingCommand+0x8e
ffffe38d`1058edd0 fffff801`c12d9424     : 00000000`0000025e ffffe38d`00000000 ffffe58f`aa971000 00000000`00000000 : dxgmms2!VIDMM_GLOBAL::FlushPagingBufferInternal+0x3a4e3
ffffe38d`1058eef0 fffff801`c12c23da     : ffffe58f`aa971000 ffffbe01`f2580180 ffffe38d`1058f2e8 ffffe58f`aa8e7600 : dxgmms2!VIDMM_GLOBAL::UpdateGpuVirtualAddressSystemCommand+0xaa0
ffffe38d`1058f050 fffff801`c12a8a4a     : ffffd20e`7989b100 ffffe58f`9ed45e60 ffffe58f`9ed45e68 ffffd20e`b3dd6b80 : dxgmms2!VIDMM_GLOBAL::ProcessDeferredCommand+0x2f09a
ffffe38d`1058f260 fffff801`c12a8209     : ffffd20e`7989b100 fffff801`7334c701 fffff801`7334c700 fffff801`00000000 : dxgmms2!VIDMM_WORKER_THREAD::Run+0x82a
ffffe38d`1058f4c0 fffff801`7280e957     : ffffe58f`aa8e7540 fffff801`c12a8200 ffffd20e`7989b100 005fe47f`b19bbfff : dxgmms2!VidMmWorkerThreadProc+0x9
ffffe38d`1058f4f0 fffff801`72a1f3b4     : fffff801`6d4a8180 ffffe58f`aa8e7540 fffff801`7280e900 4d15ff48`c933d233 : nt!PspSystemThreadStartup+0x57
ffffe38d`1058f540 00000000`00000000     : ffffe38d`10590000 ffffe38d`10589000 00000000`00000000 00000000`00000000 : nt!KiStartSystemThread+0x34
SYMBOL_NAME:  dxgmms2!VidSchSubmitPagingCommand+8e
MODULE_NAME: dxgmms2
IMAGE_NAME:  dxgmms2.sys
IMAGE_VERSION:  10.0.22621.3790
STACK_COMMAND:  .cxr 0xffffe38d1058e380 ; kb
BUCKET_ID_FUNC_OFFSET:  8e
FAILURE_BUCKET_ID:  AV_dxgmms2!VidSchSubmitPagingCommand
OSNAME:  Windows 10
FAILURE_ID_HASH:  {d7d7457b-fa7b-cb3c-d738-9f954b7fc090}
    PnpActivityTime    : 133628376488394835
    PnpProblemCode     : 24
    PnpVetoType        : 0
    DeviceId           : USB\VID_03F0&PID_2B41\5&d58ed73&0&1
    VetoString         :
[DMI Version - 0]
  Vendor                        LENOVO
       07: - PCI Supported
       19: - EDD Supported
  Manufacturer                  LENOVO
  Product Name                  82K1
  Manufacturer                  LENOVO
  Product                       LNVNB161216
  Asset Tag
       00: - Motherboard
       03: - Replaceable
  Manufacturer                  LENOVO
  Serial Number
  Asset Tag Number
  Max Speed                     4400MHz
  Serial Number
  Asset Tag Number
  Core Count                    4
  Core Enabled                  4
  Thread Count                  8
       0x 3: Multi-Core
  Core Count 2                  4
  Core Enabled 2                4
  Thread Count 2                8
  Cache Speed                   0ns
  Cache Speed                   0ns
  Cache Speed                   0ns
  Associativity                 Other
  Cache Speed                   0ns
  Number of Strings             1
   1                            Modern Preload
  Size                          8192MB
  Bank Locator                  BANK 0
  Speed                         3200MHz
  Serial Number
  Asset Tag Number
  Attributes                    1
  Minimum Voltage               0
  Maximum Voltage               0
  Memory Technology             3
  Firmware Version              0
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
  Size                          8192MB
  Bank Locator                  BANK 0
  Speed                         3200MHz
  Serial Number
  Asset Tag Number
  Attributes                    1
  Minimum Voltage               0
  Maximum Voltage               0
  Memory Technology             3
  Firmware Version              0
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
Lenovo IdeaPad Gaming 3 laptoplarda kronik bu sıkıntı herhalde Ryzen 7 4800H GTX 1650 Ti olan modeli var kaç defa mavi ekran hatası aldım SSD değiştim hata vermeye devam ediyor.
Kod:
Arguments:
Debugging Details:
    Value: 1656
    Value: 1711
    Value: 0
    Value: 0
    Value: 0
    Value: 343
    Value: 4636
    Value: 89
    Value: 0xef
    Value: 0xef
    Value: ec2c3040
    Value: unknown
    Value: 7ffcb5c16d43
    Value: 0
    Value: 0
    Value: services.exe
    Value: unknown!
    Value: 1808
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Key  : Failure.Hash
    Value: 1417df84
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 0
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 21631230
    Value: 14a10fe
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 1015
    Value: 3f7
BUGCHECK_CODE:  ef
BUGCHECK_P2: 0
BUGCHECK_P4: 0
IMAGE_NAME:  unknown
BLACKBOXWINLOGON: 1
STACK_TEXT:
OSNAME:  Windows 10
    PnpProblemCode     : 24
    PnpVetoType        : 0
    VetoString         :
[DMI Version - 0]
  Vendor                        LENOVO
       07: - PCI Supported
       19: - EDD Supported
  Manufacturer                  LENOVO
  Product Name                  82K1
  Manufacturer                  LENOVO
  Product                       LNVNB161216
  Asset Tag
       00: - Motherboard
       03: - Replaceable
  Manufacturer                  LENOVO
  Serial Number
  Asset Tag Number
  Max Speed                     4400MHz
  Serial Number
  Asset Tag Number
  Core Count                    4
  Core Enabled                  4
  Thread Count                  8
       0x 3: Multi-Core
  Core Count 2                  4
  Core Enabled 2                4
  Thread Count 2                8
  Cache Speed                   0ns
  Cache Speed                   0ns
  Cache Speed                   0ns
  Associativity                 Other
  Cache Speed                   0ns
  Number of Strings             1
   1                            Modern Preload
  Size                          8192MB
  Bank Locator                  BANK 0
  Speed                         3200MHz
  Serial Number
  Asset Tag Number
  Attributes                    1
  Minimum Voltage               0
  Maximum Voltage               0
  Memory Technology             3
  Firmware Version              0
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
  Size                          8192MB
  Bank Locator                  BANK 0
  Speed                         3200MHz
  Serial Number
  Asset Tag Number
  Attributes                    1
  Minimum Voltage               0
  Maximum Voltage               0
  Memory Technology             3
  Firmware Version              0
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
Arguments:
Debugging Details:
***    work.                                                          ***
***    work.                                                          ***
    Value: 1499
    Value: 8766
    Value: 0
    Value: 0
    Value: 1
    Value: 312
    Value: 8583
    Value: 92
    Value: 0x1e
    Value: 0x1e
    Value: 1808
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Key  : Failure.Hash
    Value: 1417df84
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 0
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 21631230
    Value: 14a10fe
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 1015
    Value: 3f7
BUGCHECK_CODE:  1e
BUGCHECK_P3: 0
 ffffffffffffffff
BLACKBOXWINLOGON: 1
STACK_TEXT:
MODULE_NAME: FLTMGR
OSNAME:  Windows 10
    PnpProblemCode     : 24
    PnpVetoType        : 0
    VetoString         :
[DMI Version - 0]
  Vendor                        LENOVO
       07: - PCI Supported
       19: - EDD Supported
  Manufacturer                  LENOVO
  Product Name                  82K1
  Manufacturer                  LENOVO
  Product                       LNVNB161216
  Asset Tag
       00: - Motherboard
       03: - Replaceable
  Manufacturer                  LENOVO
  Serial Number
  Asset Tag Number
  Max Speed                     4400MHz
  Serial Number
  Asset Tag Number
  Core Count                    4
  Core Enabled                  4
  Thread Count                  8
       0x 3: Multi-Core
  Core Count 2                  4
  Core Enabled 2                4
  Thread Count 2                8
  Cache Speed                   0ns
  Cache Speed                   0ns
  Cache Speed                   0ns
  Associativity                 Other
  Cache Speed                   0ns
  Number of Strings             1
   1                            Modern Preload
  Size                          8192MB
  Bank Locator                  BANK 0
  Speed                         3200MHz
  Serial Number
  Asset Tag Number
  Attributes                    1
  Minimum Voltage               0
  Maximum Voltage               0
  Memory Technology             3
  Firmware Version              0
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
  Size                          8192MB
  Bank Locator                  BANK 0
  Speed                         3200MHz
  Serial Number
  Asset Tag Number
  Attributes                    1
  Minimum Voltage               0
  Maximum Voltage               0
  Memory Technology             3
  Firmware Version              0
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
Arguments:
Debugging Details:
    Value: 1202
    Value: 1904
    Value: 2
    Value: 0
    Value: 7
    Value: 437
    Value: 60570
    Value: 102
    Value: 0xbe
    Value: 0xbe
    Value: 1808
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Key  : Failure.Hash
    Value: 1417df84
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 0
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 21631230
    Value: 14a10fe
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 1015
    Value: 3f7
BUGCHECK_CODE:  be
BUGCHECK_P4: b
BLACKBOXWINLOGON: 1
STACK_TEXT:
OSNAME:  Windows 10
    PnpProblemCode     : 24
    PnpVetoType        : 0
    VetoString         :
[DMI Version - 0]
  Vendor                        LENOVO
       07: - PCI Supported
       19: - EDD Supported
  Manufacturer                  LENOVO
  Product Name                  82K1
  Manufacturer                  LENOVO
  Product                       LNVNB161216
  Asset Tag
       00: - Motherboard
       03: - Replaceable
  Manufacturer                  LENOVO
  Serial Number
  Asset Tag Number
  Max Speed                     4400MHz
  Serial Number
  Asset Tag Number
  Core Count                    4
  Core Enabled                  4
  Thread Count                  8
       0x 3: Multi-Core
  Core Count 2                  4
  Core Enabled 2                4
  Thread Count 2                8
  Cache Speed                   0ns
  Cache Speed                   0ns
  Cache Speed                   0ns
  Associativity                 Other
  Cache Speed                   0ns
  Number of Strings             1
   1                            Modern Preload
  Size                          8192MB
  Bank Locator                  BANK 0
  Speed                         3200MHz
  Serial Number
  Asset Tag Number
  Attributes                    1
  Minimum Voltage               0
  Maximum Voltage               0
  Memory Technology             3
  Firmware Version              0
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
  Size                          8192MB
  Bank Locator                  BANK 0
  Speed                         3200MHz
  Serial Number
  Asset Tag Number
  Attributes                    1
  Minimum Voltage               0
  Maximum Voltage               0
  Memory Technology             3
  Firmware Version              0
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
Arguments:
Debugging Details:
    Value: 1499
    Value: 12868
    Value: 0
    Value: 0
    Value: 0
    Value: 359
    Value: 4626
    Value: 104
    Value: 0x164
    Value: 0x164
    Value: 1808
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Key  : Failure.Hash
    Value: 1417df84
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 0
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 21631230
    Value: 14a10fe
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 1015
    Value: 3f7
BUGCHECK_CODE:  164
BUGCHECK_P1: 0
BUGCHECK_P2: 0
BUGCHECK_P3: 0
BUGCHECK_P4: 0
BLACKBOXWINLOGON: 1
STACK_TEXT:
OSNAME:  Windows 10
    PnpProblemCode     : 24
    PnpVetoType        : 0
    VetoString         :
[DMI Version - 0]
  Vendor                        LENOVO
       07: - PCI Supported
       19: - EDD Supported
  Manufacturer                  LENOVO
  Product Name                  82K1
  Manufacturer                  LENOVO
  Product                       LNVNB161216
  Asset Tag
       00: - Motherboard
       03: - Replaceable
  Manufacturer                  LENOVO
  Serial Number
  Asset Tag Number
  Max Speed                     4400MHz
  Serial Number
  Asset Tag Number
  Core Count                    4
  Core Enabled                  4
  Thread Count                  8
       0x 3: Multi-Core
  Core Count 2                  4
  Core Enabled 2                4
  Thread Count 2                8
  Cache Speed                   0ns
  Cache Speed                   0ns
  Cache Speed                   0ns
  Associativity                 Other
  Cache Speed                   0ns
  Number of Strings             1
   1                            Modern Preload
  Size                          8192MB
  Bank Locator                  BANK 0
  Speed                         3200MHz
  Serial Number
  Asset Tag Number
  Attributes                    1
  Minimum Voltage               0
  Maximum Voltage               0
  Memory Technology             3
  Firmware Version              0
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
  Size                          8192MB
  Bank Locator                  BANK 0
  Speed                         3200MHz
  Serial Number
  Asset Tag Number
  Attributes                    1
  Minimum Voltage               0
  Maximum Voltage               0
  Memory Technology             3
  Firmware Version              0
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
Arguments:
Debugging Details:
    Value: NullPtr
    Key  : AV.Fault
    Value: Read
    Value: 1531
    Value: 3965
    Value: 0
    Value: 0
    Value: 3
    Value: 421
    Value: 17804
    Value: 105
    Value: 0x1000007e
    Value: 0x1000007e
    Value: 1808
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Key  : Failure.Hash
    Value: 1417df84
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 0
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 21631230
    Value: 14a10fe
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 1015
    Value: 3f7
BUGCHECK_CODE:  7e
NumberParameters: 2
BLACKBOXWINLOGON: 1
 0000000000000000
STACK_TEXT:
OSNAME:  Windows 10
    PnpProblemCode     : 24
    PnpVetoType        : 0
    VetoString         :
[DMI Version - 0]
  Vendor                        LENOVO
       07: - PCI Supported
       19: - EDD Supported
  Manufacturer                  LENOVO
  Product Name                  82K1
  Manufacturer                  LENOVO
  Product                       LNVNB161216
  Asset Tag
       00: - Motherboard
       03: - Replaceable
  Manufacturer                  LENOVO
  Serial Number
  Asset Tag Number
  Max Speed                     4400MHz
  Serial Number
  Asset Tag Number
  Core Count                    4
  Core Enabled                  4
  Thread Count                  8
       0x 3: Multi-Core
  Core Count 2                  4
  Core Enabled 2                4
  Thread Count 2                8
  Cache Speed                   0ns
  Cache Speed                   0ns
  Cache Speed                   0ns
  Associativity                 Other
  Cache Speed                   0ns
  Number of Strings             1
   1                            Modern Preload
  Size                          8192MB
  Bank Locator                  BANK 0
  Speed                         3200MHz
  Serial Number
  Asset Tag Number
  Attributes                    1
  Minimum Voltage               0
  Maximum Voltage               0
  Memory Technology             3
  Firmware Version              0
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
  Size                          8192MB
  Bank Locator                  BANK 0
  Speed                         3200MHz
  Serial Number
  Asset Tag Number
  Attributes                    1
  Minimum Voltage               0
  Maximum Voltage               0
  Memory Technology             3
  Firmware Version              0
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
