EXPO açıkken bir bellek testi yapın. Sorun çıkarsa kapatıp bir daha yapın. Kapalı olunca da hata varsa RAM arızası. Kapalı olunca hata yoksa stabil olmayan RAM frekansı.
Kod:
MEMORY_MANAGEMENT (1a)
    # Any other values for parameter 1 must be individually examined.
Arguments:
Arg1: 0000000000000031, The subtype of the BugCheck.
Arg2: ffffe68f1c6ac010
Arg3: ffffa30035a38000
Arg4: ffff810101780fc3
Debugging Details:
KEY_VALUES_STRING: 1
    Key  : Analysis.CPU.mSec
    Value: 750
    Key  : Analysis.Elapsed.mSec
    Value: 790
    Key  : Analysis.IO.Other.Mb
    Value: 2
    Key  : Analysis.IO.Read.Mb
    Value: 1
    Key  : Analysis.IO.Write.Mb
    Value: 23
    Key  : Analysis.Init.CPU.mSec
    Value: 593
    Value: 13654
    Value: 82
    Value: 10.0.27829.1001
    Value: 10.2503.24.01 amd64fre
    Key  : Analysis.Version.Ext
    Value: 1.2503.24.1
    Value: 0x1a
    Value: 0x1a
    Value: 0x21008
    Value: 1
    Value: 0x0
    Value: 1
    Value: 0
    Key  : Failure.Bucket
    Value: 0x1a_31_nt!MiApplyCompressedFixups
    Key  : Failure.Hash
    Value: {c331f2d1-f573-4955-bed6-0e48314e3a31}
BUGCHECK_CODE:  1a
BUGCHECK_P1: 31
BUGCHECK_P2: ffffe68f1c6ac010
BUGCHECK_P3: ffffa30035a38000
BUGCHECK_P4: ffff810101780fc3
FILE_IN_CAB:  070525-12218-01.dmp
DUMP_FILE_ATTRIBUTES: 0x21008
  Kernel Generated Triage Dump
FAULTING_THREAD:  ffffe68f2dd0d080
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  powershell.exe
STACK_TEXT:
ffffcb84`78b1e798 fffff804`99f3c04d     : 00000000`0000001a 00000000`00000031 ffffe68f`1c6ac010 ffffa300`35a38000 : nt!KeBugCheckEx
ffffcb84`78b1e7a0 fffff804`99f3bc5f     : ffff8101`0177ffbe 00000000`00503000 00000000`00000503 00000000`00000000 : nt!MiApplyCompressedFixups+0xed
ffffcb84`78b1e800 fffff804`99f3b966     : 00000000`00000000 ffffe68f`1c6ac010 00000000`00000001 ffff8101`01766018 : nt!MiPerformFixups+0xfb
ffffcb84`78b1e8c0 fffff804`99a0c559     : ffffe68f`1c6ac010 00000000`0000002c ffffe68f`2ae10120 ffffe68f`2ae10010 : nt!MiRelocateImagePfn+0x146
ffffcb84`78b1e930 fffff804`999a536e     : ffffe68f`2ae10030 00000000`00000008 ffffe68f`00000000 ffffe68f`00000000 : nt!MiValidateInPage+0x2a9
ffffcb84`78b1e9f0 fffff804`999a487d     : ffffcb84`00000000 00000000`00000000 ffffcb84`78b1eba0 00000000`00000000 : nt!MiWaitForInPageComplete+0x2d6
ffffcb84`78b1eaf0 fffff804`998ae532     : ffff8000`00000000 00000000`64c531c0 00000000`c0033333 00000000`00000000 : nt!MiIssueHardFault+0x2ad
ffffcb84`78b1ebf0 fffff804`99cb3dcb     : 00000000`00000004 00000000`00000002 00000000`00000000 fffff804`998787e8 : nt!MmAccessFault+0x402
ffffcb84`78b1ed60 fffff804`99cb9b0f     : fffff804`99fcdc1e 00000000`00000000 00000000`00000011 ffffcb84`78b1f4e0 : nt!KiPageFault+0x38b
ffffcb84`78b1eef8 fffff804`99fcdc1e     : 00000000`00000000 00000000`00000011 ffffcb84`78b1f4e0 ffffe68f`2c77a1a0 : nt!memcpy+0xf
ffffcb84`78b1ef00 fffff804`99fcd40f     : 00000000`00000310 ffffe68f`00000010 ffffe68f`096d1ef0 00000000`00000001 : nt!MiCopyVirtualMemory+0x34e
ffffcb84`78b1f320 fffff804`99fcd233     : ffffe68f`2dd0d080 00000000`64c531c0 00000000`006da17c 00000000`0069d9d8 : nt!MiReadWriteVirtualMemory+0x1cf
ffffcb84`78b1f3a0 fffff804`99cb8258     : 00000000`00000000 00000000`006da0f8 ffffcb84`78b1f4e0 00000000`006da1cd : nt!NtReadVirtualMemory+0x23
ffffcb84`78b1f3f0 00007ffe`3d8c25b4     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x28
00000000`0069d9b8 00000000`00000000     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ffe`3d8c25b4
SYMBOL_NAME:  nt!MiApplyCompressedFixups+ed
MODULE_NAME: nt
IMAGE_VERSION:  10.0.26100.4484
STACK_COMMAND: .process /r /p 0xffffe68f2dd0c080; .thread 0xffffe68f2dd0d080 ; kb
IMAGE_NAME:  ntkrnlmp.exe
BUCKET_ID_FUNC_OFFSET:  ed
FAILURE_BUCKET_ID:  0x1a_31_nt!MiApplyCompressedFixups
OSPLATFORM_TYPE:  x64
OSNAME:  Windows 10
FAILURE_ID_HASH:  {c331f2d1-f573-4955-bed6-0e48314e3a31}
Followup:     MachineOwner
[SMBIOS Data Tables v3.6]
[DMI Version - 0]
[2.0 Calling Convention - No]
[Table Size - 3618 bytes]
  Vendor                        American Megatrends Inc.
  BIOS Version                  3265
  BIOS Release Date             06/11/2025
  BIOS ROM Size                 1000000
  BIOS Characteristics
       07: - PCI Supported
       11: - Upgradeable FLASH BIOS
       15: - CD-Boot Supported
       17: - BIOS ROM Socketed
       19: - EDD Supported
       22: - 360KB Floppy Supported
       23: - 1.2MB Floppy Supported
       24: - 720KB Floppy Supported
       25: - 2.88MB Floppy Supported
       32: - BIOS Vendor Reserved
       00: - ACPI Supported
       01: - USB Legacy Supported
  BIOS Major Revision           32
  BIOS Minor Revision           65
  EC Firmware Major Revision    255
  EC Firmware Minor Revision    255
  Extended BIOS ROM Size        32 MB
  Manufacturer                  ASUS
  Product Name                  System Product Name
  Version                       System Version
  Serial Number                 System Serial Number
  SKUNumber                     SKU
  Family                        To be filled by O.E.M.
  Manufacturer                  ASUSTeK COMPUTER INC.
  Product                       PRIME X670E-PRO WIFI
  Version                       Rev 1.xx
  Serial Number                 220910660000124
  Asset Tag
       00: - Motherboard
       03: - Replaceable
  Location                      Default string
  Manufacturer                  Default string
  Chassis Type                  Desktop
  Version                       Default string
  Serial Number
  Asset Tag Number
  Contained Element Size        3
[Onboard Devices Information (Type 10) - Length 6 - Handle 0004h]
Note: The On Board Device Information (Type 10) struct is obsolete as of SMBIOs spec v2.6  Number of Devices             1
  01: Type                      Video [enabled]
  01: Description                  To Be Filled By O.E.M.
[OEM Strings (Type 11) - Length 5 - Handle 0005h]
  Number of Strings             6
   1                            Default string
   2                            Default string
   3                            AEGO
   4                            Default string
   5                            Default string
   6                            Default string
[System Configuration Options (Type 12) - Length 5 - Handle 0006h]
[ (Type 256) - Length 59 - Handle 0009h]
[ (Type 256) - Length 9 - Handle 000ah]
[ (Type 256) - Length 31 - Handle 000bh]
[ (Type 256) - Length 26 - Handle 000ch]
[Cache Information (Type 7) - Length 27 - Handle 000dh]
  Socket Designation            L1 - Cache
  Maximum Cache Size            0200h - 512K
  Installed Size                0200h - 512K
  Supported SRAM Type           0010h - Pipeline-Burst
  Current SRAM Type             0010h - Pipeline-Burst
  Cache Speed                   1ns
  Maximum Cache Size 2          200 - 00000512l Kb
  Installed Cache Size 2        200 - 00000512l Kb
[Cache Information (Type 7) - Length 27 - Handle 000eh]
  Socket Designation            L2 - Cache
  Maximum Cache Size            2000h - 8192K
  Installed Size                2000h - 8192K
  Cache Speed                   1ns
  Maximum Cache Size 2          2000 - 00008192l Kb
  Installed Cache Size 2        2000 - 00008192l Kb
[Cache Information (Type 7) - Length 27 - Handle 000fh]
  Socket Designation            L3 - Cache
  Maximum Cache Size            8600h - 98304K
  Installed Size                8600h - 98304K
  Cache Speed                   1ns
  Associativity                 16-way Set-Associative
  Maximum Cache Size 2          80000600 - 00098304l Kb
  Installed Cache Size 2        80000600 - 00098304l Kb
[Processor Information (Type 4) - Length 48 - Handle 0010h]
  Socket Designation            AM5
  Processor Family              6bh - AMD Zen Processor Family
  Processor Manufacturer        Advanced Micro Devices, Inc.
  Processor ID                   120fa600fffb8b17
  Processor Version             AMD Ryzen 7 7800X3D 8-Core Processor
  Processor Voltage             8dh - 1.3V
  Max Speed                     5050MHz
  Current Speed                 4200MHz
  Processor Upgrade             Specification Reserved
  L1 Cache Handle               000dh
  L2 Cache Handle               000eh
  L3 Cache Handle               000fh
  Serial Number
  Asset Tag Number
  Part Number                   Unknown
  Core Count                    8
  Core Enabled                  8
  Thread Count                  16
  Processor Characteristics     fc
  Enabled Characteristics:
       0x 2: 64-bit Capable
       0x 3: Multi-Core
       0x 4: Hardware Thread
       0x 5: Execute Protection
       0x 6: Enhanced Virtualization
  Processor Family 2            006bh - AMD Zen Processor Family
  Core Count 2                  8
  Core Enabled 2                8
  Thread Count 2                16
[ (Type 256) - Length 9 - Handle 0011h]
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 0012h]
[Physical Memory Array (Type 16) - Length 23 - Handle 0013h]
  Maximum Capacity              268435456KB
  Memory Error Inf Handle       0012h
  Number of Memory Devices      4
[Memory Array Mapped Address (Type 19) - Length 31 - Handle 0014h]
  Ending Address                01ffffffh
  Memory Array Handle           0013h
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 0015h]
[Memory Device (Type 17) - Length 92 - Handle 0016h]
  Memory Error Info Handle      0015h
  Total Width                   [Unknown]
  Data Width                    [Unknown]
  Size                          [Not Populated]
  Form Factor                   02h - Unknown
  Device Locator                DIMM 0
  Bank Locator                  P0 CHANNEL A
  Memory Type                   02h - Unknown
  Type Detail                   0004h - Unknown
  Speed                         0MHz
  Manufacturer                  Unknown
  Serial Number
  Asset Tag Number              [String Not Specified]
  Part Number                   Unknown
  Attributes                    0
  Configured Memory Speed       0
  Minimum Voltage               0
  Maximum Voltage               0
  Configured Voltage            0
  Memory Technology             2
  Memory Operating Mode Capability     4
  Firmware Version              6
  Module Manufacturer Id        0
  Module Product Id             0
  Memory Subsystem Controller Manufacturer Id  0
  Memory Subsystem Controller Product Id       0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
  Extended Configured Memory Speed     0
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 0017h]
[Memory Device (Type 17) - Length 92 - Handle 0018h]
  Memory Error Info Handle      0017h
  Size                          16384MB
  Form Factor                   09h - DIMM
  Device Locator                DIMM 1
  Memory Type                   22h - DDR5
  Type Detail                   4080h - Synchronous Unbuffered (Unregistered)
  Speed                         4800MHz
  Manufacturer                  G Skill Intl
  Serial Number
  Part Number                   F5-6000J3038F16G
  Attributes                    2
  Configured Memory Speed       6000
  Minimum Voltage               1100
  Maximum Voltage               1100
  Configured Voltage            1100
  Memory Technology             3
  Memory Operating Mode Capability     8
  Firmware Version              6
  Module Manufacturer Id        52484
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 0019h]
  Ending Address                00ffffffh
  Memory Device Handle          0018h
  Mem Array Mapped Adr Handle   0014h
  Interleave Position           [Unknown]
  Interleave Data Depth         [Unknown]
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 001ah]
[Memory Device (Type 17) - Length 92 - Handle 001bh]
  Memory Error Info Handle      001ah
  Bank Locator                  P0 CHANNEL B
  Speed                         0MHz
  Serial Number
  Part Number                   Unknown
  Attributes                    0
  Minimum Voltage               0
  Maximum Voltage               0
  Memory Technology             2
  Firmware Version              6
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 001ch]
[Memory Device (Type 17) - Length 92 - Handle 001dh]
  Memory Error Info Handle      001ch
  Size                          16384MB
  Speed                         4800MHz
  Serial Number
  Attributes                    2
  Memory Technology             3
  Firmware Version              6
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 001eh]
  Starting Address              01000000h
  Memory Device Handle          001dh
[ (Type 256) - Length 14 - Handle 001fh]
[ (Type 256) - Length 165 - Handle 0020h]
[ (Type 256) - Length 11 - Handle 0054h]
[ (Type 256) - Length 11 - Handle 0055h]
[ (Type 256) - Length 4 - Handle 0057h]
