Çözüldü MEMORY_MANAGEMENT hatası
  • Konuyu başlatan Konuyu başlatan Astronotarda
  • Mesaj Mesaj 19
  • Görüntüleme Görüntüleme 646
Aynı sorunu yaşadım, laptopumu hareket ettirince bu hatayı alıyordum. RAM'leri silgi ile silip yeniden taktım ve düzeldi, siz de deneyebilirsiniz.
RAM testi yaptın mı?
Kod:
MEMORY_MANAGEMENT (1a)
    # Any other values for parameter 1 must be individually examined.
Arguments:
Arg1: 0000000000041792, A corrupt PTE has been detected. Parameter 2 contains the address of
    the PTE. Parameters 3/4 contain the low/high parts of the PTE.
Arg2: ffff90005726b110
Arg3: 0002000000000000
Arg4: 0000000000000000
Debugging Details:
KEY_VALUES_STRING: 1
    Key  : Analysis.CPU.mSec
    Value: 1827
    Key  : Analysis.Elapsed.mSec
    Value: 10377
    Key  : Analysis.IO.Other.Mb
    Value: 5
    Key  : Analysis.IO.Read.Mb
    Value: 0
    Key  : Analysis.IO.Write.Mb
    Value: 31
    Key  : Analysis.Init.CPU.mSec
    Value: 656
    Value: 36144
    Value: 102
    Value: 0x1a
    Value: 0x1a
    Value: 8
    Value: 1
    Key  : Failure.Bucket
    Value: MEMORY_CORRUPTION_ONE_BIT
    Key  : Failure.Hash
    Value: {e3faf315-c3d0-81db-819a-6c43d23c63a7}
    Key  : MemoryManagement.PFN
    Value: 0
BUGCHECK_CODE:  1a
BUGCHECK_P1: 41792
BUGCHECK_P2: ffff90005726b110
BUGCHECK_P3: 2000000000000
BUGCHECK_P4: 0
FILE_IN_CAB:  050524-10031-01 - Kopya.dmp
DUMP_FILE_ATTRIBUTES: 0x8
  Kernel Generated Triage Dump
MEMORY_CORRUPTOR:  ONE_BIT
PROCESS_NAME:  chrome.exe
STACK_TEXT:
ffff908c`07cc6d08 fffff803`45ebad12     : 00000000`0000001a 00000000`00041792 ffff9000`5726b110 00020000`00000000 : nt!KeBugCheckEx
ffff908c`07cc6d10 fffff803`45cf3736     : ffff908c`07cc71e0 ffff9000`5726bff8 00000000`00000000 ffffe604`6a095740 : nt!MiDeleteVa+0x1a93f2
ffff908c`07cc6e00 fffff803`45cf3afa     : ffff908c`07cc71e0 ffffe604`6a095740 ffff9048`00000000 ffff908c`07cc7230 : nt!MiWalkPageTablesRecursively+0x266
ffff908c`07cc6e90 fffff803`45cf3afa     : ffff908c`07cc71e0 ffffe604`6a095740 ffff9048`00000000 ffff908c`07cc7240 : nt!MiWalkPageTablesRecursively+0x62a
ffff908c`07cc6f20 fffff803`45cf3afa     : ffff908c`07cc71e0 ffffe604`6a095740 ffff9048`00000000 ffff908c`07cc7250 : nt!MiWalkPageTablesRecursively+0x62a
ffff908c`07cc6fb0 fffff803`45cf33d1     : 00000000`00000000 ffffe604`6a095740 00000000`00000000 ffff908c`07cc7260 : nt!MiWalkPageTablesRecursively+0x62a
ffff908c`07cc7040 fffff803`45d11882     : ffff908c`07cc71e0 000000ae`00000001 00000000`00000002 ffff908c`00000000 : nt!MiWalkPageTables+0x371
ffff908c`07cc7140 fffff803`45d20e4e     : ffffe604`6a095590 ffffe604`6641e080 ffff908c`07cc74e0 ffffe604`6641e780 : nt!MiDeletePagablePteRange+0x3c2
ffff908c`07cc7450 fffff803`46188497     : 00000000`00000000 00000000`00000001 ffff908c`07cc7520 000000ae`4c800000 : nt!MiDeleteVirtualAddresses+0x4e
ffff908c`07cc74a0 fffff803`46173c66     : 000000ae`4d000000 ffffe604`64a16270 ffffe604`6a0950c0 00000000`00000000 : nt!MiDeleteVad+0x1b7
ffff908c`07cc7560 fffff803`46173111     : ffffe604`69bdbf20 ffffe604`69bdbf20 ffffe604`69bdbf20 ffffe604`6a0950c0 : nt!MiCleanVad+0x42
ffff908c`07cc7590 fffff803`460fd54d     : ffffffff`00000000 ffffffff`ffffffff 00000000`00000001 ffffe604`6a0950c0 : nt!MmCleanProcessAddressSpace+0x10d
ffff908c`07cc7610 fffff803`46176a72     : ffffe604`6a0950c0 ffffbe82`7c232860 ffff908c`07cc7839 00000000`00000000 : nt!PspRundownSingleProcess+0xc1
ffff908c`07cc76a0 fffff803`46139768     : 00000000`00000000 00000000`00000001 ffffe604`6641e0f4 000000ae`4377e000 : nt!PspExitThread+0x64e
ffff908c`07cc77a0 fffff803`45cbeb3d     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSchedulerApcTerminate+0x38
ffff908c`07cc77e0 fffff803`45e1e810     : 00000000`00000001 ffff908c`07cc78a0 00000000`00000000 ffffe604`6a0950c0 : nt!KiDeliverApc+0x47d
ffff908c`07cc78a0 fffff803`45e2d9df     : ffffe604`6641e080 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiInitiateUserApc+0x70
ffff908c`07cc79e0 00007ffd`5b00f3e4     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceExit+0x9f
000000ae`4b7ff718 00000000`00000000     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ffd`5b00f3e4
MODULE_NAME: hardware
IMAGE_NAME:  memory_corruption
STACK_COMMAND:  .cxr; .ecxr ; kb
FAILURE_BUCKET_ID:  MEMORY_CORRUPTION_ONE_BIT
OSPLATFORM_TYPE:  x64
OSNAME:  Windows 10
FAILURE_ID_HASH:  {e3faf315-c3d0-81db-819a-6c43d23c63a7}
Followup:     MachineOwner
Sistem özellikleri nedir? Bellekler kit mi?
Memtest ile 2-3 kez test ettim, sorun da çıkmadı. Ne olur ne olmaz garantiye de gittiler oradan da sorun çıkmadı. Özellikleri tam bilmiyorum RAM linkini atayım direkt. Galiba sorun taşınabilir diskimde, sağlığı %20 ve ne zaman onu taksam bu oluyor gibi. Tam emin değilim.
Sistem Özellikleri:
  • i5-10300H
  • GTX 1650
  • 32 GB RAM (16x2)
  • 250 GB M.2 SSD
  • 500 GB taşınabilir hard disk
RAM linki: https://www.hepsiburada.com/crucial-ntb-16gb-3200mhz-ddr4-ct16g4sfra32a-pm-HB000019CM9Y
Kullandığın depolama aygıtları ne var sistemde? Hata kodu var.
Ek olarak RAM'leri kit şeklinde değil tek tek Memtest86 ile test et.
Eksik sys dosyalarını onar;
