utkucetina
31 Temmuz 2024
  • Ekran Kartı: 4050
  • İşletim Sistemi: i5-12450H
  • RAM: 32 GB
Merhaba Arkadaşlar. Bilgisayarı alalı daha 4 gün oldu oyunlarda mavi ekran hatası alıyorum. Driver silme aracıyla ekran kartı driverlarımı silip güncel olanını kursam da sorunum düzelmedi. Son minidump dosyamın kodlarını sizle paylaşıyorum. Sizce problem nedir?
Diğer Minidump dosyaları: Minidump - Google Drive
[CODE title="Minidump"]
************* Preparing the environment for Debugger Extensions Gallery repositories **************
ExtensionRepository : Implicit
UseExperimentalFeatureForNugetShare : true
AllowNugetExeUpdate : true
NonInteractiveNuget : true
AllowNugetMSCredentialProviderInstall : true
AllowParallelInitializationOfLocalRepositories : true
EnableRedirectToV8JsProvider : false
-- Configuring repositories
----> Repository : LocalInstalled, Enabled: true
----> Repository : UserExtensions, Enabled: true
>>>>>>>>>>>> Preparing the environment for Debugger Extensions Gallery repositories completed, duration 0.000 seconds
************* Waiting for Debugger Extensions Gallery to Initialize **************
>>>>>>>>>>>> Waiting for Debugger Extensions Gallery to Initialize completed, duration 0.063 seconds
----> Repository : UserExtensions, Enabled: true, Packages count: 0
----> Repository : LocalInstalled, Enabled: true, Packages count: 41
Microsoft (R) Windows Debugger Version 10.0.27553.1004 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Users\cetin\OneDrive\Desktop\080124-12984-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
************* Path validation summary **************
Response Time (ms) Location
Deferred srv*
Symbol search path is: srv*
Executable search path is:
Windows 10 Kernel Version 22621 MP (12 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Edition build lab: 22621.1.amd64fre.ni_release.220506-1250
Kernel base = 0xfffff802`3b800000 PsLoadedModuleList = 0xfffff802`3c413510
Debug session time: Thu Aug 1 05:07:26.051 2024 (UTC + 3:00)
System Uptime: 0 days 4:09:15.938
Loading Kernel Symbols
Loading User Symbols
PEB is paged out (Peb.Ldr = 000000d4`08d3a018). Type ".hh dbgerr001" for details
Loading unloaded module list
For analysis of this file, run !analyze -v
nt!KeBugCheckEx:
fffff802`3bc15df0 48894c2408 mov qword ptr [rsp+8],rcx ss:fffff802`3fd379e0=0000000000000133
0: kd> !analyze -v
  • Bugcheck Analysis *
DPC_WATCHDOG_VIOLATION (133)
The DPC watchdog detected a prolonged run time at an IRQL of DISPATCH_LEVEL
or above.
Arguments:
Arg1: 0000000000000001, The system cumulatively spent an extended period of time at
DISPATCH_LEVEL or above.
Arg2: 0000000000001e00, The watchdog period (in ticks).
Arg3: fffff8023c51c340, cast to nt!DPC_WATCHDOG_GLOBAL_TRIAGE_BLOCK, which contains
additional information regarding the cumulative timeout
Arg4: 0000000000000000
Debugging Details:
  • Either you specified an unqualified symbol, or your debugger *
  • doesn't have full symbol information. Unqualified symbol *
  • resolution is turned off by default. Please either specify a *
  • fully qualified symbol module!symbolname, or enable resolution *
  • of unqualified symbols by typing ".symopt- 100". Note that *
  • enabling unqualified symbol resolution with network symbol *
  • server shares in the symbol path may cause the debugger to *
  • appear to hang for long periods of time when an incorrect *
  • symbol name is typed or the network symbol server is down. *
  • For some commands to work properly, your symbol path *
  • must point to .pdb files that have full type information. *
  • Certain .pdb files (such as the public OS symbols) do not *
  • contain the required information. Contact the group that *
  • provided you with these symbols if you need this command to *
  • work. *
  • Type referenced: TickPeriods *
KEY_VALUES_STRING: 1
Key : Analysis.CPU.mSec
Value: 1014
Key : Analysis.Elapsed.mSec
Value: 6327
Key : Analysis.IO.Other.Mb
Value: 0
Key : Analysis.IO.Read.Mb
Value: 0
Key : Analysis.IO.Write.Mb
Value: 0
Key : Analysis.Init.CPU.mSec
Value: 108
Value: 2791
Value: 98
Key : Bugcheck.Code.KiBugCheckData
Value: 0x133
Key : Bugcheck.Code.LegacyAPI
Value: 0x133
Key : Bugcheck.Code.TargetModel
Value: 0x133
Key : Failure.Bucket
Value: 0x133_ISR_nvlddmkm!unknown_function
Key : Failure.Hash
Value: {f97493a5-ea2b-23ca-a808-8602773c2a86}
Key : Hypervisor.Enlightenments.ValueHex
Value: 1417df84
Key : Hypervisor.Flags.AnyHypervisorPresent
Value: 1
Key : Hypervisor.Flags.ApicEnlightened
Value: 0
Key : Hypervisor.Flags.ApicVirtualizationAvailable
Value: 1
Key : Hypervisor.Flags.AsyncMemoryHint
Value: 0
Key : Hypervisor.Flags.CoreSchedulerRequested
Value: 0
Key : Hypervisor.Flags.CpuManager
Value: 1
Key : Hypervisor.Flags.DeprecateAutoEoi
Value: 1
Key : Hypervisor.Flags.DynamicCpuDisabled
Value: 1
Key : Hypervisor.Flags.Epf
Value: 0
Key : Hypervisor.Flags.ExtendedProcessorMasks
Value: 1
Key : Hypervisor.Flags.HardwareMbecAvailable
Value: 1
Key : Hypervisor.Flags.MaxBankNumber
Value: 0
Key : Hypervisor.Flags.MemoryZeroingControl
Value: 0
Key : Hypervisor.Flags.NoExtendedRangeFlush
Value: 0
Key : Hypervisor.Flags.NoNonArchCoreSharing
Value: 1
Key : Hypervisor.Flags.Phase0InitDone
Value: 1
Key : Hypervisor.Flags.PowerSchedulerQos
Value: 0
Key : Hypervisor.Flags.RootScheduler
Value: 0
Key : Hypervisor.Flags.SynicAvailable
Value: 1
Key : Hypervisor.Flags.UseQpcBias
Value: 0
Key : Hypervisor.Flags.Value
Value: 21631230
Key : Hypervisor.Flags.ValueHex
Value: 14a10fe
Key : Hypervisor.Flags.VpAssistPage
Value: 1
Key : Hypervisor.Flags.VsmAvailable
Value: 1
Key : Hypervisor.RootFlags.AccessStats
Value: 1
Key : Hypervisor.RootFlags.CrashdumpEnlightened
Value: 1
Key : Hypervisor.RootFlags.CreateVirtualProcessor
Value: 1
Key : Hypervisor.RootFlags.DisableHyperthreading
Value: 0
Key : Hypervisor.RootFlags.HostTimelineSync
Value: 1
Key : Hypervisor.RootFlags.HypervisorDebuggingEnabled
Value: 0
Key : Hypervisor.RootFlags.IsHyperV
Value: 1
Key : Hypervisor.RootFlags.LivedumpEnlightened
Value: 1
Key : Hypervisor.RootFlags.MapDeviceInterrupt
Value: 1
Key : Hypervisor.RootFlags.MceEnlightened
Value: 1
Key : Hypervisor.RootFlags.Nested
Value: 0
Key : Hypervisor.RootFlags.StartLogicalProcessor
Value: 1
Key : Hypervisor.RootFlags.Value
Value: 1015
Key : Hypervisor.RootFlags.ValueHex
Value: 3f7
Key : WER.OS.Branch
Value: ni_release
Key : WER.OS.Version
Value: 10.0.22621.1
BUGCHECK_CODE: 133
BUGCHECK_P1: 1
BUGCHECK_P2: 1e00
BUGCHECK_P3: fffff8023c51c340
BUGCHECK_P4: 0
FILE_IN_CAB: 080124-12984-01.dmp
TAG_NOT_DEFINED_202b: *** Unknown TAG in analysis list 202b
DPC_TIMEOUT_TYPE: DPC_QUEUE_EXECUTION_TIMEOUT_EXCEEDED
TRAP_FRAME: fffff8023fd2feb0 -- (.trap 0xfffff8023fd2feb0)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=0000000001000800 rbx=0000000000000000 rcx=0000000000042802
rdx=000000000010a008 rsi=0000000000000000 rdi=0000000000000000
rip=fffff80268bba8b4 rsp=fffff8023fd30040 rbp=ffff840932be4ca8
r8=fffff8023fd30088 r9=000000000010a008 r10=fffff80268af4e00
r11=0000000000000000 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei pl nz na pe nc
nvlddmkm+0xca8b4:
fffff802`68bba8b4 488b5c2430 mov rbx,qword ptr [rsp+30h] ss:fffff802`3fd30070=ffff840932be4000
Resetting default scope
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: cod22-cod.exe
STACK_TEXT:
fffff802`3fd379d8 fffff802`3bb2bf29 : 00000000`00000133 00000000`00000001 00000000`00001e00 fffff802`3c51c340 : nt!KeBugCheckEx
fffff802`3fd379e0 fffff802`3bb2b074 : 000021f7`e8119290 fffff802`3817e180 00000000`000e9afb 00000000`00000000 : nt!KeAccumulateTicks+0x239
fffff802`3fd37a40 fffff802`3bb2cd2f : 00000000`0000000c 00000000`00001388 00000000`000e9a00 00000000`0008b49b : nt!KiUpdateRunTime+0xf4
fffff802`3fd37c00 fffff802`3bb290e8 : 00000000`00000000 ffffa700`442f9800 fffff802`3817e180 00000000`00000000 : nt!KiUpdateTime+0x63f
fffff802`3fd37ea0 fffff802`3bb28a7a : fffff802`3c45ff60 ffffa700`442f9830 ffffa700`442f9830 00000000`00000000 : nt!KeClockInterruptNotify+0x228
fffff802`3fd37f40 fffff802`3ba44b7c : 00000022`d272224a fffff802`3c50d430 fffff802`3c50d4e0 00000000`ffffffff : nt!HalpTimerClockInterrupt+0x10a
fffff802`3fd37f70 fffff802`3bc17ffa : fffff802`3fd2ff30 fffff802`3c50d430 ffff8409`32be4ca8 00000000`00000000 : nt!KiCallInterruptServiceRoutine+0x9c
fffff802`3fd37fb0 fffff802`3bc188c7 : 00000000`0010a008 fffff802`68af4e00 ffffffff`ffffffff 00000000`00000001 : nt!KiInterruptSubDispatchNoLockNoEtw+0xfa
fffff802`3fd2feb0 fffff802`68bba8b4 : ffff8409`00000000 00000000`00000000 00000000`0010a008 00000000`00000000 : nt!KiInterruptDispatchNoLockNoEtw+0x37
fffff802`3fd30040 ffff8409`00000000 : 00000000`00000000 00000000`0010a008 00000000`00000000 00000000`0010a008 : nvlddmkm+0xca8b4
fffff802`3fd30048 00000000`00000000 : 00000000`0010a008 00000000`00000000 00000000`0010a008 fffff802`68beaaa9 : 0xffff8409`00000000
SYMBOL_NAME: nvlddmkm+ca8b4
MODULE_NAME: nvlddmkm
IMAGE_NAME: nvlddmkm.sys
STACK_COMMAND: .cxr; .ecxr ; kb
BUCKET_ID_FUNC_OFFSET: ca8b4
FAILURE_BUCKET_ID: 0x133_ISR_nvlddmkm!unknown_function
OS_VERSION: 10.0.22621.1
BUILDLAB_STR: ni_release
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {f97493a5-ea2b-23ca-a808-8602773c2a86}
Followup: MachineOwner
[/CODE]
Üçünde de ekran kartı sorunu. Muhtemel reballing gerekli ama sen doğrudan iade et bunu. Reballing yapılırsa 6 aya yine patlar.
Kod:
or above.
Arguments:
Arg3: fffff8056351c340, cast to nt!DPC_WATCHDOG_GLOBAL_TRIAGE_BLOCK, which contains
Debugging Details:
***    Either you specified an unqualified symbol, or your debugger   ***
***    doesn't have full symbol information.  Unqualified symbol      ***
***    resolution is turned off by default. Please either specify a   ***
***    fully qualified symbol module!symbolname, or enable resolution ***
***    of unqualified symbols by typing ".symopt- 100". Note that     ***
***    enabling unqualified symbol resolution with network symbol     ***
***    server shares in the symbol path may cause the debugger to     ***
***    appear to hang for long periods of time when an incorrect      ***
***    symbol name is typed or the network symbol server is down.     ***
***    For some commands to work properly, your symbol path           ***
***    must point to .pdb files that have full type information.      ***
***    Certain .pdb files (such as the public OS symbols) do not      ***
***    contain the required information.  Contact the group that      ***
***    provided you with these symbols if you need this command to    ***
***    work.                                                          ***
***    Type referenced: TickPeriods                                   ***
    Value: 1530
    Value: 4316
    Value: 0
    Value: 0
    Value: 0
    Value: 296
    Value: 1425
    Value: 88
    Value: 0x133
    Value: 0x133
    Key  : Failure.Hash
    Value: 1417df84
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 0
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 21631230
    Value: 14a10fe
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 1015
    Value: 3f7
    Key  : WER.OS.Branch
    Value: ni_release
    Value: 10.0.22621.1
BUGCHECK_CODE:  133
BUGCHECK_P1: 1
BUGCHECK_P2: 1e00
BUGCHECK_P3: fffff8056351c340
BUGCHECK_P4: 0
FILE_IN_CAB:  073124-14515-01.dmp
TRAP_FRAME:  fffff8056601fe60 -- (.trap 0xfffff8056601fe60)
rax=0000000001c438d0 rbx=0000000000000000 rcx=0000000000042d4a
rdx=000000000010b528 rsi=0000000000000000 rdi=0000000000000000
rip=fffff8058fcba8b4 rsp=fffff8056601fff0 rbp=ffff968a30720ca8
 r8=fffff80566020038  r9=000000000010b528 r10=fffff8058fbf4e00
nvlddmkm+0xca8b4:
fffff805`8fcba8b4 488b5c2430      mov     rbx,qword ptr [rsp+30h] ss:fffff805`66020020=ffff968a30720000
BLACKBOXWINLOGON: 1
PROCESS_NAME:  ReadyOrNot-Win64-Shipping.exe
STACK_TEXT:
fffff805`66027c78 fffff805`62b2bf29     : 00000000`00000133 00000000`00000001 00000000`00001e00 fffff805`6351c340 : nt!KeBugCheckEx
fffff805`66027c80 fffff805`62b2b074     : 00000297`893e8967 fffff805`5e465180 00000000`00011b49 00000000`00000000 : nt!KeAccumulateTicks+0x239
fffff805`66027ce0 fffff805`62b28f81     : 00000000`00000000 ffffd401`4a78e800 fffff805`5e465180 00000000`00000000 : nt!KiUpdateRunTime+0xf4
fffff805`66027ea0 fffff805`62b28a7a     : fffff805`6345fe58 ffffd401`4a78e830 ffffd401`4a78e830 00000000`00000002 : nt!KeClockInterruptNotify+0xc1
fffff805`66027f40 fffff805`62a44b7c     : 00000002`a36f4dc8 fffff805`6350d430 fffff805`6350d4e0 00000000`ffffffff : nt!HalpTimerClockInterrupt+0x10a
fffff805`66027f70 fffff805`62c17ffa     : fffff805`6601fee0 fffff805`6350d430 ffff968a`30720ca8 00000000`00000000 : nt!KiCallInterruptServiceRoutine+0x9c
fffff805`66027fb0 fffff805`62c188c7     : 00000000`00000000 00000000`00000000 fffff805`6601ff80 00000000`00000000 : nt!KiInterruptSubDispatchNoLockNoEtw+0xfa
fffff805`6601fe60 fffff805`8fcba8b4     : ffff968a`00000000 00000000`00000000 00000000`0010b528 00000000`00000000 : nt!KiInterruptDispatchNoLockNoEtw+0x37
fffff805`6601fff0 ffff968a`00000000     : 00000000`00000000 00000000`0010b528 00000000`00000000 00000000`0010b528 : nvlddmkm+0xca8b4
fffff805`6601fff8 00000000`00000000     : 00000000`0010b528 00000000`00000000 00000000`0010b528 fffff805`8fceaaa9 : 0xffff968a`00000000
OSNAME:  Windows 10
or above.
Arguments:
Debugging Details:
*** WARNING: Unable to verify timestamp for nvlddmkm.sys
***    work.                                                          ***
    Value: 1592
    Value: 5671
    Value: 0
    Value: 0
    Value: 0
    Value: 234
    Value: 612
    Value: 99
    Value: 0x133
    Value: 0x133
    Value: 0x133
    Key  : Failure.Hash
    Value: 1417df84
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 0
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 21631230
    Value: 14a10fe
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 1015
    Value: 3f7
    Key  : WER.OS.Branch
    Value: ni_release
    Value: 10.0.22621.1
BUGCHECK_CODE:  133
BUGCHECK_P1: 1
BUGCHECK_P2: 1e00
BUGCHECK_P4: 0
nvlddmkm+0xca8b4:
BLACKBOXWINLOGON: 1
STACK_TEXT:
OSNAME:  Windows 10
or above.
Arguments:
Arg3: fffff80556d1c340, cast to nt!DPC_WATCHDOG_GLOBAL_TRIAGE_BLOCK, which contains
Debugging Details:
***    work.                                                          ***
    Value: 1640
    Value: 5488
    Value: 0
    Value: 0
    Value: 0
    Value: 265
    Value: 1462
    Value: 89
    Value: 0x133
    Value: 0x133
    Value: 0x133
    Key  : Failure.Hash
    Value: 1417df84
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 0
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 21631230
    Value: 14a10fe
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 1015
    Value: 3f7
    Key  : WER.OS.Branch
    Value: ni_release
    Value: 10.0.22621.1
BUGCHECK_CODE:  133
BUGCHECK_P1: 1
BUGCHECK_P2: 1e00
BUGCHECK_P3: fffff80556d1c340
BUGCHECK_P4: 0
FILE_IN_CAB:  080124-13781-01.dmp
TRAP_FRAME:  fffff80554828bf0 -- (.trap 0xfffff80554828bf0)
rax=0000000000000001 rbx=0000000000000000 rcx=fffff80554829028
rdx=0000000000000008 rsi=0000000000000000 rdi=0000000000000000
rip=fffff8055635fe7d rsp=fffff80554828d80 rbp=fffff80554828de0
 r8=0000000000000000  r9=0000000000000007 r10=0000000000000018
r11=fffff80554828850 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei ng nz na pe nc
nt!RtlpWalkFrameChain+0x1d:
fffff805`5635fe7d 4889b5b8010000  mov     qword ptr [rbp+1B8h],rsi ss:fffff805`54828f98=fffff8055482a000
BLACKBOXWINLOGON: 1
STACK_TEXT:
fffff805`548309d8 fffff805`5632bf29     : 00000000`00000133 00000000`00000001 00000000`00001e00 fffff805`56d1c340 : nt!KeBugCheckEx
fffff805`548309e0 fffff805`5632b074     : 000002e4`de097ea3 fffff805`544aa180 00000000`00013cf6 00000000`00000000 : nt!KeAccumulateTicks+0x239
fffff805`54830a40 fffff805`5632cd2f     : 00000000`0000000c 00000000`00001388 00000000`00013c00 00000000`0000bced : nt!KiUpdateRunTime+0xf4
fffff805`54830c00 fffff805`563290e8     : 00000000`00000000 ffff8000`1296d800 fffff805`544aa180 00000000`00000000 : nt!KiUpdateTime+0x63f
fffff805`54830ea0 fffff805`56328a7a     : fffff805`56c5ff00 ffff8000`1296d830 ffff8000`1296d830 00000000`00000000 : nt!KeClockInterruptNotify+0x228
fffff805`54830f40 fffff805`56244b7c     : 00000002`f3b71268 fffff805`56d0d430 fffff805`56d0d4e0 ffffa803`0e9b5cc8 : nt!HalpTimerClockInterrupt+0x10a
fffff805`54830f70 fffff805`56417ffa     : fffff805`54828c70 fffff805`56d0d430 00000000`00000007 00000000`00000000 : nt!KiCallInterruptServiceRoutine+0x9c
fffff805`54830fb0 fffff805`564188c7     : fffff805`54828e30 00000000`00000002 fffff805`86002d00 00000000`0000000e : nt!KiInterruptSubDispatchNoLockNoEtw+0xfa
fffff805`54828bf0 fffff805`5635fe7d     : 00000000`0010000b 00001f80`00000200 00000000`00000000 fffff805`00000001 : nt!KiInterruptDispatchNoLockNoEtw+0x37
fffff805`54828d80 fffff805`562a6bee     : 00000000`00000000 fffff805`5482a000 00000000`00000006 fffff805`563280e8 : nt!RtlpWalkFrameChain+0x1d
fffff805`54828f90 fffff805`562a6b42     : 00000000`00000006 fffff805`54829028 00000000`00000000 00000000`00000001 : nt!RtlWalkFrameChain+0x6e
fffff805`54828fc0 fffff805`851f5737     : ffffa803`08664000 00000000`00000000 fffff805`548290d8 fffff805`8520a736 : nt!RtlCaptureStackBackTrace+0x42
fffff805`54828ff0 ffffa803`08664000     : 00000000`00000000 fffff805`548290d8 fffff805`8520a736 00000000`00000652 : nvlddmkm+0xe5737
fffff805`54828ff8 00000000`00000000     : fffff805`548290d8 fffff805`8520a736 00000000`00000652 fffff805`851f787b : 0xffffa803`08664000
SYMBOL_NAME:  nvlddmkm+e5737
BUCKET_ID_FUNC_OFFSET:  e5737
OSNAME:  Windows 10
Kod:
Machine ID Information [From Smbios 3.5, DMIVersion 0, Size=4953]
BiosMajorRelease = 5
BiosMinorRelease = 27
FirmwareMajorRelease = 1
FirmwareMinorRelease = 20
BiosVendor = American Megatrends International, LLC.
BiosVersion = N.1.13MON07
BiosReleaseDate = 01/11/2024
SystemManufacturer = MONSTER
SystemProductName = ABRA A5 V20.4
SystemFamily = ABRA
SystemVersion = Standard
SystemSKU = A5V204GM5AR5E
BaseBoardManufacturer = MONSTER
BaseBoardProduct = ABRA A5 V20.4
BaseBoardVersion = Standard
[SMBIOS Data Tables v3.5]
[DMI Version - 0]
[2.0 Calling Convention - No]
[Table Size - 4953 bytes]
  Vendor                        American Megatrends International, LLC.
  BIOS Version                  N.1.13MON07
  BIOS Release Date             01/11/2024
  BIOS ROM Size                 1000000
  BIOS Characteristics
       07: - PCI Supported
       11: - Upgradeable FLASH BIOS
       15: - CD-Boot Supported
       17: - BIOS ROM Socketed
       19: - EDD Supported
       22: - 360KB Floppy Supported
       23: - 1.2MB Floppy Supported
       24: - 720KB Floppy Supported
       25: - 2.88MB Floppy Supported
       27: - Keyboard Services Supported
       32: - BIOS Vendor Reserved
       00: - ACPI Supported
       01: - USB Legacy Supported
  BIOS Major Revision           5
  BIOS Minor Revision           27
  EC Firmware Major Revision    1
  EC Firmware Minor Revision    20
  Extended BIOS ROM Size        32 MB
  Manufacturer                  MONSTER
  Product Name                  ABRA A5 V20.4
  Version                       Standard
  Serial Number                 GM5AR5E2241605552
  SKUNumber                     A5V204GM5AR5E
  Family                        ABRA
  Product                       ABRA A5 V20.4
  Version                       Standard
  Serial Number                 Standard
  Asset Tag
       00: - Motherboard
       03: - Replaceable
  Location                      Standard
  Chassis Type                  Notebook
  Version                       Standard
  Serial Number
  Asset Tag Number
  Contained Element Size        3
[Onboard Devices Information (Type 10) - Length 6 - Handle 000eh]
Note: The On Board Device Information (Type 10) struct is obsolete as of SMBIOs spec v2.6  Number of Devices             1
  01: Type                      Unknown [enabled]
  01: Description               Device 1
[OEM Strings (Type 11) - Length 5 - Handle 000fh]
  Number of Strings             20
   1                            Standard
   2                            Standard
   3                            Standard
   4                            Standard
   5                            Standard
   6                            Standard
   7                            Standard
   8                            Standard
   9                            Standard
  10                            Standard
  11                            FBM-GM5AR5E0041FBS
  12                            GM5AR5E
  13                            Standard
  14                            Standard
  15                            Standard
  16                            1D05128DO1100700
  17                            Standard
  18                            Standard
  19                            Standard
  20                            Standard
[System Configuration Options (Type 12) - Length 5 - Handle 0010h]
[ (Type 256) - Length 9 - Handle 0025h]
[ (Type 256) - Length 23 - Handle 0026h]
[Physical Memory Array (Type 16) - Length 23 - Handle 0027h]
  Maximum Capacity              67108864KB
  Memory Error Inf Handle       [Not Provided]
  Number of Memory Devices      2
[Memory Device (Type 17) - Length 92 - Handle 0028h]
  Memory Error Info Handle      [Not Provided]
  Size                          16384MB
  Form Factor                   0dh - SODIMM
  Device Locator                Controller0-ChannelA-DIMM0
  Bank Locator                  BANK 0
  Memory Type                   1ah - DDR4
  Type Detail                   0080h - Synchronous
  Speed                         3200MHz
  Manufacturer                  Crucial Technology
  Serial Number
  Asset Tag Number
  Part Number                   CT16G4SFRA32A.C8FF
  Attributes                    1
  Configured Memory Speed       3200
  Minimum Voltage               1200
  Maximum Voltage               1200
  Configured Voltage            1200
  Memory Technology             3
  Memory Operating Mode Capability     8
  Firmware Version              0
  Module Manufacturer Id        39813
  Module Product Id             0
  Memory Subsystem Controller Manufacturer Id  0
  Memory Subsystem Controller Product Id       0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
  Extended Configured Memory Speed     0
[Memory Device (Type 17) - Length 92 - Handle 0029h]
  Size                          16384MB
  Device Locator                Controller1-ChannelA-DIMM0
  Bank Locator                  BANK 0
  Speed                         3200MHz
  Serial Number
  Asset Tag Number
  Attributes                    1
  Memory Technology             3
  Firmware Version              0
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
[Memory Array Mapped Address (Type 19) - Length 31 - Handle 002ah]
  Ending Address                01ffffffh
  Memory Array Handle           0027h
[ (Type 256) - Length 31 - Handle 002bh]
[ (Type 256) - Length 26 - Handle 002ch]
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 002dh]
  Ending Address                00ffffffh
  Memory Device Handle          0028h
  Mem Array Mapped Adr Handle   002ah
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 002eh]
  Starting Address              01000000h
  Memory Device Handle          0029h
[ (Type 256) - Length 12 - Handle 002fh]
[ (Type 256) - Length 26 - Handle 0030h]
[ (Type 256) - Length 26 - Handle 0031h]
[ (Type 256) - Length 47 - Handle 0032h]
[ (Type 256) - Length 82 - Handle 0033h]
[Cache Information (Type 7) - Length 27 - Handle 0034h]
  Socket Designation            L1 Cache
  Maximum Cache Size            00c0h - 192K
  Installed Size                00c0h - 192K
  Supported SRAM Type           0020h - Synchronous
  Current SRAM Type             0020h - Synchronous
  Cache Speed                   0ns
  Error Correction Type         ParitySingle-Bit ECC
  System Cache Type             Data
  Associativity                 12-way Set-Associative
  Maximum Cache Size 2          c0 - 00000192l Kb
  Installed Cache Size 2        c0 - 00000192l Kb
[Cache Information (Type 7) - Length 27 - Handle 0035h]
  Maximum Cache Size            0080h - 128K
  Installed Size                0080h - 128K
  Cache Speed                   0ns
  System Cache Type             Instruction
  Maximum Cache Size 2          80 - 00000128l Kb
  Installed Cache Size 2        80 - 00000128l Kb
[Cache Information (Type 7) - Length 27 - Handle 0036h]
  Socket Designation            L2 Cache
  Maximum Cache Size            1400h - 5120K
  Installed Size                1400h - 5120K
  Cache Speed                   0ns
  Error Correction Type         Multi-Bit ECC
  Associativity                 Other
  Maximum Cache Size 2          1400 - 00005120l Kb
  Installed Cache Size 2        1400 - 00005120l Kb
[Cache Information (Type 7) - Length 27 - Handle 0037h]
  Socket Designation            L3 Cache
  Maximum Cache Size            3000h - 12288K
  Installed Size                3000h - 12288K
  Cache Speed                   0ns
  Maximum Cache Size 2          3000 - 00012288l Kb
  Installed Cache Size 2        3000 - 00012288l Kb
[Cache Information (Type 7) - Length 27 - Handle 0038h]
  Cache Speed                   0ns
[Cache Information (Type 7) - Length 27 - Handle 0039h]
  Maximum Cache Size            0100h - 256K
  Installed Size                0100h - 256K
  Cache Speed                   0ns
  Maximum Cache Size 2          100 - 00000256l Kb
  Installed Cache Size 2        100 - 00000256l Kb
[Cache Information (Type 7) - Length 27 - Handle 003ah]
  Maximum Cache Size            0800h - 2048K
  Installed Size                0800h - 2048K
  Cache Speed                   0ns
  Associativity                 16-way Set-Associative
  Maximum Cache Size 2          800 - 00002048l Kb
  Installed Cache Size 2        800 - 00002048l Kb
[Cache Information (Type 7) - Length 27 - Handle 003bh]
  Cache Speed                   0ns
[Processor Information (Type 4) - Length 48 - Handle 003ch]
  Socket Designation            U3E1
  Processor Family              cdh - Intel Core 2 Solo processor
  Processor Manufacturer        Intel(R) Corporation
  Processor ID                   a3060900fffbebbf
  Processor Version             12th Gen Intel(R) Core(TM) i5-12450H
  Processor Voltage             8ch - 1.2V
  Max Speed                     4400MHz
  Current Speed                 4059MHz
  Processor Upgrade             Specification Reserved
  L1 Cache Handle               0039h
  L2 Cache Handle               003ah
  L3 Cache Handle               003bh
  Serial Number
  Asset Tag Number
  Part Number                   To Be Filled By O.E.M.
  Core Count                    8
  Core Enabled                  8
  Thread Count                  12
  Processor Characteristics     fc
  Enabled Characteristics:
       0x 2: 64-bit Capable
       0x 3: Multi-Core
       0x 4: Hardware Thread
       0x 5: Execute Protection
       0x 6: Enhanced Virtualization
  Processor Family 2            00cdh - Intel Core 2 Solo processor
  Core Count 2                  8
  Core Enabled 2                8
  Thread Count 2                12
[ (Type 256) - Length 64 - Handle 003eh]
[ (Type 256) - Length 11 - Handle 003fh]
[ (Type 256) - Length 11 - Handle 0040h]
[ (Type 256) - Length 11 - Handle 0041h]
[ (Type 256) - Length 11 - Handle 0042h]
[ (Type 256) - Length 11 - Handle 0043h]
[ (Type 256) - Length 11 - Handle 0044h]
[ (Type 256) - Length 11 - Handle 0045h]
[ (Type 256) - Length 11 - Handle 0046h]
[ (Type 256) - Length 11 - Handle 0047h]
[ (Type 256) - Length 11 - Handle 0048h]
[ (Type 256) - Length 11 - Handle 0049h]
[ (Type 256) - Length 11 - Handle 004ah]
[ (Type 256) - Length 11 - Handle 004bh]
[ (Type 256) - Length 11 - Handle 004ch]
[ (Type 256) - Length 103 - Handle 004dh]
[ (Type 256) - Length 44 - Handle 004eh]
[ (Type 256) - Length 8 - Handle 004fh]
[ (Type 256) - Length 106 - Handle 0051h]
[ (Type 256) - Length 6 - Handle 0052h]
[ (Type 256) - Length 4 - Handle 0054h]
Dosyanın kendisini konuya dahil edin. Detaylı analiz için buna ihtiyacımız var.
080124-12984-01.dmp, Minidump - Google Drive.
Kod:
or above.
Arguments:
Debugging Details:
***    work.                                                          ***
    Value: 1530
    Value: 4316
    Value: 0
    Value: 0
    Value: 0
    Value: 296
    Value: 1425
    Value: 88
    Value: 0x133
    Value: 0x133
    Key  : Failure.Hash
    Value: 1417df84
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 0
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 21631230
    Value: 14a10fe
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 1015
    Value: 3f7
    Key  : WER.OS.Branch
    Value: ni_release
    Value: 10.0.22621.1
BUGCHECK_CODE:  133
BUGCHECK_P1: 1
BUGCHECK_P2: 1e00
BUGCHECK_P4: 0
nvlddmkm+0xca8b4:
BLACKBOXWINLOGON: 1
STACK_TEXT:
OSNAME:  Windows 10
or above.
Arguments:
Debugging Details:
***    work.                                                          ***
    Value: 1592
    Value: 5671
    Value: 0
    Value: 0
    Value: 0
    Value: 234
    Value: 612
    Value: 99
    Value: 0x133
    Value: 0x133
    Value: 0x133
    Key  : Failure.Hash
    Value: 1417df84
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 0
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 21631230
    Value: 14a10fe
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 1015
    Value: 3f7
    Key  : WER.OS.Branch
    Value: ni_release
    Value: 10.0.22621.1
BUGCHECK_CODE:  133
BUGCHECK_P1: 1
BUGCHECK_P2: 1e00
BUGCHECK_P4: 0
nvlddmkm+0xca8b4:
BLACKBOXWINLOGON: 1
STACK_TEXT:
OSNAME:  Windows 10
or above.
Arguments:
Debugging Details:
***    work.                                                          ***
    Value: 1640
    Value: 5488
    Value: 0
    Value: 0
    Value: 0
    Value: 265
    Value: 1462
    Value: 89
    Value: 0x133
    Value: 0x133
    Value: 0x133
    Key  : Failure.Hash
    Value: 1417df84
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 0
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 21631230
    Value: 14a10fe
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 1015
    Value: 3f7
    Key  : WER.OS.Branch
    Value: ni_release
    Value: 10.0.22621.1
BUGCHECK_CODE:  133
BUGCHECK_P1: 1
BUGCHECK_P2: 1e00
BUGCHECK_P4: 0
BLACKBOXWINLOGON: 1
STACK_TEXT:
OSNAME:  Windows 10
Kod:
SystemFamily = ABRA
[DMI Version - 0]
       07: - PCI Supported
       19: - EDD Supported
  Version                       Standard
  Family                        ABRA
  Version                       Standard
  Asset Tag
       00: - Motherboard
       03: - Replaceable
  Location                      Standard
  Version                       Standard
  Serial Number
  Asset Tag Number
   1                            Standard
   2                            Standard
   3                            Standard
   4                            Standard
   5                            Standard
   6                            Standard
   7                            Standard
   8                            Standard
   9                            Standard
  10                            Standard
  12                            GM5AR5E
  13                            Standard
  14                            Standard
  15                            Standard
  16                            1D05128DO1100700
  17                            Standard
  18                            Standard
  19                            Standard
  20                            Standard
  Size                          16384MB
  Bank Locator                  BANK 0
  Speed                         3200MHz
  Serial Number
  Asset Tag Number
  Attributes                    1
  Memory Technology             3
  Firmware Version              0
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
  Size                          16384MB
  Bank Locator                  BANK 0
  Speed                         3200MHz
  Serial Number
  Asset Tag Number
  Attributes                    1
  Memory Technology             3
  Firmware Version              0
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
  Cache Speed                   0ns
  Cache Speed                   0ns
  Cache Speed                   0ns
  Associativity                 Other
  Cache Speed                   0ns
  Cache Speed                   0ns
  Cache Speed                   0ns
  Cache Speed                   0ns
  Cache Speed                   0ns
  Max Speed                     4400MHz
  Serial Number
  Asset Tag Number
  Core Count                    8
  Core Enabled                  8
  Thread Count                  12
       0x 3: Multi-Core
  Core Count 2                  8
  Core Enabled 2                8
  Thread Count 2                12
