Loading Kernel Symbols
Loading User Symbols
PEB is paged out (Peb.Ldr = 00000086`45ec1018). Type ".hh dbgerr001" for details
Loading unloaded module list
* Bugcheck Analysis *
PAGE_FAULT_IN_NONPAGED_AREA (50)
Invalid system memory was referenced. This cannot be protected by try-except.
Typically the address is just plain bad or it is pointing at freed memory.
Arguments:
Arg1: ffffcf87238763a0, memory referenced.
Arg2: 0000000000000011, X64: bit 0 set if the fault was due to a not-present PTE.
bit 1 is set if the fault was due to a write, clear if a read.
bit 3 is set if the processor decided the fault was due to a corrupted PTE.
bit 4 is set if the fault was due to attempted execute of a no-execute PTE.
- ARM64: bit 1 is set if the fault was due to a write, clear if a read.
bit 3 is set if the fault was due to attempted execute of a no-execute PTE.
Arg3: ffffcf87238763a0, If non-zero, the instruction address which referenced the bad memory
address.
Arg4: 0000000000000002, (reserved)
Debugging Details:
KEY_VALUES_STRING: 1
Key : AV.PTE
Value: Valid
Key : AV.Type
Value: Execute
Key : Analysis.CPU.mSec
Value: 671
Key : Analysis.Elapsed.mSec
Value: 1644
Key : Analysis.IO.Other.Mb
Value: 0
Key : Analysis.IO.Read.Mb
Value: 1
Key : Analysis.IO.Write.Mb
Value: 0
Key : Analysis.Init.CPU.mSec
Value: 234
Value: 331
Value: 72
Key : Analysis.Version.DbgEng
Value: 10.0.28000.2114
Key : Analysis.Version.Description
Value: 10.2506.23.01 amd64fre
Key : Analysis.Version.Ext
Value: 1.2506.23.1
Key : Bugcheck.Code.LegacyAPI
Value: 0x50
Key : Bugcheck.Code.TargetModel
Value: 0x50
Key : Failure.Bucket
Value: AV_X_(null)_nt!MiSystemFault
Key : Failure.Exception.IP.Address
Value: 0xffffcf87238763a0
Key : Failure.Hash
Value: {49578414-34a9-c6dc-c795-b8c5552d5975}
Key : WER.OS.Branch
Value: vb_release
Key : WER.OS.Version
Value: 10.0.19041.1
Key : WER.System.BIOSRevision
Value: 30.35.0.0
BUGCHECK_CODE: 50
BUGCHECK_P1: ffffcf87238763a0
BUGCHECK_P2: 11
BUGCHECK_P3: ffffcf87238763a0
BUGCHECK_P4: 2
FILE_IN_CAB: 092325-7546-01.dmp
FAULTING_THREAD: ffff920873047080
WRITE_ADDRESS: fffff800748fb390: Unable to get MiVisibleState
Unable to get NonPagedPoolStart
Unable to get NonPagedPoolEnd
Unable to get PagedPoolStart
Unable to get PagedPoolEnd
unable to get nt!MmSpecialPagesInUse
ffffcf87238763a0
MM_INTERNAL_CODE: 2
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXWINLOGON: 1 (!blackboxwinlogon)
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: VALORANT-Win64-Shipping.exe
STACK_TEXT:
ffffcf87`23875ea8 fffff800`7403bb7d : 00000000`00000050 ffffcf87`238763a0 00000000`00000011 ffffcf87`23876150 : nt!KeBugCheckEx
ffffcf87`23875eb0 fffff800`73e24660 : ffff9208`00000000 00000000`00000011 ffffcf87`238761d0 00000000`00000000 : nt!MiSystemFault+0x1d861d
ffffcf87`23875fb0 fffff800`7400d458 : 00000000`00000000 00000000`00000000 00000000`00000005 fffff800`7411f70e : nt!MmAccessFault+0x400
ffffcf87`23876150 ffffcf87`238763a0 : ffffcf87`23876364 ffffcf87`23876301 ffffd087`e75c5a50 ffffcf87`23876301 : nt!KiPageFault+0x358
ffffcf87`238762e0 ffffcf87`23876364 : ffffcf87`23876301 ffffd087`e75c5a50 ffffcf87`23876301 ffffcf87`23876394 : 0xffffcf87`238763a0
ffffcf87`238762e8 ffffcf87`23876301 : ffffd087`e75c5a50 ffffcf87`23876301 ffffcf87`23876394 ffffcf87`23876358 : 0xffffcf87`23876364
ffffcf87`238762f0 ffffd087`e75c5a50 : ffffcf87`23876301 ffffcf87`23876394 ffffcf87`23876358 ffffcf87`238765d0 : 0xffffcf87`23876301
ffffcf87`238762f8 ffffcf87`23876301 : ffffcf87`23876394 ffffcf87`23876358 ffffcf87`238765d0 ffffcf87`238765e0 : 0xffffd087`e75c5a50
ffffcf87`23876300 ffffcf87`23876394 : ffffcf87`23876358 ffffcf87`238765d0 ffffcf87`238765e0 00000000`00000000 : 0xffffcf87`23876301
ffffcf87`23876308 ffffcf87`23876358 : ffffcf87`238765d0 ffffcf87`238765e0 00000000`00000000 00000000`0000000a : 0xffffcf87`23876394
ffffcf87`23876310 ffffcf87`238765d0 : ffffcf87`238765e0 00000000`00000000 00000000`0000000a 00000001`23876800 : 0xffffcf87`23876358
ffffcf87`23876318 ffffcf87`238765e0 : 00000000`00000000 00000000`0000000a 00000001`23876800 ffffcf87`00000001 : 0xffffcf87`238765d0
ffffcf87`23876320 00000000`00000000 : 00000000`0000000a 00000001`23876800 ffffcf87`00000001 ffff9208`6cc9c8a0 : 0xffffcf87`238765e0
SYMBOL_NAME: nt!MiSystemFault+1d861d
MODULE_NAME: nt
IMAGE_VERSION: 10.0.19041.3803
STACK_COMMAND: .process /r /p 0xffff920873da50c0; .thread 0xffff920873047080 ; kb
IMAGE_NAME: ntkrnlmp.exe
BUCKET_ID_FUNC_OFFSET: 1d861d
FAILURE_BUCKET_ID: AV_X_(null)_nt!MiSystemFault
OS_VERSION: 10.0.19041.1
BUILDLAB_STR: vb_release
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {49578414-34a9-c6dc-c795-b8c5552d5975}
Followup: MachineOwner
KERNEL_MODE_HEAP_CORRUPTION (13a)
The kernel mode heap manager has detected corruption in a heap.
Arguments:
Arg1: 0000000000000009, An invalid argument was specified for the current operation.
Arg2: ffff960a87600000, Address of the heap that reported the corruption
Arg3: ffff960a90eee000, Address at which the corruption was detected
Arg4: 0000000000000000
Debugging Details:
Value: 609
Value: 1386
Value: 0
Value: 1
Value: 0
Value: 265
Value: 632
Value: 74
Value: 1.2506.23.1
Value: 0x13a
Value: 0x13a
Value: 0x13a_9_dxgmms2!operator_delete
Value: 0xfffff8070d7b70b9
Key : Failure.Exception.IP.Module
Value: nt
Key : Failure.Exception.IP.Offset
Value: 0x9b70b9
Key : Failure.Hash
Value: {42695e03-5e16-92c4-087f-1b06875f17dd}
Key : WER.OS.Branch
Value: vb_release
Value: 10.0.19041.1
Value: 30.35.0.0
BUGCHECK_CODE: 13a
BUGCHECK_P1: 9
BUGCHECK_P2: ffff960a87600000
BUGCHECK_P3: ffff960a90eee000
BUGCHECK_P4: 0
FILE_IN_CAB: 092325-7593-01.dmp
FAULTING_THREAD: ffffde0261cf95c0
CORRUPTING_POOL_ADDRESS: fffff8070dafb390: Unable to get MiVisibleState
ffff960a90eee000
PROCESS_NAME: System
STACK_TEXT:
ffffee8d`d34ce4a8 fffff807`0d393e4c : 00000000`0000013a 00000000`00000009 ffff960a`87600000 ffff960a`90eee000 : nt!KeBugCheckEx
ffffee8d`d34ce4b0 fffff807`0d393eac : 00000000`00000009 00000000`000000e8 ffff960a`87600000 01000000`00000000 : nt!RtlpHeapHandleError+0x40
ffffee8d`d34ce4f0 fffff807`0d393ad9 : ffff960a`87600100 00000000`00000000 ffffe7f0`00000000 00000000`00000000 : nt!RtlpHpHeapHandleError+0x58
ffffee8d`d34ce520 fffff807`0d03c3f5 : ffffde02`6bf70000 00000000`00000001 00000000`00000000 00000000`00000000 : nt!RtlpLogHeapFailure+0x45
ffffee8d`d34ce550 fffff807`0d7b70b9 : ffffee8d`00000000 ffffde02`6376d000 ffff960a`9b4ba5d0 01000000`00100000 : nt!ExFreeHeapPool+0x3a5
ffffee8d`d34ce630 fffff807`96f215ff : 00000000`0001d001 ffff960a`91d15330 ffffde02`6376d000 00000000`000000e8 : nt!ExFreePool+0x9
ffffee8d`d34ce660 fffff807`96f816ec : 00000000`000000e8 00000000`00000000 ffffde02`00000000 ffff960a`91d15330 : dxgmms2!operator delete+0x17
ffffee8d`d34ce690 fffff807`96f80d19 : 00000000`00000000 00000000`00000000 ffff960a`9b447120 00000000`000000e8 : dxgmms2!VIDMM_PAGE_TABLE::DestroyPageTable+0xc0
ffffee8d`d34ce710 fffff807`96f80c95 : 00000000`000001d0 ffff960a`9b447100 00000001`1b7a1000 00000000`00000000 : dxgmms2!VIDMM_PAGE_DIRECTORY::DestroyPdePageTableData+0x49
ffffee8d`d34ce740 fffff807`96f8fca5 : 00000000`00000000 00000000`00000000 ffffee8d`d34ceb50 00000000`0001d000 : dxgmms2!VIDMM_PAGE_DIRECTORY::HandleFullPageTableCoverage+0xb1
ffffee8d`d34ce7a0 fffff807`96f90226 : 00000000`00000000 ffff960a`91d15330 ffffee8d`d34ceb50 00000000`00000000 : dxgmms2!VIDMM_PAGE_DIRECTORY::CommitVirtualAddressRange+0x485
ffffee8d`d34ce940 fffff807`96f8f7a0 : ffffde02`611cd6a8 ffff960a`91d15330 ffffee8d`d34ceb50 00000000`00000000 : dxgmms2!VIDMM_PAGE_DIRECTORY::CommitVirtualAddressRange+0xa06
ffffee8d`d34ceae0 fffff807`96f8eb29 : ffffee8d`d34cf120 00000000`00000000 00000000`00000000 00000000`00000000 : dxgmms2!CVirtualAddressAllocator::UncommitVirtualAddressRange+0xf4
ffffee8d`d34cebf0 fffff807`96f874a0 : 00000000`00000000 00000000`00000000 ffff960a`9c46c3c8 fffff807`96f886bd : dxgmms2!VIDMM_GLOBAL::MakeOneVirtualAddressRangeNotResident+0x165
ffffee8d`d34cf080 fffff807`96f86c7a : ffff960a`e566f290 ffffee8d`d34cf200 ffff960a`9c46c390 ffffde02`63446de0 : dxgmms2!VIDMM_GLOBAL::MakeVirtualAddressRangeNotResident+0xc0
ffffee8d`d34cf0e0 fffff807`96f8c7fb : ffffde02`63776c20 ffffee8d`d34cf260 ffffde02`6376d000 ffffde02`6376d000 : dxgmms2!VIDMM_SYSMEM_SEGMENT::EvictResource+0xca
ffffee8d`d34cf160 fffff807`96face28 : ffffde02`6376d000 ffffde02`63776c10 ffffde02`6376d000 ffffde02`6376d000 : dxgmms2!VIDMM_GLOBAL::ProcessDeferredCommand+0xa9b
ffffee8d`d34cf380 fffff807`96fb72b9 : ffff960a`8bb4d950 ffffde02`61cf9500 00000000`00000000 00000000`04415400 : dxgmms2!VIDMM_WORKER_THREAD::Run+0xb78
ffffee8d`d34cf560 fffff807`0d1078e5 : ffffde02`61cf95c0 fffff807`96fb72b0 ffff960a`8bb4d950 001fe067`bcbbbdff : dxgmms2!VidMmWorkerThreadProc+0x9
ffffee8d`d34cf590 fffff807`0d2064b8 : ffff8281`c8700180 ffffde02`61cf95c0 fffff807`0d107890 00000000`00000000 : nt!PspSystemThreadStartup+0x55
ffffee8d`d34cf5e0 00000000`00000000 : ffffee8d`d34d0000 ffffee8d`d34c9000 00000000`00000000 00000000`00000000 : nt!KiStartSystemThread+0x28
SYMBOL_NAME: dxgmms2!operator delete+17
MODULE_NAME: dxgmms2
IMAGE_NAME: dxgmms2.sys
IMAGE_VERSION: 10.0.19041.3930
STACK_COMMAND: .process /r /p 0xffffde025475c080; .thread 0xffffde0261cf95c0 ; kb
BUCKET_ID_FUNC_OFFSET: 17
FAILURE_BUCKET_ID: 0x13a_9_dxgmms2!operator_delete
OSNAME: Windows 10
FAILURE_ID_HASH: {42695e03-5e16-92c4-087f-1b06875f17dd}
