Sorun RAM kaynaklı gibi. MemTest86 ile başla derim.
Kod:
PAGE_FAULT_IN_NONPAGED_AREA (50)
Invalid system memory was referenced.  This cannot be protected by try-except.
Typically the address is just plain bad or it is pointing at freed memory.
Arguments:
Arg1: ffff8884688883b8, memory referenced.
Arg2: 0000000000000000, X64: bit 0 set if the fault was due to a not-present PTE.
    bit 1 is set if the fault was due to a write, clear if a read.
    bit 3 is set if the processor decided the fault was due to a corrupted PTE.
    bit 4 is set if the fault was due to attempted execute of a no-execute PTE.
    - ARM64: bit 1 is set if the fault was due to a write, clear if a read.
    bit 3 is set if the fault was due to attempted execute of a no-execute PTE.
Arg3: fffff800e530c301, If non-zero, the instruction address which referenced the bad memory
    address.
Arg4: 0000000000000002, (reserved)
Debugging Details:
KEY_VALUES_STRING: 1
    Key  : AV.Type
    Value: Read
    Key  : Analysis.CPU.mSec
    Value: 718
    Key  : Analysis.Elapsed.mSec
    Value: 3495
    Key  : Analysis.IO.Other.Mb
    Value: 0
    Key  : Analysis.IO.Read.Mb
    Value: 1
    Key  : Analysis.IO.Write.Mb
    Value: 0
    Key  : Analysis.Init.CPU.mSec
    Value: 468
    Value: 4436
    Value: 81
    Value: 10.0.27829.1001
    Value: 10.2503.24.01 amd64fre
    Key  : Analysis.Version.Ext
    Value: 1.2503.24.1
    Value: 0x50
    Value: 0x50
    Value: 0x21808
    Value: 1
    Value: 0x0
    Value: 1
    Value: 0
    Key  : Failure.Bucket
    Value: AV_R_(null)_nt!VrpShouldOperateOnCall
    Key  : Failure.Exception.IP.Address
    Value: 0xfffff800e530c301
    Key  : Failure.Exception.IP.Module
    Value: nt
    Key  : Failure.Exception.IP.Offset
    Value: 0x90c301
    Key  : Failure.Hash
    Value: {bbfafa72-cbe1-cf9a-ab30-70200e2f2b3d}
    Key  : Hypervisor.Enlightenments.ValueHex
    Value: 0x7497cf94
    Key  : Hypervisor.Flags.AnyHypervisorPresent
    Value: 1
    Key  : Hypervisor.Flags.ApicEnlightened
    Value: 1
    Key  : Hypervisor.Flags.ApicVirtualizationAvailable
    Value: 0
    Key  : Hypervisor.Flags.AsyncMemoryHint
    Value: 0
    Key  : Hypervisor.Flags.CoreSchedulerRequested
    Value: 0
    Key  : Hypervisor.Flags.CpuManager
    Value: 1
    Key  : Hypervisor.Flags.DeprecateAutoEoi
    Value: 0
    Key  : Hypervisor.Flags.DynamicCpuDisabled
    Value: 1
    Key  : Hypervisor.Flags.Epf
    Value: 0
    Key  : Hypervisor.Flags.ExtendedProcessorMasks
    Value: 1
    Key  : Hypervisor.Flags.HardwareMbecAvailable
    Value: 1
    Key  : Hypervisor.Flags.MaxBankNumber
    Value: 0
    Key  : Hypervisor.Flags.MemoryZeroingControl
    Value: 0
    Key  : Hypervisor.Flags.NoExtendedRangeFlush
    Value: 0
    Key  : Hypervisor.Flags.NoNonArchCoreSharing
    Value: 1
    Key  : Hypervisor.Flags.Phase0InitDone
    Value: 1
    Key  : Hypervisor.Flags.PowerSchedulerQos
    Value: 0
    Key  : Hypervisor.Flags.RootScheduler
    Value: 0
    Key  : Hypervisor.Flags.SynicAvailable
    Value: 1
    Key  : Hypervisor.Flags.UseQpcBias
    Value: 0
    Key  : Hypervisor.Flags.Value
    Value: 38408431
    Key  : Hypervisor.Flags.ValueHex
    Value: 0x24a10ef
    Key  : Hypervisor.Flags.VpAssistPage
    Value: 1
    Key  : Hypervisor.Flags.VsmAvailable
    Value: 1
    Key  : Hypervisor.RootFlags.AccessStats
    Value: 1
    Key  : Hypervisor.RootFlags.CrashdumpEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.CreateVirtualProcessor
    Value: 1
    Key  : Hypervisor.RootFlags.DisableHyperthreading
    Value: 0
    Key  : Hypervisor.RootFlags.HostTimelineSync
    Value: 1
    Key  : Hypervisor.RootFlags.HypervisorDebuggingEnabled
    Value: 0
    Key  : Hypervisor.RootFlags.IsHyperV
    Value: 1
    Key  : Hypervisor.RootFlags.LivedumpEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.MapDeviceInterrupt
    Value: 1
    Key  : Hypervisor.RootFlags.MceEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.Nested
    Value: 0
    Key  : Hypervisor.RootFlags.StartLogicalProcessor
    Value: 1
    Key  : Hypervisor.RootFlags.Value
    Value: 1015
    Key  : Hypervisor.RootFlags.ValueHex
    Value: 0x3f7
BUGCHECK_CODE:  50
BUGCHECK_P1: ffff8884688883b8
BUGCHECK_P2: 0
BUGCHECK_P3: fffff800e530c301
BUGCHECK_P4: 2
FILE_IN_CAB:  042525-27796-01.dmp
TAG_NOT_DEFINED_202b:  *** Unknown TAG in analysis list 202b
DUMP_FILE_ATTRIBUTES: 0x21808
  Kernel Generated Triage Dump
FAULTING_THREAD:  ffffbe81b89d5080
READ_ADDRESS: fffff800e59c34c0: Unable to get MiVisibleState
Unable to get NonPagedPoolStart
Unable to get NonPagedPoolEnd
Unable to get PagedPoolStart
Unable to get PagedPoolEnd
unable to get nt!MmSpecialPagesInUse
 ffff8884688883b8
MM_INTERNAL_CODE:  2
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  msedgewebview2
STACK_TEXT:
ffffde82`bd82e698 fffff800`e4c73351     : 00000000`00000050 ffff8884`688883b8 00000000`00000000 ffffde82`bd82e900 : nt!KeBugCheckEx
ffffde82`bd82e6a0 fffff800`e4c913cf     : ffff8884`688883b8 00000000`00001000 00000000`00000002 fffff800`e4a00000 : nt!MiSystemFault+0x735
ffffde82`bd82e790 fffff800`e508aacb     : ffff8084`6fdc2300 ffffde82`bd82ea98 00000000`00000000 00000000`00000000 : nt!MmAccessFault+0x2ff
ffffde82`bd82e900 fffff800`e530c301     : fffff800`e58f6fa0 fffff800`e4c8d2d9 7fffffff`fffffffc 00000000`00000000 : nt!KiPageFault+0x38b
ffffde82`bd82ea90 fffff800`e523258a     : 00000000`00000028 ffffde82`bd82eb49 ffffde82`bd82ebd0 00000000`00000000 : nt!VrpShouldOperateOnCall+0x91
ffffde82`bd82ead0 fffff800`e523d466     : ffff8084`6ab9dcb0 00000000`00000000 00000000`00000000 ffff8084`6f5c88e0 : nt!VrpRegistryCallback+0x5a
ffffde82`bd82ebb0 fffff800`e523e085     : ffff8084`6f5c88e0 ffff8084`6ab9dcb0 ffff8084`642dd220 ffff8084`6f5c8928 : nt!CmpFireCleanupNotifications+0x76
ffffde82`bd82ec20 fffff800`e523d54b     : ffffbe81`8f4ffa70 00000000`00000000 00000000`ffff8003 00000000`00000000 : nt!CmpDeleteKeyObject+0x105
ffffde82`bd82ed60 fffff800`e4c41e39     : 00000000`00000000 00000000`00000000 ffffde82`bd82ef00 ffff8084`6f5c88e0 : nt!ObpRemoveObjectRoutine+0xab
ffffde82`bd82edc0 fffff800`e5235675     : 00000000`00000001 00000000`00000000 00000000`00007ffd 00000000`00000000 : nt!ObfDereferenceObjectWithTag+0x79
ffffde82`bd82ee00 fffff800`e5299680     : 00000000`00000000 fffff800`e4c83365 ffff8084`7d6700f0 00000000`000000a0 : nt!ObCloseHandleTableEntry+0x3e5
ffffde82`bd82ef50 fffff800`e52994f5     : 00000000`00000000 00000000`00000001 ffffbe81`b86f5201 fffff800`e52cbd95 : nt!ExSweepHandleTable+0xcc
ffffde82`bd82f000 fffff800`e529817a     : ffffbe81`b86f5268 00000000`00000000 ffff8084`7d58c7f8 ffffbe81`b89d5900 : nt!ObKillProcess+0x35
ffffde82`bd82f030 fffff800`e5297c76     : ffffbe81`b86f5080 ffffbe81`b86f5080 ffffde82`bd82f120 00000000`00000000 : nt!PspRundownSingleProcess+0xba
ffffde82`bd82f0c0 fffff800`e535c42b     : 000000e9`1ad6e000 00000000`00000000 ffffde82`bd82f2e8 ffffbe81`b89d5080 : nt!PspExitLastThread+0xe6
ffffde82`bd82f150 fffff800`e535ba84     : 00000000`00000000 fffff800`e4c89b01 00000000`00000000 00000000`00000000 : nt!PspExitThread+0x7bb
ffffde82`bd82f240 fffff800`e4c849cc     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`000010d8 : nt!KiSchedulerApcTerminate+0x34
ffffde82`bd82f280 fffff800`e5080570     : 00000000`00000000 ffffde82`bd82f320 00000000`00000000 00000000`00000000 : nt!KiDeliverApc+0x47c
ffffde82`bd82f320 fffff800`e508f00d     : ffffbe81`b89d5080 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiInitiateUserApc+0x70
ffffde82`bd82f460 00007ffd`c0a9c044     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceExit+0xad
000000e9`1aacf7b8 00000000`00000000     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ffd`c0a9c044
SYMBOL_NAME:  nt!VrpShouldOperateOnCall+91
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
IMAGE_VERSION:  10.0.26100.3775
STACK_COMMAND: .process /r /p 0xffffbe81b86f5080; .thread 0xffffbe81b89d5080 ; kb
BUCKET_ID_FUNC_OFFSET:  91
FAILURE_BUCKET_ID:  AV_R_(null)_nt!VrpShouldOperateOnCall
OSPLATFORM_TYPE:  x64
OSNAME:  Windows 10
FAILURE_ID_HASH:  {bbfafa72-cbe1-cf9a-ab30-70200e2f2b3d}
FAULTY_HARDWARE_CORRUPTED_PAGE (12b)
This BugCheck indicates that a single bit error was found in this page.  This is a hardware memory error.
Arguments:
Arg1: ffffffffc00002c4, virtual address mapping the corrupted page
Arg2: 00000000000005a8, physical page number
Arg3: 00000184938457d0, zero
Arg4: ffffe781411bc000, zero
Debugging Details:
    Value: 781
    Value: 1511
    Value: 0
    Value: 1
    Value: 0
    Value: 421
    Value: 4452
    Value: 81
    Value: 1.2503.24.1
    Key  : BlackBox.SmDecompressionFailure.CompressedSize
    Value: 0x5a8
    Key  : BlackBox.SmDecompressionFailure.CompressionFormat
    Value: 0x0
    Key  : BlackBox.SmDecompressionFailure.SourceDataHash
    Value: 0xea4a49fb
    Key  : BlackBox.SmDecompressionFailure.SourceDataOffset
    Value: 0x157d0
    Key  : BlackBox.SmDecompressionFailure.SourcePFN1
    Value: 0x69e655
    Key  : BlackBox.SmDecompressionFailure.SourcePFN2
    Value: 0xffffffffffffffff
    Key  : BlackBox.SmDecompressionFailure.TargetPFN
    Value: 0x278098
    Value: 0x12b
    Value: 0x12b
    Value: 0x21808
    Value: 1
    Value: 0x0
    Value: 1
    Value: 0
    Value: 0x12B_c00002c4_StCtDecompressFailed_nt!ST_STORE_SM_TRAITS_::StDmPageError
    Key  : Failure.Hash
    Value: {c6a6bb4d-3b77-dff6-2d9b-75f5d0f61a50}
    Value: 0x7497cf94
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 38408431
    Value: 0x24a10ef
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 1015
    Value: 0x3f7
BUGCHECK_CODE:  12b
BUGCHECK_P1: ffffffffc00002c4
BUGCHECK_P2: 5a8
BUGCHECK_P3: 184938457d0
BUGCHECK_P4: ffffe781411bc000
FILE_IN_CAB:  042525-13390-01.dmp
FAULTING_THREAD:  ffff8608caf3d080
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
PROCESS_NAME:  MemCompression
STACK_TEXT:
ffffd58d`8010eba8 fffff804`ef7cca59     : 00000000`0000012b ffffffff`c00002c4 00000000`000005a8 00000184`938457d0 : nt!KeBugCheckEx
ffffd58d`8010ebb0 fffff804`ef8a8251     : 00000000`00000200 ffff8608`c49ce020 00000000`c00004e0 ffff8608`c418c050 : nt!ST_STORE<SM_TRAITS>::StDmPageError+0x135
ffffd58d`8010ec00 fffff804`ef4a7849     : ffff8608`00003000 00000000`00000001 ffff8608`d0209790 ffff8608`c49ce000 : nt!ST_STORE<SM_TRAITS>::StDmFinishPageRetrieve+0x4004c1
ffffd58d`8010ec60 fffff804`ef4a752a     : ffffd58d`00000001 fffff804`00000001 ffff8608`d0209790 00000000`00000000 : nt!ST_STORE<SM_TRAITS>::StDmpSinglePageRetrieve+0x109
ffffd58d`8010ecd0 fffff804`ef4a5935     : fffff804`00000000 ffff8608`00000003 00000000`ffffffff fffff804`00000000 : nt!ST_STORE<SM_TRAITS>::StDmPageRetrieve+0x13a
ffffd58d`8010ed90 fffff804`ef4a549d     : ffff8608`c418c000 ffff8608`d0209790 ffff8608`c49ce000 00000000`000000ff : nt!SMKM_STORE<SM_TRAITS>::SmStDirectReadIssue+0xed
ffffd58d`8010ee30 fffff804`ef4a53ed     : fffff804`ef4a5310 ffffd58d`8010ef10 00000000`00000002 ffff8608`c49ce000 : nt!KeExpandKernelStackAndCalloutInternal+0x9d
ffffd58d`8010eea0 fffff804`ef4a514f     : 00000000`00000002 00000000`00000000 00000000`00000000 ffff8608`d6265b40 : nt!KeExpandKernelStackAndCalloutEx+0x1d
ffffd58d`8010eee0 fffff804`ef4c6d11     : ffff8608`c89fe5e0 ffff8608`d85ba000 ffff8608`c418c000 00000000`00000000 : nt!SMKM_STORE<SM_TRAITS>::SmStDirectRead+0xcf
ffffd58d`8010efb0 fffff804`ef4c6ac9     : ffff8608`d6265a40 ffffd58d`8010f0a0 ffff8608`d0209790 fffff804`40000010 : nt!SMKM_STORE<SM_TRAITS>::SmStWorkItemQueue+0x1b9
ffffd58d`8010f000 fffff804`ef4c67c5     : ffff8608`d6265a40 ffff8608`d0209790 ffffd58d`8010f0a0 ffff8608`d0209790 : nt!SmWorkItemQueue+0x9
ffffd58d`8010f030 fffff804`ef61e1e6     : ffff8608`d6265a40 00000000`0000000c ffff8608`00000000 00000000`00000002 : nt!SMKM_STORE_MGR<SM_TRAITS>::SmIoCtxQueueWork+0x1d5
ffffd58d`8010f0e0 fffff804`ef61e00a     : 00000000`00000002 ffffd58d`8010f1a0 00000000`00000003 00000000`00000000 : nt!SMKM_STORE_MGR<SM_TRAITS>::SmPageRead+0x1ce
ffffd58d`8010f160 fffff804`ef51ded5     : 00000000`0000afce 00000000`00000001 00000000`00592e00 fffff804`ef68259c : nt!SmPageRead+0x22
ffffd58d`8010f1a0 fffff804`ef51b661     : 00000000`00000002 00000000`00020000 00000000`00592e00 00000000`00000004 : nt!MiIssueHardFaultIo+0x15d
ffffd58d`8010f1f0 fffff804`ef49153a     : 00000000`00003000 00000000`00000002 00000000`c0033333 ffff8608`caf0e080 : nt!MiIssueHardFault+0x1fd
ffffd58d`8010f2f0 fffff804`ef88aacb     : ffff8608`caf3d080 00001f78`000ee780 00000000`00000000 00001f78`000d01c0 : nt!MmAccessFault+0x46a
ffffd58d`8010f460 00007ffb`81aa0051     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiPageFault+0x38b
00000092`9cdff4c8 00000000`00000000     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ffb`81aa0051
SYMBOL_NAME:  nt!ST_STORE<SM_TRAITS>::StDmPageError+135
MODULE_NAME: nt
STACK_COMMAND: .process /r /p 0xffff8608caf0e080; .thread 0xffff8608caf3d080 ; kb
BUCKET_ID_FUNC_OFFSET:  135
FAILURE_BUCKET_ID:  0x12B_c00002c4_StCtDecompressFailed_nt!ST_STORE_SM_TRAITS_::StDmPageError
OSNAME:  Windows 10
FAILURE_ID_HASH:  {c6a6bb4d-3b77-dff6-2d9b-75f5d0f61a50}
Followup:     MachineOwner
    PnpActivityId      : {00000000-0000-0000-0000-000000000000}
    PnpActivityTime    : 133900699392284960
    PnpEventInformation: 5
    PnpEventInProgress : 0
    PnpProblemCode     : 43
    PnpVetoType        : 0
    DeviceId           : PCI\VEN_10EC&DEV_8125&SUBSYS_87D71043&REV_05\01000000684CE00000
    VetoString         :
STORE_DATA_STRUCTURE_CORRUPTION (1c7)
The store component detected a corruption in its data structures.
Arguments:
Arg1: 0000000000000000, A chunk heap buffer's hash doesn't match.
Arg2: ffffaf88dfffb000, Chunk heap buffer whose hash didn't match.
Arg3: 00000000509841cc, Expected buffer hash.
Arg4: 00000000007887fb, Page frame number of the corrupted page.
Debugging Details:
    Value: 859
    Value: 2106
    Value: 0
    Value: 1
    Value: 0
    Value: 406
    Value: 4430
    Value: 81
    Value: 1.2503.24.1
    Value: 0x1c7
    Value: 0x1c7
    Value: 0x21808
    Value: 1
    Value: 0x0
    Value: 1
    Value: 0
    Value: 0x1C7_0_nt!ST_STORE_SM_TRAITS_::StDmPageRemove
    Key  : Failure.Hash
    Value: {41f36440-143d-fccc-822d-e94134726ddf}
    Value: 0x7497cf94
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 38408431
    Value: 0x24a10ef
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 1015
    Value: 0x3f7
BUGCHECK_CODE:  1c7
BUGCHECK_P1: 0
BUGCHECK_P2: ffffaf88dfffb000
BUGCHECK_P3: 509841cc
BUGCHECK_P4: 7887fb
FILE_IN_CAB:  042525-13484-01.dmp
FAULTING_THREAD:  ffffaf88c54e40c0
BLACKBOXWINLOGON: 1
STACK_TEXT:
ffffab0c`69db72d8 fffff804`91eb100f     : 00000000`000001c7 00000000`00000000 ffffaf88`dfffb000 00000000`509841cc : nt!KeBugCheckEx
ffffab0c`69db72e0 fffff804`91ec2365     : ffffaf88`d76edd10 ffffaf88`c7f98000 00000000`00000001 ffffaf88`a9651640 : nt!ST_STORE<SM_TRAITS>::StDmPageRemove+0xf9f
ffffab0c`69db7410 fffff804`91ec1453     : 00000000`00000000 ffffaf88`00000000 ffffaf88`ca8f97f0 00000000`00000000 : nt!ST_STORE<SM_TRAITS>::StWorkItemProcess+0x125
ffffab0c`69db74a0 fffff804`92065bcf     : ffffbfcd`00000000 ffffaf88`00000001 ffffffff`fffdb610 00000000`00000000 : nt!SMKM_STORE<SM_TRAITS>::SmStWorker+0x3a3
ffffab0c`69db7540 fffff804`9204d1fa     : ffffaf88`c7f98000 fffff804`92065ba0 ffffd581`d49e0180 025fe07f`b8bbbdff : nt!SMKM_STORE<SM_TRAITS>::SmStWorkerThread+0x2f
ffffab0c`69db7570 fffff804`9227ca94     : ffffd581`d49e0180 ffffaf88`c54e40c0 fffff804`9204d1a0 00000000`00000000 : nt!PspSystemThreadStartup+0x5a
ffffab0c`69db75c0 00000000`00000000     : ffffab0c`69db8000 ffffab0c`69db1000 00000000`00000000 00000000`00000000 : nt!KiStartSystemThread+0x34
SYMBOL_NAME:  nt!ST_STORE<SM_TRAITS>::StDmPageRemove+f9f
MODULE_NAME: nt
STACK_COMMAND: .process /r /p 0xffffaf88bff9c280; .thread 0xffffaf88c54e40c0 ; kb
BUCKET_ID_FUNC_OFFSET:  f9f
FAILURE_BUCKET_ID:  0x1C7_0_nt!ST_STORE_SM_TRAITS_::StDmPageRemove
OSNAME:  Windows 10
FAILURE_ID_HASH:  {41f36440-143d-fccc-822d-e94134726ddf}
    PnpActivityTime    : 133900827380185854
    PnpEventInformation: 3
    PnpProblemCode     : 24
    PnpVetoType        : 0
    DeviceId           : PCI\VEN_1022&DEV_43F6&SUBSYS_10621B21&REV_01\6&37563465&0&00680011
    VetoString         :
KERNEL_SECURITY_CHECK_FAILURE (139)
A kernel component has corrupted a critical data structure.  The corruption
could potentially allow a malicious user to gain control of this machine.
Arguments:
Arg1: 0000000000000003, A LIST_ENTRY has been corrupted (i.e. double remove).
Arg2: fffffe8eb5eae400, Address of the trap frame for the exception that caused the BugCheck
Arg3: fffffe8eb5eae358, Address of the exception record for the exception that caused the BugCheck
Arg4: 0000000000000000, Reserved
Debugging Details:
    Value: 1171
    Value: 3432
    Value: 0
    Value: 1
    Value: 0
    Value: 437
    Value: 4426
    Value: 85
    Value: 1.2503.24.1
    Value: 0x139
    Value: 0x139
    Value: 0x21808
    Value: 1
    Value: 0x0
    Value: 1
    Value: 0
    Key  : FailFast.Name
    Value: CORRUPT_LIST_ENTRY
    Key  : FailFast.Type
    Value: 3
    Value: 0x139_3_CORRUPT_LIST_ENTRY_dxgmms2!VIDMM_GLOBAL::NotifyAllocationEviction
    Key  : Failure.Exception.Code
    Value: 0xc0000409
    Key  : Failure.Exception.Record
    Value: 0xfffffe8eb5eae358
    Key  : Failure.Hash
    Value: {c348fc83-ae63-b870-155c-f085628ec11d}
    Value: 0x7497cf94
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 38408431
    Value: 0x24a10ef
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 1015
    Value: 0x3f7
BUGCHECK_CODE:  139
BUGCHECK_P1: 3
BUGCHECK_P2: fffffe8eb5eae400
BUGCHECK_P3: fffffe8eb5eae358
BUGCHECK_P4: 0
FILE_IN_CAB:  042525-13156-01.dmp
FAULTING_THREAD:  ffffd4820d1593c0
TRAP_FRAME:  fffffe8eb5eae400 -- (.trap 0xfffffe8eb5eae400)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=ffffd48227c4dc48 rbx=0000000000000000 rcx=0000000000000003
rdx=ffff9108a17d0280 rsi=0000000000000000 rdi=0000000000000000
rip=fffff80250bc916a rsp=fffffe8eb5eae590 rbp=ffffd48222306cb0
 r8=ffffd48227c4fb48  r9=ffffd481fbaacc90 r10=ffffd4821217a000
r11=ffff91089dd37bb8 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0         nv up ei ng nz na po cy
dxgmms2!VIDMM_GLOBAL::NotifyAllocationEviction+0x1aa:
fffff802`50bc916a cd29            int     29h
Resetting default scope
EXCEPTION_RECORD:  fffffe8eb5eae358 -- (.exr 0xfffffe8eb5eae358)
ExceptionAddress: fffff80250bc916a (dxgmms2!VIDMM_GLOBAL::NotifyAllocationEviction+0x00000000000001aa)
   ExceptionCode: c0000409 (Security check failure or stack buffer overrun)
  ExceptionFlags: 00000001
NumberParameters: 1
   Parameter[0]: 0000000000000003
Subcode: 0x3 FAST_FAIL_CORRUPT_LIST_ENTRY
BLACKBOXWINLOGON: 1
PROCESS_NAME:  System
ERROR_CODE: (NTSTATUS) 0xc0000409 - Sistem, bu uygulamada y   n tabanl  bir arabelle in ta t   n  alg lad . Bu ta ma, k t  niyetli bir kullan c n n bu uygulaman n denetimini ele ge irmesine olanak verebilir.
EXCEPTION_CODE_STR:  c0000409
EXCEPTION_PARAMETER1:  0000000000000003
EXCEPTION_STR:  0xc0000409
STACK_TEXT:
fffffe8e`b5eae0d8 fffff802`7aa8f8e9     : 00000000`00000139 00000000`00000003 fffffe8e`b5eae400 fffffe8e`b5eae358 : nt!KeBugCheckEx
fffffe8e`b5eae0e0 fffff802`7aa8fef2     : fffff802`5246dc68 fffff802`7a68d2d9 00000000`00000200 0001d088`00000040 : nt!KiBugCheckDispatch+0x69
fffffe8e`b5eae220 fffff802`7aa8db28     : 00000000`00000002 00000000`00000000 ffffd482`1217a000 00000000`00000000 : nt!KiFastFailDispatch+0xb2
fffffe8e`b5eae400 fffff802`50bc916a     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiRaiseSecurityCheckFailure+0x368
fffffe8e`b5eae590 fffff802`50bca58e     : ffffd482`27c4fb10 ffffd482`22306cb0 ffffd482`1217a000 ffffd482`1217a000 : dxgmms2!VIDMM_GLOBAL::NotifyAllocationEviction+0x1aa
fffffe8e`b5eae610 fffff802`50bbb42c     : 00000001`178ae000 fffffe8e`b5eae719 ffffd482`1217a000 ffff9108`ac402750 : dxgmms2!VIDMM_GLOBAL::EvictOneAllocation+0x6e
fffffe8e`b5eae650 fffff802`50bf1445     : ffff9108`8bc7ad40 00000000`00000000 00000000`00000000 ffff9108`a21e2de0 : dxgmms2!VIDMM_PAGE_TABLE::DestroyPageTable+0x1d4
fffffe8e`b5eae780 fffff802`50bf024f     : ffff9108`a21e2de0 ffff9108`8bc7ad40 fffffe8e`00000002 00000000`00000000 : dxgmms2!VIDMM_PAGE_DIRECTORY::CommitVirtualAddressRange+0x15e5
fffffe8e`b5eae930 fffff802`50befca6     : ffff9108`92ac0c40 ffff9108`8bc7ad40 fffffe8e`b5eaeb50 00000000`00000000 : dxgmms2!VIDMM_PAGE_DIRECTORY::CommitVirtualAddressRange+0x3ef
fffffe8e`b5eaeae0 fffff802`50bc8d6a     : 00000000`00000047 ffffd481`f761cd30 ffffd482`120ca480 00000000`00000008 : dxgmms2!CVirtualAddressAllocator::UncommitVirtualAddressRange+0x11e
fffffe8e`b5eaec00 fffff802`50bc8760     : ffffd482`20f910d0 00000000`00000001 ffffd482`20f910d0 fffff802`7a68b34e : dxgmms2!VIDMM_GLOBAL::MakeOneVirtualAddressRangeNotResident+0x43a
fffffe8e`b5eaf0c0 fffff802`50bc20e5     : ffff9108`a1da8ae0 00000000`00000001 ffffd482`27c4f300 ffffd481`fbaacc90 : dxgmms2!VIDMM_MEMORY_SEGMENT::EvictResource+0x140
fffffe8e`b5eaf120 fffff802`50bc6616     : 00000000`00000004 ffffd482`27c4f301 fffff802`0b387200 ffffd482`0d159300 : dxgmms2!VIDMM_PHYSICAL_ADAPTER::EvictResources+0x1d5
fffffe8e`b5eaf1d0 fffff802`50bc4f61     : 00000000`00000000 ffffd482`1217a000 ffff9108`7b844000 ffffd482`27c4f310 : dxgmms2!VIDMM_GLOBAL::ProcessDeferredCommand+0x3e6
fffffe8e`b5eaf3c0 fffff802`7a84d1fa     : ffff9108`7b844000 fffff802`50bc4900 ffffbd01`53d22100 025fe07f`b8bbbd02 : dxgmms2!VidMmWorkerThreadProc+0x5a1
fffffe8e`b5eaf570 fffff802`7aa7ca94     : ffffbd01`53d22180 ffffd482`0d1593c0 fffff802`7a84d1a0 8348fffd`57f2e820 : nt!PspSystemThreadStartup+0x5a
fffffe8e`b5eaf5c0 00000000`00000000     : fffffe8e`b5eb0000 fffffe8e`b5ea9000 00000000`00000000 00000000`00000000 : nt!KiStartSystemThread+0x34
SYMBOL_NAME:  dxgmms2!VIDMM_GLOBAL::NotifyAllocationEviction+1aa
MODULE_NAME: dxgmms2
IMAGE_NAME:  dxgmms2.sys
STACK_COMMAND: .process /r /p 0xffffd481f755c040; .thread 0xffffd4820d1593c0 ; kb
BUCKET_ID_FUNC_OFFSET:  1aa
FAILURE_BUCKET_ID:  0x139_3_CORRUPT_LIST_ENTRY_dxgmms2!VIDMM_GLOBAL::NotifyAllocationEviction
OSNAME:  Windows 10
FAILURE_ID_HASH:  {c348fc83-ae63-b870-155c-f085628ec11d}
    PnpActivityTime    : 133900836330352177
    PnpProblemCode     : 24
    PnpVetoType        : 0
    VetoString         :
[SMBIOS Data Tables v3.6]
[DMI Version - 0]
[2.0 Calling Convention - No]
[Table Size - 3271 bytes]
  Vendor                        American Megatrends Inc.
  BIOS Version                  3222
  BIOS Release Date             03/05/2025
  BIOS ROM Size                 1000000
  BIOS Characteristics
       07: - PCI Supported
       11: - Upgradeable FLASH BIOS
       15: - CD-Boot Supported
       17: - BIOS ROM Socketed
       19: - EDD Supported
       22: - 360KB Floppy Supported
       23: - 1.2MB Floppy Supported
       24: - 720KB Floppy Supported
       25: - 2.88MB Floppy Supported
       27: - Keyboard Services Supported
       32: - BIOS Vendor Reserved
       00: - ACPI Supported
       01: - USB Legacy Supported
  BIOS Major Revision           32
  BIOS Minor Revision           22
  EC Firmware Major Revision    255
  EC Firmware Minor Revision    255
  Extended BIOS ROM Size        32 MB
  Manufacturer                  ASUS
  Product Name                  System Product Name
  Version                       System Version
  Serial Number                 System Serial Number
  SKUNumber                     SKU
  Family                        To be filled by O.E.M.
  Manufacturer                  ASUSTeK COMPUTER INC.
  Product                       PRIME B650M-A WIFI II
  Version                       Rev 1.xx
  Serial Number                 241247673001870
  Asset Tag
       00: - Motherboard
       03: - Replaceable
  Location                      Default string
  Manufacturer                  Default string
  Chassis Type                  Desktop
  Version                       Default string
  Serial Number
  Asset Tag Number
  Contained Element Size        3
[Onboard Devices Information (Type 10) - Length 6 - Handle 0004h]
Note: The On Board Device Information (Type 10) struct is obsolete as of SMBIOs spec v2.6  Number of Devices             1
  01: Type                      Video [enabled]
  01: Description                  To Be Filled By O.E.M.
[OEM Strings (Type 11) - Length 5 - Handle 0005h]
  Number of Strings             6
   1                            Default string
   2                            Default string
   3                            Default string
   4                            Default string
   5                            Default string
   6                            Default string
[System Configuration Options (Type 12) - Length 5 - Handle 0006h]
[ (Type 256) - Length 59 - Handle 0009h]
[ (Type 256) - Length 9 - Handle 000ah]
[ (Type 256) - Length 31 - Handle 000bh]
[ (Type 256) - Length 26 - Handle 000ch]
[Cache Information (Type 7) - Length 27 - Handle 000dh]
  Socket Designation            L1 - Cache
  Maximum Cache Size            01e0h - 480K
  Installed Size                01e0h - 480K
  Supported SRAM Type           0010h - Pipeline-Burst
  Current SRAM Type             0010h - Pipeline-Burst
  Cache Speed                   1ns
  Maximum Cache Size 2          1e0 - 00000480l Kb
  Installed Cache Size 2        1e0 - 00000480l Kb
[Cache Information (Type 7) - Length 27 - Handle 000eh]
  Socket Designation            L2 - Cache
  Maximum Cache Size            1800h - 6144K
  Installed Size                1800h - 6144K
  Cache Speed                   1ns
  Associativity                 16-way Set-Associative
  Maximum Cache Size 2          1800 - 00006144l Kb
  Installed Cache Size 2        1800 - 00006144l Kb
[Cache Information (Type 7) - Length 27 - Handle 000fh]
  Socket Designation            L3 - Cache
  Maximum Cache Size            8200h - 32768K
  Installed Size                8200h - 32768K
  Cache Speed                   1ns
  Maximum Cache Size 2          80000200 - 00032768l Kb
  Installed Cache Size 2        80000200 - 00032768l Kb
[Processor Information (Type 4) - Length 48 - Handle 0010h]
  Socket Designation            AM5
  Processor Family              6bh - AMD Zen Processor Family
  Processor Manufacturer        Advanced Micro Devices, Inc.
  Processor ID                   400fb400fffb8b17
  Processor Version             AMD Ryzen 5 9600 6-Core Processor
  Processor Voltage             8dh - 1.3V
  Max Speed                     5250MHz
  Current Speed                 3800MHz
  Processor Upgrade             Specification Reserved
  L1 Cache Handle               000dh
  L2 Cache Handle               000eh
  L3 Cache Handle               000fh
  Serial Number
  Asset Tag Number
  Part Number                   Unknown
  Core Count                    6
  Core Enabled                  6
  Thread Count                  12
  Processor Characteristics     fc
  Enabled Characteristics:
       0x 2: 64-bit Capable
       0x 3: Multi-Core
       0x 4: Hardware Thread
       0x 5: Execute Protection
       0x 6: Enhanced Virtualization
  Processor Family 2            006bh - AMD Zen Processor Family
  Core Count 2                  6
  Core Enabled 2                6
  Thread Count 2                12
[ (Type 256) - Length 9 - Handle 0011h]
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 0012h]
[Physical Memory Array (Type 16) - Length 23 - Handle 0013h]
  Maximum Capacity              134217728KB
  Memory Error Inf Handle       0012h
  Number of Memory Devices      4
[Memory Array Mapped Address (Type 19) - Length 31 - Handle 0014h]
  Ending Address                01ffffffh
  Memory Array Handle           0013h
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 0015h]
[Memory Device (Type 17) - Length 92 - Handle 0016h]
  Memory Error Info Handle      0015h
  Total Width                   [Unknown]
  Data Width                    [Unknown]
  Size                          [Not Populated]
  Form Factor                   02h - Unknown
  Device Locator                DIMM 0
  Bank Locator                  P0 CHANNEL A
  Memory Type                   02h - Unknown
  Type Detail                   0004h - Unknown
  Speed                         0MHz
  Manufacturer                  Unknown
  Serial Number
  Asset Tag Number              [String Not Specified]
  Part Number                   Unknown
  Attributes                    0
  Configured Memory Speed       0
  Minimum Voltage               0
  Maximum Voltage               0
  Configured Voltage            0
  Memory Technology             2
  Memory Operating Mode Capability     4
  Firmware Version              6
  Module Manufacturer Id        0
  Module Product Id             0
  Memory Subsystem Controller Manufacturer Id  0
  Memory Subsystem Controller Product Id       0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
  Extended Configured Memory Speed     0
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 0017h]
[Memory Device (Type 17) - Length 92 - Handle 0018h]
  Memory Error Info Handle      0017h
  Size                          16384MB
  Form Factor                   09h - DIMM
  Device Locator                DIMM 1
  Memory Type                   22h - DDR5
  Type Detail                   4080h - Synchronous Unbuffered (Unregistered)
  Speed                         4800MHz
  Manufacturer                  Lexar Co Limited
  Serial Number
  Part Number                   LD5U16G60C38BG
  Attributes                    1
  Configured Memory Speed       6000
  Minimum Voltage               1100
  Maximum Voltage               1100
  Configured Voltage            1100
  Memory Technology             3
  Memory Operating Mode Capability     8
  Firmware Version              6
  Module Manufacturer Id        30346
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 0019h]
  Ending Address                00ffffffh
  Memory Device Handle          0018h
  Mem Array Mapped Adr Handle   0014h
  Interleave Position           [Unknown]
  Interleave Data Depth         [Unknown]
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 001ah]
[Memory Device (Type 17) - Length 92 - Handle 001bh]
  Memory Error Info Handle      001ah
  Bank Locator                  P0 CHANNEL B
  Speed                         0MHz
  Serial Number
  Part Number                   Unknown
  Attributes                    0
  Minimum Voltage               0
  Maximum Voltage               0
  Memory Technology             2
  Firmware Version              6
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 001ch]
[Memory Device (Type 17) - Length 92 - Handle 001dh]
  Memory Error Info Handle      001ch
  Size                          16384MB
  Speed                         4800MHz
  Serial Number
  Attributes                    1
  Memory Technology             3
  Firmware Version              6
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 001eh]
  Starting Address              01000000h
  Memory Device Handle          001dh
[ (Type 256) - Length 14 - Handle 001fh]
[ (Type 256) - Length 165 - Handle 0020h]
[ (Type 256) - Length 11 - Handle 0044h]
[ (Type 256) - Length 11 - Handle 0045h]
[ (Type 256) - Length 4 - Handle 0047h]
@Triafin, test ettiniz mi belleği? Sonuç nedir? Çözüm olarak işaretlemişsiniz de.
Kod:
Arguments:
    address.
Debugging Details:
    Key  : AV.Type
    Value: Read
    Value: 718
    Value: 3495
    Value: 0
    Value: 1
    Value: 0
    Value: 468
    Value: 4436
    Value: 81
    Value: 1.2503.24.1
    Value: 0x50
    Value: 0x50
    Value: 0x21808
    Value: 1
    Value: 0x0
    Value: 1
    Value: 0
    Value: nt
    Value: 0x90c301
    Key  : Failure.Hash
    Value: 0x7497cf94
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 38408431
    Value: 0x24a10ef
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 1015
    Value: 0x3f7
BUGCHECK_CODE:  50
BUGCHECK_P2: 0
BUGCHECK_P4: 2
 ffff8884688883b8
MM_INTERNAL_CODE:  2
BLACKBOXWINLOGON: 1
STACK_TEXT:
MODULE_NAME: nt
OSNAME:  Windows 10
Arguments:
Debugging Details:
    Value: 781
    Value: 1511
    Value: 0
    Value: 1
    Value: 0
    Value: 421
    Value: 4452
    Value: 81
    Value: 1.2503.24.1
    Value: 0x5a8
    Value: 0x0
    Value: 0xea4a49fb
    Value: 0x157d0
    Value: 0x69e655
    Value: 0x278098
    Value: 0x12b
    Value: 0x12b
    Value: 0x21808
    Value: 1
    Value: 0x0
    Value: 1
    Value: 0
    Key  : Failure.Hash
    Value: 0x7497cf94
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 38408431
    Value: 0x24a10ef
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 1015
    Value: 0x3f7
BUGCHECK_CODE:  12b
BUGCHECK_P2: 5a8
BLACKBOXWINLOGON: 1
STACK_TEXT:
MODULE_NAME: nt
OSNAME:  Windows 10
    PnpProblemCode     : 43
    PnpVetoType        : 0
    VetoString         :
Arguments:
Debugging Details:
    Value: 859
    Value: 2106
    Value: 0
    Value: 1
    Value: 0
    Value: 406
    Value: 4430
    Value: 81
    Value: 1.2503.24.1
    Value: 0x1c7
    Value: 0x1c7
    Value: 0x21808
    Value: 1
    Value: 0x0
    Value: 1
    Value: 0
    Key  : Failure.Hash
    Value: 0x7497cf94
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 38408431
    Value: 0x24a10ef
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 1015
    Value: 0x3f7
BUGCHECK_CODE:  1c7
BUGCHECK_P1: 0
BUGCHECK_P4: 7887fb
BLACKBOXWINLOGON: 1
STACK_TEXT:
MODULE_NAME: nt
OSNAME:  Windows 10
    PnpProblemCode     : 24
    PnpVetoType        : 0
    VetoString         :
Arguments:
Debugging Details:
    Value: 1171
    Value: 3432
    Value: 0
    Value: 1
    Value: 0
    Value: 437
    Value: 4426
    Value: 85
    Value: 1.2503.24.1
    Value: 0x139
    Value: 0x139
    Value: 0x21808
    Value: 1
    Value: 0x0
    Value: 1
    Value: 0
    Key  : FailFast.Name
    Key  : FailFast.Type
    Value: 3
    Value: 0xc0000409
    Key  : Failure.Hash
    Value: 0x7497cf94
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 0
    Value: 1
    Value: 1
    Value: 0
    Value: 0
    Value: 1
    Value: 0
    Value: 38408431
    Value: 0x24a10ef
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 0
    Value: 1
    Value: 1
    Value: 1
    Value: 1
    Value: 0
    Value: 1
    Value: 1015
    Value: 0x3f7
BUGCHECK_CODE:  139
BUGCHECK_P1: 3
BUGCHECK_P4: 0
NumberParameters: 1
BLACKBOXWINLOGON: 1
STACK_TEXT:
OSNAME:  Windows 10
    PnpProblemCode     : 24
    PnpVetoType        : 0
    VetoString         :
[DMI Version - 0]
  BIOS Version                  3222
       07: - PCI Supported
       19: - EDD Supported
  Manufacturer                  ASUS
  SKUNumber                     SKU
  Version                       Rev 1.xx
  Asset Tag
       00: - Motherboard
       03: - Replaceable
  Serial Number
  Asset Tag Number
  Number of Strings             6
   1                            Default string
   2                            Default string
   3                            Default string
   4                            Default string
   5                            Default string
   6                            Default string
  Cache Speed                   1ns
  Cache Speed                   1ns
  Cache Speed                   1ns
  Max Speed                     5250MHz
  Serial Number
  Asset Tag Number
  Part Number                   Unknown
  Core Count                    6
  Core Enabled                  6
  Thread Count                  12
       0x 3: Multi-Core
  Core Count 2                  6
  Core Enabled 2                6
  Thread Count 2                12
  Speed                         0MHz
  Serial Number
  Part Number                   Unknown
  Attributes                    0
  Minimum Voltage               0
  Maximum Voltage               0
  Memory Technology             2
  Firmware Version              6
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
  Size                          16384MB
  Speed                         4800MHz
  Serial Number
  Attributes                    1
  Memory Technology             3
  Firmware Version              6
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
  Speed                         0MHz
  Serial Number
  Part Number                   Unknown
  Attributes                    0
  Minimum Voltage               0
  Maximum Voltage               0
  Memory Technology             2
  Firmware Version              6
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
  Size                          16384MB
  Speed                         4800MHz
  Serial Number
  Attributes                    1
  Memory Technology             3
  Firmware Version              6
  Module Product Id             0
  Non-Volatile Size             0
  Volatile Size                 0
  Cache Size                    0
  Logical Size                  0
  Extended Speed                0
Sorun RAM kaynaklı gibi. Memtest86 ile başla derim.
Kod:
Arguments:
Arg3: fffff800e530c301, If non-zero, the instruction address which referenced the bad memory.
 address.
Debugging Details:
 Key : AV.Type
 Value: Read.
 Value: 718.
 Value: 3495.
 Value: 0
 Value: 1
 Value: 0
 Value: 468.
 Value: 4436.
 Value: 81.
 Value: 10.2503.24.01 amd64fre.
 Value: 1.2503.24.1
 Value: 0x50.
 Value: 0x50.
 Value: 0x21808.
 Value: 1
 Value: 0x0.
 Value: 1
 Value: 0
 Value: 0xfffff800e530c301.
 Value: nt.
 Value: 0x90c301.
 Key : Failure.Hash
 Value: 0x7497cf94.
 Value: 1
 Value: 1
 Value: 0
 Value: 0
 Value: 0
 Value: 1
 Value: 0
 Value: 1
 Value: 0
 Value: 1
 Value: 1
 Value: 0
 Value: 0
 Value: 0
 Value: 1
 Value: 1
 Value: 0
 Value: 0
 Value: 1
 Value: 0
 Value: 38408431.
 Value: 0x24a10ef.
 Value: 1
 Value: 1
 Value: 1
 Value: 1
 Value: 1
 Value: 0
 Value: 1
 Value: 0
 Value: 1
 Value: 1
 Value: 1
 Value: 1
 Value: 0
 Value: 1
 Value: 1015.
 Value: 0x3f7.
BUGCHECK_CODE: 50.
BUGCHECK_P1: ffff8884688883b8.
BUGCHECK_P2: 0
BUGCHECK_P3: fffff800e530c301.
BUGCHECK_P4: 2
TAG_NOT_DEFINED_202b: *** Unknown TAG in analysis list 202b.
DUMP_FILE_ATTRIBUTES: 0x21808.
 Kernel Generated Triage Dump.
FAULTING_THREAD: ffffbe81b89d5080.
READ_ADDRESS: fffff800e59c34c0: Unable to get MiVisibleState.
Unable to get NonPagedPoolStart.
Unable to get NonPagedPoolEnd.
Unable to get PagedPoolStart.
Unable to get PagedPoolEnd.
 ffff8884688883b8.
MM_INTERNAL_CODE: 2
BLACKBOXWINLOGON: 1
PROCESS_NAME: msedgewebview2.
STACK_TEXT:
MODULE_NAME: nt.
STACK_COMMAND: .process /r /p 0xffffbe81b86f5080; .thread 0xffffbe81b89d5080 ; kb.
BUCKET_ID_FUNC_OFFSET: 91.
OSPLATFORM_TYPE: x64.
OSNAME: Windows 10.
Arguments:
Arg1: ffffffffc00002c4, virtual address mapping the corrupted page.
Arg2: 00000000000005a8, physical page number.
Arg3: 00000184938457d0, zero.
Arg4: ffffe781411bc000, zero.
Debugging Details:
 Value: 781.
 Value: 1511.
 Value: 0
 Value: 1
 Value: 0
 Value: 421.
 Value: 4452.
 Value: 81.
 Value: 1.2503.24.1
 Value: 0x5a8.
 Value: 0x0.
 Value: 0xea4a49fb.
 Value: 0x157d0.
 Value: 0x69e655.
 Value: 0xffffffffffffffff.
 Value: 0x278098.
 Value: 0x12b.
 Value: 0x12b.
 Value: 0x21808.
 Value: 1
 Value: 0x0.
 Value: 1
 Value: 0
 Key : Failure.Hash
 Value: 0x7497cf94.
 Value: 1
 Value: 1
 Value: 0
 Value: 0
 Value: 0
 Value: 1
 Value: 0
 Value: 1
 Value: 0
 Value: 1
 Value: 1
 Value: 0
 Value: 0
 Value: 0
 Value: 1
 Value: 1
 Value: 0
 Value: 0
 Value: 1
 Value: 0
 Value: 38408431.
 Value: 0x24a10ef.
 Value: 1
 Value: 1
 Value: 1
 Value: 1
 Value: 1
 Value: 0
 Value: 1
 Value: 0
 Value: 1
 Value: 1
 Value: 1
 Value: 1
 Value: 0
 Value: 1
 Value: 1015.
 Value: 0x3f7.
BUGCHECK_CODE: 12b.
BUGCHECK_P1: ffffffffc00002c4.
BUGCHECK_P2: 5a8.
BUGCHECK_P3: 184938457d0.
BUGCHECK_P4: ffffe781411bc000.
FAULTING_THREAD: ffff8608caf3d080.
BLACKBOXWINLOGON: 1
PROCESS_NAME: MemCompression.
STACK_TEXT:
MODULE_NAME: nt.
STACK_COMMAND: .process /r /p 0xffff8608caf0e080; .thread 0xffff8608caf3d080 ; kb.
BUCKET_ID_FUNC_OFFSET: 135.
OSNAME: Windows 10.
Followup: MachineOwner.
 PnpActivityTime : 133900699392284960.
 PnpProblemCode : 43.
 PnpVetoType : 0
 VetoString :
Arguments:
Debugging Details:
 Value: 859.
 Value: 2106.
 Value: 0
 Value: 1
 Value: 0
 Value: 406.
 Value: 4430.
 Value: 81.
 Value: 1.2503.24.1
 Value: 0x1c7.
 Value: 0x1c7.
 Value: 0x21808.
 Value: 1
 Value: 0x0.
 Value: 1
 Value: 0
 Key : Failure.Hash
 Value: 0x7497cf94.
 Value: 1
 Value: 1
 Value: 0
 Value: 0
 Value: 0
 Value: 1
 Value: 0
 Value: 1
 Value: 0
 Value: 1
 Value: 1
 Value: 0
 Value: 0
 Value: 0
 Value: 1
 Value: 1
 Value: 0
 Value: 0
 Value: 1
 Value: 0
 Value: 38408431.
 Value: 0x24a10ef.
 Value: 1
 Value: 1
 Value: 1
 Value: 1
 Value: 1
 Value: 0
 Value: 1
 Value: 0
 Value: 1
 Value: 1
 Value: 1
 Value: 1
 Value: 0
 Value: 1
 Value: 1015.
 Value: 0x3f7.
BUGCHECK_CODE: 1c7.
BUGCHECK_P1: 0
BUGCHECK_P2: ffffaf88dfffb000.
BUGCHECK_P3: 509841cc.
BUGCHECK_P4: 7887fb.
FAULTING_THREAD: ffffaf88c54e40c0.
BLACKBOXWINLOGON: 1
STACK_TEXT:
MODULE_NAME: nt.
STACK_COMMAND: .process /r /p 0xffffaf88bff9c280; .thread 0xffffaf88c54e40c0 ; kb.
BUCKET_ID_FUNC_OFFSET: f9f.
OSNAME: Windows 10.
 PnpActivityTime : 133900827380185854.
 PnpProblemCode : 24.
 PnpVetoType : 0
 VetoString :
A kernel component has corrupted a critical data structure. The corruption.
Arguments:
Arg2: fffffe8eb5eae400, Address of the trap frame for the exception that caused the BugCheck.
Arg3: fffffe8eb5eae358, Address of the exception record for the exception that caused the BugCheck.
Arg4: 0000000000000000, Reserved.
Debugging Details:
 Value: 1171.
 Value: 3432.
 Value: 0
 Value: 1
 Value: 0
 Value: 437.
 Value: 4426.
 Value: 85.
 Value: 1.2503.24.1
 Value: 0x139.
 Value: 0x139.
 Value: 0x21808.
 Value: 1
 Value: 0x0.
 Value: 1
 Value: 0
 Key : FailFast.Name
 Value: CORRUPT_LIST_ENTRY.
 Key : FailFast.Type
 Value: 3
 Value: 0xc0000409.
 Value: 0xfffffe8eb5eae358.
 Key : Failure.Hash
 Value: 0x7497cf94.
 Value: 1
 Value: 1
 Value: 0
 Value: 0
 Value: 0
 Value: 1
 Value: 0
 Value: 1
 Value: 0
 Value: 1
 Value: 1
 Value: 0
 Value: 0
 Value: 0
 Value: 1
 Value: 1
 Value: 0
 Value: 0
 Value: 1
 Value: 0
 Value: 38408431.
 Value: 0x24a10ef.
 Value: 1
 Value: 1
 Value: 1
 Value: 1
 Value: 1
 Value: 0
 Value: 1
 Value: 0
 Value: 1
 Value: 1
 Value: 1
 Value: 1
 Value: 0
 Value: 1
 Value: 1015.
 Value: 0x3f7.
BUGCHECK_CODE: 139.
BUGCHECK_P1: 3
BUGCHECK_P2: fffffe8eb5eae400.
BUGCHECK_P3: fffffe8eb5eae358.
BUGCHECK_P4: 0
FAULTING_THREAD: ffffd4820d1593c0.
iopl=0 nv up ei ng nz na po cy.
fffff802`50bc916a cd29 int 29h.
Resetting default scope.
 ExceptionFlags: 00000001.
NumberParameters: 1
 Parameter[0]: 0000000000000003.
BLACKBOXWINLOGON: 1
PROCESS_NAME: System.
EXCEPTION_CODE_STR: c0000409.
EXCEPTION_PARAMETER1: 0000000000000003.
EXCEPTION_STR: 0xc0000409.
STACK_TEXT:
MODULE_NAME: dxgmms2.
STACK_COMMAND: .process /r /p 0xffffd481f755c040; .thread 0xffffd4820d1593c0 ; kb.
BUCKET_ID_FUNC_OFFSET: 1aa.
OSNAME: Windows 10.
 PnpActivityTime : 133900836330352177.
 PnpVetoType : 0
 VetoString :
[DMI Version - 0]
 BIOS Version 3222.
 BIOS Starting Address Segment f000.
 BIOS ROM Size 1000000.
 BIOS Characteristics.
 07: - PCI Supported.
 11: - Upgradeable FLASH BIOS.
 12: - BIOS Shadowing Supported.
 15: - CD-Boot Supported.
 16: - Selectable Boot Supported.
 17: - BIOS ROM Socketed.
 19: - EDD Supported.
 20: - NEC 9800 J-Floppy Supported.
 21: - Toshiba J-Floppy Supported.
 22: - 360KB Floppy Supported.
 23: - 1.2MB Floppy Supported.
 24: - 720KB Floppy Supported.
 25: - 2.88MB Floppy Supported.
 26: - Print Screen Device Supported.
 27: - Keyboard Services Supported.
 28: - Serial Services Supported.
 29: - Printer Services Supported.
 30: - CGA/Mono Services Supported.
 32: - BIOS Vendor Reserved.
 BIOS Characteristic Extensions.
 00: - ACPI Supported.
 01: - USB Legacy Supported.
 08: - BIOS Boot Specification Supported.
 10: - Enable Targeted Content Distribution.
 11: - UEFI Specification Supported.
 BIOS Major Revision 32.
 BIOS Minor Revision 22.
 EC Firmware Major Revision 255.
 EC Firmware Minor Revision 255.
 Extended BIOS ROM Size 32 MB.
 Manufacturer ASUS.
 Product Name System Product Name.
 Version System Version.
 Serial Number System Serial Number.
 Wakeup Type Power Switch.
 SKUNumber SKU.
 Product PRIME B650M-A WIFI II.
 Version Rev 1.xx
 Serial Number 241247673001870.
 Asset Tag
 Feature Flags 09h.
 00: - Motherboard.
 03: - Replaceable.
 Location Default string.
 Chassis Handle 0003h.
 Board Type 0ah - Processor/Memory Module.
 Manufacturer Default string.
 Chassis Type Desktop.
 Version Default string.
 Serial Number
 Asset Tag Number
 Bootup State Safe.
 Power Supply State Safe.
 Thermal State Safe.
 Security Status None.
 OEM Defined 0
 Height 0U.
 Number of Strings 6
 1 Default string.
 2 Default string.
 3 Default string.
 4 Default string.
 5 Default string.
 6 Default string.
 Socket Designation L1 - Cache.
 Cache Configuration 0180h - WBEnabled Int NonSocketed L1.
 Maximum Cache Size 01e0h - 480K.
 Installed Size 01e0h - 480K.
 Cache Speed 1ns.
 Error Correction Type Specification Reserved.
 System Cache Type Unified.
 Maximum Cache Size 2 1e0 - 00000480l Kb.
 Installed Cache Size 2 1e0 - 00000480l Kb.
 Socket Designation L2 - Cache.
 Cache Configuration 0181h - WBEnabled Int NonSocketed L2.
 Maximum Cache Size 1800h - 6144K.
 Installed Size 1800h - 6144K.
 Cache Speed 1ns.
 Maximum Cache Size 2 1800 - 00006144l Kb.
 Installed Cache Size 2 1800 - 00006144l Kb.
 Socket Designation L3 - Cache.
 Cache Configuration 0182h - WBEnabled Int NonSocketed L3.
 Maximum Cache Size 8200h - 32768K.
 Installed Size 8200h - 32768K.
 Cache Speed 1ns.
 Maximum Cache Size 2 80000200 - 00032768l Kb.
 Installed Cache Size 2 80000200 - 00032768l Kb.
 Socket Designation AM5.
 Processor Type Central Processor.
 Processor Family 6bh - AMD Zen Processor Family.
 Processor ID 400fb400fffb8b17.
 External Clock 100MHz.
 Max Speed 5250MHz.
 Current Speed 3800MHz.
 Status Enabled Populated.
 Processor Upgrade Specification Reserved.
 L1 Cache Handle 000dh.
 L2 Cache Handle 000eh.
 L3 Cache Handle 000fh.
 Serial Number
 Asset Tag Number
 Part Number Unknown.
 Core Count 6
 Core Enabled 6
 Thread Count 12.
 Processor Characteristics fc.
 0x 2: 64-bit Capable.
 0x 3: Multi-Core
 0x 4: Hardware Thread.
 0x 5: Execute Protection.
 0x 6: Enhanced Virtualization.
 0x 7: Power/Performance Control.
 Processor Family 2 006bh - AMD Zen Processor Family.
 Core Count 2 6
 Core Enabled 2 6
 Thread Count 2 12.
 Use 03h - System Memory.
 Memory Error Correction 03h - None.
 Maximum Capacity 134217728KB.
 Memory Error Inf Handle 0012h.
 Starting Address 00000000h.
 Ending Address 01ffffffh.
 Memory Array Handle 0013h.
 Partition Width 02.
 Extended Starting Address 0000000000000000h.
 Extended Ending Address 0000000000000000h.
 Memory Error Info Handle 0015h.
 Form Factor 02h - Unknown.
 Device Set [None]
 Memory Type 02h - Unknown.
 Type Detail 0004h - Unknown.
 Speed 0MHz.
 Manufacturer Unknown.
 Serial Number
 Attributes 0
 Extended Size 0
 Minimum Voltage 0
 Maximum Voltage 0
 Memory Technology 2
 Firmware Version 6
 Module Product Id 0
 Non-Volatile Size 0
 Volatile Size 0
 Cache Size 0
 Logical Size 0
 Extended Speed 0
 Memory Error Info Handle 0017h.
 Total Width 64 bits.
 Data Width 64 bits.
 Size 16384MB.
 Form Factor 09h - DIMM.
 Device Set [None]
 Memory Type 22h - DDR5.
 Speed 4800MHz.
 Manufacturer Lexar Co Limited.
 Serial Number
 Part Number LD5U16G60C38BG.
 Attributes 1
 Extended Size 0
 Configured Memory Speed 6000.
 Minimum Voltage 1100.
 Maximum Voltage 1100.
 Configured Voltage 1100.
 Memory Technology 3
 Firmware Version 6
 Module Manufacturer Id 30346.
 Module Product Id 0
 Non-Volatile Size 0
 Volatile Size 0
 Cache Size 0
 Logical Size 0
 Extended Speed 0
 Ending Address 00ffffffh.
 Memory Device Handle 0018h.
 Mem Array Mapped Adr Handle 0014h.
 Memory Error Info Handle 001ah.
 Device Set [None]
 Speed 0MHz.
 Serial Number
 Attributes 0
 Extended Size 0
 Minimum Voltage 0
 Maximum Voltage 0
 Memory Technology 2
 Firmware Version 6
 Module Product Id 0
 Non-Volatile Size 0
 Volatile Size 0
 Cache Size 0
 Logical Size 0
 Extended Speed 0
 Memory Error Info Handle 001ch.
 Data Width 64 bits.
 Size 16384MB.
 Device Set [None]
 Speed 4800MHz.
 Serial Number
 Attributes 1
 Extended Size 0
 Memory Technology 3
 Firmware Version 6
 Module Product Id 0
 Non-Volatile Size 0
 Volatile Size 0
 Cache Size 0
 Logical Size 0
 Extended Speed 0
 Starting Address 01000000h.
 Memory Device Handle 001dh.
Tüm cevaplarınız için teşekkürler evet sorun RAM ile alakalı çıktı.
