* Bugcheck Analysis *
SYSTEM_SERVICE_EXCEPTION (3b)
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c000001d, Exception code that caused the BugCheck
Arg2: fffff804e22f6299, Address of the instruction which caused the BugCheck
Arg3: ffff840198fa48d0, Address of the context record for the exception that caused the BugCheck
Arg4: 0000000000000000, zero.
Debugging Details:
KEY_VALUES_STRING: 1
Key : Analysis.CPU.mSec
Value: 1671
Key : Analysis.Elapsed.mSec
Value: 6638
Key : Analysis.IO.Other.Mb
Value: 0
Key : Analysis.IO.Read.Mb
Value: 1
Key : Analysis.IO.Write.Mb
Value: 1
Key : Analysis.Init.CPU.mSec
Value: 1687
Value: 13577
Value: 102
Key : Analysis.Version.DbgEng
Value: 10.0.27871.1001
Key : Analysis.Version.Description
Value: 10.2505.01.02 amd64fre
Key : Analysis.Version.Ext
Value: 1.2505.1.2
Key : Bugcheck.Code.LegacyAPI
Value: 0x3b
Key : Bugcheck.Code.TargetModel
Value: 0x3b
Key : Dump.Attributes.AsUlong
Value: 0x21808
Key : Dump.Attributes.DiagDataWrittenToHeader
Value: 1
Key : Dump.Attributes.ErrorCode
Value: 0x0
Key : Dump.Attributes.KernelGeneratedTriageDump
Value: 1
Key : Dump.Attributes.LastLine
Key : Dump.Attributes.ProgressPercentage
Value: 0
Key : Failure.Bucket
Value: IP_MISALIGNED_GenuineIntel.sys
Key : Failure.Exception.IP.Address
Value: 0xfffff804e22f6299
Key : Failure.Exception.IP.Module
Value: nt
Key : Failure.Exception.IP.Offset
Value: 0x4f6299
Key : Failure.Hash
Value: {e930d917-b247-3f7f-23cb-88a0c9f1b274}
Key : Hypervisor.Enlightenments.ValueHex
Value: 0x7417df84
Key : Hypervisor.Flags.AnyHypervisorPresent
Value: 1
Key : Hypervisor.Flags.ApicEnlightened
Value: 0
Key : Hypervisor.Flags.ApicVirtualizationAvailable
Value: 1
Key : Hypervisor.Flags.AsyncMemoryHint
Value: 0
Key : Hypervisor.Flags.CoreSchedulerRequested
Value: 0
Key : Hypervisor.Flags.CpuManager
Value: 1
Key : Hypervisor.Flags.DeprecateAutoEoi
Value: 1
Key : Hypervisor.Flags.DynamicCpuDisabled
Value: 1
Key : Hypervisor.Flags.Epf
Value: 0
Key : Hypervisor.Flags.ExtendedProcessorMasks
Value: 1
Key : Hypervisor.Flags.HardwareMbecAvailable
Value: 1
Key : Hypervisor.Flags.MaxBankNumber
Value: 0
Key : Hypervisor.Flags.MemoryZeroingControl
Value: 0
Key : Hypervisor.Flags.NoExtendedRangeFlush
Value: 0
Key : Hypervisor.Flags.NoNonArchCoreSharing
Value: 1
Key : Hypervisor.Flags.Phase0InitDone
Value: 1
Key : Hypervisor.Flags.PowerSchedulerQos
Value: 0
Key : Hypervisor.Flags.RootScheduler
Value: 0
Key : Hypervisor.Flags.SynicAvailable
Value: 1
Key : Hypervisor.Flags.UseQpcBias
Value: 0
Key : Hypervisor.Flags.Value
Value: 55185662
Key : Hypervisor.Flags.ValueHex
Value: 0x34a10fe
Key : Hypervisor.Flags.VpAssistPage
Value: 1
Key : Hypervisor.Flags.VsmAvailable
Value: 1
Key : Hypervisor.RootFlags.AccessStats
Value: 1
Key : Hypervisor.RootFlags.CrashdumpEnlightened
Value: 1
Key : Hypervisor.RootFlags.CreateVirtualProcessor
Value: 1
Key : Hypervisor.RootFlags.DisableHyperthreading
Value: 0
Key : Hypervisor.RootFlags.HostTimelineSync
Value: 1
Key : Hypervisor.RootFlags.HypervisorDebuggingEnabled
Value: 0
Key : Hypervisor.RootFlags.IsHyperV
Value: 1
Key : Hypervisor.RootFlags.LivedumpEnlightened
Value: 1
Key : Hypervisor.RootFlags.MapDeviceInterrupt
Value: 1
Key : Hypervisor.RootFlags.MceEnlightened
Value: 1
Key : Hypervisor.RootFlags.Nested
Value: 0
Key : Hypervisor.RootFlags.StartLogicalProcessor
Value: 1
Key : Hypervisor.RootFlags.Value
Value: 1015
Key : Hypervisor.RootFlags.ValueHex
Value: 0x3f7
Key : Stack.Pointer
Value: PRCBException
BUGCHECK_CODE: 3b
BUGCHECK_P1: c000001d
BUGCHECK_P2: fffff804e22f6299
BUGCHECK_P3: ffff840198fa48d0
BUGCHECK_P4: 0
FILE_IN_CAB: 082025-23718-01.dmp
DUMP_FILE_ATTRIBUTES: 0x21808
Kernel Generated Triage Dump
FAULTING_THREAD: ffffd58ca7b870c0
CONTEXT: ffff840198fa48d0 -- (.cxr 0xffff840198fa48d0)
rax=0000000000000001 rbx=ffffd58ca7b020c0 rcx=0000000000000007
rdx=0000000000022040 rsi=fffff804e1e00000 rdi=0000000000000003
rip=fffff804e22f6299 rsp=ffffce042b17f5a0 rbp=ffffce042b17f710
r8=ffffce042b17f868 r9=0000000000000000 r10=ffffd58ca7b020c0
r11=0000000000000000 r12=0000000000000ff0 r13=ffffd58ca7b020c0
r14=00000003ca84acce r15=ffff840198f80180
iopl=0 nv up ei pl nz na pe cy
cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00050203
nt!Feature_UserPresenceThrottling__private_IsEnabledDeviceUsageNoInline+0x2d:
fffff804`e22f6299 83c428 add esp,28h
Resetting default scope
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: League of Lege
MISALIGNED_IP:
nt!Feature_UserPresenceThrottling__private_IsEnabledDeviceUsageNoInline+2d
STACK_TEXT:
ffffce04`2b17f5a0 fffff804`e20e9999 : 00000000`00000057 00000000`00000000 00000000`00000000 00000000`00000000 : nt!Feature_UserPresenceThrottling__private_IsEnabledDeviceUsageNoInline+0x2d
ffffce04`2b17f5d0 fffff804`e2133f42 : ffffd58c`a7b02200 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiComputeThreadQos+0x89
ffffce04`2b17f610 fffff804`e2151006 : ffffce04`2b17f929 ffffd58c`b4521e68 ffffd58c`87cde000 fffff804`e208fb99 : nt!KiDeferredReadySingleThread+0x202
ffffce04`2b17f840 fffff804`e2150cfc : 00000000`00000000 00000000`00000001 00000000`00000001 00000000`00000000 : nt!KiProcessThreadWaitList+0x106
ffffce04`2b17f8e0 fffff804`e213c563 : ffffd58c`8bc49760 ffffd58c`8bc49768 00000000`00000000 ffffd58c`8bc49768 : nt!KiExitDispatcher+0x4c
ffffce04`2b17f940 fffff804`e27daf39 : 00000000`00000000 ffffce04`2b17fa60 00000000`00000000 ffffd58c`8bc49760 : nt!KeReleaseSemaphoreEx+0xdf
ffffce04`2b17f990 fffff804`e24b8541 : ffffd58c`a7b870c0 000001f5`a8010f28 ffffd58c`00000000 ffffd58c`8bc49760 : nt!NtReleaseSemaphore+0x99
ffffce04`2b17f9e0 00007ffd`cfa429f4 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceExitPico+0x496
0000006b`35a7f988 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ffd`cfa429f4
SYMBOL_NAME: nt!Feature_UserPresenceThrottling__private_IsEnabledDeviceUsageNoInline+2d
IMAGE_VERSION: 10.0.26100.4946
STACK_COMMAND: .cxr 0xffff840198fa48d0 ; kb
MODULE_NAME: GenuineIntel
IMAGE_NAME: GenuineIntel.sys
FAILURE_BUCKET_ID: IP_MISALIGNED_GenuineIntel.sys
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {e930d917-b247-3f7f-23cb-88a0c9f1b274}
Followup: MachineOwner
