Son hata ekran kartına işaret etmekte. BIOS sürümünüz nedir?
Kod:
SYSTEM_EXIT_OWNED_MUTEX (39)
Arguments:
Arg1: fffff801e935ed50
Arg2: ffff80894ea8d598
Arg3: ffff80894ea8d598
Arg4: 0000000000000000
Debugging Details:
KEY_VALUES_STRING: 1
    Key  : Analysis.CPU.mSec
    Value: 718
    Key  : Analysis.Elapsed.mSec
    Value: 736
    Key  : Analysis.IO.Other.Mb
    Value: 0
    Key  : Analysis.IO.Read.Mb
    Value: 1
    Key  : Analysis.IO.Write.Mb
    Value: 0
    Key  : Analysis.Init.CPU.mSec
    Value: 296
    Value: 3285
    Value: 77
    Value: 10.0.27829.1001
    Value: 10.2503.24.01 amd64fre
    Key  : Analysis.Version.Ext
    Value: 1.2503.24.1
    Value: 0x39
    Value: 0x39
    Value: 0x21008
    Value: 1
    Value: 0x0
    Value: 1
    Value: 0
    Key  : Failure.Bucket
    Value: 0x39_nt!IopProcessWorkItem
    Key  : Failure.Exception.IP.Address
    Value: 0xfffff801e935ed50
    Key  : Failure.Exception.IP.Module
    Value: nt
    Key  : Failure.Exception.IP.Offset
    Value: 0x35ed50
    Key  : Failure.Hash
    Value: {5025ad58-9334-8a23-6f35-301116e3793b}
BUGCHECK_CODE:  39
BUGCHECK_P1: fffff801e935ed50
BUGCHECK_P2: ffff80894ea8d598
BUGCHECK_P3: ffff80894ea8d598
BUGCHECK_P4: 0
FILE_IN_CAB:  071525-17906-01.dmp
DUMP_FILE_ATTRIBUTES: 0x21008
  Kernel Generated Triage Dump
FAULTING_THREAD:  ffff80894abf3040
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  System
STACK_TEXT:
fffff382`4b1109c8 fffff801`e92303c7     : 00000000`00000039 fffff801`e935ed50 ffff8089`4ea8d598 ffff8089`4ea8d598 : nt!KeBugCheckEx
fffff382`4b1109d0 fffff801`e949e2da     : ffff8089`4abf3040 ffff8089`4abf3040 fffff801`e9230140 ffff8089`4a795ae0 : nt!ExpWorkerThread+0x287
fffff382`4b110bb0 fffff801`e96a67e4     : ffffc780`edc51180 ffff8089`4abf3040 fffff801`e949e280 00620032`00300030 : nt!PspSystemThreadStartup+0x5a
fffff382`4b110c00 00000000`00000000     : fffff382`4b111000 fffff382`4b10a000 00000000`00000000 00000000`00000000 : nt!KiStartSystemThread+0x34
SYMBOL_NAME:  nt!IopProcessWorkItem+0
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
IMAGE_VERSION:  10.0.26100.4652
STACK_COMMAND: .process /r /p 0xffff80894a6b7040; .thread 0xffff80894abf3040 ; kb
BUCKET_ID_FUNC_OFFSET:  0
FAILURE_BUCKET_ID:  0x39_nt!IopProcessWorkItem
OSPLATFORM_TYPE:  x64
OSNAME:  Windows 10
FAILURE_ID_HASH:  {5025ad58-9334-8a23-6f35-301116e3793b}
Followup:     MachineOwner
PAGE_FAULT_IN_NONPAGED_AREA (50)
Invalid system memory was referenced.  This cannot be protected by try-except.
Typically the address is just plain bad or it is pointing at freed memory.
Arguments:
Arg1: fffff907d6aa053f, memory referenced.
Arg2: 0000000000000010, X64: bit 0 set if the fault was due to a not-present PTE.
    bit 1 is set if the fault was due to a write, clear if a read.
    bit 3 is set if the processor decided the fault was due to a corrupted PTE.
    bit 4 is set if the fault was due to attempted execute of a no-execute PTE.
    - ARM64: bit 1 is set if the fault was due to a write, clear if a read.
    bit 3 is set if the fault was due to attempted execute of a no-execute PTE.
Arg3: fffff907d6aa053f, If non-zero, the instruction address which referenced the bad memory
    address.
Arg4: 0000000000000002, (reserved)
Debugging Details:
    Key  : AV.Type
    Value: Execute
    Value: 734
    Value: 754
    Value: 0
    Value: 1
    Value: 0
    Value: 375
    Value: 3272
    Value: 77
    Value: 1.2503.24.1
    Value: 0x50
    Value: 0x50
    Value: 0x21008
    Value: 1
    Value: 0x0
    Value: 1
    Value: 0
    Value: AV_X_(null)_BAD_IP_nt!MiSystemFault
    Value: 0xfffff907d6aa053f
    Key  : Failure.Hash
    Value: {519102ae-339f-c953-2278-3f0bfcf5aa85}
    Key  : Stack.Pointer
    Value: NMI
BUGCHECK_CODE:  50
BUGCHECK_P1: fffff907d6aa053f
BUGCHECK_P2: 10
BUGCHECK_P3: fffff907d6aa053f
BUGCHECK_P4: 2
FILE_IN_CAB:  072725-14484-01.dmp
FAULTING_THREAD:  fffff807d73d1640
READ_ADDRESS: fffff807d73c44c0: Unable to get MiVisibleState
Unable to get NonPagedPoolStart
Unable to get NonPagedPoolEnd
Unable to get PagedPoolStart
Unable to get PagedPoolEnd
unable to get nt!MmSpecialPagesInUse
 fffff907d6aa053f
MM_INTERNAL_CODE:  2
DPC_STACK_BASE:  FFFFF80768ED0FB0
FAILED_INSTRUCTION_ADDRESS:
+0
fffff907`d6aa053f ??              ???
STACK_TEXT:
fffff807`68ec8568 fffff807`d66b8d88     : 00000000`00000050 fffff907`d6aa053f 00000000`00000010 fffff807`68ec87d0 : nt!KeBugCheckEx
fffff807`68ec8570 fffff807`d66ae760     : 00000000`00000000 ffff8000`00000000 fffff907`d6aa053f 0000007f`fffffff8 : nt!MiSystemFault+0x7a0
fffff807`68ec8660 fffff807`d6ab48cb     : 00000000`01439077 fffff807`68ec8850 fffff807`62cc6180 00000001`d2c44eb5 : nt!MmAccessFault+0x630
fffff807`68ec87d0 fffff907`d6aa053f     : fffff807`d68f3d2b 00000000`01439053 fffff807`68ec8aa0 ffffe590`d8b66bcb : nt!KiPageFault+0x38b
fffff807`68ec8968 fffff807`d68f3d2b     : 00000000`01439053 fffff807`68ec8aa0 ffffe590`d8b66bcb fffff807`62cce9c0 : 0xfffff907`d6aa053f
fffff807`68ec8970 fffff807`d68f4301     : 00000000`ffffffff fffff807`00000000 ffffa708`f471d010 fffff807`62cc6180 : nt!PpmIdleDefaultExecute+0x2b
fffff807`68ec89a0 fffff807`d6864ac0     : fffff807`62cc6180 fffff807`62cc6180 fffff807`68ec8b99 fffff807`62cce9c0 : nt!PpmIdleExecuteTransition+0x5a9
fffff807`68ec8b30 fffff807`d6aa6674     : fffff807`62cc6180 fffff807`62cc6100 00000000`001a7500 fffff807`6291b600 : nt!PoIdle+0x1c0
fffff807`68ec8c00 00000000`00000000     : fffff807`68ec9000 fffff807`68ec2000 00000000`00000000 00000000`00000000 : nt!KiIdleLoop+0x54
SYMBOL_NAME:  nt!MiSystemFault+7a0
MODULE_NAME: nt
STACK_COMMAND: .process /r /p 0xfffff807d73cef80; .thread 0xfffff807d73d1640 ; kb
BUCKET_ID_FUNC_OFFSET:  7a0
FAILURE_BUCKET_ID:  AV_X_(null)_BAD_IP_nt!MiSystemFault
OSNAME:  Windows 10
FAILURE_ID_HASH:  {519102ae-339f-c953-2278-3f0bfcf5aa85}
KMODE_EXCEPTION_NOT_HANDLED (1e)
This is a very common BugCheck.  Usually the exception address pinpoints
the driver/function that caused the problem.  Always note this address
as well as the link date of the driver/image that contains this address.
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff80627906064, The address that the exception occurred at
Arg3: 0000000000000000, Parameter 0 of the exception
Arg4: ffffe10f116a0800, Parameter 1 of the exception
Debugging Details:
Unable to load image amdkmdag.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for amdkmdag.sys
    Value: 1062
    Value: 2722
    Value: 0
    Value: 1
    Value: 0
    Value: 343
    Value: 3267
    Value: 84
    Value: 1.2503.24.1
    Value: 0x1e
    Value: 0x1e
    Value: 0x31008
    Value: 1
    Value: 0x0
    Value: 1
    Value: 0
    Value: AV_R_amdkmdag!unknown_function
    Value: 0xfffff80627906064
    Value: amdkmdag
    Value: 0x256064
    Key  : Failure.Hash
    Value: {d1da0bb9-c95c-08ad-7757-8c54ba35294d}
    Key  : Stack.Pointer
    Value: PRCBException
BUGCHECK_CODE:  1e
BUGCHECK_P1: ffffffffc0000005
BUGCHECK_P2: fffff80627906064
BUGCHECK_P3: 0
BUGCHECK_P4: ffffe10f116a0800
FILE_IN_CAB:  071925-16531-01.dmp
DUMP_FILE_ATTRIBUTES: 0x31008
FAULTING_THREAD:  ffffe10f795e50c0
EXCEPTION_PARAMETER1:  0000000000000000
EXCEPTION_PARAMETER2:  ffffe10f116a0800
READ_ADDRESS: fffff8067fbc44c0: Unable to get MiVisibleState
 ffffe10f116a0800
PROCESS_NAME:  appidcertstore
STACK_TEXT:
fffff806`116adeb8 00000000`00000000     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KeBugCheckEx
SYMBOL_NAME:  amdkmdag+256064
MODULE_NAME: amdkmdag
IMAGE_NAME:  amdkmdag.sys
STACK_COMMAND: .process /r /p 0xffffe10f78c810c0; .thread 0xffffe10f795e50c0 ; kb
BUCKET_ID_FUNC_OFFSET:  256064
FAILURE_BUCKET_ID:  AV_R_amdkmdag!unknown_function
OSNAME:  Windows 10
FAILURE_ID_HASH:  {d1da0bb9-c95c-08ad-7757-8c54ba35294d}
BIOS sürümüm bu şekilde. Ekran kartım da flickering sorunu olduğu için MorePowerTooldan GFXOFF yapıyorum. şu konudaki ayarlar.
    1,1 KB · Görüntüleme: 37
