SYSTEM_THREAD_EXCEPTION_NOT_HANDLED (7e)
This is a very common BugCheck. Usually the exception address pinpoints
the driver/function that caused the problem. Always note this address
as well as the link date of the driver/image that contains this address.
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff804939846f1, The address that the exception occurred at
Arg3: ffffa306be1b5638, Exception Record Address
Arg4: ffffa306be1b4e70, Context Record Address
Debugging Details:
KEY_VALUES_STRING: 1
Key : AV.Fault
Value: Read
Key : Analysis.CPU.mSec
Value: 984
Key : Analysis.Elapsed.mSec
Value: 3651
Key : Analysis.IO.Other.Mb
Value: 0
Key : Analysis.IO.Read.Mb
Value: 1
Key : Analysis.IO.Write.Mb
Value: 0
Key : Analysis.Init.CPU.mSec
Value: 296
Value: 909
Value: 91
Key : Analysis.Version.DbgEng
Value: 10.0.27725.1000
Key : Analysis.Version.Description
Value: 10.2408.27.01 amd64fre
Key : Analysis.Version.Ext
Value: 1.2408.27.1
Key : Bugcheck.Code.LegacyAPI
Value: 0x1000007e
Key : Bugcheck.Code.TargetModel
Value: 0x1000007e
Key : Failure.Bucket
Value: AV_igdkmdnd64!unknown_function
Key : Failure.Hash
Value: {f72986a3-e8f9-3600-9d7c-dd8a40f557df}
Key : WER.OS.Branch
Value: vb_release
Key : WER.OS.Version
Value: 10.0.19041.1
BUGCHECK_CODE: 7e
BUGCHECK_P1: ffffffffc0000005
BUGCHECK_P2: fffff804939846f1
BUGCHECK_P3: ffffa306be1b5638
BUGCHECK_P4: ffffa306be1b4e70
FILE_IN_CAB: 110224-8187-01.dmp
FAULTING_THREAD: ffffb00fee92f280
EXCEPTION_RECORD: ffffa306be1b5638 -- (.exr 0xffffa306be1b5638)
ExceptionAddress: fffff804939846f1 (igdkmdnd64+0x00000000004746f1)
ExceptionCode: c0000005 (Access violation)
ExceptionFlags: 00000000
NumberParameters: 2
Parameter[0]: 0000000000000000
Parameter[1]: 000000c800000510
Attempt to read from address 000000c800000510
CONTEXT: ffffa306be1b4e70 -- (.cxr 0xffffa306be1b4e70)
rax=ffff4074c0d13e7a rbx=ffffa306be1b5d18 rcx=ffffa306be1b5d18
rdx=ffffb00fee6d3000 rsi=ffffb00fed102000 rdi=ffffb00fee6d3000
rip=fffff804939846f1 rsp=ffffa306be1b5870 rbp=ffffa306be1b5c20
r8=000000c800000000 r9=0000000000000000 r10=000000c800000000
r11=cc1f000010000002 r12=ffffa306be1b6430 r13=ffffb00ff0000010
r14=ffffb00ff3326010 r15=ffffb00ff86b9270
iopl=0 nv up ei pl zr na po nc
cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00050246
igdkmdnd64+0x4746f1:
fffff804`939846f1 498b8810050000 mov rcx,qword ptr [r8+510h] ds:002b:000000c8`00000510=????????????????
Resetting default scope
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: System
READ_ADDRESS: fffff8046d0fb390: Unable to get MiVisibleState
Unable to get NonPagedPoolStart
Unable to get NonPagedPoolEnd
Unable to get PagedPoolStart
Unable to get PagedPoolEnd
unable to get nt!MmSpecialPagesInUse
000000c800000510
ERROR_CODE: (NTSTATUS) 0xc0000005 - 0x%p adresindeki y nerge 0x%p adresindeki belle e ba vurdu. Bellek u olamaz %s.
EXCEPTION_CODE_STR: c0000005
EXCEPTION_PARAMETER1: 0000000000000000
EXCEPTION_PARAMETER2: 000000c800000510
EXCEPTION_STR: 0xc0000005
STACK_TEXT:
ffffa306`be1b5870 00000009`1ff3aad8 : 00000000`00000006 ffffa306`be1b5d18 ffffb00f`ed0f0410 00000000`00000001 : igdkmdnd64+0x4746f1
ffffa306`be1b5878 00000000`00000006 : ffffa306`be1b5d18 ffffb00f`ed0f0410 00000000`00000001 00000000`00000001 : 0x00000009`1ff3aad8
ffffa306`be1b5880 ffffa306`be1b5d18 : ffffb00f`ed0f0410 00000000`00000001 00000000`00000001 ffffb00f`f0000010 : 0x6
ffffa306`be1b5888 ffffb00f`ed0f0410 : 00000000`00000001 00000000`00000001 ffffb00f`f0000010 00000000`00000000 : 0xffffa306`be1b5d18
ffffa306`be1b5890 00000000`00000001 : 00000000`00000001 ffffb00f`f0000010 00000000`00000000 00000000`00000002 : 0xffffb00f`ed0f0410
ffffa306`be1b5898 00000000`00000001 : ffffb00f`f0000010 00000000`00000000 00000000`00000002 00000000`40000100 : 0x1
ffffa306`be1b58a0 ffffb00f`f0000010 : 00000000`00000000 00000000`00000002 00000000`40000100 00000000`00000001 : 0x1
ffffa306`be1b58a8 00000000`00000000 : 00000000`00000002 00000000`40000100 00000000`00000001 fffff804`937a1965 : 0xffffb00f`f0000010
SYMBOL_NAME: igdkmdnd64+4746f1
MODULE_NAME: igdkmdnd64
IMAGE_NAME: igdkmdnd64.sys
STACK_COMMAND: .cxr 0xffffa306be1b4e70 ; kb
BUCKET_ID_FUNC_OFFSET: 4746f1
FAILURE_BUCKET_ID: AV_igdkmdnd64!unknown_function
OS_VERSION: 10.0.19041.1
BUILDLAB_STR: vb_release
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {f72986a3-e8f9-3600-9d7c-dd8a40f557df}
Followup: MachineOwner
PnpActivityId : {00000000-0000-0000-0000-000000000000}
PnpActivityTime : 133750460153950663
PnpEventInformation: 3
PnpEventInProgress : 0
PnpProblemCode : 24
PnpVetoType : 0
DeviceId : SWD\MMDEVAPI\{0.0.0.00000000}.{c2d8858e-492c-47f6-97a4-a67f1771e75d}
VetoString :
[SMBIOS Data Tables v3.3]
[DMI Version - 0]
[2.0 Calling Convention - No]
[Table Size - 1612 bytes]
Vendor American Megatrends International, LLC.
BIOS Version L3.52
BIOS Release Date 09/05/2024
BIOS ROM Size 1000000
BIOS Characteristics
07: - PCI Supported
11: - Upgradeable FLASH BIOS
15: - CD-Boot Supported
17: - BIOS ROM Socketed
19: - EDD Supported
22: - 360KB Floppy Supported
23: - 1.2MB Floppy Supported
24: - 720KB Floppy Supported
25: - 2.88MB Floppy Supported
27: - Keyboard Services Supported
32: - BIOS Vendor Reserved
00: - ACPI Supported
01: - USB Legacy Supported
BIOS Major Revision 5
BIOS Minor Revision 17
EC Firmware Major Revision 255
EC Firmware Minor Revision 255
Extended BIOS ROM Size 16 MB
Manufacturer To Be Filled By O.E.M.
Product Name A520M-HVS
Version To Be Filled By O.E.M.
Serial Number To Be Filled By O.E.M.
UUID 00000000-0000-0000-0000-000000000000
Wakeup Type Power Switch
SKUNumber To Be Filled By O.E.M.
Family To Be Filled By O.E.M.
Manufacturer ASRock
Product A520M-HVS
Version
Serial Number M80-H5000500138
Asset Tag
Feature Flags 09h
00: - Motherboard
03: - Replaceable
Location
Chassis Handle 0003h
Board Type 0ah - Processor/Memory Module
Number of Child Handles 0
Chassis Type Desktop
Serial Number
Asset Tag Number
Bootup State Safe
Power Supply State Safe
Thermal State Safe
Security Status None
OEM Defined 0
Height 0U
Number of Power Cords 1
Number of Contained Elements 0
Contained Element Size 3
[OEM Strings (Type 11) - Length 5 - Handle 000ah]
Number of Strings 1
1 To Be Filled By O.E.M.
[ (Type 256) - Length 14 - Handle 000ch]
[ (Type 256) - Length 9 - Handle 000dh]
[ (Type 256) - Length 31 - Handle 000eh]
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 000fh]
[Physical Memory Array (Type 16) - Length 23 - Handle 0010h]
Location 03h - SystemBoard/Motherboard
Use 03h - System Memory
Memory Error Correction 03h - None
Maximum Capacity 134217728KB
Memory Error Inf Handle 000fh
Number of Memory Devices 2
[Memory Array Mapped Address (Type 19) - Length 31 - Handle 0011h]
Starting Address 00000000h
Ending Address 002fffffh
Memory Array Handle 0010h
Partition Width 02
Extended Starting Address 0000000000000000h
Extended Ending Address 0000000000000000h
[Memory Array Mapped Address (Type 19) - Length 31 - Handle 0012h]
Starting Address 00400000h
Ending Address 010fffffh
Partition Width 02
[Cache Information (Type 7) - Length 27 - Handle 0013h]
Socket Designation L1 - Cache
Cache Configuration 0180h - WBEnabled Int NonSocketed L1
Maximum Cache Size 0180h - 384K
Installed Size 0180h - 384K
Supported SRAM Type 0010h - Pipeline-Burst
Current SRAM Type 0010h - Pipeline-Burst
Cache Speed 1ns
Error Correction Type Specification Reserved
System Cache Type Unified
Associativity 8-way Set-Associative
Maximum Cache Size 2 180 - 00000384l Kb
Installed Cache Size 2 180 - 00000384l Kb
[Cache Information (Type 7) - Length 27 - Handle 0014h]
Socket Designation L2 - Cache
Cache Configuration 0181h - WBEnabled Int NonSocketed L2
Maximum Cache Size 0c00h - 3072K
Installed Size 0c00h - 3072K
Cache Speed 1ns
Maximum Cache Size 2 c00 - 00003072l Kb
Installed Cache Size 2 c00 - 00003072l Kb
[Cache Information (Type 7) - Length 27 - Handle 0015h]
Socket Designation L3 - Cache
Cache Configuration 0182h - WBEnabled Int NonSocketed L3
Maximum Cache Size 8200h - 32768K
Installed Size 8200h - 32768K
Cache Speed 1ns
Associativity 16-way Set-Associative
Maximum Cache Size 2 80000200 - 00032768l Kb
Installed Cache Size 2 80000200 - 00032768l Kb
[Processor Information (Type 4) - Length 48 - Handle 0016h]
Socket Designation AM4
Processor Type Central Processor
Processor Family 6bh - AMD Zen Processor Family
Processor Manufacturer Advanced Micro Devices, Inc.
Processor ID 100f8700fffb8b17
Processor Version AMD Ryzen 5 3600 6-Core Processor
Processor Voltage 8bh - 1.1V
External Clock 100MHz
Max Speed 4200MHz
Current Speed 3600MHz
Status Enabled Populated
Processor Upgrade Socket AM4
L1 Cache Handle 0013h
L2 Cache Handle 0014h
L3 Cache Handle 0015h
Serial Number
Asset Tag Number
Part Number Unknown
Core Count 6
Core Enabled 6
Thread Count 12
Processor Characteristics fc
Enabled Characteristics:
0x 2: 64-bit Capable
0x 3: Multi-Core
0x 4: Hardware Thread
0x 5: Execute Protection
0x 6: Enhanced Virtualization
Processor Family 2 006bh - AMD Zen Processor Family
Core Count 2 6
Core Enabled 2 6
Thread Count 2 12
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 0017h]
[Memory Device (Type 17) - Length 92 - Handle 0018h]
Memory Error Info Handle 0017h
Total Width 64 bits
Data Width 64 bits
Size 8192MB
Form Factor 09h - DIMM
Device Set [None]
Device Locator DIMM 0
Bank Locator P0 CHANNEL A
Memory Type 1ah - DDR4
Type Detail 4080h - Synchronous Unbuffered (Unregistered)
Speed 3200MHz
Manufacturer Unknown
Serial Number
Asset Tag Number [String Not Specified]
Part Number IRX3200D464L16SA/8G
Attributes 1
Extended Size 0
Configured Memory Speed 3200
Minimum Voltage 1200
Maximum Voltage 1200
Configured Voltage 1200
Memory Technology 3
Memory Operating Mode Capability 8
Firmware Version 6
Module Manufacturer Id 23815
Module Product Id 0
Memory Subsystem Controller Manufacturer Id 0
Memory Subsystem Controller Product Id 0
Non-Volatile Size 0
Volatile Size 0
Cache Size 0
Logical Size 0
Extended Speed 0
Extended Configured Memory Speed 0
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 0019h]
Ending Address 00ffffffh
Memory Device Handle 0018h
Mem Array Mapped Adr Handle 0012h
Partition Row Position [Unknown]
Interleave Position [Unknown]
Interleave Data Depth [Unknown]
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 001ah]
[Memory Device (Type 17) - Length 92 - Handle 001bh]
Memory Error Info Handle 001ah
Total Width 64 bits
Data Width 64 bits
Size 8192MB
Device Set [None]
Bank Locator P0 CHANNEL B
Speed 3200MHz
Serial Number
Attributes 1
Extended Size 0
Memory Technology 3
Firmware Version 6
Module Product Id 0
Non-Volatile Size 0
Volatile Size 0
Cache Size 0
Logical Size 0
Extended Speed 0
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 001ch]
Memory Device Handle 001bh
[ (Type 256) - Length 4 - Handle 001dh]
Arguments:
Arg2: fffff801a51d46f1, The address that the exception occurred at
Arg3: fffff603a4a75628, Exception Record Address
Arg4: fffff603a4a74e60, Context Record Address
Debugging Details:
Key : AV.Fault
Value: Read
Value: 984
Value: 11879
Value: 1
Value: 1
Value: 10
Value: 312
Value: 1991
Value: 91
Value: 1.2408.27.1
Value: 0x1000007e
Value: 0x1000007e
Key : Failure.Hash
Key : WER.OS.Branch
Value: vb_release
Value: 10.0.19041.1
BUGCHECK_CODE: 7e
BUGCHECK_P2: fffff801a51d46f1
BUGCHECK_P3: fffff603a4a75628
BUGCHECK_P4: fffff603a4a74e60
FILE_IN_CAB: 110224-8015-01.dmp
FAULTING_THREAD: ffffe38183d28280
EXCEPTION_RECORD: fffff603a4a75628 -- (.exr 0xfffff603a4a75628)
ExceptionAddress: fffff801a51d46f1 (igdkmdnd64+0x00000000004746f1)
NumberParameters: 2
Parameter[1]: ffffffffffffffff
Attempt to read from address ffffffffffffffff
CONTEXT: fffff603a4a74e60 -- (.cxr 0xfffff603a4a74e60)
rax=ffff7635d6ae53d0 rbx=fffff603a4a75c38 rcx=fffff603a4a75c38
rdx=ffffe38183a2a000 rsi=ffffe3818246a000 rdi=ffffe38183a2a000
rip=fffff801a51d46f1 rsp=fffff603a4a75860 rbp=fffff603a4a75c10
r8=005f0049004d0026 r9=0000000000000014 r10=005f0049004d0026
r11=fffff603a4a75998 r12=ffffe3818263b3c0 r13=ffffe3818dcdf010
r14=ffffe3818a8a8010 r15=ffffe3818a3e4000
fffff801`a51d46f1 498b8810050000 mov rcx,qword ptr [r8+510h] ds:002b:005f0049`004d0536=????????????????
BLACKBOXWINLOGON: 1
READ_ADDRESS: fffff8017c8fb390: Unable to get MiVisibleState
ffffffffffffffff
EXCEPTION_PARAMETER2: ffffffffffffffff
STACK_TEXT:
fffff603`a4a75860 0000000c`6c994d27 : 00000000`00000006 fffff603`a4a75c38 ffffe381`824dd410 00000000`00000001 : igdkmdnd64+0x4746f1
fffff603`a4a75868 00000000`00000006 : fffff603`a4a75c38 ffffe381`824dd410 00000000`00000001 00000000`00000001 : 0x0000000c`6c994d27
fffff603`a4a75870 fffff603`a4a75c38 : ffffe381`824dd410 00000000`00000001 00000000`00000001 ffffe381`8dcdf010 : 0x6
fffff603`a4a75878 ffffe381`824dd410 : 00000000`00000001 00000000`00000001 ffffe381`8dcdf010 00000000`00000000 : 0xfffff603`a4a75c38
fffff603`a4a75880 00000000`00000001 : 00000000`00000001 ffffe381`8dcdf010 00000000`00000000 00000000`00000002 : 0xffffe381`824dd410
fffff603`a4a75888 00000000`00000001 : ffffe381`8dcdf010 00000000`00000000 00000000`00000002 00000000`40000100 : 0x1
fffff603`a4a75890 ffffe381`8dcdf010 : 00000000`00000000 00000000`00000002 00000000`40000100 00000000`00000001 : 0x1
fffff603`a4a75898 00000000`00000000 : 00000000`00000002 00000000`40000100 00000000`00000001 fffff801`a4ff1965 : 0xffffe381`8dcdf010
STACK_COMMAND: .cxr 0xfffff603a4a74e60 ; kb
OSNAME: Windows 10
[DMI Version - 0]
BIOS Version L3.52
07: - PCI Supported
19: - EDD Supported
Manufacturer ASRock
Product A520M-HVS
Version
Asset Tag
Feature Flags 09h
00: - Motherboard
03: - Replaceable
Location
Serial Number
Asset Tag Number
Bootup State Safe
Thermal State Safe
OEM Defined 0
Height 0U
Number of Strings 1
Partition Width 02
Partition Width 02
Cache Speed 1ns
Cache Speed 1ns
Cache Speed 1ns
Max Speed 4200MHz
Serial Number
Asset Tag Number
Part Number Unknown
Core Count 6
Core Enabled 6
Thread Count 12
0x 3: Multi-Core
Core Count 2 6
Core Enabled 2 6
Thread Count 2 12
Total Width 64 bits
Data Width 64 bits
Size 8192MB
Device Set [None]
Speed 3200MHz
Serial Number
Attributes 1
Extended Size 0
Memory Technology 3
Firmware Version 6
Module Product Id 0
Non-Volatile Size 0
Volatile Size 0
Cache Size 0
Logical Size 0
Extended Speed 0
Total Width 64 bits
Data Width 64 bits
Size 8192MB
Device Set [None]
Speed 3200MHz
Serial Number
Attributes 1
Extended Size 0
Memory Technology 3
Firmware Version 6
Module Product Id 0
Non-Volatile Size 0
Volatile Size 0
Cache Size 0
Logical Size 0
Extended Speed 0
Arguments:
Debugging Details:
Key : AV.Fault
Value: Read
Value: 984
Value: 3651
Value: 0
Value: 1
Value: 0
Value: 296
Value: 909
Value: 91
Value: 1.2408.27.1
Value: 0x1000007e
Value: 0x1000007e
Key : Failure.Hash
Key : WER.OS.Branch
Value: vb_release
Value: 10.0.19041.1
BUGCHECK_CODE: 7e
NumberParameters: 2
BLACKBOXWINLOGON: 1
000000c800000510
STACK_TEXT:
OSNAME: Windows 10
PnpProblemCode : 24
PnpVetoType : 0
VetoString :
[DMI Version - 0]
BIOS Version L3.52
07: - PCI Supported
19: - EDD Supported
Manufacturer ASRock
Product A520M-HVS
Version
Asset Tag
Feature Flags 09h
00: - Motherboard
03: - Replaceable
Location
Serial Number
Asset Tag Number
Bootup State Safe
Thermal State Safe
OEM Defined 0
Height 0U
Number of Strings 1
Partition Width 02
Partition Width 02
Cache Speed 1ns
Cache Speed 1ns
Cache Speed 1ns
Max Speed 4200MHz
Serial Number
Asset Tag Number
Part Number Unknown
Core Count 6
Core Enabled 6
Thread Count 12
0x 3: Multi-Core
Core Count 2 6
Core Enabled 2 6
Thread Count 2 12
Total Width 64 bits
Data Width 64 bits
Size 8192MB
Device Set [None]
Speed 3200MHz
Serial Number
Attributes 1
Extended Size 0
Memory Technology 3
Firmware Version 6
Module Product Id 0
Non-Volatile Size 0
Volatile Size 0
Cache Size 0
Logical Size 0
Extended Speed 0
Total Width 64 bits
Data Width 64 bits
Size 8192MB
Device Set [None]
Speed 3200MHz
Serial Number
Attributes 1
Extended Size 0
Memory Technology 3
Firmware Version 6
Module Product Id 0
Non-Volatile Size 0
Volatile Size 0
Cache Size 0
Logical Size 0
Extended Speed 0
Arguments:
Debugging Details:
Key : AV.Fault
Value: Read
Value: 984
Value: 11879
Value: 1
Value: 1
Value: 10
Value: 312
Value: 1991
Value: 91
Value: 1.2408.27.1
Value: 0x1000007e
Value: 0x1000007e
Key : Failure.Hash
Key : WER.OS.Branch
Value: vb_release
Value: 10.0.19041.1
BUGCHECK_CODE: 7e
NumberParameters: 2
BLACKBOXWINLOGON: 1
ffffffffffffffff
STACK_TEXT:
OSNAME: Windows 10
[DMI Version - 0]
BIOS Version L3.52
07: - PCI Supported
19: - EDD Supported
Manufacturer ASRock
Product A520M-HVS
Version
Asset Tag
Feature Flags 09h
00: - Motherboard
03: - Replaceable
Location
Serial Number
Asset Tag Number
Bootup State Safe
Thermal State Safe
OEM Defined 0
Height 0U
Number of Strings 1
Partition Width 02
Partition Width 02
Cache Speed 1ns
Cache Speed 1ns
Cache Speed 1ns
Max Speed 4200MHz
Serial Number
Asset Tag Number
Part Number Unknown
Core Count 6
Core Enabled 6
Thread Count 12
0x 3: Multi-Core
Core Count 2 6
Core Enabled 2 6
Thread Count 2 12
Total Width 64 bits
Data Width 64 bits
Size 8192MB
Device Set [None]
Speed 3200MHz
Serial Number
Attributes 1
Extended Size 0
Memory Technology 3
Firmware Version 6
Module Product Id 0
Non-Volatile Size 0
Volatile Size 0
Cache Size 0
Logical Size 0
Extended Speed 0
Total Width 64 bits
Data Width 64 bits
Size 8192MB
Device Set [None]
Speed 3200MHz
Serial Number
Attributes 1
Extended Size 0
Memory Technology 3
Firmware Version 6
Module Product Id 0
Non-Volatile Size 0
Volatile Size 0
Cache Size 0
Logical Size 0
Extended Speed 0
igdkmdnd64.sys dosyası, Intel ekran kartı sürücülerine ait.
- Grafik Sürücüsünü Güncelle: Intel ekran kartı sürücüsününen son sürümünü yüklemek hatayı belki çözebilir.
- Windows'u Güncelle: 11 kullanıyorsan 24H2 güncellemesini yapabilirsin.
- Olmazsa DDU ile sürücüyü sil ve temiz kurulum yap.
Kod:SYSTEM_THREAD_EXCEPTION_NOT_HANDLED (7e) This is a very common BugCheck. Usually the exception address pinpoints the driver/function that caused the problem. Always note this address as well as the link date of the driver/image that contains this address. Arguments: Arg1: ffffffffc0000005, The exception code that was not handled Arg2: fffff804939846f1, The address that the exception occurred at Arg3: ffffa306be1b5638, Exception Record Address Arg4: ffffa306be1b4e70, Context Record Address Debugging Details: ------------------ KEY_VALUES_STRING: 1 Key : AV.Fault Value: Read Key : Analysis.CPU.mSec Value: 984 Key : Analysis.Elapsed.mSec Value: 3651 Key : Analysis.IO.Other.Mb Value: 0 Key : Analysis.IO.Read.Mb Value: 1 Key : Analysis.IO.Write.Mb Value: 0 Key : Analysis.Init.CPU.mSec Value: 296 Key : Analysis.Init.Elapsed.mSec Value: 909 Key : Analysis.Memory.CommitPeak.Mb Value: 91 Key : Analysis.Version.DbgEng Value: 10.0.27725.1000 Key : Analysis.Version.Description Value: 10.2408.27.01 amd64fre Key : Analysis.Version.Ext Value: 1.2408.27.1 Key : Bugcheck.Code.LegacyAPI Value: 0x1000007e Key : Bugcheck.Code.TargetModel Value: 0x1000007e Key : Failure.Bucket Value: AV_igdkmdnd64!unknown_function Key : Failure.Hash Value: {f72986a3-e8f9-3600-9d7c-dd8a40f557df} Key : WER.OS.Branch Value: vb_release Key : WER.OS.Version Value: 10.0.19041.1 BUGCHECK_CODE: 7e BUGCHECK_P1: ffffffffc0000005 BUGCHECK_P2: fffff804939846f1 BUGCHECK_P3: ffffa306be1b5638 BUGCHECK_P4: ffffa306be1b4e70 FILE_IN_CAB: 110224-8187-01.dmp FAULTING_THREAD: ffffb00fee92f280 EXCEPTION_RECORD: ffffa306be1b5638 -- (.exr 0xffffa306be1b5638) ExceptionAddress: fffff804939846f1 (igdkmdnd64+0x00000000004746f1) ExceptionCode: c0000005 (Access violation) ExceptionFlags: 00000000 NumberParameters: 2 Parameter[0]: 0000000000000000 Parameter[1]: 000000c800000510 Attempt to read from address 000000c800000510 CONTEXT: ffffa306be1b4e70 -- (.cxr 0xffffa306be1b4e70) rax=ffff4074c0d13e7a rbx=ffffa306be1b5d18 rcx=ffffa306be1b5d18 rdx=ffffb00fee6d3000 rsi=ffffb00fed102000 rdi=ffffb00fee6d3000 rip=fffff804939846f1 rsp=ffffa306be1b5870 rbp=ffffa306be1b5c20 r8=000000c800000000 r9=0000000000000000 r10=000000c800000000 r11=cc1f000010000002 r12=ffffa306be1b6430 r13=ffffb00ff0000010 r14=ffffb00ff3326010 r15=ffffb00ff86b9270 iopl=0 nv up ei pl zr na po nc cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00050246 igdkmdnd64+0x4746f1: fffff804`939846f1 498b8810050000 mov rcx,qword ptr [r8+510h] ds:002b:000000c8`00000510=???????????????? Resetting default scope BLACKBOXBSD: 1 (!blackboxbsd) BLACKBOXNTFS: 1 (!blackboxntfs) BLACKBOXPNP: 1 (!blackboxpnp) BLACKBOXWINLOGON: 1 CUSTOMER_CRASH_COUNT: 1 PROCESS_NAME: System READ_ADDRESS: fffff8046d0fb390: Unable to get MiVisibleState Unable to get NonPagedPoolStart Unable to get NonPagedPoolEnd Unable to get PagedPoolStart Unable to get PagedPoolEnd unable to get nt!MmSpecialPagesInUse 000000c800000510 ERROR_CODE: (NTSTATUS) 0xc0000005 - 0x%p adresindeki y nerge 0x%p adresindeki belle e ba vurdu. Bellek u olamaz %s. EXCEPTION_CODE_STR: c0000005 EXCEPTION_PARAMETER1: 0000000000000000 EXCEPTION_PARAMETER2: 000000c800000510 EXCEPTION_STR: 0xc0000005 STACK_TEXT: ffffa306`be1b5870 00000009`1ff3aad8 : 00000000`00000006 ffffa306`be1b5d18 ffffb00f`ed0f0410 00000000`00000001 : igdkmdnd64+0x4746f1 ffffa306`be1b5878 00000000`00000006 : ffffa306`be1b5d18 ffffb00f`ed0f0410 00000000`00000001 00000000`00000001 : 0x00000009`1ff3aad8 ffffa306`be1b5880 ffffa306`be1b5d18 : ffffb00f`ed0f0410 00000000`00000001 00000000`00000001 ffffb00f`f0000010 : 0x6 ffffa306`be1b5888 ffffb00f`ed0f0410 : 00000000`00000001 00000000`00000001 ffffb00f`f0000010 00000000`00000000 : 0xffffa306`be1b5d18 ffffa306`be1b5890 00000000`00000001 : 00000000`00000001 ffffb00f`f0000010 00000000`00000000 00000000`00000002 : 0xffffb00f`ed0f0410 ffffa306`be1b5898 00000000`00000001 : ffffb00f`f0000010 00000000`00000000 00000000`00000002 00000000`40000100 : 0x1 ffffa306`be1b58a0 ffffb00f`f0000010 : 00000000`00000000 00000000`00000002 00000000`40000100 00000000`00000001 : 0x1 ffffa306`be1b58a8 00000000`00000000 : 00000000`00000002 00000000`40000100 00000000`00000001 fffff804`937a1965 : 0xffffb00f`f0000010 SYMBOL_NAME: igdkmdnd64+4746f1 MODULE_NAME: igdkmdnd64 IMAGE_NAME: igdkmdnd64.sys STACK_COMMAND: .cxr 0xffffa306be1b4e70 ; kb BUCKET_ID_FUNC_OFFSET: 4746f1 FAILURE_BUCKET_ID: AV_igdkmdnd64!unknown_function OS_VERSION: 10.0.19041.1 BUILDLAB_STR: vb_release OSPLATFORM_TYPE: x64 OSNAME: Windows 10 FAILURE_ID_HASH: {f72986a3-e8f9-3600-9d7c-dd8a40f557df} Followup: MachineOwner --------- PnpActivityId : {00000000-0000-0000-0000-000000000000} PnpActivityTime : 133750460153950663 PnpEventInformation: 3 PnpEventInProgress : 0 PnpProblemCode : 24 PnpVetoType : 0 DeviceId : SWD\MMDEVAPI\{0.0.0.00000000}.{c2d8858e-492c-47f6-97a4-a67f1771e75d} VetoString : [SMBIOS Data Tables v3.3] [DMI Version - 0] [2.0 Calling Convention - No] [Table Size - 1612 bytes] [BIOS Information (Type 0) - Length 26 - Handle 0000h] Vendor American Megatrends International, LLC. BIOS Version L3.52 BIOS Starting Address Segment f000 BIOS Release Date 09/05/2024 BIOS ROM Size 1000000 BIOS Characteristics 07: - PCI Supported 11: - Upgradeable FLASH BIOS 12: - BIOS Shadowing Supported 15: - CD-Boot Supported 16: - Selectable Boot Supported 17: - BIOS ROM Socketed 19: - EDD Supported 20: - NEC 9800 J-Floppy Supported 21: - Toshiba J-Floppy Supported 22: - 360KB Floppy Supported 23: - 1.2MB Floppy Supported 24: - 720KB Floppy Supported 25: - 2.88MB Floppy Supported 26: - Print Screen Device Supported 27: - Keyboard Services Supported 28: - Serial Services Supported 29: - Printer Services Supported 30: - CGA/Mono Services Supported 32: - BIOS Vendor Reserved BIOS Characteristic Extensions 00: - ACPI Supported 01: - USB Legacy Supported 08: - BIOS Boot Specification Supported 10: - Enable Targeted Content Distribution 11: - UEFI Specification Supported BIOS Major Revision 5 BIOS Minor Revision 17 EC Firmware Major Revision 255 EC Firmware Minor Revision 255 Extended BIOS ROM Size 16 MB [System Information (Type 1) - Length 27 - Handle 0001h] Manufacturer To Be Filled By O.E.M. Product Name A520M-HVS Version To Be Filled By O.E.M. Serial Number To Be Filled By O.E.M. UUID 00000000-0000-0000-0000-000000000000 Wakeup Type Power Switch SKUNumber To Be Filled By O.E.M. Family To Be Filled By O.E.M. [BaseBoard Information (Type 2) - Length 15 - Handle 0002h] Manufacturer ASRock Product A520M-HVS Version Serial Number M80-H5000500138 Asset Tag Feature Flags 09h 00: - Motherboard 03: - Replaceable Location Chassis Handle 0003h Board Type 0ah - Processor/Memory Module Number of Child Handles 0 [System Enclosure (Type 3) - Length 22 - Handle 0003h] Manufacturer To Be Filled By O.E.M. Chassis Type Desktop Version To Be Filled By O.E.M. Serial Number Asset Tag Number Bootup State Safe Power Supply State Safe Thermal State Safe Security Status None OEM Defined 0 Height 0U Number of Power Cords 1 Number of Contained Elements 0 Contained Element Size 3 [OEM Strings (Type 11) - Length 5 - Handle 000ah] Number of Strings 1 1 To Be Filled By O.E.M. [ (Type 256) - Length 14 - Handle 000ch] [ (Type 256) - Length 9 - Handle 000dh] [ (Type 256) - Length 31 - Handle 000eh] [32Bit Memory Error Information (Type 18) - Length 23 - Handle 000fh] [Physical Memory Array (Type 16) - Length 23 - Handle 0010h] Location 03h - SystemBoard/Motherboard Use 03h - System Memory Memory Error Correction 03h - None Maximum Capacity 134217728KB Memory Error Inf Handle 000fh Number of Memory Devices 2 [Memory Array Mapped Address (Type 19) - Length 31 - Handle 0011h] Starting Address 00000000h Ending Address 002fffffh Memory Array Handle 0010h Partition Width 02 Extended Starting Address 0000000000000000h Extended Ending Address 0000000000000000h [Memory Array Mapped Address (Type 19) - Length 31 - Handle 0012h] Starting Address 00400000h Ending Address 010fffffh Memory Array Handle 0010h Partition Width 02 Extended Starting Address 0000000000000000h Extended Ending Address 0000000000000000h [Cache Information (Type 7) - Length 27 - Handle 0013h] Socket Designation L1 - Cache Cache Configuration 0180h - WBEnabled Int NonSocketed L1 Maximum Cache Size 0180h - 384K Installed Size 0180h - 384K Supported SRAM Type 0010h - Pipeline-Burst Current SRAM Type 0010h - Pipeline-Burst Cache Speed 1ns Error Correction Type Specification Reserved System Cache Type Unified Associativity 8-way Set-Associative Maximum Cache Size 2 180 - 00000384l Kb Installed Cache Size 2 180 - 00000384l Kb [Cache Information (Type 7) - Length 27 - Handle 0014h] Socket Designation L2 - Cache Cache Configuration 0181h - WBEnabled Int NonSocketed L2 Maximum Cache Size 0c00h - 3072K Installed Size 0c00h - 3072K Supported SRAM Type 0010h - Pipeline-Burst Current SRAM Type 0010h - Pipeline-Burst Cache Speed 1ns Error Correction Type Specification Reserved System Cache Type Unified Associativity 8-way Set-Associative Maximum Cache Size 2 c00 - 00003072l Kb Installed Cache Size 2 c00 - 00003072l Kb [Cache Information (Type 7) - Length 27 - Handle 0015h] Socket Designation L3 - Cache Cache Configuration 0182h - WBEnabled Int NonSocketed L3 Maximum Cache Size 8200h - 32768K Installed Size 8200h - 32768K Supported SRAM Type 0010h - Pipeline-Burst Current SRAM Type 0010h - Pipeline-Burst Cache Speed 1ns Error Correction Type Specification Reserved System Cache Type Unified Associativity 16-way Set-Associative Maximum Cache Size 2 80000200 - 00032768l Kb Installed Cache Size 2 80000200 - 00032768l Kb [Processor Information (Type 4) - Length 48 - Handle 0016h] Socket Designation AM4 Processor Type Central Processor Processor Family 6bh - AMD Zen Processor Family Processor Manufacturer Advanced Micro Devices, Inc. Processor ID 100f8700fffb8b17 Processor Version AMD Ryzen 5 3600 6-Core Processor Processor Voltage 8bh - 1.1V External Clock 100MHz Max Speed 4200MHz Current Speed 3600MHz Status Enabled Populated Processor Upgrade Socket AM4 L1 Cache Handle 0013h L2 Cache Handle 0014h L3 Cache Handle 0015h Serial Number Asset Tag Number Part Number Unknown Core Count 6 Core Enabled 6 Thread Count 12 Processor Characteristics fc Enabled Characteristics: 0x 2: 64-bit Capable 0x 3: Multi-Core 0x 4: Hardware Thread 0x 5: Execute Protection 0x 6: Enhanced Virtualization 0x 7: Power/Performance Control Processor Family 2 006bh - AMD Zen Processor Family Core Count 2 6 Core Enabled 2 6 Thread Count 2 12 [32Bit Memory Error Information (Type 18) - Length 23 - Handle 0017h] [Memory Device (Type 17) - Length 92 - Handle 0018h] Memory Error Info Handle 0017h Total Width 64 bits Data Width 64 bits Size 8192MB Form Factor 09h - DIMM Device Set [None] Device Locator DIMM 0 Bank Locator P0 CHANNEL A Memory Type 1ah - DDR4 Type Detail 4080h - Synchronous Unbuffered (Unregistered) Speed 3200MHz Manufacturer Unknown Serial Number Asset Tag Number [String Not Specified] Part Number IRX3200D464L16SA/8G Attributes 1 Extended Size 0 Configured Memory Speed 3200 Minimum Voltage 1200 Maximum Voltage 1200 Configured Voltage 1200 Memory Technology 3 Memory Operating Mode Capability 8 Firmware Version 6 Module Manufacturer Id 23815 Module Product Id 0 Memory Subsystem Controller Manufacturer Id 0 Memory Subsystem Controller Product Id 0 Non-Volatile Size 0 Volatile Size 0 Cache Size 0 Logical Size 0 Extended Speed 0 Extended Configured Memory Speed 0 [Memory Device Mapped Address (Type 20) - Length 35 - Handle 0019h] Starting Address 00000000h Ending Address 00ffffffh Memory Device Handle 0018h Mem Array Mapped Adr Handle 0012h Partition Row Position [Unknown] Interleave Position [Unknown] Interleave Data Depth [Unknown] Extended Starting Address 0000000000000000h Extended Ending Address 0000000000000000h [32Bit Memory Error Information (Type 18) - Length 23 - Handle 001ah] [Memory Device (Type 17) - Length 92 - Handle 001bh] Memory Error Info Handle 001ah Total Width 64 bits Data Width 64 bits Size 8192MB Form Factor 09h - DIMM Device Set [None] Device Locator DIMM 0 Bank Locator P0 CHANNEL B Memory Type 1ah - DDR4 Type Detail 4080h - Synchronous Unbuffered (Unregistered) Speed 3200MHz Manufacturer Unknown Serial Number Asset Tag Number [String Not Specified] Part Number IRX3200D464L16SA/8G Attributes 1 Extended Size 0 Configured Memory Speed 3200 Minimum Voltage 1200 Maximum Voltage 1200 Configured Voltage 1200 Memory Technology 3 Memory Operating Mode Capability 8 Firmware Version 6 Module Manufacturer Id 23815 Module Product Id 0 Memory Subsystem Controller Manufacturer Id 0 Memory Subsystem Controller Product Id 0 Non-Volatile Size 0 Volatile Size 0 Cache Size 0 Logical Size 0 Extended Speed 0 Extended Configured Memory Speed 0 [Memory Device Mapped Address (Type 20) - Length 35 - Handle 001ch] Starting Address 00000000h Ending Address 00ffffffh Memory Device Handle 001bh Mem Array Mapped Adr Handle 0012h Partition Row Position [Unknown] Interleave Position [Unknown] Interleave Data Depth [Unknown] Extended Starting Address 0000000000000000h Extended Ending Address 0000000000000000h [ (Type 256) - Length 4 - Handle 001dh] SYSTEM_THREAD_EXCEPTION_NOT_HANDLED (7e) This is a very common BugCheck. Usually the exception address pinpoints the driver/function that caused the problem. Always note this address as well as the link date of the driver/image that contains this address. Arguments: Arg1: ffffffffc0000005, The exception code that was not handled Arg2: fffff801a51d46f1, The address that the exception occurred at Arg3: fffff603a4a75628, Exception Record Address Arg4: fffff603a4a74e60, Context Record Address Debugging Details: ------------------ KEY_VALUES_STRING: 1 Key : AV.Fault Value: Read Key : Analysis.CPU.mSec Value: 984 Key : Analysis.Elapsed.mSec Value: 11879 Key : Analysis.IO.Other.Mb Value: 1 Key : Analysis.IO.Read.Mb Value: 1 Key : Analysis.IO.Write.Mb Value: 10 Key : Analysis.Init.CPU.mSec Value: 312 Key : Analysis.Init.Elapsed.mSec Value: 1991 Key : Analysis.Memory.CommitPeak.Mb Value: 91 Key : Analysis.Version.DbgEng Value: 10.0.27725.1000 Key : Analysis.Version.Description Value: 10.2408.27.01 amd64fre Key : Analysis.Version.Ext Value: 1.2408.27.1 Key : Bugcheck.Code.LegacyAPI Value: 0x1000007e Key : Bugcheck.Code.TargetModel Value: 0x1000007e Key : Failure.Bucket Value: AV_igdkmdnd64!unknown_function Key : Failure.Hash Value: {f72986a3-e8f9-3600-9d7c-dd8a40f557df} Key : WER.OS.Branch Value: vb_release Key : WER.OS.Version Value: 10.0.19041.1 BUGCHECK_CODE: 7e BUGCHECK_P1: ffffffffc0000005 BUGCHECK_P2: fffff801a51d46f1 BUGCHECK_P3: fffff603a4a75628 BUGCHECK_P4: fffff603a4a74e60 FILE_IN_CAB: 110224-8015-01.dmp FAULTING_THREAD: ffffe38183d28280 EXCEPTION_RECORD: fffff603a4a75628 -- (.exr 0xfffff603a4a75628) ExceptionAddress: fffff801a51d46f1 (igdkmdnd64+0x00000000004746f1) ExceptionCode: c0000005 (Access violation) ExceptionFlags: 00000000 NumberParameters: 2 Parameter[0]: 0000000000000000 Parameter[1]: ffffffffffffffff Attempt to read from address ffffffffffffffff CONTEXT: fffff603a4a74e60 -- (.cxr 0xfffff603a4a74e60) rax=ffff7635d6ae53d0 rbx=fffff603a4a75c38 rcx=fffff603a4a75c38 rdx=ffffe38183a2a000 rsi=ffffe3818246a000 rdi=ffffe38183a2a000 rip=fffff801a51d46f1 rsp=fffff603a4a75860 rbp=fffff603a4a75c10 r8=005f0049004d0026 r9=0000000000000014 r10=005f0049004d0026 r11=fffff603a4a75998 r12=ffffe3818263b3c0 r13=ffffe3818dcdf010 r14=ffffe3818a8a8010 r15=ffffe3818a3e4000 iopl=0 nv up ei pl zr na po nc cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00050246 igdkmdnd64+0x4746f1: fffff801`a51d46f1 498b8810050000 mov rcx,qword ptr [r8+510h] ds:002b:005f0049`004d0536=???????????????? Resetting default scope BLACKBOXBSD: 1 (!blackboxbsd) BLACKBOXNTFS: 1 (!blackboxntfs) BLACKBOXWINLOGON: 1 CUSTOMER_CRASH_COUNT: 1 PROCESS_NAME: System READ_ADDRESS: fffff8017c8fb390: Unable to get MiVisibleState Unable to get NonPagedPoolStart Unable to get NonPagedPoolEnd Unable to get PagedPoolStart Unable to get PagedPoolEnd unable to get nt!MmSpecialPagesInUse ffffffffffffffff ERROR_CODE: (NTSTATUS) 0xc0000005 - 0x%p adresindeki y nerge 0x%p adresindeki belle e ba vurdu. Bellek u olamaz %s. EXCEPTION_CODE_STR: c0000005 EXCEPTION_PARAMETER1: 0000000000000000 EXCEPTION_PARAMETER2: ffffffffffffffff EXCEPTION_STR: 0xc0000005 STACK_TEXT: fffff603`a4a75860 0000000c`6c994d27 : 00000000`00000006 fffff603`a4a75c38 ffffe381`824dd410 00000000`00000001 : igdkmdnd64+0x4746f1 fffff603`a4a75868 00000000`00000006 : fffff603`a4a75c38 ffffe381`824dd410 00000000`00000001 00000000`00000001 : 0x0000000c`6c994d27 fffff603`a4a75870 fffff603`a4a75c38 : ffffe381`824dd410 00000000`00000001 00000000`00000001 ffffe381`8dcdf010 : 0x6 fffff603`a4a75878 ffffe381`824dd410 : 00000000`00000001 00000000`00000001 ffffe381`8dcdf010 00000000`00000000 : 0xfffff603`a4a75c38 fffff603`a4a75880 00000000`00000001 : 00000000`00000001 ffffe381`8dcdf010 00000000`00000000 00000000`00000002 : 0xffffe381`824dd410 fffff603`a4a75888 00000000`00000001 : ffffe381`8dcdf010 00000000`00000000 00000000`00000002 00000000`40000100 : 0x1 fffff603`a4a75890 ffffe381`8dcdf010 : 00000000`00000000 00000000`00000002 00000000`40000100 00000000`00000001 : 0x1 fffff603`a4a75898 00000000`00000000 : 00000000`00000002 00000000`40000100 00000000`00000001 fffff801`a4ff1965 : 0xffffe381`8dcdf010 SYMBOL_NAME: igdkmdnd64+4746f1 MODULE_NAME: igdkmdnd64 IMAGE_NAME: igdkmdnd64.sys STACK_COMMAND: .cxr 0xfffff603a4a74e60 ; kb BUCKET_ID_FUNC_OFFSET: 4746f1 FAILURE_BUCKET_ID: AV_igdkmdnd64!unknown_function OS_VERSION: 10.0.19041.1 BUILDLAB_STR: vb_release OSPLATFORM_TYPE: x64 OSNAME: Windows 10 FAILURE_ID_HASH: {f72986a3-e8f9-3600-9d7c-dd8a40f557df} Followup: MachineOwner --------- [SMBIOS Data Tables v3.3] [DMI Version - 0] [2.0 Calling Convention - No] [Table Size - 1612 bytes] [BIOS Information (Type 0) - Length 26 - Handle 0000h] Vendor American Megatrends International, LLC. BIOS Version L3.52 BIOS Starting Address Segment f000 BIOS Release Date 09/05/2024 BIOS ROM Size 1000000 BIOS Characteristics 07: - PCI Supported 11: - Upgradeable FLASH BIOS 12: - BIOS Shadowing Supported 15: - CD-Boot Supported 16: - Selectable Boot Supported 17: - BIOS ROM Socketed 19: - EDD Supported 20: - NEC 9800 J-Floppy Supported 21: - Toshiba J-Floppy Supported 22: - 360KB Floppy Supported 23: - 1.2MB Floppy Supported 24: - 720KB Floppy Supported 25: - 2.88MB Floppy Supported 26: - Print Screen Device Supported 27: - Keyboard Services Supported 28: - Serial Services Supported 29: - Printer Services Supported 30: - CGA/Mono Services Supported 32: - BIOS Vendor Reserved BIOS Characteristic Extensions 00: - ACPI Supported 01: - USB Legacy Supported 08: - BIOS Boot Specification Supported 10: - Enable Targeted Content Distribution 11: - UEFI Specification Supported BIOS Major Revision 5 BIOS Minor Revision 17 EC Firmware Major Revision 255 EC Firmware Minor Revision 255 Extended BIOS ROM Size 16 MB [System Information (Type 1) - Length 27 - Handle 0001h] Manufacturer To Be Filled By O.E.M. Product Name A520M-HVS Version To Be Filled By O.E.M. Serial Number To Be Filled By O.E.M. UUID 00000000-0000-0000-0000-000000000000 Wakeup Type Power Switch SKUNumber To Be Filled By O.E.M. Family To Be Filled By O.E.M. [BaseBoard Information (Type 2) - Length 15 - Handle 0002h] Manufacturer ASRock Product A520M-HVS Version Serial Number M80-H5000500138 Asset Tag Feature Flags 09h 00: - Motherboard 03: - Replaceable Location Chassis Handle 0003h Board Type 0ah - Processor/Memory Module Number of Child Handles 0 [System Enclosure (Type 3) - Length 22 - Handle 0003h] Manufacturer To Be Filled By O.E.M. Chassis Type Desktop Version To Be Filled By O.E.M. Serial Number Asset Tag Number Bootup State Safe Power Supply State Safe Thermal State Safe Security Status None OEM Defined 0 Height 0U Number of Power Cords 1 Number of Contained Elements 0 Contained Element Size 3 [OEM Strings (Type 11) - Length 5 - Handle 000ah] Number of Strings 1 1 To Be Filled By O.E.M. [ (Type 256) - Length 14 - Handle 000ch] [ (Type 256) - Length 9 - Handle 000dh] [ (Type 256) - Length 31 - Handle 000eh] [32Bit Memory Error Information (Type 18) - Length 23 - Handle 000fh] [Physical Memory Array (Type 16) - Length 23 - Handle 0010h] Location 03h - SystemBoard/Motherboard Use 03h - System Memory Memory Error Correction 03h - None Maximum Capacity 134217728KB Memory Error Inf Handle 000fh Number of Memory Devices 2 [Memory Array Mapped Address (Type 19) - Length 31 - Handle 0011h] Starting Address 00000000h Ending Address 002fffffh Memory Array Handle 0010h Partition Width 02 Extended Starting Address 0000000000000000h Extended Ending Address 0000000000000000h [Memory Array Mapped Address (Type 19) - Length 31 - Handle 0012h] Starting Address 00400000h Ending Address 010fffffh Memory Array Handle 0010h Partition Width 02 Extended Starting Address 0000000000000000h Extended Ending Address 0000000000000000h [Cache Information (Type 7) - Length 27 - Handle 0013h] Socket Designation L1 - Cache Cache Configuration 0180h - WBEnabled Int NonSocketed L1 Maximum Cache Size 0180h - 384K Installed Size 0180h - 384K Supported SRAM Type 0010h - Pipeline-Burst Current SRAM Type 0010h - Pipeline-Burst Cache Speed 1ns Error Correction Type Specification Reserved System Cache Type Unified Associativity 8-way Set-Associative Maximum Cache Size 2 180 - 00000384l Kb Installed Cache Size 2 180 - 00000384l Kb [Cache Information (Type 7) - Length 27 - Handle 0014h] Socket Designation L2 - Cache Cache Configuration 0181h - WBEnabled Int NonSocketed L2 Maximum Cache Size 0c00h - 3072K Installed Size 0c00h - 3072K Supported SRAM Type 0010h - Pipeline-Burst Current SRAM Type 0010h - Pipeline-Burst Cache Speed 1ns Error Correction Type Specification Reserved System Cache Type Unified Associativity 8-way Set-Associative Maximum Cache Size 2 c00 - 00003072l Kb Installed Cache Size 2 c00 - 00003072l Kb [Cache Information (Type 7) - Length 27 - Handle 0015h] Socket Designation L3 - Cache Cache Configuration 0182h - WBEnabled Int NonSocketed L3 Maximum Cache Size 8200h - 32768K Installed Size 8200h - 32768K Supported SRAM Type 0010h - Pipeline-Burst Current SRAM Type 0010h - Pipeline-Burst Cache Speed 1ns Error Correction Type Specification Reserved System Cache Type Unified Associativity 16-way Set-Associative Maximum Cache Size 2 80000200 - 00032768l Kb Installed Cache Size 2 80000200 - 00032768l Kb [Processor Information (Type 4) - Length 48 - Handle 0016h] Socket Designation AM4 Processor Type Central Processor Processor Family 6bh - AMD Zen Processor Family Processor Manufacturer Advanced Micro Devices, Inc. Processor ID 100f8700fffb8b17 Processor Version AMD Ryzen 5 3600 6-Core Processor Processor Voltage 8bh - 1.1V External Clock 100MHz Max Speed 4200MHz Current Speed 3600MHz Status Enabled Populated Processor Upgrade Socket AM4 L1 Cache Handle 0013h L2 Cache Handle 0014h L3 Cache Handle 0015h Serial Number Asset Tag Number Part Number Unknown Core Count 6 Core Enabled 6 Thread Count 12 Processor Characteristics fc Enabled Characteristics: 0x 2: 64-bit Capable 0x 3: Multi-Core 0x 4: Hardware Thread 0x 5: Execute Protection 0x 6: Enhanced Virtualization 0x 7: Power/Performance Control Processor Family 2 006bh - AMD Zen Processor Family Core Count 2 6 Core Enabled 2 6 Thread Count 2 12 [32Bit Memory Error Information (Type 18) - Length 23 - Handle 0017h] [Memory Device (Type 17) - Length 92 - Handle 0018h] Memory Error Info Handle 0017h Total Width 64 bits Data Width 64 bits Size 8192MB Form Factor 09h - DIMM Device Set [None] Device Locator DIMM 0 Bank Locator P0 CHANNEL A Memory Type 1ah - DDR4 Type Detail 4080h - Synchronous Unbuffered (Unregistered) Speed 3200MHz Manufacturer Unknown Serial Number Asset Tag Number [String Not Specified] Part Number IRX3200D464L16SA/8G Attributes 1 Extended Size 0 Configured Memory Speed 3200 Minimum Voltage 1200 Maximum Voltage 1200 Configured Voltage 1200 Memory Technology 3 Memory Operating Mode Capability 8 Firmware Version 6 Module Manufacturer Id 23815 Module Product Id 0 Memory Subsystem Controller Manufacturer Id 0 Memory Subsystem Controller Product Id 0 Non-Volatile Size 0 Volatile Size 0 Cache Size 0 Logical Size 0 Extended Speed 0 Extended Configured Memory Speed 0 [Memory Device Mapped Address (Type 20) - Length 35 - Handle 0019h] Starting Address 00000000h Ending Address 00ffffffh Memory Device Handle 0018h Mem Array Mapped Adr Handle 0012h Partition Row Position [Unknown] Interleave Position [Unknown] Interleave Data Depth [Unknown] Extended Starting Address 0000000000000000h Extended Ending Address 0000000000000000h [32Bit Memory Error Information (Type 18) - Length 23 - Handle 001ah] [Memory Device (Type 17) - Length 92 - Handle 001bh] Memory Error Info Handle 001ah Total Width 64 bits Data Width 64 bits Size 8192MB Form Factor 09h - DIMM Device Set [None] Device Locator DIMM 0 Bank Locator P0 CHANNEL B Memory Type 1ah - DDR4 Type Detail 4080h - Synchronous Unbuffered (Unregistered) Speed 3200MHz Manufacturer Unknown Serial Number Asset Tag Number [String Not Specified] Part Number IRX3200D464L16SA/8G Attributes 1 Extended Size 0 Configured Memory Speed 3200 Minimum Voltage 1200 Maximum Voltage 1200 Configured Voltage 1200 Memory Technology 3 Memory Operating Mode Capability 8 Firmware Version 6 Module Manufacturer Id 23815 Module Product Id 0 Memory Subsystem Controller Manufacturer Id 0 Memory Subsystem Controller Product Id 0 Non-Volatile Size 0 Volatile Size 0 Cache Size 0 Logical Size 0 Extended Speed 0 Extended Configured Memory Speed 0 [Memory Device Mapped Address (Type 20) - Length 35 - Handle 001ch] Starting Address 00000000h Ending Address 00ffffffh Memory Device Handle 001bh Mem Array Mapped Adr Handle 0012h Partition Row Position [Unknown] Interleave Position [Unknown] Interleave Data Depth [Unknown] Extended Starting Address 0000000000000000h Extended Ending Address 0000000000000000h [ (Type 256) - Length 4 - Handle 001dh]
We use cookies and similar technologies for the following purposes:
Do you accept cookies and these technologies?
