16513 00:00:37.518032 ERROR 791e [Loading] C:\BuildAgent\work\fd76be73d7b9a640\src\tlib\gfx\d3d12\commond3d12.h(81): in "d3dCallImpl()": D3D is of memory, see the log for details
options.xml dosyası C:\Users\KULLANICI ADIN\AppData\Local\Teardown\options.xml konumunda olmalı.%AppData% yaz.<registry version="1.5.1">
<options>
<display>
<mode value="1"/>
<resolution value="2"/>
<index value="0"/>
</display>
<gfx>
<gfxapi value="0"/>
<d3d12support value="0"/>
</gfx>
</options>
</registry>
strncpy at 0x000000000016a95a
_C_specific_handler at 0x000000000012ebb3
_chkstk at 0x000000000016720f
RtlGetExtendedContextLength at 0x0000000000082ced
KiUserExceptionDispatcher at 0x0000000000166b4e
0x00000000002825a4
0x0000000000337470
0x0000000000331be2
0x00000000000eb03f
0x00000000000ce8e7
0x00000000000c561a
0x000000000005d401
0x000000000006562f
0x00000000002940c6
BaseThreadInitThunk at 0x0000000000035767
RtlUserThreadStart at 0x0000000000053bec
KEY_VALUES_STRING: 1
Key : AV.Dereference
Value: NullPtr
Key : AV.Fault
Value: Write
Key : Analysis.CPU.mSec
Value: 421
Key : Analysis.Elapsed.mSec
Value: 539
Key : Analysis.IO.Other.Mb
Value: 0
Key : Analysis.IO.Read.Mb
Value: 0
Key : Analysis.IO.Write.Mb
Value: 0
Key : Analysis.Init.CPU.mSec
Value: 124
Value: 2463
Value: 107
Key : Failure.Bucket
Value: NULL_POINTER_WRITE_c0000005_teardown.exe!Unknown
Key : Failure.Hash
Value: {ecf8c185-a887-44d8-2270-b3bf14c14b52}
Key : Timeline.OS.Boot.DeltaSec
Value: 26521
Key : Timeline.Process.Start.DeltaSec
Value: 39
Key : WER.OS.Branch
Value: rs_prerelease
Key : WER.OS.Version
Value: 10.0.27686.1000
Key : WER.Process.Version
Value: 1.0.0.1
FILE_IN_CAB: minidump.dmp
CONTEXT: (.ecxr)
rax=0000000000000000 rbx=000000fcfaf9f330 rcx=0000000000000001
rdx=0000027eba5c0840 rsi=000000008007000e rdi=0000048651a7b9a0
rip=00007ff7c0b525a4 rsp=000000fcfaf9f0c0 rbp=000000fcfaf9f210
r8=7ffffffffffffffc r9=8101010101010100 r10=00000485f0000000
r11=000000fcfaf9f0a0 r12=00000000ffffffff r13=000000000000000b
r14=00000485531705c0 r15=0000000000000000
iopl=0 nv up ei pl zr na po nc
cs=0033 ss=002b ds=002b es=002b fs=0053 gs=002b efl=00010246
teardown+0x2825a4:
00007ff7`c0b525a4 89042500000000 mov dword ptr [0],eax ds:00000000`00000000=????????
Resetting default scope
EXCEPTION_RECORD: (.exr -1)
ExceptionAddress: 00007ff7c0b525a4 (teardown+0x00000000002825a4)
ExceptionCode: c0000005 (Access violation)
ExceptionFlags: 00000000
NumberParameters: 2
Parameter[0]: 0000000000000001
Parameter[1]: 0000000000000000
Attempt to write to address 0000000000000000
PROCESS_NAME: teardown.exe
WRITE_ADDRESS: 0000000000000000
ERROR_CODE: (NTSTATUS) 0xc0000005 - 0x%p adresindeki y nerge 0x%p adresindeki belle e ba vurdu. Bellek u olamaz %s.
EXCEPTION_CODE_STR: c0000005
EXCEPTION_PARAMETER1: 0000000000000001
EXCEPTION_PARAMETER2: 0000000000000000
IP_ON_STACK:
+0
000000fc`faf9f330 0100 add dword ptr [rax],eax
FRAME_ONE_INVALID: 1
STACK_TEXT:
000000fc`faf9f0c0 000000fc`faf9f330 : 000000fc`faf9f210 00000486`51f30000 00007ff7`c0bf022e 00007ff7`c106ead0 : teardown+0x2825a4
000000fc`faf9f0c8 000000fc`faf9f210 : 00000486`51f30000 00007ff7`c0bf022e 00007ff7`c106ead0 000000fc`faf9f138 : 0x000000fc`faf9f330
000000fc`faf9f0d0 00000486`51f30000 : 00007ff7`c0bf022e 00007ff7`c106ead0 000000fc`faf9f138 00000000`00000000 : 0x000000fc`faf9f210
000000fc`faf9f0d8 00007ff7`c0bf022e : 00007ff7`c106ead0 000000fc`faf9f138 00000000`00000000 00000486`51f30000 : 0x00000486`51f30000
000000fc`faf9f0e0 00007ff7`c106ead0 : 000000fc`faf9f138 00000000`00000000 00000486`51f30000 00000486`51a7b9a0 : teardown+0x32022e
000000fc`faf9f0e8 000000fc`faf9f138 : 00000000`00000000 00000486`51f30000 00000486`51a7b9a0 00007ff7`c0c07470 : teardown+0x79ead0
000000fc`faf9f0f0 00000000`00000000 : 00000486`51f30000 00000486`51a7b9a0 00007ff7`c0c07470 000000fc`faf9f330 : 0x000000fc`faf9f138
SYMBOL_NAME: teardown+2825a4
MODULE_NAME: teardown
IMAGE_NAME: teardown.exe
STACK_COMMAND: ~33s; .ecxr ; kb
FAILURE_BUCKET_ID: NULL_POINTER_WRITE_c0000005_teardown.exe!Unknown
OS_VERSION: 10.0.27686.1000
BUILDLAB_STR: rs_prerelease
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
IMAGE_VERSION: 1.0.0.1
FAILURE_ID_HASH: {ecf8c185-a887-44d8-2270-b3bf14c14b52}
Followup: MachineOwner
0000 00:00:00.171923 INFO 9577 [Init] Platform available: 1
0000 00:00:00.178678 INFO 9577 [Init] CPU: Intel(R) Core(TM) i5-10400F CPU @ 2.90GHz
Hardware threads: 12
Physical memory: 16322 Mb
Display resolution: 2560x1080
Executable path: C:/Program Files (x86)/Steam/steamapps/common/Teardown/teardown.exe
Working dir: C:/Program Files (x86)/Steam/steamapps/common/Teardown
Appdata dir: C:/Users/Kaan/AppData/Local
Documents dir: C:/Users/Kaan/Documents
0000 00:00:00.655917 INFO 9577 [Init] Starting up in resolution: 2560x1080
0000 00:00:00.845921 INFO 9577 [Init|Render] Graphics API: D3D12
0000 00:00:01.605596 INFO 9577 [Init|Render] Vendor: Amd
Renderer: AMD Radeon RX 5600 XT
Total VRAM: 6103 Mb
Available VRAM: 5335 Mb
0000 00:00:01.610699 INFO 9577 [Init|Render] GPU vendor: Amd
Indirect arguments supported:
Draw
Draw indexed
Vertex buffer view
Index buffer view
Push CBV
Bindless support: true
Conservative depth support: true
Compute shader support: true
Constant buffer alignment: 256
Frame memory alloc max size: 1048576
Wave lane count num: 32
Wave operations support: true
Max 1D texture size: 16384
Max 2D texture size: 16384
Max 3D texture size: 2048
Max cubemap texture size: 16384
Max array texture layers: 2048
0000 00:00:04.109863 INFO dc42 [] Promo folder up to date
0000 00:00:05.301239 ERROR 9577 [] TSwapChainD3D12::setFullScreen:699 mSwapChain->SetFullscreenState(isFullScreen, isFullScreen ? pTarget : nullptr) return HRESULT=887a0022
0000 00:00:05.342699 INFO 9577 [Window] New display settings: display index = 0, window mode = 0, window width = 2560, window height = 1080
0000 00:00:05.470944 INFO 9577 [] DXGI changed display state of swap chain. Current state is windowed
0000 00:00:05.470948 INFO 9577 [] Window changed state after swap buffers
0001 00:00:05.543210 INFO 9577 [] Restore window state: display idx = 0, window mode = 0, resolution index = 0
0001 00:00:05.784754 INFO 9577 [Window] New display settings: display index = 0, window mode = 0, window width = 2560, window height = 1080
5836 00:00:16.289570 INFO 791e [Loading] Loading: data/bin/mansion_sandbox.bin
16507 00:00:37.513172 ERROR 791e [Loading] TTextureD3D12::TTextureD3D12:147 pGPUAllocator->CreateResource( &allocationDesc, &textureDesc, D3D12_RESOURCE_STATE_COMMON, nullptr, allocation.GetAddressOf(), IID_ID3D12Resource, nullptr) return HRESULT=8007000e
16511 00:00:37.516685 ERROR 791e [Loading] {
"General": {
"API": "Direct3D 12",
"GPU": "AMD Radeon RX 5600 XT",
"DedicatedVideoMemory": 6399987712,
"DedicatedSystemMemory": 0,
"SharedSystemMemory": 8557434880,
"ResourceHeapTier": 2,
"ResourceBindingTier": 3,
"TiledResourcesTier": 3,
"TileBasedRenderer": false,
"UMA": false,
"CacheCoherentUMA": false
"Total": {
"BlockCount": 1203,
"BlockBytes": 13687586816,
"AllocationCount": 2507,
"AllocationBytes": 13648314368,
"UnusedRangeCount": 3,
"AllocationSizeMin": 4096,
"AllocationSizeMax": 675020800,
"UnusedRangeSizeMin": 16384,
"UnusedRangeSizeMax": 30932992
"MemoryInfo": {
"L0": {
"Budget": {
"BudgetBytes": 7861127680,
"UsageBytes": 189128704
"Stats": {
"BlockCount": 3,
"BlockBytes": 142606336,
"AllocationCount": 13,
"AllocationBytes": 103350272,
"UnusedRangeCount": 2,
"AllocationSizeMin": 65536,
"AllocationSizeMax": 33554432,
"UnusedRangeSizeMin": 8323072,
"MemoryPools": {
"UPLOAD": {
"Stats": {
"BlockCount": 2,
"BlockBytes": 134217728,
"AllocationCount": 12,
"AllocationBytes": 103284736,
"UnusedRangeCount": 1,
"AllocationSizeMin": 1048576,
"READBACK": {
"Stats": {
"BlockCount": 1,
"BlockBytes": 8388608,
"AllocationCount": 1,
"AllocationBytes": 65536,
"CUSTOM": {
"Stats": {
"BlockCount": 0,
"BlockBytes": 0,
"AllocationCount": 0,
"AllocationBytes": 0,
"UnusedRangeCount": 0
"L1": {
"Budget": {
"BudgetBytes": 4721565696,
"UsageBytes": 13770129408
"Stats": {
"BlockCount": 1200,
"BlockBytes": 13544980480,
"AllocationCount": 2494,
"AllocationBytes": 13544964096,
"MemoryPools": {
"DEFAULT": {
"Stats": {
"BlockCount": 1200,
"CUSTOM": {
"Stats": {
"BlockCount": 0,
"BlockBytes": 0,
"DefaultPools": {
"DEFAULT": {
"Flags": [],
"PreferredBlockSize": 67108864,
"Blocks": {
"0": {
"TotalBytes": 33554432,
"UnusedBytes": 0,
"Allocations": 27,
"UnusedRanges": 0,
"Suballocations": [
{"Offset": 0, "Type": "TEXTURE2D", "Size": 15400960, "Usage": 2},
{"Offset": 15400960, "Type": "BUFFER", "Size": 65536, "Usage": 0, "Layout": 1},
{"Offset": 15466496, "Type": "BUFFER", "Size": 65536, "Usage": 0, "Layout": 1},
{"Offset": 15532032, "Type": "BUFFER", "Size": 65536, "Usage": 0, "Layout": 1},
{"Offset": 15597568, "Type": "BUFFER", "Size": 65536, "Usage": 0, "Layout": 1},
{"Offset": 15663104, "Type": "BUFFER", "Size": 65536, "Usage": 0, "Layout": 1},
{"Offset": 15728640, "Type": "BUFFER", "Size": 65536, "Usage": 0, "Layout": 1},
{"Offset": 15794176, "Type": "BUFFER", "Size": 65536, "Usage": 0, "Layout": 1},
{"Offset": 15859712, "Type": "BUFFER", "Size": 65536, "Usage": 0, "Layout": 1},
Müsait olduğum en kısa süre içerisinde raporu paylaşacağım hocam, ilginiz için teşekkür ederimEvet, bir ProcMon raporu belki işe yarayabilir.
C:\Users\Kaan\AppData\Local\Teardown\crashŞu klasörün içeriğini paylaşır mısın?
<options>
<display>
<mode value="1"/>
<index value="0"/>
</display>
<gfx>
<gfxapi value="0"/>
</gfx>
</options>
</registry>
0x00000000002825a4
0x0000000000337470
0x0000000000331be2
0x00000000000eb03f
0x00000000000ce8e7
0x00000000000c561a
0x000000000005d401
0x000000000006562f
0x00000000002940c6
Value: NullPtr
Key : AV.Fault
Value: Write
Value: 421
Value: 539
Value: 0
Value: 0
Value: 0
Value: 124
Value: 2463
Value: 107
Key : Failure.Hash
Value: 26521
Value: 39
Key : WER.OS.Branch
Value: 1.0.0.1
CONTEXT: (.ecxr)
teardown+0x2825a4:
NumberParameters: 2
IP_ON_STACK:
+0
STACK_TEXT:
OSNAME: Windows 10
Total VRAM: 6103 Mb
Draw
Draw indexed
Vertex buffer view
Index buffer view
Push CBV
"General": {
"UMA": false,
"Total": {
"BlockCount": 1203,
"MemoryInfo": {
"L0": {
"Budget": {
"Stats": {
"BlockCount": 3,
"MemoryPools": {
"UPLOAD": {
"Stats": {
"BlockCount": 2,
"READBACK": {
"Stats": {
"BlockCount": 1,
"CUSTOM": {
"Stats": {
"BlockCount": 0,
"BlockBytes": 0,
"L1": {
"Budget": {
"Stats": {
"BlockCount": 1200,
"MemoryPools": {
"DEFAULT": {
"Stats": {
"BlockCount": 1200,
"CUSTOM": {
"Stats": {
"BlockCount": 0,
"BlockBytes": 0,
"DefaultPools": {
"DEFAULT": {
"Flags": [],
"Blocks": {
"0": {
"UnusedBytes": 0,
"Allocations": 27,
"UnusedRanges": 0,
"Suballocations": [
Ayarlar'dan Graphics kısmında yer alan Graphics API'yi OpenGL seçince sorunum çözüldü, size minnettarımŞimdi.... Hatamız bu:
Kod:16513 00:00:37.518032 ERROR 791e [Loading] C:\BuildAgent\work\fd76be73d7b9a640\src\tlib\gfx\d3d12\commond3d12.h(81): in "d3dCallImpl()": D3D is of memory, see the log for details
Efsaneye göre oyunu DirectX 12 yerine OpenGL ile çalıştırırsanız bu sorun ortadan kalkıyor. Çökmeyen harita ile oyunu aç.
Settings > Graphics kısmına gir. En altta menüyü aç ve OpenGL'i seç, sonra da Apply de.
Oyun hiç açılmıyorsa:
options.xmldosyasıC:\Users\KULLANICI ADIN\AppData\Local\Teardown\options.xmlkonumunda olmalı.
(AppData klasörünü görmek için Windows'ta Gizli dosya ve klasörleri göster seçeneğini etkinleştirmen gerek)
Veya “Win + R” tuşlarına basın ve%AppData%yaz.
Bir metin düzenleyici (notepad++) ile “options.xml” dosyasını açın ve bu kodu yapıştır:
Kod:<registry version="1.5.1"> <options> <display> <mode value="1"/> <resolution value="2"/> <index value="0"/> </display> <gfx> <gfxapi value="0"/> <d3d12support value="0"/> </gfx> </options> </registry>
Kod:strncpy at 0x000000000016a95a _C_specific_handler at 0x000000000012ebb3 _chkstk at 0x000000000016720f RtlGetExtendedContextLength at 0x0000000000082ced KiUserExceptionDispatcher at 0x0000000000166b4e 0x00000000002825a4 0x0000000000337470 0x0000000000331be2 0x00000000000eb03f 0x00000000000ce8e7 0x00000000000c561a 0x000000000005d401 0x000000000006562f 0x00000000002940c6 BaseThreadInitThunk at 0x0000000000035767 RtlUserThreadStart at 0x0000000000053bec
Kod:KEY_VALUES_STRING: 1 Key : AV.Dereference Value: NullPtr Key : AV.Fault Value: Write Key : Analysis.CPU.mSec Value: 421 Key : Analysis.Elapsed.mSec Value: 539 Key : Analysis.IO.Other.Mb Value: 0 Key : Analysis.IO.Read.Mb Value: 0 Key : Analysis.IO.Write.Mb Value: 0 Key : Analysis.Init.CPU.mSec Value: 124 Key : Analysis.Init.Elapsed.mSec Value: 2463 Key : Analysis.Memory.CommitPeak.Mb Value: 107 Key : Failure.Bucket Value: NULL_POINTER_WRITE_c0000005_teardown.exe!Unknown Key : Failure.Hash Value: {ecf8c185-a887-44d8-2270-b3bf14c14b52} Key : Timeline.OS.Boot.DeltaSec Value: 26521 Key : Timeline.Process.Start.DeltaSec Value: 39 Key : WER.OS.Branch Value: rs_prerelease Key : WER.OS.Version Value: 10.0.27686.1000 Key : WER.Process.Version Value: 1.0.0.1 FILE_IN_CAB: minidump.dmp CONTEXT: (.ecxr) rax=0000000000000000 rbx=000000fcfaf9f330 rcx=0000000000000001 rdx=0000027eba5c0840 rsi=000000008007000e rdi=0000048651a7b9a0 rip=00007ff7c0b525a4 rsp=000000fcfaf9f0c0 rbp=000000fcfaf9f210 r8=7ffffffffffffffc r9=8101010101010100 r10=00000485f0000000 r11=000000fcfaf9f0a0 r12=00000000ffffffff r13=000000000000000b r14=00000485531705c0 r15=0000000000000000 iopl=0 nv up ei pl zr na po nc cs=0033 ss=002b ds=002b es=002b fs=0053 gs=002b efl=00010246 teardown+0x2825a4: 00007ff7`c0b525a4 89042500000000 mov dword ptr [0],eax ds:00000000`00000000=???????? Resetting default scope EXCEPTION_RECORD: (.exr -1) ExceptionAddress: 00007ff7c0b525a4 (teardown+0x00000000002825a4) ExceptionCode: c0000005 (Access violation) ExceptionFlags: 00000000 NumberParameters: 2 Parameter[0]: 0000000000000001 Parameter[1]: 0000000000000000 Attempt to write to address 0000000000000000 PROCESS_NAME: teardown.exe WRITE_ADDRESS: 0000000000000000 ERROR_CODE: (NTSTATUS) 0xc0000005 - 0x%p adresindeki y nerge 0x%p adresindeki belle e ba vurdu. Bellek u olamaz %s. EXCEPTION_CODE_STR: c0000005 EXCEPTION_PARAMETER1: 0000000000000001 EXCEPTION_PARAMETER2: 0000000000000000 IP_ON_STACK: +0 000000fc`faf9f330 0100 add dword ptr [rax],eax FRAME_ONE_INVALID: 1 STACK_TEXT: 000000fc`faf9f0c0 000000fc`faf9f330 : 000000fc`faf9f210 00000486`51f30000 00007ff7`c0bf022e 00007ff7`c106ead0 : teardown+0x2825a4 000000fc`faf9f0c8 000000fc`faf9f210 : 00000486`51f30000 00007ff7`c0bf022e 00007ff7`c106ead0 000000fc`faf9f138 : 0x000000fc`faf9f330 000000fc`faf9f0d0 00000486`51f30000 : 00007ff7`c0bf022e 00007ff7`c106ead0 000000fc`faf9f138 00000000`00000000 : 0x000000fc`faf9f210 000000fc`faf9f0d8 00007ff7`c0bf022e : 00007ff7`c106ead0 000000fc`faf9f138 00000000`00000000 00000486`51f30000 : 0x00000486`51f30000 000000fc`faf9f0e0 00007ff7`c106ead0 : 000000fc`faf9f138 00000000`00000000 00000486`51f30000 00000486`51a7b9a0 : teardown+0x32022e 000000fc`faf9f0e8 000000fc`faf9f138 : 00000000`00000000 00000486`51f30000 00000486`51a7b9a0 00007ff7`c0c07470 : teardown+0x79ead0 000000fc`faf9f0f0 00000000`00000000 : 00000486`51f30000 00000486`51a7b9a0 00007ff7`c0c07470 000000fc`faf9f330 : 0x000000fc`faf9f138 SYMBOL_NAME: teardown+2825a4 MODULE_NAME: teardown IMAGE_NAME: teardown.exe STACK_COMMAND: ~33s; .ecxr ; kb FAILURE_BUCKET_ID: NULL_POINTER_WRITE_c0000005_teardown.exe!Unknown OS_VERSION: 10.0.27686.1000 BUILDLAB_STR: rs_prerelease OSPLATFORM_TYPE: x64 OSNAME: Windows 10 IMAGE_VERSION: 1.0.0.1 FAILURE_ID_HASH: {ecf8c185-a887-44d8-2270-b3bf14c14b52} Followup: MachineOwner ---------
Kod:0000 00:00:00.171923 INFO 9577 [Init] Platform available: 1 0000 00:00:00.178678 INFO 9577 [Init] CPU: Intel(R) Core(TM) i5-10400F CPU @ 2.90GHz Hardware threads: 12 Physical memory: 16322 Mb Display resolution: 2560x1080 Executable path: C:/Program Files (x86)/Steam/steamapps/common/Teardown/teardown.exe Working dir: C:/Program Files (x86)/Steam/steamapps/common/Teardown Appdata dir: C:/Users/Kaan/AppData/Local Documents dir: C:/Users/Kaan/Documents 0000 00:00:00.655917 INFO 9577 [Init] Starting up in resolution: 2560x1080 0000 00:00:00.845921 INFO 9577 [Init|Render] Graphics API: D3D12 0000 00:00:01.605596 INFO 9577 [Init|Render] Vendor: Amd Renderer: AMD Radeon RX 5600 XT Total VRAM: 6103 Mb Available VRAM: 5335 Mb 0000 00:00:01.610699 INFO 9577 [Init|Render] GPU vendor: Amd Indirect arguments supported: Draw Draw indexed Vertex buffer view Index buffer view Push CBV Bindless support: true Conservative depth support: true Compute shader support: true Constant buffer alignment: 256 Frame memory alloc max size: 1048576 Wave lane count num: 32 Wave operations support: true Max 1D texture size: 16384 Max 2D texture size: 16384 Max 3D texture size: 2048 Max cubemap texture size: 16384 Max array texture layers: 2048 0000 00:00:04.109863 INFO dc42 [] Promo folder up to date 0000 00:00:05.301239 ERROR 9577 [] TSwapChainD3D12::setFullScreen:699 mSwapChain->SetFullscreenState(isFullScreen, isFullScreen ? pTarget : nullptr) return HRESULT=887a0022 0000 00:00:05.342699 INFO 9577 [Window] New display settings: display index = 0, window mode = 0, window width = 2560, window height = 1080 0000 00:00:05.470944 INFO 9577 [] DXGI changed display state of swap chain. Current state is windowed 0000 00:00:05.470948 INFO 9577 [] Window changed state after swap buffers 0001 00:00:05.543210 INFO 9577 [] Restore window state: display idx = 0, window mode = 0, resolution index = 0 0001 00:00:05.784754 INFO 9577 [Window] New display settings: display index = 0, window mode = 0, window width = 2560, window height = 1080 5836 00:00:16.289570 INFO 791e [Loading] Loading: data/bin/mansion_sandbox.bin 16507 00:00:37.513172 ERROR 791e [Loading] TTextureD3D12::TTextureD3D12:147 pGPUAllocator->CreateResource( &allocationDesc, &textureDesc, D3D12_RESOURCE_STATE_COMMON, nullptr, allocation.GetAddressOf(), IID_ID3D12Resource, nullptr) return HRESULT=8007000e 16511 00:00:37.516685 ERROR 791e [Loading] { "General": { "API": "Direct3D 12", "GPU": "AMD Radeon RX 5600 XT", "DedicatedVideoMemory": 6399987712, "DedicatedSystemMemory": 0, "SharedSystemMemory": 8557434880, "ResourceHeapTier": 2, "ResourceBindingTier": 3, "TiledResourcesTier": 3, "TileBasedRenderer": false, "UMA": false, "CacheCoherentUMA": false }, "Total": { "BlockCount": 1203, "BlockBytes": 13687586816, "AllocationCount": 2507, "AllocationBytes": 13648314368, "UnusedRangeCount": 3, "AllocationSizeMin": 4096, "AllocationSizeMax": 675020800, "UnusedRangeSizeMin": 16384, "UnusedRangeSizeMax": 30932992 }, "MemoryInfo": { "L0": { "Budget": { "BudgetBytes": 7861127680, "UsageBytes": 189128704 }, "Stats": { "BlockCount": 3, "BlockBytes": 142606336, "AllocationCount": 13, "AllocationBytes": 103350272, "UnusedRangeCount": 2, "AllocationSizeMin": 65536, "AllocationSizeMax": 33554432, "UnusedRangeSizeMin": 8323072, "UnusedRangeSizeMax": 30932992 }, "MemoryPools": { "UPLOAD": { "Stats": { "BlockCount": 2, "BlockBytes": 134217728, "AllocationCount": 12, "AllocationBytes": 103284736, "UnusedRangeCount": 1, "AllocationSizeMin": 1048576, "AllocationSizeMax": 33554432 } }, "READBACK": { "Stats": { "BlockCount": 1, "BlockBytes": 8388608, "AllocationCount": 1, "AllocationBytes": 65536, "UnusedRangeCount": 1 } }, "CUSTOM": { "Stats": { "BlockCount": 0, "BlockBytes": 0, "AllocationCount": 0, "AllocationBytes": 0, "UnusedRangeCount": 0 } } } }, "L1": { "Budget": { "BudgetBytes": 4721565696, "UsageBytes": 13770129408 }, "Stats": { "BlockCount": 1200, "BlockBytes": 13544980480, "AllocationCount": 2494, "AllocationBytes": 13544964096, "UnusedRangeCount": 1, "AllocationSizeMin": 4096, "AllocationSizeMax": 675020800 }, "MemoryPools": { "DEFAULT": { "Stats": { "BlockCount": 1200, "BlockBytes": 13544980480, "AllocationCount": 2494, "AllocationBytes": 13544964096, "UnusedRangeCount": 1, "AllocationSizeMin": 4096, "AllocationSizeMax": 675020800 } }, "CUSTOM": { "Stats": { "BlockCount": 0, "BlockBytes": 0, "AllocationCount": 0, "AllocationBytes": 0, "UnusedRangeCount": 0 } } } } }, "DefaultPools": { "DEFAULT": { "Flags": [], "PreferredBlockSize": 67108864, "Blocks": { "0": { "TotalBytes": 33554432, "UnusedBytes": 0, "Allocations": 27, "UnusedRanges": 0, "Suballocations": [ {"Offset": 0, "Type": "TEXTURE2D", "Size": 15400960, "Usage": 2}, {"Offset": 15400960, "Type": "BUFFER", "Size": 65536, "Usage": 0, "Layout": 1}, {"Offset": 15466496, "Type": "BUFFER", "Size": 65536, "Usage": 0, "Layout": 1}, {"Offset": 15532032, "Type": "BUFFER", "Size": 65536, "Usage": 0, "Layout": 1}, {"Offset": 15597568, "Type": "BUFFER", "Size": 65536, "Usage": 0, "Layout": 1}, {"Offset": 15663104, "Type": "BUFFER", "Size": 65536, "Usage": 0, "Layout": 1}, {"Offset": 15728640, "Type": "BUFFER", "Size": 65536, "Usage": 0, "Layout": 1}, {"Offset": 15794176, "Type": "BUFFER", "Size": 65536, "Usage": 0, "Layout": 1}, {"Offset": 15859712, "Type": "BUFFER", "Size": 65536, "Usage": 0, "Layout": 1}, 16513 00:00:37.518032 ERROR 791e [Loading] C:\BuildAgent\work\fd76be73d7b9a640\src\tlib\gfx\d3d12\commond3d12.h(81): in "d3dCallImpl()": D3D is of memory, see the log for details
O mapi açmaya video belleği yetmiyor olabilir mi diyorsunuz yani? Eskiden açılıyordu hocam, son zamanlarda başladı bu problem. Grafik ayarlarını olabildiğince aza çekmeme rağmen maalesef D3D12'de map açılmıyor, OpenGL'de açılıyor ama 3/4'ü donuyor bir süre sonra. Arkada 1 program bile kalmayacak şekilde tüm programlari görev yöneticisinden kapatmama rağmen yine de aynı 2 sorun var. Çok tuhaf.Video belleği yetmiyor olabilir mi?
We use cookies and similar technologies for the following purposes:
Do you accept cookies and these technologies?
