SYSTEM_SERVICE_EXCEPTION (3b)
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000005, Exception code that caused the BugCheck
Arg2: fffff80248571eb4, Address of the instruction which caused the BugCheck
Arg3: ffffba8cefa55aa0, Address of the context record for the exception that caused the BugCheck
Arg4: 0000000000000000, zero.
Debugging Details:
KEY_VALUES_STRING: 1
Key : Analysis.CPU.mSec
Value: 890
Key : Analysis.Elapsed.mSec
Value: 36552
Key : Analysis.IO.Other.Mb
Value: 1
Key : Analysis.IO.Read.Mb
Value: 1
Key : Analysis.IO.Write.Mb
Value: 5
Key : Analysis.Init.CPU.mSec
Value: 312
Value: 6822
Value: 82
Key : Analysis.Version.DbgEng
Value: 10.0.27829.1001
Key : Analysis.Version.Description
Value: 10.2503.24.01 amd64fre
Key : Analysis.Version.Ext
Value: 1.2503.24.1
Key : Bugcheck.Code.LegacyAPI
Value: 0x3b
Key : Bugcheck.Code.TargetModel
Value: 0x3b
Key : Dump.Attributes.AsUlong
Value: 0x8
Key : Dump.Attributes.KernelGeneratedTriageDump
Value: 1
Key : Failure.Bucket
Value: AV_Ntfs!NtfsAddIndexEntry
Key : Failure.Exception.IP.Address
Value: 0xfffff80248571eb4
Key : Failure.Exception.IP.Module
Value: Ntfs
Key : Failure.Exception.IP.Offset
Value: 0x131eb4
Key : Failure.Hash
Value: {a989ac34-8c31-a0c6-6587-8efb490b861b}
BUGCHECK_CODE: 3b
BUGCHECK_P1: c0000005
BUGCHECK_P2: fffff80248571eb4
BUGCHECK_P3: ffffba8cefa55aa0
BUGCHECK_P4: 0
FILE_IN_CAB: 070925-4453-01.dmp
DUMP_FILE_ATTRIBUTES: 0x8
Kernel Generated Triage Dump
FAULTING_THREAD: ffffbd83f5ee10c0
CONTEXT: ffffba8cefa55aa0 -- (.cxr 0xffffba8cefa55aa0)
rax=0000000010000201 rbx=ffffbd83f0892ad8 rcx=0000000000000000
rdx=0000000000000000 rsi=ffff95816f489180 rdi=ffff95816f489180
rip=fffff80248571eb4 rsp=ffffba8cefa564a0 rbp=ffffba8cefa568e9
r8=00000000ffffffff r9=7fffbd83f23a4a68 r10=7ffffffffffffffc
r11=ffffba8cefa563b0 r12=0000000000000000 r13=ffff958172ba7a90
r14=ffff95816fb043e0 r15=ffff95817210cac0
iopl=0 nv up ei ng nz na po nc
cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00050286
Ntfs!NtfsAddIndexEntry+0x16c:
fffff802`48571eb4 f7420400002000 test dword ptr [rdx+4],200000h ds:002b:00000000`00000004=????????
Resetting default scope
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: steam.exe
STACK_TEXT:
ffffba8c`efa564a0 fffff802`48571cc8 : ffffba8c`efa569b4 ffffba8c`00000000 ffff9581`72ba75a0 00000000`00000000 : Ntfs!NtfsAddIndexEntry+0x16c
ffffba8c`efa56710 fffff802`48571765 : ffffbd83`f0892ad8 ffff9581`6fb443e0 ffff9581`72ba75a0 ffff9581`7210cac0 : Ntfs!NtfsAddNameToParent+0x444
ffffba8c`efa56810 fffff802`4856e826 : 00000000`00000002 ffff9581`72ba7700 ffff9581`72ba79f8 ffffba8c`efa570d0 : Ntfs!NtfsAddLink+0x189
ffffba8c`efa56930 fffff802`48532113 : ffffbd83`f0892ad8 ffff9581`6fb443e0 ffff9581`7210cac0 ffffba8c`efa570d0 : Ntfs!NtfsCreateNewFile+0x1996
ffffba8c`efa56ce0 fffff802`4852c68b : ffffbd83`f636e060 ffffba8c`efa570d0 ffffbd83`f636e060 00000000`00000000 : Ntfs!NtfsCommonCreate+0x14b3
ffffba8c`efa56fc0 fffff802`43e1f0e5 : ffffbd83`e86a0030 ffffbd83`f636e060 ffffba8c`efa57300 ffffbd83`f41b7440 : Ntfs!NtfsFsdCreate+0x1db
ffffba8c`efa57240 fffff802`4235710f : ffffbd83`f41b7400 ffffba8c`efa57330 ffffba8c`efa57339 fffff802`42355f7a : nt!IofCallDriver+0x55
ffffba8c`efa57280 fffff802`42389ee4 : ffffba8c`efa57330 ffffbd83`f41b7498 ffffbd83`e869d080 00000000`00000000 : FLTMGR!FltpLegacyProcessingAfterPreCallbacksCompleted+0x28f
ffffba8c`efa572f0 fffff802`43e1f0e5 : 00000000`00000000 ffffbd83`e8611b70 00000000`00000000 00000000`00000000 : FLTMGR!FltpCreate+0x324
ffffba8c`efa573a0 fffff802`43e35d64 : 00000000`00000003 ffffbd83`f636e060 00000000`6d4e6f49 fffff802`43e35993 : nt!IofCallDriver+0x55
ffffba8c`efa573e0 fffff802`44217be9 : ffffba8c`efa57690 ffffbd83`e8611b70 ffffbd83`f41b74d8 00000000`00000000 : nt!IoCallDriverWithTracing+0x34
ffffba8c`efa57430 fffff802`4420bd97 : ffffbd83`e8611b70 ffffbd83`e8611b40 ffffbd83`f23cf520 ffff9581`5e1b2601 : nt!IopParseDevice+0x11a9
ffffba8c`efa57590 fffff802`442142fa : ffffbd83`f23cf501 ffffba8c`efa577f8 00000000`00000040 ffffbd83`e3b622a0 : nt!ObpLookupObjectName+0x1117
ffffba8c`efa57760 fffff802`442ed8d1 : 00000000`00000000 00000000`0b94ed20 00000000`0b94e468 00000000`00000000 : nt!ObOpenObjectByNameEx+0x1fa
ffffba8c`efa57890 fffff802`442ecda9 : 00000000`0b94e450 00000000`40100080 00000000`0b94ed20 00000000`0b94e468 : nt!IopCreateFile+0xb11
ffffba8c`efa57940 fffff802`44011f05 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!NtCreateFile+0x79
ffffba8c`efa579d0 00007ffb`1e1adf94 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x25
00000000`0b94e3d8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ffb`1e1adf94
SYMBOL_NAME: Ntfs!NtfsAddIndexEntry+16c
MODULE_NAME: Ntfs
IMAGE_NAME: Ntfs.sys
IMAGE_VERSION: 10.0.19041.5915
STACK_COMMAND: .cxr 0xffffba8cefa55aa0 ; kb
BUCKET_ID_FUNC_OFFSET: 16c
FAILURE_BUCKET_ID: AV_Ntfs!NtfsAddIndexEntry
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {a989ac34-8c31-a0c6-6587-8efb490b861b}
Followup: MachineOwner
[SMBIOS Data Tables v3.4]
[DMI Version - 0]
[2.0 Calling Convention - No]
[Table Size - 5889 bytes]
Vendor American Megatrends International, LLC.
BIOS Version 1.10
BIOS Release Date 02/16/2022
BIOS ROM Size 1000000
BIOS Characteristics
07: - PCI Supported
11: - Upgradeable FLASH BIOS
15: - CD-Boot Supported
17: - BIOS ROM Socketed
19: - EDD Supported
22: - 360KB Floppy Supported
23: - 1.2MB Floppy Supported
24: - 720KB Floppy Supported
25: - 2.88MB Floppy Supported
27: - Keyboard Services Supported
32: - BIOS Vendor Reserved
01: - USB Legacy Supported
BIOS Major Revision 5
BIOS Minor Revision 24
EC Firmware Major Revision 255
EC Firmware Minor Revision 255
Extended BIOS ROM Size 32 MB
Manufacturer Micro-Star International Co., Ltd.
Product Name MS-7D46
Version 1.0
Serial Number Default string
UUID 00000000-0000-0000-0000-000000000000
Wakeup Type Power Switch
SKUNumber Default string
Family Default string
Product H610M BOMBER DDR4 (MS-7D46)
Version 1.0
Serial Number 07D4612_M31E311731
Asset Tag
Feature Flags 09h
00: - Motherboard
03: - Replaceable
Location Default string
Chassis Handle 0003h
Board Type 0ah - Processor/Memory Module
Number of Child Handles 0
Chassis Type Desktop
Version 1.0
Serial Number
Asset Tag Number
Bootup State Safe
Power Supply State Safe
Thermal State Safe
Security Status None
OEM Defined 0
Height 0U
Number of Power Cords 1
Number of Contained Elements 0
Contained Element Size 3
[OEM Strings (Type 11) - Length 5 - Handle 0021h]
Number of Strings 1
1 Default string
[System Configuration Options (Type 12) - Length 5 - Handle 0022h]
[ (Type 256) - Length 9 - Handle 0039h]
[Physical Memory Array (Type 16) - Length 23 - Handle 003ah]
Location 03h - SystemBoard/Motherboard
Use 03h - System Memory
Memory Error Correction 03h - None
Maximum Capacity 67108864KB
Memory Error Inf Handle [Not Provided]
Number of Memory Devices 4
[Memory Device (Type 17) - Length 92 - Handle 003bh]
Memory Error Info Handle [Not Provided]
Total Width 64 bits
Data Width 64 bits
Size 8192MB
Form Factor 09h - DIMM
Device Set [None]
Device Locator Controller0-DIMMA1
Bank Locator BANK 0
Memory Type 1ah - DDR4
Type Detail 0080h - Synchronous
Speed 2133MHz
Manufacturer G Skill Intl
Serial Number
Asset Tag Number
Part Number F4-3200C16-8GVKB
Attributes 1
Extended Size 0
Configured Memory Speed 2133
Minimum Voltage 1200
Maximum Voltage 1200
Configured Voltage 1200
Memory Technology 3
Memory Operating Mode Capability 8
Firmware Version 0
Module Manufacturer Id 52484
Module Product Id 0
Memory Subsystem Controller Manufacturer Id 0
Memory Subsystem Controller Product Id 0
Non-Volatile Size 0
Volatile Size 0
Cache Size 0
Logical Size 0
Extended Speed 0
Extended Configured Memory Speed 0
[Memory Device (Type 17) - Length 92 - Handle 003ch]
Total Width 64 bits
Data Width 64 bits
Size 8192MB
Device Set [None]
Device Locator Controller1-DIMMB1
Bank Locator BANK 0
Speed 2133MHz
Serial Number
Asset Tag Number
Attributes 1
Extended Size 0
Memory Technology 3
Firmware Version 0
Module Product Id 0
Non-Volatile Size 0
Volatile Size 0
Cache Size 0
Logical Size 0
Extended Speed 0
[Memory Array Mapped Address (Type 19) - Length 31 - Handle 003dh]
Starting Address 00000000h
Ending Address 00ffffffh
Memory Array Handle 003ah
Partition Width 02
Extended Starting Address 0000000000000000h
Extended Ending Address 0000000000000000h
[ (Type 256) - Length 31 - Handle 003eh]
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 003fh]
Ending Address 007fffffh
Memory Device Handle 003bh
Mem Array Mapped Adr Handle 003dh
Partition Row Position [Unknown]
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 0040h]
Starting Address 00800000h
Memory Device Handle 003ch
[ (Type 256) - Length 12 - Handle 0041h]
[ (Type 256) - Length 26 - Handle 0042h]
[ (Type 256) - Length 26 - Handle 0043h]
[ (Type 256) - Length 47 - Handle 0044h]
[ (Type 256) - Length 82 - Handle 0045h]
[Cache Information (Type 7) - Length 27 - Handle 0046h]
Socket Designation L1 Cache
Cache Configuration 0180h - WBEnabled Int NonSocketed L1
Maximum Cache Size 00c0h - 192K
Installed Size 00c0h - 192K
Supported SRAM Type 0020h - Synchronous
Current SRAM Type 0020h - Synchronous
Cache Speed 0ns
Error Correction Type ParitySingle-Bit ECC
System Cache Type Data
Associativity 12-way Set-Associative
Maximum Cache Size 2 c0 - 00000192l Kb
Installed Cache Size 2 c0 - 00000192l Kb
[Cache Information (Type 7) - Length 27 - Handle 0047h]
Maximum Cache Size 0080h - 128K
Installed Size 0080h - 128K
Cache Speed 0ns
System Cache Type Instruction
Associativity 8-way Set-Associative
Maximum Cache Size 2 80 - 00000128l Kb
Installed Cache Size 2 80 - 00000128l Kb
[Cache Information (Type 7) - Length 27 - Handle 0048h]
Socket Designation L2 Cache
Cache Configuration 0181h - WBEnabled Int NonSocketed L2
Maximum Cache Size 1400h - 5120K
Installed Size 1400h - 5120K
Cache Speed 0ns
Error Correction Type Multi-Bit ECC
System Cache Type Unified
Associativity Other
Maximum Cache Size 2 1400 - 00005120l Kb
Installed Cache Size 2 1400 - 00005120l Kb
[Cache Information (Type 7) - Length 27 - Handle 0049h]
Socket Designation L3 Cache
Cache Configuration 0182h - WBEnabled Int NonSocketed L3
Maximum Cache Size 3000h - 12288K
Installed Size 3000h - 12288K
Cache Speed 0ns
Error Correction Type Specification Reserved
Maximum Cache Size 2 3000 - 00012288l Kb
Installed Cache Size 2 3000 - 00012288l Kb
[Processor Information (Type 4) - Length 48 - Handle 004ah]
Socket Designation U3E1
Processor Type Central Processor
Processor Family ceh - Intel Core 2 Extreme processor
Processor Manufacturer Intel(R) Corporation
Processor ID 75060900fffbebbf
Processor Version 12th Gen Intel(R) Core(TM) i3-12100F
Processor Voltage 8ah - 1.0V
External Clock 100MHz
Max Speed 4300MHz
Current Speed 3267MHz
Status Enabled Populated
Processor Upgrade Other
L1 Cache Handle 0047h
L2 Cache Handle 0048h
L3 Cache Handle 0049h
Serial Number
Asset Tag Number
Part Number To Be Filled By O.E.M.
Core Count 4
Core Enabled 4
Thread Count 8
Processor Characteristics fc
Enabled Characteristics:
0x 2: 64-bit Capable
0x 3: Multi-Core
0x 4: Hardware Thread
0x 5: Execute Protection
0x 6: Enhanced Virtualization
Processor Family 2 00ceh - Intel Core 2 Extreme processor
Core Count 2 4
Core Enabled 2 4
Thread Count 2 8
[ (Type 256) - Length 64 - Handle 004bh]
[ (Type 256) - Length 11 - Handle 004ch]
[ (Type 256) - Length 11 - Handle 004dh]
[ (Type 256) - Length 11 - Handle 004eh]
[ (Type 256) - Length 11 - Handle 004fh]
[ (Type 256) - Length 11 - Handle 0050h]
[ (Type 256) - Length 11 - Handle 0051h]
[ (Type 256) - Length 11 - Handle 0052h]
[ (Type 256) - Length 11 - Handle 0053h]
[ (Type 256) - Length 11 - Handle 0054h]
[ (Type 256) - Length 11 - Handle 0055h]
[ (Type 256) - Length 11 - Handle 0056h]
[ (Type 256) - Length 11 - Handle 0057h]
[ (Type 256) - Length 82 - Handle 0058h]
[ (Type 256) - Length 16 - Handle 0059h]
[ (Type 256) - Length 44 - Handle 0085h]
[ (Type 256) - Length 8 - Handle 0086h]
[ (Type 256) - Length 106 - Handle 0088h]
[ (Type 256) - Length 6 - Handle 0089h]
[ (Type 256) - Length 4 - Handle 008bh]
