Machine ID Information [From Smbios 3.3, DMIVersion 0, Size=4008]
BiosMajorRelease = 5
BiosMinorRelease = 17
BiosVendor = American Megatrends Inc.
BiosVersion = 2407
BiosReleaseDate = 07/13/2021
SystemManufacturer = ASUS
SystemProductName = System Product Name
SystemFamily = To be filled by O.E.M.
SystemVersion = System Version
SystemSKU = SKU
BaseBoardManufacturer = ASUSTeK COMPUTER INC.
BaseBoardProduct = Pro B550M-C
BaseBoardVersion = Rev X.0x
System Information
Time of this report: 6/8/2023, 14:44:30
Machine name: DESKTOP-0KS14FS
Machine Id: {0E272572-38C5-45BA-B955-D40BB1FBDD2B}
Operating System: Windows 10 Pro 64-bit (10.0, Build 19045) (19041.vb_release.191206-1406)
Language: Turkish (Regional Setting: Turkish)
System Manufacturer: ASUS
System Model: System Product Name
BIOS: 3003 (type: UEFI)
Processor: AMD Ryzen 5 5600X 6-Core Processor (12 CPUs), ~3.7GHz
Memory: 16384MB RAM
Available OS Memory: 16300MB RAM
Page File: 8416MB used, 14027MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 12
DX Setup Parameters: Not found
User DPI Setting: 96 DPI (100 percent)
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
Miracast: Available, no HDCP
Microsoft Graphics Hybrid: Not Supported
DirectX Database Version: 1.0.8
DxDiag Version: 10.00.19041.2075 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No sound card was found. If one is expected, you should install a sound driver provided by the hardware manufacturer.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce RTX 3070
Manufacturer: NVIDIA
Chip type: NVIDIA GeForce RTX 3070
DAC type: Integrated RAMDAC
Device Type: Full Device (POST)
Device Key: Enum\PCI\VEN_10DE&DEV_2488&SUBSYS_883A1043&REV_A1
Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
Device Problem Code: No Problem
Driver Problem Code: Unknown
Display Memory: 16181 MB
Dedicated Memory: 8031 MB
Shared Memory: 8150 MB
Current Mode: 3440 x 1440 (32 bit) (165Hz)
HDR Support: Supported
Display Topology: Internal
Display Color Space: DXGI_COLOR_SPACE_RGB_FULL_G22_NONE_P709
Color Primaries: Red(0.672852,0.313477), Green(0.278320,0.640625), Blue(0.150391,0.069336), White Point(0.312500,0.329102)
Display Luminance: Min Luminance = 0.054800, Max Luminance = 455.523193, MaxFullFrameLuminance = 455.523193
Monitor Name: Generic PnP Monitor
Monitor Model: ZQE-CBA
Monitor Id: HWV6A25
Native Mode: 3440 x 1440(p) (99.982Hz)
Output Type: Displayport External
Monitor Capabilities: HDR Supported (BT2020RGB BT2020YCC Eotf2084Supported )
Display Pixel Format: DISPLAYCONFIG_PIXELFORMAT_32BPP
Advanced Color: AdvancedColorSupported
Driver Name: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvldumdx.dll,C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvldumdx.dll,C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvldumdx.dll,C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvldumdx.dll
Driver File Version: 31.00.0015.3203 (English)
Driver Version: 31.0.15.3203
DDI Version: 12
Feature Levels: 12_1,12_0,11_1,11_0,10_1,10_0,9_3,9_2,9_1
Driver Model: WDDM 2.7
Hardware Scheduling: Supported:True Enabled:False
Graphics Preemption: Pixel
Compute Preemption: Dispatch
Miracast: Not Supported
Detachable GPU: No
Hybrid Graphics GPU: Not Supported
Power P-states: Not Supported
Virtualization: Paravirtualization
Block List: No Blocks
Catalog Attributes: Universal:False Declarative:True
Driver Attributes: Final Retail
Driver Date/Size: 19.05.2023 03:00:00, 770656 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: Unknown
Device Identifier: {D7B71E3E-67C8-11CF-707F-35A80EC2D235}
Vendor ID: 0x10DE
Device ID: 0x2488
SubSys ID: 0x883A1043
Revision ID: 0x00A1
Driver Strong Name: oem16.inf:0f066de31a1a610b:Section072:31.0.15.3203:pci\ven_10de&dev_2488
Rank Of Driver: 00CF2001
Video Accel:
DXVA2 Modes: {86695F12-340E-4F04-9FD3-9253DD327460} DXVA2_ModeMPEG2_VLD {6F3EC719-3735-42CC-8063-65CC3CB36616} DXVA2_ModeVC1_D2010 DXVA2_ModeVC1_VLD {32FCFE3F-DE46-4A49-861B-AC71110649D5} DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT DXVA2_ModeH264_VLD_Stereo_NoFGT DXVA2_ModeH264_VLD_NoFGT DXVA2_ModeHEVC_VLD_Main DXVA2_ModeHEVC_VLD_Main10 {20BB8B0A-97AA-4571-8E99-64E60606C1A6} {15DF9B21-06C4-47F1-841E-A67C97D7F312} DXVA2_ModeMPEG4pt2_VLD_Simple DXVA2_ModeMPEG4pt2_VLD_AdvSimple_NoGMC {9947EC6F-689B-11DC-A320-0019DBBC4184} {33FCFE41-DE46-4A49-861B-AC71110649D5} DXVA2_ModeVP9_VLD_Profile0 DXVA2_ModeVP9_VLD_10bit_Profile2 {DDA19DC7-93B5-49F5-A9B3-2BDA28A2CE6E} {B8BE4CCB-CF53-46BA-8D59-D6B8A6DA5D2A} {6AFFD11E-1D96-42B1-A215-93A31F09A53D} {914C84A3-4078-4FA9-984C-E2F262CB5C9C} {8A1A1031-29BC-46D0-A007-E9B092CA6767}
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
D3D9 Overlay: Not Supported
DXVA-HD: Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
MPO MaxPlanes: 4
MPO Caps: RGB,YUV,BILINEAR,HIGH_FILTER,STRETCH_YUV,STRETCH_RGB,IMMEDIATE,HDR (MPO3)
MPO Stretch: 10.000X - 0.500X
MPO Media Hints: resizing, colorspace Conversion
MPO Formats: NV12,YUY2,R16G16B16A16_FLOAT,R10G10B10A2_UNORM,R8G8B8A8_UNORM,B8G8R8A8_UNORM
PanelFitter Caps: RGB,YUV,BILINEAR,HIGH_FILTER,STRETCH_YUV,STRETCH_RGB,IMMEDIATE,HDR (MPO3)
PanelFitter Stretch: 10.000X - 0.500X
Sound Devices
Description:
Default Sound Playback: No
Default Voice Playback: No
Hardware ID:
Manufacturer ID:
Product ID:
Type:
Driver Name:
Driver Version:
Driver Attributes:
WHQL Logo'd:
Date and Size:
Other Files:
Driver Provider:
HW Accel Level: Emulation Only
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Sound Capture Devices
Video Capture Devices
Number of Devices: 0
DirectInput Devices
Device Name: Fare
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Klavye
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: CORSAIR SABRE RGB PRO WIRELESS Gaming Mouse
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x1B1C, 0x1B98
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: Gaming Keyboard G810
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC331
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB K k Hub (USB 3.0)
| Vendor/Product ID: 0x1022, 0x43EE
| Matching Device ID: USB\ROOT_HUB30
| Service: USBHUB3
| Driver: USBHUB3.SYS, 9/8/2022 06:08:09, 648016 bytes
+-+ USB Bile ik Ayg t
| | Matching Device ID: USB\COMPOSITE
| | Service: usbccgp
| | Driver: usbccgp.sys, 6/6/2023 11:21:42, 190336 bytes
| +-+ USB Giri Ayg t
| | | Matching Device ID: USB\Class_03&SubClass_01
| | | Service: HidUsb
| | | Driver: hidusb.sys, 6/6/2023 11:21:42, 44032 bytes
| | | Driver: hidclass.sys, 6/6/2023 11:21:42, 241152 bytes
| | | Driver: hidparse.sys, 6/6/2023 11:21:42, 46080 bytes
| | +-+ AC uyumlu fare
| | | | Matching Device ID: HID_DEVICE_SYSTEM_MOUSE
| | | | Service: mouhid
| | | | Driver: mouhid.sys, 12/7/2019 12:07:56, 35328 bytes
| | | | Driver: mouclass.sys, 12/7/2019 12:07:56, 67600 bytes
| +-+ USB Giri Ayg t
| | | Service: HidUsb
| | +-+ AC Klavye Ayg t
| | | | Matching Device ID: HID_DEVICE_SYSTEM_KEYBOARD
| | | | Service: kbdhid
| | | | Driver: kbdhid.sys, 12/7/2019 12:07:56, 46592 bytes
| | | | Driver: kbdclass.sys, 12/7/2019 12:07:56, 71480 bytes
| +-+ USB Giri Ayg t
| | | Service: HidUsb
| | +-+ AC uyumlu fare
| | | | Service: mouhid
| | Service: usbccgp
| +-+ USB Giri Ayg t
| | | Service: HidUsb
| | +-+ AC Klavye Ayg t
| | | | Service: kbdhid
| +-+ USB Giri Ayg t
| | | Service: HidUsb
| | +-+ AC Klavye Ayg t
| | | | Service: kbdhid
Gameport Devices
PS/2 Devices
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 405.7 GB
Total Space: 476.3 GB
File System: NTFS
Model: KINGSTON SNV2S500G
Drive: D:
Free Space: 574.4 GB
Total Space: 953.4 GB
File System: NTFS
Model: WDC WDS100T2B0A-00SM50
System Devices
Name: AMD USB 3.10 eXtensible Host Controller - 1.10 (Microsoft)
Device ID: PCI\VEN_1022&DEV_149C&SUBSYS_87C01043&REV_00\4&231A312E&0&0341
Driver: C:\Windows\system32\DRIVERS\USBXHCI.SYS, 10.00.19041.2546 (Turkish), 6/6/2023 11:21:42, 624976 bytes
Driver: C:\Windows\system32\DRIVERS\UMDF\UsbXhciCompanion.dll, 10.00.19041.2546 (English), 6/6/2023 11:21:42, 139016 bytes
Name: PCI standart ana bilgisayar CPU k pr s
Device ID: PCI\VEN_1022&DEV_1447&SUBSYS_00000000&REV_00\3&11583659&0&C7
Driver: n/a
Name: High Definition Audio Denetleyicisi
Device ID: PCI\VEN_10DE&DEV_228B&SUBSYS_883A1043&REV_A1\4&1D81E16&0&0119
Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 10.00.19041.2546 (English), 6/6/2023 11:21:41, 137728 bytes
Driver: C:\Windows\system32\DRIVERS\drmk.sys, 10.00.19041.0746 (English), 9/8/2022 06:08:07, 97792 bytes
Driver: C:\Windows\system32\DRIVERS\portcls.sys, 10.00.19041.0746 (English), 9/8/2022 06:08:07, 388608 bytes
Name: Standart SATA AHCI Denetleyici
Device ID: PCI\VEN_1022&DEV_43EB&SUBSYS_10621B21&REV_00\4&20E120C7&0&010A
Driver: C:\Windows\system32\DRIVERS\storahci.sys, 10.00.19041.1889 (English), 9/8/2022 06:08:08, 187240 bytes
Device ID: PCI\VEN_1022&DEV_1442&SUBSYS_00000000&REV_00\3&11583659&0&C2
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1480&SUBSYS_88081043&REV_00\3&11583659&0&00
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1445&SUBSYS_00000000&REV_00\3&11583659&0&C5
Driver: n/a
Device ID: PCI\VEN_1022&DEV_148A&SUBSYS_88081043&REV_00\4&4112E7D&0&0039
Driver: C:\Windows\system32\DRIVERS\AMDPCIDev.sys, 1.00.0000.0089 (English), 7/7/2022 03:00:18, 37592 bytes
Name: PCI-PCI K pr s
Device ID: PCI\VEN_1022&DEV_1483&SUBSYS_88081043&REV_00\3&11583659&0&19
Driver: C:\Windows\system32\DRIVERS\pci.sys, 10.00.19041.1949 (Turkish), 9/8/2022 06:08:08, 473424 bytes
Device ID: PCI\VEN_1022&DEV_1483&SUBSYS_88081043&REV_00\3&11583659&0&0A
Device ID: PCI\VEN_1022&DEV_1483&SUBSYS_88081043&REV_00\3&11583659&0&09
Name: Standart NVM Express Denetleyicisi
Device ID: PCI\VEN_2646&DEV_5019&SUBSYS_50192646&REV_00\4&DB6900A&0&0009
Driver: C:\Windows\system32\DRIVERS\stornvme.sys, 10.00.19041.2075 (English), 6/6/2023 11:21:42, 169816 bytes
Device ID: PCI\VEN_1022&DEV_1440&SUBSYS_00000000&REV_00\3&11583659&0&C0
Driver: n/a
Device ID: PCI\VEN_1022&DEV_43EA&SUBSYS_33081B21&REV_00\5&302D1E64&0&48020A
Device ID: PCI\VEN_1022&DEV_1482&SUBSYS_00000000&REV_00\3&11583659&0&40
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1482&SUBSYS_00000000&REV_00\3&11583659&0&38
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1482&SUBSYS_00000000&REV_00\3&11583659&0&28
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1482&SUBSYS_00000000&REV_00\3&11583659&0&20
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1482&SUBSYS_00000000&REV_00\3&11583659&0&18
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1482&SUBSYS_00000000&REV_00\3&11583659&0&10
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1482&SUBSYS_00000000&REV_00\3&11583659&0&08
Driver: n/a
Device ID: PCI\VEN_1022&DEV_43E9&SUBSYS_02011B21&REV_00\4&20E120C7&0&020A
Device ID: PCI\VEN_1022&DEV_1443&SUBSYS_00000000&REV_00\3&11583659&0&C3
Driver: n/a
Device ID: PCI\VEN_1022&DEV_43EA&SUBSYS_33081B21&REV_00\5&302D1E64&0&40020A
Device ID: PCI\VEN_1022&DEV_1487&SUBSYS_86C71043&REV_00\4&231A312E&0&0441
Device ID: PCI\VEN_1022&DEV_1485&SUBSYS_88081043&REV_00\4&231A312E&0&0041
Device ID: PCI\VEN_1022&DEV_790B&SUBSYS_87C01043&REV_61\3&11583659&0&A0
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1446&SUBSYS_00000000&REV_00\3&11583659&0&C6
Driver: n/a
Name: Realtek PCIe GbE Family Controller
Device ID: PCI\VEN_10EC&DEV_8168&SUBSYS_86771043&REV_15\6&102E3ADF&0&0048020A
Driver: C:\Windows\system32\DRIVERS\rt640x64.sys, 10.50.0511.2021 (Turkish), 7/16/2021 22:42:40, 1151992 bytes
Device ID: PCI\VEN_1022&DEV_1484&SUBSYS_88081043&REV_00\3&11583659&0&41
Device ID: PCI\VEN_1022&DEV_1484&SUBSYS_88081043&REV_00\3&11583659&0&39
Device ID: PCI\VEN_1022&DEV_43EA&SUBSYS_33081B21&REV_00\5&302D1E64&0&20020A
Device ID: PCI\VEN_1022&DEV_43EE&SUBSYS_11421B21&REV_00\4&20E120C7&0&000A
Name: PCI standart ISA k pr s
Device ID: PCI\VEN_1022&DEV_790E&SUBSYS_87C01043&REV_51\3&11583659&0&A3
Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 10.00.19041.1202 (English), 9/8/2022 06:08:08, 20280 bytes
Name: NVIDIA GeForce RTX 3070
Device ID: PCI\VEN_10DE&DEV_2488&SUBSYS_883A1043&REV_A1\4&1D81E16&0&0019
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\NVWMI\nvPerfProvider.man, 5/19/2023 18:08:34, 14175 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\NVWMI\nvWmi.mof, 5/19/2023 18:08:34, 148921 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\NVWMI\nvWmi64.exe, 2.36.0000.0000 (English), 5/20/2023 05:39:34, 4513792 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\Display.NvContainer\MessageBus.dll, 1.22.2758.1620 (English), 5/20/2023 05:38:36, 7542600 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\Display.NvContainer\NVDisplay.Container.exe, 1.37.3103.4323 (English), 5/20/2023 05:38:40, 1014808 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\Display.NvContainer\NvContainerRecovery.bat, 5/19/2023 18:08:34, 1951 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\Display.NvContainer\dlsargs.xml, 5/19/2023 18:08:34, 544 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\Display.NvContainer\dlsnetparams.csv, 5/19/2023 18:08:34, 341661 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\Display.NvContainer\messagebus_client.conf, 5/19/2023 18:08:34, 57 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\Display.NvContainer\nvgwls.exe, 5/20/2023 05:38:44, 3941416 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\Display.NvContainer\nvtopps.db3, 5/19/2023 18:08:34, 126976 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\Display.NvContainer\plugins\LocalSystem\NvXDCore.dll, 31.00.0015.3203 (English), 5/20/2023 05:38:52, 1820200 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\Display.NvContainer\plugins\LocalSystem\NvcDispCorePlugin.dll, 31.00.0015.3203 (English), 5/20/2023 05:38:46, 522776 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\Display.NvContainer\plugins\LocalSystem\NvcDispWatchdog.dll, 1.37.3103.4323 (English), 5/20/2023 05:38:48, 738856 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\Display.NvContainer\plugins\LocalSystem\_DisplayDriverRAS.dll, 1.10.0000.0000 (English), 5/20/2023 05:38:56, 2713112 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\Display.NvContainer\plugins\LocalSystem\_NvMsgBusBroadcast.dll, 1.34.3030.7627 (English), 5/20/2023 05:38:58, 3192344 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\Display.NvContainer\plugins\LocalSystem\messagebus.conf, 5/19/2023 18:08:34, 57 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\Display.NvContainer\plugins\LocalSystem\wksServicePluginZ.dll, 31.00.0015.3203 (English), 5/20/2023 05:38:54, 267288 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\Display.NvContainer\plugins\Session\_NvGSTPlugin.dll, 31.00.0015.3203 (English), 5/20/2023 05:39:02, 2653720 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\Display.NvContainer\plugins\Session\_nvtopps.dll, 31.00.0015.3203 (English), 5/20/2023 05:39:04, 11941912 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\Display.NvContainer\plugins\Session\nvprofileupdaterplugin.dll, 31.00.0015.3203 (English), 5/20/2023 05:38:58, 2230296 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\Display.NvContainer\plugins\Session\nvxdsyncplugin.dll, 8.17.0015.3203 (English), 5/20/2023 05:39:00, 1829912 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\Display.NvContainer\plugins\Session\wksServicePlugin.dll, 31.00.0015.3203 (English), 5/20/2023 05:39:02, 309800 bytes
Driver: C:\Windows\system32\DRIVERS\NVIDIA Corporation\Drs\dbInstaller.exe, 31.00.0015.3203 (English), 5/20/2023 05:30:58, 733184 bytes
Driver: C:\Windows\system32\DRIVERS\NVIDIA Corporation\Drs\nvdrsdb.bin, 5/19/2023 18:08:34, 1902028 bytes
Driver: C:\Windows\system32\nvcpl.dll, 8.17.0015.3203 (English), 5/20/2023 05:31:50, 5835776 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nv3dappshext.dll, 6.14.0015.3203 (English), 5/20/2023 05:31:14, 1004528 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nv3dappshextr.dll, 6.14.0015.3203 (Turkish), 5/20/2023 05:31:18, 98304 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvcoproc.bin, 5/19/2023 18:08:34, 10364347 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvcpl.dll, 8.17.0015.3203 (English), 5/20/2023 05:31:50, 5835776 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvdevtools.dll, 31.00.0015.3203 (English), 5/20/2023 05:32:36, 4585968 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvdevtoolsr.dll, 31.00.0015.3203 (Turkish), 5/20/2023 05:32:40, 245224 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvdisps.dll, 31.00.0015.3203 (English), 5/20/2023 05:32:46, 11649520 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvdispsr.dll, 31.00.0015.3203 (Turkish), 5/20/2023 05:32:48, 11551784 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvgames.dll, 31.00.0015.3203 (English), 5/20/2023 05:33:16, 12479512 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvgamesr.dll, 31.00.0015.3203 (Turkish), 5/20/2023 05:33:18, 13252136 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvlicensings.dll, 6.14.0015.3203 (English), 5/20/2023 05:34:10, 4551664 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvlicensingsr.dll, 6.14.0015.3203 (Turkish), 5/20/2023 05:34:12, 306664 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvshext.dll, 1.02.0000.0001 (English), 5/20/2023 05:36:34, 133144 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvsmartmax.dll, 6.14.0010.10003 (English), 5/20/2023 05:36:38, 201728 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvsmartmax64.dll, 6.14.0010.10003 (English), 5/20/2023 05:36:40, 240128 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvsmartmaxapp.exe, 6.14.0010.10003 (English), 5/20/2023 05:36:44, 274416 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvsmartmaxapp64.exe, 6.14.0010.10003 (English), 5/20/2023 05:36:46, 285160 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvsvc64.dll, 31.00.0015.3203 (Turkish), 5/20/2023 05:36:48, 2666480 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvsvcr.dll, 31.00.0015.3203 (Turkish), 5/20/2023 05:36:50, 1801768 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvsvs.dll, 31.00.0015.3203 (English), 5/20/2023 05:36:52, 5097000 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvsvsr.dll, 31.00.0015.3203 (English), 5/20/2023 05:36:54, 2013672 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvui.dll, 8.17.0015.3203 (English), 5/20/2023 05:36:58, 6629888 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvuir.dll, 8.17.0015.3203 (Turkish), 5/20/2023 05:37:00, 2648552 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvvitvs.dll, 31.00.0015.3203 (English), 5/20/2023 05:37:08, 7451136 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvvitvsr.dll, 31.00.0015.3203 (Turkish), 5/20/2023 05:37:10, 4227096 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvwss.dll, 31.00.0015.3203 (English), 5/20/2023 05:37:56, 12259824 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvwssr.dll, 31.00.0015.3203 (Turkish), 5/20/2023 05:37:58, 9527808 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvxdapix.dll, 8.17.0015.3203 (English), 5/20/2023 05:38:02, 9273344 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvxdbat.dll, 8.17.0015.3203 (English), 5/20/2023 05:38:06, 1645040 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvxdplcy.dll, 8.17.0015.3203 (English), 5/20/2023 05:38:10, 1889256 bytes
Driver: C:\Windows\system32\lxss\lib\libcuda.so, 5/19/2023 18:08:34, 154096 bytes
Driver: C:\Windows\system32\lxss\lib\libcuda.so.1, 5/19/2023 18:08:34, 154096 bytes
Driver: C:\Windows\system32\lxss\lib\libcuda.so.1.1, 5/19/2023 18:08:34, 154096 bytes
Driver: C:\Windows\system32\lxss\lib\libnvcuvid.so, 5/19/2023 18:08:34, 10411192 bytes
Driver: C:\Windows\system32\lxss\lib\libnvcuvid.so.1, 5/19/2023 18:08:34, 10411192 bytes
Driver: C:\Windows\system32\lxss\lib\libnvdxdlkernels.so, 5/19/2023 18:08:34, 36576952 bytes
Driver: C:\Windows\system32\lxss\lib\libnvidia-encode.so, 5/19/2023 18:08:34, 547432 bytes
Driver: C:\Windows\system32\lxss\lib\libnvidia-encode.so.1, 5/19/2023 18:08:34, 547432 bytes
Driver: C:\Windows\system32\lxss\lib\libnvidia-ml.so.1, 5/19/2023 18:08:34, 223048 bytes
Driver: C:\Windows\system32\lxss\lib\libnvidia-opticalflow.so, 5/19/2023 18:08:34, 362960 bytes
Driver: C:\Windows\system32\lxss\lib\libnvidia-opticalflow.so.1, 5/19/2023 18:08:34, 362960 bytes
Driver: C:\Windows\system32\lxss\lib\libnvoptix.so.1, 5/19/2023 18:08:34, 68560 bytes
Driver: C:\Windows\system32\lxss\lib\libnvwgf2umx.so, 5/19/2023 18:08:34, 73346768 bytes
Driver: C:\Windows\system32\lxss\lib\nvidia-smi, 5/19/2023 18:08:34, 634504 bytes
Driver: C:\Windows\system32\DRIVERS\NVIDIA Corporation\license.txt, 12/22/2022 12:29:07, 28827 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\_nvngx.dll, 31.00.0015.3203 (English), 5/20/2023 05:38:34, 1529880 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\cudnn_infer64_7.dll, 5/20/2023 05:30:52, 22774176 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvngx.dll, 30.00.0014.9516 (English), 5/20/2023 05:34:16, 488688 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvngx_update.exe, 31.00.0015.3203 (English), 5/20/2023 05:34:22, 1189872 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvngxdlss.dll, 5/20/2023 05:34:20, 27376 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\NvCamera\FreqTransfer32.exe, 5/20/2023 05:39:10, 3707392 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\NvCamera\FreqTransfer64.exe, 5/20/2023 05:39:10, 4007448 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\NvCamera\GreenScreenBG01.jpg, 5/19/2023 18:08:34, 281528 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\NvCamera\GreenScreenBG02.jpg, 5/19/2023 18:08:34, 499736 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\NvCamera\HighresBlender32.exe, 5/20/2023 05:39:12, 3814952 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\NvCamera\HighresBlender64.exe, 5/20/2023 05:39:14, 4109808 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\NvCamera\NvCamera32.dll, 7.01.0817.0000 (English), 5/20/2023 05:39:16, 8062976 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\NvCamera\NvCamera64.dll, 7.01.0817.0000 (English), 5/20/2023 05:39:16, 8556544 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\NvCamera\NvCameraAllowlisting32.dll, 7.01.0817.0000 (English), 5/20/2023 05:39:18, 562688 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\NvCamera\NvCameraAllowlisting64.dll, 7.01.0817.0000 (English), 5/20/2023 05:39:20, 706032 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\NvCamera\NvCameraEnable.exe, 5/20/2023 05:39:22, 375296 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\NvCamera\NvImageConvert32.exe, 5/20/2023 05:39:24, 3710960 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\NvCamera\NvImageConvert64.exe, 5/20/2023 05:39:26, 3989504 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\NvCamera\ReShadeFXC32.exe, 2.00.0000.0000 (English), 5/20/2023 05:39:28, 776688 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\NvCamera\ReShadeFXC64.exe, 2.00.0000.0000 (English), 5/20/2023 05:39:30, 891896 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\NvCamera\ShotWithGeforce518x32.rgba, 5/19/2023 18:08:34, 66304 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\NvCamera\SphericalEquirect32.exe, 5/20/2023 05:39:32, 3660272 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\NvCamera\SphericalEquirect64.exe, 5/20/2023 05:39:34, 3914752 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\NvCamera\Sticker01.png, 5/19/2023 18:08:34, 49695 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\NvCamera\Sticker02.png, 5/19/2023 18:08:34, 474002 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\NvCamera\Sticker03.png, 5/19/2023 18:08:34, 380006 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\NvCamera\Sticker04.png, 5/19/2023 18:08:34, 86881 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\NvCamera\Sticker05.png, 5/19/2023 18:08:34, 59304 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\NvCamera\Sticker06.png, 5/19/2023 18:08:34, 13547 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\NvCamera\Sticker07.png, 5/19/2023 18:08:34, 6342 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\NvCamera\Sticker08.png, 5/19/2023 18:08:34, 96493 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\NvCamera\d3dcompiler_47_32.dll, 6.03.9600.16384 (English), 5/20/2023 05:39:04, 3471400 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\NvCamera\d3dcompiler_47_64.dll, 6.03.9600.16384 (English), 5/20/2023 05:39:06, 4177944 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\NvCamera\scratches.jpg, 5/19/2023 18:08:34, 346354 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\NvCamera\tools_licenses.txt, 5/19/2023 18:08:34, 15970 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\NvCamera\ui.tga, 5/19/2023 18:08:34, 120236 bytes
Driver: C:\Windows\system32\MCU.exe, 1.01.5204.20580 (Turkish), 5/20/2023 05:31:12, 853504 bytes
Driver: C:\Windows\system32\nvdebugdump.exe, 6.14.0015.3203 (English), 5/20/2023 05:32:26, 458240 bytes
Driver: C:\Windows\system32\nvidia-smi.exe, 8.17.0015.3203 (English), 5/20/2023 05:33:28, 741888 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvopencl32.dll, 31.00.0015.3203 (English), 5/20/2023 05:35:06, 18390512 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvopencl64.dll, 31.00.0015.3203 (English), 5/20/2023 05:35:12, 10605568 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvcompiler32.dll, 31.00.0015.3203 (English), 5/20/2023 05:31:22, 41544176 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvcompiler64.dll, 31.00.0015.3203 (English), 5/20/2023 05:31:36, 46333936 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvlddmkm.sys, 31.00.0015.3203 (English), 5/20/2023 05:33:54, 58252824 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvvm32.dll, 31.00.0015.3203 (English), 5/20/2023 05:37:14, 60342312 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvvm64.dll, 31.00.0015.3203 (English), 5/20/2023 05:37:34, 68047912 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\libcuda.so.1.1, 5/19/2023 18:08:34, 29653704 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\libcuda_loader.so, 5/19/2023 18:08:34, 154096 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\libnvcuvid.so.1, 5/19/2023 18:08:34, 10411192 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\libnvdxdlkernels.so, 5/19/2023 18:08:34, 36576952 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\libnvidia-encode.so.1, 5/19/2023 18:08:34, 547432 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\libnvidia-ml.so.1, 5/19/2023 18:08:34, 1556224 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\libnvidia-ml_loader.so, 5/19/2023 18:08:34, 223048 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\libnvidia-nvvm.so.4, 5/19/2023 18:08:34, 27511416 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\libnvidia-opticalflow.so.1, 5/19/2023 18:08:34, 362960 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\libnvidia-ptxjitcompiler.so.1, 5/19/2023 18:08:34, 21669384 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\libnvoptix_loader.so.1, 5/19/2023 18:08:34, 68560 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\libnvwgf2umx.so, 5/19/2023 18:08:34, 73346768 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nv-vk64.json, 5/19/2023 18:08:34, 671 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvDecMFTMjpeg.dll, 31.00.0015.3203 (English), 5/20/2023 05:32:32, 502760 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvDecMFTMjpegx.dll, 31.00.0015.3203 (English), 5/20/2023 05:32:34, 653296 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvEncMFTH264.dll, 31.00.0015.3203 (English), 5/20/2023 05:32:58, 890392 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvEncMFTH264x.dll, 31.00.0015.3203 (English), 5/20/2023 05:33:00, 1140264 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvEncMFThevc.dll, 31.00.0015.3203 (English), 5/20/2023 05:33:02, 896040 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvEncMFThevcx.dll, 31.00.0015.3203 (English), 5/20/2023 05:33:04, 1147944 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvcubins.bin, 5/19/2023 18:08:34, 26345360 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvcuda32.dll, 31.00.0015.3203 (English), 5/20/2023 05:31:54, 22598184 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvcuda64.dll, 31.00.0015.3203 (English), 5/20/2023 05:32:02, 9923624 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvd3dumx.dll, 31.00.0015.3203 (English), 5/20/2023 05:30:20, 49681184 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvdlistx.dll, 31.00.0015.3203 (English), 5/20/2023 05:30:36, 225648 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvdxdlkernels.dll, 5/20/2023 05:32:52, 80347176 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvidia-smi, 5/19/2023 18:08:34, 634504 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvldumdx.dll, 31.00.0015.3203 (English), 5/20/2023 05:30:42, 770656 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvml.dll, 8.17.0015.3203 (English), 5/20/2023 05:34:14, 1254376 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvoglv64.dll, 31.00.0015.3203 (English), 5/20/2023 05:34:44, 62551528 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvoptix.bin, 5/19/2023 18:08:34, 143085908 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvoptix.dll, 7.07.0000.0000 (English), 5/20/2023 05:35:24, 53352936 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvptxJitCompiler32.dll, 31.00.0015.3203 (English), 5/20/2023 05:35:46, 13664768 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvptxJitCompiler64.dll, 31.00.0015.3203 (English), 5/20/2023 05:35:50, 16422896 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvrtum64.dll, 31.00.0015.3203 (English), 5/20/2023 05:36:00, 105561640 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvwgf2umx.dll, 31.00.0015.3203 (English), 5/20/2023 05:31:06, 90780888 bytes
Driver: C:\Windows\system32\NvFBC64.dll, 6.14.0015.3203 (English), 5/20/2023 05:33:12, 2166296 bytes
Driver: C:\Windows\system32\NvIFR64.dll, 6.14.0015.3203 (English), 5/20/2023 05:33:48, 1536552 bytes
Driver: C:\Windows\system32\OpenCL.dll, 3.00.0003.0000 (English), 5/20/2023 05:38:20, 1487344 bytes
Driver: C:\Windows\system32\nvEncodeAPI64.dll, 31.00.0015.3203 (English), 5/20/2023 05:33:08, 978968 bytes
Driver: C:\Windows\system32\nvapi64.dll, 31.00.0015.3203 (English), 5/20/2023 05:29:58, 7935568 bytes
Driver: C:\Windows\system32\nvcuda.dll, 31.00.0015.3203 (English), 5/20/2023 05:32:12, 3429872 bytes
Driver: C:\Windows\system32\nvcudadebugger.dll, 0.00.0000.0000 (English), 5/20/2023 05:32:06, 5911064 bytes
Driver: C:\Windows\system32\nvcuvid.dll, 7.17.0015.3203 (English), 5/20/2023 05:32:22, 11650088 bytes
Driver: C:\Windows\system32\nvinfo.pb, 5/19/2023 18:08:34, 104369 bytes
Driver: C:\Windows\system32\nvml.dll, 8.17.0015.3203 (English), 5/20/2023 05:34:16, 851968 bytes
Driver: C:\Windows\system32\nvofapi64.dll, 5/20/2023 05:34:26, 671208 bytes
Driver: C:\Windows\system32\vulkan-1-999-0-0-0.dll, 1.03.0236.0000 (English), 5/20/2023 05:38:26, 1479264 bytes
Driver: C:\Windows\system32\vulkan-1.dll, 1.03.0236.0000 (English), 5/20/2023 05:38:26, 1479264 bytes
Driver: C:\Windows\system32\vulkaninfo-1-999-0-0-0.exe, 1.03.0236.0000 (English), 5/20/2023 05:38:30, 2172472 bytes
Driver: C:\Windows\system32\vulkaninfo.exe, 1.03.0236.0000 (English), 5/20/2023 05:38:30, 2172472 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nv-vk32.json, 5/19/2023 18:08:34, 671 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvIccAdvancedColorIdentity.icm, 5/19/2023 18:08:34, 3288 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvd3dum.dll, 31.00.0015.3203 (English), 5/20/2023 05:30:06, 45956832 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvdispco64.exe, 1.00.0016.0000 (English), 5/20/2023 05:32:44, 1579048 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvdlist.dll, 31.00.0015.3203 (English), 5/20/2023 05:30:34, 188696 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvldumd.dll, 31.00.0015.3203 (English), 5/20/2023 05:30:38, 616192 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvoglv32.dll, 31.00.0015.3203 (English), 5/20/2023 05:34:30, 44152856 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\nvwgf2um.dll, 31.00.0015.3203 (English), 5/20/2023 05:30:46, 59617088 bytes
Driver: C:\Windows\SysWow64\NvFBC.dll, 6.14.0015.3203 (English), 5/20/2023 05:33:10, 1621016 bytes
Driver: C:\Windows\SysWow64\NvIFR.dll, 6.14.0015.3203 (English), 5/20/2023 05:33:46, 1195048 bytes
Driver: C:\Windows\SysWow64\OpenCL.dll, 3.00.0003.0000 (English), 5/20/2023 05:38:18, 1227304 bytes
Driver: C:\Windows\SysWow64\nvEncodeAPI.dll, 31.00.0015.3203 (English), 5/20/2023 05:33:06, 758768 bytes
Driver: C:\Windows\SysWow64\nvapi.dll, 31.00.0015.3203 (English), 5/20/2023 05:29:52, 6798792 bytes
Driver: C:\Windows\SysWow64\nvcuda.dll, 31.00.0015.3203 (English), 5/20/2023 05:32:08, 6083560 bytes
Driver: C:\Windows\SysWow64\nvcuvid.dll, 7.17.0015.3203 (English), 5/20/2023 05:32:16, 13768728 bytes
Driver: C:\Windows\SysWow64\nvofapi.dll, 5/20/2023 05:34:24, 506920 bytes
Driver: C:\Windows\SysWow64\vulkan-1-999-0-0-0.dll, 1.03.0236.0000 (English), 5/20/2023 05:38:28, 1211488 bytes
Driver: C:\Windows\SysWow64\vulkan-1.dll, 1.03.0236.0000 (English), 5/20/2023 05:38:28, 1211488 bytes
Driver: C:\Windows\SysWow64\vulkaninfo-1-999-0-0-0.exe, 1.03.0236.0000 (English), 5/20/2023 05:38:32, 1607776 bytes
Driver: C:\Windows\SysWow64\vulkaninfo.exe, 1.03.0236.0000 (English), 5/20/2023 05:38:32, 1607776 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_91a2cdd03914725b\NvTelemetry64.dll, 14.03.0060.0000 (English), 5/20/2023 05:36:56, 4466088 bytes
Device ID: PCI\VEN_1022&DEV_1441&SUBSYS_00000000&REV_00\3&11583659&0&C1
Driver: n/a
Name: AMD PSP 11.0 Device
Device ID: PCI\VEN_1022&DEV_1486&SUBSYS_88081043&REV_00\4&231A312E&0&0141
Driver: C:\Windows\system32\DRIVERS\amdpsp.sys, 5.19.0000.0000 (English), 6/3/2022 00:04:14, 49168 bytes
Driver: C:\Windows\system32\amdtee_api.dll, 5.19.0000.0000 (English), 6/3/2022 00:04:18, 437256 bytes
Driver: C:\Windows\SysWOW64\amdtee_api.dll, 5.19.0000.0000 (English), 6/3/2022 00:04:16, 350736 bytes
Device ID: PCI\VEN_1022&DEV_43EA&SUBSYS_33081B21&REV_00\5&302D1E64&0&00020A
Device ID: PCI\VEN_1022&DEV_1444&SUBSYS_00000000&REV_00\3&11583659&0&C4
Driver: n/a
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,10.00.19041.1288
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,10.00.19041.1288
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,10.00.19041.0001
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,10.00.19041.0001
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,10.00.19041.1706
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,10.00.19041.0001
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,10.00.19041.2311
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,10.00.19041.1165
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,10.00.19041.1165
DV Muxer,0x00400000,0,0,qdv.dll,10.00.19041.0001
Color Space Converter,0x00400001,1,1,quartz.dll,10.00.19041.0746
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.19041.0001
AVI Splitter,0x00600000,1,1,quartz.dll,10.00.19041.0746
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,10.00.19041.0746
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,10.00.19041.0001
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,10.00.19041.2965
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,10.00.19041.0329
StreamBufferSink,0x00200000,0,0,sbe.dll,10.00.19041.0001
MJPEG Decompressor,0x00600000,1,1,quartz.dll,10.00.19041.0746
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,10.00.19041.0746
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,10.00.19041.0746
VBI Codec,0x00600000,1,4,VBICodec.ax,10.00.19041.0746
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,10.00.19041.0329
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,10.00.19041.0001
SBE2FileScan,0x00200000,0,0,sbe.dll,10.00.19041.0001
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.19041.2546
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,10.00.19041.0746
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,10.00.19041.0746
DV Splitter,0x00600000,1,2,qdv.dll,10.00.19041.0001
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,10.00.19041.0746
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,10.00.19041.2546
ACM Wrapper,0x00600000,1,1,quartz.dll,10.00.19041.0746
Video Renderer,0x00800001,1,0,quartz.dll,10.00.19041.0746
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,10.00.19041.0001
Line 21 Decoder,0x00600000,1,1,,
Video Port Manager,0x00600000,2,1,quartz.dll,10.00.19041.0746
Video Renderer,0x00400000,1,0,quartz.dll,10.00.19041.0746
VPS Decoder,0x00200000,0,0,WSTPager.ax,10.00.19041.0001
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.19041.0001
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,
File writer,0x00200000,1,0,qcap.dll,10.00.19041.0001
DVD Navigator,0x00200000,0,3,qdvd.dll,10.00.19041.0746
Overlay Mixer2,0x00200000,1,1,,
AVI Draw,0x00600064,9,1,quartz.dll,10.00.19041.0746
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.19041.2546
WST Pager,0x00200000,1,1,WSTPager.ax,10.00.19041.0001
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,10.00.19041.0329
DV Video Decoder,0x00800000,1,1,qdv.dll,10.00.19041.0001
SampleGrabber,0x00200000,1,1,qedit.dll,10.00.19041.0746
Null Renderer,0x00200000,1,0,qedit.dll,10.00.19041.0746
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,10.00.19041.0001
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,10.00.19041.0001
StreamBufferSource,0x00200000,0,0,sbe.dll,10.00.19041.0001
Smart Tee,0x00200000,1,2,qcap.dll,10.00.19041.0001
Overlay Mixer,0x00200000,0,0,,
AVI Decompressor,0x00600000,1,1,quartz.dll,10.00.19041.0746
AVI/WAV File Source,0x00400000,0,2,quartz.dll,10.00.19041.0746
Wave Parser,0x00400000,1,1,quartz.dll,10.00.19041.0746
MIDI Parser,0x00400000,1,1,quartz.dll,10.00.19041.0746
Multi-file Parser,0x00400000,1,1,quartz.dll,10.00.19041.0746
File stream renderer,0x00400000,1,1,quartz.dll,10.00.19041.0746
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,10.00.19041.0001
StreamBufferSink2,0x00200000,0,0,sbe.dll,10.00.19041.0001
AVI Mux,0x00200000,1,0,qcap.dll,10.00.19041.0001
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,10.00.19041.0746
File Source (Async.),0x00400000,0,1,quartz.dll,10.00.19041.0746
File Source (URL),0x00400000,0,1,quartz.dll,10.00.19041.0746
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,10.00.19041.0001
Enhanced Video Renderer,0x00200000,1,0,evr.dll,10.00.19041.0546
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,10.00.19041.0001
MPEG Video Decoder,0x40000001,1,1,quartz.dll,10.00.19041.0746
WDM Streaming Tee/Splitter Devices:
T/Al c dan-Al c ya D n t r c ,0x00200000,1,1,ksproxy.ax,10.00.19041.0746
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,10.00.19041.0867
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,10.00.19041.0001
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,10.00.19041.0001
DV Video Encoder,0x00200000,0,0,qdv.dll,10.00.19041.0001
MJPEG Compressor,0x00200000,0,0,quartz.dll,10.00.19041.0746
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,10.00.19041.0508
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,10.00.19041.0508
IMA ADPCM,0x00200000,1,1,quartz.dll,10.00.19041.0746
Microsoft ADPCM,0x00200000,1,1,quartz.dll,10.00.19041.0746
GSM 6.10,0x00200000,1,1,quartz.dll,10.00.19041.0746
CCITT A-Law,0x00200000,1,1,quartz.dll,10.00.19041.0746
CCITT u-Law,0x00200000,1,1,quartz.dll,10.00.19041.0746
MPEG Layer-3,0x00200000,1,1,quartz.dll,10.00.19041.0746
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,10.00.19041.2486
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,10.00.19041.2486
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,10.00.19041.2486
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,10.00.19041.0746
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,10.00.19041.0746
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.19041.0001
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.19041.0001
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.19041.0001
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.19041.0001
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,10.00.19041.0001
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,10.00.19041.0001
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,10.00.19041.0001
WDM Streaming Communication Transforms:
Audio Renderers:
Default DirectSound Device,0x00800000,1,0,quartz.dll,10.00.19041.0746
Default WaveOut Device,0x00200000,1,0,quartz.dll,10.00.19041.0746
Preferred DirectShow Filters
[HKEY_LOCAL_MACHINE\Software\Microsoft\DirectShow\Preferred]
<media subtype GUID>, [<filter friendly name>, ]<filter CLSID>
MEDIASUBTYPE_DVD_LPCM_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_VIDEO, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
{78766964-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_mp4s, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{64697678-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{58564944-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{5634504D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_MP4S, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
{44495658-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVA, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mpg4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_h264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_H264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_WMV3, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_MP43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMV2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS2, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_M4S2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WVP2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_WMV1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS1, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_WVC1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_AVC1, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_MPEG_LOAS, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG_ADTS_AAC, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_WMAUDIO_LOSSLESS, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_WMAUDIO3, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
WMMEDIASUBTYPE_WMAudioV8, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
WMMEDIASUBTYPE_MP3, MP3 Decoder DMO, CLSID_CMP3DecMediaObject
MEDIASUBTYPE_MPEG1Payload, MPEG Video Decoder, CLSID_CMpegVideoCodec
MEDIASUBTYPE_MPEG1Packet, MPEG Video Decoder, CLSID_CMpegVideoCodec
{6C737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64687664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
MEDIASUBTYPE_MJPG, MJPEG Decompressor, CLSID_MjpegDec
{20637664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
MEDIASUBTYPE_MPEG1AudioPayload, MPEG Audio Decoder, CLSID_CMpegAudioCodec
WMMEDIASUBTYPE_WMSP2, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
WMMEDIASUBTYPE_WMSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
Media Foundation File Versions
mfcore.dll, 10.00.19041.2965
mfreadwrite.dll, 10.00.19041.0746
mfcaptureengine.dll, 10.00.19041.0906
mfsensorgroup.dll, 10.00.19041.2673
windows.media.dll, 10.00.19041.2075
frameserver.dll, 10.00.19041.2673
frameserverclient.dll, 10.00.19041.2673
Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms]
<category>:
<transform friendly name>, <transform CLSID>, <flags>, [<merit>, ]<file name>, <file version>
Video Decoders:
NVIDIA MJPEG Video Decoder MFT, {70F36578-2741-454F-B494-E8563DDD1CB4}, 0x4, 8, nvDecMFTMjpegx.dll, 31.00.0015.3203
Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}, 0x1, msmpeg2vdec.dll, 10.00.19041.2965
DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}, 0x1, mfdvdec.dll, 10.00.19041.0001
Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT, 0x1, mp4sdecd.dll, 10.00.19041.1706
Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT, 0x1, msmpeg2vdec.dll, 10.00.19041.2965
WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject, 0x1, wmvsdecd.dll, 10.00.19041.0001
WMVideo Decoder MFT, CLSID_CWMVDecMediaObject, 0x1, wmvdecod.dll, 10.00.19041.2311
MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}, 0x1, mfmjpegdec.dll, 10.00.19041.1348
Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject, 0x1, mp43decd.dll, 10.00.19041.1165
Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject, 0x1, mpg4decd.dll, 10.00.19041.1165
HEIFImageExtension
VP9VideoExtensionDecoder
WebpImageExtension
Video Encoders:
NVIDIA H.264 Encoder MFT, {60F44560-5A20-4857-BFEF-D29773CB8040}, 0x4, 8, nvEncMFTH264x.dll, 31.00.0015.3203
NVIDIA HEVC Encoder MFT, {966F107C-8EA2-425D-B822-E4A71BEF01D7}, 0x4, 8, nvEncMFThevcx.dll, 31.00.0015.3203
H264 Encoder MFT, {6CA50344-051A-4DED-9779-A43305165E35}, 0x1, mfh264enc.dll, 10.00.19041.1806
WMVideo8 Encoder MFT, CLSID_CWMVXEncMediaObject, 0x1, wmvxencd.dll, 10.00.19041.0867
H263 Encoder MFT, {BC47FCFE-98A0-4F27-BB07-698AF24F2B38}, 0x1, mfh263enc.dll, 10.00.19041.0001
WMVideo9 Encoder MFT, CLSID_CWMV9EncMediaObject, 0x1, wmvencod.dll, 10.00.19041.0001
Microsoft MPEG-2 Video Encoder MFT, {E6335F02-80B7-4DC4-ADFA-DFE7210D20D5}, 0x2, msmpeg2enc.dll, 10.00.19041.2546
HEIFImageExtension
VP9VideoExtensionEncoder
Video Effects:
Frame Rate Converter, CLSID_CFrameRateConvertDmo, 0x1, mfvdsp.dll, 10.00.19041.0746
Resizer MFT, CLSID_CResizerDMO, 0x1, vidreszr.dll, 10.00.19041.2604
VideoStabilization MFT, {51571744-7FE4-4FF2-A498-2DC34FF74F1B}, 0x1, MSVideoDSP.dll, 10.00.19041.0746
Color Control, CLSID_CColorControlDmo, 0x1, mfvdsp.dll, 10.00.19041.0746
Color Converter MFT, CLSID_CColorConvertDMO, 0x1, colorcnv.dll, 10.00.19041.2604
Video Processor:
Microsoft Video Processor MFT, {88753B26-5B24-49BD-B2E7-0C445C78C982}, 0x1, msvproc.dll, 10.00.19041.1949
Audio Decoders:
Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}, 0x1, DolbyDecMFT.dll, 10.00.19041.2913
MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}, 0x1, MSAMRNBDecoder.dll, 10.00.19041.0001
WMAudio Decoder MFT, CLSID_CWMADecMediaObject, 0x1, WMADMOD.DLL, 10.00.19041.1288
Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT, 0x1, MSAudDecMFT.dll, 10.00.19041.1865
A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}, 0x1, mfcore.dll, 10.00.19041.2965
GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}, 0x1, mfcore.dll, 10.00.19041.2965
WMAPro over S/PDIF MFT, CLSID_CWMAudioSpdTxDMO, 0x1, WMADMOD.DLL, 10.00.19041.1288
Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}, 0x1, MSOpusDecoder.dll, 10.00.19041.0746
Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}, 0x1, MSFlacDecoder.dll, 10.00.19041.1566
Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}, 0x1, MSAudDecMFT.dll, 10.00.19041.1865
WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject, 0x1, WMSPDMOD.DLL, 10.00.19041.0001
G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}, 0x1, mfcore.dll, 10.00.19041.2965
IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}, 0x1, mfcore.dll, 10.00.19041.2965
MP3 Decoder MFT, CLSID_CMP3DecMediaObject, 0x1, mp3dmod.dll, 10.00.19041.0001
Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}, 0x1, MSAlacDecoder.dll, 10.00.19041.0746
ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}, 0x1, mfcore.dll, 10.00.19041.2965
Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}, 0x1, mfaudiocnv.dll, 10.00.19041.0746
DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}, 0x1, mfaudiocnv.dll, 10.00.19041.0746
Audio Encoders:
LPCM DVD-Audio MFT, {068A8476-9229-4CC0-9D49-2FC699DCD30A}, 0x1, mfaudiocnv.dll, 10.00.19041.0746
MP3 Encoder ACM Wrapper MFT, {11103421-354C-4CCA-A7A3-1AFF9A5B6701}, 0x1, mfcore.dll, 10.00.19041.2965
Microsoft FLAC Audio Encoder MFT, {128509E9-C44E-45DC-95E9-C255B8F466A6}, 0x1, MSFlacEncoder.dll, 10.00.19041.0746
WM Speech Encoder DMO, CLSID_CWMSPEncMediaObject2, 0x1, WMSPDMOE.DLL, 10.00.19041.0508
MS AMRNB Encoder MFT, {2FAE8AFE-04A3-423A-A814-85DB454712B0}, 0x1, MSAMRNBEncoder.dll, 10.00.19041.0001
Microsoft MPEG-2 Audio Encoder MFT, {46A4DD5C-73F8-4304-94DF-308F760974F4}, 0x1, msmpeg2enc.dll, 10.00.19041.2546
WMAudio Encoder MFT, CLSID_CWMAEncMediaObject, 0x1, WMADMOE.DLL, 10.00.19041.0508
Microsoft AAC Audio Encoder MFT, {93AF0C51-2275-45D2-A35B-F2BA21CAED00}, 0x1, mfAACEnc.dll, 10.00.19041.0001
Microsoft ALAC Audio Encoder MFT, {9AB6A28C-748E-4B6A-BFFF-CC443B8E8FB4}, 0x1, MSAlacEncoder.dll, 10.00.19041.0746
Microsoft Dolby Digital Encoder MFT, {AC3315C9-F481-45D7-826C-0B406C1F64B8}, 0x1, msac3enc.dll, 10.00.19041.0001
Audio Effects:
AEC, CLSID_CWMAudioAEC, 0x1, mfwmaaec.dll, 10.00.19041.0001
Resampler MFT, CLSID_CResamplerMediaObject, 0x1, resampledmo.dll, 10.00.19041.0001
Multiplexers:
Microsoft MPEG2 Multiplexer MFT, {AB300F71-01AB-46D2-AB6C-64906CB03258}, 0x2, mfmpeg2srcsnk.dll, 10.00.19041.2788
Others:
Microsoft H264 Video Remux (MPEG2TSToMP4) MFT, {05A47EBB-8BF0-4CBF-AD2F-3B71D75866F5}, 0x1, msmpeg2vdec.dll, 10.00.19041.2965
Media Foundation Enabled Hardware Categories
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\HardwareMFT]
EnableDecoders = 1
EnableEncoders = 1
Media Foundation Byte Stream Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\ByteStreamHandlers]
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\Preferred]
<file ext. or MIME type>, <handler CLSID>, <brief description>[, Preferred]
.3g2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.ac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.adt, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.am?, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler
.amr, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler, Preferred
.asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
.dvr-ms, {A8721937-E2FB-4D7A-A9EE-4EB08C890B6E}, MF SBE Source ByteStreamHandler
.dvr-ms, {65964407-A5D8-4060-85B0-1CCD63F768E2}, dvr-ms Byte Stream Handler, Preferred
.ec3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
.m2t, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m2ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mk3d, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mka, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mks, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mkv, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mov, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp2v, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mpg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.nsc, {B084785C-DDE0-4D30-8CA8-05A373E185BE}, NSC Byte Stream Handler, Preferred
.sami, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.smi, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.tod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.uvu, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.vob, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
.weba, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
.webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
.wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wtv, {65964407-A5D8-4060-85B0-1CCD63F768E2}, WTV Byte Stream Handler, Preferred
audio/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/aacp, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/eac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
audio/L16, {3FFB3B8C-EB99-472B-8902-E1C1B05F07CF}, LPCM Byte Stream Handler, Preferred
audio/mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/MP4A-LATM, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/vnd.dlna.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/vnd.dolby.dd-raw, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
audio/webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
audio/x-aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/x-flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
audio/x-m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
audio/x-mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-ms-wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
audio/x-wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
video/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/vnd.dece.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/vnd.dlna.mpeg-tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
video/x-m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
video/x-ms-asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
Media Foundation Scheme Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\SchemeHandlers]
<URL type>, <handler CLSID>, <brief description>[, Preferred]
file:, {477EC299-1421-4BDD-971F-7CCB933F21AD}, File Scheme Handler, Preferred
http:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler
http:, {9EC4B4F9-3029-45AD-947B-344DE2A249E2}, Urlmon Scheme Handler
http:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpd:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler, Preferred
https:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpsd:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcast:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcrecv:, {FA6D33D4-9405-4BA5-9983-12604AC8E77A}, Miracast Sink Scheme Handler, Preferred
mms:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
ms-appdata:, {CFC81939-3886-4ACF-9692-DA58037AE716}, MsAppData Scheme Handler, Preferred
ms-appx-web:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppxWeb Scheme Handler, Preferred
ms-appx:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppx Scheme Handler, Preferred
ms-winsoundevent:, {F79A6BF9-7415-4CF3-AE10-4559509ABC3C}, Sound Event Scheme Handler, Preferred
rtsp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtsps:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
sdp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
Preferred Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\Preferred]
<media subtype GUID>, [<transform friendly name>, ]<transform CLSID>
{EB27CEC4-163E-4CA3-8B74-8E25F91B517E}, Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}
{E06D802C-DB46-11CF-B4D1-00805F6CBBEA}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MFVideoFormat_MPEG2, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MEDIASUBTYPE_DOLBY_DDPLUS, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
{A61AC364-AD0E-4744-89FF-213CE0DF8804}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{A2E58EB7-0FA9-48BB-A40C-FA0E156D0645}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{73616D72-767A-494D-B478-F29D25DC9037}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
MEDIASUBTYPE_mp4s, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_DVSL, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVSD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVHD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{63616C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}
MFVideoFormat_MP4V, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_MP4S, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{53314356-0000-0010-8000-00AA00389B71}, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MJPG, MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}
MEDIASUBTYPE_WMVA, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{3F40F4F0-5622-4FF8-B6D8-A17A584BEE5E}, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MEDIASUBTYPE_mpg4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_H264, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MFVideoFormat_WMV3, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{33363248-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_mp43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MFVideoFormat_MP43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_WMV2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS2, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_M4S2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_WVP2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_WMV1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS1, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_MPG1, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MFVideoFormat_WVC1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_DVC, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{0000F1AC-0000-0010-8000-00AA00389B71}, Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}
{00007361-0000-0010-8000-00AA00389B71}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
{0000704F-0000-0010-8000-00AA00389B71}, Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}
{00006C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}
{00002001-0000-0010-8000-00AA00389B71}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{00002000-0000-0010-8000-00AA00389B71}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MFAudioFormat_AAC, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_ADTS, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_WMAudio_Lossless, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV9, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV8, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_MP3, MP3 Decoder MFT, CLSID_CMP3DecMediaObject
MFAudioFormat_MPEG, Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}
{00000031-0000-0010-8000-00AA00389B71}, GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}
{00000011-0000-0010-8000-00AA00389B71}, IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}
KSDATAFORMAT_SUBTYPE_MULAW, G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}
{00000006-0000-0010-8000-00AA00389B71}, A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}
KSDATAFORMAT_SUBTYPE_ADPCM, ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}
MFAudioFormat_MSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
Disabled Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\DoNotUse]
<transform CLSID>
Disabled Media Sources
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\DoNotUse]
<media source CLSID>
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
Quality Flags: 2576
Enabled:
Force throttling
Allow half deinterlace
Allow scaling
Decode Power Usage: 100
Balanced Flags: 1424
Enabled:
Force throttling
Allow batching
Force half deinterlace
Force scaling
Decode Power Usage: 50
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Decode Power Usage: 0
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
nt!_WHEA_ERROR_RECORD structure that describes the error condition. Try !errrec Address of the nt!_WHEA_ERROR_RECORD structure to get more details.
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: ffff9007347b7028, Address of the nt!_WHEA_ERROR_RECORD structure.
Arg3: 00000000bc000800, High order 32-bits of the MCi_STATUS value.
Arg4: 0000000001010135, Low order 32-bits of the MCi_STATUS value.
Debugging Details:
*** Either you specified an unqualified symbol, or your debugger ***
*** doesn't have full symbol information. Unqualified symbol ***
*** resolution is turned off by default. Please either specify a ***
*** fully qualified symbol module!symbolname, or enable resolution ***
*** of unqualified symbols by typing ".symopt- 100". Note that ***
*** enabling unqualified symbol resolution with network symbol ***
*** server shares in the symbol path may cause the debugger to ***
*** appear to hang for long periods of time when an incorrect ***
*** symbol name is typed or the network symbol server is down. ***
*** For some commands to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: hal!_WHEA_PROCESSOR_GENERIC_ERROR_SECTION ***
*** work. ***
KEY_VALUES_STRING: 1
Key : Analysis.CPU.mSec
Value: 1359
Key : Analysis.Elapsed.mSec
Value: 4154
Key : Analysis.IO.Other.Mb
Value: 2
Key : Analysis.IO.Read.Mb
Value: 0
Key : Analysis.IO.Write.Mb
Value: 18
Key : Analysis.Init.CPU.mSec
Value: 328
Value: 9428
Value: 85
Key : Bugcheck.Code.LegacyAPI
Value: 0x124
Key : Bugcheck.Code.TargetModel
Value: 0x124
Key : Failure.Bucket
Value: 0x124_0_AuthenticAMD_PROCESSOR__UNKNOWN_IMAGE_AuthenticAMD.sys
Key : Failure.Hash
Value: {035dcc87-485b-74b3-1c1b-ee50cb0c2865}
Key : WER.OS.Branch
Value: vb_release
Key : WER.OS.Version
Value: 10.0.19041.1
BUGCHECK_CODE: 124
BUGCHECK_P1: 0
BUGCHECK_P2: ffff9007347b7028
BUGCHECK_P3: bc000800
BUGCHECK_P4: 1010135
FILE_IN_CAB: 060723-5078-01.dmp
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: Diablo IV.exe
STACK_TEXT:
ffffba00`aa3e0938 fffff803`55eb785a : 00000000`00000124 00000000`00000000 ffff9007`347b7028 00000000`bc000800 : nt!KeBugCheckEx
ffffba00`aa3e0940 fffff803`53d115b0 : 00000000`00000000 ffff9007`347b7028 ffff9007`332ff5d0 ffff9007`347b7028 : nt!HalBugCheckSystem+0xca
ffffba00`aa3e0980 fffff803`55fb9b3e : 00000000`00000000 ffffba00`aa3e0a29 ffff9007`347b7028 ffff9007`332ff5d0 : PSHED!PshedBugCheckSystem+0x10
ffffba00`aa3e09b0 fffff803`55eb9181 : ffff9007`3885b900 ffff9007`3885b900 ffff9007`332ff620 ffff9007`332ff5d0 : nt!WheaReportHwError+0x46e
ffffba00`aa3e0a90 fffff803`55eb94f3 : 00000000`00000008 ffff9007`332ff620 ffff9007`332ff5d0 00000000`00000008 : nt!HalpMcaReportError+0xb1
ffffba00`aa3e0c00 fffff803`55eb93d0 : ffff9007`333285c0 00000000`00000000 ffffba00`aa3e0e00 00000000`00000000 : nt!HalpMceHandlerCore+0xef
ffffba00`aa3e0c50 fffff803`55eb8915 : ffff9007`333285c0 ffffba00`aa3e0ef0 00000000`00000000 00000000`00000000 : nt!HalpMceHandler+0xe0
ffffba00`aa3e0c90 fffff803`55ebb0d5 : ffff9007`333285c0 00000000`00000000 00000000`00000000 00000000`00000000 : nt!HalpHandleMachineCheck+0xe9
ffffba00`aa3e0cc0 fffff803`55f10bf9 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!HalHandleMcheck+0x35
ffffba00`aa3e0cf0 fffff803`55e0c8ba : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiHandleMcheck+0x9
ffffba00`aa3e0d20 fffff803`55e0c577 : 00000000`00000000 00000000`00000000 000001bc`b1dde000 00000000`00000000 : nt!KxMcheckAbort+0x7a
ffffba00`aa3e0e60 00007ff6`e1b946bd : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiMcheckAbort+0x277
00000062`49bfeac0 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ff6`e1b946bd
MODULE_NAME: AuthenticAMD
IMAGE_NAME: AuthenticAMD.sys
STACK_COMMAND: .cxr; .ecxr ; kb
FAILURE_BUCKET_ID: 0x124_0_AuthenticAMD_PROCESSOR__UNKNOWN_IMAGE_AuthenticAMD.sys
OS_VERSION: 10.0.19041.1
BUILDLAB_STR: vb_release
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {035dcc87-485b-74b3-1c1b-ee50cb0c2865}
Followup: MachineOwner
PnpActivityId : {00000000-0000-0000-0000-000000000000}
PnpActivityTime : 133306297699850138
PnpEventInformation: 3
PnpEventInProgress : 0
PnpProblemCode : 24
PnpVetoType : 0
DeviceId : USB\VID_1EA7&PID_0064\6&c1a2e2f&0&3
VetoString :
Arguments:
Arg2: ffff9e01cf879028, Address of the nt!_WHEA_ERROR_RECORD structure.
Debugging Details:
*** work. ***
*** work. ***
Value: 1374
Value: 3324
Value: 2
Value: 0
Value: 18
Value: 327
Value: 12113
Value: 85
Value: 0x124
Value: 0x124
Key : Failure.Hash
Key : WER.OS.Branch
Value: vb_release
Value: 10.0.19041.1
BUGCHECK_CODE: 124
BUGCHECK_P1: 0
BUGCHECK_P2: ffff9e01cf879028
FILE_IN_CAB: 060723-4968-01.dmp
BLACKBOXWINLOGON: 1
STACK_TEXT:
ffffc380`3a11b938 fffff805`0a2b785a : 00000000`00000124 00000000`00000000 ffff9e01`cf879028 00000000`bc000800 : nt!KeBugCheckEx
ffffc380`3a11b940 fffff805`088215b0 : 00000000`00000000 ffff9e01`cf879028 ffff9e01`ca5d0d50 ffff9e01`cf879028 : nt!HalBugCheckSystem+0xca
ffffc380`3a11b980 fffff805`0a3b9b3e : 00000000`00000000 ffffc380`3a11ba29 ffff9e01`cf879028 ffff9e01`ca5d0d50 : PSHED!PshedBugCheckSystem+0x10
ffffc380`3a11b9b0 fffff805`0a2b9181 : ffff9e01`cf2bfbd0 ffff9e01`cf2bfbd0 ffff9e01`ca5d0da0 ffff9e01`ca5d0d50 : nt!WheaReportHwError+0x46e
ffffc380`3a11ba90 fffff805`0a2b94f3 : 00000000`00000004 ffff9e01`ca5d0da0 ffff9e01`ca5d0d50 00000000`00000004 : nt!HalpMcaReportError+0xb1
ffffc380`3a11bc00 fffff805`0a2b93d0 : ffff9e01`ca2f12e0 b60fc833`00000000 ffffc380`3a11be00 48006e43`d9058b48 : nt!HalpMceHandlerCore+0xef
ffffc380`3a11bc50 fffff805`0a2b8915 : ffff9e01`ca2f12e0 ffffc380`3a11bef0 00000000`00000000 1de8ca8b`49000000 : nt!HalpMceHandler+0xe0
ffffc380`3a11bc90 fffff805`0a2bb0d5 : ffff9e01`ca2f12e0 f08b4c10`eb002c79 85480845`8b480beb ed3245f0`450f4cc0 : nt!HalpHandleMachineCheck+0xe9
ffffc380`3a11bcc0 fffff805`0a310bf9 : 38778b4d`0d75f685 768b4c04`75f6854d 74c08409`46b60f40 4951747c`6e38445b : nt!HalHandleMcheck+0x35
ffffc380`3a11bcf0 fffff805`0a20c8ba : 44894800`00009096 9e90b70d`8d484024 89cb8b4c`14468bff 4838468b`48382444 : nt!KiHandleMcheck+0x9
ffffc380`3a11bd20 fffff805`0a20c577 : 00000000`00000000 00000000`00000000 0000015a`42cec5f8 00000000`00000000 : nt!KxMcheckAbort+0x7a
ffffc380`3a11be60 00007ff6`27078519 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiMcheckAbort+0x277
00000055`c70ff0c0 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ff6`27078519
OSNAME: Windows 10
We use cookies and similar technologies for the following purposes:
Do you accept cookies and these technologies?
