13 Mayıs 2025
Merhaba, ben Google clang ile A366B cihazıma KernelSU-Next derledim de Wi-Fi ve BT çalışmıyor. İlgili olan kişilerin yardımını istiyorum.
Derlediğim 190 GB dosya:
Kod:
hasan@fedora:~/a36_ksu_new$ ls -l
toplam 693044
lrwxrwxrwx. 1 hasan hasan        98 May 25 11:38 bazel-a36_ksu_new -> /home/hasan/a36_ksu_new/out/bazel/output_user_root/961813790adbed783396b2f5446979cb/execroot/_main
lrwxrwxrwx. 1 hasan hasan       125 May 25 11:38 bazel-bin -> /home/hasan/a36_ksu_new/out/bazel/output_user_root/961813790adbed783396b2f5446979cb/execroot/_main/bazel-out/k8-fastbuild/bin
lrwxrwxrwx. 1 hasan hasan       108 May 25 11:38 bazel-out -> /home/hasan/a36_ksu_new/out/bazel/output_user_root/961813790adbed783396b2f5446979cb/execroot/_main/bazel-out
lrwxrwxrwx. 1 hasan hasan       130 May 25 11:38 bazel-testlogs -> /home/hasan/a36_ksu_new/out/bazel/output_user_root/961813790adbed783396b2f5446979cb/execroot/_main/bazel-out/k8-fastbuild/testlogs
-rwxr-xr-x. 1 hasan hasan 100597760 Ağu 25  2025 boot.img
drwxr-xr-x. 1 hasan hasan        48 May 17 17:13 build
drwxr-xr-x. 1 hasan hasan      2298 May 24 13:04 common
drwxr-xr-x. 1 hasan hasan        76 May 17 17:11 common-modules
drwxr-xr-x. 1 hasan hasan       480 May 17 17:13 external
drwxr-xr-x. 1 hasan hasan        14 May 17 17:11 kernel
-rwxr-xr-x. 1 hasan hasan    943848 Oca  1  2108 magiskboot
lrwxrwxrwx. 1 hasan hasan        44 May 17 17:13 MODULE.bazel -> build/kernel/kleaf/bzlmod/bazel.MODULE.bazel
drwxr-xr-x. 1 hasan hasan        48 May 25 11:38 out
drwxr-xr-x. 1 hasan hasan       124 May 18 08:41 prebuilts
drwxr-xr-x. 1 hasan hasan        94 May 25 11:59 repack_area
drwxr-xr-x. 1 hasan hasan       182 May 24 19:14 SM-A366B
-rw-r--r--. 1 hasan hasan 608103519 May 17 17:03 SM-A366B.zip
drwxr-xr-x. 1 hasan hasan        28 May 17 17:13 tools
lrwxrwxrwx. 1 hasan hasan        34 May 17 17:13 WORKSPACE -> build/kernel/kleaf/bazel.WORKSPACE
lrwxrwxrwx. 1 hasan hasan        48 May 17 17:13 WORKSPACE.bzlmod -> build/kernel/kleaf/bzlmod/bazel.WORKSPACE.bzlmod
(İsteyen olursa diğer iptalli imajların dosyasını Drive'dan atabilirim)
Farklı gcc ile clang deneyin veya bunu deneyin.
Düzeltme: Cihaz "panic" vermeden açıldı ama Wi-Fi çalışmıyor. Android 15 6.6 clang'ı indirip yaptım (boot.img'yi ksu'ladım). ravindu644/Android-Kernel-Tutorials bu program da tam ne işe yarıyor? (Google Gemini'den yardım alıp bir de böyle deneyeyim.)
Açıklamaya bakarsanız kernel modüllerini yüklemeye zorluyor.
Yapay zekâya yazdım da bana bu cevabı verdi: Paylaştığınız bağlantıdaki GitHub deposu, hazır bir "tamir aracı" değildir. Bu, Android cihazlar için kendi özel çekirdeğinizi (kernel) nasıl derleyebileceğinizi öğreten bir eğitim rehberidir.
Boot.img sorun bu imaj (bu imajda root var ama Wi-Fi BT yok) ses, NFC, kamera falan çalışıyor. İlgili olan bir gönüllü varsa diğer (vaultkeeper, proca, vm-bootsys, vbmeta flag3 iptalli imajları da atabilirim)
Sorunu buldum galiba cihazın ana (her şey çalışan) kernel sürümü 6.6.46 clang derlenen sürüm ise 6.6.126 (sistem panic vermeden açılıyor ama Wi-Fi, BT gibi sürücüler yüklenmiyor) ses, kamera, sensörler, NFC gibi şeyler çalışıyor bunu işte clangdan 6.6.46 ya düşürmeyi denedim ama clang yine de güncelledi (6.6.126 yaptı) yani clang da commit ayarı tutmuyor clang ı nasıl birebir uyumlu 6.6.46 indirebilirim.
@smasnug bükücü, @Recep Baltaş eminim senin bu konuda yetkili arkadaşların vardır arkadaşlarını konuma yönlendirirsen sevinirim cihazın %95'ini tamamladım (tüm iptalli imajların Drive linki): A366B KERNELSU-NEXT - Google Drive
Başka Wi-Fi'yi çalıştırmanın taktiği var mı? 6.6.46 clang bulamıyorum ve 1 tane buldum, repo Sync ile çekmeye çalıştım, olmadı, çekemedim, "network" hatası veriyor (en güncel 6.6 clang'ı sorunsuz çekebilmiştim). İnternetimde sıkıntı, hat da sıkıntı. TTNET in vdsl hattı zaten dillerde Codelinaro diye Qualcomm'un modifiye edilmiş kernel platformu varmış fakat Android 15 6.6 SM-6375 kernel bulamadım (SM-6375 Qualcomm işlemcinin kodu). İşlemci:
Qualcomm Snapdragon 6S Gen 3 (SM6375) @Heribert Yavuz senin verdiğin repo işe yaramadı o nu denedim. samsung un kendi opensource si de çok eksik​
