DRIVER_POWER_STATE_FAILURE mavi ekran hatası
  • Konuyu başlatan Konuyu başlatan Qubit
  • Mesaj Mesaj 15
  • Görüntüleme Görüntüleme 666
Qubit
12 Haziran 2024
Uzun süre ardından yeni bir mavi ekran hatası aldım hata kodu DRIVER_POWER_STATE_FAILURE minidump dosyası aşağıdadır.
Minidump dosyası:
[CODE highlight="5"]DRIVER_POWER_STATE_FAILURE (9f)
A driver has failed to complete a power IRP within a specific time.
Arguments:
Arg1: 0000000000000003, A device object has been blocking an IRP for too long a time
Arg2: ffffaf03723fbe00, Physical Device Object of the stack
Arg3: fffff8012f874850, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the Functional Device Object of the stack
Arg4: ffffaf03713c6be0, The blocked IRP
[/CODE]
[CODE highlight="6"]0: kd> !devstack ffffaf03723fbe00
!DevObj !DrvObj !DevExt ObjectName
ffffaf03721cce00 \Driver\ksthunk ffffaf03721ccf50 InfoMask field not found for _OBJECT_HEADER at ffffaf03721ccdd0
ffffaf0372a62050 Unable to load image \SystemRoot\system32\drivers\RTKVHD64.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for RTKVHD64.sys
\Driver\IntcAzAudAddServiceffffaf0372a621a0 InfoMask field not found for _OBJECT_HEADER at ffffaf0372a62020
ffffaf03723fbe00 \Driver\HDAudBus ffffaf03721a2f70 Cannot read info offset from nt!ObpInfoMaskToOffset
!DevNode ffffaf0372a1f9a0 :
DeviceInst is "HDAUDIO\FUNC_01&VEN_10EC&DEV_0257&SUBSYS_17AA3887&REV_1000\5&6f105c0&0&0001"
ServiceName is "IntcAzAudAddService"
[/CODE]
Kod:
0: kd> lmvmRTKVHD64
Browse full module list
start end module name
fffff801`739e0000 fffff801`7411b000 RTKVHD64 T (no symbols)
 Loaded symbol image file: RTKVHD64.sys
 Image path: \SystemRoot\system32\drivers\RTKVHD64.sys
 Image name: RTKVHD64.sys
 Browse all global symbols functions data
 Timestamp: Tue May 19 12:48:47 2020 (5EC3AB7F)
 CheckSum: 0070747A
 ImageSize: 0073B000
 Translations: 0000.04b0 0000.04e4 0409.04b0 0409.04e4
 Information from resource tables:
Realtek ses sürücünü güncellemen gerekiyor: https://download.lenovo.com/pccbbs/mobiles/r29a107w.exe
Kod:
KERNEL_SECURITY_CHECK_FAILURE (139)
A kernel component has corrupted a critical data structure.  The corruption
could potentially allow a malicious user to gain control of this machine.
Arguments:
Arg1: 0000000000000004, The thread's stack pointer was outside the legal stack
    extents for the thread.
Arg2: fffffa88ae193d10, Address of the trap frame for the exception that caused the BugCheck
Arg3: fffffa88ae193c68, Address of the exception record for the exception that caused the BugCheck
Arg4: 0000000000000000, Reserved
Dosya biraz karmaşık açıkçası zira bu dosyada SEH kullanılarak yapılan bir istisna gönderimi sonrasında stack çözme işlemi sırasında bir yığın işaretçisinin bozulduğunu görüyoruz. Stack pointer corrupt normal bir durum değil ve geçersiz bellek erişiminden de ortaya çıkabiliyor. ARG1 zaten burdaki geçersiz bellek erişimini işaret ediyor. Sonuç olarak bu arayış sonrası istisnayı eşlemek için bir fastfail buluyor.
[CODE highlight="7,11"]15: kd> k
# Child-SP RetAddr Call Site
00 fffffa88`ae1939e8 fffff804`0ea123a9 nt!KeBugCheckEx
01 fffffa88`ae1939f0 fffff804`0ea12950 nt!KiBugCheckDispatch+0x69
02 fffffa88`ae193b30 fffff804`0ea107f2 nt!KiFastFailDispatch+0xd0
03 fffffa88`ae193d10 fffff804`0ea9d725 nt!KiRaiseSecurityCheckFailure+0x332
04 fffffa88`ae193ea0 fffff804`0e95f761 nt!RtlpGetStackLimitsEx+0x13ef55
05 fffffa88`ae193ed0 fffff804`0e95d846 nt!RtlDispatchException+0xe1
06 fffffa88`ae1940f0 fffff804`0ea124ec nt!KiDispatchException+0x186
07 fffffa88`ae194920 fffff804`0ea0bf78 nt!KiExceptionDispatch+0x12c
08 fffffa88`ae194b00 00007ffe`c76ca23c nt!KiInvalidOpcodeFault+0x338
09 000000e7`463fe2a0 00000000`00000000 0x00007ffe`c76ca23c
[/CODE]
Asıl hata, nt!KiInvalidOpcodeFault+0x338 hatasıdır ama stack kısmıyla devam ettiğimiz zaman aslında meselenin nt!KiExceptionDispatch+0x12c ile başladığını görüyoruz, bu da çoğunlukla gönderilen istisnayı işlemek için uygun bir sonuç bulmaktan sorumludur. (= nt!KiRaiseSecurityCheckFailure+0x332) Yaptığı ilk şeylerden biri, meydana gelen istisnaların sayısını arttırması olarak biliniyor.
Bu işi kontrol altında tutmak için, bir sonuç bulunduğunda Stack çözme çağrısı kullanılarak çözülüyor ve bu da nt!RtlpGetStackLimitsEx+0x13ef55'i çağırıyoe. Sonra sadece PCR altındaki TIB yapısını inceleyip ve ardından yığın sınırını ve taban değerlerini geri düzeltiyor.
Kod:
15: kd> dt _NT_TIB fffff00000000
win32k!_NT_TIB
   +0x000 ExceptionList    : 0x00000001`c0000409 _EXCEPTION_REGISTRATION_RECORD
   +0x008 StackBase        : (null)
   +0x010 StackLimit       : 0xfffff804`0ea9d725 Void
   +0x018 SubSystemTib     : 0xffff9b01`00000001 Void
   +0x020 FiberData        : 0x00000000`00000004 Void
   +0x020 Version          : 4
   +0x028 ArbitraryUserPointer : 0xfffffa88`ae194070 Void
   +0x030 Self             : 0xfffffa88`ae1940e0 _NT_TIB
Burdaki mevzunun direkt bir sonucu olmasa da donanımsal olduğunu düşünüyorum. Yine de:
Kod:
01 fffffa8'8ae833db8  fffff8043db0175b  dxgmms2!VidMmReferenceWrittenPrimaries+0x1b
*** WARNING: Unable to verify timestamp for amdkmdag.sys <
02 ffffd98'67f6a5d98  ffffd9868c7a2860    \Program Files\WindowsApps\E046963F.LenovoCompanion_10.2403.25.0_x64__k1h2ywk149...""
03 ffffd98'67f6ab158  ffffd98689079080    \Program Files\BraveSoftware\Brave-Browser\Application\brave.exe""
04 ffffd98'67fe0ca60  006e00550063006f    ocUnique
AMD kartının sürücüsünü güncellemeyi öncelik iş olarak yapabilirsin. Şu kısa testi daha önce yapmadıysan sonuçlarını da paylaş. OCCT ile 1 saatlik bir test de yapabilirsin.
Bir hata daha aldım minidump linki aşağıdadır ve ne hikmetse ne çözümü denersem deneyeyim dönüp dolaşıp aynı hata geliyor sürekli.
Minidump linki:
Windows testini yaptım herhangi bir hata vermedi.
Konuya atılan mesajlara ait bir bildirim almamıştım. Yeni görüyorum, ben hala sorunun işlemci tarafından aşerdiğini düşünüyorum ama kafamı kurcalayan sorun Linux'da ciddi bir sorun yaşamamış olman. İşlemciye sağlam bir UV ayarı çekip kontrole alabilirsin. > ThorttleStop
Bende konuya uzun süre mesaj atmadığınız için yeni konu açmıştım 3 tane minidump dosyası var orada bir kontrol yapabilir misiniz onlara da.
Dosyalarına baktım, karışık dosyalar var. 1 tanesi bu konu içerisinde bahsettiğim dosyanın aynısı.
Kod:
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e)
This is a very common BugCheck. Usually the exception address pinpoints
the driver/function that caused the problem. Always note this address
as well as the link date of the driver/image that contains this address.
Some common problems are exception code 0x80000003. This means a hard
coded breakpoint or assertion was hit, but this system was booted
/NODEBUG. This is not supposed to happen as developers should never have
hardcoded breakpoints in retail code, but ...
If this happens, make sure a debugger gets connected, and the
system is booted /DEBUG. This will let us see why this breakpoint is
happening.
Arguments:
Arg1: ffffffffc0000005, < İstisna türü
Arg2: fffff8053fe358d0, < Çökmenin meydana geldiği adres
Arg3: ffff808137d10668, < İstisna kaydı
Arg4: ffffb78191cf6920, < Bağlam kaydı
Kod:
EXCEPTION_RECORD: ffff808137d10668 -- (.exr 0xffff808137d10668)
ExceptionAddress: fffff8053fe358d0 (nt!KiExitDispatcher+0x00000000000000c0)
 ExceptionCode: c0000005 (Access violation)
 ExceptionFlags: 00000000
NumberParameters: 2
 Parameter[0]: ffffffffffffffff
 Parameter[1]: 0000000000000000
Attempt to unknown address 0000000000000000
İstisna kaydı çökmenin nedenini söylüyor, Bu işlev, bir iş parçacığı ya da işlemden çıkılırken ve çıkan iş parçacığı ya da işlemle ilişkili kaynaklar temizlenirken sistem mevcut bellek bölgesinin dışına erişiyor ve StackFault ile çöküyor.
Kod:
14: kd> k
00 ffffb781`91cf60e8 fffff805`4001bae4     nt!KeBugCheckEx
01 ffffb781`91cf60f0 fffff805`3ffd0532     nt!PspSystemThreadStartup$filt$0+0x44
02 ffffb781`91cf6130 fffff805`40008692     nt!_C_specific_handler+0xa2
03 ffffb781`91cf61a0 fffff805`3ff5f917     nt!RtlpExecuteHandlerForException+0x12
04 ffffb781`91cf61d0 fffff805`3ff5d846     nt!RtlDispatchException+0x297
05 ffffb781`91cf68f0 fffff805`3fffecb2     nt!KiDispatchException+0x186
06 ffffb781`91cf6fb0 fffff805`3fffec80     nt!KxExceptionDispatchOnExceptionStack+0x12
07 ffff8081`37d10528 fffff805`400124e5     nt!KiExceptionDispatchOnExceptionStackContinue
08 ffff8081`37d10530 fffff805`4000d580     nt!KiExceptionDispatch+0x125
09 ffff8081`37d10710 fffff805`3fe358d0     nt!KiStackFault+0x340 < Çökme
0a ffff8081`37d108a0 ffff8f02`b69e40c0     nt!KiExitDispatcher+0xc0 < Çökmenin yaşandığı an
0b ffff8081`37d10910 ffff8f02`b69e4740     0xffff8f02`b69e40c0
0c ffff8081`37d10918 000001e7`ead30000     0xffff8f02`b69e4740
0d ffff8081`37d10920 00000000`00000000     0x000001e7`ead30000 < User-Mode üzerinden gelen bir çağrı
İşlemci, bir işlem mevcut yığın sınırlarının ötesinde belleğe erişmeye çalıştığında veya yığını içeren yasadışı bir bellek erişimi olduğunda bir Stack Fault'u algılıyor. Ardından yığın hatası çözülebiliyorsa (örneğin, yığını genişleterek), mevcut handler bunu yapar ve iş parçacığının yürütmeye devam etmesine izin verir. Hata çözülemezse (Sistemin geçersiz bellek erişimi yapıyor.) handler daha fazla sistem kararsızlığını önlemek için hatalı iş parçacığını sonlandırır.
[CODE highlight="6"]14: kd> !handle
PROCESS ffff8f02b69e40c0
SessionId: none Cid: 0ca0 Peb: 00000000 ParentCid: 0004
DirBase: 3e5ad2000 ObjectTable: ffffe0861f8cbac0 HandleCount: <Data Not Accessible>
Image: MemCompression
Handle Error reading handle count.
[/CODE]
Burda ana sebep işlemciye ait bir vendor olarak görünüyor. Lakin çalışan işlem de bellek sıkıştırma ile ilgili. MediaTool ile yüklenilmiş bir Windows 10 22H2 sürümü mü kullanıyorsun? Açıkçası durum karışık. Öncelikle tekrardan Özel Görünümlerdeki olay raporlarını paylaşmanı isteyeceğim. RAM testinde sorun yok diyorsun. Daha sonra Prime95 ile Small FFTs ayarında 30 dakika bir test ve ardından Large ayarında ek bir 30 dakika test daha yapmanı da isteyeceğim > Rehber: Prime95 testi
[CODE highlight="2"]01 ffffbf81a'9ef5ce8 fffff805'206123a9 nt!KiBugCheckDispatch+0x69
02 ffffbf81a'9ef6210 \MediaCreationTool_22H2.
03 ffffbd857'2778b38 fffff805'20442d54 nt!SepNormalAccessCheck+0x204
[/CODE]
İlk önce Ventoy ile Windows 11 kurmuştum. Linux üzerinden ilk Windows 11'e geçmiştim, sonra fazla kaynak kullanımından ötürü Windows 10'a geçiş yaptım. O geçişte Media Creation Tool kullandım ancak herhangi bir USB'ye yazdırmadım direkt bu bilgisayarı yükselt seçeneğinden Windows 10 kurdum. Olay raporlarının linki aşağıdadır ve verdiğiniz testleri de yaptıktan sonra sonuçlarını paylaşacağım.
Link:
Dosyaya göz attım; çoğu uygulaman geçersiz bellek erişiminden dolayı kapanıyor olarak görünüyor. Bunun dışında bir hata kaydı almamış sistem ama bu durum bile şüpheli. Testlerden sonra sonuçları paylaşmanı bekliyorum. 16-16 her 2 test için tüm çekirdekleri benimle paylaş.
