Çözüldü dxgkrnl.sys ve Wdf01000.sys yüksek gecikme süreleri nasıl düşürülür?
15 Aralık 2023
Malatya
LatencyMon uygulamasını yaklaşık bir saat boyunca açık bıraktım ve aşağıdaki gibi sonuçlar çıktı. Wdf01000.sys ve dxgkrnl.sys en yüksek gecikmeye sahip ve sürekli anlık olarak yükseltip duruyordu. Bu iki sürücünün gecikmesini nasıl düşürebilirim? Calypto's Latency Guide kullanarak ortalama gecikmeyi düşürebildim fakat en yüksek gecikmeyi bir türlü düşüremedim.
_________________________________________________________________________________________________________
CONCLUSION
Your system appears to be suitable for handling real-time audio and other tasks without dropouts.
LatencyMon has been analyzing your system for 1:00:19 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: DESKTOP-IHV0JOL
OS version: Windows 11, 10.0, version 2009, build: 22631 (x64)
Hardware: MS-7C52, Micro-Star International Co., Ltd.
BIOS: 3.L0
CPU: AuthenticAMD AMD Ryzen 5 5500
Logical processors: 6
Processor groups: 1
Processor group size: 6
RAM: 16276 MB total
CPU SPEED
Reported CPU speed (WMI): 360 MHz
Reported CPU speed (registry): 3593 MHz
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs): 179.40
Average measured interrupt to process latency (µs): 4.815624
Highest measured interrupt to DPC latency (µs): 164.50
Average measured interrupt to DPC latency (µs): 1.659428
REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 97.569719
Driver with highest ISR routine execution time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Highest reported total ISR routine time (%): 0.030242
Driver with highest ISR total time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Total time spent in ISRs (%) 0.030242
ISR count (execution time <250 µs): 2416206
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-1000 µs): 0
ISR count (execution time 1000-2000 µs): 0
ISR count (execution time 2000-4000 µs): 0
ISR count (execution time >=4000 µs): 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs): 250.597272
Driver with highest DPC routine execution time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Highest reported total DPC routine time (%): 0.084663
Driver with highest DPC total execution time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Total time spent in DPCs (%) 0.13240
DPC count (execution time <250 µs): 6541494
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-10000 µs): 1
DPC count (execution time 1000-2000 µs): 0
DPC count (execution time 2000-4000 µs): 0
DPC count (execution time >=4000 µs): 0
REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count: msmpeng.exe
Total number of hard pagefaults 39767
Hard pagefault count of hardest hit process: 13351
Number of processes hit: 59
PER CPU DATA
CPU 0 Interrupt cycle time (s): 101.123854
CPU 0 ISR highest execution time (µs): 97.569719
CPU 0 ISR total execution time (s): 6.567601
CPU 0 ISR count: 2416176
CPU 0 DPC highest execution time (µs): 250.597272
CPU 0 DPC total execution time (s): 26.577738
CPU 0 DPC count: 5903994
CPU 1 Interrupt cycle time (s): 11.243070
CPU 1 ISR highest execution time (µs): 11.572502
CPU 1 ISR total execution time (s): 0.000305
CPU 1 ISR count: 30
CPU 1 DPC highest execution time (µs): 126.505984
CPU 1 DPC total execution time (s): 0.536942
CPU 1 DPC count: 197531
CPU 2 Interrupt cycle time (s): 3.450478
CPU 2 ISR highest execution time (µs): 0.0
CPU 2 ISR total execution time (s): 0.0
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 98.220985
CPU 2 DPC total execution time (s): 0.215907
CPU 2 DPC count: 65025
CPU 3 Interrupt cycle time (s): 12.008176
CPU 3 ISR highest execution time (µs): 0.0
CPU 3 ISR total execution time (s): 0.0
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 38.434734
CPU 3 DPC total execution time (s): 0.836731
CPU 3 DPC count: 243847
CPU 4 Interrupt cycle time (s): 7.697027
CPU 4 ISR highest execution time (µs): 0.0
CPU 4 ISR total execution time (s): 0.0
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 47.732814
CPU 4 DPC total execution time (s): 0.303013
CPU 4 DPC count: 77978
CPU 5 Interrupt cycle time (s): 5.800652
CPU 5 ISR highest execution time (µs): 0.0
CPU 5 ISR total execution time (s): 0.0
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 230.848873
CPU 5 DPC total execution time (s): 0.283685
CPU 5 DPC count: 53120
Bir sorun olduğunu düşünmüyorum açıkçası:
Sonunda yakalayabildim hocam. Özellikle oyundayken farklı bir takılmalar oluyordu, biraz önce Fortnite oynarken yakalayabildim. TCP/IP sürücüsü sorun çıkartıyormuş.
Your system seems to be having difficulty handling real-time audio and other tasks. You may experience drop outs, clicks or pops due to buffer underruns. One or more DPC routines that belong to a driver running in your system appear to be executing for too long. At least one detected problem appears to be network related. In case you are using a WLAN adapter, try disabling it to get better results. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:06:25 (h:mm:ss) on all processors.
Highest DPC routine execution time (µs): 1464.828277
Driver with highest DPC routine execution time: tcpip.sys - TCP/IP Driver, Microsoft Corporation
